cgma
00001 //------------------------------------------------------------------------- 00002 // Filename : VirtualQueryEngine.hpp 00003 // 00004 // Purpose : Interface for creation/destruction of CompositeEntities. 00005 // 00006 // Special Notes : This is not a complete modeling engine. This class is 00007 // a container of functions for interaction with 00008 // CompositeEntities 00009 // 00010 // Creator : Jason Kraftcheck 00011 // 00012 // Creation Date : 7/31/97 00013 //------------------------------------------------------------------------- 00014 00015 #ifndef VIRTUAL_GEOMETRY_ENGINE_HPP 00016 #define VIRTUAL_GEOMETRY_ENGINE_HPP 00017 00018 // ********** BEGIN STANDARD INCLUDES ********** 00019 // ********** END STANDARD INCLUDES ********** 00020 00021 // ********** BEGIN MOTIF INCLUDES ********** 00022 // ********** END MOTIF INCLUDES ********** 00023 00024 // ********** BEGIN OPEN INVENTOR INCLUDES ********** 00025 // ********** END OPEN INVENTOR INCLUDES ********** 00026 00027 // ********** BEGIN CUBIT INCLUDES ********** 00028 00029 #include "GeometryQueryEngine.hpp" 00030 #include "CubitDefines.h" 00031 #include "GeometryDefines.h" 00032 #include "CubitString.hpp" 00033 #include "CubitVector.hpp" 00034 00035 // ********** END CUBIT INCLUDES ********** 00036 00037 // ********** BEGIN FORWARD DECLARATIONS ********** 00038 class BasicTopologyEntity; 00039 class Body; 00040 class RefVolume; 00041 class RefEdge; 00042 class RefFace; 00043 class RefVertex; 00044 class TBPoint; 00045 class Curve; 00046 class GMem; 00047 template <class X> class DLIList; 00048 class RefEntity; 00049 class Body; 00050 class CubitVector; 00051 class TopologyEntity; 00052 class CoEdge; 00053 00054 class CompositeCurve; 00055 class CompositeSurface; 00056 class PartitionCurve; 00057 class PartitionSurface; 00058 00059 // ********** END FORWARD DECLARATIONS ********** 00060 00061 // ********** BEGIN MACRO DEFINITIONS ********** 00062 // ********** END MACRO DEFINITIONS ********** 00063 00064 // ********** BEGIN ENUM DEFINITIONS ********** 00065 00066 class VirtualQueryEngine : public GeometryQueryEngine 00067 { 00068 00069 public: 00070 00071 virtual int curve_is_on_ignored_surface(Curve *curve, 00072 Surface *surf); 00073 void remove_virtual_geometry( RefEntity* entity_ptr, 00074 CubitBoolean all_children ); 00075 void remove_virtual_geometry( Body* body, bool all_children ); 00076 void remove_virtual_geometry( RefVolume* vol, bool all_children ); 00077 void remove_virtual_geometry( RefFace* face ); 00078 //- Remove all possible virtual geometry from the passed 00079 //- entity and its children. 00080 00081 00082 static const double param_epsilon_fraction; 00083 //- This value is used to determine epsilon for 00084 //- compensating for rounding error in parameter 00085 //- conversion between virtaul geometry and real 00086 //- geometry. 00087 00088 inline static VirtualQueryEngine* instance(); 00089 //R CompositeModelingeEngine 00090 //R- A pointer to the single instance of this class 00091 //- Access to VirtualQueryEngine must be through this function. 00092 //- This forces single instance of the class. (constructor is protected) 00093 00094 static void delete_instance(); 00095 00096 void register_attributes(); 00097 //- VGE registers attributes required for virtual geometry 00098 // -- only call this once per session 00099 00100 ~VirtualQueryEngine( ); 00101 //- Destructor 00102 00103 virtual const std::type_info& entity_type_info( ) const 00104 { return typeid(VirtualQueryEngine); } 00105 //R- The type of this entity 00106 //- This function returns the type of this class. 