cgma
#include <RefEntityFactory.hpp>
Definition at line 46 of file RefEntityFactory.hpp.
| RefEntityFactory::RefEntityFactory | ( | bool | make_lists = true | ) | [protected] |
Definition at line 80 of file RefEntityFactory.cpp.
instance_ = this;
AppUtil::instance()->event_dispatcher().add_observer(this);
if (make_lists) {
refVertexList = new DLIList<RefVertex*>();
refEdgeList = new DLIList<RefEdge*>();
refFaceList = new DLIList<RefFace*>();
refGroupList = new DLIList<RefGroup*>();
refVolumeList = new DLIList<RefVolume*>();
bodyList = new DLIList<Body*>();
register_observer(this);
else {
refVertexList = NULL;
refEdgeList = NULL;
refFaceList = NULL;
refGroupList = NULL;
refVolumeList = NULL;
bodyList = NULL;
refVertexListIsSorted = true;
refEdgeListIsSorted = true;
refFaceListIsSorted = true;
refVolumeListIsSorted = true;
bodyListIsSorted = true;
refGroupListIsSorted = true;
ManageListSorting = true;
reset_ids();
| RefEntityFactory::~RefEntityFactory | ( | ) | [protected, virtual] |
Definition at line 125 of file RefEntityFactory.cpp.
if (refVertexList != NULL) delete refVertexList;
if (refEdgeList != NULL) delete refEdgeList;
if (refFaceList != NULL) delete refFaceList;
if (refGroupList != NULL) delete refGroupList;
if (refVolumeList != NULL) delete refVolumeList;
if (bodyList != NULL) delete bodyList;
unregister_observer(this);
instance_ = NULL;
| void RefEntityFactory::add | ( | RefEntity * | ref_entity | ) | [virtual] |
Definition at line 219 of file RefEntityFactory.cpp.
assert(ref_entity != 0);
RefGroup *group;
RefVolume *volume;
RefFace *face;
RefEdge *edge;
RefVertex *vertex;
Body *body;
if ( (group = CAST_TO(ref_entity, RefGroup)) != NULL ) {
add(group);
else if ( (volume = CAST_TO(ref_entity, RefVolume)) != NULL ) {
add(volume);
else if ( (face = CAST_TO(ref_entity, RefFace)) != NULL ) {
add(face);
else if ( (edge = CAST_TO(ref_entity, RefEdge)) != NULL ) {
add(edge);
else if ( (vertex = CAST_TO(ref_entity, RefVertex)) != NULL ) {
add(vertex);
else if ( (body = CAST_TO(ref_entity, Body)) != NULL ) {
add(body);
| void RefEntityFactory::add | ( | Body * | bodyPtr | ) | [virtual] |
Definition at line 263 of file RefEntityFactory.cpp.
| void RefEntityFactory::add | ( | RefVolume * | refVolumePtr | ) | [virtual] |
Definition at line 276 of file RefEntityFactory.cpp.
assert(!refVolumeList->is_in_list(refVPtr));
if(refVolumeList->size() > 0)
refVolumeList->last();
if(ManageListSorting && refVPtr->id() < refVolumeList->get()->id())
refVolumeListIsSorted = false;
refVolumeList->append(refVPtr);
if (refVPtr->id() > maxRefVolumeId)
maxRefVolumeId = refVPtr->id();
| void RefEntityFactory::add | ( | RefGroup * | refGroupPtr | ) | [virtual] |
Definition at line 250 of file RefEntityFactory.cpp.
assert(!refGroupList->is_in_list(refGPtr));
if(refGroupList->size() > 0)
refGroupList->last();
if(ManageListSorting && refGPtr->id() < refGroupList->get()->id())
refGroupListIsSorted = false;
refGroupList->append(refGPtr);
if (refGPtr->id() > maxRefGroupId) maxRefGroupId = refGPtr->id();
| void RefEntityFactory::add | ( | RefFace * | refFacePtr | ) | [virtual] |
Definition at line 290 of file RefEntityFactory.cpp.
assert(!refFaceList->is_in_list(refFPtr));
if(refFaceList->size() > 0)
refFaceList->last();
if(ManageListSorting && refFPtr->id() < refFaceList->get()->id())
refFaceListIsSorted = false;
refFaceList->append(refFPtr);
if (refFPtr->entityId > maxRefFaceId)
maxRefFaceId = refFPtr->entityId;
| void RefEntityFactory::add | ( | RefEdge * | refEdgePtr | ) | [virtual] |
Definition at line 304 of file RefEntityFactory.cpp.
