cgma
#include <FacetGeometryCreator.hpp>
Public Member Functions | |
| FacetGeometryCreator () | |
| FacetGeometryCreator (DLIList< FacetEntity * > &face_list, DLIList< FacetEntity * > &edge_list, DLIList< FacetEntity * > &point_list) | |
| ~FacetGeometryCreator () | |
| void | print_me () |
Private Member Functions | |
| void | set_up_tool_datas () |
| void | delete_tool_datas () |
| CubitStatus | create_volume_boundaries (DLIList< FacetSurfaceMesh * > &facet_surface_sheets, CubitBoolean use_feature_angle, double min_dot, CubitBoolean split_surfaces) |
| CubitStatus | create_surface_boundaries (DLIList< FacetSurfaceMesh * > &facet_surface_list, DLIList< FacetCurveMesh * > &facet_curve_list, CubitBoolean use_feature_angle, double min_dot) |
| CubitStatus | create_curve_boundaries (DLIList< FacetCurveMesh * > &facet_curve_list, DLIList< FacetPointMesh * > &facet_point_list) |
| CubitStatus | classify_edge (FacetEntity *edge_ptr, DLIList< FacetCurveMesh * > &facet_curve_list, FacetSurfaceMesh *fsm_ptr) |
| CubitStatus | classify_point (CubitPoint *point_ptr, DLIList< FacetPointMesh * > &facet_point_list, FacetCurveMesh *fcm_ptr) |
| CubitStatus | build_geometry (DLIList< FacetSurfaceMesh * > &facet_surface_list, DLIList< FacetCurveMesh * > &facet_curve_list, DLIList< FacetPointMesh * > &facet_point_list, int interp_order, CubitBoolean use_feature_angle, double min_dot, CubitBoolean smooth_non_manifold, CubitBoolean split_surfaces) |
| CubitStatus | build_point_geometry (DLIList< FacetPointMesh * > &facet_point_list) |
| CubitStatus | build_curve_geometry (DLIList< FacetCurveMesh * > &facet_curve_list) |
| CubitStatus | build_loop_geometry (DLIList< FacetCurveMesh * > &facet_curve_list, FacetSurfaceMesh *fsm_ptr, DLIList< LoopSM * > &loop_list, int &ncurves) |
| CubitStatus | build_surface_geometry (DLIList< FacetSurfaceMesh * > &facet_surface_list, int interp_order, double min_dot) |
| CubitStatus | init_hash_curves () |
| void | delete_hash_curves () |
| int | get_curve_hash_key (DLIList< FacetSurfaceMesh * > *bsm_list_ptr) |
| CubitStatus | init_hash_points () |
| void | delete_hash_points () |
| int | get_point_hash_key (DLIList< FacetCurveMesh * > *bsm_list_ptr) |
| CubitStatus | clean_geometry (CubitBoolean smooth_non_manifold, CubitBoolean split_surfaces, CubitBoolean use_feature_angle, double min_dot, DLIList< FacetCurveMesh * > &facet_curve_list) |
Private Attributes | |
| DLIList< FacetEntity * > | faceList |
| DLIList< FacetEntity * > | edgeList |
| DLIList< FacetEntity * > | pointList |
| DLIList< FacetSurfaceMesh * > | facetSurfaceList |
| DLIList< FacetCurveMesh * > | facetCurveList |
| DLIList< FacetPointMesh * > | facetPointList |
| DLIList< FacetCurveMesh * > * | hashCurveArray |
| int | hashCurveSize |
| DLIList< FacetPointMesh * > * | hashPointArray |
| int | hashPointSize |
Definition at line 33 of file FacetGeometryCreator.hpp.
Definition at line 40 of file FacetGeometryCreator.cpp.
hashCurveArray = NULL;
hashCurveSize = 0;
hashPointArray = NULL;
hashPointSize = 0;
| FacetGeometryCreator::FacetGeometryCreator | ( | DLIList< FacetEntity * > & | face_list, |
| DLIList< FacetEntity * > & | edge_list, | ||
| DLIList< FacetEntity * > & | point_list | ||
Definition at line 51 of file FacetGeometryCreator.cpp.
faceList = face_list;
edgeList = edge_list;
pointList = point_list;
set_up_tool_datas();
hashCurveSize = 0;
hashPointSize = 0;
Definition at line 111 of file FacetGeometryCreator.cpp.
delete_tool_datas();
int ii;
//clean up any data remaining.
for (ii = facetPointList.size(); ii > 0; ii-- )
delete facetPointList.remove();
for (ii = facetCurveList.size(); ii > 0; ii-- )
delete facetCurveList.remove();
for (ii = facetSurfaceList.size(); ii > 0; ii-- )
delete facetSurfaceList.remove();
| CubitStatus FacetGeometryCreator::build_curve_geometry | ( | DLIList< FacetCurveMesh * > & | facet_curve_list | ) | [private] |
Definition at line 803 of file FacetGeometryCreator.cpp.
