, including all inherited members.
| add_facet_boundary_point(CubitPoint *point_ptr) | TDFacetBoundaryPoint | [static] |
| add_facet_boundary_point(CubitPoint *point_ptr, CubitFacet *facet_ptr, CubitVector &normal) | TDFacetBoundaryPoint | [static] |
| add_facet_boundary_point(CubitPoint *point_ptr, CubitQuadFacet *qfacet_ptr, CubitVector &normal) | TDFacetBoundaryPoint | [static] |
| add_surf(int new_id) | TDFacetBoundaryPoint | |
| add_surf_facets(DLIList< CubitFacet * > adj_facet_list) | TDFacetBoundaryPoint | |
| destroy_memory() | TDFacetBoundaryPoint | [inline, static] |
| get_boundary_point_data(int *int_data, double *double_data, int &iidx, int &didx) | TDFacetBoundaryPoint | |
| get_boundary_point_data_size(int &size_int_data, int &size_double_data) | TDFacetBoundaryPoint | |
| get_bpd(CubitFacet *facet) | TDFacetBoundaryPoint | [private] |
| get_facet_boundary_point(CubitPoint *point_ptr) | TDFacetBoundaryPoint | [static] |
| get_normal(int surf_id, CubitVector &normal) | TDFacetBoundaryPoint | |
| get_normal(CubitFacet *adj_facet, CubitVector &normal) | TDFacetBoundaryPoint | |
| get_normal(CubitFacetEdge *edge_ptr, CubitVector &normal) | TDFacetBoundaryPoint | |
| get_point() | TDFacetBoundaryPoint | [inline] |
| get_uv(CubitFacet *adj_facet, double &u, double &v) | TDFacetBoundaryPoint | |
| get_uvs(CubitFacet *adj_facet, double &u, double &v, double &s) | TDFacetBoundaryPoint | |
| init_normal(BoundaryPointData *bpd_ptr) | TDFacetBoundaryPoint | [private] |
| initialize(CubitFacet **facets, int &iidx, int &didx, int *int_data, double *double_data) | TDFacetBoundaryPoint | |
| is_facet_boundary_point(const ToolData *td) | TDFacetBoundaryPoint | [inline, static] |
| memoryManager | TDFacetBoundaryPoint | [private, static] |
| merge(ToolDataUser *other_td_user) | ToolData | [virtual] |
| merge_normals(CubitFacet *facet0, CubitFacet *facet1) | TDFacetBoundaryPoint | |
| new_facet_boundary_point(CubitPoint **points, CubitFacet **facets, int &iidx, int &didx, int *int_data, double *double_data) | TDFacetBoundaryPoint | [static] |
| next_tool_data() | ToolData | [inline] |
| next_tool_data(ToolData *data) | ToolData | [inline] |
| pointDataList | TDFacetBoundaryPoint | [private] |
| pointPtr | TDFacetBoundaryPoint | [private] |
| propogate(ToolDataUser *new_td_user) | ToolData | [virtual] |
| reset_normals() | TDFacetBoundaryPoint | |
| rotate_normal(CubitTransformMatrix &rotmat) | TDFacetBoundaryPoint | |
| s(CubitFacet *adj_facet) | TDFacetBoundaryPoint | |
| set_normal(int surf_id, CubitVector &normal) | TDFacetBoundaryPoint | |
| set_point(CubitPoint *point_ptr) | TDFacetBoundaryPoint | [inline] |
| set_surf_id(CubitFacet *facet_ptr, int surf_id) | TDFacetBoundaryPoint | |
| set_uv(CubitFacet *adj_facet, double u, double v) | TDFacetBoundaryPoint | |
| set_uvs(CubitFacet *adj_facet, double u, double v, double s) | TDFacetBoundaryPoint | |
| SetDynamicMemoryAllocation(memoryManager) static void set_memory_allocation_increment(int increment=0) | TDFacetBoundaryPoint | [inline, pure virtual] |
| TDFacetBoundaryPoint() | TDFacetBoundaryPoint | |
| ToolData() | ToolData | [inline, protected] |
| u(CubitFacet *adj_facet) | TDFacetBoundaryPoint | |
| v(CubitFacet *adj_facet) | TDFacetBoundaryPoint | |
| ~TDFacetBoundaryPoint() | TDFacetBoundaryPoint | |
| ~ToolData() | ToolData | [virtual] |