assert(!refEdgeList->is_in_list(refEPtr));
if(refEdgeList->size() > 0)
refEdgeList->last();
if(ManageListSorting && refEPtr->id() < refEdgeList->get()->id())
refEdgeListIsSorted = false;
refEdgeList->append(refEPtr);
if (refEPtr->id() > maxRefEdgeId)
maxRefEdgeId = refEPtr->id();
| void RefEntityFactory::add | ( | RefVertex * | refVertexPtr | ) | [virtual] |
Definition at line 318 of file RefEntityFactory.cpp.
assert(!refVertexList->is_in_list(refVPtr));
if(refVertexList->size() > 0)
refVertexList->last();
if(ManageListSorting && refVPtr->id() < refVertexList->get()->id())
refVertexListIsSorted = false;
refVertexList->append(refVPtr);
if (refVPtr->id() > maxRefVertexId)
maxRefVertexId = refVPtr->id();
| void RefEntityFactory::bodies | ( | DLIList< Body * > & | bodies | ) | [virtual] |
Definition at line 436 of file RefEntityFactory.cpp.
bodies = *bodyList;
| void RefEntityFactory::compress_ids | ( | DLIList< CubitEntity * > & | list | ) | [static] |
Definition at line 1110 of file RefEntityFactory.cpp.
int id = 1;
CubitEntity* entity;
if (list.size())
list.reset();
// if these are ref volumes, recompute color
CubitBoolean set_color = CUBIT_FALSE;
if (CAST_TO(list.get(), RefVolume)) set_color = CUBIT_TRUE;
// sort list so ids of entities are ascending order
list.sort( sort_by_ascending_ids);
for (int i=list.size(); i > 0; i--)
entity = list.get_and_step();
if (entity->id() != id){
entity->set_id(id);
if (set_color) {
entity->color(CUBIT_DEFAULT_COLOR_INDEX);
id++;
| void RefEntityFactory::compress_ref_ids | ( | const char * | entity_type, |
| int | retain_max_id | ||
Definition at line 1061 of file RefEntityFactory.cpp.
const std::type_info& type = RefEntity::get_entity_type_info(entity_type);
assert(type != typeid(InvalidEntity));
#ifdef VIRTUAL_GEOMETRY_ENGINE_HPP
VirtualGeometryEngine::instance()->
hidden_entity_mngr.compress_hidden_ids(type);
#endif
DLIList<GeometryQueryEngine*> gqeList;
GeometryQueryTool::instance()->get_gqe_list(gqeList);//Get the gqeList from the GQT
gqeList.reset();
int i;
for (i = 0; i < gqeList.size(); i++)//Step through the list and call compress_ids.
{ //The VGE is the only engine that will do work.
gqeList.get_and_step()->compress_ids(type);
DLIList<CubitEntity*> list;
DLIList<RefEntity*> temp_list;
CubitStatus result = ref_entity_list(entity_type, temp_list, CUBIT_FALSE);
if ( result == CUBIT_SUCCESS ) {
CAST_LIST_TO_PARENT(temp_list, list);
compress_ids(list);
// set the maximum entity id to the new max values.
if (!retain_max_id)
// must use the num_xxx() functions here, since we may have a derived factory!
if( type == typeid(RefGroup) )
maxRefGroupId = num_ref_groups();
else if( type == typeid(Body) )
maxBodyId = num_bodies();
else if( type == typeid(RefVolume) )
maxRefVolumeId = num_ref_volumes();
else if( type == typeid(RefFace) )
maxRefFaceId = num_ref_faces();
else if( type == typeid(RefEdge) )
maxRefEdgeId = num_ref_edges();
else if( type == typeid(RefVertex) )
maxRefVertexId = num_ref_vertices();
| Body * RefEntityFactory::construct_Body | ( | BodySM * | body_sm = NULL | ) | [virtual] |
Definition at line 165 of file RefEntityFactory.cpp.
Body *temp = new Body(body_sm);
AppUtil::instance()->send_event(GeometryEvent(GeometryEvent::TOPOLOGY_ENTITY_CONSTRUCTED, temp));
return temp;
| RefEdge * RefEntityFactory::construct_RefEdge | ( | Curve * | curve = NULL | ) | [virtual] |
Definition at line 144 of file RefEntityFactory.cpp.
RefEdge *temp = new RefEdge(curve);
return temp;
| RefFace * RefEntityFactory::construct_RefFace | ( | Surface * | surface = NULL | ) | [virtual] |
Definition at line 151 of file RefEntityFactory.cpp.
