cgma
#include <VirtualQueryEngine.hpp>
Public Member Functions | |
| virtual int | curve_is_on_ignored_surface (Curve *curve, Surface *surf) |
| void | remove_virtual_geometry (RefEntity *entity_ptr, CubitBoolean all_children) |
| void | remove_virtual_geometry (Body *body, bool all_children) |
| void | remove_virtual_geometry (RefVolume *vol, bool all_children) |
| void | remove_virtual_geometry (RefFace *face) |
| void | register_attributes () |
| ~VirtualQueryEngine () | |
| virtual const std::type_info & | entity_type_info () const |
| const char * | modeler_type () |
| virtual int | get_major_version () |
| virtual int | get_minor_version () |
| virtual int | get_subminor_version () |
| virtual CubitString | get_engine_version_string () |
| virtual bool | is_intermediate_engine () |
| virtual CubitStatus | get_graphics (Surface *surface_ptr, GMem *gmem, std::vector< TopologyBridge * > &vertex_edge_to_point_vector, std::vector< std::pair< TopologyBridge *, std::pair< int, int > > > &facet_edges_on_curves, unsigned short normal_tolerance, double distance_tolerance, double max_edge_length) const |
| virtual CubitStatus | get_graphics (Surface *surface_ptr, GMem *gMem, unsigned short normal_tolerance, double distance_tolerance, double max_edge_length) const |
| virtual CubitStatus | get_graphics (Curve *curve_ptr, GMem *gMem, double angle_tolerance=0, double distance_tolerance=0, double max_edge_length=0) const |
| virtual CubitStatus | get_isoparametric_points (Surface *ref_face_ptr, int &nu, int &nv, GMem *&gMem) const |
| virtual CubitStatus | get_u_isoparametric_points (Surface *ref_face_ptr, double v, int &n, GMem *&gMem) const |
| virtual CubitStatus | get_v_isoparametric_points (Surface *ref_face_ptr, double u, int &n, GMem *&gMem) const |
| virtual CubitStatus | transform_vec_position (CubitVector const &position_vector, BodySM *OSME_ptr, CubitVector &transformed_vector) const |
| CubitStatus | translate (BodySM *body, const CubitVector &offset) |
| CubitStatus | rotate (BodySM *body, const CubitVector &axis, double angle) |
| CubitStatus | scale (BodySM *body, double factor) |
| CubitStatus | scale (BodySM *body, const CubitVector &factors) |
| CubitStatus | reflect (BodySM *body, const CubitVector &axis) |
| CubitStatus | restore_transform (BodySM *body) |
| CubitStatus | translate (GeometryEntity *ent, const CubitVector &offset) |
| CubitStatus | rotate (GeometryEntity *ent, const CubitVector &axis, double degrees) |
| CubitStatus | scale (GeometryEntity *ent, double factor) |
| CubitStatus | scale (GeometryEntity *ent, const CubitVector &factors) |
| CubitStatus | reflect (GeometryEntity *ent, const CubitVector &axis) |
| virtual CubitStatus | get_visible_entities (TopologyBridge *hidden_tb, DLIList< TopologyBridge * > &real_tbs) |
| virtual TopologyBridge * | get_visible_entity_at_point (TopologyBridge *hidden_tb, CubitVector *point) |
| CubitBoolean | virtuals_created () const |
| CubitBoolean | is_partition (RefEntity *ref_entity) |
| CubitStatus | get_sister_partitions (RefEntity *ref_entity, DLIList< RefEntity * > &sisters) |
| CubitStatus | sort_edges (DLIList< RefEdge * > &edge_list) const |
| virtual CubitStatus | get_underlying_curves (Curve *curve_ptr, DLIList< TopologyBridge * > &curve_list) |
| virtual CubitStatus | get_underlying_surfaces (Surface *surf_ptr, DLIList< TopologyBridge * > &surf_list) |
| virtual CubitStatus | get_underlying_bridges (TopologyBridge *bridge_ptr, DLIList< TopologyBridge * > &bridge_list) |
| virtual CubitBoolean | bodies_overlap (BodySM *body_ptr_1, BodySM *body_ptr_2) const |
| virtual CubitBoolean | volumes_overlap (Lump *lump1, Lump *lump2) const |
| virtual CubitStatus | get_intersections (Curve *curve, CubitVector &point1, CubitVector &point2, DLIList< CubitVector > &intersection_list, CubitBoolean bounded, CubitBoolean closest) |
| virtual CubitStatus | get_intersections (Curve *ref_edge1, Curve *ref_edge2, DLIList< CubitVector > &intersection_list, bool bounded=CUBIT_FALSE, bool closest=CUBIT_FALSE) |
| virtual CubitStatus | get_intersections (Curve *ref_edge, Surface *ref_face, DLIList< CubitVector > &intersection_list, bool bounded=CUBIT_FALSE) |
| virtual CubitStatus | entity_extrema (DLIList< GeometryEntity * > &ref_entity_list, const CubitVector *dir1, const CubitVector *dir2, const CubitVector *dir3, CubitVector &extrema, GeometryEntity *&extrema_entity_ptr) |
| virtual CubitStatus | entity_entity_distance (GeometryEntity *ref_entity_ptr1, GeometryEntity *ref_entity_ptr2, CubitVector &pos1, CubitVector &pos2, double &distance) |
Static Public Member Functions | |
| static VirtualQueryEngine * | instance () |
| static void | delete_instance () |
| static void | get_VEs (RefVolume *volume_ptr, DLIList< TopologyBridge * > &ve_list, CubitBoolean visible=CUBIT_FALSE, const CubitBoolean children_too=CUBIT_TRUE) |
| static void | get_VEs (RefFace *face_ptr, DLIList< TopologyBridge * > &ve_list, CubitBoolean visible=CUBIT_FALSE, const CubitBoolean children_too=CUBIT_TRUE) |
| static void | get_VEs (RefEdge *edge_ptr, DLIList< TopologyBridge * > &ve_list, CubitBoolean visible=CUBIT_FALSE, const CubitBoolean children_too=CUBIT_TRUE) |
| static void | get_VEs (RefVertex *vertex_ptr, DLIList< TopologyBridge * > &ve_list, CubitBoolean visible=CUBIT_FALSE, const CubitBoolean children_too=CUBIT_TRUE) |
| static void | get_VEs (TopologyEntity *te_ptr, DLIList< TopologyBridge * > &ve_list, CubitBoolean visible=CUBIT_FALSE, const CubitBoolean children_too=CUBIT_TRUE) |
| static CubitBoolean | has_virtual (TopologyEntity *entity) |
| static CubitBoolean | is_virtual (TopologyEntity *entity, const CubitBoolean children_too=CUBIT_FALSE) |
| static CubitBoolean | is_virtual (DLIList< Body * > &entity_list, const CubitBoolean children_too=CUBIT_FALSE) |
| static CubitBoolean | is_virtual (DLIList< RefEntity * > &entity_list, const CubitBoolean children_too=CUBIT_FALSE) |
| static CubitStatus | associate_curves (DLIList< Curve * > &target_set, RefEdge *edge_ptr, DLIList< Curve * > &reset_set) |
Static Public Attributes | |
| static const double | param_epsilon_fraction = 1000000 |
Protected Member Functions | |
| CubitStatus | get_composite_curve_facetting (CompositeCurve *ccurve_ptr, GMem *gMem, double angle_tolerance=0, double distance_tolerance=0, double max_edge_length=0) const |
| CubitStatus | get_partition_curve_facetting (PartitionCurve *pcurve_ptr, GMem *gMem, double angle_tolerance=0, double distance_tolerance=0, double max_edge_length=0) const |
| CubitStatus | get_composite_surface_facetting (CompositeSurface *surf_ptr, GMem *gMem, std::vector< TopologyBridge * > *vertex_edge_to_point_vector, std::vector< std::pair< TopologyBridge *, std::pair< int, int > > > *facet_edges_on_curves, unsigned short normal_tol, double absolute_tol, double longest_edge) const |
| CubitStatus | get_partition_surface_facetting (PartitionSurface *surf_ptr, GMem *gMem, std::vector< TopologyBridge * > *vertex_edge_to_point_vector, std::vector< std::pair< TopologyBridge *, std::pair< int, int > > > *facet_edges_on_curves, unsigned short normal_tol, double absolute_tol, double longest_edge) const |
| virtual CubitStatus | export_solid_model (DLIList< TopologyBridge * > &bridge_list, const char *file_name, Model_File_Type file_type, const CubitString &cubit_version, ModelExportOptions &export_options) |
| virtual CubitStatus | export_solid_model (DLIList< TopologyBridge * > &bridge_list, char *&p_buffer, int &n_buffer_size, bool b_export_buffer) |
| virtual CubitStatus | save_temp_geom_file (DLIList< TopologyBridge * > &bridge_list, const char *file_name, const CubitString &cubit_version, CubitString &created_file, CubitString &created_file_type) |
| virtual CubitStatus | import_solid_model (const char *file_name, Model_File_Type file_type, DLIList< TopologyBridge * > &imported_entities, ModelImportOptions &import_options) |
| virtual CubitStatus | import_solid_model (DLIList< TopologyBridge * > &imported_entities, const char *pBuffer, const int n_buffer_size) |
| virtual void | delete_solid_model_entities (DLIList< BodySM * > &) const |
| virtual CubitStatus | delete_solid_model_entities (BodySM *body_ptr) const |
| virtual CubitStatus | delete_solid_model_entities (Surface *surf_ptr) const |
| virtual CubitStatus | delete_solid_model_entities (Curve *curve_ptr) const |
| virtual CubitStatus | delete_solid_model_entities (TBPoint *point_ptr) const |
| virtual CubitStatus | fire_ray (CubitVector &origin, CubitVector &direction, DLIList< TopologyBridge * > &at_entity_list, DLIList< double > &ray_params, int max_hits, double ray_radius, DLIList< TopologyBridge * > *hit_entity_list=0) const |
| virtual double | get_sme_resabs_tolerance () const |
| virtual double | set_sme_resabs_tolerance (double new_resabs) |
| virtual CubitStatus | set_int_option (const char *opt_name, int val) |
| virtual CubitStatus | set_dbl_option (const char *opt_name, double val) |
| virtual CubitStatus | set_str_option (const char *opt_name, const char *val) |
Static Protected Attributes | |
| static VirtualQueryEngine * | instance_ = NULL |
Private Member Functions | |
| void | default_error_message (const char callers_name[]) const |
Static Private Attributes | |
| static const int | VGE_MAJOR_VERSION = 10 |
| static const int | VGE_MINOR_VERSION = 0 |
| static const int | VGE_SUBMINOR_VERSION = 0 |
Definition at line 66 of file VirtualQueryEngine.hpp.
