cgma
00001 //------------------------------------------------------------------------- 00002 // Filename : OCCQueryEngine.cpp 00003 // 00004 // Purpose : Implementation of the OCCQueryEngine class. 00005 // This class provides OCC-based implementations 00006 // of various virtual functions in the GeometryQueryEngine 00007 // hierarchy. 00008 // 00009 // Special Notes : 00010 // 00011 // Creator : David R. White 00012 // 00013 // Creation Date : 7/17/00 00014 // 00015 //------------------------------------------------------------------------- 00016 #include <Standard_Version.hxx> 00017 #include <Standard_Stream.hxx> 00018 //#include <Standard_SStream.hxx> 00019 //#include <Standard_String.hxx> 00020 //#include <stringbuf> 00021 #if OCC_VERSION_MINOR < 5 00022 #include "TDataStd_Shape.hxx" 00023 typedef TDataStd_Shape TDataXtd_Shape; 00024 typedef Handle_TDataStd_Shape Handle_TDataXtd_Shape; 00025 #else 00026 #include "TDataXtd_Shape.hxx" 00027 #endif 00028 00029 #include "BRep_Tool.hxx" 00030 #include "gp_Pnt.hxx" 00031 #include "gp_Ax1.hxx" 00032 #include "gp_Ax2.hxx" 00033 #include "Geom_Surface.hxx" 00034 #include "Geom_Curve.hxx" 00035 #include "Interface_Static.hxx" 00036 #include "BRepBuilderAPI.hxx" 00037 #include "BRepBuilderAPI_Transform.hxx" 00038 #include "BRepBuilderAPI_GTransform.hxx" 00039 #include "BRepBuilderAPI_ModifyShape.hxx" 00040 #include "BRepBuilderAPI_MakeSolid.hxx" 00041 #include "OCCShapeAttributeSet.hpp" 00042 //#include "OCCBinToolsShapeSet.hpp" 00043 #include "BRepBuilderAPI_MakeShell.hxx" 00044 #include "GProp_GProps.hxx" 00045 #include "BRepGProp.hxx" 00046 #include "BRepTools_WireExplorer.hxx" 00047 #include "TColgp_Array1OfPnt.hxx" 00048 #include "Poly_Array1OfTriangle.hxx" 00049 #include "Poly_Triangle.hxx" 00050 #include "BRepAlgoAPI_BooleanOperation.hxx" 00051 #include "Handle_Poly_Triangulation.hxx" 00052 #include "GCPnts_TangentialDeflection.hxx" 00053 #include "BRepAdaptor_Curve.hxx" 00054 #include "TopExp.hxx" 00055 #ifdef HAVE_OCC_STEP 00056 # include "STEPControl_Reader.hxx" 00057 # include "STEPControl_Writer.hxx" 00058 # include "STEPControl_StepModelType.hxx" 00059 #endif 00060 #ifdef HAVE_OCC_IGES 00061 # include "IGESControl_Reader.hxx" 00062 # include "IGESControl_Writer.hxx" 00063 #endif 00064 #include "IFSelect_ReturnStatus.hxx" 00065 #include "BndLib_Add3dCurve.hxx" 00066 #include "Poly_Polygon3D.hxx" 00067 #include "Handle_Poly_Polygon3D.hxx" 00068 #include "BRepMesh_FastDiscret.hxx" 00069 #include "OCCQueryEngine.hpp" 00070 #include "OCCModifyEngine.hpp" 00071 #include "Poly_Triangulation.hxx" 00072 #include "TopologyEntity.hpp" 00073 #include "TopologyBridge.hpp" 00074 #include "RefEntity.hpp" 00075 #include "Body.hpp" 00076 #include "Shell.hpp" 00077 #include "Loop.hpp" 00078 #include "Chain.hpp" 00079 #include "RefVolume.hpp" 00080 #include "RefFace.hpp" 00081 #include "RefEdge.hpp" 00082 #include "RefVertex.hpp" 00083 #include "GeometryEntity.hpp" 00084 #include "DLIList.hpp" 00085 #include "CubitBox.hpp" 00086 #include "CubitString.hpp" 00087 #include "OCCPoint.hpp" 00088 #include "OCCCurve.hpp" 00089 #include "OCCCoEdge.hpp" 00090 #include "OCCLoop.hpp" 00091 #include "OCCSurface.hpp" 00092 #include "OCCShell.hpp" 00093 #include "OCCLump.hpp" 00094 #include "OCCBody.hpp" 00095 #include "OCCAttribSet.hpp" 00096 #include "GMem.hpp" 00097 #include "GeometryQueryTool.hpp" 00098 #include "CubitObserver.hpp" 00099 #include "GfxDebug.hpp" 00100 #include <stdio.h> 00101 #include <errno.h> 00102 00103 #include <BRep_Builder.hxx> 00104 #include <BRepTools.hxx> 00105 #include <TopExp_Explorer.hxx> 00106 #include <TopoDS.hxx> 00107 #include "TopoDS_Compound.hxx" 00108 #include <TopoDS_CompSolid.hxx> 00109 #include <TopoDS_Solid.hxx> 00110 #include <TopoDS_Shell.hxx> 00111 #include <TopoDS_Face.hxx> 00112 #include <TopoDS_Wire.hxx> 00113 #include <TopoDS_Edge.hxx> 00114 #include <TopoDS_Vertex.hxx> 00115 #include <Bnd_Box.hxx> 00116 #include <BndLib_AddSurface.hxx> 00117 #include <Precision.hxx> 00118 #include <BRepAdaptor_Surface.hxx> 00119 #include <TDF_ChildIterator.hxx> 00120 #include <BinTools_ShapeSet.hxx> 00121 #include "Standard_Boolean.hxx" 00122 00123 #include "TDF_Label.hxx" 00124 #include "TopTools_DataMapOfShapeInteger.hxx" 00125 #include "BRepExtrema_DistShapeShape.hxx" 00126 #include "BRepAlgoAPI_Section.hxx" 00127 #include "BRepBuilderAPI_MakeEdge.hxx" 00128 #include "TDocStd_Document.hxx" 00129 #include "TCollection_ExtendedString.hxx" 00130 #include "gp_Lin.hxx" 00131 using namespace NCubitFile; 00132 00133 #include "CGMEngineDynamicLoader.hpp" 00134 00135 00136 CGM_ENGINE_EXPORT_CREATE_GQE(OpenCascade) 00137 { 00138 return OCCQueryEngine::instance(); 00139 } 00140 00141 OCCQueryEngine* OCCQueryEngine::instance_ = NULL; 00142 00143 typedef std::map<int, TopologyBridge*>::value_type valType; 00144 typedef std::map<int, TDF_Label>::value_type labType; 00145 int OCCQueryEngine::iTotalTBCreated = 0; 00146 int OCCQueryEngine::total_coedges = 0; 00147 #define NUM_PTS_UV 30 00148 //================================================================================ 00149 // Description: 00150 // Author : 00151 // Date : 00152 //================================================================================ 00153 OCCQueryEngine* OCCQueryEngine::instance() 00154 { 00155 if (instance_ == NULL ) { 00156 instance_ = new OCCQueryEngine; 00157 } 00158 return instance_; 00159 } 00160 00161 //================================================================================ 00162 // Description: default constructor 00163 // Author : 00164 // Date : 00165 //================================================================================ 00166 OCCQueryEngine::OCCQueryEngine() 00167 { 00168 GeometryQueryTool::instance()->add_gqe( this ); 00169 OCCMap = new TopTools_DataMapOfShapeInteger; 00170 OccToCGM = new std::map<int, TopologyBridge*>; 00171 Shape_Label_Map = new std::map<int, TDF_Label>; 00172 BodyList = new DLIList<OCCBody*>; 00173 WireList = new DLIList<OCCLoop*>; 00174 SurfaceList = new DLIList<OCCSurface*>; 00175 CurveList = new DLIList<OCCCurve*>; 00176 CubitString name("Doc"); 00177 TCollection_ExtendedString xString((Standard_CString)name.c_str(), CUBIT_TRUE); 00178 MyDF = new TDocStd_Document(xString); 00179 mainLabel = MyDF->Main(); 00180 EXPORT_ATTRIB = CUBIT_TRUE; 00181 } 00182 00183 //================================================================================ 00184 // Description: destructor 00185 // Author : 00186 // Date : 00187 //================================================================================ 00188 OCCQueryEngine::~OCCQueryEngine() 00189 { 00190 instance_ = NULL; 00191 delete OCCMap; 00192 delete OccToCGM; 00193 delete Shape_Label_Map; 00194 delete BodyList; 00195 delete WireList; 00196 delete SurfaceList; 00197 delete CurveList; 00198 } 00199 00200 int OCCQueryEngine::get_major_version() 00201 { 00202 return OCC_VERSION_MAJOR; 00203 } 00204 00205 int OCCQueryEngine::get_minor_version() 00206 { 00207 return OCC_VERSION_MINOR; 00208 } 00209 00210 int OCCQueryEngine::get_subminor_version() 00211 { 00212 return OCC_VERSION_MAINTENANCE; 00213 } 00214 00215 CubitString OCCQueryEngine::get_engine_version_string() 00216 { 00217 return CubitString("OpenCascade ") + OCC_VERSION_STRING; 00218 } 00219 00220 //================================================================================ 00221 // Description: 00222 // Author : 00223 // Date : 00224 //================================================================================ 00225 const type_info& OCCQueryEngine::entity_type_info() const 00226 { 00227 return typeid(OCCQueryEngine); 00228 } 00229 00230 //================================================================================ 00231 // Description: reflect body about an axis 00232 // Author : sjowen 00233 // Date : 9/7/01 00234 //================================================================================ 00235 CubitStatus OCCQueryEngine::reflect( BodySM *bodysm, 00236 const CubitVector& axis) 00237 { 00238 OCCBody *body = CAST_TO(bodysm, OCCBody); 00239 if (!body) 00240 { 00241 PRINT_ERROR("Attempt to reflect OCC-based geometry Body. This body is not OCCBody."); 00242 return CUBIT_FAILURE; 00243 } 00244 00245 body->reflect( axis.x(), axis.y(), axis.z() ); 00246 00247 return CUBIT_SUCCESS; 00248 } 00249 00250 00251 //================================================================================ 00252 // Description: This function queries OCC for the necessary facets 00253 // information needed in facetting a RefFace. This 00254 // information is stored and output in gMem. The 00255 // number of triangles, points and facets are also 00256 // output. 00257 // normal_tolerance is in degree. 00258 // max_edge_length is not considered in getting graphics. 00259 // Author : Jane Hu 00260 // Date : 10/25/07 00261 //================================================================================ 00262 CubitStatus OCCQueryEngine::get_graphics( Surface* surface_ptr, 00263 GMem* g_mem, 00264 unsigned short normal_tolerance, 00265 double distance_tolerance, 00266 double max_edge_length) const 00267 { 00268 // Because this may be unnecessarily called twice, 00269 // say there is one triangle. 00270 if (!g_mem) 00271 return CUBIT_SUCCESS; 00272 00273 if(max_edge_length > get_sme_resabs_tolerance()) 00274 { 00275 PRINT_WARNING("OCC surface's tessilation doesn't consider edge_length.\n"); 00276 PRINT_WARNING("max_edge_length argument is ignored. \n"); 00277 } 00278 00279 OCCSurface *occ_surface_ptr = CAST_TO(surface_ptr, OCCSurface); 00280 TopoDS_Face * Topo_Face = occ_surface_ptr->get_TopoDS_Face(); 00281 00282 return get_graphics( Topo_Face, g_mem, normal_tolerance, distance_tolerance, max_edge_length ); 00283 } 00284 00285 CubitStatus OCCQueryEngine::get_graphics( TopoDS_Face* face_ptr, 00286 GMem* g_mem, 00287 unsigned short normal_tolerance, 00288 double distance_tolerance, 00289 double max_edge_length) const 00290 { 00291 if (!face_ptr) 00292 return CUBIT_FAILURE; 00293 00294 TopLoc_Location L; 00295 Handle_Poly_Triangulation facets = BRep_Tool::Triangulation(*face_ptr, L); 00296 00297 gp_Trsf tf = L.Transformation(); 00298 00299 if(facets.IsNull() || facets->NbTriangles() == 0) 00300 { 00301 //do triangulation 00302 if(distance_tolerance <= 0.0) 00303 distance_tolerance = 0.01; 00304 double angle = CUBIT_PI * normal_tolerance/180; 00305 BRepAdaptor_Surface asurface(*face_ptr); 00306 Bnd_Box aBox; 00307 BndLib_AddSurface::Add(asurface, Precision::Approximation(), aBox); 00308 BRepMesh_FastDiscret *myMesh = 00309 #if OCC_VERSION_MAJOR <= 6 && OCC_VERSION_MINOR < 8 00310 new BRepMesh_FastDiscret(distance_tolerance, *face_ptr, aBox, angle, Standard_True, Standard_True); 00311 #else 00312 new BRepMesh_FastDiscret(*face_ptr, distance_tolerance, angle, aBox, Standard_True, Standard_True); 00313 #endif 00314 if (myMesh != NULL) delete myMesh; 00315 facets = BRep_Tool::Triangulation(*face_ptr, L); 00316 if(facets.IsNull() || facets->NbTriangles() == 0) 00317 { 00318 PRINT_ERROR("Can't get triangulation representation for this surface.\n"); 00319 return CUBIT_FAILURE; 00320 } 00321 } 00322 //if necessary, the face tolerance can be returned. now, no use. 00323 //double tol = BRep_Tool::Tolerance(*Topo_Face); 00324 00325 int number_points = facets->NbNodes(); 00326 int number_triangles = facets->NbTriangles(); 00327 int number_facets = 4 * number_triangles; 00328 00329 Poly_Array1OfTriangle triangles(0, number_triangles-1); 00330 triangles.Assign( facets->Triangles() ); 00331 int *facetList = new int[number_facets]; 00332 //needs to test that N1, N2, N3 index are starting from 0 to number_points-1 00333 //otherwise needs to update either facetList or gPnts to make consistent. 00334 //It's possible also that N's starting from 1. 00335 int minN = 100; 00336 for (int i = 0; i < triangles.Length(); i++) 00337 { 00338 Poly_Triangle triangle = triangles.Value( i ); 00339 int N1, N2, N3; 00340 triangle.Get(N1, N2, N3); 00341 facetList[4 * i] = 3; 00342 facetList[4 * i + 1] = N1; 00343 minN = (minN < N1 ? minN : N1); 00344 facetList[4 * i + 2] = N2; 00345 minN = (minN < N2 ? minN : N2); 00346 facetList[4 * i + 3] = N3; 00347 minN = (minN < N3 ? minN : N3); 00348 } 00349 if(minN != 0) 00350 { 00351 //subtract the minN from the facetList for all i+1, i+2, i+3 points 00352 for (int i = 0; i < triangles.Length(); i++) 00353 { 00354 facetList[4 * i + 1] -= minN; 00355 facetList[4 * i + 2] -= minN; 00356 facetList[4 * i + 3] -= minN; 00357 } 00358 } 00359 g_mem->replace_facet_list( facetList, number_facets, number_facets); 00360 00361 TColgp_Array1OfPnt points(0, number_points-1); 00362 points.Assign(facets->Nodes()); 00363 GPoint *gPnts= new GPoint[number_points]; 00364 for (int i = 0; i < number_points ; i ++) 00365 { 00366 gp_Pnt gp_pnt = points.Value(i); 00367 if( !L.IsIdentity()) 00368 gp_pnt.Transform(tf); 00369 00370 GPoint gPnt; 00371 gPnt.x = gp_pnt.X(); 00372 gPnt.y = gp_pnt.Y(); 00373 gPnt.z = gp_pnt.Z(); 00374 gPnts[i] = gPnt; 00375 } 00376 g_mem->replace_point_list( gPnts, number_points, number_points ); 00377 00378 return CUBIT_SUCCESS; 00379 } 00380 00381 //================================================================================ 00382 // Description: This function queries OCC for the edge information 00383 // needed in facetting a RefEdge. This information is 00384 // stored and output in g_mem. 00385 // Author : Jane Hu 00386 // Date : 10/26/07 00387 //================================================================================ 00388 CubitStatus OCCQueryEngine::get_graphics( Curve* curve_ptr, 00389 GMem* gMem, 00390 double angle_tolerance, 00391 double distance_tolerance, 00392 double max_edge_length ) const 00393 { 00394 // get the OCCCurve. 00395 OCCCurve *occ_curve_ptr = CAST_TO(curve_ptr,OCCCurve); 00396 assert (gMem); 00397 00398 if(max_edge_length > get_sme_resabs_tolerance()) 00399 { 00400 PRINT_WARNING("OCC surface's tessilation doesn't consider edge_length.\n"); 00401 PRINT_WARNING("max_edge_length argument is ignored. \n"); 00402 } 00403 00404 TopoDS_Edge *edge_ptr = occ_curve_ptr->get_TopoDS_Edge(); 00405 00406 return get_graphics( edge_ptr, gMem, angle_tolerance, distance_tolerance, max_edge_length ); 00407 } 00408 00409 00410 00411 CubitStatus OCCQueryEngine::get_graphics( TopoDS_Edge* edge_ptr, 00412 GMem* gMem, 00413 double angle_tolerance, 00414 double distance_tolerance, 00415 double max_edge_length ) const 00416 { 00417 if (!edge_ptr) 00418 return CUBIT_FAILURE; 00419 00420 //do tessellation 00421 if(distance_tolerance <= 0.0) 00422 distance_tolerance = 0.2; 00423 if(angle_tolerance == 0.0) 00424 angle_tolerance = 5; 00425 double angle = CUBIT_PI * angle_tolerance/180; 00426 BRepAdaptor_Curve acurve(*edge_ptr); 00427 GCPnts_TangentialDeflection *myMesh = 00428 new GCPnts_TangentialDeflection(acurve, angle, 00429 distance_tolerance); 00430 if (myMesh == NULL) 00431 { 00432 PRINT_ERROR("Can't tessellate for this curve.