RefFace *temp = new RefFace(surface);
return temp;
| RefGroup * RefEntityFactory::construct_RefGroup | ( | const char * | name = NULL | ) | [virtual] |
Definition at line 172 of file RefEntityFactory.cpp.
RefGroup *temp = new RefGroup(name);
return temp;
| RefGroup * RefEntityFactory::construct_RefGroup | ( | DLIList< RefEntity * > & | entity_list | ) | [virtual] |
Definition at line 179 of file RefEntityFactory.cpp.
RefGroup *temp = new RefGroup(entity_list);
return temp;
| RefVertex * RefEntityFactory::construct_RefVertex | ( | TBPoint * | point = NULL | ) | [virtual] |
Definition at line 137 of file RefEntityFactory.cpp.
RefVertex *temp = new RefVertex(point);
return temp;
| RefVolume * RefEntityFactory::construct_RefVolume | ( | Lump * | lump = NULL | ) | [virtual] |
Definition at line 158 of file RefEntityFactory.cpp.
RefVolume *temp = new RefVolume(lump);
return temp;
| int RefEntityFactory::current_body_id | ( | ) | [inline] |
Definition at line 151 of file RefEntityFactory.hpp.
{return maxBodyId;};
| int RefEntityFactory::current_edge_id | ( | ) | [inline] |
Definition at line 155 of file RefEntityFactory.hpp.
{return maxRefEdgeId;};
| int RefEntityFactory::current_face_id | ( | ) | [inline] |
Definition at line 154 of file RefEntityFactory.hpp.
{return maxRefFaceId;};
| int RefEntityFactory::current_group_id | ( | ) | [inline] |
Definition at line 153 of file RefEntityFactory.hpp.
{return maxRefGroupId;};
| int RefEntityFactory::current_vertex_id | ( | ) | [inline] |
Definition at line 156 of file RefEntityFactory.hpp.
{return maxRefVertexId;};
| int RefEntityFactory::current_volume_id | ( | ) | [inline] |
Definition at line 152 of file RefEntityFactory.hpp.
{return maxRefVolumeId;};
| void RefEntityFactory::delete_instance | ( | ) | [static] |
Definition at line 116 of file RefEntityFactory.cpp.
| Body * RefEntityFactory::get_body | ( | int | id | ) | [virtual] |
Definition at line 539 of file RefEntityFactory.cpp.
if (!bodyList->size())
return NULL;
// Make sure the list is sorted for the binary search.
if(ManageListSorting && !bodyListIsSorted)
bodyList->sort(sort_by_ascending_ids);
// Do a binary search on the sorted list. We are making the assumption
// here that there are no NULL entries in the list.
bool found = false;
int left_index = 0;
int right_index = bodyList->size()-1;
int mid_index = (left_index + right_index)/2;
int mid_id = ((*bodyList)[mid_index])->id();
while(!found && (right_index-left_index) > 1)
if(mid_id == id)
found = true;
else
if(mid_id > id)
right_index = mid_index;
else
left_index = mid_index;
if(!found)
if(((*bodyList)[left_index])->id() == id)
return ((*bodyList)[left_index]);
else if(((*bodyList)[right_index])->id() == id)
return ((*bodyList)[right_index]);
else
return ((*bodyList)[mid_index]);
return NULL ;
| Body * RefEntityFactory::get_first_body | ( | ) | [virtual] |
| RefEdge * RefEntityFactory::get_first_ref_edge | ( | ) | [virtual] |
Definition at line 896 of file RefEntityFactory.cpp.
refEdgeList->reset();
return refEdgeList->size() ? refEdgeList->get() : 0;
| RefFace * RefEntityFactory::get_first_ref_face | ( | ) | [virtual] |
Definition at line 890 of file RefEntityFactory.cpp.
refFaceList->reset();
return refFaceList->size() ? refFaceList->get() : 0;
| RefGroup * RefEntityFactory::get_first_ref_group | ( | ) | [virtual] |
Definition at line 884 of file RefEntityFactory.cpp.
refGroupList->reset();
return refGroupList->size() ? refGroupList->get() : 0;
| RefVertex * RefEntityFactory::get_first_ref_vertex | ( | ) | [virtual] |
Definition at line 902 of file RefEntityFactory.cpp.
refVertexList->reset();
return refVertexList->size() ? refVertexList->get() : 0;
| RefVolume * RefEntityFactory::get_first_ref_volume | ( | ) | [virtual] |
Definition at line 878 of file RefEntityFactory.cpp.
