cgma
00001 //- Class: TDFacetBoundaryPoint 00002 //- Description: Tool data for storing additional information at 00003 //- the boundary of a facet set 00004 //- Owner: Steve Owen 00005 //- Checked by: 00006 //- Version: 00007 00008 #include "TDFacetBoundaryPoint.hpp" 00009 #include "CubitPoint.hpp" 00010 #include "CubitFacet.hpp" 00011 #include "CubitQuadFacet.hpp" 00012 #include "CubitFacetEdge.hpp" 00013 #include "CastTo.hpp" 00014 #include "CubitTransformMatrix.hpp" 00015 #include "GfxDebug.hpp" 00016 #include "CubitMessage.hpp" 00017 00018 TDFacetBoundaryPoint::TDFacetBoundaryPoint() 00019 { 00020 00021 } 00022 00023 TDFacetBoundaryPoint::~TDFacetBoundaryPoint() 00024 { 00025 for (int ii=0; ii<pointDataList.size(); ii++) 00026 { 00027 BoundaryPointData *bpd_ptr = pointDataList.get_and_step(); 00028 delete bpd_ptr; 00029 } 00030 } 00031 00032 00033 //------------------------------------------------------------------------- 00034 // Purpose : create a new facet boundary edge 00035 // 00036 // Special Notes : 00037 // 00038 // Creator : Steve Owen 00039 // 00040 // Creation Date : 05/01 00041 //------------------------------------------------------------------------- 00042 CubitStatus TDFacetBoundaryPoint::add_facet_boundary_point( 00043 CubitPoint *point_ptr ) 00044 { 00045 ToolData *td; 00046 td = point_ptr->get_TD(&TDFacetBoundaryPoint::is_facet_boundary_point); 00047 if ( td == NULL ) 00048 { 00049 TDFacetBoundaryPoint *td_gm = new TDFacetBoundaryPoint; 00050 point_ptr->add_TD( td_gm); 00051 td_gm->set_point( point_ptr ); 00052 } 00053 else 00054 { 00055 TDFacetBoundaryPoint *td_gm = CAST_TO(td, TDFacetBoundaryPoint); 00056 td_gm->set_point( point_ptr ); 00057 } 00058 return CUBIT_SUCCESS; 00059 } 00060 00061 //------------------------------------------------------------------------- 00062 // Purpose : create a new facet boundary point 00063 // 00064 // Special Notes : this is used to create and initialize with one facet 00065 // and its corresponding normal. 00066 // 00067 // Creator : Steve Owen 00068 // 00069 // Creation Date : 05/01 00070 //------------------------------------------------------------------------- 00071 CubitStatus TDFacetBoundaryPoint::add_facet_boundary_point( 00072 CubitPoint *point_ptr, 00073 CubitFacet *facet_ptr, 00074 CubitVector &pt_normal ) 00075 { 00076 ToolData *td; 00077 TDFacetBoundaryPoint *td_gm = NULL; 00078 td = point_ptr->get_TD(&TDFacetBoundaryPoint::is_facet_boundary_point); 00079 if ( td == NULL ) 00080 { 00081 td_gm = new TDFacetBoundaryPoint; 00082 point_ptr->add_TD( td_gm); 00083 td_gm->set_point( point_ptr ); 00084 } 00085 else 00086 { 00087 td_gm = CAST_TO(td, TDFacetBoundaryPoint); 00088 td_gm->set_point( point_ptr ); 00089 } 00090 00091 BoundaryPointData *bpd_ptr = new BoundaryPointData; 00092 bpd_ptr->surfFacetList.append( facet_ptr ); 00093 bpd_ptr->surfID = -1; 00094 bpd_ptr->uVal = 0.0; 00095 bpd_ptr->vVal = 0.0; 00096 bpd_ptr->sizeVal = 0.0; 00097 bpd_ptr->normal = pt_normal; 00098 td_gm->pointDataList.append( bpd_ptr ); 00099 00100 return CUBIT_SUCCESS; 00101 } 00102 00103 //------------------------------------------------------------------------- 00104 // Purpose : create a new facet boundary point 00105 // 00106 // Special Notes : this is used to create and initialize with one facet 00107 // and its corresponding normal. Same as above but uses 00108 // a CubitQuadFacet 00109 // 00110 // Creator : Steve Owen 00111 // 00112 // Creation Date : 01/2004 00113 //------------------------------------------------------------------------- 00114 CubitStatus TDFacetBoundaryPoint::add_facet_boundary_point( 00115 CubitPoint *point_ptr, 00116 CubitQuadFacet *qfacet_ptr, 00117 CubitVector &pt_normal ) 00118 { 00119 ToolData *td; 00120 TDFacetBoundaryPoint *td_gm = NULL; 00121 td = point_ptr->get_TD(&TDFacetBoundaryPoint::is_facet_boundary_point); 00122 if ( td == NULL ) 00123 { 00124 td_gm = new TDFacetBoundaryPoint; 00125 point_ptr->add_TD( td_gm); 00126 td_gm->set_point( point_ptr ); 00127 } 00128 else 00129 { 00130 td_gm = CAST_TO(td, TDFacetBoundaryPoint); 00131 td_gm->set_point( point_ptr ); 00132 } 00133 00134 CubitFacet *facet0 = qfacet_ptr->get_tri_facet(0); 00135 CubitFacet *facet1 = qfacet_ptr->get_tri_facet(1); 00136 00137 BoundaryPointData *bpd_ptr = new BoundaryPointData; 00138 if (facet0->point_index( point_ptr ) >= 0) 00139 bpd_ptr->surfFacetList.append( facet0 ); 00140 if (facet1->point_index( point_ptr ) >= 0) 00141 bpd_ptr->surfFacetList.append( facet1 ); 00142 bpd_ptr->surfID = -1; 00143 bpd_ptr->uVal = 0.0; 00144 bpd_ptr->vVal = 0.0; 00145 bpd_ptr->sizeVal = 0.0; 00146 bpd_ptr->normal = pt_normal; 00147 td_gm->pointDataList.append( bpd_ptr ); 00148 00149 return CUBIT_SUCCESS; 00150 } 00151 00152 //------------------------------------------------------------------------- 00153 // Purpose : get the facet boundary point from a point 00154 // 00155 // Special Notes : 00156 // 00157 // Creator : Steve Owen 00158 // 00159 // Creation Date : 05/01 00160 //------------------------------------------------------------------------- 00161 TDFacetBoundaryPoint* TDFacetBoundaryPoint::get_facet_boundary_point( 00162 CubitPoint *point_ptr ) 00163 { 00164 ToolData *td; 00165 td = point_ptr->get_TD(&TDFacetBoundaryPoint::is_facet_boundary_point); 00166 if ( td != NULL ) 00167 { 00168 TDFacetBoundaryPoint *td_gm = CAST_TO(td, TDFacetBoundaryPoint); 00169 return td_gm; 00170 } 00171 return (TDFacetBoundaryPoint*) NULL; 00172 } 00173 00174 00175 //------------------------------------------------------------------------- 00176 // Purpose : add a group of facets that are adjacent to this point 00177 // that are on the same surface 00178 // 00179 // Special Notes : 00180 // 00181 // Creator : Steve Owen 00182 // 00183 // Creation Date : 05/01 00184 //------------------------------------------------------------------------- 00185 void TDFacetBoundaryPoint::add_surf_facets( 00186 DLIList<CubitFacet *> adj_facet_list ) 00187 { 00188 BoundaryPointData *bpd_ptr = new BoundaryPointData; 00189 int ii; 00190 for (ii=0; ii<adj_facet_list.size(); ii++) 00191 { 00192 CubitFacet *facet_ptr = adj_facet_list.get_and_step(); 00193 bpd_ptr->surfFacetList.append( facet_ptr ); 00194 } 00195 00196 bpd_ptr->surfID = -1; 00197 bpd_ptr->uVal = 0.0; 00198 bpd_ptr->vVal = 0.0; 00199 bpd_ptr->sizeVal = 0.0; 00200 pointDataList.append( bpd_ptr ); 00201 init_normal( bpd_ptr ); 00202 } 00203 00204 //------------------------------------------------------------------------- 00205 // Purpose : get the normal from a boundary point 00206 // 00207 // Special Notes : 00208 // 00209 // Creator : Steve Owen 00210 // 00211 // Creation Date : 05/01 00212 //------------------------------------------------------------------------- 00213 CubitStatus TDFacetBoundaryPoint::get_normal( int