cgma
00001 //------------------------------------------------------------------------- 00002 // Filename : CubitOctreeCell.hpp 00003 // 00004 // Purpose : A cell of the CubitOctree model is defined 00005 // 00006 // Creator : William Roshan Quadros 00007 // 00008 // Creation Date : 01/01/2003 00009 // 00010 // Owner : 00011 //------------------------------------------------------------------------- 00012 #ifndef CUBITOCTREECELL_H 00013 #define CUBITOCTREECELL_H 00014 00015 #include "DLIList.hpp" 00016 #include "CubitVector.hpp" 00017 00018 class CubitOctreeNode; 00019 class CubitOctree; 00020 class RefFace; 00021 class CubitBox; 00022 class CubitFacet; 00023 class CubitFacetEdge; 00024 class CubitPoint; 00025 class OctreeIntersectionData; 00026 class OctreeFacetPointData; 00027 00028 00029 class CubitOctreeCell 00030 { 00031 00032 public: 00033 CubitOctreeCell(){} 00034 CubitOctreeCell( CubitVector center, double dimension, int level, CubitOctreeCell *parent_cell ); 00035 //- Constructor 00036 00037 virtual ~CubitOctreeCell(); 00038 //- Distructor 00039 00040 void display( CubitOctree *ptr_octree, int opt); 00041 //- Display of cells 00042 00043 void display_color_wireframe( CubitOctree *ptr_octree); 00044 //- diaplay cell in wireframe by color coding size at node 00045 00046 void display_octreefacetpointdata( void ); 00047 //- Displays the facet point data contained in the list 00048 00049 void release_octreefacetpointdata( void ); 00050 //- Releases the facet point data stored at cells 00051 00052 void set_oct_grid_node(const int i, const int j, const int k, CubitOctreeNode *ptr_node ); 00053 00054 inline int get_depth( void ){ return depth; } 00055 //- returns depth 00056 00057 inline double get_dimension( void ){ return dimension; } 00058 //- returns the dimension 00059 00060 void set_child( int i, int j, int k, CubitOctreeCell *ptr_child_cell ); 00061 //- updates the child of the cell 00062 00063 inline CubitVector get_center( void ){ return mCenter; } 00064 //- returns the center of the cell 00065 00066 inline CubitOctreeNode *get_octree_grid_node( const int i, const int j, const int k ){ return cubitOctreeNode[i][j][k]; } 00067 //- returns the node of the cell 00068 00069 inline int id( void ){ return num; } 00070 //- returns the numbers 00071 00072 CubitOctreeCell * get_child( const int i, const int j, const int k ); 00073 //- returns the child at i,j,k 00074 00075 inline void set_leaf( bool type ){ leaf = type; } 00076 00077 CubitOctreeCell * find_leaf_octree_cell(const CubitVector &point ); 00078 //- Find the leaf cell 00079 00080 void subdivide_octree_based_on_point( CubitPoint *ptr_point ); 00081 //- subdivides the CubitOctree based on point ( either original point or centroid ) 00082 00083 bool is_leaf( void ){ return leaf; } 00084 //- returns the status of leaf 00085 00086 void distribute_facet_points_among_children( void ); 00087 // distributes the facet points and associated face among the children 00088 00089 int num_of_facet_point_data( void ){ return octreeFacetPointDataList.size(); } 00090 //- returns number of facet points and centroids 00091 00092 CubitBoolean append_list_item( OctreeFacetPointData *ptr_facet_point_data ); 00093 //- appends the arguments into the respective list 00094 00095 inline DLIList<OctreeFacetPointData*>* get_facet_point_data_list() 00096 { 00097 return &octreeFacetPointDataList; 00098 } 00099 00100 00101 inline void set_mark( CubitBoolean type ){ mark = type; } 00102 inline CubitBoolean get_mark( void ){ return mark; } 00103 00104 inline void set_visit( CubitBoolean type ){ visit = type; } 00105 inline CubitBoolean get_visit( void ){ return visit; } 00106 00107 CubitBoolean add_adjacent_unmarked_cells( DLIList< CubitOctreeCell *> &queue ); 00108 00109 CubitBoolean is_intersects_box(const CubitBox &box ); 00110 00111 CubitBoolean does_facet_intersect_octreecell( CubitFacet *ptr_facet ); 00112 00113 00114 void set_color_and_intersection_datas(CubitFacet *ptr_facet, RefFace *ptr_Ref_face, 00115 #ifdef USE_octree_BGMESH 00116 