\n"); 00433 return CUBIT_FAILURE; 00434 } 00435 int num_points = myMesh->NbPoints(); 00436 00440 GPoint *gPnts= new GPoint[num_points]; 00441 for (int i = 1; i <= num_points ; i ++) 00442 { 00443 gp_Pnt gp_pnt = myMesh->Value(i); 00444 GPoint gPnt; 00445 gPnt.x = gp_pnt.X(); 00446 gPnt.y = gp_pnt.Y(); 00447 gPnt.z = gp_pnt.Z(); 00448 gPnts[i-1] = gPnt; 00449 } 00450 gMem->replace_point_list( gPnts, num_points, num_points ); 00451 00452 delete myMesh; 00453 return CUBIT_SUCCESS; 00454 } 00455 00456 //================================================================================ 00457 // Description: Given surface and number of point on u and v parametric 00458 // direction, find the 3-d point locations 00459 // Author : Jane Hu 00460 // Date : 10/22/07 00461 //================================================================================ 00462 CubitStatus OCCQueryEngine::get_isoparametric_points(Surface* surface, 00463 int &nu, int &nv, 00464 GMem*& g_mem) const 00465 { 00466 OCCSurface* occ_surface = CAST_TO(surface, OCCSurface); 00467 TopoDS_Face* Tops_face = occ_surface->get_TopoDS_Face(); 00468 if (Tops_face == NULL) 00469 { 00470 PRINT_ERROR("This surface is not OCCSurface."); 00471 return CUBIT_FAILURE; 00472 } 00473 Handle_Geom_Surface HGeom_surface = BRep_Tool::Surface(*Tops_face); 00474 00475 double u1, u2, v1, v2; 00476 BRepTools::UVBounds(*Tops_face, u1, u2, v1, v2); 00477 00478 assert (nu > 1 && nv > 1); 00479 if(nu <= 1) 00480 nu = NUM_PTS_UV; 00481 if(nv <= 1) 00482 nv = NUM_PTS_UV; 00483 g_mem = new GMem[nu]; 00484 00485 00486 // calculate the nu curves 00487 double interval_u = (u2-u1)/double(nu-1); 00488 double interval_v = (v2 - v1)/(double)(nv - 1); 00489 00490 for (int i = 0; i < nu; i++) 00491 { 00492 Handle_Geom_Curve HGeom_curve = HGeom_surface->UIso(u1 + i * interval_u); 00493 g_mem[i].allocate_polylines(nv-1); 00494 for (int j = 0; j < nv; j++) 00495 { 00496 gp_Pnt pnt = HGeom_curve->Value(v1 + j * interval_v); 00497 g_mem[i].point_list()[j].x = pnt.X(); 00498 g_mem[i].point_list()[j].y = pnt.Y(); 00499 g_mem[i].point_list()[j].z = pnt.Z(); 00500 } 00501 g_mem[i].pointListCount = nv; 00502 } 00503 00504 return CUBIT_SUCCESS; 00505 } 00506 00507 CubitStatus OCCQueryEngine::get_u_isoparametric_points(Surface* surface, 00508 double v, int&n, 00509 GMem*& g_mem) const 00510 { 00511 OCCSurface* occ_surface = CAST_TO(surface, OCCSurface); 00512 TopoDS_Face* Tops_face = occ_surface->get_TopoDS_Face(); 00513 TopoDS_Face the_face; 00514 if (Tops_face == NULL) 00515 { 00516 PRINT_ERROR("This surface is not OCCSurface."); 00517 return CUBIT_FAILURE; 00518 } 00519 00520 the_face = *Tops_face; 00521 00522 Handle_Geom_Surface HGeom_surface = BRep_Tool::Surface(the_face); 00523 00524 //n must be given to calculate the points. 00525 if (n <= 1) 00526 n = NUM_PTS_UV; 00527 double u1, u2, v1, v2; 00528 HGeom_surface->Bounds(u1, u2, v1, v2); 00529 double interval = (u2 - u1)/(n -1); 00530 00531 Handle_Geom_Curve HGeom_curve = HGeom_surface->VIso(v); 00532 g_mem = new GMem; 00533 g_mem->allocate_polylines(n-1); 00534 for (int j = 0; j < n; j++) 00535 { 00536 gp_Pnt pnt = HGeom_curve->Value(u1 + j * interval); 00537 g_mem->point_list()[j].x = pnt.X(); 00538 g_mem->point_list()[j].y = pnt.Y(); 00539 g_mem->point_list()[j].z = pnt.Z(); 00540 } 00541 g_mem->pointListCount = n; 00542 00543 return CUBIT_SUCCESS; 00544 } 00545 00546 CubitStatus OCCQueryEngine::get_v_isoparametric_points(Surface* surface, 00547 double u, int&n, 00548 GMem*&g_mem) const 00549 { 00550 OCCSurface* occ_surface = CAST_TO(surface, OCCSurface); 00551 TopoDS_Face* Tops_face = occ_surface->get_TopoDS_Face(); 00552 TopoDS_Face the_face; 00553 if (Tops_face == NULL) 00554 { 00555 PRINT_ERROR("This surface is not OCCSurface."); 00556 return CUBIT_FAILURE; 00557 } 00558 00559 the_face = *Tops_face; 00560 00561 Handle_Geom_Surface HGeom_surface = BRep_Tool::Surface(the_face); 00562 00563 if (n <= 1) 00564 n = NUM_PTS_UV; 00565 double u1, u2, v1, v2; 00566 HGeom_surface->Bounds(u1, u2, v1, v2); 00567 double interval = (v2 - v1)/(n -1); 00568 00569 Handle_Geom_Curve HGeom_curve = HGeom_surface->UIso(u); 00570 g_mem = new GMem; 00571 g_mem->allocate_polylines(n-1); 00572 for (int j = 0; j < n; j++) 00573 { 00574 gp_Pnt pnt = HGeom_curve->Value(v1 + j * interval); 00575 g_mem->point_list()[j].x = pnt.X(); 00576 g_mem->point_list()[j].y = pnt.Y(); 00577 g_mem->point_list()[j].z = pnt.Z(); 00578 } 00579 g_mem->pointListCount = n; 00580 00581 return CUBIT_SUCCESS; 00582 } 00583 00584 //================================================================================ 00585 // Description: 00586 // Author : 00587 // Date : 00588 //================================================================================ 00589 CubitStatus OCCQueryEngine::transform_vec_position( CubitVector const& , 00590 BodySM *, 00591 CubitVector & ) const 00592 { 00593 //Nobody is using this function in yet. 00594 PRINT_ERROR("Option not supported for OCC based geometry.\n"); 00595 return CUBIT_FAILURE; 00596 } 00597 00598 //================================================================================ 00599 // Description: Calculate for intersection points between a curve and 00600 // a segment defined by two points or 00601 // between two curves or between a curve and a surface. 00602 // Author : Jane Hu 00603 // Date : 10/15/07 00604 //================================================================================ 00605 CubitStatus OCCQueryEngine::get_intersections( Curve* curve, 00606 CubitVector& point1, 00607 CubitVector& point2, 00608 DLIList<CubitVector>& intscts, 00609 CubitBoolean bounded, 00610 CubitBoolean closest) 00611 { 00612 OCCCurve *occ_curve = CAST_TO(curve, OCCCurve); 00613 if (occ_curve == NULL) 00614 { 00615 PRINT_ERROR("Option not supported for non-occ based geometry.\n"); 00616 return CUBIT_FAILURE; 00617 } 00618 00619 OCCPoint *pt1 = new OCCPoint(point1); 00620 OCCPoint *pt2 = new OCCPoint(point2); 00621 Curve *curve2 = 00622 OCCModifyEngine::instance()->make_Curve(pt1, pt2); 00623 if (curve2 == NULL) 00624 { 00625 PRINT_ERROR( "Unable to create OCC EDGE from points\n" ); 00626 return CUBIT_FAILURE; 00627 } 00628 00629 OCCCurve *occ_curve2 = CAST_TO(curve2, OCCCurve); 00630 CubitStatus stat = get_intersections(occ_curve, occ_curve2, intscts, bounded, closest); 00631 delete_solid_model_entities(occ_curve2); 00632 return stat; 00633 } 00634 00635 CubitStatus OCCQueryEngine::get_intersections( Curve* curve1, 00636 Curve* curve2, 00637 DLIList<CubitVector>& intscts, 00638 CubitBoolean bounded, 00639 CubitBoolean closest) 00640 { 00641 //If this function has shortcomes in using BRepExtrema_DistShapeShape, 00642 //look also at IntTools_EdgeEdge. 00643 OCCCurve *occ_curve1 = CAST_TO(curve1, OCCCurve); 00644 if (occ_curve1 == NULL) 00645 { 00646 PRINT_ERROR("Option not supported for non-occ based geometry.\n"); 00647 return CUBIT_FAILURE; 00648 } 00649 00650 OCCCurve *occ_curve2 = CAST_TO(curve2, OCCCurve); 00651 if (occ_curve2 == NULL) 00652 { 00653 PRINT_ERROR("Option not supported for non-occ based geometry.\n"); 00654 return CUBIT_FAILURE; 00655 } 00656 00657 //currently, there's no effect on 'closest' argument or bounded. 00658 BRepExtrema_DistShapeShape distShapeShape( 00659 *(occ_curve1->get_TopoDS_Edge()), 00660 *(occ_curve2->get_TopoDS_Edge())); 00661 00662 //distShapeShape.Perform(); 00663 if (!distShapeShape.IsDone()) 00664 { 00665 PRINT_ERROR("Cannot calculate the intersection points for the input curves.\n"); 00666 return CUBIT_FAILURE; 00667 } 00668 00669 if (distShapeShape.Value() < get_sme_resabs_tolerance()) 00670 { 00671 int numPnt = distShapeShape.NbSolution(); 00672 for (int i = 1; i <= numPnt; i++) 00673 { 00674 gp_Pnt aPoint = distShapeShape.PointOnShape1(i); 00675 00676 CubitVector cv(aPoint.X(), aPoint.Y(), aPoint.Z()); 00677 intscts.append(cv); 00678 } 00679 } 00680 return CUBIT_SUCCESS; 00681 } 00682 00683 CubitStatus 00684 OCCQueryEngine::get_intersections( Curve* curve, Surface* surface, 00685 DLIList<CubitVector>& intscts, 00686 CubitBoolean bounded ) 00687 { 00688 // There's no effect of bounded = false. 00689 OCCCurve *occ_curve = CAST_TO(curve, OCCCurve); 00690 if (occ_curve == NULL) 00691 { 00692 PRINT_ERROR("Option not supported for non-occ based geometry.\n"); 00693 return CUBIT_FAILURE; 00694 } 00695 00696 OCCSurface *occ_surface = CAST_TO(surface, OCCSurface); 00697 if (occ_surface == NULL) 00698 { 00699 PRINT_ERROR("Option not supported for non-occ based geometry.\n"); 00700 return CUBIT_FAILURE; 00701 } 00702 00703 //currently, there's no effect on 'closest' argument or bounded. 00704 BRepExtrema_DistShapeShape distShapeShape(*(occ_curve->get_TopoDS_Edge()), 00705 *(occ_surface->get_TopoDS_Face())); 00706 00707 //distShapeShape.Perform(); 00708 if (!distShapeShape.IsDone()) 00709 { 00710 PRINT_ERROR("Cannot calculate the intersection points for the input curve and surface.\n"); 00711 return CUBIT_FAILURE; 00712 } 00713 00714 if (distShapeShape.Value() < get_sme_resabs_tolerance()) 00715 { 00716 int numPnt = distShapeShape.NbSolution(); 00717 for (int i = 1; i <= numPnt; i++) 00718 { 00719 gp_Pnt aPoint = distShapeShape.PointOnShape1(i); 00720 00721 CubitVector cv(aPoint.X(), aPoint.Y(), aPoint.Z()); 00722 intscts.append(cv); 00723 } 00724 } 00725 00726 return CUBIT_SUCCESS; 00727 } 00728 00729 //================================================================================ 00730 // Description: Find extrema position on an entity list 00731 // Author : Jane Hu 00732 // Date : 10/30/07 00733 //================================================================================ 00734 CubitStatus 00735 OCCQueryEngine::entity_extrema( DLIList<GeometryEntity*> &ref_entity_list, 00736 const CubitVector *dir1, 00737 const CubitVector *dir2, 00738 const CubitVector *dir3, 00739 CubitVector &extrema, 00740 GeometryEntity *&extrema_entity_ptr ) 00741 { 00742 //in OCC, the api_entity_extrema is used to calculate "possible 00743 //self-intersecting sweeping and to align lofting sections" 00744 PRINT_ERROR("There's no such call in OCC "); 00745 return CUBIT_FAILURE; 00746 } 00747 00748 //================================================================================ 00749 // Description: Find distance between two entities and closest positions. 00750 // Author : Jane Hu 00751 // Date : 10/19/07 00752 //================================================================================ 00753 CubitStatus 00754 OCCQueryEngine::entity_entity_distance( GeometryEntity *entity1, 00755 GeometryEntity *entity2, 00756 CubitVector &pos1, CubitVector &pos2, 00757 double &distance ) 00758 { 00759 TopoDS_Shape * shape1; 00760 TopoDS_Shape * shape2; 00761 if ((shape1 = get_TopoDS_Shape_of_entity(entity1)) == NULL) 00762 { 00763 PRINT_ERROR( "problem occured getting OCC entity.\n" 00764 " Aborting.\n" ); 00765 return CUBIT_FAILURE; 00766 } 00767 00768 if( (shape2 = get_TopoDS_Shape_of_entity( entity2 )) == NULL ) 00769 { 00770 PRINT_ERROR( "problem occured getting OCC entity.\n" 00771 " Aborting.\n"); 00772 return CUBIT_FAILURE; 00773 } 00774 00775 BRepExtrema_DistShapeShape distShapeShape(*shape1, *shape2); 00776 //distShapeShape.Perform(); 00777 00778 if (!distShapeShape.IsDone()) 00779 { 00780 PRINT_ERROR( "problem occured getting distance between OCC entities.\n" 00781 " Aborting.\n"); 00782 return CUBIT_FAILURE; 00783 } 00784 00785 distance = distShapeShape.Value(); 00786 gp_Pnt pnt1 = distShapeShape.PointOnShape1(1); 00787 gp_Pnt pnt2 = distShapeShape.PointOnShape2(1); 00788 pos1 = CubitVector(pnt1.X(), pnt1.Y(), pnt1.Z()); 00789 pos2 = CubitVector(pnt2.X(), pnt2.Y(), pnt2.Z()); 00790 return CUBIT_SUCCESS; 00791 } 00792 00793 TopoDS_Shape* OCCQueryEngine::get_TopoDS_Shape_of_entity(TopologyBridge * entity_ptr) 00794 { 00795 if (OCCBody * occ_body = CAST_TO( entity_ptr, OCCBody)) 00796 { 00797 TopoDS_Shape* theShape; 00798 occ_body->get_TopoDS_Shape(theShape); 00799 return theShape; 00800 } 00801 00802 else if (OCCLump * lump_ptr = CAST_TO( entity_ptr,OCCLump)) 00803 { 00804 TopoDS_Solid * theSolid = lump_ptr->get_TopoDS_Solid(); 00805 if(theSolid) 00806 return (TopoDS_Shape*) theSolid; 00807 else 00808 { 00809 PRINT_ERROR("OCCLump without TopoDS_Solid at %s:%d.\n", __FILE__, __LINE__ ); 00810 return NULL; 00811 } 00812 } 00813 00814 else if( OCCSurface * surface_ptr = CAST_TO( entity_ptr, OCCSurface)) 00815 { 00816 TopoDS_Face *theFace = surface_ptr->get_TopoDS_Face(); 00817 if(!theFace) 00818 { 00819 PRINT_ERROR("OCCSurface without TopoDS_Face at %s:%d.\n", __FILE__, __LINE__ ); 00820 return NULL; 00821 } 00822 00823 return (TopoDS_Shape*) theFace; 00824 } 00825 00826 else if( OCCCurve * curve_ptr = CAST_TO( entity_ptr, OCCCurve)) 00827 { 00828 TopoDS_Edge *theEdge = curve_ptr->get_TopoDS_Edge(); 00829 if (!theEdge) 00830 { 00831 PRINT_ERROR("OCCCurve without TopoDS_Edge at %s:%d.\n", __FILE__, __LINE__ ); 00832 return NULL; 00833 } 00834 00835 return (TopoDS_Shape*) theEdge; 00836 } 00837 00838 else if( OCCPoint * point_ptr = CAST_TO( entity_ptr, OCCPoint)) 00839 { 00840 TopoDS_Vertex *thePoint = point_ptr->get_TopoDS_Vertex(); 00841 if (!thePoint) 00842 { 00843 PRINT_ERROR("OCCPoint without TopoDS_Point at %s:%d.\n", __FILE__, __LINE__ ); 00844 return NULL; 00845 } 00846 00847 return (TopoDS_Shape*) thePoint; 00848 } 00849 00850 PRINT_ERROR("Non-OCC TopologyBridge at %s:%d.\n", __FILE__, __LINE__ ); 00851 return NULL; 00852 00853 } 00854 //=========================================================================== 00855 //Function Name: save_temp_geom_file 00856 //Member Type: PUBLIC 00857 //Description: function called for save/restore to save temporary FACET file 00858 // If file is created, CubitString 'created_file' and 00859 // 'create_file_type' are set 00860 //Author: Corey Ernst 00861 //Date: 1/18/2003 00862 //=========================================================================== 00863 00864 CubitStatus OCCQueryEngine::save_temp_geom_file( DLIList<TopologyBridge*>& ref_entity_list, 00865 const char *file_name, 00866 const CubitString &cubit_version, 00867 CubitString &created_file, 00868 CubitString &created_file_type) 00869 { 00870 int size_before = ref_entity_list.size(); 00871 CubitString temp_filename(file_name); 00872 temp_filename += ".occ"; 00873 00874 ModelExportOptions M_O; 00875 if( export_solid_model( ref_entity_list, temp_filename.c_str(), OCC_TYPE, 00876 cubit_version, M_O ) == CUBIT_FAILURE ) 00877 { 00878 PRINT_ERROR( "Error occured while trying to save temporary OCC_BASED_GEOMETRY file\n"); 00879 return CUBIT_FAILURE; 00880 } 00881 00882 int size_after = ref_entity_list.size(); 00883 00884 if( size_before > size_after ) 00885 { 00886 created_file += temp_filename; 00887 created_file_type += "OCC"; 00888 } 00889 return CUBIT_SUCCESS; 00890 } 00891 00892 //=========================================================================== 00893 //Function Name:export_solid_model 00894 //Member Type: PUBLIC 00895 //Description: function called for save/restore to save temporary Brep file 00896 //Author: Jane Hu 00897 //Date: 11/16/2007 00898 //=========================================================================== 00899 00900 CubitStatus OCCQueryEngine::export_solid_model( DLIList<TopologyBridge*>& ref_entity_list, 00901 const char* file_name, 00902 Model_File_Type file_type, 00903 const CubitString &, 00904 ModelExportOptions &) 00905 { 00906 if( file_type != OCC_TYPE && 00907 file_type != STEP_TYPE && 00908 file_type != IGES_TYPE) 00909 { 00910 //PRINT_ERROR("The specified file type, %s, is not supported!