00107 00108 const char * modeler_type() 00109 { return "virtual"; } 00110 00111 00112 virtual int get_major_version(); 00113 virtual int get_minor_version(); 00114 virtual int get_subminor_version(); 00115 virtual CubitString get_engine_version_string(); 00116 00117 virtual bool is_intermediate_engine() {return TRUE;} 00118 00119 virtual CubitStatus get_graphics( Surface* surface_ptr, 00120 GMem *gmem, 00121 std::vector<TopologyBridge*> &vertex_edge_to_point_vector, 00122 std::vector<std::pair<TopologyBridge*, std::pair<int,int> > > &facet_edges_on_curves, 00123 unsigned short normal_tolerance, 00124 double distance_tolerance, 00125 double max_edge_length ) const; 00126 00127 virtual CubitStatus get_graphics( Surface* surface_ptr, 00128 GMem* gMem, 00129 unsigned short normal_tolerance, 00130 double distance_tolerance, 00131 double max_edge_length ) const; 00132 //R CubitStatus 00133 //R- CUBIT_SUCCESS/CUBIT_FAILURE 00134 //I ref_face_ptr 00135 //I- The RefFAce for which hoops facetting information will be 00136 //I- gathered. 00137 //O- The number of polygons (triangles) needed for facetting. 00138 //O number_points 00139 //O- The number of points needed for facetting 00140 //O number_Facets 00141 //O- The number of facets needed for facetting. 00142 //O gMem 00143 //O- The sturage place for facets (and points). 00144 //= This function gathersw and outputs facet (and point) 00145 //- information for hoops involved in facetting an RefFace. If 00146 //- all goes well, CUBIT_Success is retuned. 00147 00148 virtual CubitStatus get_graphics( Curve* curve_ptr, 00149 GMem* gMem, 00150 double angle_tolerance=0, 00151 double distance_tolerance=0, 00152 double max_edge_length=0 ) const; 00153 //R CubitStatus 00154 //R- CUBIT_SUCCESS/CUBIT_FAILURE 00155 //I ref_edge_ptr 00156 //I- The RefEdge for which hoops facetting information will be 00157 //I- gathered/ 00158 //O numSteps 00159 //O- The number of edges gathered. 00160 //O gMem 00161 //O- The sturage place for edges involved in facetting. 00162 //I tolerance 00163 //I- The tolerance deviation used when facetting the curve (optional 00164 //I- and currently IGNORED by this engine). 00165 //- This function gathers and outputs edge information for 00166 //- hoops involved in facetting a RefEdge. If all goes well, 00167 //- CUBIT_SUCCESS is returned. Otherwise, CUBIT_FAILURE is retuned. 00168 00169 00170 virtual CubitStatus get_isoparametric_points(Surface* ref_face_ptr, 00171 int &nu, int &nv, 00172 GMem *&gMem) const; 00173 00174 virtual CubitStatus get_u_isoparametric_points(Surface* ref_face_ptr, 00175 double v, int &n, 00176 GMem *&gMem) const; 00177 00178 virtual CubitStatus get_v_isoparametric_points(Surface* ref_face_ptr, 00179 double u, int &n, 00180 GMem *&gMem) const; 00181 00182 virtual CubitStatus transform_vec_position( 00183 CubitVector const& position_vector, 00184 BodySM *OSME_ptr, 00185 CubitVector &transformed_vector ) const; 00186 00187 00188 CubitStatus translate( BodySM* body, const CubitVector& offset ); 00189 CubitStatus rotate ( BodySM* body, const CubitVector& axis, double angle ); 00190 CubitStatus scale ( BodySM* body, double factor ); 00191 CubitStatus scale ( BodySM* body, const CubitVector& factors ); 00192 CubitStatus reflect ( BodySM* body, const CubitVector& axis ); 00193 CubitStatus restore_transform( BodySM* body ); 00194 00195 CubitStatus translate( GeometryEntity* ent, const CubitVector& offset ); 00196 CubitStatus rotate ( GeometryEntity* ent, const CubitVector& axis, double degrees ); 00197 CubitStatus scale ( GeometryEntity* ent, double factor ); 00198 CubitStatus scale ( GeometryEntity* ent, const CubitVector& factors ); 00199 CubitStatus reflect ( GeometryEntity* ent, const CubitVector& axis ); 00200 00201 static void get_VEs( RefVolume* volume_ptr, 00202 DLIList<TopologyBridge*>& ve_list, 00203 CubitBoolean visible = CUBIT_FALSE, 00204 const CubitBoolean children_too = CUBIT_TRUE); 00205 static void get_VEs( RefFace* face_ptr, 00206 DLIList<TopologyBridge*>& ve_list, 00207 CubitBoolean visible = CUBIT_FALSE, 00208 const CubitBoolean