cgma
#include <CubitOctreeNode.hpp>
Definition at line 31 of file CubitOctreeNode.hpp.
| CubitOctreeNode::CubitOctreeNode | ( | const CubitVector & | cen, |
| CubitOctreeCell * | parent_cell, | ||
| const int | i, | ||
| const int | j, | ||
| const int | k | ||
Definition at line 34 of file CubitOctreeNode.cpp.
initialize_constructor( cen.x(), cen.y(), cen.z() );
adjCell[x_index][y_index][z_index] = parent_cell;
| CubitOctreeNode::CubitOctreeNode | ( | const double & | x, |
| const double & | y, | ||
| const double & | z | ||
Definition at line 40 of file CubitOctreeNode.cpp.
initialize_constructor( x, y, z );
| CubitOctreeNode::~CubitOctreeNode | ( | void | ) |
Definition at line 45 of file CubitOctreeNode.cpp.
int i;
OctreeIntersectionData *idata;
for (i=0; i < octreeIntersectionDataList.size(); ++i)
idata = octreeIntersectionDataList.get_and_step();
if (idata != NULL)
delete idata;
octreeIntersectionDataList.clean_out();
| void CubitOctreeNode::append_list_item | ( | CubitVector | facet_normal | ) |
| void CubitOctreeNode::append_list_item | ( | OctreeIntersectionData * | ptr_int_data | ) | [inline] |
Definition at line 159 of file CubitOctreeNode.hpp.
octreeIntersectionDataList.push( ptr_int_data );
| CubitBoolean CubitOctreeNode::bfs_to_find_contained_nodes | ( | int | max_onode_per_src | ) |
| void CubitOctreeNode::calc_facet_patch_distance_normal | ( | DLIList< OctreeIntersectionData * > & | idatas, |
| int | num_use_idatas, | ||
| double & | patch_distance, | ||
| CubitVector & | patch_normal, | ||
| CubitBoolean | sort, | ||
| CubitBoolean | set_Refface | ||
Definition at line 395 of file CubitOctreeNode.cpp.
int i, j;
CubitBoolean duplicate = CUBIT_FALSE;
for (i=0; i < idatas.size(); ++i)
idatas.reset();
idatas.step(i);
OctreeIntersectionData *first = idatas.get();
for (j=i+1; j < idatas.size(); ++j)
idatas.reset();
idatas.step(j);
if (idatas.get() == first) {duplicate = CUBIT_TRUE;}
break;
if (duplicate == CUBIT_TRUE) {break;}
if (duplicate) {PRINT_INFO("Duplicate idatas found for node %d\n", this->get_num());}
if (sort) {idatas.sort(OctreeIntersectionData::compare_function);}
idatas.reset();
if (sort)
patch_distance = /*(coord - idatas.get()->get_int_point())%idatas.get()->get_facet_normal();*/ idatas.get()->get_length();
// CubitFacet *ptr_facet = idatas.get()->get_facet_ptr();
// CubitVector closest_point_on_facet = idatas.get()->get_int_point(), facet_normal = idatas.get()->get_facet_normal();
/* if (fabs((coord - closest_point_on_facet)%facet_normal) != (coord-closest_point_on_facet).length())
SVDrawTool::clear_non_retained();
SVDrawTool::draw_vector(coord, closest_point_on_facet, CUBIT_YELLOW_INDEX);
PRINT_INFO("closest length is %lf\n", idatas.get()->get_length());
DLIList<CubitFacet*> temp_facets;
temp_facets.append(ptr_facet);
SVDrawTool::draw_facets(temp_facets, CUBIT_YELLOW_INDEX);
temp_facets.clean_out();
CubitFacet *facet = idatas.get()->get_facet_ptr();
if (facet != ptr_facet)
SVDrawTool::draw_vector(coord, idatas.get()->get_int_point(), CUBIT_RED_INDEX);
PRINT_INFO("Other length is %lf\n", idatas.get()->get_length());
idatas.step();
temp_facets.append(facet);
temp_facets.remove(ptr_facet);
SVDrawTool::draw_facets(temp_facets, CUBIT_RED_INDEX);
int j,k;
for (i=0; i < 2; ++i)
