cgma
#include <TDFacetBoundaryPoint.hpp>
Public Member Functions | |
| TDFacetBoundaryPoint () | |
| ~TDFacetBoundaryPoint () | |
| void | add_surf (int new_id) |
| CubitPoint * | get_point () |
| void | set_point (CubitPoint *point_ptr) |
| SetDynamicMemoryAllocation (memoryManager) static void set_memory_allocation_increment(int increment=0) | |
| CubitStatus | get_normal (int surf_id, CubitVector &normal) |
| CubitStatus | get_normal (CubitFacet *adj_facet, CubitVector &normal) |
| CubitStatus | get_normal (CubitFacetEdge *edge_ptr, CubitVector &normal) |
| CubitStatus | set_normal (int surf_id, CubitVector &normal) |
| CubitStatus | reset_normals () |
| CubitStatus | set_uv (CubitFacet *adj_facet, double u, double v) |
| CubitStatus | set_uvs (CubitFacet *adj_facet, double u, double v, double s) |
| double | u (CubitFacet *adj_facet) |
| double | v (CubitFacet *adj_facet) |
| double | s (CubitFacet *adj_facet) |
| CubitStatus | get_uv (CubitFacet *adj_facet, double &u, double &v) |
| CubitStatus | get_uvs (CubitFacet *adj_facet, double &u, double &v, double &s) |
| void | add_surf_facets (DLIList< CubitFacet * > adj_facet_list) |
| void | set_surf_id (CubitFacet *facet_ptr, int surf_id) |
| CubitStatus | merge_normals (CubitFacet *facet0, CubitFacet *facet1) |
| CubitStatus | rotate_normal (CubitTransformMatrix &rotmat) |
| CubitStatus | get_boundary_point_data_size (int &size_int_data, int &size_double_data) |
| CubitStatus | get_boundary_point_data (int *int_data, double *double_data, int &iidx, int &didx) |
| void | initialize (CubitFacet **facets, int &iidx, int &didx, int *int_data, double *double_data) |
Static Public Member Functions | |
| static int | is_facet_boundary_point (const ToolData *td) |
| static void | destroy_memory () |
| static CubitStatus | add_facet_boundary_point (CubitPoint *point_ptr) |
| static CubitStatus | add_facet_boundary_point (CubitPoint *point_ptr, CubitFacet *facet_ptr, CubitVector &normal) |
| static CubitStatus | add_facet_boundary_point (CubitPoint *point_ptr, CubitQuadFacet *qfacet_ptr, CubitVector &normal) |
| static TDFacetBoundaryPoint * | get_facet_boundary_point (CubitPoint *point_ptr) |
| static CubitStatus | new_facet_boundary_point (CubitPoint **points, CubitFacet **facets, int &iidx, int &didx, int *int_data, double *double_data) |
Private Member Functions | |
| void | init_normal (BoundaryPointData *bpd_ptr) |
| BoundaryPointData * | get_bpd (CubitFacet *facet) |
Private Attributes | |
| CubitPoint * | pointPtr |
| DLIList< BoundaryPointData * > | pointDataList |
Static Private Attributes | |
| static MemoryManager | memoryManager |
Definition at line 36 of file TDFacetBoundaryPoint.hpp.
Definition at line 18 of file TDFacetBoundaryPoint.cpp.
Definition at line 23 of file TDFacetBoundaryPoint.cpp.
for (int ii=0; ii<pointDataList.size(); ii++)
BoundaryPointData *bpd_ptr = pointDataList.get_and_step();
delete bpd_ptr;
| CubitStatus TDFacetBoundaryPoint::add_facet_boundary_point | ( | CubitPoint * | point_ptr | ) | [static] |
Definition at line 42 of file TDFacetBoundaryPoint.cpp.
ToolData *td;
td = point_ptr->get_TD(&TDFacetBoundaryPoint::is_facet_boundary_point);
if ( td == NULL )
TDFacetBoundaryPoint *td_gm = new TDFacetBoundaryPoint;
point_ptr->add_TD( td_gm);
td_gm->set_point( point_ptr );
else
TDFacetBoundaryPoint *td_gm = CAST_TO(td, TDFacetBoundaryPoint);
return CUBIT_SUCCESS;
| CubitStatus TDFacetBoundaryPoint::add_facet_boundary_point | ( | CubitPoint * | point_ptr, |
| CubitFacet * | facet_ptr, | ||
| CubitVector & | normal | ||
| ) | [static] |
Definition at line 71 of file TDFacetBoundaryPoint.cpp.
