cgma
00001 #include "FacetProjectTool.hpp" 00002 #include "PST_Data.hpp" 00003 #include "GeometryDefines.h" 00004 #include "CubitMessage.hpp" 00005 #include "CubitPlane.hpp" 00006 00007 #include "GfxDebug.hpp" /* for debugging output */ 00008 00009 const int VG_FACET_DEBUG = 145; 00010 const int VG_FACET_BOUNDARY_COLOR = CUBIT_RED_INDEX; 00011 const int VG_FACET_FACET_COLOR = CUBIT_GREEN_INDEX; 00012 const int VG_FACET_IMPRINT_COLOR = CUBIT_WHITE_INDEX; 00013 const int VG_FACET_SEGMENT_COLOR = CUBIT_CYAN_INDEX; 00014 #define VG_FACET_PRINT PRINT_DEBUG(VG_FACET_DEBUG) 00015 00016 00017 //------------------------------------------------------------------------- 00018 // Purpose : Constructor 00019 // 00020 // Special Notes : 00021 // 00022 // Creator : Jason Kraftcheck 00023 // 00024 // Creation Date : 05/11/02 00025 //------------------------------------------------------------------------- 00026 FacetProjectTool::FacetProjectTool( ) 00027 { } 00028 00029 00030 static int parent_compare_facets( PST_Face*& f1, PST_Face*& f2 ) 00031 { 00032 return (f1->parent < f2->parent) ? -1 : 00033 (f1->parent > f2->parent) ? 1 : 0; 00034 } 00035 static int sequence_compare_pts( PST_Point*& p1, PST_Point*& p2 ) 00036 { 00037 return (p1->sequence < p2->sequence) ? -1 : 00038 (p1->sequence > p2->sequence) ? 1 : 0; 00039 } 00040 00041 //------------------------------------------------------------------------- 00042 // Purpose : takes a list of edge segments and a surface and returns 00043 // the new facets, dudded facets, new points, and new edges 00044 // Special Notes : 00045 // 00046 // 00047 // Creator : John Fowler 00048 // 00049 // Creation Date : 12/03/02 00050 //------------------------------------------------------------------------- 00051 CubitStatus FacetProjectTool::project( 00052 DLIList<CubitVector*>& segments, // in 00053 const std::vector<double>& coordinates, // in 00054 const std::vector<int>& connections, // in 00055 std::vector<int>& duddedFacets, // out 00056 std::vector<int>& newFacets, // out 00057 std::vector<int>& newFacetsIndex, // out 00058 std::vector<double>& newPoints, // out 00059 std::vector<int>& edges, // out 00060 std::vector<int>& segmentPoints, 00061 const double *tolerance_length 00062 ) 00063 { 00064 int i; 00065 // const double TOL_SQR = GEOMETRY_RESABS*GEOMETRY_RESABS; 00066 00067 assert(connections.size()%3 == 0); // For triangles these must be triples 00068 assert(coordinates.size()%3 == 0); // Coordinates must come in triples 00069 DLIList<PST_Edge*> facet_edges; 00070 00071 // make the PST edges and faces from the coordinates and connections. 00072 PST_Edge::make_facets( coordinates, connections, GEOMETRY_RESABS, facet_edges ); 00073 DLIList<PST_Face*> faces; 00074 00075 CubitStatus success = CUBIT_SUCCESS; 00076 if(facet_edges.size() > 0) 00077 { 00078 00079 PST_Edge::faces( facet_edges, faces ); 00080 populate_data(faces); 00081 00082 // Order the orignal points by sequence number. New points 00083 // will be appended in order. 00084 pointList.sort(&sequence_compare_pts); 00085 00086 // Do the work 00087 CubitBoolean point_changed; 00088 success = do_projection(segments, point_changed, tolerance_length); 00089 00090 bool debug = false; 00091 if( debug ) 00092 { 00093 GfxDebug::clear(); 00094 for( int j=0; j<facetList.size(); j++ ) 00095 facetList.get_and_step()->debug_draw( CUBIT_CYAN_INDEX ); 00096 GfxDebug::mouse_xforms(); 00097 } 00098 00099 // fill in segmentPoints 00100 // assert (segPoints.size() == segments.size()); 00101 segmentPoints.resize( segPoints.size() ); 00102 segPoints.reset(); 00103 for ( i = 0; i < segPoints.size(); i++ ) 00104 { 00105 PST_Point* pt = segPoints.get_and_step(); 00106 segmentPoints[i] = pt ? pt->sequence : -1; 00107 if (point_changed) 00108 success = CUBIT_FAILURE; 00109 } 00110 } 00111 else 00112 success = CUBIT_FAILURE; 00113 00114 if (!success) 00115 { 00116 cleanup(); 00117 return success; 00118 } 00119 00120 // Now put the points with sequence > coordinates.size()/3 in newPoints. 00121 int orig_num_points = coordinates.size()/3; 00122 int num_new_points = pointList.size() - orig_num_points; 00123 pointList.reset(); 00124 pointList.step(orig_num_points); 00125 newPoints.resize(num_new_points*3); 00126 std::vector<double>::iterator ditor = newPoints.begin(); 00127 while( num_new_points-- ) { 00128 PST_Point* pt = pointList.get_and_step(); 00129 *ditor++ = pt->x(); 00130 *ditor++ = pt->y(); 00131 *ditor++ = pt->z(); 00132 } 00133 00134 if ( facetList.size() > 1 ) { // If only one facet, skip finding dudded facets 00135 // Sort (group) facets by parent. 