cgma
00001 //------------------------------------------------------------------------- 00002 // Filename : VirtualQueryEngine.cc 00003 // 00004 // Purpose : This file contains the implementation of the class 00005 // VirtualQueryEngine. 00006 // 00007 // Special Notes : There are several functions in this class which are 00008 // inhereted from GeometryQueryEngine that are not 00009 // implemented or applicable in this class. These 00010 // functions, if called, will print an error message 00011 // and return the most appropriate error condition available. 00012 // 00013 // Creator : Jason Kraftcheck 00014 // 00015 // Creation Date : 08/01/97 00016 //------------------------------------------------------------------------- 00017 00018 // ********** BEGIN STANDARD INCLUDES ********** 00019 #include <assert.h> 00020 // ********** END STANDARD INCLUDES ********** 00021 00022 // ********** BEGIN CUBIT INCLUDES ********** 00023 00024 #include "VirtualQueryEngine.hpp" 00025 #include "CompositeTool.hpp" 00026 #include "PartitionTool.hpp" 00027 #include "CompositeEngine.hpp" 00028 #include "PartitionEngine.hpp" 00029 #include "GeometryUtil.hpp" 00030 00031 #include "CubitDefines.h" 00032 #include "GeometryDefines.h" 00033 #include "CubitVector.hpp" 00034 00035 #include "CastTo.hpp" 00036 #include "GMem.hpp" 00037 00038 #include "ModelQueryEngine.hpp" 00039 #include "AppUtil.hpp" 00040 00041 #include "Body.hpp" 00042 #include "CoVolume.hpp" 00043 #include "RefVolume.hpp" 00044 #include "RefFace.hpp" 00045 #include "Loop.hpp" 00046 #include "CoEdge.hpp" 00047 #include "RefEdge.hpp" 00048 #include "Chain.hpp" 00049 #include "CoVertex.hpp" 00050 #include "RefVertex.hpp" 00051 #include "RefEntityFactory.hpp" 00052 #include "CoFace.hpp" 00053 00054 00055 #include "CompositePoint.hpp" 00056 #include "CompositeCurve.hpp" 00057 #include "CompositeSurface.hpp" 00058 #include "CompositeLump.hpp" 00059 #include "CompositeBody.hpp" 00060 #include "PartitionBody.hpp" 00061 #include "PartitionLump.hpp" 00062 #include "PartitionSurface.hpp" 00063 #include "PartitionCurve.hpp" 00064 00065 00066 #include "Shell.hpp" 00067 #include "GeometryQueryTool.hpp" 00068 #include "CubitPointData.hpp" 00069 #include "CubitFacetData.hpp" 00070 #include "CubitFacetEdgeData.hpp" 00071 00072 #include "CACompositeVG.hpp" 00073 #include "CAPartitionVG.hpp" 00074 #include "CAVirtualVG.hpp" 00075 00076 #include "HiddenEntitySet.hpp" 00077 #include "SubEntitySet.hpp" 00078 00079 // ********** END CUBIT INCLUDES ********** 00080 00081 // ********** BEGIN STATIC DECLARATIONS ********** 00082 VirtualQueryEngine* VirtualQueryEngine::instance_ = NULL; 00083 //- A pointer to the single instance of this class 00084 00085 00086 const int VirtualQueryEngine::VGE_MAJOR_VERSION = 10; 00087 const int VirtualQueryEngine::VGE_MINOR_VERSION = 0; 00088 const int VirtualQueryEngine::VGE_SUBMINOR_VERSION = 0; 00089 00090 const double VirtualQueryEngine::param_epsilon_fraction = 1000000; 00091 //- This value is used to determine epsilon for 00092 //- compensating for rounding error in parameter 00093 //- conversion between virtaul geometry and real 00094 //- geometry. 00095 00096 // ********** END STATIC DECLARATIONS ********** 00097 00098 // ********** BEGIN PUBLIC FUNCTIONS ********** 00099 00100 //------------------------------------------------------------------------- 00101 // Purpose : Destructor 00102 // 00103 // Special Notes : 00104 // 00105 // Creator : Jason Kraftcheck 00106 // 00107 // Creation Date : 08/01/97 00108 //------------------------------------------------------------------------- 00109 VirtualQueryEngine::~VirtualQueryEngine( ) 00110 { 00111 // destroy_all_virtual_entities(); 00112 // if( virtual_entity_list_.size() ) 00113 // PRINT_WARNING("Not all virtual geometry has been removed. " 00114 // "This is a bug (memory leak). Please report it.\n"); 00115 // assert( virtual_entity_list_.size() == 0 ); 00116 00117 PartitionEngine::delete_instance(); 00118 CompositeEngine::delete_instance(); 00119 00120 instance_ = NULL; 00121 } 00122 00123 void VirtualQueryEngine::delete_instance() 00124 { 00125 if( NULL != instance_ ) 00126 { 00127 delete instance_; 00128 instance_ = NULL; 00129 } 00130 } 00131 00132 00133 //------------------------------------------------------------------------- 00134 // Purpose : Return a description of this ModelingEngine 00135 // 00136 // Special Notes : 00137 // 00138 // Creator : Jason Kraftcheck 00139 // 00140 // Creation Date : 08/01/97 00141 //------------------------------------------------------------------------- 00142 int VirtualQueryEngine::get_major_version() 00143 { 00144 return VGE_MAJOR_VERSION; 00145 } 00146 00147 int VirtualQueryEngine::get_minor_version() 00148 { 00149 return VGE_MINOR_VERSION; 00150 } 00151 00152 int VirtualQueryEngine::get_subminor_version() 00153 { 00154 return VGE_SUBMINOR_VERSION; 00155 } 00156 00157 CubitString VirtualQueryEngine::get_engine_version_string() 00158 { 00159 CubitString return_this( 00160 "VirtualQueryEngine v1.2 by Jason Kraftcheck.\n" ); 00161 return_this += "I-CARVE Lab., University of Wisconsin - Madison, August 1, 1997.\n"; 00162 return_this += "This ModelingEngine performs the necessary topological "; 00163 return_this += "operations for working with VirtualEntities, including "; 00164 return_this += "objects of type CompositeEntity, PartitionEntity, and "; 00165 return_this += "ParasiteEntity. ComposinteModelingEngine also "; 00166 return_this += "provides the interface for creating, destroying, and "; 00167 return_this += "modifying VirtualEntities.\n"; 00168 00169 return return_this; 00170 } 00171 00172 CubitStatus VirtualQueryEngine::transform_vec_position( 00173 CubitVector const& , 00174 BodySM *, 00175 CubitVector & ) const 00176 { 00177 return CUBIT_FAILURE; 00178 } 00179 00180 //This is only for partition surfaces!!!!!!!!!!!!!!!!!! 00181 CubitStatus VirtualQueryEngine::get_graphics( Surface* surf_ptr, 00182 GMem *gmem, 00183 std::vector<TopologyBridge*> &vertex_edge_to_point_vector, 00184 std::vector<std::pair<TopologyBridge*, std::pair<int,int> > > &facet_edges_on_curves, 00185 unsigned short normal_tol, 00186 double dist_tol, 00187 double max_edge_length ) const 00188 { 00189 PartitionSurface* ps_ptr = CAST_TO(surf_ptr, PartitionSurface ); 00190 if( ps_ptr != NULL ) 00191 { 00192 return get_partition_surface_facetting( ps_ptr, gmem, &vertex_edge_to_point_vector, &facet_edges_on_curves, 00193 normal_tol, dist_tol, max_edge_length ); 00194 } 00195 00196 CompositeSurface* cs_ptr = CAST_TO(surf_ptr, CompositeSurface ); 00197 if( cs_ptr != NULL ) 00198 { 00199 return get_composite_surface_facetting( cs_ptr, gmem, &vertex_edge_to_point_vector, &facet_edges_on_curves, 00200 normal_tol, dist_tol, max_edge_length ); 00201 } 00202 //PRINT_INFO("VirtualQueryEngine::get_graphics_facets" 00203 // "( s%p, %p, %d, %f ) = CUBIT_FAILURE\n", 00204 // surf_ptr, gmem, normal_tol, dist_tol); 00205 return CUBIT_FAILURE; 00206 } 00207 00208 00209 00210 //------------------------------------------------------------------------- 00211 // Purpose : This function determines faceting information for use 00212 // by HOOPS. 00213 // 00214 // Special Notes : 00215 // 00216 // Creator : Jason Kraftcheck 00217 // 00218 // Creation Date : 00219 //------------------------------------------------------------------------- 00220 CubitStatus VirtualQueryEngine::get_graphics( 00221 Surface* surf_ptr, 00222 GMem* gMem, 00223 unsigned short normal_tol, 00224 double dist_tol, 00225 double max_edge_length ) const 00226 { 00227 CompositeSurface* cs_ptr = CAST_TO(surf_ptr, CompositeSurface ); 00228 PartitionSurface* ps_ptr = CAST_TO(surf_ptr, PartitionSurface ); 00229 if( cs_ptr != NULL ) 00230 { 00231 return get_composite_surface_facetting( cs_ptr, gMem, NULL, NULL, 00232 normal_tol, dist_tol, max_edge_length ); 00233 } 00234 else if( ps_ptr != NULL ) 00235 { 00236 return get_partition_surface_facetting( ps_ptr, gMem, NULL, NULL, 00237 normal_tol, dist_tol, max_edge_length ); 00238 } 00239 else 00240 { 00241 PRINT_INFO("VirtualQueryEngine::get_graphics_facets" 00242 "( s%p, %p, %d, %f ) = CUBIT_FAILURE\n", 00243 (void*)surf_ptr, (void*)gMem, normal_tol, dist_tol); 00244 return CUBIT_FAILURE; 00245 } 00246 } 00247 00248 //----------------------------------------------------------------------- 00249 // Purpose : This function returns the necessary faceting information 00250 // to display the curve. 00251 // 00252 // Special Notes : 00253 // 00254 // Creator : Jason Kraftcheck 00255 // 00256 // Creation Date : 10/10/97 00257 //----------------------------------------------------------------------- 00258 CubitStatus VirtualQueryEngine::get_graphics( Curve* curve_ptr, 00259 GMem* gMem, 00260 double angle_tolerance, 00261 double distance_tolerance, 00262 double max_edge_length ) const 00263 { 00264 CompositeCurve* ccurve = CAST_TO( curve_ptr, CompositeCurve ); 00265 PartitionCurve* pcurve = CAST_TO( curve_ptr, PartitionCurve ); 00266 00267 CubitStatus result; 00268 00269 if( ccurve != NULL ) 00270 { 00271 result = get_composite_curve_facetting( ccurve, gMem, angle_tolerance, 00272 distance_tolerance, max_edge_length ); 00273 } 00274 else if( pcurve != NULL ) 00275 { 00276 result = get_partition_curve_facetting( pcurve, gMem, angle_tolerance, 00277 distance_tolerance, max_edge_length ); 00278 } 00279 else 00280 { 00281 PRINT_ERROR("Unknown curve type or NULL curve passed to " 00282 "VirtualQueryEngine::get_graphics_edges()\n"); 00283 return CUBIT_FAILURE; 00284 } 00285 00286 return result; 00287 } 00288 00289 // This is the template for an unimplemented version of this function. 00290 CubitStatus VirtualQueryEngine::get_isoparametric_points(Surface*, 00291 int &nu, int &nv, 00292 GMem*& ) const 00293 { 00294 nu = nv = 0; 00295 return CUBIT_FAILURE; 00296 } 00297 00298 // This is the template for an unimplemented version of this function. 00299 CubitStatus VirtualQueryEngine::get_u_isoparametric_points(Surface*, 00300 double , int& , 00301 GMem*& ) const 00302 { 00303 return CUBIT_FAILURE; 00304 } 00305 00306 // This is the template for an unimplemented version of this function. 00307 CubitStatus VirtualQueryEngine::get_v_isoparametric_points(Surface*, 00308 double , int& , 00309 GMem*&) const 00310 { 00311 return CUBIT_FAILURE; 00312 } 00313 00314 //----------------------------------------------------------------------- 00315 // Purpose : This function constructs the edge facetting information 00316 // of a CompositeCurve for use by HOOPS. 