for (j=0; j < 2; ++j)
for (k=0; k < 2; ++k)
CubitOctreeCell *CubitOctree_cell = adjCell[i][j][k];
if (CubitOctree_cell == NULL) {continue;}
double corners[3];
double half_edge_length = CubitOctree_cell->get_dimension()/2.0;
CubitVector center = CubitOctree_cell->get_center();
center.get_xyz(corners);
float box[6] = {corners[0]-half_edge_length, corners[1]-half_edge_length, corners[2]-half_edge_length,
corners[0]+half_edge_length, corners[1]+half_edge_length, corners[2]+half_edge_length};
SVDrawTool::draw_cube(box, CUBIT_GREEN_INDEX, SVDrawTool::WIRE);
SVDrawTool::mouse_xforms();
else {patch_distance = -1;}
if (set_Refface) {refFace = idatas.get()->get_face();}
if (num_use_idatas == -1) {num_use_idatas = idatas.size();}
patch_normal = CubitVector(0,0,0);
/*for (i=0; i < num_use_idatas; ++i)
double len = idatas.get()->get_length();
if (len < OCTREE_EPSILON) {len = OCTREE_EPSILON;}
normal += idatas.get()->get_facet_normal() * 1/(len);
idatas.step();
normal.normalize(); */
OctreeIntersectionData *ptr_data;
//double denominator = 0.0;
double length;
//distance = 0.0;
for( i=0; i < num_use_idatas; i++ )
ptr_data = idatas.get_and_step(); // VED: important
length = ptr_data->get_length();
if( length < OCTREE_EPSILON ){
patch_normal += ptr_data->get_normal() * (1/(OCTREE_EPSILON*OCTREE_EPSILON));
//distance += ( ptr_data->get_normal()%( coord - ptr_data->get_int_point() ) ) * (1/OCTREE_EPSILON)/denominator;
else{
patch_normal += ptr_data->get_normal() * (1/(length*length));
//distance += ( ptr_data->get_normal()%( coord - ptr_data->get_int_point() ) ) * (1/length)/denominator;
patch_normal.normalize();
| void CubitOctreeNode::calculate_size_based_on_cell_dimension | ( | double | bbox_dimension | ) |
Definition at line 366 of file CubitOctreeNode.cpp.
int i;
int counter = 0;
double sum = 0.0;
for( i = 0; i < 6; i++ ){
if( adjNodeDistance[i] >= 0 ){
sum += 1.0 / pow( 2.0, adjNodeDistance[i] );
counter++;
size = sum / counter * bbox_dimension;
| CubitBoolean CubitOctreeNode::compare_function | ( | CubitOctreeNode *& | a, |
| CubitOctreeNode *& | b | ||
| ) | [static] |
Definition at line 898 of file CubitOctreeNode.cpp.
if( a->get_distance() < b->get_distance() )
return CUBIT_TRUE;
else
return CUBIT_FALSE;
| CubitBoolean CubitOctreeNode::dfs_to_find_contained_nodes | ( | int | max_onode_per_src | ) |
| void CubitOctreeNode::display | ( | OctreeNodeConstant | type = NODE_SIZE, |
| float | draw_size = -1 |
Definition at line 114 of file CubitOctreeNode.cpp.
switch( type ){
case NODE_SIZE:
if (draw_size < 0)
draw_size = size;
//SkeletonDebug::draw_point( coord, draw_size );
break;
case NODE_DISTANCE:
if( color == CUBIT_BLACK_INDEX ){
//SkeletonDebug::draw_point( coord, (float)draw_size ) ;
break;
case NODE_FACE_NUM:
if( refFace != NULL ){
//SkeletonDebug::draw_point( coord, (float)(( refFace->id() % 18) * 0.5) );
else{
PRINT_INFO("ERROR: Face Ptr Doesn't Exist in White Grid Node \n");
break;
case NODE_NORMAL:
//SkeletonDebug::draw_line(coord, draw_size, coord+mNormal,draw_size);
break;
default:
//SkeletonDebug::draw_point( coord, 1 );
break;
| void CubitOctreeNode::find_distance_at_adj_node | ( | PriorityQueue< CubitOctreeNode * > * | heap | ) |
Definition at line 907 of file CubitOctreeNode.cpp.
