cgma
00001 //------------------------------------------------------------------------- 00002 // Filename : CubitOctree.hpp 00003 // 00004 // Purpose : Defines the grid node of the CubitOctree model 00005 // 00006 // Creator : William Roshan Quadros 00007 // 00008 // Creation Date : 01/01/2003 00009 // 00010 // Owner : 00011 //------------------------------------------------------------------------- 00012 #ifndef CUBITOCTREENODE_H 00013 #define CUBITOCTREENODE_H 00014 #include "CubitVector.hpp" 00015 #include "DLIList.hpp" 00016 #include "PriorityQueue.hpp" 00017 #include <queue> 00018 #include "CubitDefines.h" 00019 //#include "MemoryManager.hpp" 00020 #include "OctreeIntersectionData.hpp" 00021 #include "CubitOctreeConstants.hpp" 00022 00023 class RefFace; 00024 class CubitOctree; 00025 class CubitOctreeCell; 00026 class CubitFacet; 00027 class CubitOctreeNode; 00028 class CubitOctreeGenerator; 00029 00030 00031 class CubitOctreeNode{ 00032 00033 public: 00034 00035 CubitOctreeNode( const CubitVector &cen, CubitOctreeCell *parent_cell, const int i, const int j, const int k ); 00036 CubitOctreeNode( const double &x, const double &y, const double &z ); 00037 void initialize_constructor( const double &x, const double &y, const double &z ); 00038 //- Constructor 00039 00040 ~CubitOctreeNode(); 00041 //- Distructor 00042 00043 void display( OctreeNodeConstant type = NODE_SIZE, float draw_size = -1 ); 00044 //- Displays the grid nodes 00045 00046 inline int get_color(){ return color; } 00047 //- Returns color 00048 00049 inline void set_color (const int new_color) {color = new_color;} 00050 00051 inline int get_num(){ return num; } 00052 //- Returns the serial number of the grid node 00053 00054 inline CubitVector& get_coord(){ return coord; } 00055 //- Returns the cartesian coordinates 00056 00057 double get_size( OctreeSourceEntityType type ) const; 00058 //- Returns size of the node 00059 00060 int id(){ return num; } 00061 00062 void set_size( double s, int type ); 00063 //- Sets size at the node 00064 00065 void set_adj_node( enum OctreePosition type, CubitOctreeNode *ptr_grid_node ); 00066 //- sets the adjacent nodes 00067 00068 void set_adj_node_distance( enum OctreePosition type, int dist ); 00069 //- sets the adjacent nodes distance 00070 00071 double manhattan_distance_adj_node( int index ); 00072 inline double manhattan_distance_adj_node( CubitOctreeNode *ptr_adj_node ); 00073 00074 inline double get_distance(){ return distance; } 00075 00076 inline double x(){ return coord.x(); } 00077 inline double y(){ return coord.y(); } 00078 inline double z(){ return coord.z(); } 00079 //- Returns cartesian co-ordinates 00080 00081 inline void x( double value ){ coord.x( value ); } 00082 inline void y( double value ){ coord.y( value ); } 00083 inline void z( double value ){ coord.z( value ); } 00084 //- Sets cartician co-ordinates of node 00085 00086 CubitOctreeNode *get_adj_node( int num ); 00087 //- Returns one of the six adjacent nodes 00088 00089 int get_adj_node_distance( enum OctreePosition type ); 00090 //- returns the distance with the adj node in the direction of type 00091 00092 void append_list_item( CubitVector facet_normal ); 00093 00094 void calc_facet_patch_distance_normal(DLIList<OctreeIntersectionData*> &idatas, int num_use_idatas, double &patch_distance, CubitVector &patch_normal, CubitBoolean sort, CubitBoolean set_Refface); 00095 void SAT_find_face_distance_average_normal (); 00096 00097 inline CubitOctreeCell* get_min_depth_cell(){ return minDepthCell; } 00098 //- returns minimum depth cell 00099 00100 inline int get_cell_depth_difference(){ return cellDepthDifference; } 00101 00102 00103 int get_counter(); 00104 //- uses static counter to number the cell 00105 00106 static inline void reset_counter() {mCounter = -1;} 00107 00108 inline void update_adj_cell( CubitOctreeCell *ptr_cell, int i, int j, int k ) 00109 { 00110 adjCell[i][j][k] = ptr_cell; 00111 } 00112 //- updates the cell at i, j, k location 00113 00114 int find_min_depth_cell_and_depth_difference( void ); 00115 //- finds the maximum depth adjacent cell and difference in adj cells' depth 00116 00117 void calculate_size_based_on_cell_dimension( double bbox_dimension ); 00118 //- calculates size using 6 adj nodes distance 00119 00120 inline CubitOctreeCell *get_adj_cell( const int i, const int j, const int k ) { return adjCell[i][j][k]; } 00121 00122 // MARK is used in establishing connection between skl point and grid nodes contained in it using DFS 00123 inline void set_mark( CubitBoolean type ){ mark = type; } 00124 inline CubitBoolean get_mark(){ return mark; } 00125 00126 inline void set_visit( CubitBoolean type ){ visit = type; } 00127 //- sets the visit with type ( CUBIT_FALSE or CUBIT_TRUE ) 00128 00129 inline CubitBoolean get_visit() const {return visit;} 00130 //- Returns visit 00131 00132 inline CubitVector get_normal() const {return mNormal;} 00133 00134 00135 00136 int find_half_space( CubitFacet *ptr_facet ); 00137 00138 //- returns half space direction 00139 00140 inline CubitBoolean get_halfspace_direction(){ return halfspaceDirection; } 00141 inline void set_halfspace_direction( const CubitBoolean type ){ halfspaceDirection = type ; } 00142 00143 void find_intersection_with_facet( CubitOctreeType type, RefFace *ptr_face, CubitFacet *ptr_facet, DLIList<CubitOctreeNode*> &boundary_white_node_list); 00144 //- checks intesection between the lines joining grid node and adjacent nodes with the facet. 