surf_id, 00214 CubitVector &normal ) 00215 { 00216 int found = 0; 00217 BoundaryPointData *bpd_ptr = NULL; 00218 for (int ii=0; ii<pointDataList.size(); ii++) 00219 { 00220 bpd_ptr = pointDataList.get_and_step(); 00221 if(bpd_ptr->surfID == surf_id) 00222 found = 1; 00223 } 00224 if (!found) // the surf_id does not match any in the list 00225 return CUBIT_FAILURE; 00226 00227 normal = bpd_ptr->normal; 00228 00229 return CUBIT_SUCCESS; 00230 } 00231 00232 //------------------------------------------------------------------------- 00233 // Purpose : get the normal from a boundary point based on its 00234 // adjacent facet 00235 // 00236 // Special Notes : 00237 // 00238 // Creator : Steve Owen 00239 // 00240 // Creation Date : 05/01 00241 //------------------------------------------------------------------------- 00242 CubitStatus TDFacetBoundaryPoint::get_normal( CubitFacet *adj_facet, 00243 CubitVector &normal ) 00244 { 00245 BoundaryPointData *bpd_ptr = get_bpd( adj_facet ); 00246 if (!bpd_ptr) 00247 return CUBIT_FAILURE; 00248 normal = bpd_ptr->normal; 00249 return CUBIT_SUCCESS; 00250 } 00251 00252 //------------------------------------------------------------------------- 00253 // Purpose : get the normal from a boundary point based on its 00254 // adjacent edge 00255 // 00256 // Special Notes : this is really only unique if the edge is non-manifold 00257 // or the facets adjacent the edge all lie on the same 00258 // surface 00259 // 00260 // Creator : Steve Owen 00261 // 00262 // Creation Date : 05/01 00263 //------------------------------------------------------------------------- 00264 CubitStatus TDFacetBoundaryPoint::get_normal( CubitFacetEdge *edge_ptr, 00265 CubitVector &normal ) 00266 { 00267 DLIList<CubitFacet *>adj_facets; 00268 edge_ptr->facets(adj_facets); 00269 BoundaryPointData *bpd_ptr = NULL; 00270 for (int ii=0; ii<adj_facets.size() && bpd_ptr == NULL; ii++) 00271 { 00272 bpd_ptr = get_bpd( adj_facets.get_and_step() ); 00273 } 00274 if (!bpd_ptr) 00275 return CUBIT_FAILURE; 00276 normal = bpd_ptr->normal; 00277 return CUBIT_SUCCESS; 00278 } 00279 00280 //------------------------------------------------------------------------- 00281 // Purpose : set the normal into a boundary point 00282 // 00283 // Special Notes : 00284 // 00285 // Creator : Steve Owen 00286 // 00287 // Creation Date : 05/01 00288 //------------------------------------------------------------------------- 00289 CubitStatus TDFacetBoundaryPoint::set_normal( int surf_id, 00290 CubitVector &normal ) 00291 { 00292 int found = 0; 00293 BoundaryPointData *bpd_ptr = NULL; 00294 for (int ii=0; ii<pointDataList.size(); ii++) 00295 { 00296 bpd_ptr = pointDataList.get_and_step(); 00297 if(bpd_ptr->surfID == surf_id) 00298 found = 1; 00299 } 00300 if (!found) // the surf_id does not match any in the list 00301 return CUBIT_FAILURE; 00302 00303 bpd_ptr->normal = normal; 00304 00305 return CUBIT_SUCCESS; 00306 } 00307 00308 //------------------------------------------------------------------------- 00309 // Purpose : reset the all normals for boundary points 00310 // 00311 // Special Notes : 00312 // 00313 // Creator : Michael Brewer 00314 // 00315 // Creation Date : 02/05 00316 //------------------------------------------------------------------------- 00317 CubitStatus TDFacetBoundaryPoint::reset_normals( ) 00318 { 00319 BoundaryPointData *bpd_ptr; 00320 for (int ii=0; ii<pointDataList.size(); ii++) 00321 { 00322 bpd_ptr = pointDataList.get_and_step(); 00323 if(bpd_ptr) 00324 init_normal(bpd_ptr); 00325 else{ 00326 PRINT_ERROR("Could not determine boundary point data.