cgma
00001 #ifndef __CUBITATTRIBMANAGER_HPP__ 00002 #define __CUBITATTRIBMANAGER_HPP__ 00003 00004 class RefEntity; 00005 class CubitAttrib; 00006 class CubitAttribUser; 00007 class CubitSimpleAttrib; 00008 00009 #include "CubitDefines.h" 00010 #include "DLIList.hpp" 00011 #include "CubitString.hpp" 00012 #include "CGMGeomConfigure.h" 00013 00014 #if defined(_MSC_VER) 00015 #pragma warning(push) 00016 #pragma warning(disable : 4251) // hide warnings about template dll exports 00017 #endif 00018 00019 #include <map> 00020 00021 typedef CubitAttrib* (*CACreateFunction)(RefEntity*, const CubitSimpleAttrib&); 00022 00023 class CUBIT_GEOM_EXPORT CubitAttribManager 00024 { 00025 public: 00026 CubitAttribManager(); 00027 virtual ~CubitAttribManager(); 00028 00029 // stores factory function and settings for an attribute 00030 // returns a key that can be used to refer to the attribute type to avoid search by name 00031 CubitStatus register_attrib_type( const int att_type, 00032 const char* att_type_name, 00033 const char* att_internal_name, 00034 CACreateFunction p_create_function, 00035 CubitBoolean auto_actuate_flag, 00036 CubitBoolean auto_update_flag, 00037 CubitBoolean auto_write_flag, 00038 CubitBoolean auto_read_flag, 00039 CubitBoolean actuate_in_constructor, 00040 CubitBoolean actuate_after_geom_changes); 00041 // actuateInConstructor flag: if this flag is set to true, 00042 // this attribute will be actuated in a constructor, otherwise 00043 // it will be actuated after a geometry operation or geometry 00044 // import; usually, attributes which need full topological information 00045 // must be actuated after the geometry operation is finished 00046 // 00047 // actuateAfterGeomChanges flag: if this flag is set to true, 00048 // this attribute will be actuated only after all changes to geometry 00049 // have been done. Implies that if an attribute changes geometry, 00050 // or if it doesn't matter, this flag should be false (the default value); 00051 // if it requires the geometry to be in its final state, this flag 00052 // should be true 00053 00054 void get_registered_types(DLIList<int> &types); 00055 00056 CubitAttrib *create_cubit_attrib(const int attrib_type, 00057 RefEntity *attrib_user, 00058 const CubitSimpleAttrib& p_csa); 00059 00060 const char * att_internal_name(int attrib_type); 00061 00062 CubitBoolean auto_actuate_flag(int attrib_type); 00063 CubitStatus set_auto_actuate_flag(int attrib_type, CubitBoolean value); 00064 void set_all_auto_actuate_flags(CubitBoolean value); 00065 00066 CubitBoolean auto_update_flag(int attrib_type); 00067 CubitStatus set_auto_update_flag(int attrib_type, CubitBoolean value); 00068 void set_all_auto_update_flags(CubitBoolean value); 00069 00070 CubitBoolean auto_write_flag(int attrib_type); 00071 CubitStatus set_auto_write_flag(int attrib_type, CubitBoolean value); 00072 void set_all_auto_write_flags(CubitBoolean value); 00073 00074 CubitBoolean auto_read_flag(int attrib_type); 00075 CubitStatus set_auto_read_flag(int attrib_type, CubitBoolean value); 00076 void set_all_auto_read_flags(CubitBoolean value); 00077 00078 CubitBoolean actuate_in_constructor(int attrib_type); 00079 CubitBoolean actuate_after_geom_changes(int attrib_type); 00080 00081 CubitStatus auto_update_attribs(RefEntity *cau); 00082 00083 // CubitStatus actuate_list(DLIList<CubitAttribUser*> entity_list); 00084 00085 int attrib_type(const CubitSimpleAttrib &csa_ptr); 00086 int attrib_type(const char* name); 00087 int attrib_type_from_internal_name(const char* name); 00088 00089 // void clear_attrib_importeds() ; 00090 // void report_attrib_importeds(); 00091 00092 int auto_flag(); 00093 void auto_flag(int flag); 00094 00095 bool silent_flag() {return silentFlag;} 00096 void silent_flag(const bool flag) {silentFlag = flag;} 00097 00098 const char * att_name(int attrib_type); 00099 00100 private: 00101 /* 00102 class CARegisterData 00103 { 00104 public: 00105 CARegisterData(const char *type_name, const char *internal_name, 00106 CACreateFunction p_func, unsigned int flags) 00107 { 00108 mTypeName = type_name; 00109 mInternalName = internal_name; 00110 mCreateFunction = p_func; 00111 mFlags = flags; 00112 } 00113 00114 ~CARegisterData(); 00115 00116 CubitString mTypeName; 00117 CubitString mInternalName; 00118 CACreateFunction mCreateFunction; 00119 unsigned int mFlags; 00120 }; 00121 00122 #define CA_AUTOACTUATE 0x01 00123 #define CA_AUTOUPDATE 0x02 00124 #define CA_AUTOWRITE 0x04 00125 #define CA_AUTOREAD 0x08 00126 #define CA_ACTUATEINCONSTRUCTOR 0x10 00127 #define CA_ACTUATEAFTERGEOMCHANGES 0x20 00128 00129 std::map<int, CARegisterData*> mTypeToCAData; 00130 //struct ltstr 00131 //{ 00132 // bool operator()(const char* s1, const char* s2) const 00133 // { 00134 // return strcmp(s1, s2) < 0; 00135 // } 00136 //}; 00137 // std::map<const char*, int, ltstr> mTypeNameToType; 00138 // std::map<const char*, int, ltstr> mInternalNameToType; 00139 */ 00140 00141 DLIList<int> mTypes; 00142 DLIList<char*> mTypeNames; 00143 DLIList<char*> mInternalNames; 00144 DLIList<CACreateFunction> mCreatorFunctions; 00145 DLIList<CubitBoolean> mAutoActuateFlags; 00146 DLIList<CubitBoolean> mAutoUpdateFlags; 00147 DLIList<CubitBoolean> mAutoWriteFlags; 00148 DLIList<CubitBoolean> mAutoReadFlags; 00149 DLIList<CubitBoolean> mActuateInConstructor; 00150 DLIList<CubitBoolean> mActuateAfterGeomChanges; 00151 00152 // TODO - get rid of mAttribImported 00153 // DLIList<CubitBoolean> mAttribImported; 00154 00155 bool silentFlag; 00156 00157 }; 00158 00159 #if defined(_MSC_VER) 00160 #pragma warning(pop) 00161 #endif 00162 00163 #endif //__CUBITATTRIBMANAGER_HPP__ 00164