CubitStatus stat = CUBIT_SUCCESS;
int kk;
for ( kk = facet_curve_list.size(); kk > 0; kk-- )
FacetCurveMesh *fcm_ptr = facet_curve_list.get_and_step();
Curve *curv_ptr = fcm_ptr->get_geometric_curve();
if (curv_ptr == NULL)
DLIList<FacetPointMesh*> fpoint_list = fcm_ptr->get_points( );
FacetPointMesh *fpm0_ptr = fpoint_list.get_and_step();
FacetPointMesh *fpm1_ptr = fpoint_list.get_and_step();
CubitPoint *start_point, *end_point;
fcm_ptr->get_ends( start_point, end_point );
if (fpm0_ptr->get_facets() != start_point)
FacetPointMesh *temp_ptr;
temp_ptr = fpm0_ptr;
fpm0_ptr = fpm1_ptr;
fpm1_ptr = temp_ptr;
PointSM *start_ptr = (PointSM *) fpm0_ptr->get_geometric_point();
PointSM *end_ptr = (PointSM *) fpm1_ptr->get_geometric_point();
// if this is a curve without a parent surface then handle it
// differently. (Curves with parents use the surface to evaluate to
// With only a curve, it must evaluate to the curve)
DLIList<FacetSurfaceMesh*> fsm_list = fcm_ptr->get_surfaces();
if (fsm_list.size() == 0)
DLIList<FacetEntity*> facet_list;
DLIList<CubitPoint*> point_list; // needs to be filled in
facet_list = fcm_ptr->get_facets();
DLIList<CubitFacetEdge*> edge_list;
CAST_LIST( facet_list, edge_list, CubitFacetEdge );
if (stat != CUBIT_SUCCESS)
return stat;
stat = FacetQueryEngine::instance()->make_facet_curve( start_ptr, end_ptr,
edge_list, point_list,
curv_ptr );
if (stat == CUBIT_SUCCESS)
CurveSM *curvsm_ptr = CAST_TO( curv_ptr, CurveSM );
GeometryQueryTool::instance()->make_free_RefEdge( curvsm_ptr );
else
curv_ptr );
if ( curv_ptr == NULL || stat != CUBIT_SUCCESS )
PRINT_ERROR("Problems building mesh based curves.\n");
return stat;
fcm_ptr->assign_geometric_curve(curv_ptr);
return stat;
| CubitStatus FacetGeometryCreator::build_geometry | ( | DLIList< FacetSurfaceMesh * > & | facet_surface_list, |
| DLIList< FacetCurveMesh * > & | facet_curve_list, | ||
| DLIList< FacetPointMesh * > & | facet_point_list, | ||
| int | interp_order, | ||
| CubitBoolean | use_feature_angle, | ||
| double | min_dot, | ||
| CubitBoolean | smooth_non_manifold, | ||
| CubitBoolean | split_surfaces | ||
| ) | [private] |
Definition at line 741 of file FacetGeometryCreator.cpp.
stat = build_point_geometry( facet_point_list );
stat = build_curve_geometry( facet_curve_list );
stat = build_surface_geometry( facet_surface_list,
interp_order, min_dot );
if (interp_order == 4)
stat = clean_geometry( smooth_non_manifold, split_surfaces,
use_feature_angle, min_dot, facet_curve_list );
return stat;
| ) | [private] |
| CubitStatus FacetGeometryCreator::build_loop_geometry | ( | DLIList< FacetCurveMesh * > & | facet_curve_list, |
| FacetSurfaceMesh * | fsm_ptr, | ||
| DLIList< LoopSM * > & | loop_list, | ||
| int & | ncurves | ||
| ) | [private] |
Definition at line 872 of file FacetGeometryCreator.cpp.
