cgma
00001 //- Class: SurfaceOverlapTool 00002 //- Description: Utilities to debug imprinting/merging problems 00003 //- Owner: Steve Storm 00004 //- Created: 22 October 1999 00005 00006 #ifndef SurfaceOverlapTool_HPP 00007 #define SurfaceOverlapTool_HPP 00008 00009 #include <map> 00010 #include "GMem.hpp" 00011 #include "AnalyticGeometryTool.hpp" 00012 #include "CGMGeomConfigure.h" 00013 #include "CurveOverlapFacet.hpp" 00014 #include "SurfaceOverlapFacet.hpp" 00015 #include "AbstractTree.hpp" 00016 00017 template <class X> class DLIList; 00018 class RefFace; 00019 00021 class CUBIT_GEOM_EXPORT SurfaceOverlapTool 00022 { 00023 00024 public : 00025 00027 CubitStatus find_overlapping_surfaces( DLIList<RefFace*> &ref_face_list, 00028 DLIList<RefEntity*> &faces_to_draw, 00029 bool filter_slivers = false ); 00030 00032 CubitStatus find_overlapping_surfaces( DLIList<Body*> &body_list, 00033 DLIList<RefEntity*> &faces_to_draw, 00034 bool filter_slivers = false ); 00035 00037 CubitStatus find_overlapping_surfaces( DLIList<RefFace*> &ref_face_list, 00038 DLIList<RefFace*> &ref_face_list1, 00039 DLIList<RefFace*> &ref_face_list2, 00040 DLIList<RefEntity*> &faces_to_draw, 00041 CubitBoolean show_messages = CUBIT_FALSE, 00042 bool filter_slivers = false); 00043 00045 CubitStatus find_overlapping_surfaces( DLIList<Body*> &body_list, 00046 DLIList<RefFace*> &ref_face_list1, 00047 DLIList<RefFace*> &ref_face_list2, 00048 DLIList<RefEntity*> &faces_to_draw, 00049 CubitBoolean show_messages = CUBIT_FALSE, 00050 bool filter_slivers = false); 00051 00053 CubitStatus find_candidate_surfaces_for_imprinting( DLIList<BodySM*> &body_list, 00054 DLIList<Surface*> &surface_list1, 00055 DLIList<Surface*> &surface_list2, 00056 double overlap_tol = -1.0, 00057 bool filter_slivers = false ); 00058 00059 // Searches for surfaces that overlap each other and are good 00060 // candidates for imprinting. It can even find those with gaps 00061 // between them (according to settings). 00062 // First method is for interactive use. They print messages and 00063 // draw the surfaces as it finds them, as dictated by settings. 00064 // The second method is for non-interactive use. It simply returns the 00065 // surface pairs in lists. Note that the same surface can occur 00066 // multiple times in the lists. The first list will contain sequential 00067 // surfaces - ie., if surface 1 overlaps with 2 other surfaces, list1 00068 // will contain surface 1, then surface 1, then the next surface, 00069 // etc.. If show_messages is CUBIT_TRUE, you will see "Finding surface 00070 // overlap...", and groupResults, listPairs and displayPairs will be 00071 // used, otherwise they will be false (default). 00072 00074 CubitStatus find_overlapping_curves( DLIList<Surface*> &surf_list, 00075 DLIList< DLIList<Curve*> *> &overlapping_curve_lists, 00076 std::map<Curve*, DLIList<Curve*>* > &curve_to_list_map, 00077 std::multimap<BodySM*, CubitVector> &body_point_imprint_map); 00078 00080 CubitStatus find_overlapping_curves( DLIList<Curve*> &curve_list, 00081 DLIList< DLIList<Curve*> *> &overlapping_curve_lists, 00082 std::map<Curve*, DLIList<Curve*>* > &curve_to_list_map, 00083 std::multimap<BodySM*, CubitVector> &body_point_imprint_map, double overlap_tol=-1.0); 00084 00086 CubitStatus find_overlapping_curves( DLIList<Body*> &bodies, 00087 std::multimap<RefEdge*, RefEdge*> &overlapping_edge_map, 00088 double maxgap = -1); 00089 00091 CubitStatus find_overlapping_curves( DLIList<BodySM*> &bodies, 00092 DLIList< DLIList<Curve*> *> &overlapping_curve_lists, 00093 std::map<Curve*, DLIList<Curve*>* > &curve_to_list_map, 00094 std::multimap<BodySM*, CubitVector> &body_vertex_imprint_map, 00095 double overlap_tol); 00096 00098 CubitStatus find_overlapping_curves( DLIList<RefFace*> &faces, 00099 std::multimap<RefEdge*, 00100 RefEdge*> &overlapping_edge_map, 00101 double maxgap = -1); 00102 00103 00105 