cgma
00001 //------------------------------------------------------------------------- 00002 // Filename : PartitionTool.hpp 00003 // 00004 // Purpose : Functions for splitting geometry 00005 // 00006 // Special Notes : 00007 // 00008 // Creator : Jason Kraftcheck 00009 // 00010 // Creation Date : 12/13/98 00011 //------------------------------------------------------------------------- 00012 00013 #ifndef PARTITION_TOOL_HPP 00014 #define PARTITION_TOOL_HPP 00015 00016 class SenseEntity; 00017 class PartitionEntity; 00018 class PartitionCurve; 00019 class PartitionSurface; 00020 class Loop; 00021 class Shell; 00022 00023 class RefEdge; 00024 class RefVertex; 00025 class Curve; 00026 template <class X> class DLIList; 00027 class PartitionCurve; 00028 00029 class CubitFacet; 00030 00031 #include "CubitDefines.h" 00032 #include "RefEdge.hpp" 00033 00034 class PartitionTool 00035 { 00036 public: 00037 00038 static PartitionTool* instance(); 00039 /* 00040 virtual CubitStatus partition( RefEdge* edge_ptr, 00041 RefVertex* split_point, 00042 RefEdge*& first_new_edge, 00043 RefEdge*& second_new_edge, 00044 CubitBoolean ignore_mesh = CUBIT_FALSE ); 00045 */ 00046 virtual RefVertex* partition( RefEdge* edge_ptr, 00047 const CubitVector& split_point, 00048 RefEdge*& first_new_edge, 00049 RefEdge*& second_new_edge, 00050 CubitBoolean ignore_mesh = CUBIT_FALSE ); 00051 virtual RefVertex* partition( RefEdge* edge_ptr, 00052 const CubitVector& split_point, 00053 DLIList<RefEdge*>& result_edges, 00054 CubitBoolean ignore_mesh = CUBIT_FALSE ); 00055 //R CubitStatus 00056 //R- CUBIT_SUCCESS/CUBIT_FAILURE 00057 //I edge_ptr 00058 //I- A pointer to the RefEdge to Partition. 00059 //I split_point 00060 //I- A pointer to the Vertex at the split location. 00061 //O first_new_edge / second_new_edge 00062 //O- Pointers to the new RefEdges created. 00063 //- Partition a RefEdge. 00064 00065 virtual RefFace* insert_edge( RefFace* face_ptr, 00066 DLIList<CubitVector*>& segments, 00067 CubitBoolean is_meshed, 00068 DLIList<RefEdge*>& created_curves, 00069 int level_of_recursion = 0, 00070 const double *tolerance_length = NULL); 00071 00072 virtual CubitStatus insert_edge( DLIList<RefFace*>& input_faces, 00073 DLIList<CubitVector*>& segments, 00074 DLIList<RefFace*>& result_faces, 00075 DLIList<RefEdge*>& created_edges, 00076 CubitBoolean do_split_curves = CUBIT_FALSE); 00077 00078 00079 virtual CubitStatus partition( RefFace* face_ptr, 00080 RefEdge* edge_ptr, 00081 RefFace*& new_face1, 00082 RefFace*& new_face2, 00083 CubitBoolean ); 00084 00085 virtual CubitStatus partition( RefFace* face_ptr, 00086 DLIList<RefEdge*>& split_edges, 00087 RefFace*& first_new_face, 00088 RefFace*& second_new_face, 00089 CubitBoolean ignore_mesh = CUBIT_FALSE ); 00090 //R CubitStatus 00091 //R- CUBIT_SUCCESS/CUBIT_FAILURE 00092 //I face_ptr 00093 //I- A pointer to the RefFace to split. 00094 //I split_edges 00095 //I- The list of edges defining split location. 00096 //O first_new_face / second_new_face 00097 //O- The new RefFaces created. 00098 //- Partition a RefFace. 00099 00100 virtual CubitStatus partition( RefVolume* vol_ptr, 00101 DLIList<RefFace*>& split_faces, 00102 RefVolume*& first_new_volume, 00103 RefVolume*& second_new_volume, 00104 CubitBoolean ignore_mesh = CUBIT_FALSE ); 00105 virtual CubitStatus partition( RefVolume* vol_ptr, 00106 DLIList<CubitFacet*>& split_faces, 00107 RefVolume*& first_new_volume, 00108 RefVolume*& second_new_volume, 00109 DLIList<RefFace*>& new_surfaces, 00110 CubitBoolean ignore_mesh = CUBIT_FALSE ); 00111 //R CubitStatus 00112 //I vol_ptr 00113 //I- A pointer to the RefVolume to split. 00114 //I split_faces 00115 //I- The list of faces defining the split location 00116 //O first_new_volume/second_new_volume 00117 //O- The new RefVolumes created 00118 //- Partition a RefVolume. 