cgma
00001 #ifndef COMPOSITE_ENGINE_HPP 00002 #define COMPOSITE_ENGINE_HPP 00003 00004 #include "CubitDefines.h" 00005 #include "GeometryDefines.h" 00006 #include "CubitString.hpp" 00007 #include <map> 00008 #include "DLIList.hpp" 00009 #include "IntermediateGeomEngine.hpp" 00010 #include "VGDefines.h" 00011 #include "TopologyBridge.hpp" 00012 00013 class TBPoint; 00014 class Curve; 00015 class Surface; 00016 class Lump; 00017 00018 class BodySM; 00019 class ShellSM; 00020 class LoopSM; 00021 class CoEdgeSM; 00022 00023 class CompositePoint; 00024 class CompositeCurve; 00025 class CompositeSurface; 00026 class CompositeLump; 00027 class CompositeBody; 00028 class CompositeCoEdge; 00029 class CompositeLoop; 00030 class CompositeShell; 00031 class Body; 00032 00033 class GeometryEntity; 00034 class TopologyBridge; 00035 class CubitSimpleAttrib; 00036 class CubitVector; 00037 class CubitTransformMatrix; 00038 00039 class CompositeEngine : public IntermediateGeomEngine 00040 { 00041 public: 00042 void get_all_curves_and_points(DLIList<TopologyBridge*> &tb_list, 00043 DLIList<Curve*> &curves, 00044 DLIList<TBPoint*> &points); 00045 bool is_composite(TBOwner *bridge_owner); 00046 bool is_composite(TopologyBridge *bridge); 00047 bool is_partition(TBOwner *bridge_owner); 00048 00049 virtual void remove_imprint_attributes_after_modify 00050 ( DLIList<BodySM*> &old_sms, 00051 DLIList<BodySM*> &new_sms ); 00052 virtual void push_named_attributes_to_curves_and_points 00053 ( DLIList<TopologyBridge*> &tb_list, const char *name_in); 00054 virtual void push_imprint_attributes_before_modify 00055 ( DLIList<BodySM*> &body_sms ); 00056 virtual void attribute_after_imprinting(DLIList<TopologyBridge*> &tb_list, 00057 DLIList<Body*> &old_bodies); 00058 00059 // This is a copy of the function in MergeTool with the difference that it 00060 // accepts a layer flag to dictate at which level the topology is traversed 00061 // (solid modeler level or virtual level). 00062 CubitBoolean about_spatially_equal( Curve *curve_1, Curve *curve_2, 00063 CubitSense &relative_sense, 00064 double tolerance_factor, 00065 int layer = TopologyBridge::MAX_TB_LAYER); 00066 virtual void remove_attributes_from_unmodifed_virtual(DLIList<TopologyBridge*> &bridges); 00067 00068 virtual ~CompositeEngine(); 00069 00070 static CompositeEngine& instance(); 00071 static void delete_instance(); 00072 00073 int level() const { return COMPOSITE_LAYER; } 00074 00075 CubitStatus import_geometry( DLIList<TopologyBridge*>& imported_geometry ); 00076 //- Recreate saved composite geometry and update the passed 00077 //- list. 00078 00079 int is_hidden(TopologyBridge *tb); 00080 00081 CubitStatus export_geometry( DLIList<TopologyBridge*>& geometry_to_save ); 00082 //- Save composite geometry and update the passed list such 00083 //- that it contains the underlying real geometry. 00084 00085 CompositeCurve* composite( Curve* survivor, 00086 Curve* dead, 00087 TBPoint* keep_point = 0, 00088 bool remove_partitions = false ); 00089 //- Combine two curves. The curves share both end vertices, 00090 //- the retained vertex can be specified in keep_point. 00091 00092 CompositePoint* stitch_points( TBPoint* point1, TBPoint* point2 ); 00093 CompositeCurve* stitch_curves( Curve* curve1, Curve* curve2 ); 00094 CompositeSurface* stitch_surfaces( Surface* surf, Surface* surf2 ); 00095 00096 CompositeCurve* remove_point( TBPoint* dead_point, 00097 bool remove_partitions = false, 00098 Curve* survivor = 0 ); 00099 //- Create a composite curve by removing the specified TBPoint. 00100 00101 00102 CompositeSurface* remove_curve( Curve* dead_curve, 00103 bool remove_partitions = false, 00104 Surface* survivor = 0 ); 00105 //- Create a composite surface by removing the specified Curve 00106 00107 CompositeLump* remove_surface( Surface* dead_surf, 00108 Surface* stitch_partner = 0, 00109 bool remove_partitions = false ); 00110 //- Create a composite lump by removing the specified Surface. 