Definition at line 109 of file VirtualQueryEngine.cpp.
// destroy_all_virtual_entities();
// if( virtual_entity_list_.size() )
// PRINT_WARNING("Not all virtual geometry has been removed. "
// "This is a bug (memory leak). Please report it.\n");
// assert( virtual_entity_list_.size() == 0 );
PartitionEngine::delete_instance();
CompositeEngine::delete_instance();
instance_ = NULL;
| VirtualQueryEngine::VirtualQueryEngine | ( | ) | [protected] |
Definition at line 814 of file VirtualQueryEngine.cpp.
assert( !instance_);
//Add the VirtualQueryEngine to the GeometryQueryTool's gqeList and
//set the VGE to the GQT's default engine.
//GeometryQueryTool::instance()->add_gqe(this);
//GeometryQueryTool::instance()->set_default_engine(this);
CompositeEngine::instance();
PartitionEngine::instance();
| static CubitStatus VirtualQueryEngine::associate_curves | ( | DLIList< Curve * > & | target_set, |
| RefEdge * | edge_ptr, | ||
| DLIList< Curve * > & | reset_set | ||
| ) | [static] |
| CubitBoolean VirtualQueryEngine::bodies_overlap | ( | BodySM * | body_ptr_1, |
| BodySM * | body_ptr_2 | ||
| ) | const [virtual] |
Implements GeometryQueryEngine.
Definition at line 2356 of file VirtualQueryEngine.cpp.
PartitionBody* partition_body1 = dynamic_cast<PartitionBody*>(body_ptr_1);
PartitionBody* partition_body2 = dynamic_cast<PartitionBody*>(body_ptr_2);
BodySM *body1 = body_ptr_1;
if( partition_body1 )
body1 = partition_body1->real_body();
BodySM *body2 = body_ptr_2;
if( partition_body2 )
body2 = partition_body2->real_body();
GeometryQueryEngine *gqe = body1->get_geometry_query_engine();
if( gqe != body2->get_geometry_query_engine() )
PRINT_ERROR("Volumes must be of the same type (, SolidWorks, etc) to\n"
"find if they overlap.\n");
return CUBIT_FALSE;
return gqe->bodies_overlap( body1, body2 );
| int VirtualQueryEngine::curve_is_on_ignored_surface | ( | Curve * | curve, |
| Surface * | surf | ||
| ) | [virtual] |
Reimplemented from GeometryQueryEngine.
Definition at line 1414 of file VirtualQueryEngine.cpp.
int i, ret = 0;
CompositeSurface *cs = dynamic_cast<CompositeSurface*>(surf);
if(cs && curve_in)
DLIList<Surface*> ignored_surfs;
cs->get_ignored_surfs(ignored_surfs);
for(i=ignored_surfs.size(); i>0 && !ret; i--)
Surface *surf = ignored_surfs.get_and_step();
DLIList<Curve*> crvs;
surf->curves(crvs);
if(crvs.is_in_list(curve_in))
ret = 1;
return ret;
| void VirtualQueryEngine::default_error_message | ( | const char | callers_name[] | ) | const [private] |
Definition at line 1346 of file VirtualQueryEngine.cpp.
PRINT_ERROR("A call was made to:\n");
PRINT_ERROR("VirtualQueryEngine::");
PRINT_ERROR("%s", callers_name);
PRINT_ERROR("\n");
PRINT_ERROR("Although this function is inhereted from GeometryQueryEngine\n");
PRINT_ERROR("it is not applicable or implememtend in VirtualQueryEngine.\n");
PRINT_ERROR("\nTHIS IS A BUG. This function should NEVER be called.\n");
PRINT_ERROR("\nThis function exists only because it is pure virtual in\n");
PRINT_ERROR("the abstract class GeometryQueryEngine, and must be\n");
PRINT_ERROR("defined in VirtualQueryEngine for the class to be\n");
PRINT_ERROR("instantiated.\n");
| void VirtualQueryEngine::delete_instance | ( | ) | [static] |
Definition at line 123 of file VirtualQueryEngine.cpp.
| void VirtualQueryEngine::delete_solid_model_entities | ( | DLIList< BodySM * > & | list | ) | const [protected, virtual] |
Definition at line 1876 of file VirtualQueryEngine.cpp.
for ( int i = list.size(); i--; )
delete_solid_model_entities( list.get_and_step() );
| CubitStatus VirtualQueryEngine::delete_solid_model_entities | ( | BodySM * | body_ptr | ) | const [protected, virtual] |
Definition at line 1884 of file VirtualQueryEngine.cpp.
CompositeBody* compbod = dynamic_cast<CompositeBody*>(bodysm);
if (compbod)
while (compbod->num_bodies())
BodySM* dead_body = compbod->get_body( compbod->num_bodies() - 1 );
dead_body->get_geometry_query_engine()->delete_solid_model_entities( dead_body );
CompositeEngine::instance().clean_out_deactivated_geometry();
return CUBIT_SUCCESS;
PartitionBody* bod = dynamic_cast<PartitionBody*>(bodysm);
if ( !bod )
return CUBIT_FAILURE;
PartitionEngine::instance().delete_solid_model_entities( bod, bodysm );
if ( bodysm ) {
bodysm->get_geometry_query_engine()->delete_solid_model_entities(bodysm);
| CubitStatus VirtualQueryEngine::delete_solid_model_entities | ( | Surface * | surf_ptr | ) | const [protected, virtual] |
Definition at line 1912 of file VirtualQueryEngine.cpp.
PartitionSurface* ps_ptr = dynamic_cast<PartitionSurface*>(surf_ptr);
CompositeSurface* cs_ptr = dynamic_cast<CompositeSurface*>(surf_ptr);
if (cs_ptr)
while(cs_ptr->num_surfs())
Surface* dead_surf = cs_ptr->get_surface(cs_ptr->num_surfs()-1);
dead_surf->get_geometry_query_engine()->delete_solid_model_entities(dead_surf);
else if( ps_ptr )
PartitionEngine::instance().delete_solid_model_entities( ps_ptr, surf_ptr );
if ( surf_ptr )
surf_ptr->get_geometry_query_engine()->delete_solid_model_entities(surf_ptr);
| CubitStatus VirtualQueryEngine::delete_solid_model_entities | ( | Curve * | curve_ptr | ) | const [protected, virtual] |
Definition at line 1939 of file VirtualQueryEngine.cpp.
CompositeCurve* cc_ptr = dynamic_cast<CompositeCurve*>(curve_ptr);
PartitionCurve* pc_ptr = dynamic_cast<PartitionCurve*>(curve_ptr);
if( cc_ptr )
while(cc_ptr->num_curves())
Curve* dead_curv = cc_ptr->get_curve(cc_ptr->num_curves()-1);
dead_curv->get_geometry_query_engine()->delete_solid_model_entities(dead_curv);
else if( pc_ptr )
PartitionEngine::instance().delete_solid_model_entities( pc_ptr, curve_ptr );
if ( curve_ptr )
curve_ptr->get_geometry_query_engine()->delete_solid_model_entities(curve_ptr);
| CubitStatus VirtualQueryEngine::delete_solid_model_entities | ( | TBPoint * | point_ptr | ) | const [protected, virtual] |
Definition at line 1965 of file VirtualQueryEngine.cpp.
| CubitStatus VirtualQueryEngine::entity_entity_distance | ( | GeometryEntity * | ref_entity_ptr1, |
| GeometryEntity * | ref_entity_ptr2, | ||
| CubitVector & | pos1, | ||
| CubitVector & | pos2, | ||
| double & | distance | ||
| ) | [virtual] |
Definition at line 1602 of file VirtualQueryEngine.cpp.
