cgma
#include <OctreeIntersectionData.hpp>
Public Member Functions | |
| OctreeIntersectionData (const CubitVector &normal, const CubitBoolean half_space, const double &len, RefFace *ptr_face, const CubitVector &closest_point_on_facet, CubitFacet *lp_facet) | |
| OctreeIntersectionData (CubitOctreeNode *ptr_white_node, CubitVector normal, CubitVector int_point, double len, RefFace *ptr_face) | |
| ~OctreeIntersectionData () | |
| CubitVector | get_normal (void) |
| CubitVector | get_int_point (void) |
| double | get_length (void) |
| RefFace * | get_face (void) |
| CubitOctreeNode * | get_white_node (void) |
| CubitFacet * | get_facet_ptr () |
| CubitBoolean | get_halfspace () |
| CubitVector | get_facet_normal () |
| CubitBoolean | is_merged () |
| void | set_merged (const CubitBoolean val) |
Static Public Member Functions | |
| static int | compare_function (OctreeIntersectionData *&a, OctreeIntersectionData *&b) |
Private Attributes | |
| CubitOctreeNode * | whiteNode |
| CubitVector | facetNormal |
| CubitVector | intPoint |
| double | length |
| RefFace * | refFace |
| CubitFacet * | ptrFacet |
| CubitBoolean | halfSpace |
| CubitBoolean | merged |
Definition at line 24 of file OctreeIntersectionData.hpp.
| OctreeIntersectionData::OctreeIntersectionData | ( | const CubitVector & | normal, |
| const CubitBoolean | half_space, | ||
| const double & | len, | ||
| RefFace * | ptr_face, | ||
| const CubitVector & | closest_point_on_facet, | ||
| CubitFacet * | lp_facet | ||
Definition at line 8 of file OctreeIntersectionData.cpp.
| OctreeIntersectionData::OctreeIntersectionData | ( | CubitOctreeNode * | ptr_white_node, |
| CubitVector | normal, | ||
| CubitVector | int_point, | ||
| double | len, | ||
| RefFace * | ptr_face | ||
Definition at line 19 of file OctreeIntersectionData.cpp.
facetNormal = normal;
intPoint = int_point;
refFace = ptr_face;
length = len;
whiteNode = ptr_white_node;
| OctreeIntersectionData::~OctreeIntersectionData | ( | ) | [inline] |
Definition at line 29 of file OctreeIntersectionData.hpp.
| static int OctreeIntersectionData::compare_function | ( | OctreeIntersectionData *& | a, |
| OctreeIntersectionData *& | b | ||
| ) | [inline, static] |
Definition at line 39 of file OctreeIntersectionData.hpp.
if (a->get_length() < b->get_length()) {return -1;}
else if (a->get_length() > b->get_length()) {return 1;}
else {return 0;}
| RefFace* OctreeIntersectionData::get_face | ( | void | ) | [inline] |
Definition at line 33 of file OctreeIntersectionData.hpp.
{ return refFace; }
| CubitVector OctreeIntersectionData::get_facet_normal | ( | ) | [inline] |
Definition at line 37 of file OctreeIntersectionData.hpp.
{return facetNormal;}
| CubitFacet* OctreeIntersectionData::get_facet_ptr | ( | ) | [inline] |
Definition at line 35 of file OctreeIntersectionData.hpp.
{return ptrFacet;} // for SAT code
| CubitBoolean OctreeIntersectionData::get_halfspace | ( | ) | [inline] |
Definition at line 36 of file OctreeIntersectionData.hpp.
{return halfSpace;} // for SAT code
| CubitVector OctreeIntersectionData::get_int_point | ( | void | ) | [inline] |
Definition at line 31 of file OctreeIntersectionData.hpp.
{return intPoint; }
| double OctreeIntersectionData::get_length | ( | void | ) | [inline] |
Definition at line 32 of file OctreeIntersectionData.hpp.
{ return length; }
| CubitVector OctreeIntersectionData::get_normal | ( | void | ) | [inline] |
Definition at line 30 of file OctreeIntersectionData.hpp.
{ return facetNormal; }
| CubitOctreeNode* OctreeIntersectionData::get_white_node | ( | void | ) | [inline] |
Definition at line 34 of file OctreeIntersectionData.hpp.
{ return whiteNode; }
| CubitBoolean OctreeIntersectionData::is_merged | ( | ) | [inline] |
Definition at line 46 of file OctreeIntersectionData.hpp.
{return merged;}
| void OctreeIntersectionData::set_merged | ( | const CubitBoolean | val | ) | [inline] |
Definition at line 47 of file OctreeIntersectionData.hpp.
{merged = val;}
Definition at line 51 of file OctreeIntersectionData.hpp.
Definition at line 56 of file OctreeIntersectionData.hpp.
CubitVector OctreeIntersectionData::intPoint [private] |
Definition at line 52 of file OctreeIntersectionData.hpp.
double OctreeIntersectionData::length [private] |
Definition at line 53 of file OctreeIntersectionData.hpp.
CubitBoolean OctreeIntersectionData::merged [private] |
Definition at line 57 of file OctreeIntersectionData.hpp.
CubitFacet* OctreeIntersectionData::ptrFacet [private] |
Definition at line 55 of file OctreeIntersectionData.hpp.
RefFace* OctreeIntersectionData::refFace [private] |
Definition at line 54 of file OctreeIntersectionData.hpp.
CubitOctreeNode* OctreeIntersectionData::whiteNode [private] |
Definition at line 50 of file OctreeIntersectionData.hpp.