00317 // 00318 // Special Notes : 00319 // 00320 // Creator : Jason Kraftcheck 00321 // 00322 // Creation Date : 10/10/97 00323 //----------------------------------------------------------------------- 00324 CubitStatus VirtualQueryEngine::get_composite_curve_facetting( 00325 CompositeCurve* ccurve_ptr, 00326 GMem* gMem, 00327 double angle_tolerance, 00328 double distance_tolerance, 00329 double max_edge_length ) const 00330 { 00331 // Just return if gMem is NULL 00332 if (gMem == NULL) 00333 { 00334 return CUBIT_SUCCESS; 00335 } 00336 00337 GMem current_gmem; 00338 int point_count = 0; //Current total of points returned 00339 // from underlying edges 00340 00341 int next_index = 0; //index of next insert spot in passed GMem object. 00342 00343 //Get points for each underlying curve 00344 current_gmem.clean_out(); 00345 for( int i = 0; i < ccurve_ptr->num_curves(); i++ ) 00346 { 00347 // Get the next curve and its GME 00348 Curve* curve_ptr = ccurve_ptr->get_curve(i); 00349 GeometryQueryEngine* GQE_ptr = 00350 curve_ptr->get_geometry_query_engine(); 00351 00352 // Get the GME to facet the curve 00353 CubitStatus current_status = 00354 GQE_ptr->get_graphics( curve_ptr, ¤t_gmem, angle_tolerance, 00355 distance_tolerance, max_edge_length ); 00356 if( current_status == CUBIT_FAILURE ) 00357 return CUBIT_FAILURE; 00358 00359 int this_point_count = current_gmem.pointListCount; 00360 00361 // Make sure the passed in gmem is big enough 00362 gMem->allocate_more_polylines(this_point_count-1); 00363 //assert( gMem->pts_size >= point_count ); 00364 00365 // If this isn't the first curve, we don't need to 00366 // repeat one of the end nodes. 00367 if (point_count != 0) 00368 this_point_count--; 00369 // Add to the total number of points so far 00370 point_count += this_point_count; 00371 00372 //Copy points to passed GMem, in the correct order 00373 //for the sense of the underlying edge wrt the 00374 //composite. 00375 CubitSense sense = ccurve_ptr->get_sense( i ); 00376 00377 if( sense == CUBIT_FORWARD ) 00378 { 00379 if (next_index == 0) 00380 for(int j = 0; j < point_count; j++) 00381 { 00382 gMem->point_list()[j] = current_gmem.point_list()[j]; 00383 } 00384 else 00385 // cur_gmem has one more point than we will access, 00386 // so last index is point_count-next_index. 00387 for(int j = next_index; j < point_count; j++) 00388 { 00389 gMem->point_list()[j] = current_gmem.point_list()[j - next_index + 1]; 00390 } 00391 } 00392 else //( sense == CUBIT_REVERSED ) 00393 { 00394 // All but the first curve will not use one of its points. 00395 // This is taken into account by decrementing point_count 00396 // earlier. 00397 for(int j = next_index; j < point_count; j++) 00398 { 00399 gMem->point_list()[j] = current_gmem.point_list()[point_count-j-1]; 00400 } 00401 } 00402 next_index = point_count; 00403 gMem->pointListCount = point_count; 00404 } 00405 00406 gMem->pointListCount = point_count; 00407 return CUBIT_SUCCESS; 00408 } 00409 00410 //----------------------------------------------------------------------- 00411 // Purpose : This function constructs the edge facetting information 00412 // of a PartitionCurve for use by HOOPS. 00413 // 00414 // Special Notes : It is currently not possible to split a face which 00415 // has more than one loop (holes) because we cannot 00416 // determine which partition the holes should lie on with 00417 // the current implementation of ParasiteCurve. 00418 // 00419 // Creator : Jason Kraftcheck 00420 // 00421 // Creation Date : 10/10/97 00422 //----------------------------------------------------------------------- 00423 CubitStatus VirtualQueryEngine::get_partition_curve_facetting( 00424 PartitionCurve* pcurve_ptr, 00425 GMem* gMem, 00426 double angle_tolerance, 00427 double distance_tolerance, 00428 double max_edge_length ) const 00429 { 00430 assert( gMem != NULL ); 00431 CubitStatus result = pcurve_ptr->get_graphics( *gMem, angle_tolerance, 00432 distance_tolerance, max_edge_length ); 00433 return result; 00434 } 00435 00436 00437 //------------------------------------------------------------------------- 00438 // Purpose : get Hoops facetting information for a CompositeSurface. 00439 // 00440 // Special Notes : 00441 // 00442 // Creator : Jason Kraftcheck 00443 // 00444 // Creation Date : 03/17/98 00445 //------------------------------------------------------------------------- 00446 CubitStatus VirtualQueryEngine::get_composite_surface_facetting( 00447 CompositeSurface* surf_ptr, 00448 GMem* gMem, 00449 std::vector<TopologyBridge*> *vertex_edge_to_point_vector, 00450 std::vector<std::pair<TopologyBridge*, std::pair<int,int> > > *facet_edges_on_curves, 00451 unsigned short normal_tol, 00452 double dist_tol, 00453 double longest_edge ) const 00454 { 00455 if( gMem == NULL ) 00456 return CUBIT_FAILURE; 00457 00458 if (surf_ptr->get_graphics(*gMem)) 00459 { 00460 /* 00461 if( vertex_edge_to_point_vector ) 00462 { 00463 vertex_edge_to_point_vector->resize( gMem->pointListCount, NULL ); 00464 //get all the points on the surface 00465 DLIList<TBPoint*> points; 00466 surf_ptr->points( points ); 00467 00468 for( int i=points.size(); i--; ) 00469 { 00470 TBPoint *tb_pt = points.get_and_step(); 00471 CompositePoint *comp_pt = CAST_TO( tb_pt, CompositePoint ); 00472 00473 if( comp_pt ) 00474 { 00475 CubitPoint *facet_point = comp_pt->facet_point(); 00476 (*vertex_edge_to_point_vector)[facet_point->marked()] = comp_pt; 00477 } 00478 } 00479 } 00480 00481 if( facet_edges_on_curves ) 00482 { 00483 DLIList<Curve*> tmp_curves; 00484 surf_ptr->curves( tmp_curves ); 00485 00486 for( int i=tmp_curves.size(); i--; ) 00487 { 00488 Curve *tmp_curve = tmp_curves.get_and_step(); 00489 CompositeCurve *comp_curve = CAST_TO( tmp_curve, CompositeCurve ); 00490 00491 if( comp_curve ) 00492 { 00493 DLIList<CubitFacetEdgeData*> facet_edges; 00494 comp_curve->get_facet_data( facet_edges ); 00495 00496 for( int j=facet_edges.size(); j--; ) 00497 { 00498 CubitFacetEdge *facet_edge = facet_edges.get_and_step(); 00499 00500 facet_edges_on_curves->push_back( std::make_pair( tmp_curve, 00501 std::make_pair( facet_edge->point(0)->marked(), 00502 facet_edge->point(1)->marked() ))); 00503 } 00504 } 00505 } 00506 } 00507 */ 00508 return CUBIT_SUCCESS; 00509 } 00510 00511 00512 // Get the underlying Surfaces 00513 GeometryQueryEngine* gqe_ptr; 00514 GMem *gMem_list = new GMem[ surf_ptr->num_surfs() ]; 00515 00516 int total_number_points = 0; 00517 int total_number_facets = 0; 00518 00519 // Get the facets of each Surface 00520 int i; 00521 for(i = 0; i < surf_ptr->num_surfs(); i++) 00522 { 00523 Surface* surface_ptr = surf_ptr->get_surface(i); 00524 00525 gqe_ptr = surface_ptr->get_geometry_query_engine(); 00526 00527 gqe_ptr->get_graphics( surface_ptr, &(gMem_list[i]), 00528 normal_tol, dist_tol, longest_edge ); 00529 00530 total_number_facets += gMem_list[i].fListCount; 00531 total_number_points += gMem_list[i].pointListCount; 00532 } 00533 00534 int point_offset = 0; 00535 int face_offset = 0; 00536 gMem->replace_point_list(new GPoint[total_number_points], 00537 total_number_points, total_number_points); 00538 gMem->replace_facet_list(new int[total_number_facets], 00539 total_number_facets, total_number_facets); 00540 00541 for( i = 0; i < surf_ptr->num_surfs(); i++ ) 00542 { 00543 int j; 00544 for( j = 0; j < gMem_list[i].pointListCount; j++ ) 00545 { 00546 assert((point_offset + j) < gMem->pointListCount ); 00547 gMem->point_list()[j + point_offset].x = gMem_list[i].point_list()[j].x; 00548 gMem->point_list()[j + point_offset].y = gMem_list[i].point_list()[j].y; 00549 gMem->point_list()[j + point_offset].z = gMem_list[i].point_list()[j].z; 00550 } 00551 00552 int k; 00553 for( k = 0; k < gMem_list[i].fListCount;) 00554 { 00555 int count = gMem_list[i].facet_list()[k]; 00556 assert( k + count < gMem->fListCount ); 00557 00558 gMem->facet_list()[k + face_offset] = count; 00559 k++; 00560 for( int l = 0; l < count; l++, k++ ) 00561 { 00562 assert( k + face_offset < gMem->fListCount ); 00563 assert( k < gMem_list[i].fListCount ); 00564 gMem->facet_list()[k + face_offset] = gMem_list[i].facet_list()[k] 00565 + point_offset; 00566 } 00567 } 00568 00569 point_offset += j; 00570 face_offset += k; 00571 } 00572 00573 gMem->consolidate_points(10*GEOMETRY_RESABS); 00574 // // Debug!!! 00575 // int q; 00576 // for (q = 0; q < bte_list.size(); q++) 00577 // { 00578 // PRINT_INFO("Printing Points for Surface %d.\n", q); 00579 // int r; 00580 // for (r = 0; r < gMem_list[q].pointListCount; r++) 00581 // { 00582 // PRINT_INFO("%g %g %g\n", 00583 // gMem_list[q].point_list()[r].x, 00584 // gMem_list[q].point_list()[r].y, 00585 // gMem_list[q].point_list()[r].z); 00586 // } 00587 // PRINT_INFO("Printing FList for Surface %d.\n", q); 00588 // for (r = 0; r < gMem_list[q].fListCount; r++) 00589 // { 00590 // PRINT_INFO("%d %s", 00591 // gMem_list[q].facet_list()[r], 00592 // r % 4 ? "" : "\n"); 00593 // } 00594 // } 00595 // PRINT_INFO("Composite points:\n"); 00596 // for (q = 0; q < gMem->pointListCount; q++) 00597 // { 00598 // PRINT_INFO("%g %g %g\n", 00599 // gMem->point_list()[q].x, 00600 // gMem->point_list()[q].y, 00601 // gMem->point_list()[q].z); 00602 // } 00603 // PRINT_INFO("Composite facet list:\n"); 00604 // for (q = 0; q < gMem->fListCount; q++) 00605 // { 00606 // PRINT_INFO("%d %s", 00607 // gMem->facet_list()[q], 00608 // q % 4 ? "" : "\n"); 00609 // } 00610 00611 if( vertex_edge_to_point_vector ) 00612 { 00613 vertex_edge_to_point_vector->resize( gMem->pointListCount, NULL ); 00614 //get all the points on the surface 00615 DLIList<TBPoint*> points; 00616 surf_ptr->points( points ); 00617 00618 for( int i=points.size(); i--; ) 00619 { 00620 TBPoint *tb_pt = points.get_and_step(); 00621 PartitionPoint *ppt = CAST_TO( tb_pt, PartitionPoint ); 00622 00623 if( ppt ) 00624 { 00625 CubitPoint *facet_point = ppt->facet_point(); 00626 (*vertex_edge_to_point_vector)[facet_point->marked()] = ppt; 00627 } 00628 } 00629 } 00630 00631 if( facet_edges_on_curves ) 00632 { 00633 DLIList<Curve*> tmp_curves; 00634 surf_ptr->curves( tmp_curves ); 00635 00636 for( int i=tmp_curves.size(); i--; ) 00637 { 00638 Curve *tmp_curve = tmp_curves.get_and_step(); 00639 PartitionCurve *pt_curve = CAST_TO( tmp_curve, PartitionCurve ); 00640 00641 if( pt_curve ) 00642 { 00643 DLIList<CubitFacetEdgeData*> facet_edges; 00644 pt_curve->get_facet_data( facet_edges ); 00645 00646 for( int j=facet_edges.size(); j--; ) 00647 { 00648 CubitFacetEdge *facet_edge = facet_edges.get_and_step(); 00649 00650 facet_edges_on_curves->push_back( std::make_pair( tmp_curve, 00651 std::make_pair( facet_edge->point(0)->marked(), 00652 facet_edge->point(1)->marked() ))); 00653 00654 } 00655 } 00656 } 00657 } 00658 00659 