cgma
00001 // 00002 // File: CubitQuadFacetData.cpp 00003 // 00004 // Owner: sjowen 00005 // 00006 00007 #include "CubitQuadFacetData.hpp" 00008 #include "CubitPoint.hpp" 00009 #include "CubitFacetEdge.hpp" 00010 #include "CubitFacetEdgeData.hpp" 00011 #include "CubitFacet.hpp" 00012 #include "CubitFacetData.hpp" 00013 00014 //=========================================================================== 00015 // Function: CubitQuadFacetData 00016 // Purpose: constructor 00017 // Notes: defines a quad facet given two existing triangle facets. 00018 // The points on the facet are also passed in so the quad 00019 // can be oriented with respect to its triangles 00020 // Date: 4/11/01 00021 // Author: sjowen 00022 //=========================================================================== 00023 CubitQuadFacetData::CubitQuadFacetData( 00024 CubitFacet *tri_facets[2], 00025 CubitPoint *points[4] ) 00026 { 00027 myTriangleFacets[0] = tri_facets[0]; 00028 myTriangleFacets[1] = tri_facets[1]; 00029 00030 CubitBoolean found = CUBIT_FALSE; 00031 CubitPoint *pt; 00032 int ii, jj, kk; 00033 00034 for (jj=0; jj<2; jj++) 00035 { 00036 for (kk=0; kk<3; kk++) 00037 { 00038 pt = myTriangleFacets[jj]->point(kk); 00039 found = CUBIT_FALSE; 00040 for (ii=0; ii<4 && !found; ii++) 00041 { 00042 if (points[ii] == pt) 00043 { 00044 triToQuadIndex[jj][kk] = ii; 00045 found = CUBIT_TRUE; 00046 } 00047 } 00048 00049 // If assertion occurs, the that points passed to the constructor do 00050 // not match the points on the triangle facets 00051 00052 assert(found == CUBIT_TRUE); 00053 } 00054 } 00055 } 00056 00057 //=========================================================================== 00058 // Function: CubitQuadFacetData 00059 // Purpose: constructor 00060 // Notes: defines a quad facet given its ordered point array. 00061 // Two triangle facets are created 00062 // Date: 4/11/01 00063 // Author: sjowen 00064 //=========================================================================== 00065 CubitQuadFacetData::CubitQuadFacetData( 00066 CubitPoint *point0, CubitPoint *point1, 00067 CubitPoint *point2, CubitPoint *point3 ) 00068 { 00069 00070 // The orientation of the triangles in the quad is arbitrary. 00071 // We may want to split based on some other criteria (ie. angles) 00072 00073 myTriangleFacets[0] = new CubitFacetData( point0, point1, point2 ); 00074 myTriangleFacets[1] = new CubitFacetData( point2, point3, point0 ); 00075 00076 triToQuadIndex[0][0] = 0; 00077 triToQuadIndex[0][1] = 1; 00078 triToQuadIndex[0][2] = 2; 00079 triToQuadIndex[1][0] = 2; 00080 triToQuadIndex[1][1] = 3; 00081 triToQuadIndex[1][2] = 0; 00082 } 00083 00084 //=========================================================================== 00085 // Function: CubitQuadFacetData 00086 // Purpose: constructor 00087 // Notes: defines a quad facet given its ordered edge array. 00088 // Two triangle facets are created 00089 // Date: 4/11/01 00090 // Author: sjowen 00091 //=========================================================================== 00092 CubitQuadFacetData::CubitQuadFacetData( 00093 CubitFacetEdge *e0, CubitFacetEdge *e1, 00094 CubitFacetEdge *e2, CubitFacetEdge *e3 ) 00095 { 00096 // create the diagonal edge 00097 00098 CubitPoint *p0 = e3->shared_point(e0); 00099 CubitPoint *p2 = e1->shared_point(e2); 00100 assert(p0 != NULL && p2 != NULL); 00101 00102 CubitFacetEdge *e4 = (CubitFacetEdge *) new CubitFacetEdgeData( p0, p2 ); 00103 00104 // create the triangles 00105 00106 myTriangleFacets[0] = new CubitFacetData( e1, e4, e0 ); 00107 myTriangleFacets[1] = new CubitFacetData( e3, e4, e2 ); 00108 00109 triToQuadIndex[0][0] = 0; 00110 triToQuadIndex[0][1] = 1; 00111 triToQuadIndex[0][2] = 2; 00112 triToQuadIndex[1][0] = 2; 00113 triToQuadIndex[1][1] = 3; 00114 triToQuadIndex[1][2] = 0; 00115 } 00116 00117 //=========================================================================== 00118 // Function: CubitQuadFacetData 00119 // Purpose: constructor 00120 // Notes: defines a quad facet given its ordered point array. 00121 // Two triangle facets are created 00122 // Date: 4/11/01 00123 // Author: sjowen 00124 //=========================================================================== 00125 CubitQuadFacetData::CubitQuadFacetData( 00126 CubitPoint *points[4] ) 00127 { 00128 00129 // The orientation of the triangles in the quad is arbitrary. 