cgma
#include <CADeferredAttrib.hpp>
Definition at line 51 of file CADeferredAttrib.hpp.
| CADeferredAttrib::~CADeferredAttrib | ( | ) | [virtual] |
Definition at line 28 of file CADeferredAttrib.cpp.
allCADeferredAttribs.erase(
std::remove(allCADeferredAttribs.begin(), allCADeferredAttribs.end(), this), allCADeferredAttribs.end()
| CADeferredAttrib::CADeferredAttrib | ( | RefEntity * | , |
| const CubitSimpleAttrib & | csa_ptr | ||
Definition at line 35 of file CADeferredAttrib.cpp.
: CubitAttrib(NULL) { init_csa(csa_ptr); hasUpdated = CUBIT_TRUE; }
| CubitStatus CADeferredAttrib::actuate | ( | ) | [virtual] |
Implements CubitAttrib.
Definition at line 91 of file CADeferredAttrib.cpp.
// test to see if we can assign this CADA to a new owner; set
// flag accordingly
if (assign_to_owner()) {
hasActuated = CUBIT_TRUE;
return CUBIT_SUCCESS;
else return CUBIT_FAILURE;
| bool CADeferredAttrib::add_unactuated_ca | ( | CubitAttrib * | ca_ptr | ) | [static] |
Definition at line 340 of file CADeferredAttrib.cpp.
std::vector<CubitAttrib*>::iterator iter = std::find(unactuatedCAs.begin(), unactuatedCAs.end(), ca_ptr);
if(iter == unactuatedCAs.end())
unactuatedCAs.push_back(ca_ptr);
return true;
return false;
| CubitStatus CADeferredAttrib::assign_to_owner | ( | CubitAttribUser * | owner = NULL | ) | [private] |
Definition at line 123 of file CADeferredAttrib.cpp.
//- looks for an entity with the right uid, assigns itself to
//- that entity if found
if (uniqueId == 0) return CUBIT_FAILURE;
if (owner == NULL) {
ToolDataUser *tdu = TDUniqueId::find_td_unique_id(uniqueId);
owner = CAST_TO(tdu, CubitAttribUser);
if (owner == NULL) return CUBIT_FAILURE;
// ok, we have an owner; create a new CA using the csa, assigning
// it to the ref entity
RefEntity *ref_ent = CAST_TO(owner, RefEntity);
assert (ref_ent != 0);
// CubitAttrib *new_cubit_attrib =
// CGMApp::instance()->attrib_manager()->create_cubit_attrib(thisCSA, ref_ent);
int attrib_type = CGMApp::instance()->attrib_manager()->attrib_type(thisCSA);
CGMApp::instance()->attrib_manager()->create_cubit_attrib(attrib_type, ref_ent, thisCSA);
// now remove this CADA from the global list and add the new CA
// to the unactuated list
// new attribute might be NULL, if there was already one there
if (NULL != new_cubit_attrib)
unactuatedCAs.push_back(new_cubit_attrib);
// ok, all done
deleteAttrib = CUBIT_TRUE;
| CubitStatus CADeferredAttrib::cleanup_cadas | ( | const CubitBoolean | from_constructor, |
| const CubitBoolean | after_geom_changes | ||
| ) | [static] |
Definition at line 183 of file CADeferredAttrib.cpp.
CubitStatus status = CUBIT_FAILURE;
if (CUBIT_TRUE == from_constructor)
status = CADeferredAttrib::cleanup_cadas_private(CUBIT_TRUE, CUBIT_FALSE);
// exit if we're not to actuate for after_geom_changes
if (CUBIT_TRUE == after_geom_changes)
status = CADeferredAttrib::cleanup_cadas_private(CUBIT_FALSE, CUBIT_TRUE);
return status;
| CubitStatus CADeferredAttrib::cleanup_cadas_private | ( | const CubitBoolean | from_constructor, |
| ) | [static, private] |
Definition at line 198 of file CADeferredAttrib.cpp.