00136 facetList.sort(&parent_compare_facets); 00137 00138 // Fill in the duddedFacets, newFacets, and newFacetsIndex vectors. 00139 00140 #ifndef NDEBUG 00141 int orig_num_facets = connections.size()/3; 00142 #endif 00143 int new_facet_index = 0; 00144 DLIList<PST_Point*> facet_pts(3); 00145 00146 facetList.reset(); 00147 duddedFacets.clear(); 00148 newFacetsIndex.clear(); 00149 newFacets.clear(); 00150 00151 for ( i = facetList.size(); i > 0; ) { 00152 PST_Face* dudded_facet = 0; 00153 if( facetList.get()->parent != facetList.next()->parent ) { 00154 00155 // unmodified original facet - skip it 00156 #ifndef NDEBUG 00157 PST_Face* facet = facetList.get(); 00158 assert(facet->sequence < orig_num_facets && 00159 facet->sequence == facet->parent); 00160 #endif 00161 facetList.step(); 00162 i--; 00163 } 00164 else { 00165 // new facets 00166 00167 // put all new facets split from the 00168 // same original facet (having same parent), 00169 // including the orignal facet which was 00170 // recycled, into newFacets 00171 PST_Face* facet = 0; 00172 do { 00173 facet = facetList.get_and_step(); 00174 i--; 00175 00176 if ( facet->parent == facet->sequence ) { 00177 assert(!dudded_facet); 00178 dudded_facet = facet; 00179 } 00180 00181 facet_pts.clean_out(); 00182 facet->append_points(facet_pts); 00183 facet_pts.reset(); 00184 newFacets.push_back(facet_pts.get_and_step()->sequence); 00185 newFacets.push_back(facet_pts.get_and_step()->sequence); 00186 newFacets.push_back(facet_pts.get_and_step()->sequence); 00187 new_facet_index += 3; 00188 } while ( (facet->parent == facetList.get()->parent) && (i > 0) ); 00189 00190 // add replaced facet to duddedFacets 00191 assert(dudded_facet && dudded_facet->sequence < orig_num_facets); 00192 duddedFacets.push_back(dudded_facet->sequence); 00193 // add end position in new_facets for the 00194 // set of replacement facets to newFacetsIndex 00195 newFacetsIndex.push_back(new_facet_index); 00196 } 00197 } 00198 } 00199 00200 DLIList<PST_CoEdge*> coedge_list; 00201 edges.clear(); 00202 finalize_results(); 00203 while( get_result_set(coedge_list) ) { 00204 00205 // add count and first point 00206 coedge_list.reset(); 00207 edges.push_back(coedge_list.size() + 1); 00208 PST_Point* pt = coedge_list.get()->start_point(); 00209 edges.push_back(pt->sequence); 00210 00211 // add all other points 00212 for( i = coedge_list.size(); i--; ) { 00213 pt = coedge_list.get_and_step()->end_point(); 00214 edges.push_back(pt->sequence); 00215 } 00216 00217 // clean up for next iteration 00218 coedge_list.clean_out(); 00219 } 00220 edges.push_back(0); // terminating zero for next segment length 00221 00222 cleanup(); 00223 return CUBIT_SUCCESS; 00224 } 00225 00226 00227 //------------------------------------------------------------------------- 00228 // Purpose : fills in the data 00229 // 00230 // Special Notes : populate private data lists and set marks on facet 00231 // entities 00232 // 00233 // Creator : Jason Kraftcheck, modified by John Fowler -- 00234 // used to be the class constructor 00235 // 00236 // Creation Date : 05/11/02, 12/03/02 00237 //------------------------------------------------------------------------- 00238 CubitStatus FacetProjectTool::populate_data( const DLIList<PST_Face*>& facets ) 00239 { 00240 facetList = facets; 00241 int i; 00242 00243 // Mark all connected edges with a 3, and initialize 00244 // parent number to sequence number. 00245 facetList.last(); 00246 for( i = facetList.size(); i--; ) 00247 { 00248 PST_Face* face = facetList.step_and_get(); 00249 face->parent = face->sequence; 00250 PST_CoEdge* coe = face->first_coedge(); 00251 do 00252 { 00253 coe->edge()->mark = 3; 00254 coe = coe->next(); 00255 } while( coe != face->first_coedge() ); 00256 } 00257 00258 // Decrement the edge mark by one for each 00259 // face that contains the edge. 00260 for( i = facetList.size(); i--; ) 00261 { 00262 PST_Face* face = facetList.step_and_get(); 00263 PST_CoEdge* coe = face->first_coedge(); 00264 do 00265 { 00266 coe->edge()->mark--; 00267 coe = coe->next(); 00268 } while( coe != face->first_coedge() ); 00269 } 00270 00271 // Populate edgeList and boundaryList with edges 00272 for( i = facetList.size(); i--; ) 00273 { 00274 PST_Face* face = facetList.step_and_get(); 00275 PST_CoEdge* coe = face->first_coedge(); 00276 do 00277 { 00278 PST_Edge* edge = coe->edge(); 00279 // If mark is 2, edge was only in one face in the 00280 // passed list, and is thus on the boundary of the 00281 // passed patch of faces. 