CompositeCurve *cc1 = dynamic_cast<CompositeCurve*>(ge1);
CompositeCurve *cc2 = dynamic_cast<CompositeCurve*>(ge2);
CompositeSurface *cs1 = dynamic_cast<CompositeSurface*>(ge1);
CompositeSurface *cs2 = dynamic_cast<CompositeSurface*>(ge2);
DLIList<GeometryEntity*> geometry_entities_1;
DLIList<GeometryEntity*> geometry_entities_2;
DLIList<GeometryQueryEngine*> gqes_1;
DLIList<GeometryQueryEngine*> gqes_2;
int i, j;
int still_ok = 1;
if(cc1)
for(i=cc1->num_curves()-1; i>-1 && still_ok; i--)
GeometryEntity *ge = cc1->get_curve(i);
if(dynamic_cast<PartitionEntity*>(ge))
still_ok = 0;
GeometryQueryEngine *gqe = ge->get_geometry_query_engine();
geometry_entities_1.append(ge);
gqes_1.append(gqe);
else if(cs1)
for(i=cs1->num_surfs()-1; i>-1 && still_ok; i--)
GeometryEntity *ge = cs1->get_surface(i);
still_ok = 0;
gqes_1.append(gqe);
else
if(dynamic_cast<PartitionEntity*>(ge1))
still_ok = 0;
else if(dynamic_cast<Curve*>(ge1) || dynamic_cast<Surface*>(ge1))
GeometryQueryEngine *gqe = ge1->get_geometry_query_engine();
geometry_entities_1.append(ge1);
gqes_1.append(gqe);
else
PRINT_ERROR("Entity-entity distance not yet supported for virtual geometry.\n");
if(cc2)
for(i=cc2->num_curves()-1; i>-1 && still_ok; i--)
GeometryEntity *ge = cc2->get_curve(i);
still_ok = 0;
geometry_entities_2.append(ge);
gqes_2.append(gqe);
else if(cs2)
for(i=cs2->num_surfs()-1; i>-1 && still_ok; i--)
GeometryEntity *ge = cs2->get_surface(i);
still_ok = 0;
gqes_2.append(gqe);
else
if(dynamic_cast<PartitionEntity*>(ge2))
still_ok = 0;
else if(dynamic_cast<Curve*>(ge2) || dynamic_cast<Surface*>(ge2))
GeometryQueryEngine *gqe = ge2->get_geometry_query_engine();
geometry_entities_2.append(ge2);
gqes_2.append(gqe);
else
if(still_ok)
double smallest_distance = CUBIT_DBL_MAX;
for(i=geometry_entities_1.size(); i--;)
GeometryEntity *ge1 = geometry_entities_1.get_and_step();
GeometryQueryEngine *gqe1 = gqes_1.get_and_step();
for(j=geometry_entities_2.size(); j--;)
GeometryEntity *ge2 = geometry_entities_2.get_and_step();
//GeometryQueryEngine *gqe2 = gqes_2.get_and_step();
CubitVector cur_pos1, cur_pos2;
double cur_distance;
gqe1->entity_entity_distance(ge1, ge2, cur_pos1, cur_pos2, cur_distance);
if(cur_distance < smallest_distance)
smallest_distance = cur_distance;
p1 = cur_pos1;
p2 = cur_pos2;
else
| CubitStatus VirtualQueryEngine::entity_extrema | ( | DLIList< GeometryEntity * > & | ref_entity_list, |
| const CubitVector * | dir1, | ||
| const CubitVector * | dir2, | ||
| const CubitVector * | dir3, | ||
| CubitVector & | extrema, | ||
| GeometryEntity *& | extrema_entity_ptr | ||
| ) | [virtual] |
Definition at line 1585 of file VirtualQueryEngine.cpp.
PRINT_ERROR("Entity extrema calculation not yet supported for virtual geometry.\n");
| virtual const std::type_info& VirtualQueryEngine::entity_type_info | ( | ) | const [inline, virtual] |
Definition at line 103 of file VirtualQueryEngine.hpp.
{ return typeid(VirtualQueryEngine); }
| CubitStatus VirtualQueryEngine::export_solid_model | ( | DLIList< TopologyBridge * > & | bridge_list, |
| const char * | file_name, | ||
| Model_File_Type | file_type, | ||
| const CubitString & | cubit_version, | ||
| ModelExportOptions & | export_options | ||
| ) | [protected, virtual] |
R CubitStatus R- CUBIT_SUCCESS/CUBIT_FAILURE I ref_entity_list I- A list of RefEntities to be exported or saved to a file. I file_name I- The name of the file to write to. I file_type I- An optional type of file.
Definition at line 1847 of file VirtualQueryEngine.cpp.
| virtual CubitStatus VirtualQueryEngine::export_solid_model | ( | DLIList< TopologyBridge * > & | bridge_list, |
| char *& | p_buffer, | ||
| int & | n_buffer_size, | ||
| bool | b_export_buffer | ||
| ) | [inline, protected, virtual] |
Definition at line 336 of file VirtualQueryEngine.hpp.
{return CUBIT_FAILURE;}
| CubitStatus VirtualQueryEngine::fire_ray | ( | CubitVector & | origin, |
| CubitVector & | direction, | ||
| DLIList< TopologyBridge * > & | at_entity_list, | ||
| DLIList< double > & | ray_params, | ||
| int | max_hits, | ||
| double | ray_radius, | ||
| DLIList< TopologyBridge * > * | hit_entity_list = 0 |
Definition at line 1970 of file VirtualQueryEngine.cpp.
// Note: for now assume we will only get curves or surfaces
int i;
int prev_num_hits = ray_params.size();
GeometryQueryEngine *gqe = 0;
TopologyBridge *bridge_ptr;
// This is only needed because this function is "const"
VirtualQueryEngine *vqe = VirtualQueryEngine::instance();
at_entity_list.reset();
for( i=at_entity_list.size(); i--; )
bridge_ptr = at_entity_list.get_and_step();
gqe = bridge_ptr->get_geometry_query_engine();
if( !gqe )
PRINT_ERROR( "Unable to find geometry engine associated with an entity!\n" );
Curve *curve_ptr = CAST_TO( bridge_ptr, Curve );
if( curve_ptr )
DLIList<TopologyBridge*> tb_curve_list;
vqe->get_underlying_curves( curve_ptr, tb_curve_list );
if( tb_curve_list.size() > 0 )
gqe = tb_curve_list.get()->get_geometry_query_engine();
gqe->fire_ray( origin, direction, tb_curve_list, ray_params, max_hits,
ray_radius, hit_entity_list_ptr );
// If curve_ptr is a PartitionCurve, it could be smaller than the underlying curve.
// This means we have to check to make sure any hit points lie inside the curve. Remove if they don't.
if (CAST_TO(curve_ptr, PartitionCurve))
// start iterating at the first new ray_param
ray_params.reset();
ray_params.step(prev_num_hits);
hit_entity_list_ptr->reset();
hit_entity_list_ptr->step(prev_num_hits);
int j;
for (j=prev_num_hits; j<ray_params.size(); j++)
CubitVector *loc_ptr;
double param = ray_params.get();
loc_ptr = new CubitVector;
origin.next_point( direction, param, *loc_ptr );
CubitPointContainment containment = CUBIT_PNT_UNKNOWN;
containment = curve_ptr->point_containment(*loc_ptr);
if ( (containment != CUBIT_PNT_ON) && (containment != CUBIT_PNT_BOUNDARY) )
//remove from the hit list
ray_params.remove();
hit_entity_list_ptr->remove();
else
ray_params.step();
hit_entity_list_ptr->step();
Surface *surface_ptr = CAST_TO( bridge_ptr, Surface );
if( surface_ptr )
DLIList<TopologyBridge*> tb_surface_list;
vqe->get_underlying_surfaces( surface_ptr, tb_surface_list );
if( tb_surface_list.size() > 0 )
gqe = tb_surface_list.get()->get_geometry_query_engine();
gqe->fire_ray( origin, direction, tb_surface_list, ray_params, max_hits,
// If surface_ptr is a PartitionSurface, it could be smaller than the underlying surface.
// This means we have to check to make sure any hit points lie inside the surface. Remove if they don't.
if (CAST_TO(surface_ptr, PartitionSurface))
ray_params.reset();
int j;
containment = surface_ptr->point_containment(*loc_ptr);
else
ray_params.step();
if( hit_entity_list_ptr && hit_entity_list_ptr->size() != ray_params.size() )
PRINT_WARNING( "Hit entity list size not equal to number of hits\n" );
// Account for max hits
if( max_hits != 0 )
if( ray_params.size() <= max_hits )
for( i=ray_params.size()-max_hits; i--; )
ray_params.last();
if( hit_entity_list_ptr )
hit_entity_list_ptr->last();
| CubitStatus VirtualQueryEngine::get_composite_curve_facetting | ( | CompositeCurve * | ccurve_ptr, |
| GMem * | gMem, | ||
| double | angle_tolerance = 0, |
| double | distance_tolerance = 0, |
| double | max_edge_length = 0 |
| ) | const [protected] |
Definition at line 324 of file VirtualQueryEngine.cpp.
// Just return if gMem is NULL
if (gMem == NULL)
GMem current_gmem;
int point_count = 0; //Current total of points returned
// from underlying edges
int next_index = 0; //index of next insert spot in passed GMem object.
//Get points for each underlying curve
current_gmem.clean_out();
for( int i = 0; i < ccurve_ptr->num_curves(); i++ )
// Get the next curve and its GME
Curve* curve_ptr = ccurve_ptr->get_curve(i);
GeometryQueryEngine* GQE_ptr =
curve_ptr->get_geometry_query_engine();
// Get the GME to facet the curve
CubitStatus current_status =
GQE_ptr->get_graphics( curve_ptr, ¤t_gmem, angle_tolerance,
distance_tolerance, max_edge_length );
if( current_status == CUBIT_FAILURE )
int this_point_count = current_gmem.pointListCount;
// Make sure the passed in gmem is big enough
gMem->allocate_more_polylines(this_point_count-1);
//assert( gMem->pts_size >= point_count );
// If this isn't the first curve, we don't need to
// repeat one of the end nodes.
if (point_count != 0)
this_point_count--;
// Add to the total number of points so far
point_count += this_point_count;
//Copy points to passed GMem, in the correct order
//for the sense of the underlying edge wrt the
//composite.
CubitSense sense = ccurve_ptr->get_sense( i );
if( sense == CUBIT_FORWARD )
if (next_index == 0)
for(int j = 0; j < point_count; j++)
gMem->point_list()[j] = current_gmem.point_list()[j];
else
// cur_gmem has one more point than we will access,
// so last index is point_count-next_index.
for(int j = next_index; j < point_count; j++)
gMem->point_list()[j] = current_gmem.point_list()[j - next_index + 1];
else //( sense == CUBIT_REVERSED )
// All but the first curve will not use one of its points.