ToolData *td;
TDFacetBoundaryPoint *td_gm = NULL;
if ( td == NULL )
else
BoundaryPointData *bpd_ptr = new BoundaryPointData;
bpd_ptr->surfFacetList.append( facet_ptr );
bpd_ptr->surfID = -1;
bpd_ptr->uVal = 0.0;
bpd_ptr->vVal = 0.0;
bpd_ptr->sizeVal = 0.0;
bpd_ptr->normal = pt_normal;
td_gm->pointDataList.append( bpd_ptr );
| CubitQuadFacet * | qfacet_ptr, | ||
| ) | [static] |
Definition at line 114 of file TDFacetBoundaryPoint.cpp.
ToolData *td;
if ( td == NULL )
else
CubitFacet *facet0 = qfacet_ptr->get_tri_facet(0);
CubitFacet *facet1 = qfacet_ptr->get_tri_facet(1);
if (facet0->point_index( point_ptr ) >= 0)
bpd_ptr->surfFacetList.append( facet0 );
if (facet1->point_index( point_ptr ) >= 0)
bpd_ptr->surfFacetList.append( facet1 );
| void TDFacetBoundaryPoint::add_surf | ( | int | new_id | ) |
| void TDFacetBoundaryPoint::add_surf_facets | ( | DLIList< CubitFacet * > | adj_facet_list | ) |
Definition at line 185 of file TDFacetBoundaryPoint.cpp.
int ii;
for (ii=0; ii<adj_facet_list.size(); ii++)
CubitFacet *facet_ptr = adj_facet_list.get_and_step();
init_normal( bpd_ptr );
| static void TDFacetBoundaryPoint::destroy_memory | ( | ) | [inline, static] |
Definition at line 76 of file TDFacetBoundaryPoint.hpp.
| CubitStatus TDFacetBoundaryPoint::get_boundary_point_data | ( | int * | int_data, |
| double * | double_data, | ||
| int & | iidx, | ||
| int & | didx | ||
Definition at line 717 of file TDFacetBoundaryPoint.cpp.
int_data[iidx++] = pointPtr->id();
int num_bpd = pointDataList.size();
int_data[iidx++] = num_bpd;
BoundaryPointData *bpd_ptr;
int ii, jj;
int numfacs = 0;
CubitFacet *facet_ptr;
for (ii=0; ii<num_bpd; ii++)
numfacs = bpd_ptr->surfFacetList.size();
int_data[iidx++] = numfacs;
for (jj=0; jj<bpd_ptr->surfFacetList.size(); jj++)
facet_ptr = bpd_ptr->surfFacetList.get_and_step();
int_data[iidx++] = facet_ptr->id();
int_data[iidx++] = bpd_ptr->surfID;
double_data[didx++] = bpd_ptr->normal.x();
double_data[didx++] = bpd_ptr->normal.y();
double_data[didx++] = bpd_ptr->normal.z();
double_data[didx++] = bpd_ptr->sizeVal;
double_data[didx++] = bpd_ptr->uVal;
double_data[didx++] = bpd_ptr->vVal;
| CubitStatus TDFacetBoundaryPoint::get_boundary_point_data_size | ( | int & | size_int_data, |
| int & | size_double_data | ||
Definition at line 690 of file TDFacetBoundaryPoint.cpp.
int ii;
//pointPtr->id() and pointDataList.size()
size_int_data += 2;
size_int_data += 2;
//num_surfaces
size_int_data += bpd_ptr->surfFacetList.size();
size_double_data += num_bpd * 6;
| BoundaryPointData * TDFacetBoundaryPoint::get_bpd | ( | CubitFacet * | facet | ) | [private] |
Definition at line 469 of file TDFacetBoundaryPoint.cpp.