00282 if( edge->mark == 2 ) 00283 { 00284 boundaryList.append( edge ); 00285 edgeList.append( edge ); 00286 edge->mark = 0; 00287 } 00288 // If mark is 1, the edge is an interior edge in the 00289 // patch of faces 00290 else if( edge->mark == 1 ) 00291 { 00292 edgeList.append( edge ); 00293 edge->mark = 0; 00294 } 00295 // If the mark on the edge is zero, we have already 00296 // added it to the list(s). 00297 else 00298 { 00299 assert( edge->mark == 0 ); 00300 } 00301 00302 coe = coe->next(); 00303 } while( coe != face->first_coedge() ); 00304 } 00305 00306 // Get all the points 00307 PST_Edge::points( edgeList, pointList ); 00308 00309 // Clear marks on all faces connected to our edge 00310 // list (the passed faces and any faces connected 00311 // at the boundary edges.) 00312 for( i = edgeList.size(); i--; ) 00313 { 00314 PST_Edge* edge = edgeList.step_and_get(); 00315 edge->mark = 0; 00316 if( edge->forward()->face() ) 00317 edge->forward()->face()->mark = 0; 00318 if( edge->reverse()->face() ) 00319 edge->reverse()->face()->mark = 0; 00320 } 00321 00322 // clear marks on faces 00323 for( i = facetList.size(); i--; ) 00324 facetList.step_and_get()->mark = 0; 00325 // Set mark to 1 on boundary edges 00326 for( i = boundaryList.size(); i--; ) 00327 boundaryList.step_and_get()->mark = 1; 00328 00329 if( DEBUG_FLAG( VG_FACET_DEBUG ) ) 00330 { 00331 // PST_Face::draw_faces( facetList, VG_FACET_FACET_COLOR, false ); 00332 PST_Edge::debug_draw_edges( boundaryList, VG_FACET_BOUNDARY_COLOR ); 00333 } 00334 00335 return CUBIT_SUCCESS; 00336 } 00337 00338 //------------------------------------------------------------------------- 00339 // Purpose : Find the face for which the projection of the passed 00340 // position onto the face is closest to the passed 00341 // position. 00342 // 00343 // Special Notes : 00344 // 00345 // Creator : Jason Kraftcheck 00346 // 00347 // Creation Date : 05/11/02 00348 //------------------------------------------------------------------------- 00349 PST_Face* FacetProjectTool::closest_face( const CubitVector& position ) 00350 { 00351 PST_Face* result = 0; 00352 double dist_sqr = 0; 00353 CubitVector projected; 00354 00355 for( int i = facetList.size(); i--; ) 00356 { 00357 PST_Face* facet = facetList.step_and_get(); 00358 if( project_to_face( facet, position, projected ) ) 00359 { 00360 double d = (projected - position).length_squared(); 00361 if( !result || d < dist_sqr ) 00362 { 00363 result = facet; 00364 dist_sqr = d; 00365 } 00366 } 00367 } 00368 00369 return result; 00370 } 00371 00372 00373 //------------------------------------------------------------------------- 00374 // Purpose : Find the edge for which the projection of the passed 00375 // position onto the edge is closest to the passed 00376 // position. 00377 // 00378 // Special Notes : 00379 // 00380 // Creator : Jason Kraftcheck 00381 // 00382 // Creation Date : 05/11/02 00383 //------------------------------------------------------------------------- 00384 PST_Edge* FacetProjectTool::closest_edge( const CubitVector& position ) 00385 { 00386 PST_Edge* result = 0; 00387 double dist_sqr = 0; 00388 00389 for( int i = edgeList.size(); i--; ) 00390 { 00391 PST_Edge* edge = edgeList.step_and_get(); 00392 00393 double t = edge->closest_on_line( position ); 00394 if( (t > -CUBIT_RESABS) && (t < (1.0 + CUBIT_RESABS)) ) 00395 { 00396 double d = (edge->position(t) - position).length_squared(); 00397 if( !result || d < dist_sqr ) 00398 { 00399 result = edge; 00400 dist_sqr = d; 00401 } 00402 } 00403 } 00404 00405 return result; 00406 } 00407 00408 //------------------------------------------------------------------------- 00409 // Purpose : Find the point closest to the passed position. 00410 // 00411 // Special Notes : 00412 // 00413 // Creator : Jason Kraftcheck 00414 // 00415 // Creation Date : 05/11/02 00416 //------------------------------------------------------------------------- 00417 PST_Point* FacetProjectTool::closest_point( const CubitVector& position ) 00418 { 00419 PST_Point* result = 0; 00420 double dist_sqr = 0; 00421 00422 for( int i = pointList.size(); i--; ) 00423 { 00424 PST_Point* pt = pointList.step_and_get(); 00425 double d = (position - *pt).length_squared(); 00426 if( !result || d < dist_sqr ) 00427 { 00428 dist_sqr = d; 00429 result = pt; 00430 } 00431 } 00432 00433 return result; 00434 } 00435 00436 00437 //------------------------------------------------------------------------- 00438 // Purpose : Project the passed position onto the plane of the 00439 // passed facet. Returns false if projection is outside 00440 // the facet. 