int i;
CubitVector mat_pnt_center;
double new_node_distance;
// PRINT_INFO("Testing: Face id = %d\n", mrefFace->id());
visit = CUBIT_TRUE;
// at the boundary of solid
if( adjGridNode[i] == NULL )
continue;
// *************** WARNING *********
// if the adjGridNode is on boundary or outside don't do anything
// Just testing white node is enough because we assume the facet and the grid
// intersection done during octree generation is correct
// At this point only at the boundary there is white and black nodes because of facet/octree intersection
// and both at interior and outside we grey node
//if( adjGridNode[i]->get_color() == CUBIT_WHITE_INDEX || adjGridNode[i]->get_color() == CUBIT_GREY_INDEX )
if( adjGridNode[i]->get_color() == CUBIT_WHITE_INDEX || adjGridNode[i]->get_color() == CUBIT_YELLOW_INDEX)
continue;
// meeting of the front should be the major
// criteria not the size value. check for null of
// grid_node->face. then check for adjacency, black_white, and size...
new_node_distance = distance + ( adjGridNode[i]->coord - coord )%mNormal;
// WARNING: The below condition is very important.
// Therefore I think the normal calculation is wrong
// Front should always go forward.
if(new_node_distance <= distance)
// OPEN IT
// this happens at the concave region containing many surfaces.
//PRINT_DEBUG_157(" Distance Calculation is wrong (discresing)\n");
if (adjGridNode[i]->refFace != NULL)
//if (adjGridNode[i]->mrefFace != mrefFace)
continue;
adjGridNode[i]->color = CUBIT_BLACK_INDEX;
//new_node_distance = distance;
continue;
//SVDrawTool::draw_vector(adjGridNode[i]->coord, closest, CUBIT_RED_INDEX);
//if( adjGridNode[i]->mrefFace != mrefFace )
if( adjGridNode[i]->refFace == NULL ){
// internal black nodes
// not near skeleton
adjGridNode[i]->distance = new_node_distance;
adjGridNode[i]->refFace = refFace;
adjGridNode[i]->mNormal = mNormal;
heap->push( adjGridNode[i] );
else{
| int CubitOctreeNode::find_half_space | ( | CubitFacet * | ptr_facet | ) |
Definition at line 383 of file CubitOctreeNode.cpp.
if( (coord - ptr_facet->point(0)->coordinates()) % (ptr_facet->normal()) >= 0 )
halfspaceDirection = OCTREE_POSITIVE;
return halfspaceDirection;
| CubitBoolean CubitOctreeNode::find_intersection_point | ( | int | axis, |
| CubitVector | grid_node0, | ||
| CubitVector | grid_node1, | ||
| CubitVector & | facet_normal, | ||
| CubitVector | facet_vert0, | ||
| CubitVector | facet_vert1, | ||
| CubitVector | facet_vert2, | ||
| CubitVector & | int_point, | ||
| double & | para | ||
Definition at line 735 of file CubitOctreeNode.cpp.
double A, B, C, D;
double nominator, denominator;
D = - ( facet_normal%(facet_vert1 - grid_node0) );
A = facet_normal.x();
B = facet_normal.y();
C = facet_normal.z();
switch( axis ){
case OCTREE_X:
if( fabs(A) < OCTREE_EPSILON ){
//line parallel to facet
// both end points are intersection points
return CUBIT_FALSE;
else{
nominator = D;
denominator = A * ( grid_node0.x() - grid_node1.x() );
para = nominator / denominator;
break;
case OCTREE_Y:
if( fabs(B) < OCTREE_EPSILON ){
return CUBIT_FALSE;
else{
nominator = D;
denominator = B * ( grid_node0.y() - grid_node1.y() );
break;
case OCTREE_Z:
if( fabs(C) < OCTREE_EPSILON ){
return CUBIT_FALSE;
else{
nominator = D;
denominator = C * ( grid_node0.z() - grid_node1.z() );
break;
default:
break;
int_point = grid_node0 + para * ( grid_node1 - grid_node0 );
return( is_intersection_point_contained_inside_facet( int_point, facet_vert0, facet_vert1, facet_vert2 ) );
| void CubitOctreeNode::find_intersection_with_facet | ( | CubitOctreeType | type, |
| RefFace * | ptr_face, | ||
| CubitFacet * | ptr_facet, | ||
| DLIList< CubitOctreeNode * > & | boundary_white_node_list | ||
Definition at line 629 of file CubitOctreeNode.cpp.