refVolumeList->reset();
return refVolumeList->size() ? refVolumeList->get() : 0;
| Body * RefEntityFactory::get_last_body | ( | ) | [virtual] |
| RefEdge * RefEntityFactory::get_last_ref_edge | ( | ) | [virtual] |
Definition at line 951 of file RefEntityFactory.cpp.
| RefFace * RefEntityFactory::get_last_ref_face | ( | ) | [virtual] |
Definition at line 945 of file RefEntityFactory.cpp.
| RefGroup * RefEntityFactory::get_last_ref_group | ( | ) | [virtual] |
Definition at line 939 of file RefEntityFactory.cpp.
| RefVertex * RefEntityFactory::get_last_ref_vertex | ( | ) | [virtual] |
Definition at line 957 of file RefEntityFactory.cpp.
| RefVolume * RefEntityFactory::get_last_ref_volume | ( | ) | [virtual] |
Definition at line 933 of file RefEntityFactory.cpp.
| Body * RefEntityFactory::get_next_body | ( | ) | [virtual] |
Definition at line 909 of file RefEntityFactory.cpp.
{return bodyList->size() ? bodyList->step_and_get() : 0;}
| RefEdge * RefEntityFactory::get_next_ref_edge | ( | ) | [virtual] |
Definition at line 921 of file RefEntityFactory.cpp.
{return refEdgeList->size() ? refEdgeList->step_and_get() : 0;}
| RefFace * RefEntityFactory::get_next_ref_face | ( | ) | [virtual] |
Definition at line 918 of file RefEntityFactory.cpp.
{return refFaceList->size() ? refFaceList->step_and_get() : 0;}
| RefGroup * RefEntityFactory::get_next_ref_group | ( | ) | [virtual] |
Definition at line 915 of file RefEntityFactory.cpp.
{return refGroupList->size() ? refGroupList->step_and_get() : 0;}
| RefVertex * RefEntityFactory::get_next_ref_vertex | ( | ) | [virtual] |
Definition at line 924 of file RefEntityFactory.cpp.
{return refVertexList->size() ? refVertexList->step_and_get() : 0;}
| RefVolume * RefEntityFactory::get_next_ref_volume | ( | ) | [virtual] |
Definition at line 912 of file RefEntityFactory.cpp.
{return refVolumeList->size() ? refVolumeList->step_and_get() : 0;}
| RefEdge * RefEntityFactory::get_ref_edge | ( | int | id | ) | [virtual] |
Definition at line 731 of file RefEntityFactory.cpp.
if (!refEdgeList->size())
return NULL;
if(ManageListSorting && !refEdgeListIsSorted)
refEdgeList->sort(sort_by_ascending_ids);
bool found = false;
int left_index = 0;
int right_index = refEdgeList->size()-1;
int mid_id = ((*refEdgeList)[mid_index])->id();
if(mid_id == id)
found = true;
else
if(mid_id > id)
else
if(!found)
if(((*refEdgeList)[left_index])->id() == id)
return ((*refEdgeList)[left_index]);
else if(((*refEdgeList)[right_index])->id() == id)
return ((*refEdgeList)[right_index]);
else
return ((*refEdgeList)[mid_index]);
return NULL ;
| RefEntity * RefEntityFactory::get_ref_entity | ( | const char * | type, |
| int | id | ||
| ) | [virtual] |
Definition at line 485 of file RefEntityFactory.cpp.
// Call the right function, cast it.
switch( toupper(*type_string) )
case 'B':
if( !strcmp(type_string+1,"ody") )
return get_body(id);
break;
case 'V':
if( !strcmp(type_string+1,"olume" ) )
return get_ref_volume(id);
else if(!strcmp(type_string+1,"ertex") )
return get_ref_vertex(id);
break;
case 'S':
if( !strcmp(type_string+1,"urface") )
return get_ref_face(id);
break;
case 'C':
if( !strcmp(type_string+1,"urve") )
return get_ref_edge(id);
break;
case 'G':
if( !strcmp(type_string+1,"roup") )
return get_ref_group(id);
break;
PRINT_ERROR("Invalid list type for the get_ref_entity "
"function: %s\n", type_string);
return NULL;
| RefEntity * RefEntityFactory::get_ref_entity | ( | const std::type_info & | type, |
| int | id | ||
| ) | [virtual] |
Definition at line 519 of file RefEntityFactory.cpp.
return CAST_TO(get_ref_group(id), RefEntity);
return CAST_TO(get_body(id), RefEntity);
return CAST_TO(get_ref_volume(id), RefEntity);
return CAST_TO(get_ref_face(id), RefEntity);
return CAST_TO(get_ref_edge(id), RefEntity);
return CAST_TO(get_ref_vertex(id), RefEntity);
return NULL;
| RefFace * RefEntityFactory::get_ref_face | ( | int | id | ) | [virtual] |
Definition at line 683 of file RefEntityFactory.cpp.