00145 //- queue_mat_generation stores the BLACK grinodes that contains distanace and normal for MAT generation. 00146 00147 CubitBoolean find_intersection_point( int axis, CubitVector grid_node0, CubitVector grid_node1, CubitVector &facet_normal, CubitVector facet_vert0, CubitVector facet_vert1, CubitVector facet_vert2, CubitVector &int_point, double ¶ ); 00148 //- returns true if the intersection between the line segment and facet takes place 00149 //- para stores the parameter of intersection point int_point 00150 00151 static CubitBoolean is_same_side(const CubitVector &p1, const CubitVector &p2, const CubitVector &a, const CubitVector &b); 00152 static CubitBoolean is_intersection_point_contained_inside_facet( const CubitVector &int_point, const CubitVector &facet_vert0, const CubitVector &facet_vert1, const CubitVector &facet_vert2 ); 00153 //- returns true if intersection point is contained inside the facet 00154 //- interior angle at the intersecton point should add up to 360 deg. 00155 00156 00157 //- Appends the source point 00158 00159 inline void append_list_item( OctreeIntersectionData *ptr_int_data ) 00160 { 00161 octreeIntersectionDataList.push( ptr_int_data ); 00162 } 00163 00164 //- Appends intesection data like, face, int_point, facet etc. 00165 00166 DLIList<OctreeIntersectionData*>* get_idata_list() {return &octreeIntersectionDataList;} 00167 00168 CubitBoolean bfs_to_find_contained_nodes(int max_onode_per_src); 00169 CubitBoolean dfs_to_find_contained_nodes(int max_onode_per_src); 00170 // Breadth first search is used to find nodes contained inside the box of skeleton source point 00171 00172 00173 //- sizing function due to each type of source point is evaluated separately. 00174 //- then these function can be blended to find final sizing function. 00175 //- curently the minimum of all function is selected. 00176 00177 static CubitBoolean compare_function( CubitOctreeNode *&a, CubitOctreeNode *&b ); 00178 00179 void find_distance_at_adj_node(PriorityQueue<CubitOctreeNode *> *heap ); 00180 00181 CubitBoolean find_size_using_adj_node(); 00182 00183 00184 //static void set_scope_box_limits( double max_x, double min_x, double max_y, double min_y, double max_z, double min_z); 00185 //static void reset_scope_box_limits(); 00186 //- To avoid the overflow of stack during linking source point and grid nodes 00187 //static double scpBoxMaxX, scpBoxMinX, scpBoxMaxY, scpBoxMinY, scpBoxMaxZ, scpBoxMinZ; 00188 //SetDynamicMemoryAllocation(memoryManager) 00189 //- class specific new and delete operators 00190 00191 private: 00192 00193 00194 00195 00196 private: 00197 int num; 00198 //- Serial number of node 00199 00200 static int mCounter; 00201 00202 CubitBoolean visit; 00203 CubitBoolean mark; 00204 00205 short color; 00206 // in CubitOctree based approach 00207 //- GREY is default ( all nodes outside WHITE or Solid ) 00208 //- BLACK (node inside solid), WHITE (node at the boundary during facet CubitOctree intersection) 00209 00210 CubitBoolean halfspaceDirection; 00211 00212 double size; 00213 00214 //- Size at the grid node is initially set to 0.0 00215 00216 00217 // OPT: keep pointer to list and clear list after intersection 00218 DLIList<OctreeIntersectionData *> octreeIntersectionDataList; 00219 00220 // OPT: use cubit hash to temp hold this data 00221 int cellDepthDifference; 00222 //- used in splitting CubitOctree cells during smooth transition 00223 00224 00225 CubitOctreeCell *minDepthCell; 00226 //- keeps the pointer to minimum depth adjacent cell 00227 00228 double distance; 00229 00230 CubitVector coord; 00231 // Co-ordinates of the grid node 00232 00233 CubitOctreeNode *adjGridNode[6]; 00234 //0 to 5 LEFT, RIGHT, BOTTOM, TOP, BACK, FRONT 00235 00236 int adjNodeDistance[6]; 00237 //- stores the lengths between adjacent nodes 00238 00239 CubitOctreeCell *adjCell[2][2][2]; 00240 00241 00242 RefFace *refFace; 00243 //- Face associated with the grid node used in wave propagation 00244 00245 CubitVector mNormal; 00246 //- Normal at the grid_node is used in MAT generation. 00247 00248 00249 //static MemoryManager memoryManager; 00250 //- memory management object 00251 00252 }; 00253 00254 #endif 00255 00256 //EOF 00257