int i;
CubitBoolean result;
CubitVector int_point;
CubitVector facet_normal;
double para;
facet_normal = ptr_facet->normal();
result = CUBIT_FALSE;
if( adjGridNode[i] != NULL ){
if( adjGridNode[i]->halfspaceDirection == OCTREE_NEGATIVE && adjGridNode[i]->mark == CUBIT_TRUE ){
//- adj_node[0] = O_FRONT Node
//- adj_node[1] = O_BACK Node
//- adj_node[2] = O_RIGHT Node
//- adj_node[3] = O_LEFT Node
//- adj_node[4] = O_TOP Node
//- adj_node[5] = O_BOTTOM Node
switch( i ){
case O_FRONT:
result = find_intersection_point( OCTREE_X, coord, adjGridNode[i]->coord, facet_normal, ptr_facet->point(0)->coordinates(), ptr_facet->point(1)->coordinates(), ptr_facet->point(2)->coordinates(), int_point, para );
break;
case O_BACK:
break;
case O_RIGHT:
result = find_intersection_point( OCTREE_Y, coord, adjGridNode[i]->coord, facet_normal, ptr_facet->point(0)->coordinates(), ptr_facet->point(1)->coordinates(), ptr_facet->point(2)->coordinates(), int_point, para );
break;
case O_LEFT:
break;
case O_TOP:
result = find_intersection_point( OCTREE_Z, coord, adjGridNode[i]->coord, facet_normal, ptr_facet->point(0)->coordinates(), ptr_facet->point(1)->coordinates(), ptr_facet->point(2)->coordinates(), int_point, para );
break;
case O_BOTTOM:
break;
default:
break;
if( result == CUBIT_TRUE ){
OctreeIntersectionData * ptr_data;
switch( type ){
case CUBIT_OCTREE_VOLUME:
// update color of boundary node
if( color != CUBIT_WHITE_INDEX ){
// Mark the common cells incident on both end points of the edge as GREY
// To resolve the intersection problems I added the SAT intersection code -ved
boundary_white_node_list.push( this );
refFace = ptr_face;
//PRINT_DEBUG_157(" Testing: Face Num = %d\n", RefFace->id() );
color = CUBIT_WHITE_INDEX;
distance = -1;
// WARNING: devided by zero.
ptr_data = new OctreeIntersectionData( this, facet_normal * -1, int_point, (adjGridNode[i]->coord - int_point).length(), ptr_face );
adjGridNode[i]->append_list_item( ptr_data );
break;
case CUBIT_OCTREE_FACE:
refFace = ptr_face;
distance = -1;
break;
default:
PRINT_INFO("This case not yet implemented \n");
break;
Definition at line 332 of file CubitOctreeNode.cpp.
int i, j, k;
int depth_min_depth_cell = CUBIT_INT_MAX;
int depth_max_detph_cell = -CUBIT_INT_MAX;
int depth;
for( i = 0; i < 2; i++ ){
for( j = 0; j < 2; j++ ){
for( k = 0; k < 2; k++ ){
if( adjCell[i][j][k] != NULL ){
depth = adjCell[i][j][k]->get_depth();
if( depth < depth_min_depth_cell ){
depth_min_depth_cell = depth;
minDepthCell = adjCell[i][j][k];
if( depth > depth_max_detph_cell ){
depth_max_detph_cell = depth;
if( depth_min_depth_cell != CUBIT_INT_MAX && depth_max_detph_cell != -CUBIT_INT_MAX ){
cellDepthDifference = depth_max_detph_cell - depth_min_depth_cell;
else{
cellDepthDifference = 0;
return cellDepthDifference;
Definition at line 871 of file CubitOctreeNode.cpp.
int i;
double sum = 0.0;
int count = 0;
for( i = 0; i < 6; i ++ ){
// WARNING: Why we need to check for -1
//if( adjGridNode[i]->size != -1 && adjGridNode[i]->size != CUBIT_DBL_MAX && adjGridNode[i]->size != 0){
//if( adjGridNode[i]->size != CUBIT_DBL_MAX && adjGridNode[i]->size != 0.0 ){
if( adjGridNode[i]->size != 0.0 ){
sum += adjGridNode[i]->size;
count++;
if( sum != 0.0 ){
size = sum / count;
return CUBIT_TRUE;
else
return CUBIT_FALSE;
| CubitOctreeCell* CubitOctreeNode::get_adj_cell | ( | const int | i, |
| const int | j, | ||
| const int | k | ||
| ) | [inline] |
Definition at line 120 of file CubitOctreeNode.hpp.