delete [] gMem_list; 00660 return CUBIT_SUCCESS; 00661 } 00662 00663 //------------------------------------------------------------------------- 00664 // Purpose : get hoops facets for a partition surface 00665 // 00666 // Special Notes : 00667 // 00668 // Creator : Jason Kraftcheck 00669 // 00670 // Creation Date : 06/18/98 00671 //------------------------------------------------------------------------- 00672 CubitStatus VirtualQueryEngine::get_partition_surface_facetting( 00673 PartitionSurface* surf_ptr, 00674 GMem* gMem, 00675 std::vector<TopologyBridge*> *vertex_edge_to_point_vector, 00676 std::vector<std::pair<TopologyBridge*, std::pair<int,int> > > *facet_edges_on_curves, 00677 unsigned short , 00678 double, 00679 double ) const 00680 { 00681 int i, j; 00682 00683 DLIList<CubitFacetData*> surf_facets; 00684 DLIList<CubitPoint*> surf_points; 00685 00686 // get surface facets 00687 surf_ptr->get_facet_data( surf_facets ); 00688 00689 // get list of points from list of facets 00690 for( i = surf_facets.size(); i--; ) 00691 { 00692 CubitFacetData* facet = surf_facets.step_and_get(); 00693 for( j = 0; j< 3; j++ ) 00694 facet->point(j)->marked(1); 00695 } 00696 for( i = surf_facets.size(); i--; ) 00697 { 00698 CubitFacetData* facet = surf_facets.step_and_get(); 00699 for( j = 0; j< 3; j++ ) 00700 { 00701 if( facet->point(j)->marked() ) 00702 { 00703 facet->point(j)->marked(0); 00704 surf_points.append( facet->point(j) ); 00705 } 00706 } 00707 } 00708 00709 if( ! gMem ) return CUBIT_SUCCESS; 00710 00711 // allocate storage for facet data 00712 gMem->allocate_tri( surf_facets.size() ); 00713 gMem->fListCount = surf_facets.size() * 4; 00714 gMem->pointListCount = surf_points.size(); 00715 00716 // put points in GMem and mark each point with 00717 // its index in the array 00718 surf_points.reset(); 00719 for( i = 0; i < gMem->pointListCount; i++ ) 00720 { 00721 GPoint* gpt = gMem->point_list() + i; 00722 CubitPoint* pt = surf_points.get_and_step(); 00723 pt->marked(i); 00724 gpt->x = (float)(pt->coordinates().x() ); 00725 gpt->y = (float)(pt->coordinates().y() ); 00726 gpt->z = (float)(pt->coordinates().z() ); 00727 } 00728 00729 // put each facet in the GMem. retreive 00730 // point indices from marks. 00731 surf_facets.reset(); 00732 int* gfacet_ptr = gMem->facet_list(); 00733 for( i = 0; i < surf_facets.size(); i++ ) 00734 { 00735 CubitFacetData* facet = surf_facets.get_and_step(); 00736 *gfacet_ptr = 3; 00737 gfacet_ptr++; 00738 for( j = 0; j < 3; j++ ) 00739 { 00740 *gfacet_ptr = facet->point(j)->marked(); 00741 gfacet_ptr++; 00742 } 00743 } 00744 00745 if( vertex_edge_to_point_vector ) 00746 { 00747 vertex_edge_to_point_vector->resize( gMem->pointListCount, NULL ); 00748 //get all the points on the surface 00749 DLIList<TBPoint*> points; 00750 surf_ptr->points( points ); 00751 00752 for( int i=points.size(); i--; ) 00753 { 00754 TBPoint *tb_pt = points.get_and_step(); 00755 PartitionPoint *ppt = CAST_TO( tb_pt, PartitionPoint ); 00756 00757 if( ppt ) 00758 { 00759 CubitPoint *facet_point = ppt->facet_point(); 00760 (*vertex_edge_to_point_vector)[facet_point->marked()] = ppt; 00761 } 00762 } 00763 } 00764 00765 if( facet_edges_on_curves ) 00766 { 00767 DLIList<Curve*> tmp_curves; 00768 surf_ptr->curves( tmp_curves ); 00769 00770 for( int i=tmp_curves.size(); i--; ) 00771 { 00772 Curve *tmp_curve = tmp_curves.get_and_step(); 00773 PartitionCurve *pt_curve = CAST_TO( tmp_curve, PartitionCurve ); 00774 00775 if( pt_curve ) 00776 { 00777 DLIList<CubitFacetEdgeData*> facet_edges; 00778 pt_curve->get_facet_data( facet_edges ); 00779 00780 for( int j=facet_edges.size(); j--; ) 00781 { 00782 CubitFacetEdge *facet_edge = facet_edges.get_and_step(); 00783 00784 facet_edges_on_curves->push_back( std::make_pair( tmp_curve, 00785 std::make_pair( facet_edge->point(0)->marked(), 00786 facet_edge->point(1)->marked() ))); 00787 00788 } 00789 } 00790 } 00791 } 00792 00793 // clear point marks 00794 for( i = surf_points.size(); i--; ) 00795 surf_points.step_and_get()->marked(0); 00796 00797 return CUBIT_SUCCESS; 00798 } 00799 00800 // ********** END PUBLIC FUNCTIONS ********** 00801 00802 // ********** BEGIN PROTECTED FUNCTIONS ********** 00803 00804 //------------------------------------------------------------------------- 00805 // Purpose : The constructor of the VirtualQueryEngine class. 00806 // 00807 // Special Notes : 00808 // 00809 // Creator : Wes Gill 00810 // 00811 // Creation Date : 10/5/01 00812 //------------------------------------------------------------------------- 00813 00814 VirtualQueryEngine::VirtualQueryEngine() 00815 { 00816 assert( !instance_); 00817 //Add the VirtualQueryEngine to the GeometryQueryTool's gqeList and 00818 //set the VGE to the GQT's default engine. 00819 //GeometryQueryTool::instance()->add_gqe(this); 00820 //GeometryQueryTool::instance()->set_default_engine(this); 00821 CompositeEngine::instance(); 00822 PartitionEngine::instance(); 00823 } 00824 00825 00826 //------------------------------------------------------------------------- 00827 // Purpose : get child virtual geometry 00828 // 00829 // Special Notes : 00830 // 00831 // Creator : Jason Kraftcheck 00832 // 00833 // Creation Date : 08/11/98 00834 //------------------------------------------------------------------------- 00835 void VirtualQueryEngine::get_VEs( TopologyEntity* te_ptr, 00836 DLIList<TopologyBridge*>& ve_list, 00837 CubitBoolean visible, 00838 const CubitBoolean children_too) 00839 { 00840 DLIList<TopologyBridge*> child_list; 00841 Body* body_ptr = CAST_TO( te_ptr, Body ); 00842 CoVolume* covol_ptr = CAST_TO( te_ptr, CoVolume ); 00843 RefVolume* vol_ptr = CAST_TO( te_ptr, RefVolume ); 00844 Shell* shell_ptr = CAST_TO( te_ptr, Shell ); 00845 CoFace* coface_ptr = CAST_TO( te_ptr, CoFace ); 00846 RefFace* face_ptr = CAST_TO( te_ptr, RefFace ); 00847 Loop* loop_ptr = CAST_TO( te_ptr, Loop ); 00848 CoEdge* coedge_ptr = CAST_TO( te_ptr, CoEdge ); 00849 RefEdge* edge_ptr = CAST_TO( te_ptr, RefEdge ); 00850 Chain* chain_ptr = CAST_TO( te_ptr, Chain ); 00851 CoVertex* covex_ptr = CAST_TO( te_ptr, CoVertex ); 00852 RefVertex* vex_ptr = CAST_TO( te_ptr, RefVertex ); 00853 00854 if( (body_ptr != NULL) || (covol_ptr != NULL) ) 00855 { 00856 if (children_too) { 00857 DLIList<RefVolume*> vol_list; 00858 te_ptr->ref_volumes( vol_list ); 00859 for( int i = vol_list.size(); i > 0; i-- ) 00860 { 00861 child_list.clean_out(); 00862 get_VEs( vol_list.get_and_step(), child_list, visible, 00863 children_too); 00864 ve_list.merge_unique( child_list ); 00865 } 00866 } 00867 } 00868 else if( vol_ptr != NULL ) 00869 { 00870 get_VEs( vol_ptr, ve_list, visible, children_too ); 00871 } 00872 else if( (shell_ptr != NULL) || (coface_ptr != NULL) ) 00873 { 00874 if (children_too) { 00875 DLIList<RefFace*> face_list; 00876 te_ptr->ref_faces( face_list ); 00877 for( int i = face_list.size(); i> 0; i-- ) 00878 { 00879 child_list.clean_out(); 00880 get_VEs( face_list.get_and_step(), child_list, visible, 00881 children_too); 00882 ve_list.merge_unique( child_list ); 00883 } 00884 } 00885 } 00886 else if( face_ptr != NULL ) 00887 { 00888 get_VEs( face_ptr, ve_list, visible, children_too ); 00889 } 00890 else if( (loop_ptr != NULL) || (coedge_ptr != NULL) ) 00891 { 00892 if (children_too) { 00893 DLIList<RefEdge*> edge_list; 00894 te_ptr->ref_edges( edge_list ); 00895 for( int i = edge_list.size(); i > 0; i-- ) 00896 { 00897 child_list.clean_out(); 00898 get_VEs( edge_list.get_and_step(), child_list, visible, 00899 children_too); 00900 ve_list.merge_unique( child_list ); 00901 } 00902 } 00903 } 00904 else if( edge_ptr != NULL ) 00905 { 00906 get_VEs( edge_ptr, ve_list, visible, children_too ); 00907 } 00908 else if( (chain_ptr != NULL) || (covex_ptr != NULL ) ) 00909 { 00910 if (children_too) { 00911 DLIList<RefVertex*> vertex_list; 00912 te_ptr->ref_vertices( vertex_list ); 00913 for( int i = vertex_list.size(); i > 0; i-- ) 00914 { 00915 child_list.clean_out(); 00916 get_VEs( vertex_list.get_and_step(), child_list, visible, 00917 children_too); 00918 ve_list.merge_unique( child_list ); 00919 } 00920 } 00921 } 00922 else if( vex_ptr != NULL ) 00923 { 00924 get_VEs( vex_ptr, ve_list, visible, children_too ); 00925 } 00926 else 00927 { 00928 PRINT_ERROR("Unknown type of TopologyEntity passed to " 00929 "VirtualQueryEngine::get_VEs(..). Passed pointer" 00930 " may be stale.\n"); 00931 } 00932 } 00933 00934 00935 void VirtualQueryEngine::get_VEs( RefVolume* volume_ptr, 00936 DLIList<TopologyBridge*>& ve_list, 00937 CubitBoolean visible, 00938 const CubitBoolean children_too ) 00939 { 00940 DLIList<BasicTopologyEntity*> bte_list; 00941 int i; 00942 00943 DLIList<TopologyBridge*> tb_list; 00944 volume_ptr->bridge_manager()->get_bridge_list( tb_list ); 00945 00946 for( i = tb_list.size(); i--; ) 00947 { 00948 TopologyBridge* tb_ptr = tb_list.get_and_step(); 00949 PartitionEntity* ve_ptr = dynamic_cast<PartitionEntity*>(tb_ptr); 00950 CompositeLump* ce_ptr = dynamic_cast<CompositeLump*>(tb_ptr); 00951 if( ve_ptr || ce_ptr ) 00952 { 00953 ve_list.append( tb_ptr ); 00954 } 00955 } 00956 00957 if (!children_too) return; 00958 DLIList<TopologyBridge*> child_list; 00959 00960 DLIList<RefFace*> face_list; 00961 volume_ptr->ref_faces( face_list ); 00962 DLIList<BasicTopologyEntity*> temp_face_list; 00963 CAST_LIST_TO_PARENT( face_list, temp_face_list ); 00964 bte_list.merge_unique( temp_face_list ); 00965 // bte_list.merge_unique( face_list ); 00966 for( i = bte_list.size();i > 0;i--) 00967 { 00968 child_list.clean_out(); 00969 get_VEs( bte_list.get_and_step(), child_list, visible ); 00970 ve_list.merge_unique( child_list ); 00971 } 00972 } 00973 00974 void VirtualQueryEngine::get_VEs( RefFace* face_ptr, 00975 DLIList<TopologyBridge*>& ve_list, 00976 CubitBoolean visible, 00977 const CubitBoolean children_too ) 00978 { 00979 DLIList<BasicTopologyEntity*> bte_list; 00980 DLIList<TopologyBridge*> tb_list; 00981 int i; 00982 00983 face_ptr->bridge_manager()->get_bridge_list( tb_list ); 00984 tb_list.reset(); 00985 00986 for( i = tb_list.size(); i--; ) 00987 { 00988 00989 TopologyBridge* ve_ptr = tb_list.get_and_step(); 00990 if( dynamic_cast<PartitionEntity*>(ve_ptr) || 00991 dynamic_cast<CompositeSurface*>(ve_ptr) ) 00992 { 00993 ve_list.append( ve_ptr ); 00994 } 00995 } 00996 00997 00998 if (!children_too) return; 00999 01000 DLIList<TopologyBridge*> child_list; 01001 DLIList<RefEdge*> edge_list; 01002 face_ptr->ref_edges( edge_list ); 01003 DLIList<BasicTopologyEntity*> temp_edge_list; 01004 CAST_LIST_TO_PARENT( edge_list, temp_edge_list ); 01005 bte_list.merge_unique( temp_edge_list ); 01006 01007 