// moves between the global CADA list and the unactuated list:
// 1. tries to actuate all CADAs on unactuated list
// 2. tries to assign_to_owner all CADAs on global list
// after each of these steps, if anything happened, the loop is
// repeated
// this function should be called as part of the auto actuate process
// first call for from_constructor and !after_geom_changes attributes
CubitBoolean done = CUBIT_FALSE;
CubitStatus did_something = CUBIT_FAILURE;
while (done == CUBIT_FALSE) {
done = CUBIT_TRUE;
for(std::vector<CubitAttrib*>::iterator iter = unactuatedCAs.begin(); iter != unactuatedCAs.end();)
CubitAttrib *attrib = *iter;
if( attrib == 0 )
++iter;
continue;
// check the auto actuate flag for this CA; since this function
// is only called from the auto actuating process, we don't need
// to check whether the user requested that this attribute be actuated
if (attrib->auto_actuate_flag() == CUBIT_TRUE &&
(!from_constructor || attrib->actuate_in_constructor()) &&
(after_geom_changes || !attrib->actuate_after_geom_changes()))
// if the attribute has already actuated, but is still in our list,
// count it as doing something
if ( /*attrib->has_actuated() || */
attrib->actuate() == CUBIT_SUCCESS) {
PRINT_DEBUG_90("Actuated a CADA of type %s\n",
attrib->att_internal_name());
did_something = CUBIT_SUCCESS;
done = CUBIT_FALSE;
iter = unactuatedCAs.erase(iter);
else
++iter;
else
++iter;
if (done == CUBIT_TRUE) break;
// if we did something in the previous loop, some of our CADAs might
// now have owners; check and see
for (std::vector<CADeferredAttrib*>::iterator iter = allCADeferredAttribs.begin();
iter != allCADeferredAttribs.end(); ++iter)
CADeferredAttrib *cada = *iter;
if (cada->assign_to_owner() == CUBIT_SUCCESS) {
PRINT_DEBUG_90("Assigned a CADA to a new owner in CADA::cleanup_cadas\n");
done = CUBIT_FALSE;
// if there wasn't anthing to do in the first place, we didn't
// really fail
if (did_something == CUBIT_FAILURE && unactuatedCAs.size() == 0)
return did_something;
| CubitSimpleAttrib CADeferredAttrib::csa_from_dcsa | ( | const CubitSimpleAttrib & | csa_ptr, |
| const int | uid = 0 |
Definition at line 317 of file CADeferredAttrib.cpp.
//- given a deferred csa, convert it to a normal csa by removing
//- first type string and first int; if first int doesn't match
//- uid passed in, NULL is returned
if (csa_ptr.string_data_list()[0] != CGMApp::instance()->attrib_manager()->att_internal_name(CA_DEFERRED_ATTRIB))
// csa isn't deferred type - return
return CubitSimpleAttrib();
if (uid != 0 && csa_ptr.int_data_list()[0] != uid)
// csa uid doesn't match - return
CubitSimpleAttrib c = csa_ptr;
c.string_data_list().erase(c.string_data_list().begin());
c.int_data_list().erase(c.int_data_list().begin());
// else we have a match - build new csa
return c;
| CubitSimpleAttrib CADeferredAttrib::cubit_simple_attrib | ( | ) | [virtual] |
| CubitStatus CADeferredAttrib::get_deferred_attribs | ( | const int | uid, |
| std::vector< CADeferredAttrib * > & | cada_list | ||
Definition at line 164 of file CADeferredAttrib.cpp.
// find a deferred attribute for the entity with the uid passed in
cada_list.clear();
for(std::vector<CADeferredAttrib*>::iterator iter=allCADeferredAttribs.begin();
if((*iter)->unique_id() == uid)
cada_list.push_back(*iter);
if (cada_list.size() > 0) return CUBIT_SUCCESS;
| static std::vector<CubitAttrib*> CADeferredAttrib::get_unactuated_deferred_attribs | ( | ) | [inline, static] |
Definition at line 108 of file CADeferredAttrib.hpp.
