cgma
#include <PlanarParamTool.hpp>
Public Member Functions | |
| PlanarParamTool () | |
| ~PlanarParamTool () | |
| CubitStatus | set_up_space (CubitVector &du, CubitVector &dv, CubitVector &uv_center) |
| CubitStatus | transform_to_uv (const CubitVector &xyz_location, CubitVector &uv_location) |
| CubitStatus | transform_to_xyz (CubitVector &xyz_location, const CubitVector &uv_location) |
| virtual CubitStatus | uv_derivitives (double u_param, double v_param, CubitVector &du, CubitVector &dv) |
Private Attributes | |
| CubitVector | Du |
| CubitVector | Dv |
| CubitVector | uvCenter |
Definition at line 20 of file PlanarParamTool.hpp.
Definition at line 25 of file PlanarParamTool.cpp.
Definition at line 35 of file PlanarParamTool.cpp.
| CubitStatus PlanarParamTool::set_up_space | ( | CubitVector & | du, |
| CubitVector & | dv, | ||
| CubitVector & | uv_center | ||
Definition at line 43 of file PlanarParamTool.cpp.
Du = du;
Dv = dv;
uvCenter = uv_center;
return CUBIT_SUCCESS;
| CubitStatus PlanarParamTool::transform_to_uv | ( | const CubitVector & | xyz_location, |
| CubitVector & | uv_location | ||
| ) | [virtual] |
Implements ParamTool.
Definition at line 58 of file PlanarParamTool.cpp.
// Translate to local origin at center
CubitVector vect = xyz_location - uvCenter;
// Multiply by transpose (inverse) of transformation vector
uv_location.x( vect % Du );
uv_location.y( vect % Dv );
uv_location.z( 0.0 );
| CubitStatus PlanarParamTool::transform_to_xyz | ( | CubitVector & | xyz_location, |
| const CubitVector & | uv_location | ||
| ) | [virtual] |
Definition at line 79 of file PlanarParamTool.cpp.
// Multiply by transformation matrix
CubitVector vect;
vect.x( uv_location.x() * Du.x() +
uv_location.y() * Dv.x() );
vect.y( uv_location.x() * Du.y() +
uv_location.y() * Dv.y() );
vect.z( uv_location.x() * Du.z() +
uv_location.y() * Dv.z() );
// Translate from origin
xyz_location = vect + uvCenter;
| CubitStatus PlanarParamTool::uv_derivitives | ( | double | u_param, |
| double | v_param, | ||
| CubitVector & | du, | ||
| CubitVector & | dv | ||
| ) | [virtual] |
Reimplemented from ParamTool.
Definition at line 98 of file PlanarParamTool.cpp.
(void)u_param;
(void)v_param;
du = Du;
dv = Dv;
CubitVector PlanarParamTool::Du [private] |
Definition at line 41 of file PlanarParamTool.hpp.
CubitVector PlanarParamTool::Dv [private] |
Definition at line 42 of file PlanarParamTool.hpp.
CubitVector PlanarParamTool::uvCenter [private] |
Definition at line 43 of file PlanarParamTool.hpp.