for( i = bte_list.size();i > 0;i--) 01008 { 01009 child_list.clean_out(); 01010 get_VEs( bte_list.get_and_step(), child_list, visible ); 01011 ve_list.merge_unique( child_list ); 01012 } 01013 } 01014 01015 void VirtualQueryEngine::get_VEs( RefEdge* edge_ptr, 01016 DLIList<TopologyBridge*>& ve_list, 01017 CubitBoolean visible, 01018 const CubitBoolean children_too ) 01019 { 01020 DLIList<BasicTopologyEntity*> bte_list; 01021 DLIList<TopologyBridge*> tb_list; 01022 int i; 01023 01024 edge_ptr->bridge_manager()->get_bridge_list( tb_list ); 01025 tb_list.reset(); 01026 01027 for( i = tb_list.size(); i--; ) 01028 { 01029 01030 TopologyBridge* ve_ptr = tb_list.get_and_step(); 01031 if( dynamic_cast<PartitionCurve*>(ve_ptr) || 01032 dynamic_cast<CompositeCurve*>(ve_ptr) ) 01033 { 01034 ve_list.append( ve_ptr ); 01035 } 01036 } 01037 01038 if (!children_too) return; 01039 DLIList<TopologyBridge*> child_list; 01040 DLIList<RefVertex*> vex_list; 01041 edge_ptr->ref_vertices( vex_list ); 01042 DLIList<BasicTopologyEntity*> temp_vex_list; 01043 CAST_LIST_TO_PARENT( vex_list, temp_vex_list ); 01044 bte_list.merge_unique( temp_vex_list ); 01045 01046 for( i = bte_list.size();i > 0;i--) 01047 { 01048 child_list.clean_out(); 01049 get_VEs( bte_list.get_and_step(), child_list, visible ); 01050 ve_list.merge_unique( child_list ); 01051 } 01052 } 01053 01054 void VirtualQueryEngine::get_VEs( RefVertex* vex_ptr, 01055 DLIList<TopologyBridge*>& ve_list, 01056 CubitBoolean , 01057 const CubitBoolean ) 01058 { 01059 DLIList<TopologyBridge*> tb_list; 01060 vex_ptr->bridge_manager()->get_bridge_list( tb_list ); 01061 tb_list.reset(); 01062 for( int i = tb_list.size(); i--; ) 01063 { 01064 TopologyBridge* tb = tb_list.get_and_step(); 01065 if( dynamic_cast<PartitionPoint*>(tb) || 01066 dynamic_cast<CompositePoint*>(tb) ) 01067 ve_list.append( tb ); 01068 } 01069 } 01070 01071 01072 //------------------------------------------------------------------------- 01073 // Purpose : check if the entity is virtual or has virtual entities. 01074 // 01075 // Special Notes : all is_virtual entity, has_virtual = true 01076 // only body, refvolume, refface can be non-virtual but has 01077 // virtual. 01078 // 01079 // Creator : Jane Hu 01080 // 01081 // Creation Date : 10/01/04 01082 //------------------------------------------------------------------------- 01083 CubitBoolean VirtualQueryEngine::has_virtual(TopologyEntity* te_ptr) 01084 { 01085 if (te_ptr == NULL) 01086 return CUBIT_FALSE; 01087 01088 if (is_virtual(te_ptr)) 01089 return CUBIT_TRUE; 01090 01091 // check if children has partition or composite entities 01092 int i; 01093 Body * body_ptr = CAST_TO (te_ptr, Body); 01094 RefVolume * vol_ptr = CAST_TO (te_ptr, RefVolume); 01095 RefFace * face_ptr = CAST_TO (te_ptr, RefFace); 01096 CubitBoolean has_vir = CUBIT_FALSE; 01097 01098 if (body_ptr != NULL) 01099 { 01100 DLIList<RefVolume*> vol_list; 01101 te_ptr->ref_volumes(vol_list); 01102 for (i = vol_list.size(); i > 0; i--) 01103 { 01104 if (has_virtual(vol_list.get_and_step())) 01105 { 01106 has_vir = CUBIT_TRUE; 01107 break; 01108 } 01109 } 01110 } 01111 01112 if (vol_ptr != NULL) 01113 { 01114 DLIList<RefFace*> face_list; 01115 te_ptr->ref_faces(face_list); 01116 for (i = face_list.size(); i > 0; i --) 01117 { 01118 if (has_virtual(face_list.get_and_step())) 01119 { 01120 has_vir = CUBIT_TRUE; 01121 break; 01122 } 01123 } 01124 } 01125 01126 if (face_ptr != NULL) 01127 { 01128 DLIList<RefEdge *> edge_list; 01129 te_ptr->ref_edges(edge_list); 01130 for (i = edge_list.size(); i > 0; i --) 01131 { 01132 if (is_virtual(edge_list.get_and_step())) 01133 { 01134 has_vir = CUBIT_TRUE; 01135 break; 01136 } 01137 } 01138 } 01139 01140 return has_vir; 01141 } 01142 01143 CubitBoolean VirtualQueryEngine::is_virtual(TopologyEntity *entity, 01144 const CubitBoolean children_too) 01145 //Check if a TopologyEntity has any topologyBridge that is composite or 01146 //partition type. 01147 { 01148 if ( entity == NULL ) 01149 return CUBIT_FALSE; 01150 01151 if (CAST_TO(entity, Body) !=NULL) 01152 { 01153 int i; 01154 DLIList<TopologyBridge*> list; 01155 entity->bridge_manager()->get_bridge_list(list); 01156 TopologyBridge * tb; 01157 for (i = list.size(); i > 0; i--) 01158 { 01159 tb = list.get_and_step(); 01160 if (CAST_TO(tb, PartitionBody) != NULL || 01161 CAST_TO(tb, CompositeBody) != NULL) 01162 return CUBIT_TRUE; 01163 } 01164 } 01165 01166 DLIList<TopologyBridge*> ve_list; 01167 get_VEs(entity, ve_list, CUBIT_TRUE, children_too); 01168 return (ve_list.size() ? CUBIT_TRUE : CUBIT_FALSE); 01169 } 01170 01171 CubitBoolean VirtualQueryEngine::is_virtual(DLIList<Body*> &entity_list, 01172 const CubitBoolean children_too) 01173 { 01174 if (!children_too) return CUBIT_FALSE; 01175 01176 int i; 01177 for (i = entity_list.size(); i > 0; i--) 01178 if (is_virtual(entity_list.get_and_step(), children_too)) return CUBIT_TRUE; 01179 return CUBIT_FALSE; 01180 } 01181 01182 CubitBoolean VirtualQueryEngine::is_virtual(DLIList<RefEntity*> &entity_list, 01183 const CubitBoolean children_too) 01184 { 01185 int i; 01186 for (i = entity_list.size(); i > 0; i--) { 01187 RefEntity *ref_entity = entity_list.get_and_step(); 01188 if (is_virtual(CAST_TO(ref_entity, TopologyEntity), children_too)) return CUBIT_TRUE; 01189 } 01190 01191 return CUBIT_FALSE; 01192 } 01193 01194 CubitBoolean VirtualQueryEngine::is_partition( RefEntity *ref_entity ) 01195 { 01196 RefEdge *ref_edge = CAST_TO( ref_entity, RefEdge ); 01197 01198 if( ref_edge ) 01199 { 01200 Curve *curve_ptr = ref_edge->get_curve_ptr(); 01201 PartitionCurve *part_curve = CAST_TO(curve_ptr, PartitionCurve); 01202 01203 if( part_curve ) 01204 return CUBIT_TRUE; 01205 } 01206 01207 return CUBIT_FALSE; 01208 } 01209 01210 CubitStatus VirtualQueryEngine::get_sister_partitions( RefEntity *ref_entity, 01211 DLIList<RefEntity*> &sisters) 01212 { 01213 RefEdge *ref_edge = CAST_TO( ref_entity, RefEdge ); 01214 01215 if( ref_edge ) 01216 { 01217 Curve *curve_ptr = ref_edge->get_curve_ptr(); 01218 PartitionCurve *part_curve = CAST_TO(curve_ptr, PartitionCurve); 01219 01220 if( part_curve ) 01221 { 01222 DLIList<TopologyBridge*> tb_list; 01223 part_curve->sub_entity_set().get_owners( tb_list ); 01224 01225 int k; 01226 for( k=tb_list.size(); k--; ) 01227 { 01228 TopologyBridge *tmp_bridge = tb_list.get_and_step(); 01229 TopologyEntity *te = tmp_bridge->topology_entity(); 01230 if( te ) 01231 { 01232 RefEntity *sister = CAST_TO(te, RefEntity ); 01233 if( sister ) 01234 sisters.append( sister ); 01235 } 01236 } 01237 } 01238 } 01239 01240 return CUBIT_SUCCESS; 01241 } 01242 01243 //------------------------------------------------------------------------- 01244 // Purpose : Sort a DLList of RefEdges to be used in the construction 01245 // of a CompositeCurve. 01246 // 01247 // Special Notes : Sorted using topological information 01248 // 01249 // Creator : Jason Kraftcheck 01250 // 01251 // Creation Date : 08/04/97 01252 //------------------------------------------------------------------------- 01253 CubitStatus VirtualQueryEngine::sort_edges( 01254 DLIList<RefEdge*>& edge_list ) const 01255 { 01256 DLIList<RefEdge*> sorted_edge_list; 01257 RefEdge *first, *current = NULL, *prev; 01258 CubitStatus return_value = CUBIT_SUCCESS; 01259 01260 if( edge_list.size( ) <= 0 ) 01261 { 01262 return CUBIT_FAILURE; 01263 } 01264 01265 if( edge_list.size() == 1 ) 01266 { 01267 return CUBIT_SUCCESS; 01268 } 01269 01270 //Note: this part badly needs some optimization. Given the array-based 01271 // implementation of the DLList class, this is a very inefficient 01272 // approach to sorting the edges. Look into a different seach 01273 // algorithm, and possible switching functions in DLList. 01274 01275 //add first Curve 01276 edge_list.reset( ); 01277 first = prev = edge_list.remove( ); 01278 sorted_edge_list.append( first ); 01279 01280 //sort the rest of the Curves 01281 int i; 01282 for( i = 0; i < edge_list.size( ); i++ ) //loop for each remaining RefEdge 01283 { 01284 edge_list.reset( ); 01285 //look through list for next RefEdge 01286 for( int j = 0; j < edge_list.size( ); j++ ) 01287 { 01288 current = edge_list.get( ); 01289 if( prev->common_ref_vertex( current ) != NULL ) 01290 { 01291 edge_list.remove( ); 01292 sorted_edge_list.append( current ); 01293 i--; //edge_list.size() decreases with removal of edge 01294 prev = current; 01295 break; 01296 } 01297 else if( first->common_ref_vertex( current ) != NULL ) 01298 { 01299 edge_list.remove( ); 01300 sorted_edge_list.insert_first( current ); 01301 first = current; 01302 i--; //edge_list.size() decreases with removal of edge 01303 break; 01304 } 01305 else 01306 { 01307 edge_list.step( ); 01308 } 01309 }//end for(j) 01310 }//end for(i) 01311 01312 //check if all the RefEdges got sorted 01313 if( edge_list.size( ) > 0 ) 01314 { 01315 return_value = CUBIT_FAILURE; 01316 01317 //Sort the rest of the edges anyway, for use by 01318 //other functions than composite edge creation. 01319 01320 sort_edges( edge_list ); 01321 edge_list.reset( ); 01322 for( i = 0; i < edge_list.size(); i++ ) 01323 { 01324 current = edge_list.get_and_step( ); 01325 sorted_edge_list.append( current ); 01326 } 01327 } 01328 else 01329 { 01330 return_value = CUBIT_SUCCESS; 01331 } 01332 01333 edge_list.clean_out( ); 01334 edge_list = sorted_edge_list; 01335 edge_list.reset( ); 01336 return return_value; 01337 } 01338 01339 01340 01341 // ********** BEGIN PRIVATE FUNCTIONS ********** 01342 01343 //------------------------------------------------------------------------- 01344 // Purpose: Display a default error message for certain inherited functions 01345 //------------------------------------------------------------------------- 01346 void VirtualQueryEngine::default_error_message( 01347 const char callers_name[] ) const 01348 { 01349 PRINT_ERROR("A call was made to:\n"); 01350 PRINT_ERROR("VirtualQueryEngine::"); 01351 PRINT_ERROR("%s", callers_name); 01352 PRINT_ERROR("\n"); 01353 PRINT_ERROR("Although this function is inhereted from GeometryQueryEngine\n"); 01354 PRINT_ERROR("it is not applicable or implememtend in VirtualQueryEngine.\n"); 01355 PRINT_ERROR("\nTHIS IS A BUG. This function should NEVER be called.\n"); 01356 PRINT_ERROR("\nThis function exists only because it is pure virtual in\n"); 01357 PRINT_ERROR("the abstract class GeometryQueryEngine, and must be\n"); 01358 PRINT_ERROR("defined in VirtualQueryEngine for the class to be\n"); 01359 PRINT_ERROR("instantiated.