// This is taken into account by decrementing point_count
// earlier.
gMem->point_list()[j] = current_gmem.point_list()[point_count-j-1];
next_index = point_count;
gMem->pointListCount = point_count;
| CubitStatus VirtualQueryEngine::get_composite_surface_facetting | ( | CompositeSurface * | surf_ptr, |
| GMem * | gMem, | ||
| std::vector< TopologyBridge * > * | vertex_edge_to_point_vector, | ||
| std::vector< std::pair< TopologyBridge *, std::pair< int, int > > > * | facet_edges_on_curves, | ||
| unsigned short | normal_tol, | ||
| double | absolute_tol, | ||
| double | longest_edge | ||
Definition at line 446 of file VirtualQueryEngine.cpp.
if( gMem == NULL )
if (surf_ptr->get_graphics(*gMem))
if( vertex_edge_to_point_vector )
vertex_edge_to_point_vector->resize( gMem->pointListCount, NULL );
//get all the points on the surface
DLIList<TBPoint*> points;
surf_ptr->points( points );
for( int i=points.size(); i--; )
TBPoint *tb_pt = points.get_and_step();
CompositePoint *comp_pt = CAST_TO( tb_pt, CompositePoint );
if( comp_pt )
CubitPoint *facet_point = comp_pt->facet_point();
(*vertex_edge_to_point_vector)[facet_point->marked()] = comp_pt;
if( facet_edges_on_curves )
DLIList<Curve*> tmp_curves;
surf_ptr->curves( tmp_curves );
for( int i=tmp_curves.size(); i--; )
Curve *tmp_curve = tmp_curves.get_and_step();
CompositeCurve *comp_curve = CAST_TO( tmp_curve, CompositeCurve );
if( comp_curve )
DLIList<CubitFacetEdgeData*> facet_edges;
comp_curve->get_facet_data( facet_edges );
for( int j=facet_edges.size(); j--; )
CubitFacetEdge *facet_edge = facet_edges.get_and_step();
facet_edges_on_curves->push_back( std::make_pair( tmp_curve,
std::make_pair( facet_edge->point(0)->marked(),
facet_edge->point(1)->marked() )));
// Get the underlying Surfaces
GeometryQueryEngine* gqe_ptr;
GMem *gMem_list = new GMem[ surf_ptr->num_surfs() ];
int total_number_points = 0;
int total_number_facets = 0;
// Get the facets of each Surface
int i;
for(i = 0; i < surf_ptr->num_surfs(); i++)
Surface* surface_ptr = surf_ptr->get_surface(i);
gqe_ptr = surface_ptr->get_geometry_query_engine();
gqe_ptr->get_graphics( surface_ptr, &(gMem_list[i]),
normal_tol, dist_tol, longest_edge );
total_number_facets += gMem_list[i].fListCount;
total_number_points += gMem_list[i].pointListCount;
int point_offset = 0;
int face_offset = 0;
gMem->replace_point_list(new GPoint[total_number_points],
total_number_points, total_number_points);
gMem->replace_facet_list(new int[total_number_facets],
total_number_facets, total_number_facets);
for( i = 0; i < surf_ptr->num_surfs(); i++ )
int j;
for( j = 0; j < gMem_list[i].pointListCount; j++ )
assert((point_offset + j) < gMem->pointListCount );
gMem->point_list()[j + point_offset].x = gMem_list[i].point_list()[j].x;
gMem->point_list()[j + point_offset].y = gMem_list[i].point_list()[j].y;
gMem->point_list()[j + point_offset].z = gMem_list[i].point_list()[j].z;
int k;
for( k = 0; k < gMem_list[i].fListCount;)
int count = gMem_list[i].facet_list()[k];
assert( k + count < gMem->fListCount );
gMem->facet_list()[k + face_offset] = count;
k++;
for( int l = 0; l < count; l++, k++ )
assert( k + face_offset < gMem->fListCount );
assert( k < gMem_list[i].fListCount );
gMem->facet_list()[k + face_offset] = gMem_list[i].facet_list()[k]
+ point_offset;
point_offset += j;
face_offset += k;
gMem->consolidate_points(10*GEOMETRY_RESABS);
// // Debug!!!
// int q;
// for (q = 0; q < bte_list.size(); q++)
// PRINT_INFO("Printing Points for Surface %d.\n", q);
// int r;
// for (r = 0; r < gMem_list[q].pointListCount; r++)
// PRINT_INFO("%g %g %g\n",
// gMem_list[q].point_list()[r].x,
// gMem_list[q].point_list()[r].y,
// gMem_list[q].point_list()[r].z);
// PRINT_INFO("Printing FList for Surface %d.\n", q);
// for (r = 0; r < gMem_list[q].fListCount; r++)
// PRINT_INFO("%d %s",
// gMem_list[q].facet_list()[r],
// r % 4 ? "" : "\n");
// PRINT_INFO("Composite points:\n");
// for (q = 0; q < gMem->pointListCount; q++)
// gMem->point_list()[q].x,
// gMem->point_list()[q].y,
// gMem->point_list()[q].z);
// PRINT_INFO("Composite facet list:\n");
// for (q = 0; q < gMem->fListCount; q++)
// gMem->facet_list()[q],
// q % 4 ? "" : "\n");
PartitionPoint *ppt = CAST_TO( tb_pt, PartitionPoint );
if( ppt )
CubitPoint *facet_point = ppt->facet_point();
(*vertex_edge_to_point_vector)[facet_point->marked()] = ppt;
PartitionCurve *pt_curve = CAST_TO( tmp_curve, PartitionCurve );
if( pt_curve )
pt_curve->get_facet_data( facet_edges );
delete [] gMem_list;
| CubitString VirtualQueryEngine::get_engine_version_string | ( | ) | [virtual] |
Definition at line 157 of file VirtualQueryEngine.cpp.
CubitString return_this(
"VirtualQueryEngine v1.2 by Jason Kraftcheck.\n" );
return_this += "I-CARVE Lab., University of Wisconsin - Madison, August 1, 1997.\n";
return_this += "This ModelingEngine performs the necessary topological ";
return_this += "operations for working with VirtualEntities, including ";
return_this += "objects of type CompositeEntity, PartitionEntity, and ";
return_this += "ParasiteEntity. ComposinteModelingEngine also ";
return_this += "provides the interface for creating, destroying, and ";
return_this += "modifying VirtualEntities.\n";
return return_this;
| CubitStatus VirtualQueryEngine::get_graphics | ( | Surface * | surface_ptr, |
| GMem * | gmem, | ||
| std::vector< TopologyBridge * > & | vertex_edge_to_point_vector, | ||
| std::vector< std::pair< TopologyBridge *, std::pair< int, int > > > & | facet_edges_on_curves, | ||
| unsigned short | normal_tolerance, | ||
| double | distance_tolerance, | ||
| double | max_edge_length | ||
Definition at line 181 of file VirtualQueryEngine.cpp.
PartitionSurface* ps_ptr = CAST_TO(surf_ptr, PartitionSurface );
if( ps_ptr != NULL )
return get_partition_surface_facetting( ps_ptr, gmem, &vertex_edge_to_point_vector, &facet_edges_on_curves,
normal_tol, dist_tol, max_edge_length );
CompositeSurface* cs_ptr = CAST_TO(surf_ptr, CompositeSurface );
if( cs_ptr != NULL )
return get_composite_surface_facetting( cs_ptr, gmem, &vertex_edge_to_point_vector, &facet_edges_on_curves,
//PRINT_INFO("VirtualQueryEngine::get_graphics_facets"
// "( s%p, %p, %d, %f ) = CUBIT_FAILURE\n",
// surf_ptr, gmem, normal_tol, dist_tol);
| GMem * | gMem, | ||
Definition at line 220 of file VirtualQueryEngine.cpp.
return get_composite_surface_facetting( cs_ptr, gMem, NULL, NULL,
else if( ps_ptr != NULL )
return get_partition_surface_facetting( ps_ptr, gMem, NULL, NULL,
else
(void*)surf_ptr, (void*)gMem, normal_tol, dist_tol);
| CubitStatus VirtualQueryEngine::get_graphics | ( | Curve * | curve_ptr, |
| GMem * | gMem, | ||
Definition at line 258 of file VirtualQueryEngine.cpp.
CompositeCurve* ccurve = CAST_TO( curve_ptr, CompositeCurve );
PartitionCurve* pcurve = CAST_TO( curve_ptr, PartitionCurve );
CubitStatus result;
if( ccurve != NULL )
result = get_composite_curve_facetting( ccurve, gMem, angle_tolerance,
else if( pcurve != NULL )
result = get_partition_curve_facetting( pcurve, gMem, angle_tolerance,
else
PRINT_ERROR("Unknown curve type or NULL curve passed to "
"VirtualQueryEngine::get_graphics_edges()\n");
return result;
| CubitStatus VirtualQueryEngine::get_intersections | ( | Curve * | curve, |
| CubitVector & | point1, | ||
| CubitVector & | point2, | ||
| DLIList< CubitVector > & | intersection_list, | ||
| CubitBoolean | bounded, | ||
| CubitBoolean | closest | ||
| ) | [virtual] |
Definition at line 1385 of file VirtualQueryEngine.cpp.
