cgma
00001 //------------------------------------------------------------------------- 00002 // Filename : FacetProjectTool.hpp 00003 // 00004 // Purpose : Project curve segments onto a facetted surface. 00005 // 00006 // Special Notes : Used for surface partitioning. 00007 // 00008 // Creator : Jason Kraftcheck 00009 // 00010 // Creation Date : 05/08/02 00011 //------------------------------------------------------------------------- 00012 00013 #ifndef FACET_PROJECT_TOOL_HPP 00014 #define FACET_PROJECT_TOOL_HPP 00015 00016 #include <vector> 00017 00018 #include "CubitDefines.h" 00019 #include "DLIList.hpp" 00020 00021 class PST_Edge; 00022 class PST_CoEdge; 00023 class PST_Face; 00024 class PST_Point; 00025 class PST_Entity; 00026 00027 class CubitVector; 00028 00034 class FacetProjectTool 00035 { 00036 public: 00037 00038 FacetProjectTool(); 00039 ~FacetProjectTool(); 00040 00092 CubitStatus project( 00093 DLIList<CubitVector*>& segments, // in 00094 const std::vector<double>& coordinates, // in 00095 const std::vector<int>& connections, // in 00096 std::vector<int>& duddedFacets, // out 00097 std::vector<int>& newFacets, // out 00098 std::vector<int>& newFacetsIndex, // out 00099 std::vector<double>& newPoints, // out 00100 std::vector<int>& edges, // out 00101 std::vector<int>& segmentPoints, // out 00102 const double *tolerance_length = NULL 00103 ); 00104 00105 void debug( DLIList<CubitVector*>& segments, 00106 std::vector<double>& coordinates, 00107 std::vector<int>& connections ); 00108 00109 protected: 00110 00111 void cleanup(); 00112 00113 PST_Point* project( const CubitVector& point, 00114 const double* tolerance_length = NULL ); 00115 //- Project a single point into the surface facetting. 00116 //- Returns resulting facet point. 00117 //- Used for creating point-curves on partition surfaces. 00118 00119 //- Use get_result_set(..) to get the results of the projection. 00120 00121 CubitStatus get_result_set( DLIList<PST_CoEdge*>& edges ); 00122 //- Get one of multiple possible sections of projected curve 00123 //- from the above project() method. Returns CUBIT_FAILURE 00124 //- when there are no more results available. 00125 00126 CubitStatus do_projection( const DLIList<CubitVector*>& segments , 00127 CubitBoolean& point_changed, 00128 const double *tolerance_length = NULL); 00129 //- Project a segmented curve onto the facetted surface. 00130 //- project(..) will return CUBIT_FAILURE if none of the 00131 //- segmentes projected onto the surface. 00132 //- Use get_result_set(..) to get the results of the projection. 00133 00134 CubitStatus project( PST_Point* &start, PST_Point* &end ); 00135 //- Given two points within the facet patch, project the 00136 //- connecting segment onto the facets. Assumes the 00137 //- projected segment will not intersect the boundary of 00138 //- the patch anywhere except the passed points. 00139 00140 PST_Face* closest_face( const CubitVector& position ); 00141 //- Find the facet for which the projection of the 00142 //- passed position onto the facet lies within the 00143 //- boundary of the facet and is closest to the passed 00144 //- position. May return NULL if the position projects 00145 //- into no facets. 00146 00147 PST_Edge* closest_edge( const CubitVector& position ); 00148 //- Find the edge for which the closest point on the line 00149 //- of the edge to the passed position lies within the 00150 //- bounded edge and is closest to the passed position. 00151 //- May return NULL if the projection of the position 00152 //- lies outside of all bounded edges. 00153 00154 PST_Point* closest_point( const CubitVector& position ); 00155 //- Find the point closest to the passed position. Does 00156 //- not check points on the boundary of the facet patch. 00157 //- Will return null if all points are on the boundary. 00158 00159 static bool project_to_face( PST_Face* face, 00160 const CubitVector& position, 00161 CubitVector& result ) ; 00162 //- Project the pasesd position onto the passed face. Returns 00163 //- false and does not change result if the projection of the 00164 //- point onto the plane of the face lies outside the face. 00165 00166 static bool inside_face( PST_Face* face, const CubitVector& position ); 00167 00168 PST_Point* insert_in_face( PST_Face* face, 00169 const CubitVector& position ); 00170 //- Insert a point in the interior of a triangle, splitting 00171 //- the triangle into three triangles. 00172 00173 PST_Point* split_edge( PST_Edge* edge, double t ); 00174 //- Split an edge, creating a new point and edge. Adjacent 00175 //- faces are split with an edge from the new point to 00176 //- the point opposite the original edge on the face. 00177 00178 static 00179 void closest_on_lines( const CubitVector& base1, 00180 const CubitVector& direction1, 00181 const CubitVector& base2, 00182 const CubitVector& direction2, 00183 double& t1, double& t2 ); 00184 //- Find the closest point on each of two skew lines to 00185 //- the other. Result is returned as fraction of the 00186 //- direction vector (from the base point) for each line. 00187 00188 static 00189 double closest_on_line( const CubitVector& base, 00190 const CubitVector& direction, 00191 const CubitVector& from_position ); 00192 //- Find the closest point on a line from the passed position. 00193 //- Returns result location as a multiple of the direction vector 00194 //- from the base point. 00195 00196 CubitStatus populate_data( const DLIList<PST_Face*>& facets ); 00197 //- Used to be the class constructor. Fills in the private data lists 00198 //- and sets marks on facet entities 00199 00200 static 00201 bool within_tolerance ( PST_Edge* edge, const CubitVector& point, double tolerance ); 00202 00203 //static 00204 CubitStatus next_around_point( PST_Point*& point, 00205 const CubitVector& segment_end, 00206 PST_Face*& closest_face, 00207 PST_Edge*& closest_edge, 00208 CubitBoolean & is_boundary_edge, 00209 PST_Edge *last_closest_edge); 00210 00211 private: 00212 00213 DLIList<PST_Face*> facetList; 00214 DLIList<PST_Edge*> edgeList; 00215 DLIList<PST_Point*> pointList; 00216 //- Lists of all entities in the facet patch 00217 00218 DLIList<PST_Point*> segPoints; 00219 //- List of facet points corresponding to input segment points. 00220 //- Some entries may be NULL. 00221 00222 DLIList<PST_Edge*> boundaryList; 00223 //- List of edges on the boundary of the facet patch 00224 00225 DLIList<PST_CoEdge*> imprintResult; 00226 //- List of resulting imprinted edges. 00227 00228 CubitStatus find_closest_int_point_with_boundary( 00229 CubitVector &start_pt, 00230 CubitVector &end_pt, 00231 CubitVector &closest_pt ); 00232 00233 int point_on_facets( 00234 CubitVector *pos, 00235 double tolerance_sq ); 00236 00237 void finalize_results(); 00238 }; 00239 00240 #endif 00241