00111 //- Note: If stitch_partner is non-null, you need to call 00112 //- combine_bodies on the owning bodies first. 00113 00114 CompositeBody* combine_bodies( BodySM* body1, BodySM* body2 ); 00115 //- Combine two BodySMs into one Composite Body. 00116 00117 CubitStatus split_body( CompositeBody* body_to_split, 00118 DLIList<BodySM*>& resulting_bodies ); 00119 //- Split a CompositeBody into several Bodies 00120 //- as permissible by common child topology and 00121 //- existing real Bodies. 00122 00123 CubitStatus restore_point( TBPoint* point ); 00124 //- Split a composite curve by restoring the 00125 //- passed, previously removed TBPoint. 00126 00127 CubitStatus restore_curve( Curve* curve ); 00128 //- Split a composite surface by restoring the 00129 //- passed, previously removed Curve. 00130 00131 CubitStatus restore_surface( Surface* surface, Surface*& stitch_parnter ); 00132 //- Split a composite lump by restoring the 00133 //- passed, previously removed surface. 00134 00135 /* 00136 static void fix_up_query_results( DLIList<TopologyBridge*>& list, 00137 bool keep_hidden_entities = false ); 00138 //- Update TB-level query results obtained from calling 00139 //- get_parents/children_virt such that the results are at the 00140 //- "composite level" of the TB graph. 00141 */ 00142 static CubitSimpleAttrib 00143 find_attribute_by_name( TopologyBridge* bridge, const CubitString name ); 00144 //- Find the attribute with the specified name. 00145 //- Caller is responsible for freeing the returned, heap-allocated 00146 //- CubitSimpleAttrib object. 00147 00148 CompositePoint* replace_point( TBPoint* dead_point ); 00149 CompositeCurve* replace_curve( Curve* dead_curve ); 00150 CompositeSurface* replace_surface( Surface* surface ); 00151 CompositeLump* replace_lump( Lump* lump ); 00152 CompositeBody* replace_body( BodySM* body ); 00153 //- These methods are public for use by other clases internal 00154 //- to the VG code. 00155 00156 /**************** To be called by PartitionEngine *****************/ 00157 00158 TBPoint* insert_point(CompositeCurve* curve, double u); 00159 //- Partition a composite curve. 00160 00161 TBPoint* insert_point_curve( CompositeSurface* surface, 00162 const CubitVector& position ); 00163 00164 CubitStatus insert_curve( DLIList<Surface*>& surfaces, 00165 DLIList<CubitVector*>& polyline, 00166 DLIList<Surface*>& new_surfaces, 00167 DLIList<Curve*>& new_curves ); 00168 00169 void notify_deactivated (CompositeBody* body); 00170 void notify_deactivated (CompositeLump* volume); 00171 void notify_deactivated (CompositeSurface* surface); 00172 void notify_deactivated (CompositeCurve* curve); 00173 void notify_deactivated (CompositePoint* point); 00174 void clean_out_deactivated_geometry(); 00175 00176 CubitStatus restore_point_in_curve( TBPoint* point ); 00177 //- Restore a point hidden by a curve, splitting the 00178 //- curve. 00179 00180 CompositeCurve* restore_point_in_surface( TBPoint* point ); 00181 //- Restore a point hidden by a surface, creating a 00182 //- point-curve. 00183 00184 00185 CubitStatus translate( CompositeBody* body, const CubitVector& delta ); 00186 CubitStatus rotate( CompositeBody* body, const CubitVector& axis, double degrees ); 00187 CubitStatus scale( CompositeBody* body, const CubitVector& factors ); 00188 CubitStatus reflect( CompositeBody* body, const CubitVector& axis ); 00189 CubitStatus restore_transform( CompositeBody* body ); 00190 00191 CubitStatus translate( CompositeSurface* surface, const CubitVector& delta ); 00192 CubitStatus rotate( CompositeSurface* surface, const CubitVector& axis, double degrees ); 00193 CubitStatus scale( CompositeSurface* surface, const CubitVector& factors ); 00194 CubitStatus reflect( CompositeSurface* surface, const CubitVector& axis ); 00195 00196 CubitStatus translate( CompositeCurve* curve, const CubitVector& delta ); 00197 CubitStatus rotate( CompositeCurve* curve, const CubitVector& axis, double degrees ); 00198 CubitStatus scale( CompositeCurve* curve, const CubitVector& factors ); 00199 CubitStatus reflect( CompositeCurve* curve, const CubitVector& axis ); 00200 00201 CubitStatus notify_transform( TopologyBridge* bridge, 00202 const CubitTransformMatrix& xform ); 00203 00204 static void strip_attributes( TopologyBridge* bridge ); 00205 // remove all attributes related to composite geometry 00206 // from passed bridge. 