if (!refFaceList->size())
return NULL;
if(ManageListSorting && !refFaceListIsSorted)
refFaceList->sort(sort_by_ascending_ids);
bool found = false;
int left_index = 0;
int right_index = refFaceList->size()-1;
int mid_id = ((*refFaceList)[mid_index])->id();
if(mid_id == id)
found = true;
else
if(mid_id > id)
else
if(!found)
if(((*refFaceList)[left_index])->id() == id)
return ((*refFaceList)[left_index]);
else if(((*refFaceList)[right_index])->id() == id)
return ((*refFaceList)[right_index]);
else
return ((*refFaceList)[mid_index]);
return NULL ;
| RefGroup * RefEntityFactory::get_ref_group | ( | int | id | ) | [virtual] |
Definition at line 587 of file RefEntityFactory.cpp.
if (!refGroupList->size())
return NULL;
if(ManageListSorting && !refGroupListIsSorted)
refGroupList->sort(sort_by_ascending_ids);
bool found = false;
int left_index = 0;
int right_index = refGroupList->size()-1;
int mid_id = ((*refGroupList)[mid_index])->id();
if(mid_id == id)
found = true;
else
if(mid_id > id)
else
if(!found)
if(((*refGroupList)[left_index])->id() == id)
return ((*refGroupList)[left_index]);
else if(((*refGroupList)[right_index])->id() == id)
return ((*refGroupList)[right_index]);
else
return ((*refGroupList)[mid_index]);
return NULL ;
| RefVertex * RefEntityFactory::get_ref_vertex | ( | int | id | ) | [virtual] |
Definition at line 779 of file RefEntityFactory.cpp.
if (!refVertexList->size())
return NULL;
if(ManageListSorting && !refVertexListIsSorted)
refVertexList->sort(sort_by_ascending_ids);
bool found = false;
int left_index = 0;
int right_index = refVertexList->size()-1;
int mid_id = ((*refVertexList)[mid_index])->id();
if(mid_id == id)
found = true;
else
if(mid_id > id)
else
if(!found)
if(((*refVertexList)[left_index])->id() == id)
return ((*refVertexList)[left_index]);
else if(((*refVertexList)[right_index])->id() == id)
return ((*refVertexList)[right_index]);
else
return ((*refVertexList)[mid_index]);
return NULL ;
| RefVolume * RefEntityFactory::get_ref_volume | ( | int | id | ) | [virtual] |
Definition at line 635 of file RefEntityFactory.cpp.
if (!refVolumeList->size())
return NULL;
if(ManageListSorting && !refVolumeListIsSorted)
refVolumeList->sort(sort_by_ascending_ids);
bool found = false;
int left_index = 0;
int right_index = refVolumeList->size()-1;
int mid_id = ((*refVolumeList)[mid_index])->id();
if(mid_id == id)
found = true;
else
if(mid_id > id)
else
if(!found)
if(((*refVolumeList)[left_index])->id() == id)
return ((*refVolumeList)[left_index]);
else if(((*refVolumeList)[right_index])->id() == id)
return ((*refVolumeList)[right_index]);
else
return ((*refVolumeList)[mid_index]);
return NULL ;
| void RefEntityFactory::incorporate_id | ( | RefEntity * | ref_ent | ) |
Definition at line 963 of file RefEntityFactory.cpp.
if (ref_ent)
//________ Change Code by DZ of Cat, 3/17/99 10:47:39 AM ________
int max_ent_id = 0;
max_ent_id = ref_ent->id();
// Do nothing with groups
if( CAST_TO( ref_ent, RefGroup ) ) {
if (maxRefGroupId < max_ent_id)
maxRefGroupId = max_ent_id;
else if( CAST_TO( ref_ent, Body ) )
if (maxBodyId < max_ent_id)
maxBodyId = max_ent_id;
else if( CAST_TO( ref_ent, RefVolume ) )
if (maxRefVolumeId < max_ent_id)
maxRefVolumeId = max_ent_id;
else if( CAST_TO( ref_ent, RefFace ) )
if (maxRefFaceId < max_ent_id)
maxRefFaceId = max_ent_id;
else if( CAST_TO( ref_ent, RefEdge ) )
if (maxRefEdgeId < max_ent_id)
maxRefEdgeId = max_ent_id;
else if( CAST_TO( ref_ent, RefVertex ) )
if (maxRefVertexId < max_ent_id)
maxRefVertexId = max_ent_id;
//________ Change End by DZ of Cat, 3/17/99 10:47:39 AM ________
| RefEntityFactory * RefEntityFactory::instance | ( | void | ) | [static] |
Definition at line 71 of file RefEntityFactory.cpp.