children_too = CUBIT_TRUE ); 00209 static void get_VEs( RefEdge* edge_ptr, 00210 DLIList<TopologyBridge*>& ve_list, 00211 CubitBoolean visible = CUBIT_FALSE, 00212 const CubitBoolean children_too = CUBIT_TRUE ); 00213 static void get_VEs( RefVertex* vertex_ptr, 00214 DLIList<TopologyBridge*>& ve_list, 00215 CubitBoolean visible = CUBIT_FALSE, 00216 const CubitBoolean children_too = CUBIT_TRUE ); 00217 static void get_VEs( TopologyEntity* te_ptr, 00218 DLIList<TopologyBridge*>& ve_list, 00219 CubitBoolean visible = CUBIT_FALSE, 00220 const CubitBoolean children_too = CUBIT_TRUE ); 00221 //R void 00222 //I te_ptr, volume_ptr, face_ptr, edge_ptr 00223 //I- Entity to query. 00224 //O ve_list 00225 //O- result set. 00226 //I visible 00227 //I- Return only entities visible in the model. 00228 //- Get any virtual geometry of the passed entity or its children. 00229 00230 virtual CubitStatus get_visible_entities( TopologyBridge *hidden_tb, 00231 DLIList<TopologyBridge*> &real_tbs ); 00232 00233 virtual TopologyBridge* get_visible_entity_at_point(TopologyBridge* hidden_tb, CubitVector* point); 00234 //R TopologyBridge* 00235 //I hidden_tb, point 00236 //I- Returns the lowest level visible entity that contains 'point.' (used for fire_ray()) 00237 00238 CubitBoolean virtuals_created() const; 00239 //- returns CUBIT_TRUE if there are virtual entities in the model 00240 00241 static CubitBoolean has_virtual( TopologyEntity* entity); 00242 00243 static CubitBoolean is_virtual(TopologyEntity *entity, 00244 const CubitBoolean children_too = CUBIT_FALSE); 00245 static CubitBoolean is_virtual(DLIList<Body*> &entity_list, 00246 const CubitBoolean children_too = CUBIT_FALSE); 00247 //- returns CUBIT_TRUE if the entities passed in are virtual or 00248 //- contain any virtual entities 00249 00250 static CubitBoolean is_virtual(DLIList<RefEntity*> &entity_list, 00251 const CubitBoolean children_too = CUBIT_FALSE); 00252 //- returns CUBIT_TRUE if the entities passed in are virtual or 00253 //- contain any virtual entities 00254 00255 CubitBoolean is_partition( RefEntity *ref_entity ); 00256 00257 CubitStatus get_sister_partitions( RefEntity *ref_entity, 00258 DLIList<RefEntity*> &sisters); 00259 00260 CubitStatus sort_edges( DLIList<RefEdge*>& edge_list ) const; 00261 //R CubitStatus 00262 //R- CUBIT_SUCCESS/CUBIT_FAILURE 00263 //I edge_list 00264 //I- Input: The list of RefEdges to sort. 00265 //I- Output: The list of sorted RefEdges. 00266 //O composite_sense_wrt_first 00267 //O- The sense of the CompositeCurve relative to the first RefEdge's 00268 //O- Curve geometry object. NOT w.r.t. the RefEdge. 00269 //O- in the SORTED list of RefEdges RETURNED. 00270 //- This function sorts a list of RefEdges using topological 00271 //- information. The RefEdges are sorted such that they form a 00272 //- consecutive chain of edges. CUBIT_SUCCESS is returned if the 00273 //- RefEdges are C0 continous, and CUBIT_FAILURE if they are not. 00274 //- The C0 continuity is checked topologically, which assumes the 00275 //- model is manifold. 00276 00277 static CubitStatus associate_curves( DLIList<Curve*>& target_set, 00278 RefEdge* edge_ptr, 00279 DLIList<Curve*>& reset_set ); 00280 //- Find the subset of target_set that correspond to the curves contained 00281 //- in the passed edge_ptr OR any hosts of the passed edge_ptr. 00282 00283 virtual CubitStatus get_underlying_curves(Curve *curve_ptr, 00284 DLIList<TopologyBridge*>& curve_list); 00285 virtual CubitStatus get_underlying_surfaces(Surface * surf_ptr, 00286 DLIList<TopologyBridge*>& surf_list) ; 00287 virtual CubitStatus get_underlying_bridges(TopologyBridge* bridge_ptr, 00288 DLIList<TopologyBridge*>& bridge_list); 00289 00290 virtual CubitBoolean bodies_overlap (BodySM *body_ptr_1, BodySM *body_ptr_2 ) const; 00291 virtual CubitBoolean volumes_overlap (Lump *lump1, Lump *lump2 ) const; 00292 00293 protected: 00294 00295 VirtualQueryEngine(); 00296 //- Constructor. 