00441 // 00442 // Special Notes : "result" is unchanged if false is returned. 00443 // 00444 // Creator : Jason Kraftcheck 00445 // 00446 // Creation Date : 05/11/02 00447 //------------------------------------------------------------------------- 00448 bool FacetProjectTool::project_to_face( PST_Face* triangle, 00449 const CubitVector& position, 00450 CubitVector& result ) 00451 { 00452 // First check if projection of the point will be within 00453 // the bounds of the triangle. 00454 if( ! inside_face( triangle, position ) ) 00455 return false; 00456 00457 // Calculate the actual projection 00458 result = triangle->plane().project( position ); 00459 return true; 00460 } 00461 00462 //------------------------------------------------------------------------- 00463 // Purpose : Destructor. Clear marks on all facet entities. 00464 // 00465 // Special Notes : 00466 // 00467 // Creator : Jason Kraftcheck 00468 // 00469 // Creation Date : 05/11/02 00470 //------------------------------------------------------------------------- 00471 FacetProjectTool::~FacetProjectTool() 00472 { 00473 cleanup(); 00474 } 00475 00476 00477 //------------------------------------------------------------------------- 00478 // Purpose : clean out internal data 00479 // 00480 // Special Notes : 00481 // 00482 // Creator : Jason Kraftcheck 00483 // 00484 // Creation Date : 02/13/03 00485 //------------------------------------------------------------------------- 00486 void FacetProjectTool::cleanup() 00487 { 00488 while( pointList.size() ) 00489 delete pointList.pop(); 00490 facetList.clean_out(); 00491 edgeList.clean_out(); 00492 boundaryList.clean_out(); 00493 imprintResult.clean_out(); 00494 segPoints.clean_out(); 00495 } 00496 00497 00498 //------------------------------------------------------------------------- 00499 // Purpose : Inset a point in the interior of a facet. 00500 // 00501 // Special Notes : Assumes input facet is a triangle, and splits facet 00502 // as necessary to ensure that resulting facets are tris. 00503 // 00504 // Creator : Jason Kraftcheck 00505 // 00506 // Creation Date : 05/11/02 00507 //------------------------------------------------------------------------- 00508 PST_Point* FacetProjectTool::insert_in_face( PST_Face* face, 00509 const CubitVector& position ) 00510 { 00511 PST_Point* new_point = new PST_Point( position ); 00512 PST_CoEdge* ce1 = face->first_coedge(); 00513 PST_CoEdge* ce2 = ce1->next(); 00514 PST_CoEdge* ce3 = ce2->next(); 00515 00516 // insert non-mainifold edge in face after ce1 00517 PST_Edge* edge1 = PST_Edge::insert_in_face( new_point, ce1 ); 00518 if( ! edge1 ) 00519 { 00520 delete new_point; 00521 return 0; 00522 } 00523 new_point->sequence = pointList.size(); 00524 pointList.append(new_point); 00525 edgeList.append( edge1 ); 00526 if( DEBUG_FLAG( VG_FACET_DEBUG ) ) 00527 edge1->debug_draw( VG_FACET_FACET_COLOR ); 00528 00529 // connect non-manifold edge to opposite side of the face 00530 // to make manifold topology. 00531 PST_Edge* edge2 = PST_Edge::split_face( ce2, edge1->start_point() == new_point ? 00532 edge1->reverse() : edge1->forward() ); 00533 if( ! edge2 ) return new_point; 00534 edgeList.append( edge2 ); 00535 PST_Face* new_face = edge2->other(face); 00536 new_face->sequence = facetList.size(); 00537 new_face->parent = face->parent; 00538 facetList.append( new_face ); 00539 if( face->owner() ) 00540 face->owner()->notify_split( face, new_face ); 00541 00542 if( DEBUG_FLAG( VG_FACET_DEBUG ) ) 00543 edge2->debug_draw( VG_FACET_FACET_COLOR ); 00544 00545 // Split face so that all faces are triangles. 00546 PST_Face* split_face = ce3->face(); 00547 PST_Edge* edge3 = PST_Edge::split_face( new_point, ce3->end_point(), split_face ); 00548 if( edge3 ) 00549 { 00550 edgeList.append( edge3 ); 00551 new_face = edge3->other(split_face); 00552 new_face->sequence = facetList.size(); 00553 new_face->parent = face->parent; 00554 facetList.append( new_face ); 00555 if( split_face->owner() ) 00556 split_face->owner()->notify_split( split_face, new_face ); 00557 } 00558 00559 return new_point; 00560 } 00561 00562 00563 //------------------------------------------------------------------------- 00564 // Purpose : Add a point where the passed position is projected 00565 // into the facet patch. 