\n", filetype ); 00911 return CUBIT_FAILURE; 00912 } 00913 00914 /* 00915 char* name = "write.iges.unit"; 00916 Standard_CString orig_unit; 00917 char* unit = "M"; 00918 if(strcmp( file_type, "IGES") == 0 && unit != NULL) 00919 { 00920 orig_unit = Interface_Static::CVal(name); 00921 Interface_Static::SetCVal (name, unit); 00922 } 00923 */ 00924 DLIList<OCCBody*> OCC_bodies; 00925 DLIList<OCCSurface*> OCC_surfaces; 00926 DLIList<OCCCurve*> OCC_curves; 00927 DLIList<OCCPoint*> OCC_points; 00928 00929 DLIList<TopologyBridge*> ref_entities_handled; 00930 00931 int i; 00932 //Collect all free entities (bodies, curves, vertices ) 00933 ref_entity_list.reset(); 00934 for(i=ref_entity_list.size(); i>0; i--) 00935 { 00936 TopologyBridge* ref_entity_ptr = ref_entity_list.get(); 00937 CubitBoolean handled = CUBIT_TRUE; 00938 00939 //if it is a Vertex 00940 if( OCCPoint* pt = CAST_TO( ref_entity_ptr, OCCPoint) ) 00941 OCC_points.append( pt ); 00942 00943 //if it is a Curve 00944 else if( OCCCurve* curve = CAST_TO( ref_entity_ptr, OCCCurve) ) 00945 OCC_curves.append( curve ); 00946 00947 //if it is a surface 00948 else if( OCCSurface* surf = CAST_TO( ref_entity_ptr, OCCSurface) ) 00949 OCC_surfaces.append( surf ); 00950 00951 //if it is a Body 00952 else if( OCCBody* body = CAST_TO( ref_entity_ptr, OCCBody ) ) 00953 OCC_bodies.append( body ); 00954 00955 else 00956 handled = CUBIT_FALSE; 00957 00958 if( handled == CUBIT_TRUE ) 00959 { 00960 ref_entities_handled.append( ref_entity_ptr ); 00961 ref_entity_list.change_to(NULL); 00962 } 00963 00964 ref_entity_list.step(); 00965 } 00966 00967 ref_entity_list.remove_all_with_value(NULL); 00968 00969 int free_body_count = OCC_bodies.size(); 00970 int free_curve_count = OCC_curves.size(); 00971 int free_point_count = OCC_points.size(); 00972 int free_surface_count = OCC_surfaces.size(); 00973 00974 //if nothing to write out...return 00975 if( free_body_count == 0 && free_surface_count == 0 && 00976 free_curve_count == 0 && free_point_count == 0) 00977 return CUBIT_SUCCESS; 00978 00979 //save the facets (geometry info ) 00980 CubitStatus status; 00981 00982 //write out topology and attributes 00983 status = write_topology( file_name, file_type, 00984 OCC_bodies, OCC_surfaces, 00985 OCC_curves, OCC_points ); 00986 /* 00987 //set the unit back. 00988 if(strcmp( file_type, "IGES") == 0 && unit != NULL) 00989 Interface_Static::SetCVal (name,orig_unit); 00990 */ 00991 if( status == CUBIT_FAILURE ) return CUBIT_FAILURE; 00992 00993 if( free_body_count || free_surface_count || 00994 free_curve_count || free_point_count ) 00995 PRINT_INFO( "\nExported:" ); 00996 00997 int flg = 0; 00998 00999 if( free_body_count ) 01000 { 01001 if( flg )PRINT_INFO( " " );else flg=1; 01002 if( free_body_count == 1 ) 01003 PRINT_INFO( "%4d OCC Body to %s\n", free_body_count, file_name ); 01004 else 01005 PRINT_INFO( "%4d OCC Bodies to %s\n", free_body_count, file_name ); 01006 } 01007 01008 if( free_surface_count ) 01009 { 01010 if( flg )PRINT_INFO( " " );else flg=1; 01011 if( free_surface_count == 1 ) 01012 PRINT_INFO( "%4d OCC Surface to %s\n", free_surface_count, file_name ); 01013 else 01014 PRINT_INFO( "%4d OCC Surface to %s\n", free_surface_count, file_name ); 01015 } 01016 01017 if( free_curve_count ) 01018 { 01019 if( flg )PRINT_INFO( " " );else flg=1; 01020 if( free_curve_count == 1 ) 01021 PRINT_INFO( "%4d OCC Curve to %s\n", free_curve_count, file_name ); 01022 else 01023 PRINT_INFO( "%4d OCC Curves to %s\n", free_curve_count, file_name ); 01024 } 01025 01026 if( free_point_count ) 01027 { 01028 if( flg )PRINT_INFO( " " );else flg=1; 01029 if( free_point_count == 1 ) 01030 PRINT_INFO( "%4d OCC Point to %s\n", free_point_count, file_name ); 01031 else 01032 PRINT_INFO( "%4d OCC Points to %s\n", free_point_count, file_name ); 01033 } 01034 PRINT_INFO( "\n" ); 01035 01036 return CUBIT_SUCCESS; 01037 } 01038 01039 CubitStatus OCCQueryEngine::export_solid_model( DLIList<TopologyBridge*>& ref_entity_list, 01040 char*& p_buffer, 01041 int& n_buffer_size, 01042 bool b_export_buffer) 01043 { 01044 DLIList<OCCBody*> OCC_bodies; 01045 DLIList<OCCSurface*> OCC_surfaces; 01046 DLIList<OCCCurve*> OCC_curves; 01047 DLIList<OCCPoint*> OCC_points; 01048 01049 DLIList<TopologyBridge*> ref_entities_handled; 01050 01051 int i; 01052 //Collect all free entities (bodies, curves, vertices ) 01053 ref_entity_list.reset(); 01054 for(i=ref_entity_list.size(); i>0; i--) 01055 { 01056 TopologyBridge* ref_entity_ptr = ref_entity_list.get(); 01057 CubitBoolean handled = CUBIT_TRUE; 01058 01059 //if it is a Vertex 01060 if( OCCPoint* pt = CAST_TO( ref_entity_ptr, OCCPoint) ) 01061 OCC_points.append( pt ); 01062 01063 //if it is a Curve 01064 else if( OCCCurve* curve = CAST_TO( ref_entity_ptr, OCCCurve) ) 01065 OCC_curves.append( curve ); 01066 01067 //if it is a surface 01068 else if( OCCSurface* surf = CAST_TO( ref_entity_ptr, OCCSurface) ) 01069 OCC_surfaces.append( surf ); 01070 01071 //if it is a Body 01072 else if( OCCBody* body = CAST_TO( ref_entity_ptr, OCCBody ) ) 01073 OCC_bodies.append( body ); 01074 01075 else 01076 handled = CUBIT_FALSE; 01077 01078 if( handled == CUBIT_TRUE ) 01079 { 01080 ref_entities_handled.append( ref_entity_ptr ); 01081 ref_entity_list.change_to(NULL); 01082 } 01083 01084 ref_entity_list.step(); 01085 } 01086 01087 ref_entity_list.remove_all_with_value(NULL); 01088 01089 int free_body_count = OCC_bodies.size(); 01090 int free_curve_count = OCC_curves.size(); 01091 int free_point_count = OCC_points.size(); 01092 int free_surface_count = OCC_surfaces.size(); 01093 01094 //if nothing to write out...return 01095 if( free_body_count == 0 && free_surface_count == 0 && 01096 free_curve_count == 0 && free_point_count == 0) 01097 return CUBIT_SUCCESS; 01098 01099 //save the facets (geometry info ) 01100 CubitStatus status; 01101 01102 //write out topology and attributes 01103 status = write_topology( p_buffer, n_buffer_size, 01104 b_export_buffer, 01105 OCC_bodies, OCC_surfaces, 01106 OCC_curves, OCC_points); 01107 if( status == CUBIT_FAILURE ) return CUBIT_FAILURE; 01108 01109 if( free_body_count || free_surface_count || 01110 free_curve_count || free_point_count ) 01111 { 01112 if (b_export_buffer) PRINT_INFO( "\nExported:" ); 01113 else PRINT_INFO( "\nSize checked:" ); 01114 } 01115 int flg = 0; 01116 01117 if( free_body_count ) 01118 { 01119 if( flg )PRINT_INFO( " " );else flg=1; 01120 if( free_body_count == 1 ) 01121 PRINT_INFO( "%4d OCC Body to buffer\n", free_body_count ); 01122 else 01123 PRINT_INFO( "%4d OCC Bodies to buffer\n", free_body_count ); 01124 } 01125 01126 if( free_surface_count ) 01127 { 01128 if( flg )PRINT_INFO( " " );else flg=1; 01129 if( free_surface_count == 1 ) 01130 PRINT_INFO( "%4d OCC Surface to buffer\n", free_surface_count ); 01131 else 01132 PRINT_INFO( "%4d OCC Surface to buffer\n", free_surface_count ); 01133 } 01134 01135 if( free_curve_count ) 01136 { 01137 if( flg )PRINT_INFO( " " );else flg=1; 01138 if( free_curve_count == 1 ) 01139 PRINT_INFO( "%4d OCC Curve to buffer\n", free_curve_count ); 01140 else 01141 PRINT_INFO( "%4d OCC Curves to buffer\n", free_curve_count ); 01142 } 01143 01144 if( free_point_count ) 01145 { 01146 if( flg )PRINT_INFO( " " );else flg=1; 01147 if( free_point_count == 1 ) 01148 PRINT_INFO( "%4d OCC Point to buffer\n", free_point_count ); 01149 else 01150 PRINT_INFO( "%4d OCC Points to buffer\n", free_point_count ); 01151 } 01152 PRINT_INFO( "\n" ); 01153 01154 return CUBIT_SUCCESS; 01155 } 01156 01157 void OCCQueryEngine::body_attributes_for_writing(DLIList<OCCBody*> &OCC_bodies, 01158 BRep_Builder &B, 01159 TopoDS_Compound &Co, 01160 DLIList<OCCLump*> &single_lumps, 01161 DLIList< DLIList<CubitSimpleAttrib>*> &lists) 01162 { 01163 //Add every shape to the compound 01164 OCCLump* lump = NULL; 01165 DLIList<CubitSimpleAttrib> body_csa_list; 01166 01167 for (int i = 0; i < OCC_bodies.size(); i++) 01168 { 01169 OCCBody* body = OCC_bodies.get_and_step(); 01170 TopoDS_Compound *shape = body->get_TopoDS_Shape(); 01171 if (shape == NULL || shape->IsNull()) //single lump or sheet or shell body 01172 { 01173 DLIList<OCCSurface*> surfaces = body->my_sheet_surfaces(); 01174 DLIList<OCCShell*> shells = body->shells(); 01175 DLIList<Lump*> lumps = body->lumps(); 01176 if(surfaces.size() == 1) 01177 B.Add(Co,*(surfaces.get()->get_TopoDS_Face())); 01178 else if (shells.size() == 1) 01179 B.Add(Co,*(shells.get()->get_TopoDS_Shell())); 01180 else 01181 { 01182 lump = CAST_TO(lumps.get(), OCCLump); 01183 B.Add(Co, *(lump->get_TopoDS_Solid())); 01184 //if body has attributes, add them to the solid. 01185 DLIList<CubitSimpleAttrib> csa_list; 01186 body->get_simple_attribute(csa_list); 01187 body_csa_list.clean_out(); 01188 for(int i = 0; i < csa_list.size(); i++) 01189 { 01190 CubitSimpleAttrib body_csa = csa_list.get_and_step(); 01191 CubitString pre_fix("#SINGLELUMP%"); 01192 pre_fix += CubitString::number(i); 01193 01194 body_csa.string_data_list().insert(body_csa.string_data_list().begin(), pre_fix); 01195 lump->append_simple_attribute_virt(body_csa); 01196 body_csa_list.append(body_csa); 01197 } 01198 if(csa_list.size() > 0) 01199 { 01200 single_lumps.append(lump); 01201 lists.append(new DLIList<CubitSimpleAttrib>(body_csa_list)); 01202 } 01203 } 01204 continue; 01205 } 01206 B.Add(Co, *shape); 01207 } 01208 } 01209 //=========================================================================== 01210 //Function Name:write_topology 01211 //Member Type: PUBLIC 01212 //Description: function called for write out temporary Brep file 01213 //Author: Jane Hu 01214 //Date: 11/16/2007 01215 //=========================================================================== 01216 01217 CubitStatus 01218 OCCQueryEngine::write_topology( const char* file_name, 01219 Model_File_Type file_type, 01220 DLIList<OCCBody*> &OCC_bodies, 01221 DLIList<OCCSurface*> &OCC_surfaces, 01222 DLIList<OCCCurve*> &OCC_curves, 01223 DLIList<OCCPoint*> &OCC_points ) 01224 { 01225 01226 int i; 01227 //Create a compound shape to export 01228 BRep_Builder B; 01229 TopoDS_Compound Co; 01230 B.MakeCompound(Co); 01231 01232 //Add every shape to the compound 01233 DLIList<OCCLump*> single_lumps; 01234 DLIList< DLIList<CubitSimpleAttrib>*> lists; 01235 OCCLump* lump = NULL; 01236 01237 if(OCC_bodies.size() > 0) 01238 body_attributes_for_writing(OCC_bodies, B, Co, single_lumps, lists); 01239 01240 for (i = 0; i < OCC_surfaces.size(); i++) 01241 { 01242 TopoDS_Face *face = OCC_surfaces.get_and_step()->get_TopoDS_Face(); 01243 B.Add(Co, *face); 01244 } 01245 01246 //Add standalone wires to the export BRep file 01247 for (i = 0; i < WireList->size(); i++) 01248 { 01249 TopoDS_Wire *wire = WireList->get_and_step()->get_TopoDS_Wire(); 01250 B.Add(Co, *wire); 01251 } 01252 01253 for (i = 0; i < OCC_curves.size(); i++) 01254 { 01255 TopoDS_Edge *edge = OCC_curves.get_and_step()->get_TopoDS_Edge(); 01256 B.Add(Co, *edge); 01257 } 01258 01259 for (i = 0; i < OCC_points.size(); i++) 01260 { 01261 TopoDS_Vertex *vertex = OCC_points.get_and_step()->get_TopoDS_Vertex(); 01262 B.Add(Co, *vertex); 01263 } 01264 01265 if(file_type == OCC_TYPE) 01266 { 01267 TDF_Label label; 01268 if(EXPORT_ATTRIB) 01269 label = mainLabel; 01270 01271 CubitBoolean result = Write(Co, const_cast<char*>(file_name),label); 01272 //remove the body attributes from lump 01273 for (int i = 0; i < single_lumps.size(); i++) 01274 { 01275 lump = single_lumps.get_and_step(); 01276 DLIList<CubitSimpleAttrib>* p_csas = lists.get_and_step(); 01277 for(int j = 0 ; j < p_csas->size(); j ++) 01278 { 01279 const CubitSimpleAttrib& csa = p_csas->get_and_step(); 01280 lump->remove_simple_attribute_virt(csa); 01281 } 01282 delete p_csas; 01283 } 01284 if(!result) 01285 return CUBIT_FAILURE; 01286 } 01287 01288 #ifdef HAVE_OCC_STEP 01289 else if(file_type == STEP_TYPE) 01290 { 01291 STEPControl_Writer writer; 01292 writer.Model( Standard_True); 01293 writer.Transfer(Co, STEPControl_AsIs ); 01294 IFSelect_ReturnStatus stat = writer.Write( (char*) file_name); 01295 if (stat != IFSelect_RetDone) 01296 { 01297 PRINT_INFO("%s: Cannot open file", file_name ); 01298 return CUBIT_FAILURE; 01299 } 01300 } 01301 #endif 01302 #ifdef HAVE_OCC_IGES 01303 else if (file_type == IGES_TYPE) // IGES file 01304 { 01305 IGESControl_Writer writer; 01306 writer.AddShape(Co); 01307 writer.ComputeModel(); 01308 Standard_Boolean stat = writer.Write( (char*) file_name); 01309 if (!stat ) 01310 { 01311 PRINT_INFO("%s: Cannot open file", file_name ); 01312 return CUBIT_FAILURE; 01313 } 01314 } 01315 #endif 01316 else { 01317 PRINT_ERROR("File formats other than OCC, STEP and IGES are not supported by OCC.\n"); 01318 return CUBIT_FAILURE; 01319 } 01320 01321 return CUBIT_SUCCESS; 01322 } 01323 01324 CubitStatus 01325 OCCQueryEngine::write_topology( char*& p_buffer, 01326 int& n_buffer_size, 01327 bool b_export_buffer, 01328 DLIList<OCCBody*> &OCC_bodies, 01329 DLIList<OCCSurface*> &OCC_surfaces, 01330 DLIList<OCCCurve*> &OCC_curves, 01331 DLIList<OCCPoint*> &OCC_points) 01332 { 01333 01334 int i; 01335 //Create a compound shape to export 01336 BRep_Builder B; 01337 TopoDS_Compound Co; 01338 B.MakeCompound(Co); 01339 01340 //Add every shape to the compound 01341 DLIList<OCCLump*> single_lumps; 01342 DLIList< DLIList<CubitSimpleAttrib>*> lists; 01343 OCCLump* lump = NULL; 01344 01345 if(OCC_bodies.size() > 0) 01346 body_attributes_for_writing(OCC_bodies, B, Co, single_lumps, lists); 01347 01348 for (i = 0; i < OCC_surfaces.size(); i++) 01349 { 01350 TopoDS_Face *face = OCC_surfaces.get_and_step()->get_TopoDS_Face(); 01351 B.Add(Co, *face); 01352 } 01353 01354 //Add standalone wires to the export BRep file 01355 for (i = 0; i < WireList->size(); i++) 01356 { 01357 TopoDS_Wire *wire = WireList->get_and_step()->get_TopoDS_Wire(); 01358 B.Add(Co, *wire); 01359 } 01360 01361 for (i = 0; i < OCC_curves.size(); i++) 01362 { 01363 TopoDS_Edge *edge = OCC_curves.get_and_step()->get_TopoDS_Edge(); 01364 B.Add(Co, *edge); 01365 } 01366 01367 for (i = 0; i < OCC_points.size(); i++) 01368 { 01369 TopoDS_Vertex *vertex = OCC_points.get_and_step()->get_TopoDS_Vertex(); 01370 B.Add(Co, *vertex); 01371 } 01372 01373 //if(strcmp(file_type, "OCC") == 0) 01374 //{ 01375 TDF_Label label; 01376 if(EXPORT_ATTRIB) 01377 label = mainLabel; 01378 01379 if(!Write(Co, p_buffer, n_buffer_size, b_export_buffer, label)) 01380 return CUBIT_FAILURE; 01381 01382 //remove the body attributes from lump 01383 for (int i = 0; i < single_lumps.size(); i++) 01384 { 01385 lump = single_lumps.get_and_step(); 01386 DLIList<CubitSimpleAttrib>* p_csas = lists.get_and_step(); 01387 for(int j = 0 ; j < p_csas->size(); j ++) 01388 { 01389 const CubitSimpleAttrib& csa = p_csas->get_and_step(); 01390 lump->remove_simple_attribute_virt(csa); 01391 } 01392 delete p_csas; 01393 } 01394 01395 return CUBIT_SUCCESS; 01396 } 01397 01398 CubitBoolean OCCQueryEngine::Write(const TopoDS_Shape& Sh, 01399 const Standard_CString File, 01400 TDF_Label label) 01401 { 01402 ofstream os; 01403 os.open(File, ios::out); 01404 if (!os.rdbuf()->is_open()) return Standard_False; 01405 01406 CubitBoolean isGood = (os.good() && !os.eof()); 01407 if(!isGood) 01408 return isGood; 01409 01410 OCCShapeAttributeSet SS; 01411 SS.Add(Sh); 01412 01413 os << "DBRep_DrawableShape\n"; // for easy Draw read 01414 SS.Write(os); 01415 isGood = os.good(); 01416 if(isGood ) 01417 SS.Write(Sh,os,&label); 01418 os.flush(); 01419 isGood = os.good(); 01420 os.close(); 01421 isGood = os.good() && isGood; 01422 01423 return isGood; 01424 } 01425 01426 CubitBoolean OCCQueryEngine::Write(const TopoDS_Shape& Sh, 01427 char*& pBuffer, 01428 int& n_buffer_size, 01429 bool b_write_buffer, 01430 TDF_Label label) 01431 { 01432 // make buffer as ouput stream 01433 std::stringbuf sb; 01434 std::iostream os(&sb); 01435 OCCShapeAttributeSet SS; 01436 01437 // write to output stream 01438 SS.Add(Sh); 01439 os << "DBRep_DrawableShape\n"; // for easy Draw read 01440 SS.Write(os); 01441 CubitBoolean isGood = os.good(); 01442 if (!isGood) return isGood; 01443 SS.Write(Sh,os,&label); 01444 isGood = os.good(); 01445 if (!isGood) return isGood; 01446 01447 n_buffer_size = os.rdbuf()->pubseekoff(0, std::ios_base::end, std::ios::out); 01448 01449 // get real geometries from output stream to buffer 01450 if (b_write_buffer) os.read(pBuffer, n_buffer_size); 01451 01452 return CUBIT_TRUE; 01453 } 01454 01455 CubitBoolean OCCQueryEngine::Read(TopoDS_Shape& Sh, 01456 const Standard_CString File, 01457 TDF_Label label) 01458 { 01459 ifstream in( File ); 01460 if (in.fail()) { 01461 PRINT_INFO("%s: Cannot open file", File ); 01462 return CUBIT_FAILURE; 01463 } 01464 01465 OCCShapeAttributeSet SS; 01466 SS.Read(in, CUBIT_TRUE); 01467 int nbshapes = SS.NbShapes(); 01468 if(!nbshapes) return CUBIT_FALSE; 01469 SS.Read(Sh,in,nbshapes, &label); 01470 return CUBIT_TRUE; 01471 } 01472 01473 CubitBoolean OCCQueryEngine::Read(TopoDS_Shape& Sh, 01474 const char* pBuffer, 01475 const int n_buffer_size, 01476 TDF_Label label) 01477 { 01478 // make buffer as input stream 01479 std::stringbuf sb; 01480 std::iostream is(&sb); 01481 is.write(pBuffer, n_buffer_size); 01482 01483 // read from input stream 01484 OCCShapeAttributeSet SS; 01485 SS.Read(is, false); 01486 int nbshapes = SS.NbShapes(); 01487 if (!nbshapes) return CUBIT_FALSE; 01488 SS.Read(Sh, is, nbshapes, &label); 01489 01490 return CUBIT_TRUE; 01491 } 01492 01493 CubitStatus 01494 OCCQueryEngine::import_temp_geom_file(FILE* file_ptr, 01495 const char* file_name, 01496 Model_File_Type file_type, 01497 DLIList<TopologyBridge*> &bridge_list ) 01498 { 01499 ModelImportOptions M_O; 01500 return import_solid_model( file_name, file_type, bridge_list, M_O ); 01501 } 01502 01503 //=========================================================================== 01504 //Function Name:import_solid_model 01505 //Member Type: PUBLIC 01506 //Description: function called for read in temporary Brep file 01507 //Author: Jane Hu 01508 //Date: 11/16/2007 01509 //=========================================================================== 01510 01511 CubitStatus OCCQueryEngine::import_solid_model( 01512 const char* file_name , 01513 Model_File_Type file_type, 01514 DLIList<TopologyBridge*> &imported_entities, 01515 ModelImportOptions &import_options) 01516 { 01517 TopoDS_Shape *aShape = new TopoDS_Shape; 01518 01519 //BRep_Builder aBuilder; 01520 if(file_type == OCC_TYPE) 01521 { 01522 Standard_Boolean result = Read(*aShape, (char*) file_name, mainLabel); 01523 if (result==0) return CUBIT_FAILURE; 01524 } 01525 #ifdef HAVE_OCC_STEP 01526 else if (file_type == STEP_TYPE) 01527 { 01528 STEPControl_Reader reader; 01529 /* 01530 char* name = "xstep.cascade.unit"; 01531 char* unit = "M"; 01532 Standard_CString orig_unit = Interface_Static::CVal(name); 01533 Interface_Static::SetCVal (name, unit); //this set is good for both step 01534 // and iges files. 