cgma
00001 //------------------------------------------------------------------------- 00002 // Filename : OCCLump.hpp 00003 // 00004 // Purpose : 00005 // 00006 // Special Notes : 00007 // 00008 // Creator : David White 00009 // 00010 // Creation Date : 7/18/2000 00011 //------------------------------------------------------------------------- 00012 00013 #ifndef FACET_LUMP_HPP 00014 #define FACET_LUMP_HPP 00015 00016 // ********** BEGIN STANDARD INCLUDES ********** 00017 // ********** END STANDARD INCLUDES ********** 00018 00019 // ********** BEGIN CUBIT INCLUDES ********** 00020 #include "CubitDefines.h" 00021 #include "Lump.hpp" 00022 #include <stdio.h> 00023 #include "TopoDS_Solid.hxx" 00024 // ********** END CUBIT INCLUDES ********** 00025 00026 // ********** BEGIN FORWARD DECLARATIONS ********** 00027 class TopologyEntity; 00028 class BodySM; 00029 class OCCAttrib; 00030 00031 class OCCBody; 00032 class OCCShell; 00033 class OCCSurface; 00034 class OCCLoop; 00035 class OCCCoEdge; 00036 class OCCCurve; 00037 class OCCPoint; 00038 class BRepBuilderAPI_MakeShape; 00039 class BRepBuilderAPI_ModifyShape; 00040 class BRepAlgoAPI_BooleanOperation; 00041 class LocOpe_SplitShape; 00042 // ********** END FORWARD DECLARATIONS ********** 00043 00044 class OCCLump : public Lump 00045 { 00046 public: 00047 00048 OCCLump(TopoDS_Solid *theSolid, OCCSurface* surface = NULL, 00049 OCCShell* shell = NULL); 00050 00051 OCCSurface* my_sheet_surface() {return mySheetSurface;} 00052 OCCShell * my_shell() {return myShell;} 00053 void set_surface(OCCSurface* surface) {mySheetSurface = surface;} 00054 void set_shell(OCCShell* shell) {myShell = shell;} 00055 00056 virtual ~OCCLump(); 00057 //- The destructor 00058 00059 void add_body(BodySM* new_body) 00060 {myBodyPtr = new_body;} 00061 00062 TopoDS_Solid *get_TopoDS_Solid() 00063 {if(myTopoDSSolid && !myTopoDSSolid->IsNull()) assert (myTopoDSSolid->ShapeType() == TopAbs_SOLID); return myTopoDSSolid; } 00064 void set_TopoDS_Solid(TopoDS_Solid solid); 00065 00066 virtual void append_simple_attribute_virt(const CubitSimpleAttrib&); 00067 //R void 00068 //I 00069 //I- 00070 //I- that is to be appended to this OSME object. 00071 //- The purpose of this function is to append a 00072 //- attribute to the OSME. The is attached to each of the 00073 //- underlying solid model entities this one points to. 00074 00075 virtual void remove_simple_attribute_virt(const CubitSimpleAttrib&); 00076 //R void 00077 //I CubitSimpleAttrib* 00078 //I- A reference to a CubitSimpleAttrib object which is the object 00079 //I- that is to be removed to this OSME object. 00080 //- The purpose of this function is to remove a simple 00081 //- attribute from the OSME. The attribute is attached to each of the 00082 //- underlying solid model entities this one points to. 00083 00084 virtual void remove_all_simple_attribute_virt(); 00085 //R void 00086 //I- 00087 //- The purpose of this function is to remove all simple 00088 //- attributes from the OSME. 00089 00090 virtual CubitStatus get_simple_attribute(DLIList<CubitSimpleAttrib>&); 00091 virtual CubitStatus get_simple_attribute(const CubitString& name, 00092 DLIList<CubitSimpleAttrib>&); 00093 //R CubitSimpleAttrib* 00094 //R- the returned cubit simple attribute. 00095 //- The purpose of this function is to get the attributes 00096 //- of the geometry entity. The name is attached to the underlying solid 00097 //- model entity(ies) this one points to. 00098 //- MJP Note: 00099 //- This is the code that implements the requirement that names 00100 //- of VGI Entities propagate across solid model boolean 00101 //- operations. The success of this relies, of course, on the underlying 00102 //- solid modeler being able to propagate attributes across 00103 //- such operations on its entities. If it cannot, then "names" 00104 //- of VGI entities will not propagate. 00105 00106 virtual CubitBox bounding_box() const ; 00107 00108 virtual GeometryQueryEngine* 00109 get_geometry_query_engine() const; 00110 //R GeometryQueryEngine* 00111 //R- A pointer to the geometric modeling engine associated with 00112 //R- the object. 00113 //- This function returns a pointer to the geometric modeling engine 00114 //- associated with the object. 00115 00116 virtual CubitStatus merge( GeometryEntity* /*GEPtr*/) 00117 { 00118 PRINT_ERROR("BUG: In OCCLump::merge\n" 00119 " This function should not be called at all\n" 00120 " This is a Bug -- please report it!\n"); 00121 return CUBIT_FAILURE; 00122 } 00123 00124 virtual TopologyEntity* unmerge(DLIList<RefVolume*>) 00125 { 00126 PRINT_ERROR( "BUG: In OCCLump::unmerge\n" 00127 " This function should not be called\n" 00128 " This is a Bug -- please report it!\n" ); 00129 return (TopologyEntity*)NULL; 00130 } 00131 00132 virtual double measure(); 00133 //R double 00134 //R- The numeric value of the measure (its units depend on the dimension 00135 //R- of the RefEntity being "measured") 00136 //- A generic geometric extent function. 00137 //- Returns volume for Lump, area for Surface, length for Curve and 00138 //- 1.0 for Point 00139 00140 virtual void get_parents_virt( DLIList<TopologyBridge*>& parents ); 00141 virtual void get_children_virt( DLIList<TopologyBridge*>& children ); 00142 00143 BodySM* get_body() const; 00144 00145 inline void remove_body() {myBodyPtr = 0;} 00146 00147 CubitStatus mass_properties( CubitVector& centroid, double& volume ); 00148 00149 CubitPointContainment point_containment( const CubitVector &point ); 00150 00151 CubitStatus update_OCC_entity( BRepBuilderAPI_ModifyShape *aBRepTrsf, 00152 BRepAlgoAPI_BooleanOperation *op = NULL); 00153 static CubitStatus update_OCC_entity(TopoDS_Solid& old_shape, 00154 TopoDS_Shape& new_shape, 00155 BRepBuilderAPI_MakeShape *op, 00156 LocOpe_SplitShape* sp = NULL); 00157 protected: 00158 00159 private: 00160 BodySM *myBodyPtr; 00161 00162 TopoDS_Solid *myTopoDSSolid; 00163 00164 OCCSurface *mySheetSurface; 00165 OCCShell * myShell; 00166 } ; 00167 00168 00169 // ********** BEGIN INLINE FUNCTIONS ********** 00170 // ********** END INLINE FUNCTIONS ********** 00171 00172 // ********** BEGIN FRIEND FUNCTIONS ********** 00173 // ********** END FRIEND FUNCTIONS ********** 00174 00175 // ********** BEGIN EXTERN FUNCTIONS ********** 00176 // ********** END EXTERN FUNCTIONS ********** 00177 00178 #endif 00179