DLIList<CubitOctreeCell*> *greyCellList, 00117 #endif 00118 CubitSense surf_sense=CUBIT_FORWARD); 00119 //- if cell intersects supplied facet call this function to color cell grey and attached OctreeIntersectionDatas to its nodes 00120 //- function assumes that grid nodes of cell still have halfspace settings corresponding to the supplied facet 00121 00122 // The function assumes that nodes have half space information 00123 CubitBoolean does_contain_positive_and_negative_nodes(); 00124 00125 CubitBoolean is_facet_point_data_present( const CubitVector &coord ); 00126 CubitBoolean is_facet_point_data_present( OctreeFacetPointData *new_facet_point_data ); 00127 //- Currently CubitVector is passed and distance between existing points and coord is compared 00128 //- with SKL_EPSILON in determining if the coord already exists. 00129 //- To avoid SKL_EPSILON CubitPoint srl number can be used. This function is currently not used. 00130 00131 CubitBoolean interpolate_grey_octreecell_node( void ); 00132 //- Finds size at WHITE nodes of GREY cells 00133 00134 void coloring( /*DLIList<CubitOctreeCell *> &grey_cell_list,*/ DLIList<CubitOctreeCell*> &black_cell_list); 00135 //- Colors the cells with WHITE (cell outside solid), BLACK (cell inside solid), and GREY (cell at the boundary) 00136 00137 // Trilienar interpolation 00138 // if number of nodes with zero size exceeds MAX_NUM_ZERO_SIZE_NODES 00139 // then average size is used instead of zero 00140 // Even GREY grid nodes are consided 00141 // If a node has zero size then that node is not considered 00142 // Therefore color is not important but the size 00143 double trilinear_interpolation(const CubitVector &point ); 00144 00145 double inverse_distance_interpolation(const CubitVector &point ); 00146 double min_size_interpolation(const CubitVector &point ); 00147 double min_distance_interpolation(const CubitVector &point ); 00148 00149 CubitStatus find_indices_in_parent( int *index ); 00150 00151 #ifndef NDEBUG 00152 void write_octreecell_sizing_info_file( FILE *pof, DLIList<CubitOctreeCell*> &stack ); 00153 #endif 00154 00155 /* 00156 void set_node( CubitOctreeNode *r_t_n_, CubitOctreeNode *r_t_f_, CubitOctreeNode *r_b_n_, CubitOctreeNode *r_b_f_, CubitOctreeNode *l_t_n_, CubitOctreeNode *l_t_f_, CubitOctreeNode *l_b_n_, CubitOctreeNode *l_b_f_ ); 00157 //- Sets the eight nodes of the cell 00158 00159 void set_octreecell( CubitOctreeCell *left_cell, CubitOctreeCell *right_cell, CubitOctreeCell *bottom_cell, CubitOctreeCell *top_cell, CubitOctreeCell *far_cell, CubitOctreeCell *near_cell ); 00160 //- Sets the six adjacent cells 00161 */ 00162 inline void mark_color( int type ){ color = type; } 00163 //- Cell contained completely inside the solid is call BLACK 00164 //- Cell contained completely outside the solid is calle WHITE 00165 //- Cell at the boundary with some nodes inside and others outside 00166 // are called GREY 00167 00168 inline int get_color() {return color;} 00169 //- Returns the color of cell 00170 00171 private: 00172 00173 CubitVector mCenter; 00174 //- Center of cell 00175 00176 double dimension; 00177 //- size of the CubitOctree cell 00178 00179 int depth; 00180 //- depth of the node 00181 00182 CubitBoolean leaf; 00183 //- to check leaf 00184 00185 int num; 00186 //- Serial number of cell 00187 00188 int color; 00189 //- WHITE (outside solid), BLACK (inside solid), and GREY (on boundary) 00190 00191 CubitBoolean mark; 00192 //- Mark used for visiting cell; 00193 00194 CubitBoolean visit; 00195 00196 //CubitOctreeNode* (*CubitOctreeNode)[2][2]; 00197 CubitOctreeNode* cubitOctreeNode[2][2][2]; 00198 00199 //- Eight corner nodes of cell 00200 00201 //CubitOctree *CubitOctree; 00202 //- CubitOctree is currently not used 00203 00204 CubitOctreeCell *parent; 00205 CubitOctreeCell *children[2][2][2]; 00206 //- eight children 00207 00208 DLIList< OctreeFacetPointData *> octreeFacetPointDataList; 00209 //- Stores the facet points 00210 00211 DLIList<OctreeIntersectionData*> *myFacetList; 00212 00213 }; 00214 00215 #endif 00216 00217 //EOF 00218