\n"); 00327 return CUBIT_FAILURE; 00328 } 00329 } 00330 return CUBIT_SUCCESS; 00331 } 00332 00333 //------------------------------------------------------------------------- 00334 // Purpose : set the surface id of associated with one of the 00335 // facets adjacent to this point 00336 // 00337 // Special Notes : 00338 // 00339 // Creator : Steve Owen 00340 // 00341 // Creation Date : 05/01 00342 //------------------------------------------------------------------------- 00343 void TDFacetBoundaryPoint::set_surf_id( CubitFacet *facet_ptr, int surf_id ) 00344 { 00345 int found = 0; 00346 int ii, jj; 00347 CubitFacet *check_facet_ptr; 00348 BoundaryPointData *bpd_ptr; 00349 for (ii=0; ii<pointDataList.size() && !found; ii++) 00350 { 00351 bpd_ptr = pointDataList.get_and_step(); 00352 for (jj=0; jj<bpd_ptr->surfFacetList.size() && !found; jj++) 00353 { 00354 check_facet_ptr = bpd_ptr->surfFacetList.get_and_step(); 00355 if (check_facet_ptr == facet_ptr) 00356 { 00357 found = 1; 00358 bpd_ptr->surfID = surf_id; 00359 } 00360 } 00361 } 00362 assert(found); // couldn't find the facet adjacent the surface 00363 } 00364 00365 //------------------------------------------------------------------------- 00366 // Purpose : compute and set the normal 00367 // 00368 // Special Notes : 00369 // 00370 // Creator : Steve Owen 00371 // 00372 // Creation Date : 05/01 00373 //------------------------------------------------------------------------- 00374 void TDFacetBoundaryPoint::init_normal( BoundaryPointData *bpd_ptr ) 00375 { 00376 00377 if (bpd_ptr && bpd_ptr->surfFacetList.size() > 0) { 00378 CubitFacet *facet; 00379 double angle; 00380 int j; 00381 CubitVector normal; 00382 CubitVector avg_normal(0.0e0, 0.0e0, 0.0e0); 00383 double totangle = 0.0e0; 00384 00385 // weight the normal by the spanning angle at the point 00386 int mydebug =0; 00387 for (j = 0; j < bpd_ptr->surfFacetList.size(); j++) 00388 { 00389 facet = bpd_ptr->surfFacetList.get_and_step(); 00390 angle = facet->angle( pointPtr ); 00391 facet->weight( angle ); 00392 totangle += angle; 00393 if(mydebug){ 00394 if(angle <= 0.0){ 00395 PRINT_INFO("Small angle.\n"); 00396 } 00397 } 00398 } 00399 //First... 00400 // Attempt to handle this very odd case. There is a facet with 00401 // zero area on the boundary. Set normal to that of an adjacet 00402 // facet that doesn't have zero area. 00403 if(totangle == 0 && bpd_ptr->surfFacetList.size() == 1){ 00404 PRINT_WARNING("Degenerate facet on edge of boundary.\n"); 00405 facet = bpd_ptr->surfFacetList.get_and_step(); 00406 00407 CubitPoint* my_pt[3]; 00408 my_pt[0] = facet->point(0); 00409 my_pt[1] = facet->point(1); 00410 my_pt[2] = facet->point(2); 00411 double largest_area=-1.0; 00412 double current_area=0.0; 00413 if(my_pt[0] == NULL || my_pt[1] == NULL || my_pt[2] == NULL){ 00414 PRINT_ERROR("Problem determining normal.\n"); 00415 return; 00416 } 00417 00418 int tmp_i; 00419 for(tmp_i = 0; tmp_i < 3; tmp_i++){ 00420 CubitFacet* other_facet = facet->shared_facet(my_pt[tmp_i], 00421 my_pt[(tmp_i+1)%3]); 00422 if(other_facet != NULL){ 00423 if(mydebug) 00424 other_facet->debug_draw(CUBIT_WHITE_INDEX); 00425 current_area=other_facet->area(); 00426 if(current_area>largest_area){ 00427 largest_area=current_area; 00428 normal=other_facet->normal(); 00429 } 00430 } 00431 } 00432 if(largest_area < CUBIT_DBL_MIN){ 00433 PRINT_ERROR("Could not initialize facet normal.