00566 // 00567 // Special Notes : May return NULL if projection does not lie within 00568 // facet patch. 00569 // 00570 // Creator : Jason Kraftcheck 00571 // 00572 // Creation Date : 05/11/02 00573 //------------------------------------------------------------------------- 00574 PST_Point* FacetProjectTool::project( const CubitVector& pos, 00575 const double* tolerance_length ) 00576 { 00577 PST_Point* point = closest_point( pos ); 00578 PST_Edge * edge = closest_edge ( pos ); 00579 PST_Face * face = closest_face ( pos ); 00580 00581 // find closest facet 00582 double face_dist = CUBIT_DBL_MAX; 00583 CubitVector face_pos; 00584 if( face ) 00585 { 00586 project_to_face( face, pos, face_pos ); 00587 face_dist = (pos - face_pos).length_squared(); 00588 } 00589 00590 // find closest edge 00591 double edge_dist = CUBIT_DBL_MAX; 00592 double edge_pos = CUBIT_DBL_MAX; 00593 if( edge ) 00594 { 00595 edge_pos = edge->closest_on_edge( pos ); 00596 edge_dist = (pos - edge->position(edge_pos)).length_squared(); 00597 } 00598 00599 // find closest point 00600 double point_dist = CUBIT_DBL_MAX; 00601 if( point ) 00602 { 00603 point_dist = (pos - *point).length_squared(); 00604 } 00605 00606 // if the position is closer to a facet than a point or edge... 00607 if( face && (face_dist < point_dist) && (face_dist < edge_dist) ) 00608 { 00609 // get a tolerance based on a sample face size. I attempted 00610 // to do this with a representative facet size but still 00611 // ended up with problems. While this is slower is more 00612 // robust. KGM 00613 double facet_length; 00614 00615 if(tolerance_length) 00616 { 00617 facet_length = *tolerance_length; 00618 } 00619 else 00620 { 00621 facet_length = face->bounding_length(); 00622 } 00623 00624 // use the square of the facet length times an arbitrary factor to 00625 // determine the tolerance 00626 double tol_sqr = facet_length*facet_length*.00001; 00627 00628 // check if projected position is within tolerance of 00629 // any bounding edge of the face. 00630 PST_CoEdge* coe = face->first_coedge(); 00631 bool insert = true; 00632 do { 00633 PST_Edge* e = coe->edge(); 00634 CubitVector p = e->position( e->closest_on_line( face_pos ) ); 00635 double d = (p - face_pos).length_squared(); 00636 00637 // use a relative tolerance here - KGM 00638 if( d < tol_sqr ) 00639 { 00640 edge = e; 00641 edge_pos = edge->closest_on_edge( pos ); 00642 face_dist = d; 00643 edge_dist = d; 00644 insert = false; 00645 } 00646 coe = coe->next(); 00647 } while( coe != face->first_coedge() ); 00648 00649 // If projected position was sufficiently far from the edges 00650 // of the facet, insert an interior point in the facet. Otherwise 00651 // fall through and split edge. 00652 if( insert ) 00653 { 00654 return insert_in_face( face, face_pos ); 00655 } 00656 } 00657 00658 // If the point was closer to an edge than a point 00659 if( edge && (edge_dist <= point_dist) ) 00660 { 00661 // If within tolerance of an end point of the edge, return 00662 // the end point. 00663 CubitVector pt = edge->position( edge_pos ); 00664 if( (pt - *edge->start_point()).length_squared() < GEOMETRY_RESABS*GEOMETRY_RESABS ) 00665 point = edge->start_point(); 00666 else if( (pt - *edge->end_point()).length_squared() < GEOMETRY_RESABS*GEOMETRY_RESABS ) 00667 point = edge->end_point(); 00668 // Otherwise split the edge at the projected position 00669 else point = split_edge( edge, edge_pos ); 00670 } 00671 00672 if( DEBUG_FLAG( VG_FACET_DEBUG ) && point ) 00673 point->debug_draw( VG_FACET_IMPRINT_COLOR ); 00674 00675 // If this was not set in the above if-block, then it is either 00676 // the closest point in the facet patch or NULL if the position 00677 // projected outside the facet patch. 00678 return point; 00679 } 00680 00681 //------------------------------------------------------------------------- 00682 // Purpose : Split an edge at the specified parameter value on the 00683 // edge. Splits connected facets to maintain triangular 00684 // facets. 