cgma
#include <GeomDataObserver.hpp>
Public Member Functions | |
| virtual void | notify_observer (const CubitEvent *event) |
| virtual | ~GeomDataObserver () |
| double | get_measure () |
| void | set_measure (double val) |
| CubitBoolean | is_measure_set () |
Static Public Member Functions | |
| static GeomDataObserver * | get (RefEntity *on_this) |
| static GeomDataObserver * | create (RefEntity *on_this) |
Private Member Functions | |
| GeomDataObserver (RefEntity *watched) | |
Private Attributes | |
| RefEntity * | myRefEntity |
| double | myMeasure |
| CubitBoolean | measureSet |
Definition at line 19 of file GeomDataObserver.hpp.
| GeomDataObserver::~GeomDataObserver | ( | ) | [virtual] |
Definition at line 21 of file GeomDataObserver.cpp.
unregister_observable( myRefEntity );
| GeomDataObserver::GeomDataObserver | ( | RefEntity * | watched | ) | [private] |
Definition at line 13 of file GeomDataObserver.cpp.
: myRefEntity(watched) { measureSet = CUBIT_FALSE; //initialize to something weird. myMeasure = -CUBIT_DBL_MAX; }
| GeomDataObserver * GeomDataObserver::create | ( | RefEntity * | on_this | ) | [static] |
Definition at line 40 of file GeomDataObserver.cpp.
GeomDataObserver* eo = get(on_this);
if (eo)
return eo;
eo = new GeomDataObserver(on_this);
eo->register_observable(on_this);
return eo;
| GeomDataObserver * GeomDataObserver::get | ( | RefEntity * | on_this | ) | [static] |
The following are specific functions for making this a dynamic observer.
Definition at line 26 of file GeomDataObserver.cpp.
DLIList<CubitObserver*> list;
GeomDataObserver* eo = NULL;
on_this->get_observer_list(list);
for (int i = list.size(); i--; )
if ( (eo = dynamic_cast<GeomDataObserver*>(list.step_and_get()) ))
break;
return eo;
| double GeomDataObserver::get_measure | ( | ) | [inline] |
Now the reset are more specific to the GeomDataObserver.
Definition at line 37 of file GeomDataObserver.hpp.
{return myMeasure;}
| CubitBoolean GeomDataObserver::is_measure_set | ( | ) | [inline] |
| void GeomDataObserver::notify_observer | ( | const CubitEvent * | event | ) | [virtual] |
Implements CubitObserver.
Definition at line 50 of file GeomDataObserver.cpp.
const GeometryEvent* geom_event = dynamic_cast<const GeometryEvent*>(event);
if(geom_event)
assert(geom_event->get_entity() == myRefEntity);
switch (geom_event->get_type())
case GeometryEvent::GEOMETRY_TOPOLOGY_MODIFIED:
case GeometryEvent::TOPOLOGY_MODIFIED:
case GeometryEvent::GEOMETRY_MODIFIED:
case GeometryEvent::TOPOLOGY_ENTITY_DESTRUCTED:
break;
default:
return;
/* don't call virtual functions or access
class data after this! */
delete this;
| void GeomDataObserver::set_measure | ( | double | val | ) | [inline] |
Returns the cached measurment for the RefEntity.
Definition at line 43 of file GeomDataObserver.hpp.
{ measureSet = CUBIT_TRUE;
myMeasure = val;}
CubitBoolean GeomDataObserver::measureSet [private] |
Definition at line 58 of file GeomDataObserver.hpp.
double GeomDataObserver::myMeasure [private] |
Definition at line 57 of file GeomDataObserver.hpp.
RefEntity* GeomDataObserver::myRefEntity [private] |
Definition at line 56 of file GeomDataObserver.hpp.