// find the first unused curve on the list. Use that as the starting curve
// in the loop
ncurves = 0;
int ii, jj;
int found = 0;
FacetCurveMesh *fcm_ptr = NULL;
for(ii=0; ii<facet_curve_list.size() && !found; ii++)
if (fcm_ptr->get_flag() == 0)
found = 1;
if (!found)
return CUBIT_FAILURE; // all the curves have already been used in this surface
// get the first mesh edge on the first curve. use it to determine the
// orientation of the curve with respect to the surface
DLIList<FacetEntity*> facet_list = fcm_ptr->get_facets();
FacetEntity *facet_ptr = facet_list.get();
CubitFacetEdge *edge_ptr = CAST_TO( facet_ptr, CubitFacetEdge );
if (!edge_ptr)
return CUBIT_FAILURE; // facet edges are not on the list ????
// get the adjacent face on this surface
DLIList<FacetEntity*> adj_face_list;
FacetEntity *face_ptr = NULL;
edge_ptr->get_parents( adj_face_list );
found = 0;
for ( jj = 0; jj < adj_face_list.size() && !found; jj++ )
face_ptr = adj_face_list.get_and_step();
TDGeomFacet *td_gm_face = TDGeomFacet::get_geom_facet(face_ptr);
DLIList<FacetSurfaceMesh*> fsurf_list;
td_gm_face->get_facet_surfs( fsurf_list );
FacetSurfaceMesh *face_fsm_ptr = fsurf_list.get();
if(face_fsm_ptr == fsm_ptr)
found = 1;
if (!found)
return CUBIT_FAILURE; // didn't find an adj face on the surface ???
// determine orientation of nodes on this mesh face
CubitPoint *start_ptr, *end_ptr;
fcm_ptr->get_ends( start_ptr, end_ptr );
end_ptr = edge_ptr->other_point( start_ptr );
if (end_ptr == NULL)
return CUBIT_FAILURE; // the edge list may not be ordered correctly??
CubitPoint *points[3];
CubitFacet *tri_ptr = CAST_TO( face_ptr, CubitFacet );
tri_ptr->points( points[0], points[1], points[2] );
found = 0;
CubitSense orientation;
for ( jj = 0; jj < 3 && !found; jj++ )
if (points[jj] == start_ptr)
int next_jj = (jj + 1)%3;
int prev_jj = (jj + 2)%3;
if(points[next_jj] == end_ptr)
found = 1;
orientation = CUBIT_FORWARD;
else if(points[prev_jj] == end_ptr)
found = 1;
orientation = CUBIT_REVERSED;
if (!found)
return CUBIT_FAILURE; // couldn't determine the orientation
// create a new coedge
CoEdgeSM *coedge_ptr = NULL;
stat = GeometryModifyTool::instance()->make_facet_coedge( (CurveSM*)curv_ptr, orientation,
coedge_ptr );
if ( coedge_ptr == NULL || stat != CUBIT_SUCCESS )
PRINT_ERROR("Problems building mesh based coedges.\n");
return stat;
// start a list of coedges for this loop
DLIList<CoEdgeSM*> coedge_list;
coedge_list.append( coedge_ptr );
fcm_ptr->set_flag(1);
FacetCurveMesh *last_fcm_ptr = fcm_ptr;
// loop through and determine the rest of the coedges based on the
// orientation of the first curve in the loop
FacetEntity *n0_ptr, *n1_ptr;
if (orientation == CUBIT_FORWARD)
n0_ptr = start_ptr;
n1_ptr = end_ptr;
else
n1_ptr = start_ptr;
n0_ptr = end_ptr;
while (n0_ptr != n1_ptr)
// find the next curve in the loop
int ntimes = 0;
found = 0;
while(!found)
for ( jj = 0; jj < facet_curve_list.size() && !found; jj++)
if (last_fcm_ptr != fcm_ptr && (fcm_ptr->get_flag() == 0 || ntimes > 0))
if (start_ptr == n1_ptr)
found = 1;
n1_ptr = end_ptr;
else if (end_ptr == n1_ptr)
found = 1;
n1_ptr = start_ptr;
if (!found)
// in this special case - we have gone through the whole list without
// finding the next curve on the loop. In the first pass we have assumed
// that each curve is only used once. This may not be the case. Go
// back and see of we can find a curve that has already been used that
// will work. If we fail the second time through, then we fail!
ntimes++;
if (ntimes > 1)
// return CUBIT_FAILURE; // didn't find the next curve in the loop
// DEBUG ONLY -- THIS NEEDS TO BE FIXED
goto create_loop;
coedge_ptr = NULL;
coedge_ptr );
return stat;
if (coedge_list.size() > 2*facet_curve_list.size())
return CUBIT_FAILURE; // more curves in the loop than their are curves ????