01535 */ 01536 IFSelect_ReturnStatus stat = reader.ReadFile( (char*) file_name); 01537 /* 01538 //set the unit back. 01539 Interface_Static::SetCVal (name,orig_unit); 01540 */ 01541 if (stat != IFSelect_RetDone) 01542 { 01543 PRINT_INFO("%s: Cannot open file", file_name ); 01544 return CUBIT_FAILURE; 01545 } 01546 reader.TransferRoots(); 01547 *aShape = reader.OneShape(); 01548 } 01549 #endif 01550 #ifdef HAVE_OCC_IGES 01551 else if(file_type == IGES_TYPE) 01552 { 01553 IGESControl_Reader reader; 01554 /* 01555 char* name = "xstep.cascade.unit"; 01556 char* unit = "M"; 01557 Interface_Static::SetCVal (name, unit); //this set is good for both step 01558 // and iges files. 01559 */ 01560 const Standard_CString string1 = file_name; 01561 IFSelect_ReturnStatus stat = reader.ReadFile( string1); 01562 01563 // Interface_Static::SetCVal (name, "MM"); 01564 01565 if (stat != IFSelect_RetDone) 01566 { 01567 PRINT_INFO("%s: Cannot open file", file_name ); 01568 return CUBIT_FAILURE; 01569 } 01570 reader.TransferRoots(); 01571 *aShape = reader.OneShape(); 01572 } 01573 #endif 01574 else 01575 { 01576 PRINT_ERROR("File formats other than OCC, STEP and IGES are not supported by OCC\n"); 01577 return CUBIT_FAILURE; 01578 } 01579 01580 //All read in shapes are wrapped inside a compound shape. Ignore this one 01581 TopoDS_Iterator it(*aShape); 01582 if(aShape->ShapeType() != TopAbs_COMPOUND) 01583 { 01584 imported_entities += populate_topology_bridge(*aShape); 01585 return CUBIT_SUCCESS; 01586 } 01587 01588 for(;it.More();it.Next()) 01589 { 01590 TopoDS_Shape shape = it.Value(); 01591 imported_entities += populate_topology_bridge(shape); 01592 } 01593 01594 return CUBIT_SUCCESS; 01595 } 01596 01597 CubitStatus OCCQueryEngine::import_solid_model(DLIList<TopologyBridge*> &imported_entities, 01598 const char* pBuffer, 01599 const int n_buffer_size) 01600 { 01601 TopoDS_Shape *aShape = new TopoDS_Shape; 01602 Standard_Boolean result = Read(*aShape, pBuffer, n_buffer_size, mainLabel); 01603 if (result==0) return CUBIT_FAILURE; 01604 01605 //All read in shapes are wrapped inside a compound shape. Ignore this one 01606 TopoDS_Iterator it(*aShape); 01607 if(aShape->ShapeType() != TopAbs_COMPOUND) 01608 { 01609 imported_entities += populate_topology_bridge(*aShape); 01610 return CUBIT_SUCCESS; 01611 } 01612 01613 for(;it.More();it.Next()) 01614 { 01615 TopoDS_Shape shape = it.Value(); 01616 imported_entities += populate_topology_bridge(shape); 01617 } 01618 01619 return CUBIT_SUCCESS; 01620 } 01621 01622 //=========================================================================== 01623 //Function Name:populate_topology_bridge 01624 //Member Type: PUBLIC 01625 //Description: function called for populating topology bridge for OCC entity 01626 //Author: Jane Hu 01627 //Date: 11/16/2007 01628 //=========================================================================== 01629 01630 DLIList<TopologyBridge*> OCCQueryEngine::populate_topology_bridge(TopoDS_Shape& aShape) 01631 { 01632 DLIList<TopologyBridge*> tblist; 01633 // suitable to populate for a TopoDS_Compound shape. 01634 if ( aShape.ShapeType() == TopAbs_COMPOUND) 01635 tblist.append(populate_topology_bridge(TopoDS::Compound(aShape))); 01636 01637 else if(aShape.ShapeType() == TopAbs_SOLID) 01638 { 01639 Lump *lump = 01640 populate_topology_bridge(TopoDS::Solid(aShape), CUBIT_TRUE); 01641 tblist.append(CAST_TO(lump, OCCLump)->get_body()); 01642 } 01643 01644 else if(aShape.ShapeType() == TopAbs_SHELL) 01645 { 01646 OCCShell* shell = 01647 populate_topology_bridge(TopoDS::Shell(aShape), CUBIT_TRUE); 01648 tblist.append(shell->my_body()); 01649 } 01650 01651 else if(aShape.ShapeType() == TopAbs_FACE) 01652 { 01653 Surface* face = 01654 populate_topology_bridge(TopoDS::Face(aShape), CUBIT_TRUE); 01655 if(face) 01656 tblist.append(CAST_TO(face, OCCSurface)->my_body()); 01657 } 01658 01659 else if(aShape.ShapeType() == TopAbs_WIRE) 01660 populate_topology_bridge(TopoDS::Wire(aShape), CUBIT_TRUE); 01661 01662 else if(aShape.ShapeType() == TopAbs_EDGE) 01663 tblist.append(populate_topology_bridge(TopoDS::Edge(aShape),CUBIT_TRUE)); 01664 01665 else if(aShape.ShapeType() == TopAbs_VERTEX) 01666 tblist.append(populate_topology_bridge(TopoDS::Vertex(aShape), CUBIT_TRUE)); 01667 else 01668 PRINT_ERROR("Wrong topology type is given. \n"); 01669 tblist.remove_all_with_value(NULL); 01670 return tblist; 01671 } 01672 01673 BodySM* OCCQueryEngine::populate_topology_bridge(const TopoDS_Compound& aShape) 01674 { 01675 if(aShape.IsNull()) 01676 return (BodySM*)NULL; 01677 OCCBody *body = (OCCBody*)NULL; 01678 if (!OCCMap->IsBound(aShape) || 01679 OccToCGM->find(OCCMap->Find(aShape)) == OccToCGM->end()) 01680 { 01681 //check to see if this compound has only one lump which is already in 01682 //in another body. Unite operation will return a one lump compound. 01683 //Check also if this compound has only shells. which is or has faces that 01684 //are already in another body. Unite faces will return such shell. 01685 TopExp_Explorer Ex; 01686 int num_lumps = 0, num_shells = 0, num_faces = 0; 01687 TopoDS_Solid solid; 01688 for (Ex.Init(aShape, TopAbs_SOLID); Ex.More(); Ex.Next()) 01689 { 01690 num_lumps++; 01691 solid = TopoDS::Solid(Ex.Current()); 01692 } 01693 01694 TopoDS_Shell shell; 01695 for (Ex.Init(aShape, TopAbs_SHELL, TopAbs_SOLID); Ex.More(); Ex.Next()) 01696 { 01697 num_shells++; 01698 shell = TopoDS::Shell(Ex.Current()); 01699 } 01700 01701 TopoDS_Face face; 01702 for (Ex.Init(aShape, TopAbs_FACE, TopAbs_SHELL); Ex.More(); Ex.Next()) 01703 { 01704 num_faces++; 01705 face = TopoDS::Face(Ex.Current()); 01706 } 01707 01708 if(num_faces + num_shells + num_lumps == 1) 01709 { 01710 if (num_faces == 1 && (!OCCMap->IsBound(face) || 01711 OccToCGM->find(OCCMap->Find(face)) == OccToCGM->end())) 01712 { 01713 Surface* surface = populate_topology_bridge(face, CUBIT_TRUE); 01714 return CAST_TO(surface, OCCSurface)->my_body(); 01715 } 01716 else if (num_shells == 1 && (!OCCMap->IsBound(shell)|| 01717 OccToCGM->find(OCCMap->Find(shell)) == OccToCGM->end())) 01718 { 01719 OCCShell* occ_shell = populate_topology_bridge(shell, CUBIT_TRUE); 01720 return occ_shell->my_body(); 01721 } 01722 else if( num_lumps == 1 && (!OCCMap->IsBound(solid) || 01723 OccToCGM->find(OCCMap->Find(solid)) == OccToCGM->end())) 01724 { 01725 Lump* lump= populate_topology_bridge(solid, CUBIT_TRUE); 01726 return CAST_TO(lump, OCCLump)->get_body(); 01727 } 01728 else //find existing body 01729 { 01730 int k; 01731 if(num_lumps == 1) 01732 { 01733 k = OCCMap->Find(solid); 01734 OCCLump* lump = (OCCLump*)(OccToCGM->find(k))->second; 01735 body = CAST_TO(lump->get_body(), OCCBody); 01736 } 01737 else if (num_shells == 1) 01738 { 01739 k = OCCMap->Find(shell); 01740 OCCShell* occ_shell = (OCCShell*)(OccToCGM->find(k))->second; 01741 body = occ_shell->my_body(); 01742 } 01743 else 01744 { 01745 k = OCCMap->Find(face); 01746 OCCSurface* occ_surface = (OCCSurface*) (OccToCGM->find(k))->second; 01747 body = occ_surface->my_body(); 01748 } 01749 } 01750 } 01751 01752 else 01753 { 01754 TopoDS_Compound *comsolid = new TopoDS_Compound; 01755 *comsolid = aShape; 01756 body = new OCCBody(comsolid); 01757 int current_id; 01758 if(!OCCMap->IsBound(aShape)) 01759 { 01760 iTotalTBCreated++; 01761 current_id = iTotalTBCreated; 01762 OCCMap->Bind(aShape, current_id); 01763 } 01764 01765 else 01766 current_id = OCCMap->Find(aShape); 01767 01768 OccToCGM->insert(valType(current_id, 01769 (TopologyBridge*)body)); 01770 BodyList->append(body); 01771 } 01772 } 01773 else 01774 { 01775 int k = OCCMap->Find(aShape); 01776 body = (OCCBody*)(OccToCGM->find(k))->second; 01777 TopoDS_Compound compound = aShape; 01778 body->set_TopoDS_Shape(compound); 01779 } 01780 01781 TopExp_Explorer Ex; 01782 DLIList<Lump*> lumps; 01783 for (Ex.Init(aShape, TopAbs_SOLID); Ex.More(); Ex.Next()) 01784 { 01785 TopoDS_Shape sh = Ex.Current(); 01786 Lump* lump = populate_topology_bridge(TopoDS::Solid(sh)); 01787 lumps.append(lump); 01788 CAST_TO(lump, OCCLump)->add_body(body); 01789 //add the solid shape into map 01790 TopoDS_Shape parent = aShape; 01791 int current_id; 01792 add_shape_to_map(sh, parent, current_id); 01793 if(!OCCMap->IsBound(sh) || 01794 OccToCGM->find(OCCMap->Find(sh)) == OccToCGM->end()) 01795 OccToCGM->insert(valType(current_id, (TopologyBridge*)lump)); 01796 } 01797 body->lumps(lumps); 01798 01799 DLIList<OCCShell*> shells; 01800 for (Ex.Init(aShape, TopAbs_SHELL, TopAbs_SOLID);Ex.More(); Ex.Next()) 01801 { 01802 TopoDS_Shape sh = Ex.Current(); 01803 OCCShell * shell = populate_topology_bridge(TopoDS::Shell(sh)); 01804 OCCLump* lump = shell->my_lump(); 01805 if(lump == (OCCLump*)NULL) 01806 lump = new OCCLump(NULL, NULL, shell); 01807 lumps.append(lump); 01808 lump->add_body(body); 01809 shell->set_body(body); 01810 shell->set_lump(lump); 01811 shells.append(shell); 01812 TopoDS_Shape parent = aShape; 01813 int current_id; 01814 add_shape_to_map(sh, parent, current_id); 01815 if(!OCCMap->IsBound(sh) || 01816 OccToCGM->find(OCCMap->Find(sh)) == OccToCGM->end()) 01817 OccToCGM->insert(valType(current_id, (TopologyBridge*)shell)); 01818 } 01819 body->shells(shells); 01820 01821 DLIList<OCCSurface*> surfaces; 01822 for (Ex.Init(aShape, TopAbs_FACE, TopAbs_SHELL);Ex.More(); Ex.Next()) 01823 { 01824 TopoDS_Shape sh = Ex.Current(); 01825 Surface* face = populate_topology_bridge(TopoDS::Face(sh)); 01826 OCCSurface *surface = CAST_TO(face, OCCSurface); 01827 OCCShell* shell = surface->my_shell(); 01828 if (shell == (OCCShell*) NULL) 01829 shell = new OCCShell(NULL, surface); 01830 OCCLump* lump = surface->my_lump(); 01831 if(lump == (OCCLump*) NULL) 01832 lump = new OCCLump(NULL, surface); 01833 lumps.append(lump); 01834 lump->add_body(body); 01835 surface->set_body(body); 01836 surface->set_lump(lump); 01837 surface->set_shell(shell); 01838 shell->set_body(body); 01839 shell->set_lump(lump); 01840 TopoDS_Shape parent = aShape; 01841 surfaces.append(surface); 01842 int current_id; 01843 add_shape_to_map(sh, parent, current_id); 01844 if(!OCCMap->IsBound(sh) || 01845 OccToCGM->find(OCCMap->Find(sh)) == OccToCGM->end()) 01846 OccToCGM->insert(valType(current_id, (TopologyBridge*)face)); 01847 01848 } 01849 body->set_sheet_surfaces(surfaces); 01850 return body; 01851 } 01852 01853 Lump* OCCQueryEngine::populate_topology_bridge(const TopoDS_Solid& aShape, 01854 CubitBoolean build_body) 01855 { 01856 if(aShape.IsNull()) 01857 return (Lump*)NULL; 01858 01859 OCCLump *lump = NULL; 01860 OCCBody *body = NULL; 01861 int current_lump_number = 0; 01862 if (!OCCMap->IsBound(aShape) || 01863 OccToCGM->find(OCCMap->Find(aShape)) == OccToCGM->end()) 01864 { 01865 TopoDS_Solid *posolid = new TopoDS_Solid; 01866 *posolid = aShape; 01867 lump = new OCCLump(posolid); 01868 if (build_body) 01869 { 01870 if(OCCMap->IsBound(aShape)) 01871 current_lump_number = OCCMap->Find(aShape); 01872 else 01873 { 01874 iTotalTBCreated++; 01875 current_lump_number = iTotalTBCreated; 01876 } 01877 body = new OCCBody(NULL, NULL, NULL, lump); 01878 DLIList<CubitSimpleAttrib> csa_list; 01879 lump->get_simple_attribute(csa_list); 01880 //if there's body attribute, append it to body and delete it from lump. 01881 for(int i = 0; i < csa_list.size(); i++) 01882 { 01883 const CubitSimpleAttrib& csa = csa_list.get_and_step(); 01884 CubitString type = csa.string_data_list()[0]; 01885 CubitString subtype = type.substr(0,12); 01886 if(subtype == "#SINGLELUMP%") 01887 { 01888 lump->remove_simple_attribute_virt(csa); 01889 CubitSimpleAttrib copy = csa; 01890 copy.string_data_list().erase(copy.string_data_list().begin()); 01891 body->append_simple_attribute_virt(copy); 01892 } 01893 } 01894 BodyList->append(body); 01895 lump->add_body(body); 01896 } 01897 } 01898 else 01899 { 01900 int k = OCCMap->Find(aShape); 01901 lump = (OCCLump*)(OccToCGM->find(k))->second; 01902 lump->set_TopoDS_Solid(aShape); 01903 body = static_cast<OCCBody*>(lump->get_body()); 01904 TopoDS_Shape *b_shape = NULL; 01905 if(body) 01906 body->get_TopoDS_Shape(b_shape); 01907 if (!body || b_shape == NULL) 01908 { 01909 if(body) 01910 BodyList->remove(body); 01911 body = new OCCBody(NULL, NULL, NULL, lump); 01912 BodyList->append(body); 01913 lump->add_body(body); 01914 } 01915 } 01916 01917 TopoDS_Compound *shape = NULL; 01918 if(body) 01919 shape = body->get_TopoDS_Shape(); 01920 01921 if(build_body && OCCMap->IsBound(aShape) && shape && !shape->IsNull()) 01922 { 01923 PRINT_ERROR("Single lump body shouldn't have Compound shape.\n"); 01924 return (Lump*) NULL; 01925 } 01926 01927 TopExp_Explorer Ex; 01928 for (Ex.Init(aShape, TopAbs_SHELL); Ex.More(); Ex.Next()) 01929 { 01930 TopoDS_Shape sh = Ex.Current(); 01931 OCCShell* shell = populate_topology_bridge(TopoDS::Shell(sh)); 01932 shell->set_lump(lump); 01933 shell->set_body(body); 01934 TopoDS_Shape parent = aShape; 01935 int current_id; 01936 add_shape_to_map(sh, parent, current_id); 01937 if(!OCCMap->IsBound(sh) || 01938 OccToCGM->find(OCCMap->Find(sh)) == OccToCGM->end()) 01939 OccToCGM->insert(valType(current_id, (TopologyBridge*)shell)); 01940 } 01941 01942 if(build_body && (!OCCMap->IsBound(aShape)|| 01943 OccToCGM->find(OCCMap->Find(aShape)) == OccToCGM->end())) 01944 { 01945 if (!OCCMap->IsBound(aShape)) 01946 OCCMap->Bind(aShape, current_lump_number); 01947 OccToCGM->insert(valType(current_lump_number, 01948 (TopologyBridge*)lump)); 01949 } 01950 return lump; 01951 } 01952 01953 void OCCQueryEngine::add_shape_to_map(TopoDS_Shape& sh, 01954 TopoDS_Shape& aShape, /*In, parent */ 01955 int ¤t_id /*Out*/) 01956 { 01957 //add the shape into map 01958 if(sh.IsNull()) 01959 return; 01960 01961 if(!OCCMap->IsBound(sh) || 01962 OccToCGM->find(OCCMap->Find(sh)) == OccToCGM->end()) 01963 { 01964 DLIList<TopoDS_Shape*> list; 01965 //find the sh shape without aShape's location. 