cgma
00001 //------------------------------------------------------------------------- 00002 // Filename : Loop.hpp 00003 // 00004 // Purpose : Represents a loop of edges of a face of a model. 00005 // 00006 // Special Notes : 00007 // 00008 // Creator : Xuechen Liu 00009 // 00010 // Creation Date : 08/02/96 00011 // 00012 // Owner : Malcolm J. Panthaki 00013 //------------------------------------------------------------------------- 00014 00015 #ifndef LOOP_HPP 00016 #define LOOP_HPP 00017 00018 // ********** BEGIN STANDARD INCLUDES ********** 00019 // ********** END STANDARD INCLUDES ********** 00020 00021 // ********** BEGIN CUBIT INCLUDES ********** 00022 #include "CubitDefines.h" 00023 #include "GeometryDefines.h" 00024 #include "CubitBox.hpp" 00025 #include "GroupingEntity.hpp" 00026 // ********** END CUBIT INCLUDES ********** 00027 00028 // ********** BEGIN FORWARD DECLARATIONS ********** 00029 class CoEdge; 00030 class RefFace; 00031 class RefEdge; 00032 class RefVertex; 00033 class CubitVector; 00034 class LoopSM; 00035 // ********** END FORWARD DECLARATIONS ********** 00036 00037 class CUBIT_GEOM_EXPORT Loop : public GroupingEntity 00038 { 00039 public : 00040 00041 Loop() ; 00042 //- The default constructor. 00043 00044 Loop(LoopSM* OSMEPtr) ; 00045 //- The constructor with a pointer to an other solid model entity. 00046 00047 DagType dag_type() const { return DagType::loop_type(); } 00048 00049 LoopType loop_type() const; 00050 //R LoopType 00051 //- Gets the type of this loop. See LoopType enum for more details. 00052 00053 CubitStatus get_angle_metric(double& angle_metric); 00054 //R CubitStatus 00055 //R- CUBIT_SUCCESS/CUBIT_FAILURE 00056 //O angle_metric 00057 //O- Angle metric value 00058 //- Gets the angle metric for this Loop. The value of the angle 00059 //- metric returned is 00060 //- ( sum(interior_angles_at_vertices)/pi - n ). 00061 //- For planar faces this metric is 2.0 for internal 00062 //- Loops and -2.0 for 00063 //- external Loops. 00064 00065 CubitStatus ordered_ref_edges( DLIList<RefEdge*>& ordered_edge_list ); 00066 //R CubitStatus 00067 //R- CUBIT_SUCCESS/CUBIT_FAILURE 00068 //O ordered_edge_list 00069 //O- Ordered list of ref edges with respect to this loop. 00070 //- This function works through the co_edges to get the correct 00071 //- ref_edges with respect to this loop. 00072 00073 CubitStatus ordered_co_edges (DLIList<CoEdge*>& ordered_coedge_list); 00074 //R CubitStatus 00075 //R- CUBIT_SUCCESS/CUBIT_FAILURE 00076 //O ordered_edge_list 00077 //O- Ordered list of co edges with respect to this loop. 00078 //- This function is differnt than the simple co_edges function. 00079 //- You must use this function if you want the co_edges to respect 00080 //- the loop in their list. 00081 00082 RefFace* get_ref_face_ptr( ); 00083 //R RefFace* 00084 //R- A pointer to the parent RefFace. 00085 00086 CoEdge* get_co_edge_ptr( RefEdge* ref_edge_ptr ); 00087 //R CoEdge* 00088 //R- A pointer to a child CoEdge 00089 //I ref_edge_ptr 00090 //I- A pointer to a child RefEdge 00091 //- This method returns the child CoEdge connecting the 00092 //- passed RefEdge to this Loop. If the RefEdge occurs 00093 //- more than once in the Loop, only the first CoEdge 00094 //- encountered will be returned. 00095 00096 00097 CubitBox bounding_box(); 00098 //R CubitBox 00099 //R- The bounding box of this loop. 00100 //- This method returns the bounding box of a Loop 00101 //- as the union of the bounding boxes of its child 00102 //- RefEdges. 00103 00104 CubitStatus tangents( RefVertex* vertex_ptr, 00105 CubitVector& first_vector, 00106 CubitVector& second_vector ) ; 00107 //R CubitStatus 00108 //I veretx_ptr 00109 //I- A pointer to a vertex in this loop. 00110 //O first_vector 00111 //O- For the first edge on the loop which contains the passed 00112 //O- vertex, this is (an approximation of) the tangent of that 00113 //O- edge at the location of the vertex, pointing outwards from 00114 //O- the vertex. 00115 //O second_vector 00116 //O- For the second edge on the loop which contains the passed 00117 //O- vertex, this is (an approximation of) the tangent of that 00118 //O- edge at the location of the vertex, pointing outwards from 00119 //O- the vertex. 00120 //- Get the tangent vectors of the loop at the location of the 00121 //- passed vertex, pointing outwards from the vertex. 00122 //- 00123 //- NOTE: Both returned vectors point outward from the vertex. 00124 //- To have both tangents pointing in the direction of 00125 //- the loop, reverse first_vector. 00126 00127 CubitBoolean validate() ; 00128 //R CubitBoolean 00129 //R- CUBIT_TRUE if the Loop is topologically valid. 00130 //R- CUBIT_FALSE otherwise. 00131 //- Validate the Loop. 00132 //- Returns CubitFalse if: 00133 //- * The Loop has no CoEdges. 00134 //- * Any CoEdge has no child RefEdge. 00135 //- * Any CoEdge has an undefined sense (sense is CUBIT_UNKNOWN). 00136 //- * The Loop is not topologically closed. 00137 //- * The sense of a CoEdge does not correspond to 00138 //- the order of the vertices on its child RefEdge. 00139 //- * The Loop has two child RefEdges which form a topological 00140 //- figure-eight (there is only one child vertex of the Loop.) 00141 00142 LoopSM* get_loop_sm_ptr() const; 00143 00144 CubitBoolean about_spatially_equal( DLIList<CoEdge*>& other_loop_coedges, 00145 CubitSense relative_sense, 00146 double tolerance_factor = 1.0, 00147 CubitBoolean notify_refEntity 00148 = CUBIT_FALSE ); 00149 00150 00151 protected: 00152 00153 private: 00154 Loop( const Loop& ); 00155 void operator=( const Loop&); 00156 } ; 00157 00158 // ********** BEGIN INLINE FUNCTIONS ********** 00159 // ********** END INLINE FUNCTIONS ********** 00160 00161 // ********** BEGIN FRIEND FUNCTIONS ********** 00162 // ********** END FRIEND FUNCTIONS ********** 00163 00164 // ********** BEGIN EXTERN FUNCTIONS ********** 00165 // ********** END EXTERN FUNCTIONS ********** 00166 00167 #endif 00168
