, including all inherited members.
| adjCell | CubitOctreeNode | [private] |
| adjGridNode | CubitOctreeNode | [private] |
| adjNodeDistance | CubitOctreeNode | [private] |
| append_list_item(CubitVector facet_normal) | CubitOctreeNode | |
| append_list_item(OctreeIntersectionData *ptr_int_data) | CubitOctreeNode | [inline] |
| bfs_to_find_contained_nodes(int max_onode_per_src) | CubitOctreeNode | |
| calc_facet_patch_distance_normal(DLIList< OctreeIntersectionData * > &idatas, int num_use_idatas, double &patch_distance, CubitVector &patch_normal, CubitBoolean sort, CubitBoolean set_Refface) | CubitOctreeNode | |
| calculate_size_based_on_cell_dimension(double bbox_dimension) | CubitOctreeNode | |
| cellDepthDifference | CubitOctreeNode | [private] |
| color | CubitOctreeNode | [private] |
| compare_function(CubitOctreeNode *&a, CubitOctreeNode *&b) | CubitOctreeNode | [static] |
| coord | CubitOctreeNode | [private] |
| CubitOctreeNode(const CubitVector &cen, CubitOctreeCell *parent_cell, const int i, const int j, const int k) | CubitOctreeNode | |
| CubitOctreeNode(const double &x, const double &y, const double &z) | CubitOctreeNode | |
| dfs_to_find_contained_nodes(int max_onode_per_src) | CubitOctreeNode | |
| display(OctreeNodeConstant type=NODE_SIZE, float draw_size=-1) | CubitOctreeNode | |
| distance | CubitOctreeNode | [private] |
| find_distance_at_adj_node(PriorityQueue< CubitOctreeNode * > *heap) | CubitOctreeNode | |
| find_half_space(CubitFacet *ptr_facet) | CubitOctreeNode | |
| find_intersection_point(int axis, CubitVector grid_node0, CubitVector grid_node1, CubitVector &facet_normal, CubitVector facet_vert0, CubitVector facet_vert1, CubitVector facet_vert2, CubitVector &int_point, double ¶) | CubitOctreeNode | |
| find_intersection_with_facet(CubitOctreeType type, RefFace *ptr_face, CubitFacet *ptr_facet, DLIList< CubitOctreeNode * > &boundary_white_node_list) | CubitOctreeNode | |
| find_min_depth_cell_and_depth_difference(void) | CubitOctreeNode | |
| find_size_using_adj_node() | CubitOctreeNode | |
| get_adj_cell(const int i, const int j, const int k) | CubitOctreeNode | [inline] |
| get_adj_node(int num) | CubitOctreeNode | |
| get_adj_node_distance(enum OctreePosition type) | CubitOctreeNode | |
| get_cell_depth_difference() | CubitOctreeNode | [inline] |
| get_color() | CubitOctreeNode | [inline] |
| get_coord() | CubitOctreeNode | [inline] |
| get_counter() | CubitOctreeNode | |
| get_distance() | CubitOctreeNode | [inline] |
| get_halfspace_direction() | CubitOctreeNode | [inline] |
| get_idata_list() | CubitOctreeNode | [inline] |
| get_mark() | CubitOctreeNode | [inline] |
| get_min_depth_cell() | CubitOctreeNode | [inline] |
| get_normal() const | CubitOctreeNode | [inline] |
| get_num() | CubitOctreeNode | [inline] |
| get_size(OctreeSourceEntityType type) const | CubitOctreeNode | |
| get_visit() const | CubitOctreeNode | [inline] |
| halfspaceDirection | CubitOctreeNode | [private] |
| id() | CubitOctreeNode | [inline] |
| initialize_constructor(const double &x, const double &y, const double &z) | CubitOctreeNode | |
| is_intersection_point_contained_inside_facet(const CubitVector &int_point, const CubitVector &facet_vert0, const CubitVector &facet_vert1, const CubitVector &facet_vert2) | CubitOctreeNode | [static] |
| is_same_side(const CubitVector &p1, const CubitVector &p2, const CubitVector &a, const CubitVector &b) | CubitOctreeNode | [static] |
| manhattan_distance_adj_node(int index) | CubitOctreeNode | |
| manhattan_distance_adj_node(CubitOctreeNode *ptr_adj_node) | CubitOctreeNode | [inline] |
| mark | CubitOctreeNode | [private] |
| mCounter | CubitOctreeNode | [private, static] |
| minDepthCell | CubitOctreeNode | [private] |
| mNormal | CubitOctreeNode | [private] |
| num | CubitOctreeNode | [private] |
| octreeIntersectionDataList | CubitOctreeNode | [private] |
| refFace | CubitOctreeNode | [private] |
| reset_counter() | CubitOctreeNode | [inline, static] |
| SAT_find_face_distance_average_normal() | CubitOctreeNode | |
| set_adj_node(enum OctreePosition type, CubitOctreeNode *ptr_grid_node) | CubitOctreeNode | |
| set_adj_node_distance(enum OctreePosition type, int dist) | CubitOctreeNode | |
| set_color(const int new_color) | CubitOctreeNode | [inline] |
| set_halfspace_direction(const CubitBoolean type) | CubitOctreeNode | [inline] |
| set_mark(CubitBoolean type) | CubitOctreeNode | [inline] |
| set_size(double s, int type) | CubitOctreeNode | |
| set_visit(CubitBoolean type) | CubitOctreeNode | [inline] |
| size | CubitOctreeNode | [private] |
| update_adj_cell(CubitOctreeCell *ptr_cell, int i, int j, int k) | CubitOctreeNode | [inline] |
| visit | CubitOctreeNode | [private] |
| x() | CubitOctreeNode | [inline] |
| x(double value) | CubitOctreeNode | [inline] |
| y() | CubitOctreeNode | [inline] |
| y(double value) | CubitOctreeNode | [inline] |
| z() | CubitOctreeNode | [inline] |
| z(double value) | CubitOctreeNode | [inline] |
| ~CubitOctreeNode() | CubitOctreeNode | |