\n"); 00434 return; 00435 } 00436 if(mydebug){ 00437 facet->debug_draw(CUBIT_RED_INDEX); 00438 PRINT_INFO("\n\nLargest area = %f\n\n",largest_area); 00439 GfxDebug::mouse_xforms(); 00440 } 00441 bpd_ptr->normal = normal; 00442 00443 } 00444 //Now... 00445 // Handle the normal case. 00446 else{ 00447 for (j = 0; j < bpd_ptr->surfFacetList.size(); j++) 00448 { 00449 facet = bpd_ptr->surfFacetList.get_and_step(); 00450 normal = facet->normal(); 00451 normal.normalize(); 00452 avg_normal += (facet->weight() / totangle) * normal; 00453 } 00454 avg_normal.normalize(); 00455 bpd_ptr->normal = avg_normal; 00456 } 00457 } 00458 } 00459 00460 //------------------------------------------------------------------------- 00461 // Purpose : return the boundary point data associated with a facet 00462 // 00463 // Special Notes : 00464 // 00465 // Creator : Steve Owen 00466 // 00467 // Creation Date : 05/01 00468 //------------------------------------------------------------------------- 00469 BoundaryPointData *TDFacetBoundaryPoint::get_bpd( CubitFacet *facet ) 00470 { 00471 BoundaryPointData *bpd_ptr = NULL; 00472 int found = 0; 00473 int ii, jj; 00474 for (ii=0; ii<pointDataList.size() && !found; ii++) 00475 { 00476 bpd_ptr = pointDataList.get_and_step(); 00477 for (jj=0; jj<bpd_ptr->surfFacetList.size() && !found; jj++) 00478 { 00479 if (bpd_ptr->surfFacetList.get_and_step() == facet) 00480 return bpd_ptr; 00481 } 00482 } 00483 00484 return NULL; 00485 } 00486 00487 //=============================================================================== 00488 //Function: merge_normals (PRIVATE) 00489 //Description: Enforce continuity across facets by merging the normals at two 00490 // points. Assumes the points are coincident. 00491 //Date: 05/01 00492 //=============================================================================== 00493 CubitStatus TDFacetBoundaryPoint::merge_normals( 00494 CubitFacet *facet0, 00495 CubitFacet *facet1) 00496 { 00497 00498 BoundaryPointData *bpd0_ptr = get_bpd( facet0 ); 00499 BoundaryPointData *bpd1_ptr = get_bpd( facet1 ); 00500 if (!bpd0_ptr || !bpd1_ptr) 00501 return CUBIT_FAILURE; 00502 00503 CubitVector avg_normal(0.0e0, 0.0e0, 0.0e0); 00504 double totangle = 0.0e0; 00505 double angle; 00506 CubitFacet *facet; 00507 int j; 00508 00509 // weight the normal by the spanning angle at the point 00510 00511 for (j = 0; j < bpd0_ptr->surfFacetList.size(); j++) 00512 { 00513 facet = bpd0_ptr->surfFacetList.get_and_step(); 00514 angle = facet->angle( pointPtr ); 00515 facet->weight( angle ); 00516 totangle += angle; 00517 } 00518 00519 for (j = 0; j < bpd1_ptr->surfFacetList.size(); j++) 00520 { 00521 facet = bpd1_ptr->surfFacetList.get_and_step(); 00522 angle = facet->angle( pointPtr ); 00523 facet->weight( angle ); 00524 totangle += angle; 00525 } 00526 00527 // computed weighted normal 00528 00529 CubitVector normal; 00530 for (j = 0; j < bpd0_ptr->surfFacetList.size(); j++) 00531 { 00532 facet = bpd0_ptr->surfFacetList.get_and_step(); 00533 normal = facet->normal(); 00534 normal.normalize(); 00535 avg_normal += (facet->weight() / totangle) * normal; 00536 } 00537 00538 // orientation of facets may be opposite on opposing surfaces. 