00685 // 00686 // Special Notes : 00687 // 00688 // Creator : Jason Kraftcheck 00689 // 00690 // Creation Date : 05/11/02 00691 //------------------------------------------------------------------------- 00692 PST_Point* FacetProjectTool::split_edge( PST_Edge* edge, double t ) 00693 { 00694 assert( t > 0.0 && t < 1.0 ); 00695 00696 // create point 00697 PST_Point* point = new PST_Point( edge->position(t) ); 00698 00699 // get connected faces 00700 PST_Face* face1 = edge->forward()->face(); 00701 PST_Face* face2 = edge->reverse()->face(); 00702 00703 // point on each triangle opposite the edge to be split 00704 PST_Point* face1_pt = face1 ? edge->forward()->next()->end_point() : 0; 00705 PST_Point* face2_pt = face2 ? edge->reverse()->next()->end_point() : 0; 00706 00707 PST_Edge* face1_edge = 0, *face2_edge = 0; 00708 00709 // split edge edge 00710 PST_Edge* split_edge = edge->split( point ); 00711 if( edge->owner() ) 00712 edge->owner()->notify_split( edge, split_edge ); 00713 // if we split a boundary edge, put the new edge in the 00714 // list of boundary edges too. 00715 if( edge->mark ) 00716 { 00717 split_edge->mark = edge->mark; 00718 boundaryList.append( split_edge ); 00719 } 00720 // add edge to our list of edges 00721 edgeList.append( split_edge ); 00722 // If the first face was not a boundary face (different 00723 // than the boundary of our patch of facets), then split 00724 // it so that it remains a triangle. 00725 if( face1 ) 00726 { 00727 face1_edge = PST_Edge::split_face( point, face1_pt, face1 ); 00728 00729 if( face1_edge ) 00730 { 00731 if( DEBUG_FLAG( VG_FACET_DEBUG ) ) 00732 face1_edge->debug_draw( VG_FACET_FACET_COLOR ); 00733 00734 edgeList.append( face1_edge ); 00735 PST_Face* new_face = face1_edge->other(face1); 00736 new_face->sequence = facetList.size(); 00737 new_face->parent = face1->parent; 00738 facetList.append(new_face ); 00739 00740 if( face1->owner() ) 00741 face1->owner()->notify_split( face1, face1_edge->other(face1) ); 00742 } 00743 } 00744 // If the second face is not a boundary face, split it 00745 // so that we still have triangles. 00746 if( face2 ) 00747 { 00748 face2_edge = PST_Edge::split_face( point, face2_pt, face2 ); 00749 if( face2_edge ) 00750 { 00751 if( DEBUG_FLAG( VG_FACET_DEBUG ) ) 00752 face2_edge->debug_draw( VG_FACET_FACET_COLOR ); 00753 00754 edgeList.append( face2_edge ); 00755 PST_Face* new_face = face2_edge->other(face2); 00756 new_face->sequence = facetList.size(); 00757 new_face->parent = face2->parent; 00758 facetList.append( new_face ); 00759 00760 if( face2->owner() ) 00761 face2->owner()->notify_split( face2, face2_edge->other(face2) ); 00762 } 00763 } 00764 point->sequence = pointList.size(); 00765 pointList.append(point); 00766 00767 return point; 00768 } 00769 00770 //------------------------------------------------------------------------- 00771 // Purpose : This is the main or outer-loop function for the 00772 // polyline projection. It is called after the input data 00773 // is converted to the working representation. The passed 00774 // list of CubitVectors is the polyline. 00775 // 00776 // Special Notes : 00777 // 00778 // Creator : Jason Kraftcheck 00779 // 00780 // Creation Date : ?? 00781 //------------------------------------------------------------------------- 00782 00783 CubitStatus 00784 FacetProjectTool::do_projection( const DLIList<CubitVector*>& passed_list, 00785 CubitBoolean & point_changed, 00786 const double *tolerance_length) 00787 { 00788 const double TOL_SQR = GEOMETRY_RESABS*GEOMETRY_RESABS; 00789 point_changed = CUBIT_FALSE; 00790 DLIList<CubitVector*> segments( passed_list ); 00791 00792 bool first_and_last_points_coincident = false; 00793 if( segments[0]->distance_between_squared( *(segments[ segments.size()-1]) ) < TOL_SQR ) 00794 first_and_last_points_coincident = true; 00795 00796 segments.reset(); 00797 CubitVector end = *(segments.get_and_step()); 00798 PST_Point* last_point = 0; 00799 00800 bool did_any_projection = false; 00801 00802 int where_is_last_pt; 00803 int where_is_end_pt; 00804 00805 bool debug = false; 00806 00807 for( int i = segments.size(); i > 1; i-- ) 00808 { 00809 CubitVector start(end); 00810 end = *(segments.get_and_step()); 00811 00812 if( debug ) 00813 { 00814 GfxDebug::clear(); 00815 for( int j=facetList.size(); j--; ) 00816 facetList.get_and_step()->debug_draw( CUBIT_CYAN_INDEX+j, false ); 00817 GfxDebug::draw_point( start, CUBIT_GREEN_INDEX ); 00818 GfxDebug::draw_point( end, CUBIT_RED_INDEX ); 00819 GfxDebug::flush(); 00820 GfxDebug::mouse_xforms(); 00821 } 