if (instance_ == NULL) {
new RefEntityFactory();
return instance_;
| int RefEntityFactory::maximum_id | ( | const char * | entity_type | ) |
Definition at line 1005 of file RefEntityFactory.cpp.
if (strcmp("body", entity_type) == 0)
return maxBodyId;
else if (strcmp("curve", entity_type) == 0)
else if (strcmp("group", entity_type) == 0)
else if (strcmp("volume", entity_type) == 0)
else if (strcmp("vertex", entity_type) == 0)
else if (strcmp("surface", entity_type) == 0)
else {
PRINT_ERROR("Unrecognized entity_type: '%s'\n", entity_type);
return 0;
| int RefEntityFactory::maximum_id | ( | RefEntity * | ref_ent | ) |
Definition at line 1041 of file RefEntityFactory.cpp.
if (!ref_ent)
return 0;
else if( CAST_TO( ref_ent, RefGroup ) )
return maxBodyId;
else
return 0;
| void RefEntityFactory::maximum_id | ( | const std::type_info & | type, |
| int | max_id | ||
Definition at line 1025 of file RefEntityFactory.cpp.
maxRefGroupId = max_id;
maxBodyId = max_id;
maxRefVolumeId = max_id;
maxRefFaceId = max_id;
maxRefEdgeId = max_id;
maxRefVertexId = max_id;
| int RefEntityFactory::next_body_id | ( | ) |
Definition at line 830 of file RefEntityFactory.cpp.
return ++maxBodyId;
Definition at line 850 of file RefEntityFactory.cpp.
return ++maxRefEdgeId;
Definition at line 845 of file RefEntityFactory.cpp.
return ++maxRefFaceId;
Definition at line 835 of file RefEntityFactory.cpp.
return ++maxRefGroupId;
Definition at line 855 of file RefEntityFactory.cpp.
return ++maxRefVertexId;
Definition at line 840 of file RefEntityFactory.cpp.
return ++maxRefVolumeId;
| void RefEntityFactory::notify_observer | ( | const CubitEvent * | observer_event | ) | [virtual] |
Implements CubitObserver.
Definition at line 1179 of file RefEntityFactory.cpp.
const GeometryEvent* geom_event = dynamic_cast<const GeometryEvent*>(observer_event);
if(!geom_event)
return;
RefEntity* entity = geom_event->get_entity();
//- handle MODEL_ENTITY_DESTRUCTED/MODEL_ENTITY_CONSTRUCTED events
if (geom_event->get_type() == GeometryEvent::TOPOLOGY_ENTITY_CONSTRUCTED)
add(entity);
else if (geom_event->get_type() == GeometryEvent::TOPOLOGY_ENTITY_DESTRUCTED)
remove(entity);
else if (geom_event->get_type() == GeometryEvent::ID_SET)
if(CAST_TO(entity, RefEdge) && ManageListSorting)
else if(CAST_TO(entity, RefFace) && ManageListSorting)
else if(CAST_TO(entity, RefVertex) && ManageListSorting)
else if(CAST_TO(entity, RefVolume) && ManageListSorting)
else if(CAST_TO(entity, RefGroup) && ManageListSorting)
else if(CAST_TO(entity, Body) && ManageListSorting)
bodyListIsSorted = false;
| int RefEntityFactory::num_bodies | ( | ) | const [virtual] |
Definition at line 478 of file RefEntityFactory.cpp.
| int RefEntityFactory::num_ref_edges | ( | ) | const [virtual] |
Definition at line 482 of file RefEntityFactory.cpp.
{return refEdgeList->size();}
| int RefEntityFactory::num_ref_faces | ( | ) | const [virtual] |
Definition at line 481 of file RefEntityFactory.cpp.
{return refFaceList->size();}
| int RefEntityFactory::num_ref_groups | ( | ) | const [virtual] |
Definition at line 480 of file RefEntityFactory.cpp.
{return refGroupList->size();}
| int RefEntityFactory::num_ref_vertices | ( | ) | const [virtual] |
Definition at line 483 of file RefEntityFactory.cpp.
{return refVertexList->size();}
| int RefEntityFactory::num_ref_volumes | ( | ) | const [virtual] |
Definition at line 479 of file RefEntityFactory.cpp.
