cgma
00001 //------------------------------------------------------------------------- 00002 // Filename : SegmentedCurve.hpp 00003 // 00004 // Purpose : 00005 // 00006 // Special Notes : 00007 // 00008 // Creator : Jason Kraftcheck 00009 // 00010 // Creation Date : 04/18/02 00011 //------------------------------------------------------------------------- 00012 00013 #ifndef SEGMENTED_CURVE_HPP 00014 #define SEGMENTED_CURVE_HPP 00015 00016 #include "PartitionCurve.hpp" 00017 #include "PartitionLoop.hpp" 00018 #include "VGArray.hpp" 00019 00020 class PartitionSurface; 00021 class PartitionLump; 00022 class CubitSimpleAttrib; 00023 class CubitTransformMatrix; 00024 00025 class SegmentedCurve : public PartitionCurve 00026 { 00027 public: 00028 00029 PartitionCurve* split( double param ); 00030 CubitStatus combine( PartitionCurve* dead_curve ); 00031 00032 static SegmentedCurve* construct( const CubitSimpleAttrib& attrib, 00033 PartitionEntity* parent ); 00034 00035 SegmentedCurve( PartitionSurface* owning_surf, DLIList<CubitVector*>& segments ); 00036 SegmentedCurve( PartitionLump* owning_vol, DLIList<CubitVector*>& segments ); 00037 00038 virtual ~SegmentedCurve( ); 00039 00040 CubitBoolean is_linear( ); 00041 00042 virtual CubitStatus save( CubitSimpleAttrib& attrib ); 00043 00044 virtual CubitStatus get_point_direction( CubitVector& origin, 00045 CubitVector& direction ); 00046 00047 virtual CubitStatus get_center_radius( CubitVector& center, double& radius ); 00048 00049 virtual double length_from_u( double param1, double param2 ); 00050 00051 virtual CubitBoolean is_periodic( double& period); 00052 CubitBoolean is_periodic() const; 00053 00054 virtual CubitBoolean get_param_range( double& lower_bound, 00055 double& upper_bound ); 00056 00057 virtual CubitStatus closest_point( 00058 CubitVector const& location, 00059 CubitVector& closest_location, 00060 CubitVector* tangent_ptr = NULL, 00061 CubitVector* curvature_ptr = NULL, 00062 double* param = NULL); 00063 00064 virtual CubitStatus closest_point_trimmed( 00065 CubitVector const& from_pt, CubitVector& result_pt ); 00066 00067 00068 virtual double u_from_position (const CubitVector& position); 00069 00070 virtual CubitStatus position_from_u (double u_value, 00071 CubitVector& position); 00072 00073 virtual double u_from_arc_length ( double param, double length ); 00074 00075 virtual CubitBoolean is_position_on( const CubitVector &position ); 00076 00077 virtual double start_param(){ return 0.0; } 00078 virtual double end_param(){ return point_count() - 1; } 00079 00080 virtual CubitBox bounding_box() const; 00081 00082 virtual double measure(); 00083 00084 virtual CubitStatus get_segments( DLIList<CubitVector*>& points ); 00085 00086 virtual CubitStatus get_interior_extrema( DLIList<CubitVector*>& points, 00087 CubitSense& return_sense ); 00088 00089 virtual int point_count() const; 00090 00091 virtual CubitBoolean G1_discontinuous( double param, 00092 CubitVector* minus_tangent = NULL, 00093 CubitVector* plus_tangent = NULL ); 00094 00095 CubitPointContainment point_containment( const CubitVector& vect ); 00096 00097 CubitStatus get_graphics( GMem& result, 00098 double angle_tolerance=0, 00099 double distance_tolerance=0, 00100 double max_edge_length=0); 00101 00102 void reverse_sense(); 00103 00104 virtual void print_debug_info( const char* prefix, bool pss = true ) const; 00105 00106 00107 virtual void transform( const CubitTransformMatrix& ); 00108 00109 //R CubitStatus 00110 //O- true or false if spline is rational or not. 00111 //O- the degree of this spline 00112 //O- the control points 00113 //O- If rational, weight for each control point 00114 //O- whether underlying spline is reversed 00115 virtual CubitStatus get_spline_params( bool &rational, 00116 int °ree, 00117 DLIList<CubitVector> &cntrl_pts, 00118 DLIList<double> &cntrl_pt_weights, 00119 DLIList<double> &knots, 00120 bool &spline_is_reversed 00121 ) const; 00122 //R CubitStatus 00123 //O- center - ellipse center point 00124 //O- normal - normal of the plane of the ellipse 00125 //O- major_axis - major axis of the ellipse 00126 //O- radius_ratio - ratio of the length of the major to minor axis. 00127 virtual CubitStatus get_ellipse_params( CubitVector ¢er, 00128 CubitVector &normal, 00129 CubitVector &major_axis, 00130 double &radius_ratio ) const; 00131 protected: 00132 00133 int segment_from_u( double& u ); 00134 // Return the index of the segment corresponding to the 00135 // passed parameter value, and change the passed double 00136 // to be a parameter on the segment. Returns -1 to 00137 // indicate an invalid parameter value. 00138 00139 int closest_segment( CubitVector const& location, 00140 double* fraction_on_segment = NULL, 00141 CubitVector* closest_pt = NULL ); 00142 //Find the segment of the curve closest to the passed location. 00143 //The return value is the index of the start point of the 00144 //segment. Optional values passed back are the fraction along 00145 //the segment at which the passed location was closest, and the 00146 //corresponding position. 00147 00148 static double closest_point_on_segment( 00149 const CubitVector& segment_base, 00150 const CubitVector& segment_direction, 00151 const CubitVector& from_position ); 00152 //Find the closest location on a bounded segment defined by 00153 //segment_base and segment_direction to from_position. The 00154 //return value is the fraction along segment_direction from 00155 //segment_base. Or a parameter value in the range [0,1], where 00156 //zero is segment_base, and 1 is segment_base+segment_direction. 00157 00158 double segment_length( int segment_no ) const; 00159 00160 CubitVector position( int index ) const; 00161 00162 void normalize_periodic_parameter( double& u ); 00163 00164 private: 00165 SegmentedCurve( PartitionEntity* owning_vol, 00166 const CubitSimpleAttrib& attrib, 00167 DLIList<int>& pass_back_vertex_conn ); 00168 00169 SegmentedCurve( SegmentedCurve* split_from, int num_points ); 00170 00171 VGArray<CubitVector> point_list; 00172 }; 00173 00174 #endif