{ return adjCell[i][j][k]; }
| CubitOctreeNode * CubitOctreeNode::get_adj_node | ( | int | num | ) |
Definition at line 169 of file CubitOctreeNode.cpp.
switch (select)
case O_LEFT:
return adjGridNode[O_LEFT];
case O_RIGHT:
return adjGridNode[O_RIGHT];
case O_BOTTOM:
return adjGridNode[O_BOTTOM];
case O_TOP:
return adjGridNode[O_TOP];
case O_BACK:
return adjGridNode[O_BACK];
case O_FRONT:
return adjGridNode[O_FRONT];
default:
PRINT_INFO("ERROR: AdjNode index exceeded\n");
return NULL;
| int CubitOctreeNode::get_adj_node_distance | ( | enum OctreePosition | type | ) |
Definition at line 302 of file CubitOctreeNode.cpp.
switch( select ){
case O_LEFT:
return adjNodeDistance[O_LEFT];
case O_RIGHT:
return adjNodeDistance[O_RIGHT];
case O_BOTTOM:
return adjNodeDistance[O_BOTTOM];
case O_TOP:
return adjNodeDistance[O_TOP];
case O_BACK:
return adjNodeDistance[O_BACK];
case O_FRONT:
return adjNodeDistance[O_FRONT];
default:
PRINT_INFO("ERROR: AdjNode index exceeded");
return CUBIT_TRUE;
| int CubitOctreeNode::get_cell_depth_difference | ( | ) | [inline] |
Definition at line 100 of file CubitOctreeNode.hpp.
{ return cellDepthDifference; }
| int CubitOctreeNode::get_color | ( | ) | [inline] |
Definition at line 46 of file CubitOctreeNode.hpp.
{ return color; }
| CubitVector& CubitOctreeNode::get_coord | ( | ) | [inline] |
Definition at line 54 of file CubitOctreeNode.hpp.
{ return coord; }
| int CubitOctreeNode::get_counter | ( | ) |
Definition at line 107 of file CubitOctreeNode.cpp.
| double CubitOctreeNode::get_distance | ( | ) | [inline] |
Definition at line 74 of file CubitOctreeNode.hpp.
{ return distance; }
| CubitBoolean CubitOctreeNode::get_halfspace_direction | ( | ) | [inline] |
Definition at line 140 of file CubitOctreeNode.hpp.
{ return halfspaceDirection; }
| DLIList<OctreeIntersectionData*>* CubitOctreeNode::get_idata_list | ( | ) | [inline] |
Definition at line 166 of file CubitOctreeNode.hpp.
{return &octreeIntersectionDataList;}
| CubitBoolean CubitOctreeNode::get_mark | ( | void | ) | [inline] |
Definition at line 124 of file CubitOctreeNode.hpp.
{ return mark; }
| CubitOctreeCell* CubitOctreeNode::get_min_depth_cell | ( | ) | [inline] |
Definition at line 97 of file CubitOctreeNode.hpp.
{ return minDepthCell; }
| CubitVector CubitOctreeNode::get_normal | ( | ) | const [inline] |
Definition at line 132 of file CubitOctreeNode.hpp.
{return mNormal;}
| int CubitOctreeNode::get_num | ( | ) | [inline] |
Definition at line 51 of file CubitOctreeNode.hpp.
{ return num; }
| double CubitOctreeNode::get_size | ( | OctreeSourceEntityType | type | ) | const |
Definition at line 157 of file CubitOctreeNode.cpp.
return size;
| CubitBoolean CubitOctreeNode::get_visit | ( | ) | const [inline] |
Definition at line 129 of file CubitOctreeNode.hpp.
{return visit;}
| int CubitOctreeNode::id | ( | void | ) | [inline] |
Definition at line 60 of file CubitOctreeNode.hpp.
{ return num; }
| void CubitOctreeNode::initialize_constructor | ( | const double & | x, |
in CubitOctree outside nodes are GREY, inside nodes are BLACK. And boundary nodes are WHITE.