DLIList<TopologyBridge*> curve_list;
get_underlying_curves( curve, curve_list );
int i;
for (i = 0; i < curve_list.size(); i++)
Curve* curve_ptr = CAST_TO(curve_list.get_and_step(), Curve);
GQE_ptr->get_intersections(curve_ptr, point1, point2, intersection_list,
bounded, closest);
| virtual CubitStatus VirtualQueryEngine::get_intersections | ( | Curve * | ref_edge1, |
| Curve * | ref_edge2, | ||
| bool | bounded = CUBIT_FALSE, |
| bool | closest = CUBIT_FALSE |
| ) | [virtual] |
| virtual CubitStatus VirtualQueryEngine::get_intersections | ( | Curve * | ref_edge, |
| Surface * | ref_face, | ||
| bool | bounded = CUBIT_FALSE |
| ) | [virtual] |
| CubitStatus VirtualQueryEngine::get_isoparametric_points | ( | Surface * | ref_face_ptr, |
| int & | nu, | ||
| int & | nv, | ||
| GMem *& | gMem | ||
Definition at line 290 of file VirtualQueryEngine.cpp.
nu = nv = 0;
| int VirtualQueryEngine::get_major_version | ( | ) | [virtual] |
Definition at line 142 of file VirtualQueryEngine.cpp.
return VGE_MAJOR_VERSION;
| int VirtualQueryEngine::get_minor_version | ( | ) | [virtual] |
Definition at line 147 of file VirtualQueryEngine.cpp.
return VGE_MINOR_VERSION;
| CubitStatus VirtualQueryEngine::get_partition_curve_facetting | ( | PartitionCurve * | pcurve_ptr, |
| GMem * | gMem, | ||
Definition at line 423 of file VirtualQueryEngine.cpp.
assert( gMem != NULL );
CubitStatus result = pcurve_ptr->get_graphics( *gMem, angle_tolerance,
return result;
| CubitStatus VirtualQueryEngine::get_partition_surface_facetting | ( | PartitionSurface * | surf_ptr, |
| GMem * | gMem, | ||
Definition at line 672 of file VirtualQueryEngine.cpp.
int i, j;
DLIList<CubitFacetData*> surf_facets;
DLIList<CubitPoint*> surf_points;
// get surface facets
surf_ptr->get_facet_data( surf_facets );
// get list of points from list of facets
for( i = surf_facets.size(); i--; )
CubitFacetData* facet = surf_facets.step_and_get();
for( j = 0; j< 3; j++ )
facet->point(j)->marked(1);
if( facet->point(j)->marked() )
facet->point(j)->marked(0);
surf_points.append( facet->point(j) );
if( ! gMem ) return CUBIT_SUCCESS;
// allocate storage for facet data
gMem->allocate_tri( surf_facets.size() );
gMem->fListCount = surf_facets.size() * 4;
gMem->pointListCount = surf_points.size();
// put points in GMem and mark each point with
// its index in the array
surf_points.reset();
for( i = 0; i < gMem->pointListCount; i++ )
GPoint* gpt = gMem->point_list() + i;
CubitPoint* pt = surf_points.get_and_step();
pt->marked(i);
gpt->x = (float)(pt->coordinates().x() );
gpt->y = (float)(pt->coordinates().y() );
gpt->z = (float)(pt->coordinates().z() );
// put each facet in the GMem. retreive
// point indices from marks.
surf_facets.reset();
int* gfacet_ptr = gMem->facet_list();
for( i = 0; i < surf_facets.size(); i++ )
CubitFacetData* facet = surf_facets.get_and_step();
*gfacet_ptr = 3;
gfacet_ptr++;
for( j = 0; j < 3; j++ )
*gfacet_ptr = facet->point(j)->marked();
gfacet_ptr++;
if( ppt )
if( pt_curve )
// clear point marks
for( i = surf_points.size(); i--; )
surf_points.step_and_get()->marked(0);
| CubitStatus VirtualQueryEngine::get_sister_partitions | ( | RefEntity * | ref_entity, |
| DLIList< RefEntity * > & | sisters | ||
Definition at line 1210 of file VirtualQueryEngine.cpp.
RefEdge *ref_edge = CAST_TO( ref_entity, RefEdge );
if( ref_edge )
Curve *curve_ptr = ref_edge->get_curve_ptr();
PartitionCurve *part_curve = CAST_TO(curve_ptr, PartitionCurve);
if( part_curve )
DLIList<TopologyBridge*> tb_list;
part_curve->sub_entity_set().get_owners( tb_list );
int k;
for( k=tb_list.size(); k--; )
TopologyBridge *tmp_bridge = tb_list.get_and_step();
TopologyEntity *te = tmp_bridge->topology_entity();
if( te )
RefEntity *sister = CAST_TO(te, RefEntity );
if( sister )
sisters.append( sister );
| double VirtualQueryEngine::get_sme_resabs_tolerance | ( | ) | const [protected, virtual] |
Definition at line 2129 of file VirtualQueryEngine.cpp.
return GEOMETRY_RESABS;
| int VirtualQueryEngine::get_subminor_version | ( | ) | [virtual] |
Definition at line 152 of file VirtualQueryEngine.cpp.
return VGE_SUBMINOR_VERSION;
| CubitStatus VirtualQueryEngine::get_u_isoparametric_points | ( | Surface * | ref_face_ptr, |
| double | v, | ||
| int & | n, | ||
| GMem *& | gMem | ||
Definition at line 299 of file VirtualQueryEngine.cpp.
| CubitStatus VirtualQueryEngine::get_underlying_bridges | ( | TopologyBridge * | bridge_ptr, |
| DLIList< TopologyBridge * > & | bridge_list | ||
| ) | [virtual] |
Definition at line 1507 of file VirtualQueryEngine.cpp.
assert (bridge_ptr);
CompositeSurface *comp_surf = CAST_TO(bridge_ptr, CompositeSurface);
PartitionSurface *part_surf = CAST_TO(bridge_ptr, PartitionSurface);
CompositeCurve *comp_curve = CAST_TO(bridge_ptr, CompositeCurve);
PartitionCurve *part_curve = CAST_TO(bridge_ptr, PartitionCurve);
CompositePoint *comp_point = CAST_TO(bridge_ptr, CompositePoint);
PartitionPoint *part_point = CAST_TO(bridge_ptr, PartitionPoint);
PartitionBody *part_body = CAST_TO(bridge_ptr, PartitionBody);
if (part_body )
bridge_list.append( part_body->partitioned_entity() );
else if ( comp_surf )
int i;
for (i = 0; i < comp_surf->num_surfs(); i ++)
part_surf = CAST_TO(comp_surf->get_surface(i), PartitionSurface);
if (!part_surf)
bridge_list.append_unique(CAST_TO(comp_surf->get_surface(i),
TopologyBridge));
else
if(dynamic_cast<Surface*>(part_surf->partitioned_entity()))
bridge_list.append_unique(CAST_TO(part_surf->partitioned_entity(),
TopologyBridge));
else if ( part_surf )
bridge_list.append( part_surf->partitioned_entity() );
else if ( comp_curve )
int i;
for (i = 0; i < comp_curve->num_curves(); i ++)
part_curve = CAST_TO(comp_curve->get_curve(i), PartitionCurve);
if (!part_curve)
bridge_list.append_unique(comp_curve->get_curve(i));
else
if(dynamic_cast<Curve*>(part_curve->partitioned_entity()))
bridge_list.append_unique( part_curve->partitioned_entity() );
else if ( part_curve )
bridge_list.append( part_curve->partitioned_entity() );
else if ( part_point )
TopologyBridge *tb_point = part_point->real_point();
if( tb_point )
bridge_list.append( tb_point );
else if ( comp_point )
TopologyBridge *tb_point = comp_point->get_point();
if( tb_point )
| CubitStatus VirtualQueryEngine::get_underlying_curves | ( | Curve * | curve_ptr, |
| DLIList< TopologyBridge * > & | curve_list | ||
| ) | [virtual] |
Definition at line 1445 of file VirtualQueryEngine.cpp.
assert (curve_ptr);
CompositeCurve *comp_curve = CAST_TO(curve_ptr, CompositeCurve);
if ( comp_curve )
int i;
if (!part_curve)
curve_list.append_unique(CAST_TO(comp_curve->get_curve(i),
TopologyBridge));
else
curve_list.append_unique(CAST_TO(part_curve->partitioned_entity(),
TopologyBridge));
curve_list.append(CAST_TO(part_curve->partitioned_entity(),
TopologyBridge));
| CubitStatus VirtualQueryEngine::get_underlying_surfaces | ( | Surface * | surf_ptr, |
| DLIList< TopologyBridge * > & | surf_list | ||
| ) | [virtual] |
Definition at line 1476 of file VirtualQueryEngine.cpp.
assert (surf_ptr);
CompositeSurface *comp_surf = CAST_TO(surf_ptr, CompositeSurface);
PartitionSurface *part_surf = CAST_TO(surf_ptr, PartitionSurface);
if ( comp_surf )
int i;
if (!part_surf)
surf_list.append_unique(CAST_TO(comp_surf->get_surface(i),
TopologyBridge));
else
surf_list.append_unique(CAST_TO(part_surf->partitioned_entity(),
TopologyBridge));
surf_list.append(CAST_TO(part_surf->partitioned_entity(),
TopologyBridge));
| CubitStatus VirtualQueryEngine::get_v_isoparametric_points | ( | Surface * | ref_face_ptr, |
| double | u, | ||
| int & | n, | ||
| GMem *& | gMem | ||
Definition at line 307 of file VirtualQueryEngine.cpp.
| void VirtualQueryEngine::get_VEs | ( | RefVolume * | volume_ptr, |
| DLIList< TopologyBridge * > & | ve_list, | ||
| CubitBoolean | visible = CUBIT_FALSE, |
| const CubitBoolean | children_too = CUBIT_TRUE |
| ) | [static] |
Definition at line 935 of file VirtualQueryEngine.cpp.