{return refVolumeList->size();}
| void RefEntityFactory::ref_edges | ( | DLIList< RefEdge * > & | ref_edges | ) | [virtual] |
Definition at line 456 of file RefEntityFactory.cpp.
ref_edges = *refEdgeList;
| CubitStatus RefEntityFactory::ref_entity_list | ( | char const * | keyword, |
| DLIList< RefEntity * > & | entity_list, | ||
| const CubitBoolean | print_errors = CUBIT_TRUE |
| ) | [virtual] |
Definition at line 186 of file RefEntityFactory.cpp.
if ( !strcmp( keyword, "body" ) || !strcmp( keyword, "Body" )) {
CAST_LIST_TO_PARENT((*bodyList), entity_list) ;
else if ( !strcmp( keyword, "curve" ) || !strcmp( keyword, "Curve" ) ) {
CAST_LIST_TO_PARENT((*refEdgeList), entity_list) ;
else if ( !strcmp( keyword, "volume" ) || !strcmp( keyword, "Volume" ) ) {
CAST_LIST_TO_PARENT((*refVolumeList), entity_list) ;
else if ( !strcmp( keyword, "vertex" ) || !strcmp( keyword, "Vertex" ) ) {
CAST_LIST_TO_PARENT((*refVertexList), entity_list) ;
else if ( !strcmp( keyword, "surface" ) || !strcmp( keyword, "Surface" ) ) {
CAST_LIST_TO_PARENT((*refFaceList), entity_list) ;
else if ( !strcmp( keyword, "group" ) || !strcmp( keyword, "Group" ) ) {
CAST_LIST_TO_PARENT((*refGroupList), entity_list) ;
else
if (print_errors)
PRINT_ERROR("Invalid list type for the ref_entity_list "
"function: %s\n", keyword);
return CUBIT_FAILURE;
return CUBIT_SUCCESS;
| void RefEntityFactory::ref_faces | ( | DLIList< RefFace * > & | ref_faces | ) | [virtual] |
Definition at line 451 of file RefEntityFactory.cpp.
ref_faces = *refFaceList;
| void RefEntityFactory::ref_groups | ( | DLIList< RefGroup * > & | ref_groups | ) | [virtual] |
Definition at line 446 of file RefEntityFactory.cpp.
ref_groups = *refGroupList;
| void RefEntityFactory::ref_vertices | ( | DLIList< RefVertex * > & | ref_vertices | ) | [virtual] |
Definition at line 461 of file RefEntityFactory.cpp.
ref_vertices = *refVertexList;
| void RefEntityFactory::ref_volumes | ( | DLIList< RefVolume * > & | ref_volumes | ) | [virtual] |
Definition at line 441 of file RefEntityFactory.cpp.
ref_volumes = *refVolumeList;
| void RefEntityFactory::remove | ( | RefEntity * | ref_entity | ) | [virtual] |
Definition at line 333 of file RefEntityFactory.cpp.
RefGroup *group;
RefVolume *volume;
RefFace *face;
RefEdge *edge;
RefVertex *vertex;
Body *body;
remove(group);
remove(volume);
remove(face);
remove(edge);
remove(vertex);
remove(body);
| void RefEntityFactory::remove | ( | RefVertex * | refVertexPtr | ) | [virtual] |
Definition at line 364 of file RefEntityFactory.cpp.
if (!refVertexList) return;
if (ref_vertex_ptr != NULL)
if (refVertexList->move_to ( ref_vertex_ptr ))
refVertexList->remove ();
else assert(0);
| void RefEntityFactory::remove | ( | RefEdge * | refEdgePtr | ) | [virtual] |
Definition at line 376 of file RefEntityFactory.cpp.
if (!refEdgeList) return;
if (ref_edge_ptr != NULL)
if (refEdgeList->move_to ( ref_edge_ptr ))
refEdgeList->remove ();
else assert(0);
| void RefEntityFactory::remove | ( | RefFace * | refFacePtr | ) | [virtual] |
Definition at line 388 of file RefEntityFactory.cpp.
if (!refFaceList) return;
if (ref_face_ptr != NULL)
if (refFaceList->move_to ( ref_face_ptr ))
refFaceList->remove ();
else assert(0);
| void RefEntityFactory::remove | ( | RefGroup * | refGroupPtr | ) | [virtual] |
Definition at line 412 of file RefEntityFactory.cpp.
if (!refGroupList) return;
if (ref_group_ptr != NULL)
if (refGroupList->move_to ( ref_group_ptr ))
refGroupList->remove ();
else assert(0);
| void RefEntityFactory::remove | ( | RefVolume * | refVolumePtr | ) | [virtual] |
Definition at line 400 of file RefEntityFactory.cpp.
if (!refVolumeList) return;
if (ref_volume_ptr != NULL)
if (refVolumeList->move_to ( ref_volume_ptr ))
refVolumeList->remove ();
else assert(0);
| void RefEntityFactory::remove | ( | Body * | bodyPtr | ) | [virtual] |
| void RefEntityFactory::renumber_geometry_by_properties | ( | CubitBoolean | retain_max_ids | ) | [virtual] |
Definition at line 1165 of file RefEntityFactory.cpp.