00297 00298 static VirtualQueryEngine* instance_; 00299 00300 //**** Display related methods 00301 00302 CubitStatus get_composite_curve_facetting( CompositeCurve* ccurve_ptr, 00303 GMem* gMem, 00304 double angle_tolerance=0, 00305 double distance_tolerance=0, 00306 double max_edge_length=0 ) const; 00307 00308 CubitStatus get_partition_curve_facetting( PartitionCurve* pcurve_ptr, 00309 GMem* gMem, 00310 double angle_tolerance=0, 00311 double distance_tolerance=0, 00312 double max_edge_length=0 ) const; 00313 00314 CubitStatus get_composite_surface_facetting( CompositeSurface* surf_ptr, 00315 GMem* gMem, 00316 std::vector<TopologyBridge*> *vertex_edge_to_point_vector, 00317 std::vector<std::pair<TopologyBridge*, std::pair<int,int> > > *facet_edges_on_curves, 00318 unsigned short normal_tol, 00319 double absolute_tol, 00320 double longest_edge ) const; 00321 00322 CubitStatus get_partition_surface_facetting( PartitionSurface* surf_ptr, 00323 GMem* gMem, 00324 std::vector<TopologyBridge*> *vertex_edge_to_point_vector, 00325 std::vector<std::pair<TopologyBridge*, std::pair<int,int> > > *facet_edges_on_curves, 00326 unsigned short normal_tol, 00327 double absolute_tol, 00328 double longest_edge ) const; 00329 00330 virtual CubitStatus export_solid_model( DLIList<TopologyBridge*>& bridge_list, 00331 const char* file_name, 00332 Model_File_Type file_type, 00333 const CubitString &cubit_version, 00334 ModelExportOptions &export_options ); 00335 00336 virtual CubitStatus export_solid_model( DLIList<TopologyBridge*>& bridge_list, 00337 char*& p_buffer, 00338 int& n_buffer_size, 00339 bool b_export_buffer) 00340 {return CUBIT_FAILURE;} 00341 00342 virtual CubitStatus save_temp_geom_file(DLIList<TopologyBridge*>& bridge_list, 00343 const char *file_name, 00344 const CubitString &cubit_version, 00345 CubitString &created_file, 00346 CubitString &created_file_type); 00347 00348 virtual CubitStatus import_solid_model( 00349 const char* file_name, 00350 Model_File_Type file_type, 00351 DLIList<TopologyBridge*>& imported_entities, 00352 ModelImportOptions &import_options ); 00353 00354 virtual CubitStatus import_solid_model(DLIList<TopologyBridge*> &imported_entities, 00355 const char* pBuffer, 00356 const int n_buffer_size) 00357 {return CUBIT_FAILURE;} 00358 00359 virtual void delete_solid_model_entities(DLIList<BodySM*>&) const; 00360 virtual CubitStatus delete_solid_model_entities( BodySM* body_ptr ) const; 00361 virtual CubitStatus delete_solid_model_entities(Surface* surf_ptr ) const; 00362 virtual CubitStatus delete_solid_model_entities( Curve* curve_ptr ) const; 00363 virtual CubitStatus delete_solid_model_entities( TBPoint* point_ptr ) const; 00364 00365 virtual CubitStatus fire_ray( CubitVector &origin, 00366 CubitVector &direction, 00367 DLIList<TopologyBridge*> &at_entity_list, 00368 DLIList<double> &ray_params, 00369 int max_hits, 00370 double ray_radius, 00371 DLIList<TopologyBridge*> *hit_entity_list=0 ) const; 00372 //- Fire a ray at specified entities, returning the parameters (distances) 00373 //- along the ray and optionally the entities hit. Returned lists are 00374 //- appended to. Input entities can be any of bodies, volumes, faces, 00375 //- edges or vertices. Optionally you can specify the maximum number of 00376 //- hits to return (default = 0 = unlimited), and the ray radius to use for 00377 //- intersecting the entities (default = 0.0 = use modeller default). 00378 //- NOTE: returned entities hit might be "hidden" beneath virtual entities. 00379 //- To resolve to visible entities, use "get_visible_ents_for_hits" 00380 //- in GeometryQueryTool. 