00822 00823 if( DEBUG_FLAG( VG_FACET_DEBUG ) ) 00824 { 00825 GfxDebug::draw_line( 00826 (float)start.x(), (float)start.y(), (float)start.z(), 00827 (float)end.x() , (float)end.y() , (float)end.z(), 00828 VG_FACET_SEGMENT_COLOR ); 00829 GfxDebug::flush(); 00830 GfxDebug::mouse_xforms(); 00831 } 00832 00833 double facet_dist_tol = start.distance_between_squared( end ); 00834 facet_dist_tol *= 0.0001; 00835 00836 //determine if start is on/off/on-boundary of facets 00837 if( !last_point ) 00838 { 00839 where_is_last_pt = point_on_facets( &start, facet_dist_tol ); 00840 00841 if( 1 == where_is_last_pt || 00842 2 == where_is_last_pt ) 00843 { 00844 last_point = project( start, tolerance_length ); 00845 00846 segPoints.append(last_point); 00847 start = *last_point; 00848 00849 if( first_and_last_points_coincident ) 00850 *(segments[segments.size()-1]) = start; 00851 } 00852 else 00853 segPoints.append(NULL); //it's not on the facets 00854 } 00855 00856 where_is_end_pt = point_on_facets( &end, facet_dist_tol ); 00857 00858 //both points off the facets 00859 //or one-on, one-off 00860 PST_Point *end_pt = NULL; 00861 00862 //both points off 00863 //one-point-on && one-point-off 00864 if( (0 == where_is_last_pt && 0 == where_is_end_pt ) || 00865 (0 == where_is_last_pt && 1 == where_is_end_pt ) || 00866 (1 == where_is_last_pt && 0 == where_is_end_pt ) ) 00867 { 00868 //see if segment intersects boundary 00869 CubitVector int_pt; 00870 CubitStatus my_status = find_closest_int_point_with_boundary( start, end, int_pt ); 00871 if( CUBIT_FAILURE == my_status ) 00872 { 00873 segPoints.append( NULL ); 00874 continue; 00875 } 00876 00877 if( 0 == where_is_last_pt ) 00878 { 00879 last_point = project( int_pt, tolerance_length ); 00880 00881 if( 0 == where_is_end_pt ) 00882 { 00883 my_status = find_closest_int_point_with_boundary( end, *last_point, int_pt ); 00884 if( CUBIT_SUCCESS == my_status ) 00885 { 00886 end_pt = project( int_pt, tolerance_length ); 00887 i++; 00888 segments.back(); 00889 } 00890 } 00891 else 00892 { 00893 end_pt = project( end, tolerance_length ); 00894 segPoints.append( end_pt ); 00895 } 00896 } 00897 else if( 0 == where_is_end_pt ) 00898 { 00899 end_pt = project( int_pt, tolerance_length ); 00900 i++; 00901 segments.back(); 00902 } 00903 } 00904 else if( (1 == where_is_last_pt || 2 == where_is_last_pt) && 00905 (1 == where_is_end_pt || 2 == where_is_end_pt) ) 00906 { 00907 end_pt = project( end, tolerance_length ); 00908 segPoints.append( end_pt ); 00909 } 00910 else if( (0 == where_is_last_pt && 2 == where_is_end_pt ) || 00911 (2 == where_is_last_pt && 0 == where_is_end_pt ) ) 00912 { 00913 if( 0 == where_is_last_pt && 2 == where_is_end_pt ) 00914 { 00915 //see if segment intersects boundary 00916 CubitVector int_pt; 00917 CubitStatus my_status = find_closest_int_point_with_boundary( start, end, int_pt ); 00918 if( CUBIT_SUCCESS == my_status ) 00919 { 00920 end_pt = project( end, tolerance_length ); 00921 last_point = project( int_pt, tolerance_length ); 00922 segPoints.append( end_pt ); 00923 } 00924 else 00925 { 00926 segPoints.append(NULL); 00927 continue; 00928 } 00929 } 00930 else 00931 { 00932 //see if segment intersects boundary 00933 CubitVector int_pt; 00934 CubitStatus my_status = find_closest_int_point_with_boundary( end, start, int_pt ); 00935 00936 if( CUBIT_SUCCESS == my_status ) 00937 { 00938 end_pt = project( int_pt, tolerance_length ); 00939 segPoints.append( NULL ); 00940 } 00941 else 00942 { 00943 segPoints.append( NULL ); 00944 continue; 00945 } 00946 } 00947 } 00948 00949 00950 PST_Point* start_point = last_point; 00951 PST_Point* end_point = end_pt; 00952 00953 if( debug ) 00954 { 00955 GfxDebug::draw_line( *last_point, *end_pt, CUBIT_MAGENTA_INDEX ); 00956 GfxDebug::flush(); 00957 GfxDebug::mouse_xforms(); 00958 } 00959 00960 if(project( last_point, end_pt ) == CUBIT_SUCCESS) 00961 { 00962 did_any_projection = true; 00963 if ((*start_point - *last_point).length_squared() > TOL_SQR) 00964 { 00965 segPoints.move_to(start_point); 00966 segPoints.change_to(last_point); 00967 point_changed = CUBIT_TRUE; 00968 } 00969 if ((*end_pt - *end_point).length_squared() > TOL_SQR) 00970 { 00971 segPoints.move_to(end_point); 00972 segPoints.change_to(end_pt); 00973 point_changed = CUBIT_TRUE; 00974 } 00975 } 00976 00977 last_point = end_pt; 00978 where_is_last_pt = where_is_end_pt; 00979 00980 } // end for( i = segments ) 00981 00982 if( !did_any_projection ) 00983 return CUBIT_FAILURE; 00984 00985 return CUBIT_SUCCESS; 00986 } 00987 00988 //------------------------------------------------------------------------- 00989 // Purpose : Determines if a position is off/on/on-boundary of the 00990 // facets in this tool. For off/on/on-boundary returns 00991 // 0, 1, and 2 respectively. The passed in tolerance_sq is 00992 // used as a coincidence tolerance. 