\n"); 01360 } 01361 01362 // ********** END PRIVATE FUNCTIONS ********** 01363 01364 // ********** BEGIN HELPER CLASSES ********** 01365 // ********** END HELPER CLASSES ********** 01366 01367 // ********** BEGIN EXTERN FUNCTIONS ********** 01368 // ********** END EXTERN FUNCTIONS ********** 01369 01370 // ********** BEGIN STATIC FUNCTIONS ********** 01371 // ********** END STATIC FUNCTIONS ********** 01372 01373 01374 01375 CubitStatus 01376 VirtualQueryEngine::get_intersections( Curve* , Curve* , 01377 DLIList<CubitVector>& /*intersection_list*/, 01378 CubitBoolean /*bounded*/, 01379 CubitBoolean /*closest*/ ) 01380 { 01381 return CUBIT_FAILURE; 01382 } 01383 01384 CubitStatus 01385 VirtualQueryEngine::get_intersections(Curve* curve, CubitVector &point1, 01386 CubitVector &point2, 01387 DLIList<CubitVector>& intersection_list, 01388 CubitBoolean bounded, 01389 CubitBoolean closest ) 01390 { 01391 DLIList<TopologyBridge*> curve_list; 01392 get_underlying_curves( curve, curve_list ); 01393 int i; 01394 for (i = 0; i < curve_list.size(); i++) 01395 { 01396 // Get the next curve and its GME 01397 Curve* curve_ptr = CAST_TO(curve_list.get_and_step(), Curve); 01398 GeometryQueryEngine* GQE_ptr = 01399 curve_ptr->get_geometry_query_engine(); 01400 GQE_ptr->get_intersections(curve_ptr, point1, point2, intersection_list, 01401 bounded, closest); 01402 } 01403 return CUBIT_SUCCESS; 01404 } 01405 01406 CubitStatus 01407 VirtualQueryEngine::get_intersections( Curve*, Surface*, 01408 DLIList<CubitVector>& /* intersection_list */, 01409 CubitBoolean /* bounded */) 01410 { 01411 return CUBIT_FAILURE; 01412 } 01413 01414 int VirtualQueryEngine::curve_is_on_ignored_surface(Curve *curve_in, Surface *surf) 01415 { 01416 int i, ret = 0; 01417 01418 CompositeSurface *cs = dynamic_cast<CompositeSurface*>(surf); 01419 if(cs && curve_in) 01420 { 01421 DLIList<Surface*> ignored_surfs; 01422 cs->get_ignored_surfs(ignored_surfs); 01423 for(i=ignored_surfs.size(); i>0 && !ret; i--) 01424 { 01425 Surface *surf = ignored_surfs.get_and_step(); 01426 DLIList<Curve*> crvs; 01427 surf->curves(crvs); 01428 if(crvs.is_in_list(curve_in)) 01429 ret = 1; 01430 } 01431 } 01432 01433 return ret; 01434 } 01435 01436 //------------------------------------------------------------------------- 01437 // Purpose : This function get underlying curves for virtual curves 01438 // 01439 // Special Notes : 01440 // 01441 // Creator : Jane Hu 01442 // 01443 // Creation Date : 01444 //------------------------------------------------------------------------- 01445 CubitStatus VirtualQueryEngine::get_underlying_curves(Curve * curve_ptr, 01446 DLIList<TopologyBridge*>& curve_list) 01447 { 01448 assert (curve_ptr); 01449 CompositeCurve *comp_curve = CAST_TO(curve_ptr, CompositeCurve); 01450 PartitionCurve *part_curve = CAST_TO(curve_ptr, PartitionCurve); 01451 if ( comp_curve ) 01452 { 01453 int i; 01454 for (i = 0; i < comp_curve->num_curves(); i ++) 01455 { 01456 part_curve = CAST_TO(comp_curve->get_curve(i), PartitionCurve); 01457 if (!part_curve) 01458 curve_list.append_unique(CAST_TO(comp_curve->get_curve(i), 01459 TopologyBridge)); 01460 else 01461 { 01462 if(dynamic_cast<Curve*>(part_curve->partitioned_entity())) 01463 { 01464 curve_list.append_unique(CAST_TO(part_curve->partitioned_entity(), 01465 TopologyBridge)); 01466 } 01467 } 01468 } 01469 } 01470 else if ( part_curve ) 01471 curve_list.append(CAST_TO(part_curve->partitioned_entity(), 01472 TopologyBridge)); 01473 return CUBIT_SUCCESS; 01474 } 01475 01476 CubitStatus VirtualQueryEngine::get_underlying_surfaces(Surface * surf_ptr, 01477 DLIList<TopologyBridge*>& surf_list) 01478 { 01479 assert (surf_ptr); 01480 CompositeSurface *comp_surf = CAST_TO(surf_ptr, CompositeSurface); 01481 PartitionSurface *part_surf = CAST_TO(surf_ptr, PartitionSurface); 01482 if ( comp_surf ) 01483 { 01484 int i; 01485 for (i = 0; i < comp_surf->num_surfs(); i ++) 01486 { 01487 part_surf = CAST_TO(comp_surf->get_surface(i), PartitionSurface); 01488 if (!part_surf) 01489 surf_list.append_unique(CAST_TO(comp_surf->get_surface(i), 01490 TopologyBridge)); 01491 else 01492 { 01493 if(dynamic_cast<Surface*>(part_surf->partitioned_entity())) 01494 { 01495 surf_list.append_unique(CAST_TO(part_surf->partitioned_entity(), 01496 TopologyBridge)); 01497 } 01498 } 01499 } 01500 } 01501 else if ( part_surf ) 01502 surf_list.append(CAST_TO(part_surf->partitioned_entity(), 01503 TopologyBridge)); 01504 return CUBIT_SUCCESS; 01505 } 01506 01507 CubitStatus VirtualQueryEngine::get_underlying_bridges(TopologyBridge* bridge_ptr, 01508 DLIList<TopologyBridge*>& bridge_list) 01509 { 01510 assert (bridge_ptr); 01511 CompositeSurface *comp_surf = CAST_TO(bridge_ptr, CompositeSurface); 01512 PartitionSurface *part_surf = CAST_TO(bridge_ptr, PartitionSurface); 01513 CompositeCurve *comp_curve = CAST_TO(bridge_ptr, CompositeCurve); 01514 PartitionCurve *part_curve = CAST_TO(bridge_ptr, PartitionCurve); 01515 CompositePoint *comp_point = CAST_TO(bridge_ptr, CompositePoint); 01516 PartitionPoint *part_point = CAST_TO(bridge_ptr, PartitionPoint); 01517 PartitionBody *part_body = CAST_TO(bridge_ptr, PartitionBody); 01518 01519 if (part_body ) 01520 { 01521 bridge_list.append( part_body->partitioned_entity() ); 01522 } 01523 else if ( comp_surf ) 01524 { 01525 int i; 01526 for (i = 0; i < comp_surf->num_surfs(); i ++) 01527 { 01528 part_surf = CAST_TO(comp_surf->get_surface(i), PartitionSurface); 01529 if (!part_surf) 01530 bridge_list.append_unique(CAST_TO(comp_surf->get_surface(i), 01531 TopologyBridge)); 01532 else 01533 { 01534 if(dynamic_cast<Surface*>(part_surf->partitioned_entity())) 01535 { 01536 bridge_list.append_unique(CAST_TO(part_surf->partitioned_entity(), 01537 TopologyBridge)); 01538 } 01539 } 01540 } 01541 } 01542 else if ( part_surf ) 01543 bridge_list.append( part_surf->partitioned_entity() ); 01544 else if ( comp_curve ) 01545 { 01546 int i; 01547 for (i = 0; i < comp_curve->num_curves(); i ++) 01548 { 01549 part_curve = CAST_TO(comp_curve->get_curve(i), PartitionCurve); 01550 if (!part_curve) 01551 bridge_list.append_unique(comp_curve->get_curve(i)); 01552 else 01553 { 01554 if(dynamic_cast<Curve*>(part_curve->partitioned_entity())) 01555 { 01556 bridge_list.append_unique( part_curve->partitioned_entity() ); 01557 } 01558 } 01559 } 01560 } 01561 else if ( part_curve ) 01562 bridge_list.append( part_curve->partitioned_entity() ); 01563 else if ( part_point ) 01564 { 01565 TopologyBridge *tb_point = part_point->real_point(); 01566 if( tb_point ) 01567 bridge_list.append( tb_point ); 01568 } 01569 else if ( comp_point ) 01570 { 01571 TopologyBridge *tb_point = comp_point->get_point(); 01572 if( tb_point ) 01573 bridge_list.append( tb_point ); 01574 } 01575 01576 return CUBIT_SUCCESS; 01577 } 01578 01579 //================================================================================ 01580 // Description: Find extrema position on an entity list 01581 // Author : 01582 // Date : 01583 //================================================================================ 01584 CubitStatus 01585 VirtualQueryEngine::entity_extrema( DLIList<GeometryEntity*> &, 01586 const CubitVector *, 01587 const CubitVector *, 01588 const CubitVector *, 01589 CubitVector &, 01590 GeometryEntity *& ) 01591 { 01592 PRINT_ERROR("Entity extrema calculation not yet supported for virtual geometry.\n"); 01593 return CUBIT_FAILURE; 01594 } 01595 01596 //================================================================================ 01597 // Description: Find distance between two entities and closest positions. 01598 // Author : 01599 // Date : 01600 //================================================================================ 01601 CubitStatus 01602 VirtualQueryEngine::entity_entity_distance( GeometryEntity *ge1, 01603 GeometryEntity *ge2, 01604 CubitVector &p1, CubitVector &p2, 01605 double &distance ) 01606 { 01607 CompositeCurve *cc1 = dynamic_cast<CompositeCurve*>(ge1); 01608 CompositeCurve *cc2 = dynamic_cast<CompositeCurve*>(ge2); 01609 CompositeSurface *cs1 = dynamic_cast<CompositeSurface*>(ge1); 01610 CompositeSurface *cs2 = dynamic_cast<CompositeSurface*>(ge2); 01611 01612 DLIList<GeometryEntity*> geometry_entities_1; 01613 DLIList<GeometryEntity*> geometry_entities_2; 01614 DLIList<GeometryQueryEngine*> gqes_1; 01615 DLIList<GeometryQueryEngine*> gqes_2; 01616 01617 int i, j; 01618 int still_ok = 1; 01619 01620 if(cc1) 01621 { 01622 for(i=cc1->num_curves()-1; i>-1 && still_ok; i--) 01623 { 01624 GeometryEntity *ge = cc1->get_curve(i); 01625 if(dynamic_cast<PartitionEntity*>(ge)) 01626 still_ok = 0; 01627 GeometryQueryEngine *gqe = ge->get_geometry_query_engine(); 01628 geometry_entities_1.append(ge); 01629 gqes_1.append(gqe); 01630 } 01631 } 01632 else if(cs1) 01633 { 01634 for(i=cs1->num_surfs()-1; i>-1 && still_ok; i--) 01635 { 01636 GeometryEntity *ge = cs1->get_surface(i); 01637 if(dynamic_cast<PartitionEntity*>(ge)) 01638 still_ok = 0; 01639 GeometryQueryEngine *gqe = ge->get_geometry_query_engine(); 01640 geometry_entities_1.append(ge); 01641 gqes_1.append(gqe); 01642 } 01643 } 01644 else 01645 { 01646 if(dynamic_cast<PartitionEntity*>(ge1)) 01647 still_ok = 0; 01648 else if(dynamic_cast<Curve*>(ge1) || dynamic_cast<Surface*>(ge1)) 01649 { 01650 GeometryQueryEngine *gqe = ge1->get_geometry_query_engine(); 01651 geometry_entities_1.append(ge1); 01652 gqes_1.append(gqe); 01653 } 01654 else 01655 { 01656 PRINT_ERROR("Entity-entity distance not yet supported for virtual geometry.\n"); 01657 return CUBIT_FAILURE; 01658 } 01659 } 01660 if(cc2) 01661 { 01662 for(i=cc2->num_curves()-1; i>-1 && still_ok; i--) 01663 { 01664 GeometryEntity *ge = cc2->get_curve(i); 01665 if(dynamic_cast<PartitionEntity*>(ge)) 01666 still_ok = 0; 01667 GeometryQueryEngine *gqe = ge->get_geometry_query_engine(); 01668 geometry_entities_2.append(ge); 01669 gqes_2.append(gqe); 01670 } 01671 } 01672 else if(cs2) 01673 { 01674 for(i=cs2->num_surfs()-1; i>-1 && still_ok; i--) 01675 { 01676 GeometryEntity *ge = cs2->get_surface(i); 01677 if(dynamic_cast<PartitionEntity*>(ge)) 01678 still_ok = 0; 01679 GeometryQueryEngine *gqe = ge->get_geometry_query_engine(); 01680 geometry_entities_2.append(ge); 01681 gqes_2.append(gqe); 01682 } 01683 } 01684 else 01685 { 01686 if(dynamic_cast<PartitionEntity*>(ge2)) 01687 still_ok = 0; 01688 else if(dynamic_cast<Curve*>(ge2) || dynamic_cast<Surface*>(ge2)) 01689 { 01690 GeometryQueryEngine *gqe = ge2->get_geometry_query_engine(); 01691 geometry_entities_2.append(ge2); 01692 gqes_2.append(gqe); 01693 } 01694 else 01695 { 01696 PRINT_ERROR("Entity-entity distance not yet supported for virtual geometry.