00119 00120 CubitStatus destroy_volume_partition( RefVolume* partition ); 00121 00122 //CubitStatus partition( RefEdge* edge_ptr, 00123 // DLIList<RefVertex*>& split_points, 00124 // DLIList<RefEdge*>& new_edges, 00125 // CubitBoolean ignore_mesh = CUBIT_FALSE ); 00126 CubitStatus partition( RefEdge* edge_ptr, 00127 DLIList<CubitVector*>& split_points, 00128 DLIList<RefEdge*>& new_edges, 00129 CubitBoolean ignore_mesh = CUBIT_FALSE ); 00130 CubitStatus partition( RefEdge* edge_ptr, 00131 DLIList<CubitVector*>& split_points, 00132 DLIList<RefVertex*>& new_vertices, 00133 DLIList<RefEdge*>& new_edges, 00134 CubitBoolean ignore_mesh = CUBIT_FALSE ); 00135 //R CubitStatus 00136 //R- CUBIT_SUCCESS/CUBIT_FAILURE 00137 //I edge_ptr 00138 //I- A pointer to the RefEdge to Partition. 00139 //I split_points 00140 //I- A list of Vertices at which to split the curve. 00141 //O new_edges 00142 //O- The new RefEdges created. 00143 //- Partition a RefEdge. 00144 00145 CubitStatus partition_face_by_curves( RefFace* face_ptr, 00146 const DLIList<Curve*>& split_curves, 00147 DLIList<RefFace*>& result_faces, 00148 CubitBoolean do_split_curves = CUBIT_FALSE, 00149 DLIList<RefEdge*>* new_edges = NULL, 00150 CubitBoolean ignore_mesh = CUBIT_FALSE ); 00151 //- Similar to the next function but takes curves as input 00152 00153 CubitStatus partition( RefFace* face_ptr, 00154 const DLIList<RefEdge*>& split_edges, 00155 DLIList<RefFace*>& result_faces, 00156 CubitBoolean do_split_curves = CUBIT_FALSE, 00157 DLIList<RefEdge*>* new_edges = NULL, 00158 CubitBoolean ignore_mesh = CUBIT_FALSE ); 00159 //R CubitStatus 00160 //R- CUBIT_SUCCESS/CUBIT_FAILURE 00161 //I face_ptr 00162 //I- A pointer to the RefFace to partition 00163 //I split_edges 00164 //I- A list of RefEdges with which to partition the RefFace 00165 //O result_faces 00166 //O- The RefFaces resulting from the splitting operation 00167 //I split_curves 00168 //I- If true, spatially compare all RefVertices in the split_edge 00169 //I- list with edges in that list and on the RefFace, and partition 00170 //I- RefEdges as necessary. 00171 //O new_edges 00172 //O- If split_curves in CUBIT_TRUE, and this is non-null, a list 00173 //O- of new RefEdges created by partitioning will be passed back. 00174 //I ignore_mesh 00175 //I- If true, operator will not fail if the passed RefFace is meshed, 00176 //I- or if split_curves in true and any of the RefEdges are meshed. 00177 //I- NOTE: If this is passed as CUBIT_TRUE, it is the responsibility 00178 //I- of the caller to remove the mesh from hidden entities. 00179 //- Do multiple partitioning of a RefFace. 00180 00181 RefEdge* unpartition( RefEdge* first_partition_edge, 00182 RefEdge* second_partition_edge ); 00183 //R RefEdge* 00184 //R- The RefEdge restored to the model. 00185 //I first_partition_edge / second_partition_edge 00186 //I- Pointers to RefEdges with PartitionCurve geometry. 00187 //O free_vertex 00188 //O- A pointer to the freed vertex. 00189 //I keep_dead 00190 //I- If true, the passed-in RefEdges are not destroyed, but the 00191 //I- attached PartitionCurve is. 00192 //- Undo a partitioning operation. 00193 00194 RefFace* unpartition( RefFace* first_partition_face, 00195 RefFace* second_partition_face ); 00196 //R RefFace* 00197 //R- The RefFace restored to the model. 00198 //I first_partition_face / second_partition_face 00199 //I- Pointers to RefFaces with PartitionSurface geometry. 00200 //O free_edges 00201 //O- A list of edges freed by this operation. 00202 //I keep_dead 00203 //I- If true, the passed-in RefFaces are not destroyed, but the 00204 //I- attached PartitionSurface is. 00205 //- Undo a partitioning operation. 00206 00207 RefVolume* unpartition( RefVolume* first_partition_volume, 00208 RefVolume* second_partition_volume ); 00209 //R RefVolume* 00210 //R- The RefVolume restored to the model. 00211 //I first_partition_volume / second_partition_volume 00212 //I- Pointers to RefVolumes with PartitionLump geometry. 00213 //O free_faces 00214 //O- A list of faces freed by this operation. 