01966 TopLoc_Location L = aShape.Location(); 01967 TopoDS_Iterator it(aShape, Standard_True, Standard_False); 01968 TopoDS_Shape bare_shape; 01969 for(; it.More(); it.Next()) 01970 { 01971 TopoDS_Shape test_shape = it.Value(); 01972 test_shape.Move(L); 01973 if(sh.IsEqual(test_shape)) 01974 { 01975 bare_shape = it.Value(); 01976 break; 01977 } 01978 } 01979 if(!OCCMap->IsBound(sh)) 01980 { 01981 CubitBoolean shape_found = false; 01982 if(OCCMap->IsBound(bare_shape)) 01983 { 01984 current_id = OCCMap->Find(bare_shape); 01985 //There are two possiblities when coming here: 01986 //1. After OCCAttribute binds the bare_shape but not binds the topo. 01987 //2. The bare_shape is bound because it binds to a different topo. 01988 if( OccToCGM->find(current_id) == OccToCGM->end() ) 01989 { 01990 OCCMap->UnBind(bare_shape); 01991 std::map<int, TDF_Label>::iterator it = 01992 Shape_Label_Map->find(current_id); 01993 if(it != Shape_Label_Map->end()) 01994 { 01995 TDF_Label aLabel = (*it).second; 01996 Handle_TDataXtd_Shape attr_shape = TDataXtd_Shape::Set(aLabel, sh); 01997 } 01998 shape_found = true; 01999 } 02000 } 02001 if(!shape_found) 02002 { 02003 iTotalTBCreated++; 02004 current_id = iTotalTBCreated; 02005 } 02006 OCCMap->Bind(sh, current_id); 02007 } 02008 else 02009 current_id = OCCMap->Find(sh); 02010 } 02011 else 02012 current_id = OCCMap->Find(sh); 02013 } 02014 02015 OCCShell* OCCQueryEngine::populate_topology_bridge(const TopoDS_Shell& aShape, 02016 CubitBoolean standalone) 02017 { 02018 if(aShape.IsNull()) 02019 return (OCCShell*)NULL; 02020 OCCShell *shell ; 02021 if (!OCCMap->IsBound(aShape) || 02022 OccToCGM->find(OCCMap->Find(aShape)) == OccToCGM->end()) 02023 { 02024 if(standalone) 02025 { 02026 //check if just has one Face,if so, don't make new shell. 02027 TopExp_Explorer Ex; 02028 int num_faces = 0; 02029 TopoDS_Face topo_face; 02030 for (Ex.Init(aShape, TopAbs_FACE); Ex.More(); Ex.Next()) 02031 { 02032 topo_face = TopoDS::Face(Ex.Current()); 02033 num_faces++; 02034 } 02035 if(num_faces == 1) 02036 { 02037 Surface* face = populate_topology_bridge(topo_face, standalone); 02038 return CAST_TO(face, OCCSurface)->my_shell(); 02039 } 02040 } 02041 TopoDS_Shell *poshell = new TopoDS_Shell; 02042 *poshell = aShape; 02043 shell = new OCCShell(poshell); 02044 shell->set_body(NULL); 02045 shell->set_lump(NULL); 02046 if(standalone) 02047 { 02048 OCCLump* lump = new OCCLump(NULL, NULL, shell); 02049 OCCBody* body = new OCCBody(NULL, NULL, shell); 02050 BodyList->append(body); 02051 shell->set_body(body); 02052 shell->set_lump(lump); 02053 int k; 02054 if(!OCCMap->IsBound(aShape)) 02055 { 02056 iTotalTBCreated++; 02057 k = iTotalTBCreated; 02058 OCCMap->Bind(*poshell, k); 02059 } 02060 else 02061 k = OCCMap->Find(aShape); 02062 OccToCGM->insert(valType(k, (TopologyBridge*)shell)); 02063 } 02064 } 02065 else 02066 { 02067 int k = OCCMap->Find(aShape); 02068 shell = (OCCShell*)(OccToCGM->find(k))->second; 02069 shell->set_TopoDS_Shell(aShape); 02070 } 02071 02072 DLIList<OCCSurface*> memberSurfaces; 02073 TopExp_Explorer Ex; 02074 for (Ex.Init(aShape, TopAbs_FACE); Ex.More(); Ex.Next()) 02075 { 02076 TopoDS_Shape sh = Ex.Current(); 02077 TopoDS_Face topo_face = TopoDS::Face(sh); 02078 Surface* face = 02079 populate_topology_bridge(topo_face, CUBIT_FALSE); 02080 02081 TopoDS_Shape parent = aShape; 02082 int current_id; 02083 add_shape_to_map(sh, parent, current_id); 02084 if(!OCCMap->IsBound(sh) || 02085 OccToCGM->find(OCCMap->Find(sh)) == OccToCGM->end()) 02086 OccToCGM->insert(valType(current_id, (TopologyBridge*)face)); 02087 02088 if(!face) 02089 continue; 02090 OCCSurface *occ_surface = CAST_TO(face, OCCSurface); 02091 //check if surface was a sheet surface, delete it if so 02092 if(occ_surface->my_shell() != NULL && occ_surface->my_shell() != shell) 02093 { 02094 //if Sheet_body, delete this sheet body 02095 OCCBody* occ_body = occ_surface->my_body(); 02096 if(occ_body != NULL) 02097 { 02098 delete_solid_model_entities(occ_body); 02099 face = 02100 populate_topology_bridge(topo_face, CUBIT_FALSE); 02101 02102 if(!face) 02103 continue; 02104 occ_surface = CAST_TO(face, OCCSurface); 02105 shell->set_sheet_surface(occ_surface); 02106 } 02107 } 02108 02109 memberSurfaces.append(occ_surface); 02110 occ_surface->set_shell(shell); 02111 } 02112 02113 shell->setMemberSurfaces(memberSurfaces); 02114 return shell; 02115 } 02116 02117 Surface* OCCQueryEngine::populate_topology_bridge(const TopoDS_Face& aShape, 02118 CubitBoolean build_body) 02119 { 02120 if(aShape.IsNull()) 02121 return (Surface*)NULL; 02122 OCCSurface *surface = NULL; 02123 GProp_GProps myProps; 02124 BRepGProp::SurfaceProperties(aShape, myProps); 02125 double area = myProps.Mass(); 02126 double tol = get_sme_resabs_tolerance(); 02127 if(area < tol * tol && area > 0.) 02128 PRINT_WARNING("Generated a sliver surface. \n"); 02129 02130 else if (area < 0.0) 02131 PRINT_WARNING("Generated a negative area surface. \n"); 02132 02133 if (!OCCMap->IsBound(aShape) || 02134 OccToCGM->find(OCCMap->Find(aShape)) == OccToCGM->end()) 02135 { 02136 TopoDS_Face *poface = new TopoDS_Face; 02137 *poface = aShape; 02138 surface = new OCCSurface(poface); 02139 SurfaceList->append(surface); 02140 surface->set_body(NULL); 02141 surface->set_lump(NULL); 02142 surface->set_shell(NULL); 02143 if(build_body) 02144 { 02145 OCCShell* shell = new OCCShell(NULL, surface); 02146 OCCLump* lump = new OCCLump(NULL, surface); 02147 OCCBody* body = new OCCBody(NULL, surface); 02148 surface->set_body(body); 02149 surface->set_lump(lump); 02150 surface->set_shell(shell); 02151 shell->set_body(body); 02152 shell->set_lump(lump); 02153 BodyList->append(body); 02154 int k; 02155 if(!OCCMap->IsBound(aShape)) 02156 { 02157 iTotalTBCreated++; 02158 k = iTotalTBCreated; 02159 OCCMap->Bind(*poface, iTotalTBCreated); 02160 } 02161 else 02162 k = OCCMap->Find(aShape); 02163 OccToCGM->insert(valType(k, (TopologyBridge*)surface)); 02164 } 02165 } 02166 02167 else 02168 { 02169 int k = OCCMap->Find(aShape); 02170 surface = (OCCSurface*)(OccToCGM->find(k))->second; 02171 TopoDS_Face aFace(aShape); 02172 surface->set_TopoDS_Face(aFace); 02173 } 02174 02175 TopExp_Explorer Ex; 02176 for (Ex.Init(aShape.Oriented(TopAbs_FORWARD), TopAbs_WIRE); Ex.More(); 02177 Ex.Next()) 02178 { 02179 TopoDS_Shape sh = Ex.Current(); 02180 02181 OCCLoop* loop = populate_topology_bridge(TopoDS::Wire(sh)); 02182 /* 02183 if( aShape.Orientation() == TopAbs_REVERSED ) 02184 { 02185 DLIList<OCCCoEdge*> coedges_new = loop->coedges(); 02186 coedges_new.reverse(); 02187 //Reverse all coedges' senses. 02188 for (int i = 0; i < coedges_new.size(); i ++) 02189 { 02190 OCCCoEdge* coedge = coedges_new.get_and_step(); 02191 CubitSense sense = (coedge->sense() == CUBIT_FORWARD ? CUBIT_REVERSED : CUBIT_FORWARD); 02192 coedge->set_sense(sense); 02193 } 02194 loop->coedges(coedges_new); 02195 } 02196 */ 02197 TopoDS_Shape parent = aShape; 02198 int current_id; 02199 add_shape_to_map(sh, parent, current_id); 02200 if(!OCCMap->IsBound(sh) || 02201 OccToCGM->find(OCCMap->Find(sh)) == OccToCGM->end()) 02202 OccToCGM->insert(valType(current_id, (TopologyBridge*)loop)); 02203 } 02204 02205 return surface; 02206 } 02207 02208 OCCLoop* OCCQueryEngine::populate_topology_bridge(const TopoDS_Wire& aShape, 02209 CubitBoolean standalone) 02210 { 02211 if(aShape.IsNull()) 02212 return (OCCLoop*)NULL; 02213 02214 BRepTools_WireExplorer Ex; 02215 02216 OCCLoop *loop ; 02217 if (!OCCMap->IsBound(aShape) || 02218 OccToCGM->find(OCCMap->Find(aShape)) == OccToCGM->end()) 02219 { 02220 TopoDS_Wire *powire = new TopoDS_Wire; 02221 *powire = aShape; 02222 loop = new OCCLoop(powire); 02223 if(standalone) 02224 { 02225 int k; 02226 if(!OCCMap->IsBound(aShape)) 02227 { 02228 iTotalTBCreated++; 02229 k = iTotalTBCreated; 02230 OCCMap->Bind(aShape, iTotalTBCreated); 02231 } 02232 else 02233 k = OCCMap->Find(aShape); 02234 OccToCGM->insert(valType(k, (TopologyBridge*)loop)); 02235 WireList->append(loop); 02236 } 02237 } 02238 else 02239 { 02240 int k = OCCMap->Find(aShape); 02241 loop = (OCCLoop*)(OccToCGM->find(k))->second; 02242 loop->set_TopoDS_Wire(aShape); 02243 } 02244 02245 CubitVector v; 02246 02247 DLIList <OCCCoEdge*> coedges_old, coedges_new; 02248 coedges_old = loop->coedges(); 02249 02250 for (Ex.Init(aShape); Ex.More(); Ex.Next()) 02251 { 02252 const TopoDS_Edge& anEdgeForPop = Ex.Current(); 02253 TopoDS_Shape crv = anEdgeForPop; 02254 Curve* curve = populate_topology_bridge(anEdgeForPop); 02255 if(!curve) 02256 continue; 02257 TopoDS_Shape parent = aShape; 02258 int current_id; 02259 add_shape_to_map(crv, parent, current_id); 02260 if(!OCCMap->IsBound(crv) || 02261 OccToCGM->find(OCCMap->Find(crv)) == OccToCGM->end()) 02262 OccToCGM->insert(valType(current_id, (TopologyBridge*)curve)); 02263 02264 OCCCurve *occ_curve = CAST_TO(curve, OCCCurve); 02265 DLIList<OCCLoop*> loops = occ_curve->loops(); 02266 CubitBoolean exist = CUBIT_FALSE; 02267 OCCCoEdge * coedge = NULL; 02268 int size = coedges_old.size(); 02269 CubitSense sense = (crv.Orientation() == TopAbs_FORWARD ? 02270 CUBIT_FORWARD : CUBIT_REVERSED); 02271 02272 //for the cylinder side face, there are 4 coedges, 2 of them are seam 02273 //edges and should have opposite sense. 02274 for(int i = 0; i < coedges_new.size(); i++) 02275 { 02276 coedge = coedges_new.get_and_step(); 02277 Curve* test_c = coedge->curve(); 02278 if(test_c == curve) 02279 { 02280 if(sense == coedge->sense()) 02281 sense = (sense == CUBIT_FORWARD ? CUBIT_REVERSED : CUBIT_FORWARD); 02282 02283 break; 02284 } 02285 } 02286 02287 for(int i = 0; i < size; i++) 02288 { 02289 coedge = coedges_old.get_and_step(); 02290 if(coedge->curve() == curve && coedge->sense() == sense) 02291 { 02292 coedge->set_mark(1); 02293 exist = CUBIT_TRUE; 02294 coedge->set_sense(sense); 02295 coedges_new.append(coedge); 02296 break; 02297 } 02298 } 02299 02300 if(!exist ) 02301 { 02302 //search through the curve loops 02303 for(int i = 0; i < loops.size() ; i++) 02304 { 02305 OCCLoop* occ_loop = loops.get_and_step(); 02306 TopoDS_Wire* wire = occ_loop->get_TopoDS_Wire(); 02307 if (size > 0 && (wire->IsNull() || !OCCMap->IsBound(*wire))) 02308 { 02309 DLIList<OCCCoEdge*> coedge_list = occ_loop->coedges(); 02310 for(int j = 0; j < coedge_list.size(); j++) 02311 { 02312 OCCCoEdge * test_coedge = coedge_list.get_and_step(); 02313 occ_loop->remove_coedge(test_coedge); 02314 occ_curve->remove_loop(occ_loop); 02315 delete test_coedge; 02316 } 02317 if(!wire->IsNull()) 02318 wire->Nullify(); 02319 WireList->remove(occ_loop); 02320 } 02321 } 02322 02323 if(occ_curve->loops().size() == 2) 02324 { 02325 // If there are some assumptions made about manifold geometry . . . 02326 //there must be a loop which doesn't have this curve anymore 02327 //this is been found in subtract cases while one solid becomes 02328 //2 solid, and one face becomes two faces. One face uses/updates 02329 //the old face while the other face generates face and wire from 02330 //new. However, in order to uses the curves, the old curve is kept 02331 //as possible, so curve's loops get kept, but since it's going to 02332 //associate with new loop, the old loop should be removed from the 02333 //loop list. 02334 DLIList<OCCLoop*> old_loops = occ_curve->loops(); 02335 for (int i = 0; i < 2; i++) 02336 { 02337 int found = 0; 02338 OCCLoop* old_loop = old_loops.get_and_step(); 02339 TopoDS_Wire* thewire = old_loop->get_TopoDS_Wire(); 02340 if (thewire < (void*) 0x1000 || thewire->IsNull()) 02341 { 02342 found = 1; 02343 break; 02344 } 02345 DLIList<OCCCoEdge*> test_coedges = old_loop->coedges(); 02346 for(int j = 0; j < test_coedges.size() ; j++) 02347 { 02348 if(test_coedges.get()->curve() != curve) 02349 test_coedges.step(); 02350 else 02351 { 02352 found = 1; 02353 break; 02354 } 02355 } 02356 if(!found) 02357 occ_curve->remove_loop(old_loop); 02358 } 02359 } 02360 //for unite case, it's possible that the a curve has 3 coedges because 02361 //opencascade do not perform unite on surfaces. 02362 coedge = new OCCCoEdge( curve, loop, sense); 02363 coedges_new.append(coedge); 02364 occ_curve->add_loop(loop); 02365 } 02366 } 02367 02368 //Double check edge sense to make sure it consists with loop direction 02369 //coedges size = 2 case is checked in the face level so the face normal will 02370 //be considered. 02371 if(coedges_new.size() > 2) 02372 { 02373 OCCCoEdge* coedge = coedges_new.get_and_step(); 02374 double d1, d1_, d2, d2_; 02375 OCCCoEdge* next_coedge = coedges_new.get(); 02376 //because of tolerance issue, now check current loop end vertices distance 02377 //compared with reversed loop's end vertices distance, which ever shorter 02378 //will be the direction. 02379 //current loop's parameter not using " _ ", reversed loop's parameter 02380 //uses " _ ". 02381 if (coedge->sense() == CUBIT_FORWARD) 02382 { 02383 d1 = coedge->curve()->end_param(); 02384 d1_ = coedge->curve()->start_param(); 02385 } 02386 else 02387 { 02388 d1 = coedge->curve()->start_param(); 02389 d1_ = coedge->curve()->end_param(); 02390 } 02391 if( next_coedge->sense() == CUBIT_FORWARD) 02392 { 02393 d2_ = next_coedge->curve()->end_param(); 02394 d2 = next_coedge->curve()->start_param(); 02395 } 02396 else 02397 { 02398 d2 = next_coedge->curve()->end_param(); 02399 d2_ = next_coedge->curve()->start_param(); 02400 } 02401 CubitVector v1, v1_, v2, v2_; 02402 coedge->curve()->position_from_u(d1, v1); 02403 coedge->curve()->position_from_u(d1_, v1_); 02404 next_coedge->curve()->position_from_u(d2, v2); 02405 next_coedge->curve()->position_from_u(d2_, v2_); 02406 if(v1.distance_between(v2) > v1_.distance_between(v2_)) 02407 { 02408 //Reverse all coedges' senses. 02409 for (int i = 0; i < coedges_new.size(); i ++) 02410 { 02411 coedge = coedges_new.get_and_step(); 02412 CubitSense sense = (coedge->sense() == CUBIT_FORWARD ? CUBIT_REVERSED : CUBIT_FORWARD); 02413 coedge->set_sense(sense); 02414 } 02415 } 02416 } 02417 02418 /* 02419 if(aShape.Orientation() == TopAbs_REVERSED) 02420 coedges_new.reverse(); 02421 //Reverse all coedges' senses. 02422 for (int i = 0; i < coedges_new.size(); i ++) 02423 { 02424 OCCCoEdge* coedge = coedges_new.get_and_step(); 02425 CubitSense sense = (coedge->sense() == CUBIT_FORWARD ? CUBIT_REVERSED : CUBIT_FORWARD); 02426 coedge->set_sense(sense); 02427 } 02428 */ 02429 loop->coedges(coedges_new); 02430 02431 //remove unused coedges 02432 for(int i = 0; i < coedges_old.size(); i++) 02433 { 02434 OCCCoEdge *coedge = coedges_old.get_and_step(); 02435 if(coedge->get_mark() == 0) 02436 delete coedge; 02437 else 02438 coedge->set_mark(0); 02439 } 02440 return loop; 02441 } 02442 02443 Curve* OCCQueryEngine::populate_topology_bridge(const TopoDS_Edge& aShape, 02444 CubitBoolean stand_along ) 02445 { 02446 if(aShape.IsNull()) 02447 return (Curve*)NULL; 02448 Curve *curve; 02449 GProp_GProps myProps; 02450 BRepGProp::LinearProperties(aShape, myProps); 02451 double length = myProps.Mass(); 02452 TopExp_Explorer Ex; 02453 if(length < get_sme_resabs_tolerance()) 02454 { 02455 //check if the two vertices are acctually the same point. 