00381 00382 virtual double get_sme_resabs_tolerance() const; 00383 virtual double set_sme_resabs_tolerance( double new_resabs ); 00384 00385 virtual CubitStatus set_int_option( const char* opt_name, int val ); 00386 virtual CubitStatus set_dbl_option( const char* opt_name, double val ); 00387 virtual CubitStatus set_str_option( const char* opt_name, const char* val ); 00388 00389 private: 00390 00391 void default_error_message( const char callers_name[] ) const; 00392 //- Error message for inhereted functions which are not implemented. 00393 00394 static const int VGE_MAJOR_VERSION; 00395 static const int VGE_MINOR_VERSION; 00396 static const int VGE_SUBMINOR_VERSION; 00397 00398 public: 00399 virtual CubitStatus get_intersections(Curve* curve, CubitVector &point1, 00400 CubitVector &point2, 00401 DLIList<CubitVector>& intersection_list, 00402 CubitBoolean bounded, 00403 CubitBoolean closest ); 00404 00405 virtual CubitStatus get_intersections( Curve* ref_edge1, Curve* ref_edge2, 00406 DLIList<CubitVector>& intersection_list, 00407 bool bounded = CUBIT_FALSE, 00408 bool closest = CUBIT_FALSE ); 00409 //- Finds the intersections of the two curves. If the bounded flag is 00410 //- true, it finds only those intersections within the parameter range 00411 //- of both curves; otherwise it uses the extensions of the curves. The 00412 //- closest option is currently valid only if both curves are straight, 00413 //- in which case it will return the 2 closest intersection locations, 00414 //- if the straight lines don't actually intersect. The function allocates 00415 //- the CubitVectors in the returned list, so be sure to free them. 00416 //- NOT DEFINED YET IN THIS GEOMETRY ENGINE. 00417 00418 virtual CubitStatus get_intersections( Curve* ref_edge, Surface* ref_face, 00419 DLIList<CubitVector>& intersection_list, 00420 bool bounded = CUBIT_FALSE ); 00421 //- Finds the intersections of the curve and surface. The curve is extended 00422 //- if the bounded flag is not false. The function allocates the CubitVectors 00423 //- in the returned list, so be sure to free them. 00424 //- NOT DEFINED YET IN THIS GEOMETRY ENGINE. 00425 00426 virtual CubitStatus entity_extrema( DLIList<GeometryEntity*> &ref_entity_list, 00427 const CubitVector *dir1, 00428 const CubitVector *dir2, 00429 const CubitVector *dir3, 00430 CubitVector &extrema, 00431 GeometryEntity *&extrema_entity_ptr ); 00432 //- Gets the extrema position along the first given direction. If there 00433 //- is more than one extrema position, the other directions will be used 00434 //- to determine a unique position. Directions 2 and 3 can be NULL. 00435 //- Entities supported include bodies, volumes, surfaces, curves and 00436 //- vertices. The entity the extrema is found on is also returned. 00437 //- NOT DEFINED YET IN THIS GEOMETRY ENGINE. 00438 00439 virtual CubitStatus entity_entity_distance( GeometryEntity *ref_entity_ptr1, 00440 GeometryEntity *ref_entity_ptr2, 00441 CubitVector &pos1, CubitVector &pos2, 00442 double &distance ); 00443 //- Gets the minimum distance between two entities and the closest positions 00444 //- on those entities. Supports vertices, curves, surfaces, volumes and bodies. 00445 //- NOT DEFINED YET IN THIS GEOMETRY ENGINE. 00446 00447 }; 00448 00449 00450 // ********** BEGIN INLINE FUNCTIONS ********** 00451 inline VirtualQueryEngine* VirtualQueryEngine::instance() 00452 { 00453 if( instance_ == NULL ) 00454 { 00455 instance_ = new VirtualQueryEngine; 00456 assert( instance_ != NULL ); 00457 } 00458 00459 return instance_; 00460 } 00461 00462 // ********** END INLINE FUNCTIONS ********** 00463 00464 // ********** BEGIN FRIEND FUNCTIONS ********** 00465 // ********** END FRIEND FUNCTIONS ********** 00466 00467 // ********** BEGIN EXTERN FUNCTIONS ********** 00468 // ********** END EXTERN FUNCTIONS ********** 00469 00470 // ********** BEGIN HELPER CLASS DECLARATIONS ********** 00471 // ********** END HELPER CLASS DECLARATIONS ********** 00472 00473 #endif