Definition at line 63 of file CubitOctreeNode.cpp.
int i, j, k;
color = CUBIT_GREY_INDEX; // boundary nodes are colored white and inside nodes black
// during facet intersection the white nodes dominates black
visit = CUBIT_FALSE; // mat generation
mark = CUBIT_FALSE;
halfspaceDirection = OCTREE_NEGATIVE;
num = get_counter();
size = 0.0;
distance = CUBIT_DBL_MAX;
minDepthCell = NULL;
mNormal.x(0.0);
mNormal.y(0.0);
mNormal.z(0.0);
coord.x(x);
coord.y(y);
coord.z(z);
adjCell[i][j][k] = NULL;
// LRBTFN
adjGridNode[i] = NULL;
adjNodeDistance[i] = -1; // ?
refFace = NULL;
| CubitBoolean CubitOctreeNode::is_intersection_point_contained_inside_facet | ( | const CubitVector & | int_point, |
| const CubitVector & | facet_vert0, | ||
| const CubitVector & | facet_vert1, | ||
| const CubitVector & | facet_vert2 | ||
| ) | [static] |
Definition at line 815 of file CubitOctreeNode.cpp.
if ( fabs((int_point-facet_vert0)%( (facet_vert1-facet_vert0) * (facet_vert2-facet_vert0) )) > OCTREE_EPSILON)
return CUBIT_FALSE;
if (is_same_side(int_point,facet_vert0, facet_vert1,facet_vert2) && is_same_side(int_point,facet_vert1, facet_vert0,facet_vert2) && is_same_side(int_point,facet_vert2, facet_vert0,facet_vert1)) {return CUBIT_TRUE;}
return CUBIT_FALSE;
/*CubitVector line0, line1, line2;
double ang0, ang1, ang2;
line0 = facet_vert0 - int_point ;
line0 = line0 / line0.length();
line1 = facet_vert1 - int_point ;
line1 = line1 / line1.length();
line2 = facet_vert2 - int_point ;
line2 = line2 / line2.length();
//Added (M. Brewer) to check for an invalid number passed to acos
//compute ang0
double temp_double = line0 % line1;
if(temp_double>1.0)
temp_double=1.0;
else if (temp_double<-1.0)
temp_double=-1.0;
ang0 = acos( temp_double );
//compute ang1
temp_double = line1 % line2;
if(temp_double>1.0)
temp_double=1.0;
temp_double=-1.0;
ang1 = acos( temp_double );
//compute ang2
temp_double = line2 % line0;
if(temp_double>1.0)
temp_double=1.0;
temp_double=-1.0;
ang2 = acos( temp_double );
if( fabs ( ( ang0 + ang1 + ang2 ) - CUBIT_PI * 2 ) < OCTREE_EPSILON ){
return CUBIT_TRUE;
else{
return CUBIT_FALSE;
| CubitBoolean CubitOctreeNode::is_same_side | ( | const CubitVector & | p1, |
| const CubitVector & | p2, | ||
| const CubitVector & | a, | ||
| const CubitVector & | b | ||
| ) | [static] |
Definition at line 802 of file CubitOctreeNode.cpp.
static CubitVector edge;
edge = b-a;
//cp1 = edge*(p1-a);
//cp2 = edge*(p2-a);
if ( (edge*(p1-a)) % (edge*(p2-a)) >= 0) {return CUBIT_TRUE;}
return CUBIT_FALSE;
| double CubitOctreeNode::manhattan_distance_adj_node | ( | int | index | ) |
Definition at line 269 of file CubitOctreeNode.cpp.
switch( index ){
case O_FRONT:
return fabs( coord.x() - adjGridNode[index]->coord.x() );
case O_BACK:
case O_RIGHT:
return fabs( coord.y() - adjGridNode[index]->coord.y() );
case O_LEFT:
case O_TOP:
return fabs( coord.z() - adjGridNode[index]->coord.z() );
case O_BOTTOM:
default:
PRINT_INFO("WARNING: Adjacent grid node index doesn't exist");
return 1.0;
| double CubitOctreeNode::manhattan_distance_adj_node | ( | CubitOctreeNode * | ptr_adj_node | ) | [inline] |
| static void CubitOctreeNode::reset_counter | ( | ) | [inline, static] |
Definition at line 106 of file CubitOctreeNode.hpp.
{mCounter = -1;}
Definition at line 518 of file CubitOctreeNode.cpp.