02456 CubitVector v[2]; 02457 int i = 0; 02458 for (Ex.Init(aShape, TopAbs_VERTEX); Ex.More(); Ex.Next()) 02459 { 02460 TopoDS_Vertex vt = TopoDS::Vertex(Ex.Current()); 02461 gp_Pnt pt = BRep_Tool::Pnt(vt); 02462 v[i] = CubitVector(pt.X(), pt.Y(), pt.Z()); 02463 i++; 02464 } 02465 02466 if(v[0] == v[1]) 02467 return (Curve*) NULL; 02468 else 02469 PRINT_WARNING("Generated a sliver curve. \n"); 02470 } 02471 02472 if (!OCCMap->IsBound(aShape) || 02473 OccToCGM->find(OCCMap->Find(aShape)) == OccToCGM->end()) 02474 { 02475 TopoDS_Edge *poedge = new TopoDS_Edge; 02476 *poedge = aShape; 02477 curve = new OCCCurve(poedge); 02478 CurveList->append((OCCCurve*)curve); 02479 if(stand_along) 02480 { 02481 int k; 02482 if(!OCCMap->IsBound(aShape)) 02483 { 02484 iTotalTBCreated++; 02485 k = iTotalTBCreated; 02486 OCCMap->Bind(*poedge, iTotalTBCreated); 02487 } 02488 else 02489 k = OCCMap->Find(aShape); 02490 OccToCGM->insert(valType(k, (TopologyBridge*)curve)); 02491 } 02492 } 02493 else 02494 { 02495 int i = OCCMap->Find(aShape); 02496 curve = (Curve*)(OccToCGM->find(i))->second; 02497 CAST_TO(curve, OCCCurve)->set_TopoDS_Edge(aShape); 02498 } 02499 02500 for (Ex.Init(aShape, TopAbs_VERTEX); Ex.More(); Ex.Next()) 02501 { 02502 TopoDS_Shape sh = Ex.Current(); 02503 02504 /* bool alreadyWrapped=false; 02505 if(OCCMap->IsBound(sh)) 02506 { 02507 alreadyWrapped=true; 02508 }*/ 02509 02510 TBPoint* point = populate_topology_bridge(TopoDS::Vertex(Ex.Current())); 02511 CAST_TO(point, OCCPoint)->add_curve(CAST_TO(curve, OCCCurve)); 02512 TopoDS_Shape parent = aShape; 02513 int current_id; 02514 add_shape_to_map(sh, parent, current_id); 02515 if(!OCCMap->IsBound(sh) || 02516 OccToCGM->find(OCCMap->Find(sh)) == OccToCGM->end()) 02517 OccToCGM->insert(valType(current_id, (TopologyBridge*)point)); 02518 02519 02520 /* if(alreadyWrapped) 02521 PRINT_INFO("Vertex Already Wrapped: "); 02522 else 02523 PRINT_INFO("Vertex Wrapped: "); 02524 PRINT_INFO(" Shape ID = %d", OCCMap->Find(sh) ); 02525 PRINT_INFO(" TBPoint Address: %p", point ); 02526 PRINT_INFO(" Shape Orientation: %s\n", sh.Orientation()==TopAbs_FORWARD ? "Forward" : "Reversed" ); 02527 */ 02528 02529 } 02530 02531 return curve; 02532 } 02533 02534 TBPoint* OCCQueryEngine::populate_topology_bridge(const TopoDS_Vertex& aShape, 02535 CubitBoolean stand_along) 02536 { 02537 if(aShape.IsNull()) 02538 return (TBPoint*)NULL; 02539 OCCPoint *point; 02540 if (iTotalTBCreated == 0 || !OCCMap->IsBound(aShape) || 02541 OccToCGM->find(OCCMap->Find(aShape)) == OccToCGM->end()) 02542 { 02543 TopoDS_Vertex *povertex = new TopoDS_Vertex; 02544 *povertex = aShape; 02545 point = new OCCPoint(povertex); 02546 if(stand_along) 02547 { 02548 int k; 02549 if(!OCCMap->IsBound(aShape)) 02550 { 02551 iTotalTBCreated++; 02552 k = iTotalTBCreated; 02553 OCCMap->Bind(*povertex, iTotalTBCreated); 02554 } 02555 else 02556 k = OCCMap->Find(aShape); 02557 OccToCGM->insert(valType(k, (TopologyBridge*)point)); 02558 } 02559 02560 } 02561 else 02562 { 02563 int i = OCCMap->Find(aShape); 02564 point = (OCCPoint*)(OccToCGM->find(i))->second; 02565 point->set_TopoDS_Vertex(aShape); 02566 } 02567 return point; 02568 } 02569 02570 TopologyBridge* OCCQueryEngine::occ_to_cgm(const TopoDS_Shape& shape) 02571 { 02572 if(!OCCMap->IsBound(shape)) 02573 return (TopologyBridge*) NULL; 02574 02575 int k = OCCMap->Find(shape); 02576 return (OccToCGM->find(k))->second; 02577 } 02578 02579 //----------------------------------------------------------------------- 02580 // Purpose : Deletes all solid model entities associated with the 02581 // Bodies in the input list. 02582 // 02583 // Special Notes : 02584 // 02585 // Creator : Jane Hu 02586 // 02587 // Creation Date : 7/23/11 02588 //------------------------------------------------------------------------- 02589 void OCCQueryEngine::delete_solid_model_entities(DLIList<BodySM*>&bodyList)const 02590 { 02591 delete_bodies(bodyList, true); 02592 } 02593 02594 //------------------------------------------------------------------------- 02595 // Purpose : Deletes all solid model entities associated with the 02596 // Bodies in the input list depending on remove_lower_entities 02597 // flag. 02598 // 02599 // Special Notes : 02600 // 02601 // Creator : Steve Owen 02602 // 02603 // Creation Date : 4/23/01 02604 //------------------------------------------------------------------------- 02605 void OCCQueryEngine::delete_bodies(DLIList<BodySM*>&bodyList, 02606 bool remove_lower_entities ) const 02607 { 02608 BodySM* BodyPtr = NULL; 02609 for (int i = 0; i < bodyList.size(); i++ ) 02610 { 02611 BodyPtr = bodyList.get_and_step(); 02612 this->delete_body(BodyPtr, remove_lower_entities); 02613 } 02614 02615 return; 02616 } 02617 02618 CubitStatus OCCQueryEngine::delete_solid_model_entities( 02619 GeometryEntity* ref_entity_ptr, 02620 bool remove_lower_entities) const 02621 { 02622 //Lump 02623 Lump* lump = CAST_TO(ref_entity_ptr, Lump); 02624 if(lump != NULL) 02625 { 02626 BodySM* body = CAST_TO(lump, OCCLump)->get_body(); 02627 DLIList<Lump*> lumps = CAST_TO(body, OCCBody)->lumps(); 02628 02629 if (remove_lower_entities) 02630 return delete_solid_model_entities(body); 02631 02632 DLIList<TopologyBridge*> children; 02633 for(int i = 0; i < lumps.size(); i++) 02634 { 02635 lump = lumps.get_and_step(); 02636 CAST_TO(lump, OCCLump)->get_children_virt(children); 02637 } 02638 02639 CubitStatus stat = this->unhook_BodySM_from_OCC(body); 02640 if(stat) 02641 { 02642 while (children.size()) 02643 delete children.pop(); 02644 while(lumps.size()) 02645 delete lumps.pop(); 02646 delete body; 02647 } 02648 return stat; 02649 } 02650 02651 // Surface 02652 Surface* ref_face_ptr = CAST_TO(ref_entity_ptr, Surface); 02653 if (ref_face_ptr != NULL) 02654 { 02655 if (remove_lower_entities) 02656 return ( this->delete_solid_model_entities(ref_face_ptr) ); 02657 CubitStatus stat = this->unhook_Surface_from_OCC(ref_face_ptr); 02658 if(stat) 02659 delete ref_face_ptr; 02660 return stat; 02661 } 02662 02663 // Curve 02664 Curve* ref_edge_ptr = CAST_TO(ref_entity_ptr, Curve); 02665 if (ref_edge_ptr != NULL) 02666 { 02667 if (remove_lower_entities) 02668 return ( this->delete_solid_model_entities(ref_edge_ptr)); 02669 CubitStatus stat = this->unhook_Curve_from_OCC(ref_edge_ptr); 02670 if(stat) 02671 delete ref_edge_ptr; 02672 return stat; 02673 } 02674 02675 // Point 02676 TBPoint* ref_vertex_ptr = CAST_TO(ref_entity_ptr, TBPoint); 02677 if (ref_vertex_ptr != NULL) 02678 { 02679 return ( this->delete_solid_model_entities(ref_vertex_ptr) ); 02680 } 02681 02682 // Oops! 02683 PRINT_ERROR("In OCCQueryEngine::delete_solid_model_entities\n" 02684 " Can only delete solid model entities underlying \n" 02685 "RefFaces, RefEdges and RefVertices.\n"); 02686 return CUBIT_FAILURE; 02687 02688 } 02689 //------------------------------------------------------------------------- 02690 // Purpose : Delete a OCCBody and child entities. 02691 // 02692 // Special Notes : 02693 // 02694 // Creator : Jane Hu 02695 // 02696 // Creation Date : 10/29/07 02697 //------------------------------------------------------------------------- 02698 CubitStatus 02699 OCCQueryEngine::delete_solid_model_entities( BodySM* bodysm) const 02700 { 02701 return delete_body(bodysm, true); 02702 } 02703 //------------------------------------------------------------------------- 02704 // Purpose : Delete a OCCBody and child entities depending on 02705 // remove_lower_entities flag. 02706 // 02707 // Special Notes : 02708 // 02709 // Creator : Jane Hu 02710 // 02711 // Creation Date : 10/29/07 02712 //------------------------------------------------------------------------- 02713 CubitStatus 02714 OCCQueryEngine::delete_body( BodySM* bodysm, 02715 bool remove_lower_entities) const 02716 { 02717 OCCBody* occ_body = static_cast<OCCBody*>(bodysm); 02718 if (!occ_body) 02719 return CUBIT_FAILURE; 02720 02721 DLIList<Lump*> lumps; 02722 DLIList<ShellSM*> shell_list; 02723 DLIList<OCCSurface*> surfaces = occ_body->my_sheet_surfaces(); 02724 for(int i = 0; i <surfaces.size(); i++) 02725 { 02726 OCCSurface* occ_surface = surfaces.get_and_step(); 02727 occ_surface->set_body((OCCBody*)NULL); 02728 if(remove_lower_entities) 02729 { 02730 delete occ_surface->my_lump(); 02731 OCCShell* shell = occ_surface->my_shell(); 02732 delete_solid_model_entities(occ_surface); 02733 delete shell; 02734 } 02735 } 02736 02737 DLIList<OCCShell*> shells = occ_body->shells(); 02738 for(int i = 0; i <shells.size(); i++) 02739 { 02740 OCCShell* occ_shell = shells.get_and_step(); 02741 occ_shell->set_body((OCCBody*)NULL); 02742 if(remove_lower_entities) 02743 { 02744 delete occ_shell->my_lump(); 02745 DLIList<TopologyBridge*> tb_surfaces; 02746 occ_shell->get_children_virt(tb_surfaces); 02747 unhook_ShellSM_from_OCC(occ_shell); 02748 for(int k = 0; k < tb_surfaces.size(); k++) 02749 delete_solid_model_entities(CAST_TO(tb_surfaces.get_and_step(), Surface)); 02750 delete occ_shell; 02751 } 02752 } 02753 02754 DLIList<TopologyBridge*> children; 02755 lumps = occ_body->lumps(); 02756 int size = lumps.size(); 02757 02758 for(int i =0; i < size; i++) 02759 { 02760 Lump* lump = lumps.get_and_step(); 02761 OCCLump* occ_lump = CAST_TO(lump, OCCLump); 02762 if (!occ_lump) 02763 continue; 02764 occ_lump->remove_body(); 02765 if(remove_lower_entities) 02766 { 02767 children.clean_out(); 02768 occ_lump->get_children_virt(children); 02769 for(int j = 0; j < children.size(); j++) 02770 { 02771 ShellSM* shell = CAST_TO(children.get_and_step(), ShellSM); 02772 02773 if (shell) 02774 shell_list.append(shell); 02775 DLIList<TopologyBridge*> tb_surfaces; 02776 shell->get_children_virt(tb_surfaces); 02777 for(int k = 0; k < tb_surfaces.size(); k++) 02778 delete_solid_model_entities(CAST_TO(tb_surfaces.get_and_step(), Surface)); 02779 } 02780 } 02781 } 02782 CubitStatus stat = CUBIT_SUCCESS; 02783 stat = unhook_BodySM_from_OCC(bodysm, remove_lower_entities); 02784 02785 if(remove_lower_entities) 02786 { 02787 for(int j = 0; j < shell_list.size(); j++) 02788 delete shell_list.get_and_step(); 02789 02790 for(int i =0; i < lumps.size(); i++) 02791 delete lumps.get_and_step(); 02792 } 02793 02794 BodyList->remove(occ_body); 02795 delete bodysm; 02796 return stat; 02797 } 02798 02799 CubitStatus 02800 OCCQueryEngine::unhook_BodySM_from_OCC( BodySM* bodysm , 02801 bool remove_lower_entities)const 02802 { 02803 OCCBody* occ_body = dynamic_cast<OCCBody*>(bodysm); 02804 if (!occ_body) 02805 return CUBIT_FAILURE; 02806 02807 TopoDS_Shape* shape = occ_body->get_TopoDS_Shape(); 02808 02809 if (shape && !shape->IsNull()) 02810 { 02811 //remove the entry from label tree 02812 OCCAttribSet::remove_attribute(*shape) ; 02813 02814 //remove the entry from the map 02815 int k; 02816 if(shape && !shape->IsNull() && OCCMap->IsBound(*shape)) 02817 { 02818 k = OCCMap->Find(*shape); 02819 OCCMap->UnBind(*shape); 02820 02821 if(!OccToCGM->erase(k)) 02822 PRINT_ERROR("The OccBody and iCreatedTotal %i pair is not in the map!", k); 02823 } 02824 } 02825 02826 DLIList<Lump*> lumps = occ_body->lumps(); 02827 for(int i =0; i < lumps.size()&& remove_lower_entities; i++) 02828 { 02829 Lump* lump = lumps.get_and_step(); 02830 //OCCLump* occ_lump = CAST_TO(lump, OCCLump); 02831 //if(occ_lump) 02832 // occ_lump->remove_body(); 02833 02834 unhook_Lump_from_OCC(lump); 02835 } 02836 02837 if (shape && !shape->IsNull()) 02838 shape->Nullify(); 02839 return CUBIT_SUCCESS; 02840 } 02841 02842 //------------------------------------------------------------------------- 02843 // Purpose : unhook a OCClumps and child entities. 02844 // 02845 // Special Notes : 02846 // 02847 // Creator : Jane Hu 02848 // 02849 // Creation Date : 11/29/07 02850 //------------------------------------------------------------------------- 02851 CubitStatus 02852 OCCQueryEngine::unhook_Lump_from_OCC( Lump* lump ) const 02853 { 02854 if (lump == NULL) 02855 return CUBIT_FAILURE; 02856 02857 OCCLump* occ_lump = dynamic_cast<OCCLump*>(lump); 02858 if (!occ_lump) 02859 return CUBIT_FAILURE; 02860 02861 TopoDS_Solid* solid = occ_lump->get_TopoDS_Solid(); 02862 02863 if(!solid) 02864 return CUBIT_FAILURE; 02865 02866 //remove the entry from label tree 02867 OCCAttribSet::remove_attribute(*solid) ; 02868 02869 //remove the entry from the map 02870 int k; 02871 if(OCCMap->IsBound(*solid)) 02872 { 02873 k = OCCMap->Find(*solid); 02874 02875 OCCMap->UnBind(*solid); 02876 02877 if(!OccToCGM->erase(k)) 02878 PRINT_ERROR("The OccLump and iCreatedTotal pair is not in the map!"); 02879 } 02880 02881 DLIList<TopologyBridge*> children; 02882 occ_lump->get_children_virt(children); 02883 for(int i = 0; i < children.size(); i++) 02884 { 02885 ShellSM* shell = CAST_TO(children.get_and_step(), ShellSM); 02886 unhook_ShellSM_from_OCC(shell); 02887 } 02888 if (occ_lump->get_body() != NULL) 02889 BodyList->remove(CAST_TO(occ_lump->get_body(), OCCBody)); 02890 02891 if(!solid->IsNull()) 02892 solid->Nullify(); 02893 return CUBIT_SUCCESS; 02894 } 02895 02896 //------------------------------------------------------------------------- 02897 // Purpose : unhook a ShellSM from its underlining OCC entity. 02898 // 02899 // Special Notes : 02900 // 02901 // Creator : Jane Hu 02902 // 02903 // Creation Date : 12/12/07 02904 //------------------------------------------------------------------------- 02905 CubitStatus 02906 OCCQueryEngine::unhook_ShellSM_from_OCC( ShellSM* shell) const 02907 { 02908 OCCShell* occ_shell = dynamic_cast<OCCShell*>(shell); 02909 if (!occ_shell) 02910 return CUBIT_FAILURE; 02911 02912 TopoDS_Shell* Shell = occ_shell->get_TopoDS_Shell(); 02913 02914 if(!Shell) 02915 return CUBIT_FAILURE; 02916 02917 //remove the entry from the map 02918 int k; 02919 if(OCCMap->IsBound(*Shell)) 02920 { 02921 k = OCCMap->Find(*Shell); 02922 02923 OCCMap->UnBind(*Shell); 02924 02925 if(!OccToCGM->erase(k)) 02926 PRINT_ERROR("The OccShell and iCreatedTotal pair is not in the map!"); 02927 } 02928 02929 if(!Shell->IsNull()) 02930 Shell->Nullify(); 02931 return CUBIT_SUCCESS; 02932 } 02933 02934 //------------------------------------------------------------------------- 02935 // Purpose : Delete a OCCSurface and child entities. 02936 // 02937 // Special Notes : 02938 // 02939 // Creator : Jane Hu 02940 // 02941 // Creation Date : 10/29/07 02942 //------------------------------------------------------------------------- 02943 CubitStatus 02944 OCCQueryEngine::delete_solid_model_entities( Surface* surface)const 02945 { 02946 OCCSurface* fsurf = dynamic_cast<OCCSurface*>(surface); 02947 if (!fsurf) 02948 return CUBIT_FAILURE; 02949 02950 OCCBody* sheet_body = fsurf->my_body(); 02951 if(sheet_body != NULL) 02952 BodyList->remove(sheet_body); 02953 02954 double d = fsurf->measure(); 02955 if(d < 0.0) 02956 PRINT_WARNING("Negative area surface is being deleted. \n"); 02957 02958 DLIList<TopologyBridge*> children; 02959 fsurf->get_children_virt(children); 02960 for(int i = 0; i < children.size(); i++) 02961 { 02962 LoopSM* loop = CAST_TO(children.get_and_step(), LoopSM); 02963 delete_loop(loop); 02964 } 02965 CubitStatus stat = unhook_Surface_from_OCC(surface); 02966 if (stat) 02967 delete surface; 02968 return stat; 02969 } 02970 02971 //------------------------------------------------------------------------- 02972 // Purpose : unhook a Surface from its underlining OCC entity. 02973 // 02974 // Special Notes : 02975 // 02976 // Creator : Jane Hu 02977 // 02978 // Creation Date : 12/12/07 02979 //------------------------------------------------------------------------- 02980 CubitStatus 02981 OCCQueryEngine::unhook_Surface_from_OCC( Surface* surface) const 02982 { 02983 OCCSurface* fsurf = dynamic_cast<OCCSurface*>(surface); 02984 if (!fsurf) 02985 return CUBIT_FAILURE; 02986 02987 TopoDS_Face *face = fsurf->get_TopoDS_Face(); 02988 02989 if(!face) 02990 return CUBIT_FAILURE; 02991 02992 //remove the entry from label tree 02993 OCCAttribSet::remove_attribute(*face) ; 02994 02995 //remove the entry from the map 02996 int k; 02997 if(OCCMap->IsBound(*face)) 02998 { 02999 k = OCCMap->Find(*face); 03000 03001 OCCMap->UnBind(*face); 03002 03003 if(!OccToCGM->erase(k)) 03004 PRINT_WARNING("The OccSurface and iCreatedTotal pair is not in the map!"); 03005 } 03006 SurfaceList->remove(fsurf); 03007 if(!face->IsNull()) 03008 face->Nullify(); 03009 return CUBIT_SUCCESS; 03010 } 03011 03012 //------------------------------------------------------------------------- 03013 // Purpose : Delete a OCCLoop and child entities. 03014 // 03015 // Special Notes : 03016 // 03017 // Creator : Jane Hu 03018 // 03019 // Creation Date : 10/29/07 03020 //------------------------------------------------------------------------- 03021 CubitStatus 03022 OCCQueryEngine::delete_loop( LoopSM* loopsm)const 03023 { 03024 OCCLoop* occ_loop = dynamic_cast<OCCLoop*>(loopsm); 03025 if (!occ_loop) 03026 return CUBIT_FAILURE; 03027 03028 DLIList<OCCCoEdge*> children; 03029 children = occ_loop->coedges(); 03030 int size = children.size(); 03031 DLIList<Curve*> curves; 03032 while(size > 0) 03033 { 03034 OCCCoEdge* coedge = children.pop(); 03035 Curve* curve = coedge->curve(); 03036 curves.append_unique(curve); 03037 size = children.size(); 03038 } 03039 03040 CubitStatus status = unhook_LoopSM_from_OCC(loopsm); 03041 03042 for(int i = 0; i < curves.size(); i ++) 03043 { 03044 OCCCurve* occ_curve = CAST_TO(curves.get_and_step(), OCCCurve); 03045 unhook_coedges_of_a_curve(occ_curve, occ_loop); 03046 occ_curve->remove_loop(occ_loop); 03047 delete_solid_model_entities(occ_curve); 03048 } 03049 03050 if (status) 03051 { 03052 WireList->remove(occ_loop); 03053 delete loopsm; 03054 } 03055 return status; 03056 } 03057 03058 //------------------------------------------------------------------------- 03059 // Purpose : unhook a LoopSM from its underlining OCC entity. 