// create the loop
create_loop:
LoopSM *loop_ptr = NULL;
stat = GeometryModifyTool::instance()->make_facet_loop( coedge_list, loop_ptr );
PRINT_ERROR("Problems building mesh based loops.\n");
return stat;
loop_list.append( loop_ptr );
ncurves = coedge_list.size();
return stat;
| ) | [private] |
| CubitStatus FacetGeometryCreator::build_point_geometry | ( | DLIList< FacetPointMesh * > & | facet_point_list | ) | [private] |
Definition at line 772 of file FacetGeometryCreator.cpp.
int kk;
for ( kk = facet_point_list.size(); kk > 0; kk-- )
FacetPointMesh *fpm_ptr = facet_point_list.get_and_step();
Point *point_ptr = fpm_ptr->get_geometric_point();
if (point_ptr == NULL)
FacetEntity *facet_ptr = fpm_ptr->get_facets();
CubitPoint *cp_ptr = CAST_TO( facet_ptr, CubitPoint );
PointSM *point = NULL;
stat = GeometryModifyTool::instance()->make_facet_point( cp_ptr, point );
if ( point == NULL || stat != CUBIT_SUCCESS )
PRINT_ERROR("Problems building mesh based points.\n");
return stat;
point_ptr = (Point *)point;
fpm_ptr->assign_geometric_point(point_ptr);
return stat;
| CubitStatus FacetGeometryCreator::build_surface_geometry | ( | DLIList< FacetSurfaceMesh * > & | facet_surface_list, |
| double | min_dot | ||
| ) | [private] |
Definition at line 1081 of file FacetGeometryCreator.cpp.
int ii, kk;
// make sure the facet flags have been reset
FacetCurveMesh *fcm_ptr;
for ( kk = facet_surface_list.size(); kk > 0; kk-- )
FacetSurfaceMesh *fsm_ptr = facet_surface_list.get_and_step();
fsm_ptr->reset_facet_flags();
// now loop through surfaces and create them
int mydebug = 0;
int num_curves = 0;
DLIList<FacetCurveMesh*> fcurve_list;
fsm_ptr->get_curves( fcurve_list );
// init flags for curves on this surface
for (ii=0; ii< fcurve_list.size(); ii++)
fcm_ptr = fcurve_list.get_and_step();
fcm_ptr->set_flag(0);
if (mydebug)
fcm_ptr->draw();
// generate loops - keep going until we have used all the curves in the list
DLIList<LoopSM*> loop_list;
while (num_curves < fcurve_list.size())
int ncurves = 0;
stat = build_loop_geometry( fcurve_list, fsm_ptr, loop_list, ncurves );
PRINT_ERROR("Can't build geometric loop from facets\n");
return stat;
num_curves += ncurves;
// create the surface
Surface *surf_ptr = fsm_ptr->get_geometric_surface();
if (surf_ptr == NULL)
DLIList<FacetEntity*> facet_entity_list;
fsm_ptr->get_points(point_list);
fsm_ptr->get_facets(facet_entity_list);
DLIList<CubitFacet*> facet_list;
CAST_LIST( facet_entity_list, facet_list, CubitFacet );
stat = GeometryModifyTool::instance()->make_facet_surface(facet_list,
point_list,
loop_list,
interp_order,
min_dot,
surf_ptr);
if ( surf_ptr == NULL || stat != CUBIT_SUCCESS )
PRINT_ERROR("Problems building mesh based surfaces.\n");
return stat;
fsm_ptr->assign_geometric_surface(surf_ptr);
return stat;
| ) | [private] |
| CubitStatus FacetGeometryCreator::classify_edge | ( | FacetEntity * | edge_ptr, |
| FacetSurfaceMesh * | fsm_ptr | ||
| ) | [private] |
Definition at line 434 of file FacetGeometryCreator.cpp.