BoundaryPointData *bpd_ptr = NULL;
int found = 0;
int ii, jj;
for (ii=0; ii<pointDataList.size() && !found; ii++)
for (jj=0; jj<bpd_ptr->surfFacetList.size() && !found; jj++)
if (bpd_ptr->surfFacetList.get_and_step() == facet)
return bpd_ptr;
return NULL;
| TDFacetBoundaryPoint * TDFacetBoundaryPoint::get_facet_boundary_point | ( | CubitPoint * | point_ptr | ) | [static] |
Definition at line 161 of file TDFacetBoundaryPoint.cpp.
ToolData *td;
if ( td != NULL )
return td_gm;
return (TDFacetBoundaryPoint*) NULL;
| CubitStatus TDFacetBoundaryPoint::get_normal | ( | int | surf_id, |
Definition at line 213 of file TDFacetBoundaryPoint.cpp.
int found = 0;
if(bpd_ptr->surfID == surf_id)
found = 1;
if (!found) // the surf_id does not match any in the list
return CUBIT_FAILURE;
normal = bpd_ptr->normal;
| CubitStatus TDFacetBoundaryPoint::get_normal | ( | CubitFacet * | adj_facet, |
Definition at line 242 of file TDFacetBoundaryPoint.cpp.
BoundaryPointData *bpd_ptr = get_bpd( adj_facet );
if (!bpd_ptr)
| CubitStatus TDFacetBoundaryPoint::get_normal | ( | CubitFacetEdge * | edge_ptr, |
Definition at line 264 of file TDFacetBoundaryPoint.cpp.
DLIList<CubitFacet *>adj_facets;
edge_ptr->facets(adj_facets);
for (int ii=0; ii<adj_facets.size() && bpd_ptr == NULL; ii++)
bpd_ptr = get_bpd( adj_facets.get_and_step() );
if (!bpd_ptr)
| CubitPoint* TDFacetBoundaryPoint::get_point | ( | ) | [inline] |
Definition at line 63 of file TDFacetBoundaryPoint.hpp.
{ return pointPtr; }
| CubitStatus TDFacetBoundaryPoint::get_uv | ( | CubitFacet * | adj_facet, |
| double & | u, | ||
| double & | v | ||
Definition at line 639 of file TDFacetBoundaryPoint.cpp.
if (!bpd_ptr)
u = bpd_ptr->uVal;
v = bpd_ptr->vVal;
| CubitStatus TDFacetBoundaryPoint::get_uvs | ( | CubitFacet * | adj_facet, |
| double & | u, | ||
| double & | v, | ||
| double & | s | ||
Definition at line 655 of file TDFacetBoundaryPoint.cpp.
if (!bpd_ptr)
u = bpd_ptr->uVal;
v = bpd_ptr->vVal;
s = bpd_ptr->sizeVal;
| void TDFacetBoundaryPoint::init_normal | ( | BoundaryPointData * | bpd_ptr | ) | [private] |
Definition at line 374 of file TDFacetBoundaryPoint.cpp.
if (bpd_ptr && bpd_ptr->surfFacetList.size() > 0) {
CubitFacet *facet;
double angle;
int j;
CubitVector normal;
CubitVector avg_normal(0.0e0, 0.0e0, 0.0e0);
double totangle = 0.0e0;
// weight the normal by the spanning angle at the point
int mydebug =0;
for (j = 0; j < bpd_ptr->surfFacetList.size(); j++)
facet = bpd_ptr->surfFacetList.get_and_step();
angle = facet->angle( pointPtr );
facet->weight( angle );
totangle += angle;
if(mydebug){
if(angle <= 0.0){
PRINT_INFO("Small angle.\n");
//First...