{ return unactuatedCAs; }
| CubitStatus CADeferredAttrib::init_csa | ( | const CubitSimpleAttrib & | csa_ptr | ) | [private] |
Definition at line 56 of file CADeferredAttrib.cpp.
int csa_type = CGMApp::instance()->attrib_manager()->attrib_type(csa_ptr);
if (CA_DEFERRED_ATTRIB != csa_type)
assert(false);
// initialize this according to csa_ptr
// first get the uniqueId off the csa
uniqueId = csa_ptr.int_data_list()[0];
assert(uniqueId > 0);
// now check to see if we have this CADA alreedy; if so, set the
// delete flag and exit
std::vector<CADeferredAttrib*>::iterator iter = std::find_if(allCADeferredAttribs.begin(), allCADeferredAttribs.end(), find_attrib_id(uniqueId));
if (iter != allCADeferredAttribs.end()) {
// copy the info on the csa; need a new one, since
// we don't own the original
thisCSA = csa_from_dcsa(csa_ptr);
assert(!thisCSA.isEmpty());
// add this to the global list
allCADeferredAttribs.push_back(this);
| int CADeferredAttrib::int_attrib_type | ( | ) | [inline, private, virtual] |
Definition at line 97 of file CADeferredAttrib.hpp.
{return CA_DEFERRED_ATTRIB;};
| CubitStatus CADeferredAttrib::owner_created | ( | RefEntity * | new_owner, |
| const int | uid | ||
| ) | [static] |
Definition at line 278 of file CADeferredAttrib.cpp.
// for a newly created ref entity, assigns any CADA with the same uid to the
// new entity
// get any CADAs with the same uid
std::vector<CADeferredAttrib*> attrib_list;
get_deferred_attribs(uid, attrib_list);
// now assign them to the owner
for (std::vector<CADeferredAttrib*>::iterator iter = attrib_list.begin();
iter != attrib_list.end(); ++iter)
(*iter)->assign_to_owner(new_owner);
if (attrib_list.size() > 0) return CUBIT_SUCCESS;
| bool CADeferredAttrib::remove_unactuated_ca | ( | CubitAttrib * | ca_ptr | ) | [static] |
Definition at line 351 of file CADeferredAttrib.cpp.
if(iter != unactuatedCAs.end())
*iter = NULL;
return true;
return false;
| CubitStatus CADeferredAttrib::reset | ( | ) | [virtual] |
Definition at line 111 of file CADeferredAttrib.cpp.
// do nothing; this CA manages its own duplicates, so no need
// to worry about them in parent code
| int CADeferredAttrib::unique_id | ( | ) | [inline] |
Definition at line 89 of file CADeferredAttrib.hpp.
{ return uniqueId;}
| void CADeferredAttrib::unique_id | ( | int | id | ) | [inline] |
Definition at line 91 of file CADeferredAttrib.hpp.
| CubitStatus CADeferredAttrib::update | ( | ) | [virtual] |
Definition at line 102 of file CADeferredAttrib.cpp.
// the hasUpdated flag should always be true by the time
// we get here, since the function that put this CA on the
// owning entity set the flag
assert(hasUpdated == CUBIT_TRUE);
std::vector< CADeferredAttrib * > CADeferredAttrib::allCADeferredAttribs [static, private] |
Definition at line 61 of file CADeferredAttrib.hpp.
CubitSimpleAttrib CADeferredAttrib::thisCSA [private] |
Definition at line 58 of file CADeferredAttrib.hpp.
std::vector< CubitAttrib * > CADeferredAttrib::unactuatedCAs [static, private] |
Definition at line 64 of file CADeferredAttrib.hpp.
int CADeferredAttrib::uniqueId [private] |
Definition at line 55 of file CADeferredAttrib.hpp.