CubitStatus rv = CUBIT_SUCCESS;
// see if we have already classified this edge (from another surface)
TDGeomFacet *td_gm_edge = TDGeomFacet::get_geom_facet(edge_ptr);
if (td_gm_edge->get_hit_flag() != 0)
return rv;
td_gm_edge->set_hit_flag(1);
// get the surfaces adjacent to this edge
DLIList<FacetSurfaceMesh*> this_fsurf_list;
td_gm_edge->get_facet_surfs( this_fsurf_list );
int this_num_adj = this_fsurf_list.size();
// see if the surfaces defined on this face match any
// of the existing block curves
DLIList<FacetSurfaceMesh*> *fsurf_list_ptr;
int found = 0;
int key = get_curve_hash_key( &this_fsurf_list );
int ii;
for (ii=0; ii<hashCurveArray[key].size() && !found; ii++)
fcm_ptr = hashCurveArray[key].get();
// the first one checked should be the same as the last one checked (don't
// use get_and_step here) This should speed things up
// check if surfaces are the same
fsurf_list_ptr = fcm_ptr->get_surface_list_ptr( );
int num_adj = fsurf_list_ptr->size();
if (num_adj == this_num_adj)
found = 1;
int jj, kk;
for (jj=fsurf_list_ptr->size(); jj>0 && found; jj--)
int same_surf = 0;
FacetSurfaceMesh *fsm_ptr = fsurf_list_ptr->get_and_step();
for(kk=this_fsurf_list.size(); kk>0 && !same_surf; kk--)
FacetSurfaceMesh *this_fsm_ptr = this_fsurf_list.get_and_step();
if (this_fsm_ptr == fsm_ptr)
same_surf = 1;
if (!same_surf)
found = 0;
if (!found)
hashCurveArray[key].step();
// if the unique set of surfaces that this edge is associated
// with was found to already exist for a facet curve -- add the
// edge to the block curve
if (found)
// add the edge to the block curve mesh (make sure it is only added once)
int was_added = fcm_ptr->add_facet_unique( edge_ptr );
// add the curve to the surface (if needed)
facet_surf_mesh_ptr->add_curve_unique( fcm_ptr );
// add the curve to the edge
td_gm_edge->add_facet_curve( fcm_ptr );
// with is not found, then create a new facet curve and add the edge to it
else
// create it and update surface and nodeset info
int block_id = td_gm_edge->get_block_id();
FacetCurveMesh *new_fcm_ptr = new FacetCurveMesh( block_id );
for (int mm=0; mm<this_num_adj; mm++)
new_fcm_ptr->add_surface( this_fsurf_list.get_and_step() );
// add the edge
new_fcm_ptr->add_facet( edge_ptr );
// update the surface with this new curve
facet_surf_mesh_ptr->add_curve( new_fcm_ptr );
// add the new curve to the global list
facet_curve_list.append( new_fcm_ptr );
td_gm_edge->add_facet_curve( new_fcm_ptr );
// add the new curve to the hash table
hashCurveArray[key].append( new_fcm_ptr );
return rv;
| ) | [private] |
| CubitStatus FacetGeometryCreator::classify_point | ( | CubitPoint * | point_ptr, |
| FacetCurveMesh * | fcm_ptr | ||
| ) | [private] |
Definition at line 607 of file FacetGeometryCreator.cpp.
int ii;
int found = 0;
TDGeomFacet *td_node = TDGeomFacet::get_geom_facet( point_ptr );
FacetPointMesh *fpm_ptr;
DLIList<FacetCurveMesh*> fcm_list;
td_node->get_facet_curves(fcm_list);
int key = get_point_hash_key( &fcm_list );
for (ii = 0; ii < hashPointArray[key].size() && !found; ii++)
fpm_ptr = hashPointArray[key].get();
FacetEntity *this_point_ptr = fpm_ptr->get_facets();
if (this_point_ptr == point_ptr)
found = 1;
else
hashPointArray[key].step();
if (found)
fpm_ptr->add_curve( fcm_ptr );
fcm_ptr->add_point( fpm_ptr );
else
FacetPointMesh *new_fpm_ptr = new FacetPointMesh();
new_fpm_ptr->add_facet( point_ptr );
new_fpm_ptr->add_curve( fcm_ptr );
fcm_ptr->add_point( new_fpm_ptr );
facet_point_list.append( new_fpm_ptr );
hashPointArray[key].append( new_fpm_ptr );
return CUBIT_SUCCESS;
| ) | [private] |
| CubitStatus FacetGeometryCreator::clean_geometry | ( | CubitBoolean | smooth_non_manifold, |
| CubitBoolean | split_surfaces, | ||
| DLIList< FacetCurveMesh * > & | facet_curve_list | ||
| ) | [private] |
Definition at line 1169 of file FacetGeometryCreator.cpp.