// See MRefEntityFactory::renumber_geometry_by_properties.
// If you want this implemented, copy what was done there.
PRINT_ERROR("'Sort' option not supported.\n"
" Compressing IDs without sorting.");
compress_ref_ids("group", retain_max);
compress_ref_ids("body", retain_max);
compress_ref_ids("volume", retain_max);
compress_ref_ids("surface", retain_max);
compress_ref_ids("curve", retain_max);
compress_ref_ids("vertex", retain_max);
| void RefEntityFactory::reset_ids | ( | ) |
Definition at line 1139 of file RefEntityFactory.cpp.
maxBodyId = 0;
maxRefVolumeId = 0;
maxRefGroupId = 0;
maxRefFaceId = 0;
maxRefEdgeId = 0;
maxRefVertexId = 0;
maxSurfSubDomainId = 0;
maxCurveSubDomainId = 0;
maxRefCoordSysId = 0;
#ifdef PROE
maxRefAssemblyId = 0;
maxRefPartId = 0;
#endif
DLIList<Body*>* RefEntityFactory::bodyList [private] |
Definition at line 226 of file RefEntityFactory.hpp.
bool RefEntityFactory::bodyListIsSorted [private] |
Definition at line 218 of file RefEntityFactory.hpp.
RefEntityFactory * RefEntityFactory::instance_ = NULL [static, protected] |
Definition at line 194 of file RefEntityFactory.hpp.
bool RefEntityFactory::ManageListSorting [protected] |
Definition at line 197 of file RefEntityFactory.hpp.
int RefEntityFactory::maxBodyId [protected] |
Definition at line 198 of file RefEntityFactory.hpp.
int RefEntityFactory::maxCurveSubDomainId [protected] |
Definition at line 206 of file RefEntityFactory.hpp.
int RefEntityFactory::maxRefCoordSysId [protected] |
Definition at line 204 of file RefEntityFactory.hpp.
int RefEntityFactory::maxRefEdgeId [protected] |
Definition at line 202 of file RefEntityFactory.hpp.
int RefEntityFactory::maxRefFaceId [protected] |
Definition at line 201 of file RefEntityFactory.hpp.
int RefEntityFactory::maxRefGroupId [protected] |
Definition at line 200 of file RefEntityFactory.hpp.
int RefEntityFactory::maxRefVertexId [protected] |
Definition at line 203 of file RefEntityFactory.hpp.
int RefEntityFactory::maxRefVolumeId [protected] |
Definition at line 199 of file RefEntityFactory.hpp.
int RefEntityFactory::maxSurfSubDomainId [protected] |
Definition at line 205 of file RefEntityFactory.hpp.
DLIList<RefEdge*>* RefEntityFactory::refEdgeList [private] |
Definition at line 222 of file RefEntityFactory.hpp.
bool RefEntityFactory::refEdgeListIsSorted [private] |
Definition at line 215 of file RefEntityFactory.hpp.
DLIList<RefFace*>* RefEntityFactory::refFaceList [private] |
Definition at line 223 of file RefEntityFactory.hpp.
bool RefEntityFactory::refFaceListIsSorted [private] |
Definition at line 216 of file RefEntityFactory.hpp.
DLIList<RefGroup*>* RefEntityFactory::refGroupList [private] |
Definition at line 224 of file RefEntityFactory.hpp.
bool RefEntityFactory::refGroupListIsSorted [private] |
Definition at line 219 of file RefEntityFactory.hpp.
DLIList<RefVertex*>* RefEntityFactory::refVertexList [private] |
Definition at line 221 of file RefEntityFactory.hpp.
bool RefEntityFactory::refVertexListIsSorted [private] |
Definition at line 214 of file RefEntityFactory.hpp.
DLIList<RefVolume*>* RefEntityFactory::refVolumeList [private] |
Definition at line 225 of file RefEntityFactory.hpp.
bool RefEntityFactory::refVolumeListIsSorted [private] |
Definition at line 217 of file RefEntityFactory.hpp.