00207 00208 void remove_attributes( DLIList<TopologyBridge*> &bridge_list ); 00209 //remove Composite attributes off of topology bridges 00210 virtual void remove_modified(DLIList<Surface*> &all_surfs, 00211 DLIList<Curve*> &all_curves, DLIList<TBPoint*> &all_pts); 00212 00213 void get_tbs_with_bridge_manager_as_owner( TopologyBridge *source_bridge, 00214 DLIList<TopologyBridge*> &tbs ); 00215 00216 00217 protected: 00218 00219 TBPoint* remove_composite( CompositePoint* point ); 00220 Curve* remove_composite( CompositeCurve* composite ); 00221 Surface* remove_composite( CompositeSurface* composite ); 00222 Lump* remove_composite( CompositeLump* composite ); 00223 BodySM* remove_composite( CompositeBody* composite ); 00224 00225 CubitStatus remove_partition_point( CompositePoint* point_owner ); 00226 CubitStatus remove_partition_curves( CompositeCurve* curve_owner ); 00227 00228 CompositePoint* destroy_point_curve( CompositeCurve* curve ); 00229 00230 CompositeCurve* combine( CompositeCurve* curve1, 00231 CompositeCurve* curve2, 00232 CompositePoint* keep_point = 0, 00233 bool remove_partitions = false ); 00234 CubitStatus split( CompositeCurve* curve, int after_index, 00235 Curve*& result1, Curve*& resutl2 ); 00236 00237 // Shell modification helpers for composite lump creation 00238 CompositeShell* split_shell( CompositeShell* shell ); 00239 void insert_nonmanifold_surfaces( DLIList<CompositeSurface*>& surfs, 00240 CompositeShell* shell1, 00241 CompositeShell* shell2 ); 00242 CubitStatus inside_shell( CompositeShell* const shell, 00243 CompositeSurface* const surf, 00244 bool& result ); 00245 00246 CubitStatus create_composites( DLIList<BodySM*>& ); 00247 CubitStatus create_composites( DLIList<Surface*>& ); 00248 CubitStatus create_composites( DLIList<Curve*>& ); 00249 CubitStatus create_composites( DLIList<TBPoint*>& ); 00250 //- Methods called by import(..) to re-create 00251 //- composites from saved attributes. 00252 00253 CubitStatus save( CompositePoint* ); 00254 CubitStatus save( CompositeCurve* ); 00255 CubitStatus save( CompositeSurface* ); 00256 CubitStatus save( CompositeLump* ); 00257 CubitStatus save( CompositeBody* ); 00258 00259 static void append_attrib( TopologyBridge* bridge, 00260 const CubitSimpleAttrib& attrib ); 00261 00262 00263 static CubitStatus find_coedges( CompositeSurface* surface, 00264 CompositeCurve* curve, 00265 CompositePoint* point, 00266 CompositeCoEdge*& previous, 00267 CompositeCoEdge*& next ); 00268 static CompositeCoEdge* find_next_point_coedge( 00269 CompositeSurface* const surface, 00270 CoEdgeSM* const coedge, 00271 CompositePoint* point, 00272 DLIList<CompositeCoEdge*>& point_coedges ); 00273 00274 static CompositeEngine* instance_; 00275 00276 private: 00277 00278 CompositeEngine(); 00279 00280 CompositeSurface* split_surface( CompositeSurface* surf_to_split, 00281 CompositeLoop* loop_on_surf, 00282 CompositeLoop* new_loop ); 00283 00284 CompositeLump* split_lump( CompositeShell* shell_to_split ); 00285 // If a shell had a previously-hidden surface inserted into 00286 // it due to the un-hiding of that surface, test if the 00287 // shell is split by the surface, and if so, split the shell 00288 // and corresponding lump. 00289 void process_curves_after_imprint(Curve *att_bridge, 00290 Curve *other_bridge, 00291 DLIList<BodySM*> &new_sms); 00292 void process_points_after_imprint(TBPoint *att_bridge, 00293 TBPoint *other_bridge, 00294 DLIList<BodySM*> &new_sms); 00295 00296 DLIList<TopologyBridge*> deactivatedList; 00297 }; 00298 00299 #endif