int iedge;
FacetEntity *fedge_ptr;
CubitFacetEdge *edge_ptr;
DLIList <FacetEntity *> facet_list;
DLIList<CubitFacetEdge *> feature_edge_list;
int icurve;
for (icurve=0; icurve<facet_curve_list.size(); icurve++)
facet_list.clean_out();
facet_list = fcm_ptr->get_facets( );
for (iedge=0; iedge<facet_list.size(); iedge++)
fedge_ptr = facet_list.get_and_step();
edge_ptr = CAST_TO( fedge_ptr, CubitFacetEdge );
feature_edge_list.append( edge_ptr );
return FacetQueryEngine::instance()->fix_geometry( smooth_non_manifold,
split_surfaces,
use_feature_angle,
mindot, feature_edge_list );
| ) | [private] |
| CubitStatus FacetGeometryCreator::create_curve_boundaries | ( | DLIList< FacetCurveMesh * > & | facet_curve_list, |
| DLIList< FacetPointMesh * > & | facet_point_list | ||
| ) | [private] |
Definition at line 560 of file FacetGeometryCreator.cpp.
// hash the points for speed
stat = init_hash_points();
delete_hash_points();
return stat;
// loop through each of the end nodes on the curves
// Determine which point it is a part of.
// Create a new FacetPointMesh for each point
int ii, kk;
for ( ii = facet_curve_list.size(); ii > 0; ii-- )
CubitPoint *point_ptr[2];
fcm_ptr->get_ends( point_ptr[0], point_ptr[1] );
for ( kk = 0; kk < 2; kk++)
stat = classify_point( point_ptr[kk], facet_point_list, fcm_ptr );
return stat;
return stat;
| ) | [private] |
| CubitStatus FacetGeometryCreator::create_surface_boundaries | ( | DLIList< FacetSurfaceMesh * > & | facet_surface_list, |
| ) | [private] |
Definition at line 217 of file FacetGeometryCreator.cpp.
// determine the boundaries for each surface. One curve per surface
int ii;
for ( ii = facet_surface_list.size(); ii > 0; ii-- )
if (fcurve_list.size() == 0)
fsm_ptr->get_facets(facet_list);
FacetSkinTool f_skin_tool;
stat = f_skin_tool.skin_2d(facet_list, fsm_ptr);
if ( stat != CUBIT_SUCCESS )
return stat;
// create a hash list of curves - to speed up classification
stat = init_hash_curves();
delete_hash_curves();
return stat;
// loop through each of the edges on the surfaces
// Determine which curve it is a part of.
// Create a new FacetCurveMesh for each curve
// Curves are created wherever there is a unique set of associated
// surfaces
int jj, kk;
// curently there should only be one curve list per surface
for (jj=fcurve_list.size(); jj>0; jj--)
FacetCurveMesh *fcm_ptr = fcurve_list.get_and_step();
FacetEntity *edge_ptr;
for ( kk = 0; kk < facet_list.size(); kk++)
stat = classify_edge( edge_ptr, facet_curve_list, fsm_ptr );
return stat;
// delete this FacetCurveMesh - it should have been replaced by one
// or more curves bounding this surface
fsm_ptr->remove_curve( fcm_ptr );
// Split these curves so that there is only one string of continuous
// edges per curve (it will also order the edges and set the start
// and end nodes for each curve)
int num_curves = facet_curve_list.size();
facet_curve_list.reset();
for ( ii = num_curves; ii > 0 && stat == CUBIT_SUCCESS; ii-- )
FacetCurveMesh *fcm_ptr = facet_curve_list.get();
// if necessary mark nodes that will serve as feature breaks (vertices
// will be generatedat them)
if (use_feature_angle)
stat = fcm_ptr->feature_angle( min_dot );
return stat;
// split the curve based on various criteria
stat = fcm_ptr->split_curve( facet_curve_list );
// delete this curve (new curves were created in split_curve)
delete fcm_ptr;
facet_curve_list.change_to(NULL);
facet_curve_list.step();
facet_curve_list.remove_all_with_value(NULL);
// update the point->curve associativity
for (ii=0; ii<facet_curve_list.size(); ii++)
TDGeomFacet *td = TDGeomFacet::get_geom_facet( start_ptr );
td->add_facet_curve( fcm_ptr );
td = TDGeomFacet::get_geom_facet( end_ptr );
return stat;
| ) | [private] |
| CubitStatus FacetGeometryCreator::create_volume_boundaries | ( | DLIList< FacetSurfaceMesh * > & | facet_surface_sheets, |
| ) | [private] |
Definition at line 132 of file FacetGeometryCreator.cpp.