03060 // 03061 // Special Notes : 03062 // 03063 // Creator : Jane Hu 03064 // 03065 // Creation Date : 12/12/07 03066 //------------------------------------------------------------------------- 03067 CubitStatus 03068 OCCQueryEngine::unhook_LoopSM_from_OCC( LoopSM* loopsm) const 03069 { 03070 OCCLoop* occ_loop = dynamic_cast<OCCLoop*>(loopsm); 03071 if (!occ_loop) 03072 return CUBIT_FAILURE; 03073 03074 TopoDS_Wire* wire = occ_loop->get_TopoDS_Wire(); 03075 03076 if(!wire) 03077 return CUBIT_FAILURE; 03078 03079 //remove the entry from the map 03080 int k; 03081 if(OCCMap->IsBound(*wire)) 03082 { 03083 k = OCCMap->Find(*wire); 03084 03085 OCCMap->UnBind(*wire); 03086 03087 if(!OccToCGM->erase(k)) 03088 PRINT_ERROR("The OccLoop and iCreatedTotal pair is not in the map!"); 03089 } 03090 03091 if(!wire->IsNull()) 03092 wire->Nullify(); 03093 return CUBIT_SUCCESS; 03094 } 03095 03096 //------------------------------------------------------------------------- 03097 // Purpose : unhook a list of OCCCoEdges from their underlining OCC entity. 03098 // 03099 // Special Notes : 03100 // 03101 // Creator : Jane Hu 03102 // 03103 // Creation Date : 12/12/07 03104 //------------------------------------------------------------------------- 03105 CubitStatus 03106 OCCQueryEngine::unhook_CoEdges_from_OCC( DLIList<OCCCoEdge*>& coedges) const 03107 { 03108 int size = coedges.size(); 03109 while(size > 0) 03110 { 03111 OCCCoEdge* coedge = coedges.pop(); 03112 03113 LoopSM* loopsm = coedge->loop(); 03114 OCCLoop* loop = CAST_TO(loopsm, OCCLoop); 03115 assert(loop); 03116 loop->remove_coedge(coedge); 03117 03118 delete coedge; 03119 03120 size = coedges.size(); 03121 } 03122 return CUBIT_SUCCESS; 03123 } 03124 03125 //------------------------------------------------------------------------- 03126 // Purpose : Delete a OCCCurve and child entities. 03127 // 03128 // Special Notes : 03129 // 03130 // Creator : Jason Kraftcheck 03131 // 03132 // Creation Date : 09/29/03 03133 //------------------------------------------------------------------------- 03134 CubitStatus 03135 OCCQueryEngine::delete_solid_model_entities( Curve* curve)const 03136 { 03137 OCCCurve* fcurve = CAST_TO(curve, OCCCurve); 03138 if (!fcurve ) 03139 return CUBIT_FAILURE; 03140 03141 if(fcurve->loops().size() > 0 && fcurve->loops().get() != NULL) 03142 return CUBIT_FAILURE; 03143 03144 DLIList<TopologyBridge*> children; 03145 fcurve->get_children_virt(children); 03146 for(int i = 0; i < children.size(); i++) 03147 { 03148 TBPoint* point = CAST_TO(children.get_and_step(), TBPoint); 03149 CAST_TO(point, OCCPoint)->remove_curve(fcurve); 03150 delete_solid_model_entities(point); 03151 } 03152 03153 CubitStatus stat = unhook_Curve_from_OCC(curve); 03154 if (!stat) 03155 return CUBIT_FAILURE; 03156 03157 CurveList->remove(fcurve); 03158 delete fcurve; 03159 return stat; 03160 } 03161 03162 //------------------------------------------------------------------------- 03163 // Purpose : unhook a Curve from its underlining OCC entity. 03164 // 03165 // Special Notes : 03166 // 03167 // Creator : Jane Hu 03168 // 03169 // Creation Date : 12/12/07 03170 //------------------------------------------------------------------------- 03171 CubitStatus 03172 OCCQueryEngine::unhook_Curve_from_OCC( Curve* curve ) const 03173 { 03174 OCCCurve* fcurve = dynamic_cast<OCCCurve*>(curve); 03175 if (!fcurve ) 03176 return CUBIT_FAILURE; 03177 03178 DLIList<TopologyBridge*> children; 03179 fcurve->get_children_virt(children); 03180 for(int i = 0; i < children.size(); i++) 03181 { 03182 TBPoint* point = CAST_TO(children.get_and_step(), TBPoint); 03183 CAST_TO(point, OCCPoint)->remove_curve(fcurve); 03184 } 03185 03186 unhook_coedges_of_a_curve(fcurve, NULL); 03187 03188 fcurve->clean_loops(); 03189 TopoDS_Edge* edge = fcurve->get_TopoDS_Edge(); 03190 if (!edge) 03191 return CUBIT_FAILURE; 03192 03193 //remove the entry from label tree 03194 OCCAttribSet::remove_attribute(*edge) ; 03195 03196 //remove the entry from the map 03197 int k; 03198 if(edge && !edge->IsNull() && OCCMap->IsBound(*edge)) 03199 { 03200 k = OCCMap->Find(*edge); 03201 03202 OCCMap->UnBind(*edge); 03203 03204 if(!OccToCGM->erase(k)) 03205 PRINT_WARNING("The OccCurve and iCreatedTotal pair is not in the map!"); 03206 } 03207 CurveList->remove(fcurve); 03208 if(!edge->IsNull()) 03209 edge->Nullify(); 03210 return CUBIT_SUCCESS; 03211 } 03212 //------------------------------------------------------------------------- 03213 // Purpose : Delete a OCCPoint and child entities. 03214 // 03215 // Special Notes : 03216 // 03217 // Creator : Jason Kraftcheck 03218 // 03219 // Creation Date : 09/29/03 03220 //------------------------------------------------------------------------- 03221 CubitStatus 03222 OCCQueryEngine::delete_solid_model_entities( TBPoint* point) const 03223 { 03224 OCCPoint* fpoint = dynamic_cast<OCCPoint*>(point); 03225 if (!fpoint) 03226 return CUBIT_FAILURE; 03227 03228 if(fpoint->num_curves() > 0) 03229 return CUBIT_FAILURE; 03230 03231 CubitStatus stat = unhook_Point_from_OCC(point); 03232 03233 if(stat) 03234 delete point; 03235 return stat; 03236 } 03237 03238 //------------------------------------------------------------------------- 03239 // Purpose : unhook a Point from its underlining OCC entity. 03240 // 03241 // Special Notes : 03242 // 03243 // Creator : Jane Hu 03244 // 03245 // Creation Date : 12/12/07 03246 //------------------------------------------------------------------------- 03247 CubitStatus 03248 OCCQueryEngine::unhook_Point_from_OCC( TBPoint* point) const 03249 { 03250 OCCPoint* fpoint = dynamic_cast<OCCPoint*>(point); 03251 if (!fpoint) 03252 return CUBIT_FAILURE; 03253 03254 TopoDS_Vertex* vertex = fpoint->get_TopoDS_Vertex(); 03255 if (!vertex) 03256 return CUBIT_FAILURE; 03257 03258 //remove the entry from label tree 03259 OCCAttribSet::remove_attribute(*vertex) ; 03260 03261 //remove the entry from the map 03262 int k; 03263 if(OCCMap->IsBound(*vertex)) 03264 { 03265 k = OCCMap->Find(*vertex); 03266 03267 OCCMap->UnBind(*vertex); 03268 03269 if(!OccToCGM->erase(k)) 03270 PRINT_ERROR("The OccPoint and iCreatedTotal pair is not in the map!"); 03271 } 03272 if(!vertex->IsNull()) 03273 vertex->Nullify(); 03274 return CUBIT_SUCCESS; 03275 } 03276 03277 03278 //------------------------------------------------------------------------- 03279 // Purpose : fire a ray at the specified body, returning the entities hit. 03280 // 03281 // Special Notes : 03282 // 03283 // Creator : Jane Hu 03284 // 03285 // Creation Date : 12/12/07 03286 //------------------------------------------------------------------------- 03287 CubitStatus OCCQueryEngine::fire_ray( CubitVector &origin, 03288 CubitVector &direction, 03289 DLIList<TopologyBridge*> &at_entity_list, 03290 DLIList<double> &ray_params, 03291 int max_hits , 03292 double ray_radius , 03293 DLIList<TopologyBridge*> *hit_entity_list_ptr )const 03294 { 03295 CubitStatus status = CUBIT_SUCCESS; 03296 03297 //- fire a ray at the specified body, returning the entities hit and 03298 //- the parameters along the ray; return CUBIT_FAILURE if error 03299 // - line body intersection. 03300 gp_Pnt p(origin.x(), origin.y(), origin.z()); 03301 gp_Dir dir(direction.x(), direction.y(), direction.z()); 03302 gp_Lin L(p, dir); 03303 TopoDS_Edge edge = BRepBuilderAPI_MakeEdge(L); 03304 03305 for(int i = 0; i < at_entity_list.size(); i++) 03306 { 03307 TopologyBridge* tb = at_entity_list.get_and_step(); 03308 TopoDS_Shape *shape; 03309 OCCBody *occBody = CAST_TO(tb, OCCBody); 03310 if (occBody ) 03311 { 03312 occBody->get_TopoDS_Shape(shape); 03313 03314 BRepExtrema_DistShapeShape distShapeShape(edge, *shape); 03315 //distShapeShape.Perform(); 03316 if (!distShapeShape.IsDone()) 03317 { 03318 PRINT_ERROR("Cannot calculate the intersection points for the input body.\n"); 03319 return CUBIT_FAILURE; 03320 } 03321 03322 if (distShapeShape.Value() < get_sme_resabs_tolerance()) 03323 { 03324 int numPnt = distShapeShape.NbSolution(); 03325 for (int i = 1; i <= numPnt; i++) 03326 { 03327 double para; 03328 distShapeShape.ParOnEdgeS1(i , para); 03329 ray_params.append(para); 03330 } 03331 hit_entity_list_ptr->append(tb); 03332 } 03333 } 03334 } 03335 return status; 03336 } 03337 03338 double OCCQueryEngine::get_sme_resabs_tolerance() const 03339 { 03340 return Precision::Confusion(); 03341 } 03342 // Gets solid modeler's resolution absolute tolerance 03343 03344 double OCCQueryEngine::set_sme_resabs_tolerance( double p) 03345 { 03346 double old_p = get_sme_resabs_tolerance(); 03347 BRepBuilderAPI::Precision(p); 03348 return old_p; 03349 } 03350 03351 CubitStatus OCCQueryEngine::set_int_option( const char* , int ) 03352 { 03353 PRINT_ERROR("OCCQueryEngine::set_int_option not yet implemented.\n"); 03354 return CUBIT_FAILURE; 03355 } 03356 03357 CubitStatus OCCQueryEngine::set_dbl_option( const char* , double ) 03358 { 03359 PRINT_ERROR("OCCQueryEngine::set_dbl_option not yet implemented.\n"); 03360 return CUBIT_FAILURE; 03361 } 03362 03363 CubitStatus OCCQueryEngine::set_str_option( const char* , const char* ) 03364 { 03365 PRINT_ERROR("OCCQueryEngine::set_str_option not yet implemented.\n"); 03366 return CUBIT_FAILURE; 03367 } 03368 //- Set solid modeler options 03369 03370 03371 //=========================================================================== 03372 //Function Name: ensure_is_ascii_stl_file 03373 //Member Type: 03374 //Description: returns CUBIT_TRUE in is_ascii if fp is an ascii stl file 03375 //Author: Plamen Stoyanov (USF) 03376 //=========================================================================== 03377 CubitStatus OCCQueryEngine::ensure_is_ascii_stl_file(FILE * fp, CubitBoolean &is_ascii) 03378 { 03379 03380 char line[128]=""; 03381 03382 if (fgets(line, 128, fp)==NULL) 03383 { 03384 return CUBIT_FAILURE; 03385 } 03386 if (fgets(line, 128, fp)==NULL) 03387 { 03388 return CUBIT_FAILURE; 03389 } 03390 if (strlen(line)==127) 03391 { 03392 if (fgets(line, 128, fp)==NULL) 03393 { 03394 return CUBIT_FAILURE; 03395 } 03396 } 03397 03398 03399 unsigned int dummy_int=0; 03400 03401 while (isspace(line[dummy_int])&& dummy_int<strlen(line)) dummy_int++; 03402 03403 if (strlen(line)-dummy_int>5) 03404 { 03405 if (tolower(line[dummy_int++])=='f' && 03406 tolower(line[dummy_int++])=='a' && 03407 tolower(line[dummy_int++])=='c' && 03408 tolower(line[dummy_int++])=='e' && 03409 tolower(line[dummy_int])=='t') 03410 { 03411 if (fgets(line, 128, fp)==NULL) 03412 { 03413 return CUBIT_FAILURE; 03414 } 03415 dummy_int=0; 03416 while (isspace(line[dummy_int])&& dummy_int<strlen(line)) 03417 { 03418 dummy_int++; 03419 } 03420 if (strlen(line)-dummy_int>5) 03421 { 03422 if (tolower(line[dummy_int++])=='o' && 03423 tolower(line[dummy_int++])=='u' && 03424 tolower(line[dummy_int++])=='t' && 03425 tolower(line[dummy_int++])=='e' && 03426 tolower(line[dummy_int])=='r') 03427 { 03428 if (fgets(line, 128, fp)==NULL) 03429 { 03430 return CUBIT_FAILURE; 03431 } 03432 dummy_int=0; 03433 while (isspace(line[dummy_int])&& dummy_int<strlen(line)) { 03434 dummy_int++; 03435 } 03436 if (strlen(line)-dummy_int>6) 03437 { 03438 if (tolower(line[dummy_int++])=='v' && 03439 tolower(line[dummy_int++])=='e' && 03440 tolower(line[dummy_int++])=='r' && 03441 tolower(line[dummy_int++])=='t' && 03442 tolower(line[dummy_int++])=='e' && 03443 tolower(line[dummy_int])=='x') 03444 { 03445 is_ascii=CUBIT_TRUE; 03446 } 03447 } 03448 } 03449 } 03450 } 03451 } 03452 return CUBIT_SUCCESS; 03453 } 03454 03455 03456 //============================================================================= 03457 //Function: create_super_facet_bounding_box(PUBLIC) 03458 //Description: Find the bounding box of a list of BodySMs 03459 //Author: jdfowle 03460 //Date: 12/15/03 03461 //============================================================================= 03462 CubitStatus OCCQueryEngine::create_super_bounding_box( 03463 DLIList<BodySM*>& body_list, 03464 CubitBox& super_box ) 03465 { 03466 BodySM *bodySM; 03467 int i; 03468 CubitStatus status = CUBIT_SUCCESS; 03469 03470 body_list.reset(); 03471 for ( i = 0; i < body_list.size(); i++ ) { 03472 bodySM = body_list.get_and_step(); 03473 OCCBody* occBody = CAST_TO(bodySM, OCCBody); 03474 super_box |= occBody->get_bounding_box(); 03475 } 03476 03477 return status; 03478 } 03479 03480 CubitStatus OCCQueryEngine::restore_transform( BodySM* body ) 03481 { 03482 return CUBIT_FAILURE; 03483 } 03484 03485 CubitStatus OCCQueryEngine::translate( BodySM* body, const CubitVector& d ) 03486 { 03487 OCCBody* theBody = dynamic_cast<OCCBody*>(body); 03488 return theBody ? theBody->move( d.x(), d.y(), d.z() ) : CUBIT_FAILURE; 03489 } 03490 CubitStatus OCCQueryEngine::rotate( BodySM* body, const CubitVector& v, double a ) 03491 { 03492 // a is in degree. 03493 OCCBody* occ_bod = dynamic_cast<OCCBody*>(body); 03494 a *= CUBIT_PI/180; 03495 return occ_bod ? occ_bod->rotate( v.x(), v.y(), v.z(), a ) : CUBIT_FAILURE; 03496 } 03497 CubitStatus OCCQueryEngine::scale( BodySM* body, double factor ) 03498 { 03499 OCCBody* facetbod = dynamic_cast<OCCBody*>(body); 03500 return facetbod ? facetbod->scale( factor ) : CUBIT_FAILURE; 03501 } 03502 CubitStatus OCCQueryEngine::scale( BodySM* body, const CubitVector& f ) 03503 { 03504 OCCBody* facetbod = dynamic_cast<OCCBody*>(body); 03505 return facetbod ? facetbod->scale( f.x(), f.y(), f.z() ) : CUBIT_FAILURE; 03506 } 03507 03508 //------------------------------------------------------------------------- 03509 // Purpose : Transform a Solid, Surface, Curve, or Vertex 03510 // 03511 // Special Notes : 03512 // 03513 // Creator : Jane Hu 03514 // 03515 // Creation Date : 10/23/07 03516 //------------------------------------------------------------------------- 03517 CubitStatus OCCQueryEngine::translate( GeometryEntity* entity, 03518 const CubitVector& v ) 03519 { 03520 TopoDS_Shape * shape; 03521 if ((shape = get_TopoDS_Shape_of_entity(entity)) == NULL) 03522 { 03523 PRINT_ERROR( "problem occured getting OCC entity.\n" 03524 " Aborting.\n" ); 03525 return CUBIT_FAILURE; 03526 } 03527 03528 gp_Vec aVec(v.x(), v.y(),v.z()); 03529 gp_Trsf aTrsf; 03530 aTrsf.SetTranslation(aVec); 03531 03532 BRepBuilderAPI_Transform aBRepTrsf(*shape, aTrsf); 03533 03534 update_entity_shape(entity, &aBRepTrsf); 03535 return CUBIT_SUCCESS; 03536 } 03537 03538 CubitStatus OCCQueryEngine::update_entity_shape(GeometryEntity* entity_ptr, 03539 BRepBuilderAPI_ModifyShape* aBRepTrsf, 03540 BRepAlgoAPI_BooleanOperation *op) 03541 { 03542 if (OCCBody *body_ptr = CAST_TO( entity_ptr, OCCBody)) 03543 { 03544 body_ptr->update_OCC_entity(aBRepTrsf, op); 03545 return CUBIT_SUCCESS; 03546 } 03547 03548 else if( OCCSurface *surface_ptr = CAST_TO( entity_ptr, OCCSurface)) 03549 { 03550 surface_ptr->update_OCC_entity(aBRepTrsf, op); 03551 return CUBIT_SUCCESS; 03552 } 03553 03554 else if( OCCCurve *curve_ptr = CAST_TO( entity_ptr, OCCCurve)) 03555 { 03556 curve_ptr->update_OCC_entity(aBRepTrsf, op); 03557 return CUBIT_SUCCESS; 03558 } 03559 03560 else if( OCCPoint *point_ptr = CAST_TO( entity_ptr, OCCPoint)) 03561 { 03562 point_ptr->update_OCC_entity(aBRepTrsf, op); 03563 return CUBIT_SUCCESS; 03564 } 03565 03566 PRINT_ERROR("Non-OCC TopologyBridge at %s:%d.\n", __FILE__, __LINE__ ); 03567 return CUBIT_FAILURE; 03568 } 03569 03570 //a is angular value of rotation in radians 03571 CubitStatus OCCQueryEngine::rotate( GeometryEntity* entity, 03572 const CubitVector& v, double a ) 03573 { 03574 TopoDS_Shape * shape; 03575 if ((shape = get_TopoDS_Shape_of_entity(entity)) == NULL) 03576 { 03577 PRINT_ERROR( "problem occured getting OCC entity.