cgma
00001 //- Class: PeriodicParamTool 00002 //------------------------------------------------------------------------- 00003 // Filename : PeriodicParamTool.cpp 00004 // 00005 // Purpose : Handles surfaces that have a periodic parameterization 00006 // Uses, but modifies, the underlying engine parameterization 00007 // 00008 // 00009 // Creator : Ray J. Meyers 00010 // 00011 // Creation Date : 12/15/2008 00012 // 00013 // Owner : Ray J. Meyers 00014 //------------------------------------------------------------------------- 00015 00016 #include "PeriodicParamTool.hpp" 00017 //#include "CastTo.hpp" 00018 #include "Surface.hpp" 00019 #include "CubitMessage.hpp" 00020 //#include "DLIList.hpp" 00021 00022 //------------------------------------------------------------------------- 00023 // Function: PeriodicParamTool 00024 // Description: constructor 00025 // Author: chynes 00026 // Date: 7/10/2002 00027 //------------------------------------------------------------------------- 00028 PeriodicParamTool::PeriodicParamTool(Surface *surf) 00029 { 00030 //- update private variables 00031 refSurf = surf; 00032 uOffset = 0.0; 00033 vOffset = 0.0; 00034 uPeriod = 0.0; 00035 vPeriod = 0.0; 00036 mirrorSurface = false; 00037 00038 } 00039 00040 //------------------------------------------------------------------------- 00041 // Function: PeriodicParamTool 00042 // Description: deconstructor 00043 // Author: chynes 00044 // Date: 7/10/2002 00045 //------------------------------------------------------------------------- 00046 PeriodicParamTool::~PeriodicParamTool() {} 00047 00048 //=================================================================================== 00049 // Function: set_up_space (Public) 00050 // Description: sets up space of flattening 00051 // Author: chynes 00052 // Date: 7/10/02 00053 //=================================================================================== 00054 CubitStatus PeriodicParamTool::set_up_space(double u_period, double v_period, double u_offset, double v_offset) 00055 { 00056 // store the u and periods 00057 00058 uPeriod = u_period; 00059 vPeriod = v_period; 00060 uOffset = u_offset; 00061 vOffset = v_offset; 00062 00063 00064 CubitStatus rv = CUBIT_SUCCESS; 00065 00066 return rv; 00067 } 00068 00069 //=================================================================================== 00070 // Function: transform_to_uv (Public) 00071 // Description: same as title, the local sizing will be returned in the z coord 00072 // Author: chynes 00073 // Date: 7/10/02 00074 //=================================================================================== 00075 CubitStatus PeriodicParamTool::transform_to_uv(const CubitVector &xyz_location, CubitVector &uv_location) 00076 { 00077 00078 double u,v; 00079 00080 CubitStatus rv = refSurf->u_v_from_position(xyz_location, u, v); 00081 00082 // offset values to avoid parameter discontinuity 00083 00084 if (uPeriod && u < uOffset) 00085 { 00086 u += uPeriod; 00087 } 00088 00089 // mirror surface if required to get correct loop orientation 00090 if (mirrorSurface) 00091 { 00092 u = -u; 00093 } 00094 00095 if (vPeriod && v < vOffset) 00096 { 00097 v += vPeriod; 00098 } 00099 00100 uv_location.set(u,v,1.0); 00101 00102 00103 return rv; 00104 } 00105 00106 //=================================================================================== 00107 // Function: transform_to_xyz (Public) 00108 // Description: same as title 00109 // Author: chynes 00110 // Date: 7/10/02 00111 //=================================================================================== 00112 CubitStatus PeriodicParamTool::transform_to_xyz(CubitVector &xyz_location, const CubitVector &uv_location) 00113 { 00114 double u = uv_location.x(); 00115 if (mirrorSurface) 00116 { 00117 u = -u; 00118 } 00119 if (u > uPeriod) 00120 { 00121 u = u - uPeriod; 00122 } 00123 double v = uv_location.y(); 00124 if (v > vPeriod) 00125 { 00126 v = v - vPeriod; 00127 } 00128 xyz_location = refSurf->position_from_u_v(u,v); 00129 00130 00131 return CUBIT_SUCCESS; 00132 } 00133 00134 void PeriodicParamTool::mirror_surface(bool true_false) 00135 { 00136 mirrorSurface = true_false; 00137 if (mirrorSurface) 00138 PRINT_INFO("Loops appear backwards, mirroring surface...\n"); 00139 00140 } 00141 00142 CubitStatus PeriodicParamTool::uv_derivitives(double u_param, double v_param, 00143 CubitVector &du, CubitVector &dv) 00144 { 00145 if (mirrorSurface) 00146 u_param = -u_param; 00147 if (u_param > uPeriod) 00148 u_param = u_param-uPeriod; 00149 if (v_param > vPeriod) 00150 v_param = v_param-vPeriod; 00151 refSurf->uv_derivitives(u_param, v_param, du, dv); 00152 return CUBIT_SUCCESS; 00153 } 00154 //EOF