// Split these surfaces so that there is only one set of continuous
// faces per surface
int ii;
int num_surfaces = facet_surface_sheets.size();
facet_surface_sheets.reset();
for ( ii = num_surfaces; ii > 0; ii-- )
FacetSurfaceMesh *fsm_ptr = facet_surface_sheets.get_and_step();
// make a list of feature edges
rv = fsm_ptr->feature_angle( min_dot, feature_edge_list );
else
rv = fsm_ptr->non_manifold_edges( feature_edge_list );
if (rv != CUBIT_SUCCESS)
return rv;
// crack the surface at the feature edges. create new edges and
// points so the facet representation is discontinuous.
rv = FacetQueryEngine::make_features( feature_edge_list, split_surfaces );
return rv;
// split up the surface
rv = fsm_ptr->split_surface( facet_surface_sheets );
return rv;
// Clean up any edges that do not form complete loops as a result of
// feature angle. For this implementation we will allow features to exist
// within the surface without defining a complete loop. -- so the next
// piece of code is never executed.
CubitBoolean use_complete_loops_only = CUBIT_FALSE;
if (use_feature_angle && use_complete_loops_only)
for ( ii = facet_surface_sheets.size(); ii > 0; ii-- )
fsm_ptr->clean_features();
// Now that we've broken everything into surfaces, update the surface IDs
// on the boundary facet tool data
if (!split_surfaces)
fsm_ptr->update_boundary_tool_data();
return rv;
| ) | [private] |
| void FacetGeometryCreator::delete_hash_curves | ( | ) | [private] |
Definition at line 388 of file FacetGeometryCreator.cpp.
if (hashCurveArray)
delete [] hashCurveArray;
hashCurveSize = 0;
| void FacetGeometryCreator::delete_hash_points | ( | ) | [private] |
Definition at line 699 of file FacetGeometryCreator.cpp.
if (hashPointArray)
delete [] hashPointArray;
hashPointSize = 0;
| void FacetGeometryCreator::delete_tool_datas | ( | ) | [private] |
Definition at line 87 of file FacetGeometryCreator.cpp.
int ii;
FacetEntity *fe_ptr;
for (ii=0; ii<faceList.size(); ii++)
fe_ptr = faceList.get_and_step();
fe_ptr->delete_TD( &TDGeomFacet::is_geom_facet );
for (ii=0; ii<edgeList.size(); ii++)
fe_ptr = edgeList.get_and_step();
for (ii=0; ii<pointList.size(); ii++)
fe_ptr = pointList.get_and_step();
| int FacetGeometryCreator::get_curve_hash_key | ( | DLIList< FacetSurfaceMesh * > * | bsm_list_ptr | ) | [private] |
Definition at line 402 of file FacetGeometryCreator.cpp.
int key, j;
FacetSurfaceMesh *fsm_ptr;
if (fsm_list_ptr->size() == 0)
key = 0;
else
key = INT_MAX;
for (j=0; j<fsm_list_ptr->size(); j++)
fsm_ptr = fsm_list_ptr->get_and_step();
if (fsm_ptr->get_id() < key)
key = fsm_ptr->get_id();
key = key % hashCurveSize;
return key;
| int FacetGeometryCreator::get_point_hash_key | ( | DLIList< FacetCurveMesh * > * | bsm_list_ptr | ) | [private] |
Definition at line 713 of file FacetGeometryCreator.cpp.
int key, j;
if (fcm_list_ptr->size() == 0)
key = 0;
else
key = INT_MAX;
for (j=0; j<fcm_list_ptr->size(); j++)
fcm_ptr = fcm_list_ptr->get_and_step();
if (fcm_ptr->get_id() < key)
key = fcm_ptr->get_id();
key = key % hashPointSize;
return key;
| CubitStatus FacetGeometryCreator::init_hash_curves | ( | ) | [private] |
Definition at line 346 of file FacetGeometryCreator.cpp.