// Attempt to handle this very odd case. There is a facet with
// zero area on the boundary. Set normal to that of an adjacet
// facet that doesn't have zero area.
if(totangle == 0 && bpd_ptr->surfFacetList.size() == 1){
PRINT_WARNING("Degenerate facet on edge of boundary.\n");
CubitPoint* my_pt[3];
my_pt[0] = facet->point(0);
my_pt[1] = facet->point(1);
my_pt[2] = facet->point(2);
double largest_area=-1.0;
double current_area=0.0;
if(my_pt[0] == NULL || my_pt[1] == NULL || my_pt[2] == NULL){
PRINT_ERROR("Problem determining normal.\n");
return;
int tmp_i;
for(tmp_i = 0; tmp_i < 3; tmp_i++){
CubitFacet* other_facet = facet->shared_facet(my_pt[tmp_i],
my_pt[(tmp_i+1)%3]);
if(other_facet != NULL){
if(mydebug)
other_facet->debug_draw(CUBIT_WHITE_INDEX);
current_area=other_facet->area();
if(current_area>largest_area){
largest_area=current_area;
normal=other_facet->normal();
if(largest_area < CUBIT_DBL_MIN){
PRINT_ERROR("Could not initialize facet normal.\n");
return;
if(mydebug){
facet->debug_draw(CUBIT_RED_INDEX);
PRINT_INFO("\n\nLargest area = %f\n\n",largest_area);
GfxDebug::mouse_xforms();
bpd_ptr->normal = normal;
//Now...
// Handle the normal case.
else{
normal = facet->normal();
normal.normalize();
avg_normal += (facet->weight() / totangle) * normal;
avg_normal.normalize();
bpd_ptr->normal = avg_normal;
| void TDFacetBoundaryPoint::initialize | ( | CubitFacet ** | facets, |
| int & | iidx, | ||
| int & | didx, | ||
| int * | int_data, | ||
| double * | double_data | ||
Definition at line 782 of file TDFacetBoundaryPoint.cpp.
int num_bpd = int_data[iidx++];
int ii, jj, id;
int numfacs = 0;
pointDataList.append(bpd_ptr);
numfacs = int_data[iidx++];
for (jj=0; jj<numfacs; jj++)
id = int_data[iidx++];
facet_ptr = facets[id];
bpd_ptr->surfFacetList.append(facet_ptr);
bpd_ptr->surfID = int_data[iidx++];
bpd_ptr->normal.x(double_data[didx++]);
bpd_ptr->normal.y(double_data[didx++]);
bpd_ptr->normal.z(double_data[didx++]);
bpd_ptr->sizeVal = double_data[didx++];
bpd_ptr->uVal = double_data[didx++];
bpd_ptr->vVal = double_data[didx++];
| static int TDFacetBoundaryPoint::is_facet_boundary_point | ( | const ToolData * | td | ) | [inline, static] |
Definition at line 58 of file TDFacetBoundaryPoint.hpp.
{return (CAST_TO(const_cast<ToolData*>(td), TDFacetBoundaryPoint) != NULL);}
| CubitStatus TDFacetBoundaryPoint::merge_normals | ( | CubitFacet * | facet0, |
| CubitFacet * | facet1 | ||
Definition at line 493 of file TDFacetBoundaryPoint.cpp.
BoundaryPointData *bpd0_ptr = get_bpd( facet0 );
BoundaryPointData *bpd1_ptr = get_bpd( facet1 );
if (!bpd0_ptr || !bpd1_ptr)
double angle;
CubitFacet *facet;
int j;
for (j = 0; j < bpd0_ptr->surfFacetList.size(); j++)
facet = bpd0_ptr->surfFacetList.get_and_step();
totangle += angle;
for (j = 0; j < bpd1_ptr->surfFacetList.size(); j++)
facet = bpd1_ptr->surfFacetList.get_and_step();
totangle += angle;
// computed weighted normal
CubitVector normal;
normal.normalize();
// orientation of facets may be opposite on opposing surfaces.
// Check for this case and correct of necessary
CubitVector norm0, norm1;
norm0 = bpd0_ptr->normal;
norm0.normalize();
norm1 = bpd1_ptr->normal;
norm1.normalize();
double dot = norm0 % norm1;
double sign = 1.0;
if (dot < 0.0)
sign = -1.0;
normal = sign * facet->normal();
normal.normalize();
// set the new normal on both points
bpd0_ptr->normal = avg_normal;
CubitVector temp_vector = sign * avg_normal;
bpd1_ptr->normal = temp_vector;
| CubitStatus TDFacetBoundaryPoint::new_facet_boundary_point | ( | CubitPoint ** | points, |
| CubitFacet ** | facets, | ||
| int & | iidx, | ||
| int & | didx, | ||
| ) | [static] |
Definition at line 758 of file TDFacetBoundaryPoint.cpp.