DLIList<BasicTopologyEntity*> bte_list;
int i;
volume_ptr->bridge_manager()->get_bridge_list( tb_list );
for( i = tb_list.size(); i--; )
TopologyBridge* tb_ptr = tb_list.get_and_step();
PartitionEntity* ve_ptr = dynamic_cast<PartitionEntity*>(tb_ptr);
CompositeLump* ce_ptr = dynamic_cast<CompositeLump*>(tb_ptr);
if( ve_ptr || ce_ptr )
ve_list.append( tb_ptr );
if (!children_too) return;
DLIList<TopologyBridge*> child_list;
DLIList<RefFace*> face_list;
volume_ptr->ref_faces( face_list );
DLIList<BasicTopologyEntity*> temp_face_list;
CAST_LIST_TO_PARENT( face_list, temp_face_list );
bte_list.merge_unique( temp_face_list );
// bte_list.merge_unique( face_list );
for( i = bte_list.size();i > 0;i--)
child_list.clean_out();
get_VEs( bte_list.get_and_step(), child_list, visible );
ve_list.merge_unique( child_list );
| void VirtualQueryEngine::get_VEs | ( | RefFace * | face_ptr, |
| ) | [static] |
Definition at line 974 of file VirtualQueryEngine.cpp.
int i;
face_ptr->bridge_manager()->get_bridge_list( tb_list );
tb_list.reset();
TopologyBridge* ve_ptr = tb_list.get_and_step();
if( dynamic_cast<PartitionEntity*>(ve_ptr) ||
dynamic_cast<CompositeSurface*>(ve_ptr) )
ve_list.append( ve_ptr );
DLIList<RefEdge*> edge_list;
face_ptr->ref_edges( edge_list );
DLIList<BasicTopologyEntity*> temp_edge_list;
CAST_LIST_TO_PARENT( edge_list, temp_edge_list );
bte_list.merge_unique( temp_edge_list );
| void VirtualQueryEngine::get_VEs | ( | RefEdge * | edge_ptr, |
| ) | [static] |
Definition at line 1015 of file VirtualQueryEngine.cpp.
int i;
edge_ptr->bridge_manager()->get_bridge_list( tb_list );
tb_list.reset();
if( dynamic_cast<PartitionCurve*>(ve_ptr) ||
dynamic_cast<CompositeCurve*>(ve_ptr) )
DLIList<RefVertex*> vex_list;
edge_ptr->ref_vertices( vex_list );
DLIList<BasicTopologyEntity*> temp_vex_list;
CAST_LIST_TO_PARENT( vex_list, temp_vex_list );
bte_list.merge_unique( temp_vex_list );
| void VirtualQueryEngine::get_VEs | ( | RefVertex * | vertex_ptr, |
| ) | [static] |
Definition at line 1054 of file VirtualQueryEngine.cpp.
vex_ptr->bridge_manager()->get_bridge_list( tb_list );
tb_list.reset();
for( int i = tb_list.size(); i--; )
TopologyBridge* tb = tb_list.get_and_step();
if( dynamic_cast<PartitionPoint*>(tb) ||
dynamic_cast<CompositePoint*>(tb) )
ve_list.append( tb );
| void VirtualQueryEngine::get_VEs | ( | TopologyEntity * | te_ptr, |
| ) | [static] |
Definition at line 835 of file VirtualQueryEngine.cpp.
Body* body_ptr = CAST_TO( te_ptr, Body );
CoVolume* covol_ptr = CAST_TO( te_ptr, CoVolume );
RefVolume* vol_ptr = CAST_TO( te_ptr, RefVolume );
Shell* shell_ptr = CAST_TO( te_ptr, Shell );
CoFace* coface_ptr = CAST_TO( te_ptr, CoFace );
RefFace* face_ptr = CAST_TO( te_ptr, RefFace );
Loop* loop_ptr = CAST_TO( te_ptr, Loop );
CoEdge* coedge_ptr = CAST_TO( te_ptr, CoEdge );
RefEdge* edge_ptr = CAST_TO( te_ptr, RefEdge );
Chain* chain_ptr = CAST_TO( te_ptr, Chain );
CoVertex* covex_ptr = CAST_TO( te_ptr, CoVertex );
RefVertex* vex_ptr = CAST_TO( te_ptr, RefVertex );
if( (body_ptr != NULL) || (covol_ptr != NULL) )
if (children_too) {
DLIList<RefVolume*> vol_list;
te_ptr->ref_volumes( vol_list );
for( int i = vol_list.size(); i > 0; i-- )
get_VEs( vol_list.get_and_step(), child_list, visible,
children_too);
else if( vol_ptr != NULL )
get_VEs( vol_ptr, ve_list, visible, children_too );
else if( (shell_ptr != NULL) || (coface_ptr != NULL) )
if (children_too) {
te_ptr->ref_faces( face_list );
for( int i = face_list.size(); i> 0; i-- )
get_VEs( face_list.get_and_step(), child_list, visible,
children_too);
else if( face_ptr != NULL )
get_VEs( face_ptr, ve_list, visible, children_too );
else if( (loop_ptr != NULL) || (coedge_ptr != NULL) )
if (children_too) {
te_ptr->ref_edges( edge_list );
for( int i = edge_list.size(); i > 0; i-- )
get_VEs( edge_list.get_and_step(), child_list, visible,
children_too);
else if( edge_ptr != NULL )
get_VEs( edge_ptr, ve_list, visible, children_too );
else if( (chain_ptr != NULL) || (covex_ptr != NULL ) )
if (children_too) {
DLIList<RefVertex*> vertex_list;
te_ptr->ref_vertices( vertex_list );
for( int i = vertex_list.size(); i > 0; i-- )
get_VEs( vertex_list.get_and_step(), child_list, visible,
children_too);
else if( vex_ptr != NULL )
get_VEs( vex_ptr, ve_list, visible, children_too );
else
PRINT_ERROR("Unknown type of TopologyEntity passed to "
"VirtualQueryEngine::get_VEs(..). Passed pointer"
" may be stale.\n");
| CubitStatus VirtualQueryEngine::get_visible_entities | ( | TopologyBridge * | hidden_tb, |
| DLIList< TopologyBridge * > & | real_tbs | ||
| ) | [virtual] |
Definition at line 2635 of file VirtualQueryEngine.cpp.
int j;
TopologyBridge* bridge_ptr = NULL;
TopologyBridge* tb_owner = NULL;
TopologyBridge* visible_tb = NULL;
DLIList<TopologyBridge*> tbs_to_search;
tbs_to_search.append( hidden_tb );
while(tbs_to_search.size())
bridge_ptr = tbs_to_search.pop();
tb_owner = dynamic_cast<TopologyBridge*>(bridge_ptr->owner());
if( tb_owner )
if( tb_owner->topology_entity() )
visible_tb = tb_owner;
real_tbs.append( visible_tb );
continue;
else
if( bridge_ptr->topology_entity() )
visible_tb = bridge_ptr;
continue;
TopologyBridge *tb_ptr;
if( tb_owner )
tb_ptr = tb_owner;
else
tb_ptr = bridge_ptr;
TBOwner* tb_owner = tb_ptr->owner();
if (CAST_TO(tb_owner, HiddenEntitySet)) // it is a composite
TopologyBridge* parent = NULL;
while (CAST_TO(tb_owner, HiddenEntitySet)) // virtual geometry
HiddenEntitySet* hidden_set_ptr = CAST_TO(tb_owner, HiddenEntitySet);
parent = dynamic_cast<TopologyBridge*>(hidden_set_ptr->owner());
if (parent)
tb_owner = parent->owner();
if (parent)
tbs_to_search.append( parent );
continue;
else if (CAST_TO(tb_owner, SubEntitySet)) // partition geometry
SubEntitySet* sub_set_ptr = CAST_TO(tb_owner, SubEntitySet);
DLIList<TopologyBridge*> owner_list;
sub_set_ptr->get_owners(owner_list);
owner_list.reset();
// need to traverse all the entities that make up the original geometry
// if intersected a surface, and the surface is partitioned into mult surfaces,
// which surface did we hit? Did we hit the curve in between? The vertices? gahhhh...
for (j=0; j<owner_list.size(); j++)
TopologyBridge* owner_partition = owner_list.get_and_step();
tbs_to_search.append( owner_partition );
real_tbs.uniquify_ordered();
| TopologyBridge * VirtualQueryEngine::get_visible_entity_at_point | ( | TopologyBridge * | hidden_tb, |
| CubitVector * | point | ||
| ) | [virtual] |
Definition at line 2381 of file VirtualQueryEngine.cpp.
// Determine entity type; should only be Curve or TBPoint
int j, k;
bool added_entity = false;
TopologyBridge* bridge_ptr = hidden_tb;
bool hidden = CUBIT_TRUE;
while (hidden)
if( tb_owner )
hidden = CUBIT_FALSE;
added_entity = true;
continue;
else
else
continue;
else
if( tb_owner )
tb_ptr = tb_owner;
else
if (CAST_TO(tb_owner, HiddenEntitySet)) // virtual geometry
if (parent)
if (parent)
bridge_ptr = parent;
continue;
owner_list.reset();
//determine geometry type and call point_containment
if (CAST_TO(owner_partition, Surface))
containment = CAST_TO(owner_partition, Surface)->point_containment(*point);
switch (containment)
case CUBIT_PNT_OFF:
break;
case CUBIT_PNT_ON:
bridge_ptr = owner_partition;
break;
case CUBIT_PNT_UNKNOWN:
break;
case CUBIT_PNT_BOUNDARY:
DLIList<TopologyBridge*> children, related_loops, related_coedges;
DLIList<TopologyBridge*> related_curves, temp;
// Goal: get curves (incl. virtual ones)
// Note: can't use ->curves() func b/c it won't grab the virtual curves
// get all Loops, including virtual
owner_partition->get_children( related_loops, true );
related_loops.reset();
int ii;
// get all CoEdges
for (ii = related_loops.size(); ii--;)
temp.clean_out();
related_loops.get_and_step()->get_children(temp, true);
related_coedges.merge_unique(temp);
// get all Curves
for (ii = related_coedges.size(); ii--;)
temp.clean_out();
related_coedges.get_and_step()->get_children(temp, true);
related_curves.merge_unique(temp);
CAST_LIST(related_curves, children, TopologyBridge);
for (k=0; k<children.size(); k++)
// CAST and do point_containment for each curve
TopologyBridge* partition_curve = children.get_and_step();
containment = CAST_TO(partition_curve, Curve)->point_containment(*point);
case CUBIT_PNT_OFF:
break;
case CUBIT_PNT_ON:
bridge_ptr = partition_curve;
break;
// CAST and do point_containment for each vertex
children.clean_out();
partition_curve->get_children(children, true);
int kk;
for (kk=0; kk<children.size(); kk++)
TopologyBridge* partition_vertex = children.get_and_step();
CubitVector coords = CAST_TO(partition_vertex, TBPoint)->coordinates();
if (coords.distance_between_squared(*point) < GEOMETRY_RESABS*GEOMETRY_RESABS)
containment = CUBIT_PNT_ON;
bridge_ptr = partition_vertex;
break;
else
containment = CUBIT_PNT_OFF;
if (added_entity)
break;
break;
if (added_entity)
break;
else if (CAST_TO(owner_partition, Curve))
containment = CAST_TO(owner_partition, Curve)->point_containment(*point);
case CUBIT_PNT_OFF:
break;
case CUBIT_PNT_ON:
break;
DLIList<TopologyBridge*> children;
owner_partition->get_children(children, true);
int kk;
break;
else
break;
if (added_entity)
break;
else if (CAST_TO(owner_partition, TBPoint))
CubitVector coords = CAST_TO(owner_partition, TBPoint)->coordinates();
break;
else
else
PRINT_WARNING("Hit unknown partition entity.\n");
if (!added_entity)
visible_tb = NULL;
//break;
} //while
return visible_tb;
| CubitBoolean VirtualQueryEngine::has_virtual | ( | TopologyEntity * | entity | ) | [static] |
Definition at line 1083 of file VirtualQueryEngine.cpp.
