cgma
00001 //------------------------------------------------------------------------- 00002 // Filename : RefEntity.hpp 00003 // 00004 // Purpose : This file consolidates functionality from several 00005 // base classes in CUBIT, and serves as the entry point 00006 // to geometry from the meshing and other CUBIT classes 00007 // 00008 // Creator : Tim Tautges (in it's new state) 00009 // 00010 // Creation Date : 9/99 00011 //------------------------------------------------------------------------- 00012 00013 #ifndef REFENTITY_HPP 00014 #define REFENTITY_HPP 00015 00016 // ********** BEGIN CUBIT INCLUDES ********** 00017 #include "CubitObservable.hpp" 00018 #include "CubitEntity.hpp" 00019 #include "CubitAttribUser.hpp" 00020 #include "CubitColor.hpp" 00021 #include "ToolDataUser.hpp" 00022 #include "DagType.hpp" 00023 #include "GeometryEvent.hpp" 00024 00025 // ********** END CUBIT INCLUDES ********** 00026 00027 // ********** BEGIN FORWARD DECLARATIONS ********** 00028 00029 class CubitString; 00030 template <class X> class DLIList; 00031 class RefVolume; 00032 class RefFace; 00033 class RefEdge; 00034 class RefVertex; 00035 class RefEntity; 00036 class MeshEntity; 00037 class CubitEntity; 00038 00039 class Body; 00040 class RefGroup; 00041 class RefEdge; 00042 class RefFace; 00043 class RefVolume; 00044 class RefVertex; 00045 00046 // ********** END FORWARD DECLARATIONS ********** 00047 00048 // ********** BEGIN MACRO DEFINITIONS ********** 00049 // ********** END MACRO DEFINITIONS ********** 00050 00051 // ********** BEGIN ENUM DEFINITIONS ********** 00052 00053 enum AutoMergeStatus { 00054 AUTO_MERGE_AUTO = 2, 00055 AUTO_MERGE_ON = 1, 00056 AUTO_MERGE_OFF = 0 00057 }; 00058 00059 00060 // ********** END ENUM DEFINITIONS ********** 00062 class CUBIT_GEOM_EXPORT RefEntity: public CubitEntity, 00063 public CubitObservable, 00064 public ToolDataUser, 00065 public CubitAttribUser 00066 { 00067 public: 00068 00069 RefEntity() ; 00070 //- The default constructor 00071 00072 virtual ~RefEntity (); 00073 //- A pure virtual destructor - this ensures that the class is 00074 //- non-instantiable. 00075 00077 static const char* get_ref_class_name(const std::type_info& ref_type); 00078 00080 static RefEntity* get_by_name(const CubitString& name); 00081 00083 virtual CubitString entity_name() const; 00084 00086 CubitStatus entity_name (CubitString name); 00087 00089 void entity_names(DLIList<CubitString> &names) const; 00090 00092 int num_names() const; 00093 00096 CubitStatus generate_default_name ( CubitString &name ); 00097 00099 CubitStatus assign_default_name( CubitBoolean user_setting = CUBIT_FALSE ); 00100 00101 CubitStatus remove_entity_name(CubitString const & name); 00102 CubitStatus remove_entity_names(); 00103 void merge_entity_names(RefEntity* dead_entity); 00104 void switch_entity_names(RefEntity *other_entity); 00105 00107 //- Generic flag for temporary use by algorithms. 00108 //- Value is volatile and may change unexpectedly. 00109 virtual void marked(int value); 00110 virtual int marked (); 00112 00114 virtual void is_mergeable(AutoMergeStatus val); 00115 00117 AutoMergeStatus merge_status() const; 00118 00120 bool is_mergeable(); 00121 00123 CubitBoolean is_merged(); 00124 // return true if this RefEntity has multiple TopologyBridges. 00125 00127 void update_auto_merge_state(); 00128 00130 virtual bool children_mergeable(); 00131 00135 virtual int can_modify(); 00136 00139 virtual int dimension() const; 00140 00143 virtual void get_child_ref_entities(DLIList<RefEntity*>& entity_list); 00144 00147 void get_all_child_ref_entities(DLIList<RefEntity*>& entity_list); 00148 00150 static void get_all_child_ref_entities(DLIList<RefEntity*>& input_list, 00151 DLIList<RefEntity*>& output_list ); 00152 00153 00158 static void gather_bdy_entities( DLIList<RefEntity*> &entity_list, 00159 DLIList<RefEntity*> &bdy_list ); 00160 00165 virtual void get_parent_ref_entities(DLIList<RefEntity*>& entity_list) = 0; 00166 00169 void get_all_parent_ref_entities(DLIList<RefEntity*>& entity_list, 00170 const int get_bodies = CUBIT_FALSE ); 00171 00174 static void change_to_parent_ref_entities( DLIList<RefEntity*>& ancestors ); 00175 00177 00178 00179 00180 00181 00182 00183 00184 00185 00186 00187 00188 00189 RefEntity *join( RefEntity* ref_entity_2, DLIList<RefEntity*> &join_set ); 00190 static RefEntity *join( DLIList<RefEntity*> &ref_entities, 00191 DLIList<RefEntity*> &join_set ); 00193 00195 //- like join, except returns the lower order entities common to the input 00196 //- entities 00197 RefEntity *meet( RefEntity* ref_entity_2, DLIList<RefEntity*> &join_set ); 00198 static RefEntity *meet( DLIList<RefEntity*> &ref_entities, 00199 DLIList<RefEntity*> &join_set ); 00201 00204 int valence(RefEntity *parent = NULL); 00205 00206 00208 //- Return TRUE if this is entity, or a direct child (parent) of entity. 