\n" 03578 " Aborting.\n" ); 03579 return CUBIT_FAILURE; 03580 } 03581 03582 gp_Pnt aOrigin(0,0,0); 03583 gp_Dir aDir(v.x(), v.y(), v.z()); 03584 gp_Ax1 anAxis(aOrigin, aDir); 03585 03586 //a is angular value of rotation in radians 03587 gp_Trsf aTrsf; 03588 aTrsf.SetRotation(anAxis, a); 03589 03590 BRepBuilderAPI_Transform aBRepTrsf(*shape, aTrsf); 03591 update_entity_shape(entity, &aBRepTrsf); 03592 return CUBIT_SUCCESS; 03593 } 03594 03595 CubitStatus OCCQueryEngine::scale( GeometryEntity* entity, double f ) 03596 { 03597 TopoDS_Shape * shape; 03598 if ((shape = get_TopoDS_Shape_of_entity(entity)) == NULL) 03599 { 03600 PRINT_ERROR( "problem occured getting OCC entity.\n" 03601 " Aborting.\n" ); 03602 return CUBIT_FAILURE; 03603 } 03604 03605 gp_Trsf aTrsf; 03606 aTrsf.SetScaleFactor(f); 03607 03608 BRepBuilderAPI_Transform aBRepTrsf(*shape, aTrsf); 03609 update_entity_shape(entity, &aBRepTrsf); 03610 return CUBIT_SUCCESS; 03611 } 03612 03613 CubitStatus OCCQueryEngine::scale( GeometryEntity* entity, 03614 const CubitVector& v ) 03615 { 03616 TopoDS_Shape * shape; 03617 if ((shape = get_TopoDS_Shape_of_entity(entity)) == NULL) 03618 { 03619 PRINT_ERROR( "problem occured getting OCC entity.\n" 03620 " Aborting.\n" ); 03621 return CUBIT_FAILURE; 03622 } 03623 03624 gp_GTrsf gTrsf; 03625 gTrsf.SetValue(1,1, v.x()); 03626 gTrsf.SetValue(2,2, v.y()); 03627 gTrsf.SetValue(3,3, v.z()); 03628 03629 BRepBuilderAPI_GTransform gBRepTrsf(gTrsf); 03630 gBRepTrsf.Perform(*shape); 03631 update_entity_shape(entity, &gBRepTrsf); 03632 return CUBIT_SUCCESS; 03633 } 03634 03635 // like other engines here v is the normal of symmetric plane. 03636 CubitStatus OCCQueryEngine::reflect( GeometryEntity* entity, 03637 const CubitVector& v) 03638 { 03639 TopoDS_Shape * shape; 03640 if ((shape = get_TopoDS_Shape_of_entity(entity)) == NULL) 03641 { 03642 PRINT_ERROR( "problem occured getting OCC entity.\n" 03643 " Aborting.\n" ); 03644 return CUBIT_FAILURE; 03645 } 03646 03647 gp_Pnt aOrigin(0,0,0); 03648 gp_Dir aDir(v.x(), v.y(), v.z()); 03649 gp_Ax2 anAx2(aOrigin, aDir); 03650 03651 gp_Trsf aTrsf; 03652 aTrsf.SetMirror(anAx2); 03653 03654 BRepBuilderAPI_Transform aBRepTrsf(*shape, aTrsf); 03655 update_entity_shape(entity, &aBRepTrsf); 03656 return CUBIT_SUCCESS; 03657 } 03658 03659 //=============================================================================== 03660 // Function : bodies_overlap 03661 // Member Type: PUBLIC 03662 // Description: determine if OCC-based bodies overlap 03663 // Author : Jane Hu 03664 // Date : 10/07 03665 //=============================================================================== 03666 CubitBoolean OCCQueryEngine::bodies_overlap (BodySM * body_ptr_1, 03667 BodySM * body_ptr_2 ) const 03668 { 03669 OCCBody *occ_body1 = CAST_TO(body_ptr_1, OCCBody); 03670 if (!occ_body1) 03671 { 03672 PRINT_ERROR("Can't calculate intersection of non-OCC bodies."); 03673 return CUBIT_FALSE; 03674 } 03675 03676 OCCBody *occ_body2 = CAST_TO(body_ptr_2, OCCBody); 03677 if (!occ_body2) 03678 { 03679 PRINT_ERROR("Can't calculate intersection of non-OCC bodies."); 03680 return CUBIT_FALSE; 03681 } 03682 03683 CubitBox box_1 = occ_body1->get_bounding_box(); 03684 CubitBox box_2 = occ_body2->get_bounding_box(); 03685 if ( !box_1.overlap( GEOMETRY_RESABS, box_2 ) ) 03686 return CUBIT_FALSE; 03687 03688 TopoDS_Shape *shape1; 03689 occ_body1->get_TopoDS_Shape(shape1); 03690 TopoDS_Shape *shape2; 03691 occ_body2->get_TopoDS_Shape(shape2); 03692 03693 //BRepAlgoAPI_Section calculates intersection between faces only. 03694 TopExp_Explorer Ex1, Ex2; 03695 for (Ex1.Init(*shape1, TopAbs_SOLID); Ex1.More(); Ex1.Next()) 03696 { 03697 TopoDS_Solid *posolid1 = new TopoDS_Solid; 03698 *posolid1 = TopoDS::Solid(Ex1.Current()); 03699 OCCLump * lump1 = new OCCLump(posolid1); 03700 for (Ex2.Init(*shape2, TopAbs_SOLID); Ex2.More(); Ex2.Next()) 03701 { 03702 TopoDS_Solid *posolid2 = new TopoDS_Solid; 03703 *posolid2 = TopoDS::Solid(Ex2.Current()); 03704 OCCLump * lump2 = new OCCLump(posolid2); 03705 CubitBoolean is_overlap = volumes_overlap(lump1, lump2); 03706 if(is_overlap) 03707 return CUBIT_TRUE; 03708 } 03709 } 03710 return CUBIT_FALSE; 03711 } 03712 03713 CubitBoolean OCCQueryEngine::volumes_overlap (Lump *lump1, Lump *lump2 ) const 03714 { 03715 OCCLump *occ_lump1 = CAST_TO(lump1, OCCLump); 03716 if (!occ_lump1) 03717 { 03718 PRINT_ERROR("Can't calculate intersection of non-OCC solids."); 03719 return CUBIT_FALSE; 03720 } 03721 03722 OCCLump *occ_lump2 = CAST_TO(lump2, OCCLump); 03723 if (!occ_lump2) 03724 { 03725 PRINT_ERROR("Can't calculate intersection of non-OCC solids."); 03726 return CUBIT_FALSE; 03727 } 03728 03729 CubitBox box_1 = occ_lump1->bounding_box(); 03730 CubitBox box_2 = occ_lump2->bounding_box(); 03731 if ( !box_1.overlap( GEOMETRY_RESABS, box_2 ) ) 03732 return CUBIT_FALSE; 03733 03734 TopoDS_Shape *shape1 = (TopoDS_Shape*)(occ_lump1->get_TopoDS_Solid()); 03735 TopoDS_Shape *shape2 = (TopoDS_Shape*)(occ_lump2->get_TopoDS_Solid()); 03736 03737 //BRepAlgoAPI_Section calculates intersection between faces only. 03738 TopExp_Explorer Ex1, Ex2; 03739 for (Ex1.Init(*shape1, TopAbs_FACE); Ex1.More(); Ex1.Next()) 03740 { 03741 for (Ex2.Init(*shape2, TopAbs_FACE); Ex2.More(); Ex2.Next()) 03742 { 03743 BRepAlgoAPI_Section section(Ex1.Current(), Ex2.Current()); 03744 if (section.HasGenerated()) 03745 return CUBIT_TRUE; 03746 } 03747 } 03748 return CUBIT_FALSE; 03749 } 03750 03751 void OCCQueryEngine::copy_attributes(TopoDS_Shape& old_shape, 03752 TopoDS_Shape& new_shape) 03753 { 03754 if(new_shape.IsNull()) 03755 return; 03756 03757 //update the attribute label tree 03758 DLIList<CubitSimpleAttrib> list; 03759 OCCAttribSet::get_attributes(old_shape, list); 03760 03761 for(int i = 0; i < list.size(); i ++) 03762 { 03763 const CubitSimpleAttrib& s_attr = list.get_and_step(); 03764 TopAbs_ShapeEnum type = old_shape.ShapeType(); 03765 if(new_shape.ShapeType() < type) 03766 { 03767 TopTools_IndexedMapOfShape M; 03768 TopExp::MapShapes(new_shape, type, M); 03769 for(int j = 1; j <= M.Extent() ; j++ ) 03770 { 03771 TopoDS_Shape sub_shape = M(j); 03772 OCCAttribSet::append_attribute(s_attr, sub_shape); 03773 } 03774 } 03775 else 03776 OCCAttribSet::append_attribute(s_attr, new_shape); 03777 } 03778 } 03779 03780 int OCCQueryEngine::update_OCC_map(TopoDS_Shape& old_shape, 03781 TopoDS_Shape& new_shape) 03782 { 03783 if (old_shape.IsNull() || !OCCMap->IsBound(old_shape) || 03784 old_shape.IsEqual(new_shape)) 03785 return -1; 03786 03787 //update the attribute label tree 03788 int current_id = OCCMap->Find(old_shape); 03789 std::map<int, TDF_Label>::iterator it_lab = 03790 Shape_Label_Map->find(current_id); 03791 CubitBoolean newlyBound = CUBIT_FALSE; 03792 TopTools_IndexedMapOfShape M; 03793 TopoDS_Shape new_subshape; 03794 new_subshape.Nullify(); 03795 03796 if(old_shape.ShapeType() == TopAbs_SOLID) 03797 TopExp::MapShapes(new_shape, TopAbs_SOLID, M); 03798 else if (old_shape.ShapeType() == TopAbs_SHELL) 03799 TopExp::MapShapes(new_shape, TopAbs_SHELL, M); 03800 else if (old_shape.ShapeType() == TopAbs_FACE) 03801 TopExp::MapShapes(new_shape, TopAbs_FACE, M); 03802 03803 if(it_lab != Shape_Label_Map->end()) 03804 { 03805 CubitBoolean isNewShapeBound = CUBIT_FALSE; 03806 if(old_shape.ShapeType() > TopAbs_COMPOUND && !new_shape.IsNull() && 03807 new_shape.ShapeType() == TopAbs_COMPOUND && M.Extent() == 1) 03808 { 03809 new_subshape = M(1); 03810 isNewShapeBound = OCCMap->IsBound(new_subshape); 03811 copy_attributes(old_shape, new_subshape); 03812 Shape_Label_Map->erase(current_id); 03813 if(isNewShapeBound != OCCMap->IsBound(new_subshape)) 03814 newlyBound = CUBIT_TRUE; 03815 } 03816 else 03817 { 03818 isNewShapeBound = OCCMap->IsBound(new_shape); 03819 copy_attributes(old_shape, new_shape); 03820 Shape_Label_Map->erase(current_id); 03821 if(isNewShapeBound != OCCMap->IsBound(new_shape)) 03822 newlyBound = CUBIT_TRUE; 03823 } 03824 } 03825 03826 //update CGM-OCC map 03827 int k = current_id; 03828 assert (k > 0 && k <= iTotalTBCreated); 03829 03830 std::map<int, TopologyBridge*>::iterator it = OccToCGM->find(k); 03831 TopologyBridge* tb = NULL; 03832 if (it != OccToCGM->end()) 03833 tb = (*it).second; 03834 03835 //unless just changing location, if the TShape is going to change, remove 03836 //old curve_list . 03837 CubitBoolean curve_removed = CUBIT_FALSE; 03838 if(old_shape.ShapeType() == TopAbs_VERTEX && !new_shape.IsPartner(old_shape)) 03839 { 03840 //remove the curve list associated with the vertex too. 03841 GeometryEntity* ge = CAST_TO(tb, GeometryEntity); 03842 if (ge) 03843 { 03844 OCCPoint* test_p = CAST_TO(ge, OCCPoint); 03845 if(test_p) 03846 { 03847 test_p->clear_curves(); 03848 curve_removed = CUBIT_TRUE; 03849 } 03850 } 03851 } 03852 03853 OCCMap->UnBind(old_shape); 03854 if(new_subshape.IsNull()) 03855 new_subshape = new_shape; 03856 03857 if (tb && TopAbs_SOLID == old_shape.ShapeType() && !new_shape.IsNull() && 03858 TopAbs_COMPOUND == new_shape.ShapeType() && M.Extent() > 1) 03859 { 03860 OccToCGM->erase(k); 03861 GeometryEntity* ge = CAST_TO(tb, GeometryEntity); 03862 if(ge) 03863 delete_solid_model_entities( ge, CUBIT_TRUE); 03864 return k; 03865 } 03866 03867 else if(tb && TopAbs_FACE == old_shape.ShapeType() && !new_shape.IsNull() && 03868 TopAbs_COMPOUND == new_shape.ShapeType() && M.Extent() > 1) 03869 { 03870 GeometryEntity* ge = CAST_TO(tb, GeometryEntity); 03871 if(ge) 03872 { 03873 OCCSurface *face = CAST_TO(ge, OCCSurface); 03874 OCCShell* shell = face->my_shell(); 03875 if (shell) 03876 { 03877 TopoDS_Shell* shape = shell->get_TopoDS_Shell(); 03878 assert(!shape ); 03879 if (shape) { 03880 PRINT_ERROR("Unexpected non-NULL TopoDS_Shell pointer.\n"); 03881 return -1; 03882 } 03883 } 03884 OCCLump* lump = face->my_lump(); 03885 if(lump) 03886 { 03887 TopoDS_Solid* shape = lump->get_TopoDS_Solid(); 03888 assert(!shape ); 03889 if (shape) { 03890 PRINT_ERROR("Unexpected non-NULL TopoDS_Solid pointer.\n"); 03891 return -1; 03892 } 03893 delete lump; 03894 } 03895 OCCBody* body = face->my_body(); 03896 if (body) 03897 delete body; 03898 03899 delete_solid_model_entities(ge, CUBIT_TRUE); 03900 if(shell) 03901 delete shell; 03902 } 03903 return k; 03904 } 03905 03906 else if (tb && ((!new_subshape.IsNull() && !old_shape.IsSame(new_subshape)&& 03907 OCCMap->IsBound(new_subshape) && 03908 OccToCGM->find(OCCMap->Find(new_subshape))!= OccToCGM->end()) || 03909 new_subshape.IsNull())) 03910 //already has a TB built on new_shape 03911 { 03912 //delete the second TB corresponding to old_shape 03913 OccToCGM->erase(k); 03914 GeometryEntity* ge = CAST_TO(tb, GeometryEntity); 03915 if(ge) 03916 { 03917 //PRINT_INFO("TB: %p\n",ge); 03918 Lump* lump = CAST_TO(ge, Lump); 03919 if(lump) 03920 { 03921 BodySM* body = CAST_TO(lump,OCCLump)->get_body(); 03922 if(body) 03923 { 03924 //OCCBody* occ_body = CAST_TO(body, OCCBody); 03925 //TopoDS_Compound* pshape = occ_body->get_TopoDS_Shape(); 03926 //if(!pshape || pshape->IsNull()) 03927 delete_solid_model_entities(body); 03928 } 03929 } 03930 03931 else 03932 { 03933 OCCPoint* test_p = CAST_TO(ge, OCCPoint); 03934 if(test_p) 03935 test_p->clear_curves(); 03936 delete_solid_model_entities( ge, CUBIT_FALSE ); 03937 } 03938 } 03939 03940 else 03941 { 03942 ShellSM * shell = CAST_TO(tb, ShellSM); 03943 if(shell) 03944 { 03945 DLIList<OCCSurface*> memberSurfaces; 03946 OCCShell* occShell = CAST_TO(shell, OCCShell); 03947 memberSurfaces = occShell->getMemberSurfaces(); 03948 while (memberSurfaces.size()) 03949 { 03950 OCCSurface* memberSurf = memberSurfaces.pop(); 03951 if (SurfaceList->is_in_list(memberSurf)) 03952 // if the surface has not been unhooked and deleted 03953 memberSurf->set_shell((OCCShell*)NULL); 03954 } 03955 03956 OCCLump* lump = CAST_TO(shell, OCCShell)->my_lump(); 03957 if(lump && (lump->get_TopoDS_Solid() == NULL || 03958 !OCCMap->IsBound(*(lump->get_TopoDS_Solid())))) 03959 { 03960 delete CAST_TO(shell, OCCShell)->my_body(); 03961 delete lump; 03962 } 03963 unhook_ShellSM_from_OCC(shell); 03964 delete shell; 03965 return k; 03966 } 03967 LoopSM* loop = CAST_TO(tb, LoopSM); 03968 if(loop) 03969 { 03970 DLIList<OCCCoEdge*> children; 03971 children = CAST_TO(loop, OCCLoop)->coedges(); 03972 while(children.size()) 03973 { 03974 OCCCoEdge* coedge = children.pop(); 03975 CAST_TO(coedge->curve(), OCCCurve)->remove_loop(CAST_TO(loop, OCCLoop)); 03976 delete (OCCCoEdge*)coedge; 03977 } 03978 unhook_LoopSM_from_OCC(loop); 03979 delete loop; 03980 return k; 03981 } 03982 } 03983 } 03984 03985 else 03986 { 03987 //if the new_shape is bounded in copy_attribute, unbind it and rebind to 03988 //the old k 03989 if(newlyBound) 03990 { 03991 int new_k = OCCMap->Find(new_subshape); 03992 TDF_Label aLabel; 03993 CubitBoolean found = CUBIT_FALSE; 03994 OCCAttribSet::FindShape(new_subshape, aLabel, found); 03995 assert(found); 03996 Shape_Label_Map->erase(new_k); 03997 Shape_Label_Map->insert(labType(k, aLabel)); 03998 OCCMap->UnBind(new_subshape); 03999 } 04000 if(!OCCMap->IsBound(new_subshape)) 04001 OCCMap->Bind(new_subshape, k); 04002 if(tb && !curve_removed) 04003 set_TopoDS_Shape(tb, new_subshape); 04004 } 04005 return k; 04006 } 04007 04008 void OCCQueryEngine::unhook_coedges_of_a_curve(OCCCurve* curve, 04009 OCCLoop* loop)const 04010 { 04011 DLIList<OCCCoEdge*> coedges; 04012 DLIList<OCCCoEdge *> children ; 04013 if (loop != NULL) 04014 children = loop->coedges(); 04015 else 04016 { 04017 DLIList<OCCLoop*> loops; 04018 loops = curve->loops(); 04019 for (int i = 0; i < loops.size(); i ++) 04020 children += loops.get_and_step()->coedges(); 04021 } 04022 for(int j = 0; j < children.size(); j++) 04023 { 04024 OCCCoEdge* coedge = children.get_and_step(); 04025 if (coedge->curve() == curve) 04026 coedges.append(coedge); 04027 } 04028 unhook_CoEdges_from_OCC(coedges); 04029 } 04030 04031 void OCCQueryEngine::set_TopoDS_Shape(TopologyBridge* tb, 04032 TopoDS_Shape& shape) 04033 { 04034 BodySM* body = CAST_TO(tb, BodySM); 04035 if(body) 04036 return CAST_TO(body, OCCBody)->set_TopoDS_Shape(TopoDS::Compound(shape)); 04037 04038 Lump* lump = CAST_TO(tb, Lump); 04039 if(lump) 04040 return CAST_TO(lump, OCCLump)->set_TopoDS_Solid(TopoDS::Solid(shape)); 04041 04042 ShellSM* shell = CAST_TO(tb, ShellSM); 04043 if(shell) 04044 return CAST_TO(shell, OCCShell)->set_TopoDS_Shell(TopoDS::Shell(shape)); 04045 04046 Surface* surface = CAST_TO(tb, Surface); 04047 if (surface) 04048 return CAST_TO(surface, OCCSurface)->set_TopoDS_Face(TopoDS::Face(shape)); 04049 04050 LoopSM* loop = CAST_TO(tb, LoopSM); 04051 if(loop) 04052 return CAST_TO(loop, OCCLoop)->set_TopoDS_Wire(TopoDS::Wire(shape)); 04053 04054 Curve* curve = CAST_TO(tb, Curve); 04055 if (curve) 04056 return CAST_TO(curve, OCCCurve)->set_TopoDS_Edge(TopoDS::Edge(shape)); 04057 04058 TBPoint* point = CAST_TO(tb, TBPoint); 04059 if(point) 04060 return CAST_TO(point, OCCPoint)->set_TopoDS_Vertex(TopoDS::Vertex(shape)); 04061 04062 } 04063 04064 //Added by Jane Hu on 06/17/11 04065 void OCCQueryEngine::bound_TopoDS_Shape(const TopoDS_Shape & aShape) 04066 { 04067 (iTotalTBCreated)++; 04068 switch (aShape.ShapeType()) 04069 { 04070 case TopAbs_COMPOUND: 04071 OCCMap->Bind(TopoDS::Compound(aShape), iTotalTBCreated); 04072 break; 04073 case TopAbs_SOLID: 04074 OCCMap->Bind(TopoDS::Solid(aShape), iTotalTBCreated); 04075 break; 04076 case TopAbs_SHELL: 04077 OCCMap->Bind(TopoDS::Shell(aShape), iTotalTBCreated); 04078 break; 04079 case TopAbs_FACE: 04080 OCCMap->Bind(TopoDS::Face(aShape), iTotalTBCreated); 04081 break; 04082 case TopAbs_WIRE: 04083 OCCMap->Bind(TopoDS::Wire(aShape), iTotalTBCreated); 04084 break; 04085 case TopAbs_EDGE: 04086 OCCMap->Bind(TopoDS::Edge(aShape), iTotalTBCreated); 04087 break; 04088 case TopAbs_VERTEX: 04089 OCCMap->Bind(TopoDS::Vertex(aShape), iTotalTBCreated); 04090 break; 04091 04092 default: 04093 (iTotalTBCreated)--; 04094 } 04095 } 04096 //EOF