// three cases:
// 1) One facet (one RefFace) => use facet's normal and distance to facet, RefFace is set to facet's owning face
// 2) Multiple facets, one refFace => use distance to closest facet and its owning RefFace, IDW normal from N closest facets
// 3) Multiple facets, multiple RefFaces => use distance to closest facet and its owning RefFace, IDW normal from N closest facets
//int i, j, k;
// case: no intersection datas, this should not happen. I should prolly put an cassertere.
if (octreeIntersectionDataList.size() == 0)
PRINT_ERROR("No OctreeIntersectionDatas attached to black grid node in queue for MAT generation!\n");
return;
// case: one facet, just get distance, normal, and face from facet
if (octreeIntersectionDataList.size() == 1)
distance = octreeIntersectionDataList.get()->get_length();
mNormal = octreeIntersectionDataList.get()->get_facet_normal();
refFace = octreeIntersectionDataList.get()->get_face();
// remember to delete the idata - check if this is ok
delete octreeIntersectionDataList.get();
return;
// case: multiple facets, one face
// just initialize normal, distance, and Refface
// case: two faces
// determine if disconnected and if normals diverge => EWC case 1
// else check angle
// now find N closest facets (keep list of idatas though)
// choose closest one, use distance to it and use its RefFace
// then use all and IDW to get normal
int num_facets_to_use;
if (N_CLOSEST_FACETS_FACTOR_FOR_FRONT_NORMALS == 0.00) {num_facets_to_use = 1;}
else if (N_CLOSEST_FACETS_FACTOR_FOR_FRONT_NORMALS == 1.00) {num_facets_to_use = octreeIntersectionDataList.size();}
else {num_facets_to_use = (int)(N_CLOSEST_FACETS_FACTOR_FOR_FRONT_NORMALS * octreeIntersectionDataList.size());}
if (num_facets_to_use == 0) {num_facets_to_use = 1;}
else if (num_facets_to_use > octreeIntersectionDataList.size()) {num_facets_to_use = octreeIntersectionDataList.size();}
/*DLIList<OctreeIntersectionData*> n_closest_idatas;
RTree<OctreeIntersectionData*> *rtree = new RTree<OctreeIntersectionData*>;
double closest = CUBIT_DBL_MAX;
rtree->add(octreeIntersectionDataList.get_and_step());
rtree->k_nearest_neighbor(coord, num_facets_to_use, closest, n_closest_idatas, OctreeIntersectionData::dist_sqr_to_vec);
delete rtree;
// calc_facet_patch_distance_normal(octreeIntersectionDataList, num_facets_to_use, distance, normal, CUBIT_TRUE, CUBIT_TRUE);
refFace = n_closest_idatas.get()->get_face();
distance = n_closest_idatas.get()->get_length();
for (i=0; i < num_facets_to_use; ++i)
double len = n_closest_idatas.get()->get_length();
normal += n_closest_idatas.get_and_step()->get_facet_normal() * 1/(len);
normal.normalize();*/
mNormal = CubitVector(0,0,0);
calc_facet_patch_distance_normal(octreeIntersectionDataList, num_facets_to_use, distance, mNormal, CUBIT_TRUE, CUBIT_TRUE);
octreeIntersectionDataList.sort(OctreeIntersectionData::compare_function);
octreeIntersectionDataList.reset();
double len = octreeIntersectionDataList.get()->get_length();
normal += octreeIntersectionDataList.get_and_step()->get_facet_normal() * 1/(len);
normal.normalize();
// now normal, distance to boundary, and Refface have been set
| void CubitOctreeNode::set_adj_node | ( | enum OctreePosition | type, |
| CubitOctreeNode * | ptr_grid_node | ||
Definition at line 197 of file CubitOctreeNode.cpp.
switch( select )
case O_LEFT:
adjGridNode[O_LEFT] = ptr_node;
break;
case O_RIGHT:
adjGridNode[O_RIGHT] = ptr_node;
break;
case O_BOTTOM:
adjGridNode[O_BOTTOM] = ptr_node;
break;
case O_TOP:
adjGridNode[O_TOP] = ptr_node;
break;
case O_BACK:
adjGridNode[O_BACK] = ptr_node;
break;
case O_FRONT:
adjGridNode[O_FRONT] = ptr_node;
break;
default:
| void CubitOctreeNode::set_adj_node_distance | ( | enum OctreePosition | type, |
| int | dist | ||
Definition at line 233 of file CubitOctreeNode.cpp.
switch( select ){
case O_LEFT:
adjNodeDistance[O_LEFT] = dist;
break;
case O_RIGHT:
adjNodeDistance[O_RIGHT] = dist;
break;
case O_BOTTOM:
adjNodeDistance[O_BOTTOM] = dist;
break;
case O_TOP:
adjNodeDistance[O_TOP] = dist;
break;
case O_BACK:
adjNodeDistance[O_BACK] = dist;
break;
case O_FRONT:
adjNodeDistance[O_FRONT] = dist;
break;
default:
PRINT_INFO(" ERROR: AdjNode index exceeded");
| void CubitOctreeNode::set_color | ( | const int | new_color | ) | [inline] |
Definition at line 49 of file CubitOctreeNode.hpp.
