cgma
00001 //- Class: BoundingBoxTool 00002 //- Description: Class for bounding boxes (primarily for "tight" bounding boxes) 00003 //- Owner: Steve Storm 00004 //- Created: 06-October-2000 00005 00006 #ifndef BoundingBoxTool_HPP 00007 #define BoundingBoxTool_HPP 00008 00009 #include "CubitDefines.h" 00010 #include "CGMGeomConfigure.h" 00011 #include "DLIList.hpp" 00012 #include "CubitVector.hpp" 00013 00014 00015 class Body; 00016 class GMem; 00017 class CubitVector; 00018 class RefEntity; 00019 class RefVolume; 00020 class RefEdge; 00021 class RefFace; 00022 class RefVertex; 00023 00025 class CUBIT_GEOM_EXPORT BoundingBoxTool 00026 { 00027 00028 public : 00029 00033 static CubitStatus get_tight_bounding_box( DLIList<RefEntity*> &ref_entity_list, 00034 CubitVector ¢er, 00035 CubitVector axes[3], 00036 CubitVector &extension, 00037 double ang_facet_tol, 00038 double abs_facet_tol); 00039 00042 static CubitStatus get_axis_bounding_box( DLIList<RefEntity*> &ref_entity_list, 00043 CubitVector ¢er, 00044 CubitVector axes[3], 00045 CubitVector &extension ); 00046 00048 static CubitStatus get_corner_points( CubitVector ¢er, 00049 CubitVector axes[3], 00050 CubitVector &extension, 00051 CubitVector& p1, CubitVector& p2, 00052 CubitVector& p3, CubitVector& p4, 00053 CubitVector& p5, CubitVector& p6, 00054 CubitVector& p7, CubitVector& p8); 00055 00060 static CubitBoolean get_use_triangles(); 00061 static void set_use_triangles( CubitBoolean val ); 00062 00063 static int get_use_triangles_setting(); 00064 static void set_use_triangles_setting( int val ); 00065 00074 //- tessellations are always used, even if this parameter is false. 00075 static CubitBoolean get_use_curves(); 00076 static void set_use_curves( CubitBoolean val ); 00077 00078 static int get_use_curves_setting(); 00079 static void set_use_curves_setting( int val ); 00080 00088 static CubitBoolean get_use_vertices(); 00089 static void set_use_vertices( CubitBoolean val ); 00090 00091 static int get_use_vertices_setting(); 00092 static void set_use_vertices_setting( int val ); 00093 00094 00096 static void initialize_settings(); 00097 00098 protected : 00099 00100 ~BoundingBoxTool(); 00101 //- Destructor. 00102 00103 BoundingBoxTool(); 00104 //- Constructor for the BoundingBoxTool object 00105 00106 private : 00107 00108 static CubitStatus append_ref_entity_points( DLIList<RefEntity*> &ref_entity_list, 00109 DLIList<CubitVector*> &vec_list, 00110 double ang_tol, double abs_tol); 00111 static CubitStatus append_body_points( DLIList<Body*> &body_list, 00112 DLIList<CubitVector*> &vec_list, 00113 double ang_tol, double abs_tol ); 00114 static CubitStatus append_volume_points( DLIList<RefVolume*> &vol_list, 00115 DLIList<CubitVector*> &vec_list, 00116 double ang_tol, double abs_tol ); 00117 static CubitStatus append_curve_points( DLIList<RefEdge*> &ref_edge_list, 00118 DLIList<CubitVector*> &vec_list ); 00119 static CubitStatus append_vertex_points( DLIList<RefVertex*> &ref_vertex_list, 00120 DLIList<CubitVector*> &vec_list ); 00121 static CubitStatus append_surface_points( DLIList<RefFace*> &ref_face_list, 00122 DLIList<CubitVector*> &vec_list, 00123 double ang_tol, double abs_tol ); 00124 //- The "append" functions allocate memory for the vectors which 00125 //- must be freed by the calling code. 00126 00127 static CubitBoolean expand_groups_in_list( DLIList<RefEntity*> &ref_entity_list ); 00128 00129 00130 static CubitBoolean useTriangles; 00131 static CubitBoolean useCurves; 00132 static CubitBoolean useVertices; 00133 }; 00134 00135 00136 00137 #endif 00138 00139 00140