00539 // Check for this case and correct of necessary 00540 00541 CubitVector norm0, norm1; 00542 norm0 = bpd0_ptr->normal; 00543 norm0.normalize(); 00544 norm1 = bpd1_ptr->normal; 00545 norm1.normalize(); 00546 double dot = norm0 % norm1; 00547 double sign = 1.0; 00548 if (dot < 0.0) 00549 sign = -1.0; 00550 00551 for (j = 0; j < bpd1_ptr->surfFacetList.size(); j++) 00552 { 00553 facet = bpd1_ptr->surfFacetList.get_and_step(); 00554 normal = sign * facet->normal(); 00555 normal.normalize(); 00556 avg_normal += (facet->weight() / totangle) * normal; 00557 } 00558 00559 // set the new normal on both points 00560 00561 avg_normal.normalize(); 00562 bpd0_ptr->normal = avg_normal; 00563 CubitVector temp_vector = sign * avg_normal; 00564 bpd1_ptr->normal = temp_vector; 00565 00566 return CUBIT_SUCCESS; 00567 } 00568 00569 //=============================================================================== 00570 //Function: set_uv (PUBLIC) 00571 //Description: set the u-v values on a boundary point data 00572 //Date: 06/01 00573 //=============================================================================== 00574 CubitStatus TDFacetBoundaryPoint::set_uv( CubitFacet *adj_facet, 00575 double u, double v ) 00576 { 00577 BoundaryPointData *bpd_ptr = get_bpd( adj_facet ); 00578 if (!bpd_ptr) 00579 return CUBIT_FAILURE; 00580 bpd_ptr->uVal = u; 00581 bpd_ptr->vVal = v; 00582 return CUBIT_SUCCESS; 00583 } 00584 //=============================================================================== 00585 //Function: set_uvs (PUBLIC) 00586 //Description: set the u-v values and size on a boundary point data 00587 //Date: 06/01 00588 //=============================================================================== 00589 CubitStatus TDFacetBoundaryPoint::set_uvs( CubitFacet *adj_facet, 00590 double u, double v, double s ) 00591 { 00592 BoundaryPointData *bpd_ptr = get_bpd( adj_facet ); 00593 if (!bpd_ptr) 00594 return CUBIT_FAILURE; 00595 bpd_ptr->uVal = u; 00596 bpd_ptr->vVal = v; 00597 bpd_ptr->sizeVal = s; 00598 return CUBIT_SUCCESS; 00599 } 00600 //=============================================================================== 00601 //Function: u (PUBLIC) 00602 //Description: get the u value from a boundary point data 00603 //Date: 06/01 00604 //=============================================================================== 00605 double TDFacetBoundaryPoint::u( CubitFacet *adj_facet ) 00606 { 00607 BoundaryPointData *bpd_ptr = get_bpd( adj_facet ); 00608 assert( bpd_ptr != 0 ); // adjacent facet was not found in list 00609 return bpd_ptr->uVal; 00610 } 00611 00612 //=============================================================================== 00613 //Function: v (PUBLIC) 00614 //Description: get the v value from a boundary point data 00615 //Date: 06/01 00616 //=============================================================================== 00617 double TDFacetBoundaryPoint::v( CubitFacet *adj_facet ) 00618 { 00619 BoundaryPointData *bpd_ptr = get_bpd( adj_facet ); 00620 assert( bpd_ptr != 0 ); // adjacent facet was not found in list 00621 return bpd_ptr->vVal; 00622 } 00623 //=============================================================================== 00624 //Function: s (PUBLIC) 00625 //Description: get the s value from a boundary point data 00626 //Date: 07/02 00627 //=============================================================================== 00628 double