int id = int_data[iidx++];
CubitPoint *point_ptr = points[id];
TDFacetBoundaryPoint::add_facet_boundary_point(point_ptr);
TDFacetBoundaryPoint *td = (TDFacetBoundaryPoint *)
point_ptr->get_TD( &TDFacetBoundaryPoint::is_facet_boundary_point);
td->initialize( facets, iidx, didx, int_data, double_data );
Definition at line 317 of file TDFacetBoundaryPoint.cpp.
if(bpd_ptr)
init_normal(bpd_ptr);
else{
PRINT_ERROR("Could not determine boundary point data.\n");
Definition at line 672 of file TDFacetBoundaryPoint.cpp.
BoundaryPointData * bpd_ptr;
int ii;
for (ii=0; ii<pointDataList.size(); ii++)
bpd_ptr->normal = rotmat * bpd_ptr->normal;
| double TDFacetBoundaryPoint::s | ( | CubitFacet * | adj_facet | ) |
Definition at line 628 of file TDFacetBoundaryPoint.cpp.
assert( bpd_ptr != 0 ); // adjacent facet was not found in list
return bpd_ptr->sizeVal;
| CubitStatus TDFacetBoundaryPoint::set_normal | ( | int | surf_id, |
Definition at line 289 of file TDFacetBoundaryPoint.cpp.
int found = 0;
found = 1;
| void TDFacetBoundaryPoint::set_point | ( | CubitPoint * | point_ptr | ) | [inline] |
Definition at line 66 of file TDFacetBoundaryPoint.hpp.
{ pointPtr = point_ptr; }
| void TDFacetBoundaryPoint::set_surf_id | ( | CubitFacet * | facet_ptr, |
| int | surf_id | ||
Definition at line 343 of file TDFacetBoundaryPoint.cpp.
int found = 0;
int ii, jj;
CubitFacet *check_facet_ptr;
check_facet_ptr = bpd_ptr->surfFacetList.get_and_step();
if (check_facet_ptr == facet_ptr)
found = 1;
bpd_ptr->surfID = surf_id;
assert(found); // couldn't find the facet adjacent the surface
| CubitStatus TDFacetBoundaryPoint::set_uv | ( | CubitFacet * | adj_facet, |
| double | u, | ||
| double | v | ||
Definition at line 574 of file TDFacetBoundaryPoint.cpp.
if (!bpd_ptr)
bpd_ptr->uVal = u;
bpd_ptr->vVal = v;
| CubitStatus TDFacetBoundaryPoint::set_uvs | ( | CubitFacet * | adj_facet, |
| double | u, | ||
| double | v, | ||
| double | s | ||
Definition at line 589 of file TDFacetBoundaryPoint.cpp.
if (!bpd_ptr)
bpd_ptr->uVal = u;
bpd_ptr->vVal = v;
bpd_ptr->sizeVal = s;
| TDFacetBoundaryPoint::SetDynamicMemoryAllocation | ( | memoryManager | ) | [inline, pure virtual] |
Definition at line 69 of file TDFacetBoundaryPoint.hpp.
{memoryManager.set_memory_allocation_increment(increment);}
| double TDFacetBoundaryPoint::u | ( | CubitFacet * | adj_facet | ) |
Definition at line 605 of file TDFacetBoundaryPoint.cpp.
return bpd_ptr->uVal;
| double TDFacetBoundaryPoint::v | ( | CubitFacet * | adj_facet | ) |
Definition at line 617 of file TDFacetBoundaryPoint.cpp.
return bpd_ptr->vVal;
MemoryManager TDFacetBoundaryPoint::memoryManager [static, private] |
Definition at line 40 of file TDFacetBoundaryPoint.hpp.
DLIList<BoundaryPointData *> TDFacetBoundaryPoint::pointDataList [private] |
Definition at line 44 of file TDFacetBoundaryPoint.hpp.
CubitPoint* TDFacetBoundaryPoint::pointPtr [private] |
Definition at line 43 of file TDFacetBoundaryPoint.hpp.
