cgma
00001 #undef NDEBUG 00002 00003 #include <vector> 00004 00005 #include "InitCGMA.hpp" 00006 #include "CGMApp.hpp" 00007 #include "CubitCompat.hpp" 00008 #include "FacetQueryEngine.hpp" 00009 00010 #include "BodySM.hpp" 00011 #include "Body.hpp" 00012 #include "GeometryQueryTool.hpp" 00013 00014 #define STRINGIFY(S) XSTRINGIFY(S) 00015 #define XSTRINGIFY(S) #S 00016 #ifndef SRCDIR 00017 # define SRCDIR "." 00018 #endif 00019 00020 int main( int argc, char** argv ) { 00021 00022 std::vector<CubitString> args; 00023 CGMApp::instance()->startup(args); 00024 00025 const char* filename = STRINGIFY(SRCDIR) "/unit_cube.stl"; 00026 const char *out_file = "unit_cube.facet"; 00027 00028 CubitStatus status = InitCGMA::initialize_cgma(); 00029 if (CUBIT_SUCCESS != status) return 1; 00030 if (argc>=2) 00031 filename = argv[1]; 00032 if (argc>=3) 00033 out_file = argv[2]; 00034 00035 DLIList<CubitQuadFacet*> quad_facet_list; 00036 DLIList<CubitFacet*> tri_facet_list; 00037 DLIList<Surface*> surface_list; 00038 FacetQueryEngine* fqe = FacetQueryEngine::instance(); 00039 status = fqe->import_facets(filename, CUBIT_TRUE, 135, 1.e-6, 4, CUBIT_TRUE, 00040 CUBIT_FALSE, CUBIT_TRUE, CUBIT_TRUE, quad_facet_list, tri_facet_list, 00041 surface_list, STL_FILE); 00042 00043 // get bodies, then export to a facet file 00044 DLIList<Body*> bodies; 00045 GeometryQueryTool::instance()->bodies(bodies); 00046 PRINT_INFO(" num bodies: %d\n", bodies.size()); 00047 //BodySM* bodysm_ptr = body_ptr->get_body_sm_ptr(); 00048 DLIList<TopologyBridge*> model; 00049 for (int j=0; j<bodies.size(); j++) 00050 { 00051 BodySM* bodysm_ptr = bodies[j]->get_body_sm_ptr(); 00052 model.append( (TopologyBridge*)bodysm_ptr); 00053 } 00054 ModelExportOptions opts; 00055 00056 fqe->export_solid_model( 00057 model, out_file, FACET_TYPE, 00058 CubitString(), opts); 00059 PRINT_INFO( "converted stl %s to %s \n", filename, out_file); 00060 if (CUBIT_SUCCESS != status) return 1; 00061 00062 return 0; 00063 }