\n"); 01697 return CUBIT_FAILURE; 01698 } 01699 } 01700 01701 if(still_ok) 01702 { 01703 double smallest_distance = CUBIT_DBL_MAX; 01704 for(i=geometry_entities_1.size(); i--;) 01705 { 01706 GeometryEntity *ge1 = geometry_entities_1.get_and_step(); 01707 GeometryQueryEngine *gqe1 = gqes_1.get_and_step(); 01708 for(j=geometry_entities_2.size(); j--;) 01709 { 01710 GeometryEntity *ge2 = geometry_entities_2.get_and_step(); 01711 //GeometryQueryEngine *gqe2 = gqes_2.get_and_step(); 01712 01713 CubitVector cur_pos1, cur_pos2; 01714 double cur_distance; 01715 01716 gqe1->entity_entity_distance(ge1, ge2, cur_pos1, cur_pos2, cur_distance); 01717 01718 if(cur_distance < smallest_distance) 01719 { 01720 smallest_distance = cur_distance; 01721 distance = cur_distance; 01722 p1 = cur_pos1; 01723 p2 = cur_pos2; 01724 } 01725 } 01726 } 01727 } 01728 else 01729 { 01730 PRINT_ERROR("Entity-entity distance not yet supported for virtual geometry.\n"); 01731 return CUBIT_FAILURE; 01732 } 01733 01734 return CUBIT_SUCCESS; 01735 } 01736 01737 //------------------------------------------------------------------------- 01738 // Purpose : Remove all possible virtual geometry. 01739 // 01740 // Special Notes : 01741 // 01742 // Creator : Jason Kraftcheck 01743 // 01744 // Creation Date : 06/28/00 01745 //------------------------------------------------------------------------- 01746 void VirtualQueryEngine::remove_virtual_geometry( RefEntity* entity_ptr, 01747 CubitBoolean all_children ) 01748 { 01749 if ( Body* body_ptr = dynamic_cast<Body*>(entity_ptr) ) 01750 remove_virtual_geometry(body_ptr, all_children); 01751 else if( RefVolume* vol_ptr = dynamic_cast<RefVolume*>(entity_ptr) ) 01752 remove_virtual_geometry(vol_ptr, all_children); 01753 else if( RefFace* face_ptr = dynamic_cast<RefFace*>(entity_ptr) ) 01754 remove_virtual_geometry(face_ptr); 01755 } 01756 01757 void VirtualQueryEngine::remove_virtual_geometry( Body* body_ptr, 01758 bool all_children ) 01759 { 01760 int i; 01761 DLIList<RefVolume*> volumes, part_results; 01762 body_ptr->ref_volumes(volumes); 01763 for ( i = volumes.size(); i--; ) { 01764 RefVolume* vol = volumes.step_and_get(); 01765 if ( ! dynamic_cast<PartitionLump*>(vol->get_lump_ptr()) ) 01766 volumes.change_to(0); 01767 } 01768 volumes.remove_all_with_value(0); 01769 if ( volumes.size() ) 01770 PartitionTool::instance()->unpartitionAll(volumes, part_results); 01771 01772 if ( !all_children ) 01773 return; 01774 01775 volumes.clean_out(); 01776 body_ptr->ref_volumes(volumes); 01777 for ( i = volumes.size(); i--; ) 01778 remove_virtual_geometry( volumes.step_and_get(), true ); 01779 } 01780 01781 void VirtualQueryEngine::remove_virtual_geometry( RefVolume* vol_ptr, 01782 bool all_children ) 01783 { 01784 int i; 01785 DLIList<RefFace*> faces, part_results; 01786 bool had_virtual_geometry = false; 01787 vol_ptr->ref_faces( faces ); 01788 for ( i = faces.size(); i--; ) 01789 { 01790 if ( dynamic_cast<CompositeSurface*>(faces.step_and_get()->get_surface_ptr()) ) 01791 { 01792 CompositeTool::instance()->uncomposite(faces.get()); 01793 had_virtual_geometry = true; 01794 } 01795 } 01796 01797 faces.clean_out(); 01798 vol_ptr->ref_faces( faces ); 01799 for ( i = faces.size(); i--; ) 01800 { 01801 if ( !dynamic_cast<PartitionSurface*>(faces.step_and_get()->get_surface_ptr())) 01802 faces.change_to(0); 01803 } 01804 faces.remove_all_with_value(0); 01805 if ( faces.size() ) 01806 { 01807 PartitionTool::instance()->unpartitionAll(faces, part_results); 01808 had_virtual_geometry = true; 01809 } 01810 01811 if ( !all_children ) 01812 return; 01813 01814 faces.clean_out(); 01815 vol_ptr->ref_faces( faces ); 01816 for ( i = faces.size(); i--; ) 01817 remove_virtual_geometry( faces.step_and_get() ); 01818 01819 if( had_virtual_geometry ) 01820 AppUtil::instance()->send_event(GeometryEvent(GeometryEvent::TOPOLOGY_MODIFIED, vol_ptr)); 01821 } 01822 01823 void VirtualQueryEngine::remove_virtual_geometry( RefFace* face_ptr ) 01824 { 01825 int i; 01826 DLIList<RefEdge*> edges, part_results; 01827 face_ptr->ref_edges( edges ); 01828 for ( i = edges.size(); i--; ) { 01829 if ( dynamic_cast<CompositeCurve*>(edges.step_and_get()->get_curve_ptr()) ) 01830 CompositeTool::instance()->uncomposite(edges.get()); 01831 } 01832 01833 edges.clean_out(); 01834 face_ptr->ref_edges( edges ); 01835 for ( i = edges.size(); i--; ) { 01836 if ( !dynamic_cast<PartitionCurve*>(edges.step_and_get()->get_curve_ptr())) 01837 edges.change_to(0); 01838 } 01839 edges.remove_all_with_value(0); 01840 if ( edges.size() ) 01841 PartitionTool::instance()->unpartitionAll(edges, part_results); 01842 } 01843 01844 01845 01846 01847 CubitStatus VirtualQueryEngine::export_solid_model( DLIList<TopologyBridge*>& , 01848 const char* , 01849 Model_File_Type , 01850 const CubitString &, 01851 ModelExportOptions & ) 01852 { 01853 return CUBIT_FAILURE; 01854 } 01855 01856 CubitStatus VirtualQueryEngine::save_temp_geom_file( DLIList<TopologyBridge*>& , 01857 const char* , 01858 const CubitString &, 01859 CubitString &, 01860 CubitString &) 01861 { 01862 return CUBIT_FAILURE; 01863 } 01864 01865 CubitStatus VirtualQueryEngine::import_solid_model( const char* , 01866 Model_File_Type, 01867 DLIList<TopologyBridge*>&, 01868 ModelImportOptions &import_options ) 01869 { 01870 PRINT_INFO("VirtualQueryEngine::import_solid_model\n"); 01871 01872 default_error_message( "import_solid_model()"); 01873 return CUBIT_FAILURE; 01874 } 01875 01876 void VirtualQueryEngine::delete_solid_model_entities(DLIList<BodySM*>& list) const 01877 { 01878 for ( int i = list.size(); i--; ) 01879 delete_solid_model_entities( list.get_and_step() ); 01880 } 01881 01882 01883 01884 CubitStatus VirtualQueryEngine::delete_solid_model_entities( 01885 BodySM* bodysm ) const 01886 { 01887 CompositeBody* compbod = dynamic_cast<CompositeBody*>(bodysm); 01888 if (compbod) 01889 { 01890 while (compbod->num_bodies()) 01891 { 01892 BodySM* dead_body = compbod->get_body( compbod->num_bodies() - 1 ); 01893 dead_body->get_geometry_query_engine()->delete_solid_model_entities( dead_body ); 01894 } 01895 01896 CompositeEngine::instance().clean_out_deactivated_geometry(); 01897 return CUBIT_SUCCESS; 01898 } 01899 01900 01901 PartitionBody* bod = dynamic_cast<PartitionBody*>(bodysm); 01902 if ( !bod ) 01903 return CUBIT_FAILURE; 01904 01905 PartitionEngine::instance().delete_solid_model_entities( bod, bodysm ); 01906 if ( bodysm ) { 01907 bodysm->get_geometry_query_engine()->delete_solid_model_entities(bodysm); 01908 } 01909 return CUBIT_SUCCESS; 01910 } 01911 01912 CubitStatus VirtualQueryEngine::delete_solid_model_entities( 01913 Surface* surf_ptr ) const 01914 { 01915 PartitionSurface* ps_ptr = dynamic_cast<PartitionSurface*>(surf_ptr); 01916 CompositeSurface* cs_ptr = dynamic_cast<CompositeSurface*>(surf_ptr); 01917 01918 if (cs_ptr) 01919 { 01920 while(cs_ptr->num_surfs()) 01921 { 01922 Surface* dead_surf = cs_ptr->get_surface(cs_ptr->num_surfs()-1); 01923 dead_surf->get_geometry_query_engine()->delete_solid_model_entities(dead_surf); 01924 } 01925 01926 CompositeEngine::instance().clean_out_deactivated_geometry(); 01927 } 01928 01929 else if( ps_ptr ) 01930 { 01931 PartitionEngine::instance().delete_solid_model_entities( ps_ptr, surf_ptr ); 01932 if ( surf_ptr ) 01933 surf_ptr->get_geometry_query_engine()->delete_solid_model_entities(surf_ptr); 01934 } 01935 01936 return CUBIT_SUCCESS; 01937 } 01938 01939 CubitStatus VirtualQueryEngine::delete_solid_model_entities( 01940 Curve* curve_ptr ) const 01941 { 01942 CompositeCurve* cc_ptr = dynamic_cast<CompositeCurve*>(curve_ptr); 01943 PartitionCurve* pc_ptr = dynamic_cast<PartitionCurve*>(curve_ptr); 01944 01945 if( cc_ptr ) 01946 { 01947 while(cc_ptr->num_curves()) 01948 { 01949 Curve* dead_curv = cc_ptr->get_curve(cc_ptr->num_curves()-1); 01950 dead_curv->get_geometry_query_engine()->delete_solid_model_entities(dead_curv); 01951 } 01952 01953 CompositeEngine::instance().clean_out_deactivated_geometry(); 01954 } 01955 else if( pc_ptr ) 01956 { 01957 PartitionEngine::instance().delete_solid_model_entities( pc_ptr, curve_ptr ); 01958 if ( curve_ptr ) 01959 curve_ptr->get_geometry_query_engine()->delete_solid_model_entities(curve_ptr); 01960 } 01961 01962 return CUBIT_SUCCESS; 01963 } 01964 01965 CubitStatus VirtualQueryEngine::delete_solid_model_entities( TBPoint* ) const 01966 { 01967 return CUBIT_FAILURE; 01968 } 01969 01970 CubitStatus VirtualQueryEngine::fire_ray( CubitVector &origin, 01971 CubitVector &direction, 01972 DLIList<TopologyBridge*> &at_entity_list, 01973 DLIList<double> &ray_params, 01974 int max_hits, 01975 double ray_radius, 01976 DLIList<TopologyBridge*> *hit_entity_list_ptr) const 01977 { 01978 // Note: for now assume we will only get curves or surfaces 01979 01980 int i; 01981 int prev_num_hits = ray_params.size(); 01982 GeometryQueryEngine *gqe = 0; 01983 TopologyBridge *bridge_ptr; 01984 01985 // This is only needed because this function is "const" 01986 VirtualQueryEngine *vqe = VirtualQueryEngine::instance(); 01987 01988 at_entity_list.reset(); 01989 for( i=at_entity_list.size(); i--; ) 01990 { 01991 prev_num_hits = ray_params.size(); 01992 bridge_ptr = at_entity_list.get_and_step(); 01993 01994 gqe = bridge_ptr->get_geometry_query_engine(); 01995 if( !gqe ) 01996 { 01997 PRINT_ERROR( "Unable to find geometry engine associated with an entity!\n" ); 01998 return CUBIT_FAILURE; 01999 } 02000 02001 Curve *curve_ptr = CAST_TO( bridge_ptr, Curve ); 02002 if( curve_ptr ) 02003 { 02004 DLIList<TopologyBridge*> tb_curve_list; 02005 vqe->get_underlying_curves( curve_ptr, tb_curve_list ); 02006 02007 if( tb_curve_list.size() > 0 ) 02008 { 02009 gqe = tb_curve_list.get()->get_geometry_query_engine(); 02010 02011 gqe->fire_ray( origin, direction, tb_curve_list, ray_params, max_hits, 02012 ray_radius, hit_entity_list_ptr ); 02013 02014 // If curve_ptr is a PartitionCurve, it could be smaller than the underlying curve. 02015 // This means we have to check to make sure any hit points lie inside the curve. Remove if they don't. 02016 if (CAST_TO(curve_ptr, PartitionCurve)) 02017 { 02018 // start iterating at the first new ray_param 02019 ray_params.reset(); 02020 ray_params.step(prev_num_hits); 02021 hit_entity_list_ptr->reset(); 02022 hit_entity_list_ptr->step(prev_num_hits); 02023 02024 int j; 02025 for (j=prev_num_hits; j<ray_params.size(); j++) 02026 { 02027 CubitVector *loc_ptr; 02028 double param = ray_params.get(); 02029 02030 loc_ptr = new CubitVector; 02031 origin.next_point( direction, param, *loc_ptr ); 02032 02033 CubitPointContainment containment = CUBIT_PNT_UNKNOWN; 02034 containment = curve_ptr->point_containment(*loc_ptr); 02035 if ( (containment != CUBIT_PNT_ON) && (containment != CUBIT_PNT_BOUNDARY) ) 02036 { 02037 //remove from the hit list 02038 ray_params.remove(); 02039 hit_entity_list_ptr->remove(); 02040 } 02041 else 02042 { 02043 ray_params.step(); 02044 hit_entity_list_ptr->step(); 02045 } 02046 } 02047 } 02048 02049 } 02050 } 02051 02052 Surface *surface_ptr = CAST_TO( bridge_ptr, Surface ); 02053 if( surface_ptr ) 02054 { 02055 DLIList<TopologyBridge*> tb_surface_list; 02056 vqe->get_underlying_surfaces( surface_ptr, tb_surface_list ); 02057 02058 if( tb_surface_list.size() > 0 ) 02059 { 02060 gqe = tb_surface_list.get()->get_geometry_query_engine(); 02061 02062 gqe->fire_ray( origin, direction, tb_surface_list, ray_params, max_hits, 02063 ray_radius, hit_entity_list_ptr ); 02064 02065 // If surface_ptr is a PartitionSurface, it could be smaller than the underlying surface. 