if (te_ptr == NULL)
return CUBIT_FALSE;
if (is_virtual(te_ptr))
return CUBIT_TRUE;
// check if children has partition or composite entities
int i;
Body * body_ptr = CAST_TO (te_ptr, Body);
RefVolume * vol_ptr = CAST_TO (te_ptr, RefVolume);
RefFace * face_ptr = CAST_TO (te_ptr, RefFace);
CubitBoolean has_vir = CUBIT_FALSE;
if (body_ptr != NULL)
te_ptr->ref_volumes(vol_list);
for (i = vol_list.size(); i > 0; i--)
if (has_virtual(vol_list.get_and_step()))
has_vir = CUBIT_TRUE;
break;
if (vol_ptr != NULL)
te_ptr->ref_faces(face_list);
for (i = face_list.size(); i > 0; i --)
if (has_virtual(face_list.get_and_step()))
break;
if (face_ptr != NULL)
DLIList<RefEdge *> edge_list;
te_ptr->ref_edges(edge_list);
for (i = edge_list.size(); i > 0; i --)
if (is_virtual(edge_list.get_and_step()))
break;
return has_vir;
| CubitStatus VirtualQueryEngine::import_solid_model | ( | const char * | file_name, |
| DLIList< TopologyBridge * > & | imported_entities, | ||
| ModelImportOptions & | import_options | ||
R CubitStatus R- CUBIT_SUCCESS/CUBIT_FAILURE I file_ptr I- A pointer to the file to read (can be NULL for IGES and STEP files). I file_type I- Type of file.
Definition at line 1865 of file VirtualQueryEngine.cpp.
PRINT_INFO("VirtualQueryEngine::import_solid_model\n");
default_error_message( "import_solid_model()");
| virtual CubitStatus VirtualQueryEngine::import_solid_model | ( | DLIList< TopologyBridge * > & | imported_entities, |
| const char * | pBuffer, | ||
| const int | n_buffer_size | ||
Definition at line 354 of file VirtualQueryEngine.hpp.
| VirtualQueryEngine * VirtualQueryEngine::instance | ( | void | ) | [inline, static] |
Definition at line 451 of file VirtualQueryEngine.hpp.
if( instance_ == NULL )
instance_ = new VirtualQueryEngine;
assert( instance_ != NULL );
return instance_;
| virtual bool VirtualQueryEngine::is_intermediate_engine | ( | ) | [inline, virtual] |
Definition at line 117 of file VirtualQueryEngine.hpp.
{return TRUE;}
| CubitBoolean VirtualQueryEngine::is_partition | ( | RefEntity * | ref_entity | ) |
Definition at line 1194 of file VirtualQueryEngine.cpp.
if( ref_edge )
if( part_curve )
return CUBIT_TRUE;
return CUBIT_FALSE;
| CubitBoolean VirtualQueryEngine::is_virtual | ( | TopologyEntity * | entity, |
| const CubitBoolean | children_too = CUBIT_FALSE |
| ) | [static] |
Definition at line 1143 of file VirtualQueryEngine.cpp.
if ( entity == NULL )
return CUBIT_FALSE;
if (CAST_TO(entity, Body) !=NULL)
int i;
DLIList<TopologyBridge*> list;
entity->bridge_manager()->get_bridge_list(list);
TopologyBridge * tb;
for (i = list.size(); i > 0; i--)
tb = list.get_and_step();
if (CAST_TO(tb, PartitionBody) != NULL ||
CAST_TO(tb, CompositeBody) != NULL)
return CUBIT_TRUE;
DLIList<TopologyBridge*> ve_list;
get_VEs(entity, ve_list, CUBIT_TRUE, children_too);
return (ve_list.size() ? CUBIT_TRUE : CUBIT_FALSE);
| CubitBoolean VirtualQueryEngine::is_virtual | ( | DLIList< Body * > & | entity_list, |
| ) | [static] |
Definition at line 1171 of file VirtualQueryEngine.cpp.
if (!children_too) return CUBIT_FALSE;
int i;
for (i = entity_list.size(); i > 0; i--)
if (is_virtual(entity_list.get_and_step(), children_too)) return CUBIT_TRUE;
return CUBIT_FALSE;
| CubitBoolean VirtualQueryEngine::is_virtual | ( | DLIList< RefEntity * > & | entity_list, |
| ) | [static] |
Definition at line 1182 of file VirtualQueryEngine.cpp.
int i;
for (i = entity_list.size(); i > 0; i--) {
RefEntity *ref_entity = entity_list.get_and_step();
if (is_virtual(CAST_TO(ref_entity, TopologyEntity), children_too)) return CUBIT_TRUE;
return CUBIT_FALSE;
| const char* VirtualQueryEngine::modeler_type | ( | ) | [inline, virtual] |
Definition at line 108 of file VirtualQueryEngine.hpp.
{ return "virtual"; }
| CubitStatus VirtualQueryEngine::reflect | ( | BodySM * | body, |
| const CubitVector & | axis | ||
| ) | [virtual] |
Definition at line 2244 of file VirtualQueryEngine.cpp.
if (PartitionBody* part = dynamic_cast<PartitionBody*>(body))
return PartitionEngine::instance().reflect( part, axis );
else if(CompositeBody* comp = dynamic_cast<CompositeBody*>(body))
return CompositeEngine::instance().reflect( comp, axis );
PRINT_ERROR("Non-virtual entity in VGE::reflect.\n");
| CubitStatus VirtualQueryEngine::reflect | ( | GeometryEntity * | ent, |
| ) | [virtual] |
Definition at line 2316 of file VirtualQueryEngine.cpp.
if (PartitionEntity* part = dynamic_cast<PartitionEntity*>(ent))
else if(CompositeSurface* csurf = dynamic_cast<CompositeSurface*>(ent))
return CompositeEngine::instance().reflect( csurf, axis );
else if(CompositeCurve* ccurve = dynamic_cast<CompositeCurve*>(ent))
return CompositeEngine::instance().reflect( ccurve, axis );
Definition at line 2166 of file VirtualQueryEngine.cpp.
CubitStatus result;
result = CGMApp::instance()->attrib_manager()->register_attrib_type(
CA_PARTITION_VG, "partition vg", "PARTITION_VG",
CAPartitionVG_creator, CUBIT_FALSE,
CUBIT_FALSE, CUBIT_TRUE, CUBIT_TRUE,
CUBIT_FALSE, CUBIT_FALSE);
if (CUBIT_SUCCESS != result) {
PRINT_ERROR("Failed to register attribute type partition vg.\n");
return;
CA_COMPOSITE_VG, "composite vg", "COMPOSITE_VG",
CACompositeVG_creator, CUBIT_FALSE,
PRINT_ERROR("Failed to register attribute type composite vg.\n");
return;
CA_VIRTUAL_VG, "virtual vg", "VIRTUAL_VG",
CAVirtualVG_creator, CUBIT_FALSE,
PRINT_ERROR("Failed to register attribute type virtual vg.\n");
| void VirtualQueryEngine::remove_virtual_geometry | ( | RefEntity * | entity_ptr, |
| CubitBoolean | all_children | ||
Definition at line 1746 of file VirtualQueryEngine.cpp.
if ( Body* body_ptr = dynamic_cast<Body*>(entity_ptr) )
remove_virtual_geometry(body_ptr, all_children);
else if( RefVolume* vol_ptr = dynamic_cast<RefVolume*>(entity_ptr) )
remove_virtual_geometry(vol_ptr, all_children);
else if( RefFace* face_ptr = dynamic_cast<RefFace*>(entity_ptr) )
remove_virtual_geometry(face_ptr);
| void VirtualQueryEngine::remove_virtual_geometry | ( | Body * | body, |
| bool | all_children | ||
Definition at line 1757 of file VirtualQueryEngine.cpp.
int i;
DLIList<RefVolume*> volumes, part_results;
body_ptr->ref_volumes(volumes);
for ( i = volumes.size(); i--; ) {
RefVolume* vol = volumes.step_and_get();
if ( ! dynamic_cast<PartitionLump*>(vol->get_lump_ptr()) )
volumes.change_to(0);
volumes.remove_all_with_value(0);
if ( volumes.size() )
PartitionTool::instance()->unpartitionAll(volumes, part_results);
if ( !all_children )
return;
volumes.clean_out();
remove_virtual_geometry( volumes.step_and_get(), true );
| void VirtualQueryEngine::remove_virtual_geometry | ( | RefVolume * | vol, |
Definition at line 1781 of file VirtualQueryEngine.cpp.