CubitStatus find_overlapping_curves( DLIList<RefEdge*> &edgelist, 00106 std::multimap<RefEdge*, RefEdge*> &overlapping_edge_map, 00107 double maxgap = -1); 00108 00110 CubitStatus find_overlapping_curves( DLIList<RefEdge*> &edges1, DLIList<RefEdge*> &edges2, 00111 std::multimap<RefEdge*, RefEdge*> &overlapping_edge_map, 00112 double maxgap = -1); 00113 00115 CubitBoolean check_overlap( SurfaceOverlapFacet *facet1, SurfaceOverlapFacet *facet2, const double facet_compare_tol ); 00116 00118 CubitBoolean check_overlap( RefEdge *edge1, RefEdge *edge2, 00119 std::map<RefEdge*, DLIList<CurveOverlapFacet*>* > *facet_map, 00120 double *overlap_tol = NULL ); 00121 00123 CubitBoolean check_overlap( RefFace *ref_face_ptr1, 00124 RefFace *ref_face_ptr2, 00125 CubitBoolean abort, 00126 CubitBoolean draw_overlap = CUBIT_FALSE, 00127 double *overlap_area = NULL ); 00128 00130 CubitBoolean check_overlap( Curve *curve1, Curve *curve2, 00131 std::map<Curve*, DLIList<CurveOverlapFacet*>* > *facet_map, 00132 std::multimap<BodySM*, CubitVector > *body_point_imprint_map = NULL, 00133 double overlap_tol = -1.0); 00134 00136 CubitBoolean check_boundary_contact( 00137 DLIList<SurfaceOverlapFacet*> *facet_list1, 00138 DLIList<SurfaceOverlapFacet*> *facet_list2, 00139 AbstractTree<SurfaceOverlapFacet*> *a_tree, 00140 const double facet_compare_tol, 00141 const double tmp_overlap_tol ); 00142 00143 00144 // swap surfaces and facets to keep the smaller surface first 00145 CubitBoolean check_size_and_swap_surfs( 00146 Surface *&tmp_surf1, 00147 Surface *&tmp_surf2, 00148 const double tolerance, 00149 const double facet_tol, 00150 DLIList<SurfaceOverlapFacet*> *&facet_list1, 00151 DLIList<SurfaceOverlapFacet*> *&facet_list2, 00152 std::map<Surface*, AbstractTree<SurfaceOverlapFacet*>* > *&a_tree_map, 00153 AbstractTree<SurfaceOverlapFacet*> *&a_tree2 ); 00154 00155 // extract facets if not already available 00156 CubitBoolean extract_surf_facets( 00157 Surface *surface1, 00158 Surface *surface2, 00159 std::map<Surface*, DLIList<SurfaceOverlapFacet*>* > *facet_map, 00160 const double tolerance, 00161 const double facet_tol, 00162 DLIList<SurfaceOverlapFacet*> *&facet_list1, 00163 DLIList<SurfaceOverlapFacet*> *&facet_list2 ); 00164 00166 CubitBoolean calculate_tolerances_for_surf_intersection( 00167 Surface *tmp_surf1, 00168 Surface *tmp_surf2, 00169 DLIList<SurfaceOverlapFacet*> *facet_list1, 00170 DLIList<SurfaceOverlapFacet*> *facet_list2, 00171 std::map<Surface*, double > *area_map, 00172 double &facet_compare_tol, 00173 double &overlap_tolerance ); 00174 00176 CubitBoolean check_overlap( DLIList<SurfaceOverlapFacet*> *facet_list1, 00177 DLIList<SurfaceOverlapFacet*> *facet_list2, 00178 AbstractTree<SurfaceOverlapFacet*> *a_tree, 00179 const double facet_tol, 00180 const double tolerance ); 00181 00183 CubitBoolean check_overlap( DLIList<SurfaceOverlapFacet*> *facet_list1, 00184 DLIList<SurfaceOverlapFacet*> *facet_list2, 00185 AbstractTree<SurfaceOverlapFacet*> *a_tree, 00186 CubitBoolean abort, 00187 CubitBoolean draw_overlap, 00188 double *overlap_area ); 00189 00191 CubitBoolean draw_overlapping_surface_pair( RefFace *ref_face_1, 00192 RefFace *ref_face_2); 00193 00194 00196 void list_settings(); 00197 00198 unsigned short get_facet_ang_tol(); 00199 void set_facet_ang_tol( unsigned short angle_tol ); 00200 00201 00202 //Initialize all settings in this class 00203 static void initialize_settings(); 00204 00205 static int get_facet_ang_tol_setting(); 00206 static void set_facet_ang_tol_setting( int angle_tol ); 00207 00208 static double get_facet_abs_tol(); 00209 static void set_facet_abs_tol( double absolute_tol ); 00210 00211 static double get_gap_min(); 00212 static void set_gap_min( double val ); 00213 00214 static double get_gap_max(); 00215 static void set_gap_max( double val ); 00216 00217 static double get_angle_min(); 00218 static void set_angle_min( double