00209 virtual CubitBoolean is_child(RefEntity *entity); 00210 virtual CubitBoolean is_parent(RefEntity *entity); 00212 00215 int num_parent_ref_entities(); 00216 00217 // void common_draw_label(int color, const int label_style); 00218 // //- Common code used for drawing labels. Actually, the entire 00219 // //- draw_label function could be implemented here if the 00220 // //- is_*_labeling_on() functions were virtual or better implemented. 00221 00222 //CubitBoolean is_free_ref_entity(); 00223 //- return CUBIT_TRUE if this ref entity has no non-virtual parents 00224 00226 virtual CubitVector center_point(); 00227 00235 virtual double measure(); 00236 00238 virtual CubitString measure_label(); 00239 00241 virtual int validate(); 00242 00244 virtual DagType dag_type() const = 0; 00245 00247 virtual const std::type_info& entity_type_info() const = 0; 00248 00250 static DagType dag_type( const std::type_info& ); 00251 00253 DagType get_parent_ref_entity_type() const; 00254 00256 DagType get_child_ref_entity_type() const; 00257 00259 static DagType get_parent_ref_entity_type( DagType child_type ); 00260 00262 static DagType get_child_ref_entity_type( DagType parent_type ); 00263 00266 void notify_sub_all_observers(const GeometryEvent::Type& event); 00267 00270 void comparison_found(RefEntity* partner); 00271 00278 void add_compare_data(RefEntity* partner) ; 00279 00281 void remove_compare_data() ; 00282 00286 RefEntity* get_compare_partner() ; 00287 00288 //======== Change Code by RY of Cat, 5/7/99 11:08:12 AM ======== 00289 void get_related_entity_list(const std::type_info& related_entity_type, 00290 DLIList<RefEntity*>& entity_list); 00291 //- to parse group in <ref_entity> commands 00292 //======== Change End by RY of Cat, 5/7/99 11:08:12 AM ======== 00293 00295 virtual void set_id(int i ); 00296 00298 void set_id(int i, CubitBoolean emit_event ); 00299 00301 static const std::type_info& get_entity_type_info(const char* entity_type); 00302 00304 static DagType dag_type( const char* cli_type_name ); 00305 00307 virtual void color(int value); 00308 00310 virtual int color() const; 00311 00313 inline void local_tolerance( double value ){ localTolerance = value; } 00314 inline double local_tolerance( void ){ return localTolerance; } 00315 00316 protected : 00317 00318 int autoMergeStatus;//- Whether entity will participate 00319 //- in 'merge all XXX' operation. 00320 int markedFlag; //- Scratch flag for algorithm use. 00321 //- NOTE: should be Bit markedFlag: 8 ntfolwe 00322 Bit listFlag : 1; //- Scratch flag for low-level use 00323 00324 int mColor; // color of this entity 00325 00326 private: 00327 00328 RefEntity( const RefEntity& ); 00329 void operator=( const RefEntity& ); 00330 00331 void list_mark(int value); 00332 int list_mark(); 00333 //- Generic flag for marking whether an entity is in a list or not. 00334 //- For internal use by RefEntity. 00335 00336 // This local tolerance is used in tolerant imprinting 00337 // This local tolerance is set automatically by LocalToleranceTool class 00338 double localTolerance; 00339 00340 }; 00341 00342 // ********** BEGIN INLINE FUNCTIONS ********** 00343 00344 inline void 00345 RefEntity::marked(int value) 00346 {markedFlag = value;} 00347 00348 inline int 00349 RefEntity::marked() 00350 {return (int) markedFlag;} 00351 00352 inline void 00353 RefEntity::list_mark(int value) 00354 {listFlag = value;} 00355 00356 inline int 00357 RefEntity::list_mark() 00358 {return listFlag;} 00359 00360 // ********** END INLINE FUNCTIONS ********** 00361 00362 // ********** BEGIN FRIEND FUNCTIONS ********** 00363 // ********** END FRIEND FUNCTIONS ********** 00364 00365 // ********** BEGIN EXTERN FUNCTIONS ********** 00366 // ********** END EXTERN FUNCTIONS ********** 00367 00368 // ********** BEGIN HELPER CLASS DECLARATIONS ********** 00369 // ********** END HELPER CLASS DECLARATIONS ********** 00370 00371 template <> struct DLIListSorter<RefEntity*> 00372 { 00373 bool operator()(RefEntity* a, RefEntity* b) 00374 { 00375 if (a == NULL) 00376 { 00377 if(a == b) 00378 return false; 00379 else 00380 return true; 00381 } 00382 else if(b == NULL) 00383 { 00384 return false; 00385 } 00386 else if (a->id() < b->id()) 00387 { 00388 return true; 00389 } 00390 else if (a->id() > b->id()) 00391 { 00392 return false; 00393 } 00394 // equal id, sort on dimension 00395 return a->dimension() < b->dimension(); 00396 } 00397 }; 00398 00399 #endif 00400