TDFacetBoundaryPoint::s( CubitFacet *adj_facet ) 00629 { 00630 BoundaryPointData *bpd_ptr = get_bpd( adj_facet ); 00631 assert( bpd_ptr != 0 ); // adjacent facet was not found in list 00632 return bpd_ptr->sizeVal; 00633 } 00634 //=============================================================================== 00635 //Function: get_uv (PUBLIC) 00636 //Description: get the uv values from a boundary point data 00637 //Date: 06/01 00638 //=============================================================================== 00639 CubitStatus TDFacetBoundaryPoint::get_uv( CubitFacet *adj_facet, 00640 double &u, double &v ) 00641 { 00642 BoundaryPointData *bpd_ptr = get_bpd( adj_facet ); 00643 if (!bpd_ptr) 00644 return CUBIT_FAILURE; 00645 u = bpd_ptr->uVal; 00646 v = bpd_ptr->vVal; 00647 return CUBIT_SUCCESS; 00648 } 00649 00650 //=============================================================================== 00651 //Function: get_uvs (PUBLIC) 00652 //Description: get the uv values and size from a boundary point data 00653 //Date: 7/02 00654 //=============================================================================== 00655 CubitStatus TDFacetBoundaryPoint::get_uvs( CubitFacet *adj_facet, 00656 double &u, double &v, double &s ) 00657 { 00658 BoundaryPointData *bpd_ptr = get_bpd( adj_facet ); 00659 if (!bpd_ptr) 00660 return CUBIT_FAILURE; 00661 u = bpd_ptr->uVal; 00662 v = bpd_ptr->vVal; 00663 s = bpd_ptr->sizeVal; 00664 return CUBIT_SUCCESS; 00665 } 00666 00667 //=============================================================================== 00668 //Function: rotate_normal (PUBLIC) 00669 //Description: rotate the normal at this point 00670 //Date: 03/02 00671 //=============================================================================== 00672 CubitStatus TDFacetBoundaryPoint::rotate_normal( CubitTransformMatrix &rotmat ) 00673 { 00674 BoundaryPointData * bpd_ptr; 00675 00676 int ii; 00677 for (ii=0; ii<pointDataList.size(); ii++) 00678 { 00679 bpd_ptr = pointDataList.get_and_step(); 00680 bpd_ptr->normal = rotmat * bpd_ptr->normal; 00681 } 00682 return CUBIT_SUCCESS; 00683 } 00684 00685 //=============================================================================== 00686 //Function: get_boundary_point_data_size (PUBLIC) 00687 //Description: get the size of the boundary point data for mem alloc. purposes 00688 //Date: 01/23/2003 00689 //=============================================================================== 00690 CubitStatus TDFacetBoundaryPoint::get_boundary_point_data_size( 00691 int &size_int_data, 00692 int &size_double_data ) 00693 { 00694 int num_bpd = pointDataList.size(); 00695 int ii; 00696 BoundaryPointData *bpd_ptr; 00697 00698 //pointPtr->id() and pointDataList.size() 00699 size_int_data += 2; 00700 for (ii=0; ii<num_bpd; ii++) 00701 { 00702 size_int_data += 2; 00703 bpd_ptr = pointDataList.get_and_step(); 00704 //num_surfaces 00705 size_int_data += bpd_ptr->surfFacetList.size(); 00706 } 00707 size_double_data += num_bpd * 6; 00708 return CUBIT_SUCCESS; 00709 } 00710 00711 //=============================================================================== 00712 //Function: get_boundary_point_data (PUBLIC) 00713 //Description: retreive the boundary point data so it can be dumped to a file 00714 // data must be allocated prior to calling this function! 