02066 // This means we have to check to make sure any hit points lie inside the surface. Remove if they don't. 02067 if (CAST_TO(surface_ptr, PartitionSurface)) 02068 { 02069 // start iterating at the first new ray_param 02070 ray_params.reset(); 02071 ray_params.step(prev_num_hits); 02072 hit_entity_list_ptr->reset(); 02073 hit_entity_list_ptr->step(prev_num_hits); 02074 02075 int j; 02076 for (j=prev_num_hits; j<ray_params.size(); j++) 02077 { 02078 CubitVector *loc_ptr; 02079 double param = ray_params.get(); 02080 02081 loc_ptr = new CubitVector; 02082 origin.next_point( direction, param, *loc_ptr ); 02083 02084 CubitPointContainment containment = CUBIT_PNT_UNKNOWN; 02085 containment = surface_ptr->point_containment(*loc_ptr); 02086 if ( (containment != CUBIT_PNT_ON) && (containment != CUBIT_PNT_BOUNDARY) ) 02087 { 02088 //remove from the hit list 02089 ray_params.remove(); 02090 hit_entity_list_ptr->remove(); 02091 } 02092 else 02093 { 02094 ray_params.step(); 02095 hit_entity_list_ptr->step(); 02096 } 02097 } 02098 } 02099 02100 } 02101 } 02102 02103 } 02104 02105 if( hit_entity_list_ptr && hit_entity_list_ptr->size() != ray_params.size() ) 02106 PRINT_WARNING( "Hit entity list size not equal to number of hits\n" ); 02107 02108 // Account for max hits 02109 if( max_hits != 0 ) 02110 { 02111 if( ray_params.size() <= max_hits ) 02112 return CUBIT_SUCCESS; 02113 02114 for( i=ray_params.size()-max_hits; i--; ) 02115 { 02116 ray_params.last(); 02117 ray_params.remove(); 02118 if( hit_entity_list_ptr ) 02119 { 02120 hit_entity_list_ptr->last(); 02121 hit_entity_list_ptr->remove(); 02122 } 02123 } 02124 } 02125 02126 return CUBIT_SUCCESS; 02127 } 02128 02129 double VirtualQueryEngine::get_sme_resabs_tolerance() const 02130 { 02131 return GEOMETRY_RESABS; 02132 } 02133 02134 double VirtualQueryEngine::set_sme_resabs_tolerance( double ) 02135 { 02136 PRINT_INFO("VirtualQueryEngine::set_sme_resabs_tolerance\n"); 02137 02138 default_error_message( "set_sme_resabs_tolerance()"); 02139 return 0; 02140 } 02141 02142 CubitStatus VirtualQueryEngine::set_int_option( const char* , int ) 02143 { 02144 PRINT_INFO("VirtualQueryEngine::set_int_option\n"); 02145 02146 default_error_message( "set_int_option()"); 02147 return CUBIT_FAILURE; 02148 } 02149 02150 CubitStatus VirtualQueryEngine::set_dbl_option( const char* , double ) 02151 { 02152 PRINT_INFO("VirtualQueryEngine::set_dbl_option\n"); 02153 02154 default_error_message( "set_dbl_option()"); 02155 return CUBIT_FAILURE; 02156 } 02157 02158 CubitStatus VirtualQueryEngine::set_str_option( const char* , const char* ) 02159 { 02160 PRINT_INFO("VirtualQueryEngine::set_str_option\n"); 02161 02162 default_error_message( "set_str_option()"); 02163 return CUBIT_FAILURE; 02164 } 02165 02166 void VirtualQueryEngine::register_attributes() 02167 { 02168 CubitStatus result; 02169 result = CGMApp::instance()->attrib_manager()->register_attrib_type( 02170 CA_PARTITION_VG, "partition vg", "PARTITION_VG", 02171 CAPartitionVG_creator, CUBIT_FALSE, 02172 CUBIT_FALSE, CUBIT_TRUE, CUBIT_TRUE, 02173 CUBIT_FALSE, CUBIT_FALSE); 02174 if (CUBIT_SUCCESS != result) { 02175 PRINT_ERROR("Failed to register attribute type partition vg.\n"); 02176 return; 02177 } 02178 02179 result = CGMApp::instance()->attrib_manager()->register_attrib_type( 02180 CA_COMPOSITE_VG, "composite vg", "COMPOSITE_VG", 02181 CACompositeVG_creator, CUBIT_FALSE, 02182 CUBIT_FALSE, CUBIT_TRUE, CUBIT_TRUE, 02183 CUBIT_FALSE, CUBIT_FALSE); 02184 if (CUBIT_SUCCESS != result) { 02185 PRINT_ERROR("Failed to register attribute type composite vg.\n"); 02186 return; 02187 } 02188 02189 result = CGMApp::instance()->attrib_manager()->register_attrib_type( 02190 CA_VIRTUAL_VG, "virtual vg", "VIRTUAL_VG", 02191 CAVirtualVG_creator, CUBIT_FALSE, 02192 CUBIT_FALSE, CUBIT_TRUE, CUBIT_TRUE, 02193 CUBIT_FALSE, CUBIT_FALSE); 02194 if (CUBIT_SUCCESS != result) { 02195 PRINT_ERROR("Failed to register attribute type virtual vg.\n"); 02196 } 02197 } 02198 02199 02200 02201 CubitStatus VirtualQueryEngine::translate( BodySM* body, 02202 const CubitVector& offset ) 02203 { 02204 if (PartitionBody* part = dynamic_cast<PartitionBody*>(body)) 02205 return PartitionEngine::instance().translate( part, offset ); 02206 else if(CompositeBody* comp = dynamic_cast<CompositeBody*>(body)) 02207 return CompositeEngine::instance().translate( comp, offset ); 02208 02209 PRINT_ERROR("Non-virtual entity in VGE::translate.\n"); 02210 return CUBIT_FAILURE; 02211 } 02212 02213 CubitStatus VirtualQueryEngine::rotate ( BodySM* body, 02214 const CubitVector& axis, 02215 double angle ) 02216 { 02217 if (PartitionBody* part = dynamic_cast<PartitionBody*>(body)) 02218 return PartitionEngine::instance().rotate( part, axis, angle ); 02219 else if(CompositeBody* comp = dynamic_cast<CompositeBody*>(body)) 02220 return CompositeEngine::instance().rotate( comp, axis, angle ); 02221 02222 PRINT_ERROR("Non-virtual entity in VGE::rotate.\n"); 02223 return CUBIT_FAILURE; 02224 } 02225 02226 CubitStatus VirtualQueryEngine::scale ( BodySM* body, 02227 double factor ) 02228 { 02229 return scale( body, CubitVector(factor,factor,factor) ); 02230 } 02231 02232 CubitStatus VirtualQueryEngine::scale ( BodySM* body, 02233 const CubitVector& factors ) 02234 { 02235 if (PartitionBody* part = dynamic_cast<PartitionBody*>(body)) 02236 return PartitionEngine::instance().scale( part, factors ); 02237 else if(CompositeBody* comp = dynamic_cast<CompositeBody*>(body)) 02238 return CompositeEngine::instance().scale( comp, factors ); 02239 02240 PRINT_ERROR("Non-virtual entity in VGE::scale.\n"); 02241 return CUBIT_FAILURE; 02242 } 02243 02244 CubitStatus VirtualQueryEngine::reflect ( BodySM* body, 02245 const CubitVector& axis ) 02246 { 02247 if (PartitionBody* part = dynamic_cast<PartitionBody*>(body)) 02248 return PartitionEngine::instance().reflect( part, axis ); 02249 else if(CompositeBody* comp = dynamic_cast<CompositeBody*>(body)) 02250 return CompositeEngine::instance().reflect( comp, axis ); 02251 02252 PRINT_ERROR("Non-virtual entity in VGE::reflect.\n"); 02253 return CUBIT_FAILURE; 02254 } 02255 02256 CubitStatus VirtualQueryEngine::restore_transform( BodySM* body ) 02257 { 02258 if (PartitionBody* part = dynamic_cast<PartitionBody*>(body)) 02259 return PartitionEngine::instance().restore_transform( part ); 02260 else if(CompositeBody* comp = dynamic_cast<CompositeBody*>(body)) 02261 return CompositeEngine::instance().restore_transform( comp ); 02262 02263 PRINT_ERROR("Non-virtual entity in VGE::restore_transform.\n"); 02264 return CUBIT_FAILURE; 02265 } 02266 02267 CubitStatus VirtualQueryEngine::translate( GeometryEntity* ent, 02268 const CubitVector& offset ) 02269 { 02270 if (PartitionEntity* part = dynamic_cast<PartitionEntity*>(ent)) 02271 return PartitionEngine::instance().translate( part, offset ); 02272 else if(CompositeSurface* csurf = dynamic_cast<CompositeSurface*>(ent)) 02273 return CompositeEngine::instance().translate( csurf, offset ); 02274 else if(CompositeCurve* ccurve = dynamic_cast<CompositeCurve*>(ent)) 02275 return CompositeEngine::instance().translate( ccurve, offset ); 02276 02277 PRINT_ERROR("Non-virtual entity in VGE::translate.\n"); 02278 return CUBIT_FAILURE; 02279 } 02280 02281 CubitStatus VirtualQueryEngine::rotate ( GeometryEntity* ent, 02282 const CubitVector& axis, 02283 double degrees ) 02284 { 02285 if (PartitionEntity* part = dynamic_cast<PartitionEntity*>(ent)) 02286 return PartitionEngine::instance().rotate( part, axis, degrees ); 02287 else if(CompositeSurface* csurf = dynamic_cast<CompositeSurface*>(ent)) 02288 return CompositeEngine::instance().rotate( csurf, axis, degrees ); 02289 else if(CompositeCurve* ccurve = dynamic_cast<CompositeCurve*>(ent)) 02290 return CompositeEngine::instance().rotate( ccurve, axis, degrees ); 02291 02292 PRINT_ERROR("Non-virtual entity in VGE::rotate.\n"); 02293 return CUBIT_FAILURE; 02294 } 02295 02296 CubitStatus VirtualQueryEngine::scale ( GeometryEntity* ent, 02297 double factor ) 02298 { 02299 return scale( ent, CubitVector( factor, factor, factor ) ); 02300 } 02301 02302 CubitStatus VirtualQueryEngine::scale ( GeometryEntity* ent, 02303 const CubitVector& factors ) 02304 { 02305 if (PartitionEntity* part = dynamic_cast<PartitionEntity*>(ent)) 02306 return PartitionEngine::instance().scale( part, factors ); 02307 else if(CompositeSurface* csurf = dynamic_cast<CompositeSurface*>(ent)) 02308 return CompositeEngine::instance().scale( csurf, factors ); 02309 else if(CompositeCurve* ccurve = dynamic_cast<CompositeCurve*>(ent)) 02310 return CompositeEngine::instance().scale( ccurve, factors ); 02311 02312 PRINT_ERROR("Non-virtual entity in VGE::scale.\n"); 02313 return CUBIT_FAILURE; 02314 } 02315 02316 CubitStatus VirtualQueryEngine::reflect ( GeometryEntity* ent, 02317 const CubitVector& axis ) 02318 { 02319 if (PartitionEntity* part = dynamic_cast<PartitionEntity*>(ent)) 02320 return PartitionEngine::instance().reflect( part, axis ); 02321 else if(CompositeSurface* csurf = dynamic_cast<CompositeSurface*>(ent)) 02322 return CompositeEngine::instance().reflect( csurf, axis ); 02323 else if(CompositeCurve* ccurve = dynamic_cast<CompositeCurve*>(ent)) 02324 return CompositeEngine::instance().reflect( ccurve, axis ); 02325 02326 PRINT_ERROR("Non-virtual entity in VGE::reflect.\n"); 02327 return CUBIT_FAILURE; 02328 } 02329 02330 //Function should only be called on volumes of multi-volume bodies 02331 CubitBoolean VirtualQueryEngine::volumes_overlap (Lump *lump1, Lump *lump2 ) const 02332 { 02333 PartitionLump* partition_lump1 = dynamic_cast<PartitionLump*>(lump1); 02334 PartitionLump* partition_lump2 = dynamic_cast<PartitionLump*>(lump2); 02335 02336 Lump *tmp_lump1 = lump1; 02337 if( partition_lump1 ) 02338 tmp_lump1 = partition_lump1->real_lump(); 02339 02340 Lump *tmp_lump2 = lump2; 02341 if( partition_lump2 ) 02342 tmp_lump2 = partition_lump2->real_lump(); 02343 02344 GeometryQueryEngine *gqe = tmp_lump1->get_geometry_query_engine(); 02345 if( gqe != tmp_lump2->get_geometry_query_engine() ) 02346 { 02347 PRINT_ERROR("Volumes must be of the same type (, SolidWorks, etc) to\n" 02348 "find if they overlap.