00130 // We may want to split based on some other criteria (ie. angles) 00131 00132 myTriangleFacets[0] = new CubitFacetData( points[0], points[1], points[2] ); 00133 myTriangleFacets[1] = new CubitFacetData( points[2], points[3], points[0] ); 00134 00135 triToQuadIndex[0][0] = 0; 00136 triToQuadIndex[0][1] = 1; 00137 triToQuadIndex[0][2] = 2; 00138 triToQuadIndex[1][0] = 2; 00139 triToQuadIndex[1][1] = 3; 00140 triToQuadIndex[1][2] = 0; 00141 } 00142 00143 //=========================================================================== 00144 // Function: ~CubitQuadFacetData 00145 // Purpose: destructor 00146 // Date: 4/11/01 00147 // Author: sjowen 00148 //=========================================================================== 00149 CubitQuadFacetData::~CubitQuadFacetData() 00150 { 00151 if (myTriangleFacets[0] == NULL && myTriangleFacets[1] == NULL) 00152 return; 00153 00154 assert(myTriangleFacets[0] && myTriangleFacets[1]); 00155 00156 // determine the dialogonal edge 00157 CubitPoint *p0 = this->point(0); 00158 CubitPoint *p2 = this->point(2); 00159 CubitFacetEdge *dedge = NULL; 00160 if (p0 != NULL && p2 != NULL) 00161 { 00162 dedge = p0->shared_edge(p2); 00163 } 00164 00165 // delete both triangles 00166 delete myTriangleFacets[0]; 00167 delete myTriangleFacets[1]; 00168 00169 // delete the dialgonal edge 00170 if (dedge != NULL) 00171 { 00172 delete dedge; 00173 } 00174 } 00175 00176 //=========================================================================== 00177 // Function: ~CubitQuadFacetData 00178 // Purpose: destructor 00179 // Date: 4/11/01 00180 // Author: sjowen 00181 //=========================================================================== 00182 void CubitQuadFacetData::remove_tri_facets( ) 00183 { 00184 myTriangleFacets[0] = NULL; 00185 myTriangleFacets[1] = NULL; 00186 } 00187 00188 //=========================================================================== 00189 // Function: points 00190 // Purpose: get the points from the facet 00191 // Date: 4/11/01 00192 // Author: sjowen 00193 //=========================================================================== 00194 void CubitQuadFacetData::points( 00195 CubitPoint *thepoints[4] ) 00196 { 00197 00198 thepoints[triToQuadIndex[0][0]] = myTriangleFacets[0]->point(0); 00199 thepoints[triToQuadIndex[0][1]] = myTriangleFacets[0]->point(1); 00200 thepoints[triToQuadIndex[0][2]] = myTriangleFacets[0]->point(2); 00201 thepoints[triToQuadIndex[1][0]] = myTriangleFacets[1]->point(0); 00202 thepoints[triToQuadIndex[1][1]] = myTriangleFacets[1]->point(1); 00203 thepoints[triToQuadIndex[1][2]] = myTriangleFacets[1]->point(2); 00204 } 00205 00206 //=========================================================================== 00207 // Function: point 00208 // Purpose: get the point from the facet 00209 // Date: 11/28/2002 00210 // Author: sjowen 00211 //=========================================================================== 00212 CubitPoint *CubitQuadFacetData::point( int index ) 00213 { 00214 int ii, jj; 00215 for (ii=0; ii<2; ii++) 00216 { 00217 for (jj=0; jj<3; jj++) 00218 { 00219 if (triToQuadIndex[ii][jj] == index) 00220 { 00221 return myTriangleFacets[ii]->point(jj); 00222 } 00223 } 00224 } 00225 assert(0); // index is probably out of range 00226 return NULL; 00227 } 00228 00229 //=========================================================================== 00230 // Function: edge 00231 // Purpose: get the edge from the facet 00232 // Date: 11/28/2002 00233 // Author: sjowen 00234 //=========================================================================== 00235 CubitFacetEdge *CubitQuadFacetData::edge( int index ) 00236 { 00237 int ii, jj; 00238 CubitPoint *p0 = NULL; 00239 CubitPoint *p1 = NULL; 00240 int index1 = (index + 1) % 4; 00241 for (ii=0; ii<2; ii++) 00242 { 00243 for (jj=0; jj<3; jj++) 00244 { 00245 if (triToQuadIndex[ii][jj] == index) 00246 { 00247 p0 = myTriangleFacets[ii]->point(jj); 00248 } 00249 else if ( triToQuadIndex[ii][jj] == index1 ) 00250 { 00251 p1 = myTriangleFacets[ii]->point(jj); 00252 } 00253 } 00254 } 00255 assert(p0 != NULL && p1 != NULL); // index is probably out of range 00256 00257 return p0->shared_edge( p1 ); 00258 } 00259 00260 00261 //=========================================================================== 00262 // Function: get_tri_facet 00263 // Purpose: return the underlying triangle of which the point_ptr is a vertex 00264 // Date: 11/28/2002 00265 // Author: sjowen 00266 //=========================================================================== 00267 CubitFacet *CubitQuadFacetData::get_tri_facet_at_point( CubitPoint *point_ptr ) 00268 { 00269 int ii, jj; 00270 for (ii=0; ii<2; ii++) 00271 { 00272 for (jj=0; jj<3; jj++) 00273 { 00274 if (myTriangleFacets[ii]->point(jj) == point_ptr) 00275 { 00276 return myTriangleFacets[ii]; 00277 } 00278 } 00279 } 00280 assert(0); // point isn't on facet 00281 return NULL; 00282 } 00283