00715 //Date: 01/23/2003 00716 //=============================================================================== 00717 CubitStatus TDFacetBoundaryPoint::get_boundary_point_data(int *int_data, 00718 double *double_data, 00719 int &iidx, 00720 int &didx ) 00721 { 00722 int_data[iidx++] = pointPtr->id(); 00723 int num_bpd = pointDataList.size(); 00724 int_data[iidx++] = num_bpd; 00725 00726 BoundaryPointData *bpd_ptr; 00727 int ii, jj; 00728 int numfacs = 0; 00729 CubitFacet *facet_ptr; 00730 for (ii=0; ii<num_bpd; ii++) 00731 { 00732 bpd_ptr = pointDataList.get_and_step(); 00733 numfacs = bpd_ptr->surfFacetList.size(); 00734 int_data[iidx++] = numfacs; 00735 for (jj=0; jj<bpd_ptr->surfFacetList.size(); jj++) 00736 { 00737 facet_ptr = bpd_ptr->surfFacetList.get_and_step(); 00738 int_data[iidx++] = facet_ptr->id(); 00739 } 00740 int_data[iidx++] = bpd_ptr->surfID; 00741 00742 double_data[didx++] = bpd_ptr->normal.x(); 00743 double_data[didx++] = bpd_ptr->normal.y(); 00744 double_data[didx++] = bpd_ptr->normal.z(); 00745 double_data[didx++] = bpd_ptr->sizeVal; 00746 double_data[didx++] = bpd_ptr->uVal; 00747 double_data[didx++] = bpd_ptr->vVal; 00748 } 00749 return CUBIT_SUCCESS; 00750 } 00751 00752 //=============================================================================== 00753 //Function: new_boundary_point_data (static PUBLIC) 00754 //Description: create a new boundary point data and assign to a cubit point 00755 //Author: sjowen 00756 //Date: 01/26/2003 00757 //=============================================================================== 00758 CubitStatus TDFacetBoundaryPoint::new_facet_boundary_point(CubitPoint **points, 00759 CubitFacet **facets, 00760 int &iidx, 00761 int &didx, 00762 int *int_data, 00763 double *double_data) 00764 { 00765 int id = int_data[iidx++]; 00766 CubitPoint *point_ptr = points[id]; 00767 TDFacetBoundaryPoint::add_facet_boundary_point(point_ptr); 00768 TDFacetBoundaryPoint *td = (TDFacetBoundaryPoint *) 00769 point_ptr->get_TD( &TDFacetBoundaryPoint::is_facet_boundary_point); 00770 00771 td->initialize( facets, iidx, didx, int_data, double_data ); 00772 00773 return CUBIT_SUCCESS; 00774 } 00775 00776 //=============================================================================== 00777 //Function: initialize (PUBLIC) 00778 //Description: initialize a boundary point data from data read from a CUB file 00779 //Author: sjowen 00780 //Date: 01/26/2003 00781 //=============================================================================== 00782 void TDFacetBoundaryPoint::initialize(CubitFacet **facets, 00783 int &iidx, 00784 int &didx, 00785 int *int_data, 00786 double *double_data) 00787 { 00788 int num_bpd = int_data[iidx++]; 00789 00790 BoundaryPointData *bpd_ptr; 00791 int ii, jj, id; 00792 int numfacs = 0; 00793 CubitFacet *facet_ptr; 00794 for (ii=0; ii<num_bpd; ii++) 00795 { 00796 bpd_ptr = new BoundaryPointData; 00797 pointDataList.append(bpd_ptr); 00798 numfacs = int_data[iidx++]; 00799 for (jj=0; jj<numfacs; jj++) 00800 { 00801 id = int_data[iidx++]; 00802 facet_ptr = facets[id]; 00803 bpd_ptr->surfFacetList.append(facet_ptr); 00804 } 00805 bpd_ptr->surfID = int_data[iidx++]; 00806 00807 bpd_ptr->normal.x(double_data[didx++]); 00808 bpd_ptr->normal.y(double_data[didx++]); 00809 bpd_ptr->normal.z(double_data[didx++]); 00810 bpd_ptr->sizeVal = double_data[didx++]; 00811 bpd_ptr->uVal = double_data[didx++]; 00812 bpd_ptr->vVal = double_data[didx++]; 00813 } 00814 00815 } 00816 00817 // eof