/* === find the next highest prime number */
int num_surfs = facetSurfaceList.size();
int i;
hashCurveSize = num_surfs;
if (num_surfs < 30) hashCurveSize = 31;
else
i=2;
while (i<hashCurveSize*0.5 + 1) {
if (hashCurveSize % i == 0) {
i=2;
hashCurveSize++;
else {
i++;
hashCurveArray = new DLIList<FacetCurveMesh*>[hashCurveSize];
int key = 0;
DLIList<FacetSurfaceMesh*> *fsm_list_ptr;
for (i=0; i<facetCurveList.size(); i++)
fcm_ptr = facetCurveList.get_and_step();
fsm_list_ptr = fcm_ptr->get_surface_list_ptr();
key = get_curve_hash_key( fsm_list_ptr );
hashCurveArray[key].append( fcm_ptr );
| CubitStatus FacetGeometryCreator::init_hash_points | ( | ) | [private] |
Definition at line 657 of file FacetGeometryCreator.cpp.
int num_curves = facetCurveList.size();
int i;
hashPointSize = num_curves;
if (num_curves < 30) hashPointSize = 31;
else
i=2;
while (i<hashPointSize*0.5 + 1) {
if (hashPointSize % i == 0) {
i=2;
hashPointSize++;
else {
i++;
hashPointArray = new DLIList<FacetPointMesh*>[hashPointSize];
int key = 0;
DLIList<FacetCurveMesh*> *fcm_list_ptr;
for (i=0; i<facetPointList.size(); i++)
fpm_ptr = facetPointList.get_and_step();
fcm_list_ptr = fpm_ptr->get_curve_list_ptr();
key = get_point_hash_key( fcm_list_ptr );
hashPointArray[key].append( fpm_ptr );
| void FacetGeometryCreator::print_me | ( | ) |
Definition at line 1206 of file FacetGeometryCreator.cpp.
FILE *fp = fopen( "fbg.out", "w" );
int ii, jj, kk;
for (ii=0; ii<facetSurfaceList.size(); ii++)
FacetSurfaceMesh *fsm_ptr = facetSurfaceList.get_and_step();
fprintf( fp, "*********** Surface %d ***************\n", fsm_ptr->get_id());
DLIList<FacetCurveMesh *> fcm_list;
fsm_ptr->get_curves( fcm_list );
for (jj=0; jj<fcm_list.size(); jj++)
FacetCurveMesh *fcm_ptr = fcm_list.get_and_step();
fprintf(fp, " Curve %d\n", fcm_ptr->get_id() );
DLIList<FacetPointMesh *> fpm_list = fcm_ptr->get_points();
for (kk=0; kk<fpm_list.size(); kk++)
FacetPointMesh *fpm_ptr = fpm_list.get_and_step();
FacetEntity *facet_point = fpm_ptr->get_facets();
if (facet_point)
CubitPoint *point_ptr = CAST_TO(facet_point, CubitPoint);
CubitVector pt = point_ptr->coordinates();
fprintf(fp, " (%d) x = %8.4lf y = %8.4lf z = %8.4lf\n",
fpm_ptr->get_id(), pt.x(), pt.y(), pt.z());
fclose(fp);
| void FacetGeometryCreator::set_up_tool_datas | ( | ) | [private] |
Definition at line 68 of file FacetGeometryCreator.cpp.
int ii;
TDGeomFacet::add_geom_facet( fe_ptr, -1 );
DLIList< FacetEntity * > FacetGeometryCreator::edgeList [private] |
Definition at line 50 of file FacetGeometryCreator.hpp.
DLIList< FacetEntity * > FacetGeometryCreator::faceList [private] |
Definition at line 49 of file FacetGeometryCreator.hpp.
DLIList< FacetCurveMesh * > FacetGeometryCreator::facetCurveList [private] |
Definition at line 53 of file FacetGeometryCreator.hpp.
DLIList< FacetPointMesh * > FacetGeometryCreator::facetPointList [private] |
Definition at line 54 of file FacetGeometryCreator.hpp.
DLIList< FacetSurfaceMesh * > FacetGeometryCreator::facetSurfaceList [private] |
Definition at line 52 of file FacetGeometryCreator.hpp.
DLIList< FacetCurveMesh * > * FacetGeometryCreator::hashCurveArray [private] |
Definition at line 56 of file FacetGeometryCreator.hpp.
int FacetGeometryCreator::hashCurveSize [private] |
Definition at line 57 of file FacetGeometryCreator.hpp.
DLIList< FacetPointMesh * > * FacetGeometryCreator::hashPointArray [private] |
Definition at line 58 of file FacetGeometryCreator.hpp.
int FacetGeometryCreator::hashPointSize [private] |
Definition at line 59 of file FacetGeometryCreator.hpp.
DLIList< FacetEntity * > FacetGeometryCreator::pointList [private] |
Definition at line 51 of file FacetGeometryCreator.hpp.