\n"); 02349 return CUBIT_FALSE; 02350 } 02351 02352 return gqe->volumes_overlap( tmp_lump1, tmp_lump2 ); 02353 } 02354 02355 02356 CubitBoolean VirtualQueryEngine::bodies_overlap (BodySM *body_ptr_1, BodySM *body_ptr_2 ) const 02357 { 02358 PartitionBody* partition_body1 = dynamic_cast<PartitionBody*>(body_ptr_1); 02359 PartitionBody* partition_body2 = dynamic_cast<PartitionBody*>(body_ptr_2); 02360 02361 BodySM *body1 = body_ptr_1; 02362 if( partition_body1 ) 02363 body1 = partition_body1->real_body(); 02364 02365 BodySM *body2 = body_ptr_2; 02366 if( partition_body2 ) 02367 body2 = partition_body2->real_body(); 02368 02369 GeometryQueryEngine *gqe = body1->get_geometry_query_engine(); 02370 if( gqe != body2->get_geometry_query_engine() ) 02371 { 02372 PRINT_ERROR("Volumes must be of the same type (, SolidWorks, etc) to\n" 02373 "find if they overlap.\n"); 02374 return CUBIT_FALSE; 02375 } 02376 02377 return gqe->bodies_overlap( body1, body2 ); 02378 02379 } 02380 02381 TopologyBridge* VirtualQueryEngine::get_visible_entity_at_point(TopologyBridge* hidden_tb, CubitVector* point) 02382 { 02383 // Determine entity type; should only be Curve or TBPoint 02384 02385 int j, k; 02386 bool added_entity = false; 02387 TopologyBridge* bridge_ptr = hidden_tb; 02388 TopologyBridge* tb_owner = NULL; 02389 bool hidden = CUBIT_TRUE; 02390 02391 TopologyBridge* visible_tb = NULL; 02392 02393 while (hidden) 02394 { 02395 tb_owner = dynamic_cast<TopologyBridge*>(bridge_ptr->owner()); 02396 if( tb_owner ) 02397 { 02398 if( tb_owner->topology_entity() ) 02399 { 02400 visible_tb = tb_owner; 02401 hidden = CUBIT_FALSE; 02402 added_entity = true; 02403 continue; 02404 } 02405 else 02406 hidden = CUBIT_TRUE; 02407 } 02408 else 02409 { 02410 if( bridge_ptr->topology_entity() ) 02411 { 02412 visible_tb = bridge_ptr; 02413 hidden = CUBIT_FALSE; 02414 added_entity = true; 02415 continue; 02416 } 02417 else 02418 { 02419 hidden = CUBIT_TRUE; 02420 } 02421 } 02422 02423 02424 TopologyBridge *tb_ptr; 02425 if( tb_owner ) 02426 tb_ptr = tb_owner; 02427 else 02428 tb_ptr = bridge_ptr; 02429 02430 TBOwner* tb_owner = tb_ptr->owner(); 02431 if (CAST_TO(tb_owner, HiddenEntitySet)) // virtual geometry 02432 { 02433 TopologyBridge* parent = NULL; 02434 while (CAST_TO(tb_owner, HiddenEntitySet)) // virtual geometry 02435 { 02436 HiddenEntitySet* hidden_set_ptr = CAST_TO(tb_owner, HiddenEntitySet); 02437 parent = dynamic_cast<TopologyBridge*>(hidden_set_ptr->owner()); 02438 if (parent) 02439 tb_owner = parent->owner(); 02440 } 02441 if (parent) 02442 { 02443 bridge_ptr = parent; 02444 added_entity = true; 02445 continue; 02446 } 02447 } 02448 else if (CAST_TO(tb_owner, SubEntitySet)) // partition geometry 02449 { 02450 SubEntitySet* sub_set_ptr = CAST_TO(tb_owner, SubEntitySet); 02451 02452 DLIList<TopologyBridge*> owner_list; 02453 sub_set_ptr->get_owners(owner_list); 02454 owner_list.reset(); 02455 // need to traverse all the entities that make up the original geometry 02456 // if intersected a surface, and the surface is partitioned into mult surfaces, 02457 // which surface did we hit? Did we hit the curve in between? The vertices? gahhhh... 02458 for (j=0; j<owner_list.size(); j++) 02459 { 02460 TopologyBridge* owner_partition = owner_list.get_and_step(); 02461 //determine geometry type and call point_containment 02462 02463 CubitPointContainment containment = CUBIT_PNT_UNKNOWN; 02464 02465 if (CAST_TO(owner_partition, Surface)) 02466 { 02467 containment = CAST_TO(owner_partition, Surface)->point_containment(*point); 02468 switch (containment) 02469 { 02470 case CUBIT_PNT_OFF: 02471 break; 02472 case CUBIT_PNT_ON: 02473 bridge_ptr = owner_partition; 02474 added_entity = true; 02475 break; 02476 case CUBIT_PNT_UNKNOWN: 02477 break; 02478 case CUBIT_PNT_BOUNDARY: 02479 { 02480 DLIList<TopologyBridge*> children, related_loops, related_coedges; 02481 DLIList<TopologyBridge*> related_curves, temp; 02482 02483 // Goal: get curves (incl. virtual ones) 02484 // Note: can't use ->curves() func b/c it won't grab the virtual curves 02485 02486 // get all Loops, including virtual 02487 owner_partition->get_children( related_loops, true ); 02488 02489 related_loops.reset(); 02490 int ii; 02491 02492 // get all CoEdges 02493 for (ii = related_loops.size(); ii--;) 02494 { 02495 temp.clean_out(); 02496 related_loops.get_and_step()->get_children(temp, true); 02497 related_coedges.merge_unique(temp); 02498 } 02499 // get all Curves 02500 for (ii = related_coedges.size(); ii--;) 02501 { 02502 temp.clean_out(); 02503 related_coedges.get_and_step()->get_children(temp, true); 02504 related_curves.merge_unique(temp); 02505 } 02506 02507 CAST_LIST(related_curves, children, TopologyBridge); 02508 for (k=0; k<children.size(); k++) 02509 { 02510 // CAST and do point_containment for each curve 02511 containment = CUBIT_PNT_UNKNOWN; 02512 TopologyBridge* partition_curve = children.get_and_step(); 02513 containment = CAST_TO(partition_curve, Curve)->point_containment(*point); 02514 switch (containment) 02515 { 02516 case CUBIT_PNT_OFF: 02517 case CUBIT_PNT_UNKNOWN: 02518 break; 02519 case CUBIT_PNT_ON: 02520 bridge_ptr = partition_curve; 02521 added_entity = true; 02522 break; 02523 case CUBIT_PNT_BOUNDARY: 02524 { 02525 // CAST and do point_containment for each vertex 02526 children.clean_out(); 02527 partition_curve->get_children(children, true); 02528 int kk; 02529 for (kk=0; kk<children.size(); kk++) 02530 { 02531 TopologyBridge* partition_vertex = children.get_and_step(); 02532 containment = CUBIT_PNT_UNKNOWN; 02533 CubitVector coords = CAST_TO(partition_vertex, TBPoint)->coordinates(); 02534 if (coords.distance_between_squared(*point) < GEOMETRY_RESABS*GEOMETRY_RESABS) 02535 { 02536 containment = CUBIT_PNT_ON; 02537 bridge_ptr = partition_vertex; 02538 added_entity = true; 02539 break; 02540 } 02541 else 02542 containment = CUBIT_PNT_OFF; 02543 } 02544 } 02545 } 02546 02547 if (added_entity) 02548 break; 02549 } 02550 break; 02551 } 02552 } 02553 if (added_entity) 02554 break; 02555 } 02556 else if (CAST_TO(owner_partition, Curve)) 02557 { 02558 // CAST and do point_containment for each curve 02559 containment = CUBIT_PNT_UNKNOWN; 02560 containment = CAST_TO(owner_partition, Curve)->point_containment(*point); 02561 switch (containment) 02562 { 02563 case CUBIT_PNT_OFF: 02564 case CUBIT_PNT_UNKNOWN: 02565 break; 02566 case CUBIT_PNT_ON: 02567 bridge_ptr = owner_partition; 02568 added_entity = true; 02569 break; 02570 case CUBIT_PNT_BOUNDARY: 02571 { 02572 // CAST and do point_containment for each vertex 02573 DLIList<TopologyBridge*> children; 02574 children.clean_out(); 02575 owner_partition->get_children(children, true); 02576 int kk; 02577 for (kk=0; kk<children.size(); kk++) 02578 { 02579 TopologyBridge* partition_vertex = children.get_and_step(); 02580 containment = CUBIT_PNT_UNKNOWN; 02581 CubitVector coords = CAST_TO(partition_vertex, TBPoint)->coordinates(); 02582 if (coords.distance_between_squared(*point) < GEOMETRY_RESABS*GEOMETRY_RESABS) 02583 { 02584 containment = CUBIT_PNT_ON; 02585 bridge_ptr = partition_vertex; 02586 added_entity = true; 02587 break; 02588 } 02589 else 02590 containment = CUBIT_PNT_OFF; 02591 } 02592 break; 02593 } 02594 } 02595 02596 if (added_entity) 02597 break; 02598 } 02599 02600 else if (CAST_TO(owner_partition, TBPoint)) 02601 { 02602 CubitVector coords = CAST_TO(owner_partition, TBPoint)->coordinates(); 02603 if (coords.distance_between_squared(*point) < GEOMETRY_RESABS*GEOMETRY_RESABS) 02604 { 02605 containment = CUBIT_PNT_ON; 02606 bridge_ptr = owner_partition; 02607 added_entity = true; 02608 break; 02609 } 02610 else 02611 containment = CUBIT_PNT_OFF; 02612 } 02613 02614 else 02615 PRINT_WARNING("Hit unknown partition entity.\n"); 02616 02617 02618 } 02619 if (!added_entity) 02620 { 02621 visible_tb = NULL; 02622 hidden = CUBIT_FALSE; 02623 //break; 02624 } 02625 02626 } 02627 02628 02629 } //while 02630 02631 return visible_tb; 02632 } 02633 02634 02635 CubitStatus VirtualQueryEngine::get_visible_entities( TopologyBridge *hidden_tb, 02636 DLIList<TopologyBridge*> &real_tbs ) 02637 { 02638 int j; 02639 TopologyBridge* bridge_ptr = NULL; 02640 TopologyBridge* tb_owner = NULL; 02641 02642 TopologyBridge* visible_tb = NULL; 02643 02644 DLIList<TopologyBridge*> tbs_to_search; 02645 tbs_to_search.append( hidden_tb ); 02646 02647 while(tbs_to_search.size()) 02648 { 02649 bridge_ptr = tbs_to_search.pop(); 02650 02651 tb_owner = dynamic_cast<TopologyBridge*>(bridge_ptr->owner()); 02652 if( tb_owner ) 02653 { 02654 if( tb_owner->topology_entity() ) 02655 { 02656 visible_tb = tb_owner; 02657 real_tbs.append( visible_tb ); 02658 continue; 02659 } 02660 } 02661 else 02662 { 02663 if( bridge_ptr->topology_entity() ) 02664 { 02665 visible_tb = bridge_ptr; 02666 real_tbs.append( visible_tb ); 02667 continue; 02668 } 02669 } 02670 02671 02672 TopologyBridge *tb_ptr; 02673 if( tb_owner ) 02674 tb_ptr = tb_owner; 02675 else 02676 tb_ptr = bridge_ptr; 02677 02678 TBOwner* tb_owner = tb_ptr->owner(); 02679 if (CAST_TO(tb_owner, HiddenEntitySet)) // it is a composite 02680 { 02681 TopologyBridge* parent = NULL; 02682 while (CAST_TO(tb_owner, HiddenEntitySet)) // virtual geometry 02683 { 02684 HiddenEntitySet* hidden_set_ptr = CAST_TO(tb_owner, HiddenEntitySet); 02685 parent = dynamic_cast<TopologyBridge*>(hidden_set_ptr->owner()); 02686 if (parent) 02687 tb_owner = parent->owner(); 02688 } 02689 if (parent) 02690 { 02691 tbs_to_search.append( parent ); 02692 continue; 02693 } 02694 } 02695 else if (CAST_TO(tb_owner, SubEntitySet)) // partition geometry 02696 { 02697 SubEntitySet* sub_set_ptr = CAST_TO(tb_owner, SubEntitySet); 02698 02699 DLIList<TopologyBridge*> owner_list; 02700 sub_set_ptr->get_owners(owner_list); 02701 owner_list.reset(); 02702 // need to traverse all the entities that make up the original geometry 02703 // if intersected a surface, and the surface is partitioned into mult surfaces, 02704 // which surface did we hit? Did we hit the curve in between? The vertices? gahhhh... 02705 for (j=0; j<owner_list.size(); j++) 02706 { 02707 TopologyBridge* owner_partition = owner_list.get_and_step(); 02708 tbs_to_search.append( owner_partition ); 02709 } 02710 } 02711 } 02712 02713 real_tbs.uniquify_ordered(); 02714 02715 return CUBIT_SUCCESS; 02716 }