int i;
DLIList<RefFace*> faces, part_results;
bool had_virtual_geometry = false;
vol_ptr->ref_faces( faces );
for ( i = faces.size(); i--; )
if ( dynamic_cast<CompositeSurface*>(faces.step_and_get()->get_surface_ptr()) )
CompositeTool::instance()->uncomposite(faces.get());
had_virtual_geometry = true;
faces.clean_out();
if ( !dynamic_cast<PartitionSurface*>(faces.step_and_get()->get_surface_ptr()))
faces.change_to(0);
faces.remove_all_with_value(0);
if ( faces.size() )
PartitionTool::instance()->unpartitionAll(faces, part_results);
return;
faces.clean_out();
remove_virtual_geometry( faces.step_and_get() );
if( had_virtual_geometry )
AppUtil::instance()->send_event(GeometryEvent(GeometryEvent::TOPOLOGY_MODIFIED, vol_ptr));
| void VirtualQueryEngine::remove_virtual_geometry | ( | RefFace * | face | ) |
Definition at line 1823 of file VirtualQueryEngine.cpp.
int i;
DLIList<RefEdge*> edges, part_results;
face_ptr->ref_edges( edges );
for ( i = edges.size(); i--; ) {
if ( dynamic_cast<CompositeCurve*>(edges.step_and_get()->get_curve_ptr()) )
CompositeTool::instance()->uncomposite(edges.get());
edges.clean_out();
if ( !dynamic_cast<PartitionCurve*>(edges.step_and_get()->get_curve_ptr()))
edges.change_to(0);
edges.remove_all_with_value(0);
if ( edges.size() )
PartitionTool::instance()->unpartitionAll(edges, part_results);
| CubitStatus VirtualQueryEngine::restore_transform | ( | BodySM * | body | ) | [virtual] |
Definition at line 2256 of file VirtualQueryEngine.cpp.
return PartitionEngine::instance().restore_transform( part );
return CompositeEngine::instance().restore_transform( comp );
PRINT_ERROR("Non-virtual entity in VGE::restore_transform.\n");
| CubitStatus VirtualQueryEngine::rotate | ( | BodySM * | body, |
| const CubitVector & | axis, | ||
| double | angle | ||
| ) | [virtual] |
Definition at line 2213 of file VirtualQueryEngine.cpp.
return PartitionEngine::instance().rotate( part, axis, angle );
return CompositeEngine::instance().rotate( comp, axis, angle );
PRINT_ERROR("Non-virtual entity in VGE::rotate.\n");
| CubitStatus VirtualQueryEngine::rotate | ( | GeometryEntity * | ent, |
| double | degrees | ||
| ) | [virtual] |
Definition at line 2281 of file VirtualQueryEngine.cpp.
return PartitionEngine::instance().rotate( part, axis, degrees );
return CompositeEngine::instance().rotate( csurf, axis, degrees );
return CompositeEngine::instance().rotate( ccurve, axis, degrees );
| CubitStatus VirtualQueryEngine::save_temp_geom_file | ( | DLIList< TopologyBridge * > & | ref_entity_list, |
| const char * | filename, | ||
| CubitString & | created_file, | ||
| CubitString & | created_file_type | ||
Saves out a temporary geometry file. Entities in list must all be of same modeling engine.
Definition at line 1856 of file VirtualQueryEngine.cpp.
| CubitStatus VirtualQueryEngine::scale | ( | BodySM * | body, |
| double | factor | ||
| ) | [virtual] |
Definition at line 2226 of file VirtualQueryEngine.cpp.
return scale( body, CubitVector(factor,factor,factor) );
| const CubitVector & | factors | ||
| ) | [virtual] |
Definition at line 2232 of file VirtualQueryEngine.cpp.
return PartitionEngine::instance().scale( part, factors );
return CompositeEngine::instance().scale( comp, factors );
PRINT_ERROR("Non-virtual entity in VGE::scale.\n");
| CubitStatus VirtualQueryEngine::scale | ( | GeometryEntity * | ent, |
| ) | [virtual] |
Definition at line 2296 of file VirtualQueryEngine.cpp.
return scale( ent, CubitVector( factor, factor, factor ) );
| ) | [virtual] |
Definition at line 2302 of file VirtualQueryEngine.cpp.
return CompositeEngine::instance().scale( csurf, factors );
return CompositeEngine::instance().scale( ccurve, factors );
| CubitStatus VirtualQueryEngine::set_dbl_option | ( | const char * | opt_name, |
| double | val | ||
Definition at line 2150 of file VirtualQueryEngine.cpp.
PRINT_INFO("VirtualQueryEngine::set_dbl_option\n");
default_error_message( "set_dbl_option()");
| CubitStatus VirtualQueryEngine::set_int_option | ( | const char * | opt_name, |
| int | val | ||
Definition at line 2142 of file VirtualQueryEngine.cpp.
PRINT_INFO("VirtualQueryEngine::set_int_option\n");
default_error_message( "set_int_option()");
| double VirtualQueryEngine::set_sme_resabs_tolerance | ( | double | new_resabs | ) | [protected, virtual] |
Definition at line 2134 of file VirtualQueryEngine.cpp.
PRINT_INFO("VirtualQueryEngine::set_sme_resabs_tolerance\n");
default_error_message( "set_sme_resabs_tolerance()");
return 0;
| CubitStatus VirtualQueryEngine::set_str_option | ( | const char * | opt_name, |
| const char * | val | ||
Definition at line 2158 of file VirtualQueryEngine.cpp.
PRINT_INFO("VirtualQueryEngine::set_str_option\n");
default_error_message( "set_str_option()");
| CubitStatus VirtualQueryEngine::sort_edges | ( | DLIList< RefEdge * > & | edge_list | ) | const |
Definition at line 1253 of file VirtualQueryEngine.cpp.
DLIList<RefEdge*> sorted_edge_list;
RefEdge *first, *current = NULL, *prev;
CubitStatus return_value = CUBIT_SUCCESS;
if( edge_list.size( ) <= 0 )
if( edge_list.size() == 1 )
//Note: this part badly needs some optimization. Given the array-based
// implementation of the DLList class, this is a very inefficient
// approach to sorting the edges. Look into a different seach
// algorithm, and possible switching functions in DLList.
//add first Curve
edge_list.reset( );
first = prev = edge_list.remove( );
sorted_edge_list.append( first );
//sort the rest of the Curves
int i;
for( i = 0; i < edge_list.size( ); i++ ) //loop for each remaining RefEdge
edge_list.reset( );
//look through list for next RefEdge
for( int j = 0; j < edge_list.size( ); j++ )
current = edge_list.get( );
if( prev->common_ref_vertex( current ) != NULL )
sorted_edge_list.append( current );
i--; //edge_list.size() decreases with removal of edge
prev = current;
break;
else if( first->common_ref_vertex( current ) != NULL )
sorted_edge_list.insert_first( current );
first = current;
break;
else
edge_list.step( );
}//end for(j)
}//end for(i)
//check if all the RefEdges got sorted
if( edge_list.size( ) > 0 )
return_value = CUBIT_FAILURE;
//Sort the rest of the edges anyway, for use by
//other functions than composite edge creation.
sort_edges( edge_list );
edge_list.reset( );
for( i = 0; i < edge_list.size(); i++ )
current = edge_list.get_and_step( );
else
edge_list.clean_out( );
edge_list = sorted_edge_list;
edge_list.reset( );
return return_value;
| CubitStatus VirtualQueryEngine::transform_vec_position | ( | CubitVector const & | position_vector, |
| BodySM * | OSME_ptr, | ||
| CubitVector & | transformed_vector | ||
Definition at line 172 of file VirtualQueryEngine.cpp.
| CubitStatus VirtualQueryEngine::translate | ( | BodySM * | body, |
| const CubitVector & | offset | ||
| ) | [virtual] |
Definition at line 2201 of file VirtualQueryEngine.cpp.
return PartitionEngine::instance().translate( part, offset );
return CompositeEngine::instance().translate( comp, offset );
PRINT_ERROR("Non-virtual entity in VGE::translate.\n");
| CubitStatus VirtualQueryEngine::translate | ( | GeometryEntity * | ent, |
| ) | [virtual] |
Definition at line 2267 of file VirtualQueryEngine.cpp.
return CompositeEngine::instance().translate( csurf, offset );
return CompositeEngine::instance().translate( ccurve, offset );
| CubitBoolean VirtualQueryEngine::volumes_overlap | ( | Lump * | lump1, |
| Lump * | lump2 | ||
Definition at line 2331 of file VirtualQueryEngine.cpp.
PartitionLump* partition_lump1 = dynamic_cast<PartitionLump*>(lump1);
PartitionLump* partition_lump2 = dynamic_cast<PartitionLump*>(lump2);
Lump *tmp_lump1 = lump1;
if( partition_lump1 )
tmp_lump1 = partition_lump1->real_lump();
Lump *tmp_lump2 = lump2;
if( partition_lump2 )
tmp_lump2 = partition_lump2->real_lump();
GeometryQueryEngine *gqe = tmp_lump1->get_geometry_query_engine();
if( gqe != tmp_lump2->get_geometry_query_engine() )
return CUBIT_FALSE;
return gqe->volumes_overlap( tmp_lump1, tmp_lump2 );
VirtualQueryEngine * VirtualQueryEngine::instance_ = NULL [static, protected] |
Definition at line 298 of file VirtualQueryEngine.hpp.
const double VirtualQueryEngine::param_epsilon_fraction = 1000000 [static] |
Definition at line 82 of file VirtualQueryEngine.hpp.
const int VirtualQueryEngine::VGE_MAJOR_VERSION = 10 [static, private] |
Definition at line 394 of file VirtualQueryEngine.hpp.
const int VirtualQueryEngine::VGE_MINOR_VERSION = 0 [static, private] |
Definition at line 395 of file VirtualQueryEngine.hpp.
const int VirtualQueryEngine::VGE_SUBMINOR_VERSION = 0 [static, private] |
Definition at line 396 of file VirtualQueryEngine.hpp.