{color = new_color;}
| void CubitOctreeNode::set_halfspace_direction | ( | const CubitBoolean | type | ) | [inline] |
Definition at line 141 of file CubitOctreeNode.hpp.
{ halfspaceDirection = type ; }
| void CubitOctreeNode::set_mark | ( | CubitBoolean | type | ) | [inline] |
Definition at line 123 of file CubitOctreeNode.hpp.
{ mark = type; }
| void CubitOctreeNode::set_size | ( | double | s, |
| int | type | ||
Definition at line 163 of file CubitOctreeNode.cpp.
size = s;
| void CubitOctreeNode::set_visit | ( | CubitBoolean | type | ) | [inline] |
Definition at line 126 of file CubitOctreeNode.hpp.
{ visit = type; }
| void CubitOctreeNode::update_adj_cell | ( | CubitOctreeCell * | ptr_cell, |
| int | i, | ||
| int | j, | ||
| int | k | ||
| ) | [inline] |
Definition at line 108 of file CubitOctreeNode.hpp.
adjCell[i][j][k] = ptr_cell;
| double CubitOctreeNode::x | ( | ) | [inline] |
Definition at line 76 of file CubitOctreeNode.hpp.
| void CubitOctreeNode::x | ( | double | value | ) | [inline] |
Definition at line 81 of file CubitOctreeNode.hpp.
| double CubitOctreeNode::y | ( | ) | [inline] |
Definition at line 77 of file CubitOctreeNode.hpp.
| void CubitOctreeNode::y | ( | double | value | ) | [inline] |
Definition at line 82 of file CubitOctreeNode.hpp.
| double CubitOctreeNode::z | ( | ) | [inline] |
Definition at line 78 of file CubitOctreeNode.hpp.
| void CubitOctreeNode::z | ( | double | value | ) | [inline] |
Definition at line 83 of file CubitOctreeNode.hpp.
CubitOctreeCell* CubitOctreeNode::adjCell[2][2][2] [private] |
Definition at line 239 of file CubitOctreeNode.hpp.
CubitOctreeNode* CubitOctreeNode::adjGridNode[6] [private] |
Definition at line 233 of file CubitOctreeNode.hpp.
int CubitOctreeNode::adjNodeDistance[6] [private] |
Definition at line 236 of file CubitOctreeNode.hpp.
int CubitOctreeNode::cellDepthDifference [private] |
Definition at line 221 of file CubitOctreeNode.hpp.
short CubitOctreeNode::color [private] |
Definition at line 205 of file CubitOctreeNode.hpp.
CubitVector CubitOctreeNode::coord [private] |
Definition at line 230 of file CubitOctreeNode.hpp.
double CubitOctreeNode::distance [private] |
Definition at line 228 of file CubitOctreeNode.hpp.
Definition at line 210 of file CubitOctreeNode.hpp.
CubitBoolean CubitOctreeNode::mark [private] |
Definition at line 203 of file CubitOctreeNode.hpp.
int CubitOctreeNode::mCounter = -1 [static, private] |
Definition at line 200 of file CubitOctreeNode.hpp.
CubitOctreeCell* CubitOctreeNode::minDepthCell [private] |
Definition at line 225 of file CubitOctreeNode.hpp.
CubitVector CubitOctreeNode::mNormal [private] |
Definition at line 245 of file CubitOctreeNode.hpp.
int CubitOctreeNode::num [private] |
Definition at line 197 of file CubitOctreeNode.hpp.
Definition at line 218 of file CubitOctreeNode.hpp.
RefFace* CubitOctreeNode::refFace [private] |
Definition at line 242 of file CubitOctreeNode.hpp.
double CubitOctreeNode::size [private] |
Definition at line 212 of file CubitOctreeNode.hpp.
CubitBoolean CubitOctreeNode::visit [private] |
Definition at line 202 of file CubitOctreeNode.hpp.