00215 //- Undo a partitioning operation. 00216 00217 RefVolume* unpartition( DLIList<RefVolume*>& partition_volumes ); 00218 00219 00220 virtual CubitStatus unpartitionAll( DLIList<RefEdge*>& partition_edges, 00221 DLIList<RefEdge*>& restored_edges ); 00222 //R CubitStatus 00223 //R- CUBIT_SUCCESS/CUBIT_FAILURE 00224 //I partition_edges 00225 //I- A list of RefEdges with PartitionCurve geometry. 00226 //O restored_edges 00227 //O- A list of RefEdges restored to the model. 00228 //- Remove a bunch of partitions. 00229 //- 00230 //- Note: Any vertices freed by this operation will be deleted. 00231 00232 virtual CubitStatus unpartitionAll( DLIList<RefFace*>& partition_faces, 00233 DLIList<RefFace*>& restored_faces ); 00234 //R CubitStatus 00235 //R- CUBIT_SUCCESS/CUBIT_FAILURE 00236 //I partition_faces 00237 //I- A list of RefFaces with PartitionSurfaces geometry. 00238 //O restored_faces 00239 //O- A list of RefFaces restored to the model. 00240 //- Remove a bunch of partitions. 00241 //- 00242 //- Note: any RefEdges freed by this operation and thier child 00243 //- RefVertices will be deleted. 00244 00245 00246 virtual CubitStatus unpartitionAll( DLIList<RefVolume*>& partition_vols, 00247 DLIList<RefVolume*>& restored_vols ); 00248 00249 RefVertex* make_point_curve( RefFace* ref_face, 00250 const CubitVector& position ); 00251 00252 CubitStatus make_point_curves( RefFace* ref_face, 00253 DLIList<CubitVector> &position, 00254 DLIList<RefVertex*> &new_vertices); 00255 00256 virtual ~PartitionTool(); 00257 00258 virtual CubitStatus can_remove( RefVertex* vertex ); 00259 virtual CubitStatus can_remove( RefEdge* edge ); 00260 virtual CubitStatus can_remove( RefFace* face ); 00261 00262 int get_faceting_tolerance() {return facetingTolerance;} 00263 00264 protected: 00265 00266 static PartitionTool* instance_; 00267 00268 PartitionTool(); 00269 00270 DLIList<Surface*>* group_merged_surfaces( DLIList<RefFace*>& face_list, 00271 int& num_result_sets ); 00272 00273 00274 private: 00275 00276 void notify_partition( DLIList<RefEntity*> &partitioning_entities, 00277 BasicTopologyEntity *first_partitioned_entity, 00278 BasicTopologyEntity *second_partitioned_entity, 00279 BasicTopologyEntity *old_entity ); 00280 // notify observers that the old_entity was partitioned 00281 00282 00283 00284 CubitStatus commonGroupingEntities( BasicTopologyEntity* first_bte_ptr, 00285 BasicTopologyEntity* secnd_bte_ptr, 00286 GroupingEntity*& first_gpe_ptr, 00287 GroupingEntity*& second_gpe_ptr ) const; 00288 //R CubitStatus 00289 //R- CUBIT_SUCCESS/CUBIT_FAILURE 00290 //I first_bte_ptr/second_bte_ptr 00291 //I- Pointers to two BTEs of the same type. 00292 //O first_gpe_ptr/second_gpe_ptr 00293 //O- Child grouping entities of first_bte_ptr and second_bte_ptr, 00294 //O- respectively. 00295 //- This function searches for a grouping entity from each 00296 //- of the BTEs for which those GroupingEntites have atleast one 00297 //- common child. 00298 //- If there is only one pair of grouping entities which meet this 00299 //- criteria, they are passed back, and CUBIT_SUCCESS is returned. 00300 //- If there is more than one pair, an arbitrary pair is passed 00301 //- back, and CUBIT_FAILURE is returned. 00302 //- If no common GpEs are found, both pointers are passed back as 00303 //- NULL, and CUBIT_FAILURE is returned. 00304 00305 int facetingTolerance; 00306 00307 }; 00308 00309 //------------------------------------------------------------------------- 00310 // Purpose : Singleton class 00311 // 00312 // Special Notes : 00313 // 00314 // Creator : Jason Kraftcheck 00315 // 00316 // Creation Date : 12/13/98 00317 //------------------------------------------------------------------------- 00318 inline PartitionTool* PartitionTool::instance() 00319 { 00320 if( instance_ == NULL ) instance_ = new PartitionTool(); 00321 return instance_; 00322 } 00323 00324 #endif 00325