val ); 00219 00220 static double get_angle_max(); 00221 static void set_angle_max( double val ); 00222 00223 static double get_overlap_tolerance(); 00224 static void set_overlap_tolerance( double val ); 00225 00226 static int get_normal_type(); // 00227 static void set_normal_type( int type ); // 00228 00229 static CubitString get_normal_type_setting(); 00230 static void set_normal_type_setting( CubitString type ); 00231 00232 static CubitBoolean get_group_results(); // 00233 static void set_group_results( CubitBoolean setting ); // 00234 00235 static CubitBoolean get_list_pairs(); // 00236 static void set_list_pairs( CubitBoolean setting ); // 00237 00238 static CubitBoolean get_display_pairs(); // 00239 static void set_display_pairs( CubitBoolean setting ); // 00240 00241 static int get_group_results_setting(); 00242 static void set_group_results_setting( int setting ); 00243 00244 static int get_list_pairs_setting(); 00245 static void set_list_pairs_setting( int setting ); 00246 00247 static int get_display_pairs_setting(); 00248 static void set_display_pairs_setting( int setting ); 00249 00250 static CubitBoolean get_imprint(); 00251 static void set_imprint( CubitBoolean setting ); 00252 00253 static CubitBoolean get_check_within_bodies(); 00254 static void set_check_within_bodies( CubitBoolean setting ); 00255 00256 static CubitBoolean get_check_across_bodies(); 00257 static void set_check_across_bodies( CubitBoolean setting ); 00258 CubitBoolean get_skip_facing_surfaces(); 00259 void set_skip_facing_surfaces( CubitBoolean setting ); 00260 static SurfaceOverlapTool* instance(); 00261 // Returns a static pointer to unique instance of this class. 00262 static void delete_instance() 00263 { 00264 if(instance_) 00265 delete instance_; 00266 instance_ = NULL; 00267 }; 00268 00269 ~SurfaceOverlapTool(); 00270 //- Destructor. 00271 00272 protected : 00273 00274 private : 00275 00276 00277 00278 CubitStatus find_overlapping_surfaces( DLIList<RefFace*> &ref_face_list, 00279 DLIList<RefFace*> &ref_face_list1, 00280 DLIList<RefFace*> &ref_face_list2, 00281 DLIList<RefEntity*> &pair_list, 00282 CubitBoolean list_pairs, 00283 int prog_step, 00284 bool filter_slivers = false); 00285 // Private workhorse function for finding the overlapping surfaces. Here 00286 // pair_list is a list of all the surfaces that were found that overlap. 00287 // If prog_step == -1 it does not step the progress bar. 00288 00289 double find_area_overlap( SurfaceOverlapFacet *facet1, SurfaceOverlapFacet *facet2, const double facet_compare_tol ); 00290 00291 00292 CubitBoolean check_surfs_for_imprinting( Surface *surface1, 00293 Surface *surface2, 00294 std::map<Surface*, DLIList<SurfaceOverlapFacet*>* > *facet_map, 00295 std::map<Surface*, double > *area_map, 00296 std::map<Surface*, AbstractTree<SurfaceOverlapFacet*>* > *a_tree_map, 00297 double overlap_tol=-1.0); 00298 00299 00300 //CubitStatus draw_facets( GMem* gMem, int color = 2 ); 00301 //void draw_triangle( Triangle3 &T, int color = 2 ); 00302 00303 CubitStatus imprint(DLIList<RefFace*> &ref_face_list1, 00304 DLIList<RefFace*> &ref_face_list2); 00305 //- Imprints the bodies containing the lists of surfaces. Also 00306 //- uses the edges imprinting rather than the normal imprint. 00307 00308 int num_descendants(Body *body); 00309 //- Counts the total number of descendants of the body. 00310 //- Only counts Ref* entities. 00311 00312 CubitStatus copy_edges_in_list(DLIList<RefEdge*> &old_list, 00313 DLIList<RefEdge*> &new_list ); 00314 //- copy's each of the edges in the old list, and puts the 00315 //- stand alone edges in the new list. 00316 //- NOTE: THESE ARE NEWLY CREATED EDGES AND SHOULD BE DELETED 00317 //- BY THE CALLING FUNCTION. 00318 00319 CubitStatus delete_edges_in_list(DLIList<RefEdge*> &edge_list); 00320 //- Deletes the RefEdges in the list via GeometryQueryTool. 00321 00322 static SurfaceOverlapTool* instance_; 00323 // Static pointer to unique instance of this class 00324 00325 SurfaceOverlapTool(); 00326 //- Constructor for the SurfaceOverlapTool object 00327 00333 static unsigned short facetAngTol; 00334 00339 static double facetAbsTol; 00340 00343 static double gapMin; 00344 static double gapMax; 00345 00347 00350 static double angleMin; 00351 static double angleMax; 00353 00356 static int normalType; // 1=any, 2=opposite, 3=same 00357 00359 static CubitBoolean groupResults; 00360 00362 static CubitBoolean listPairs; 00363 00365 static CubitBoolean displayPairs; 00366 00368 static CubitBoolean imprintResults; 00369 00372 static double overlapTolerance; 00373 00375 static CubitBoolean skipFacingSurfaces; 00376 00381 static CubitBoolean checkWithinBodies; 00382 00387 static CubitBoolean checkAcrossBodies; 00388 }; 00389 00390 inline 00391 void SurfaceOverlapTool::set_facet_ang_tol( unsigned short val ) 00392 {facetAngTol=val;} 00393 00394 inline 00395 double SurfaceOverlapTool::get_facet_abs_tol() 00396 {return facetAbsTol;} 00397 inline 00398 void SurfaceOverlapTool::set_facet_abs_tol( double val ) 00399 {facetAbsTol=val;} 00400 00401 inline 00402 double SurfaceOverlapTool::get_gap_min() 00403 {return gapMin;} 00404 inline 00405 void SurfaceOverlapTool::set_gap_min( double val ) 00406 {gapMin=val;} 00407 00408 inline 00409 double SurfaceOverlapTool::get_gap_max() 00410 {return gapMax;} 00411 inline 00412 void SurfaceOverlapTool::set_gap_max( double val ) 00413 {gapMax=val;} 00414 00415 inline 00416 double SurfaceOverlapTool::get_angle_min() 00417 {return angleMin;} 00418 inline 00419 void SurfaceOverlapTool::set_angle_min( double val ) 00420 {angleMin=val;} 00421 00422 inline 00423 double SurfaceOverlapTool::get_angle_max() 00424 {return angleMax;} 00425 inline 00426 void SurfaceOverlapTool::set_angle_max( double val ) 00427 {angleMax=val;} 00428 00429 inline 00430 double SurfaceOverlapTool::get_overlap_tolerance() 00431 {return overlapTolerance;} 00432 inline 00433 void SurfaceOverlapTool::set_overlap_tolerance( double val ) 00434 {overlapTolerance=val;} 00435 00436 inline 00437 int SurfaceOverlapTool::get_normal_type() 00438 {return normalType;} 00439 inline 00440 void SurfaceOverlapTool::set_normal_type( int type ) 00441 {normalType=type;} 00442 00443 inline 00444 CubitBoolean SurfaceOverlapTool::get_group_results() 00445 {return groupResults;} 00446 inline 00447 void SurfaceOverlapTool::set_group_results( CubitBoolean setting ) 00448 {groupResults=setting;} 00449 00450 inline 00451 CubitBoolean SurfaceOverlapTool::get_list_pairs() 00452 {return listPairs;} 00453 inline 00454 void SurfaceOverlapTool::set_list_pairs( CubitBoolean setting ) 00455 {listPairs=setting;} 00456 00457 inline 00458 CubitBoolean SurfaceOverlapTool::get_display_pairs() 00459 {return displayPairs;} 00460 inline 00461 void SurfaceOverlapTool::set_display_pairs( CubitBoolean setting ) 00462 {displayPairs=setting;} 00463 inline 00464 CubitBoolean SurfaceOverlapTool::get_imprint() 00465 {return imprintResults;} 00466 inline 00467 void SurfaceOverlapTool::set_imprint( CubitBoolean setting ) 00468 {imprintResults=setting;} 00469 inline 00470 CubitBoolean SurfaceOverlapTool::get_check_within_bodies() 00471 {return checkWithinBodies;} 00472 inline 00473 void SurfaceOverlapTool::set_check_within_bodies( CubitBoolean setting ) 00474 {checkWithinBodies=setting;} 00475 inline 00476 CubitBoolean SurfaceOverlapTool::get_check_across_bodies() 00477 {return checkAcrossBodies;} 00478 inline 00479 void SurfaceOverlapTool::set_check_across_bodies( CubitBoolean setting ) 00480 {checkAcrossBodies=setting;} 00481 inline 00482 CubitBoolean SurfaceOverlapTool::get_skip_facing_surfaces() 00483 {return skipFacingSurfaces;} 00484 inline 00485 void SurfaceOverlapTool::set_skip_facing_surfaces( CubitBoolean setting ) 00486 {skipFacingSurfaces=setting;} 00487 #endif 00488 00489 00490