00993 // 00994 // Special Notes : 00995 // 00996 // Creator : Corey Ernst 00997 // 00998 // Creation Date : 24-April-2013 00999 //------------------------------------------------------------------------- 01000 01001 int FacetProjectTool::point_on_facets( 01002 CubitVector *pos, 01003 double tolerance_sq ) 01004 { 01005 //Return Values: 01006 //0 is outside of facets 01007 //1 is inside of facets 01008 //2 is on boundary of facets 01009 01010 PST_Point* point = closest_point( *pos ); 01011 PST_Edge * edge = closest_edge ( *pos ); 01012 PST_Face * face = closest_face ( *pos ); 01013 01014 // find closest facet 01015 double face_dist = CUBIT_DBL_MAX; 01016 CubitVector face_pos; 01017 if( face ) 01018 { 01019 project_to_face( face, *pos, face_pos ); 01020 face_dist = (*pos - face_pos).length_squared(); 01021 } 01022 01023 // find closest edge 01024 double edge_dist = CUBIT_DBL_MAX; 01025 double edge_pos = CUBIT_DBL_MAX; 01026 if( edge ) 01027 { 01028 edge_pos = edge->closest_on_edge( *pos ); 01029 edge_dist = (*pos - edge->position(edge_pos)).length_squared(); 01030 } 01031 01032 // find closest point 01033 double point_dist = CUBIT_DBL_MAX; 01034 if( point ) 01035 { 01036 point_dist = (*pos - *point).length_squared(); 01037 } 01038 01039 // if the position is closer to a facet than a point or edge... 01040 if( face && (face_dist < point_dist) && (face_dist < edge_dist) ) 01041 { 01042 // check if projected position is within tolerance of 01043 // any bounding edge of the face. 01044 PST_CoEdge* coe = face->first_coedge(); 01045 bool edge_closer = false; 01046 do { 01047 PST_Edge* e = coe->edge(); 01048 CubitVector p = e->position( e->closest_on_line( face_pos ) ); 01049 double d = (p - face_pos).length_squared(); 01050 01051 if( d < tolerance_sq ) 01052 { 01053 edge = e; 01054 edge_pos = edge->closest_on_edge( *pos ); 01055 face_dist = d; 01056 edge_dist = d; 01057 edge_closer = true; 01058 } 01059 coe = coe->next(); 01060 } while( coe != face->first_coedge() ); 01061 01062 if( edge_closer ) 01063 { 01064 if( boundaryList.is_in_list( edge ) ) 01065 return 2; 01066 else 01067 return 1; 01068 } 01069 else 01070 return 1; 01071 01072 return 0; 01073 } 01074 01075 // If the point was closer to an edge than a point 01076 if( edge && (edge_dist < point_dist) ) 01077 { 01078 if( edge_dist < tolerance_sq ) 01079 { 01080 if( boundaryList.is_in_list( edge ) ) 01081 return 2; 01082 else 01083 return 1; 01084 } 01085 else 01086 return 0; 01087 } 01088 01089 PST_Edge *first_edge = point->edge(); 01090 PST_Edge *tmp_edge = first_edge; 01091 if( point_dist < tolerance_sq ) 01092 { 01093 do 01094 { 01095 if( boundaryList.is_in_list( tmp_edge ) ) 01096 return 2; 01097 tmp_edge = point->next( tmp_edge ); 01098 } 01099 while( first_edge != tmp_edge ); 01100 01101 return 1; 01102 } 01103 return 0; 01104 } 01105 01106 01107 //------------------------------------------------------------------------- 01108 // Purpose : Finds the closest intersection point to 'start_pt' 01109 // between the boundary facet edges in this tool and a line 01110 // segement defined by 'start_pt' and 'end_pt'. The 01111 // intersection must be at or between the two end points 01112 // of the segment. 01113 // 01114 // Special Notes : 01115 // 01116 // Creator : Corey Ernst 01117 // 01118 // Creation Date : 24-April-2013 01119 //------------------------------------------------------------------------- 01120 CubitStatus FacetProjectTool::find_closest_int_point_with_boundary( 01121 CubitVector &start_pt, CubitVector &end_pt, CubitVector &closest_pt ) 01122 { 01123 CubitVector seg_direction = end_pt - start_pt; 01124 double seg_length_sq = seg_direction.length_squared(); 01125 double shortest_length = CUBIT_DBL_MAX; 01126 01127 const double TOL_SQR = GEOMETRY_RESABS*GEOMETRY_RESABS; 01128 01129 bool debug = false; 01130 01131 //find the farthest boundary edge that is on the line segment 01132 CubitVector split_position; 01133 for( int k=boundaryList.size(); k--; ) 01134 { 01135 PST_Edge *tmp_edge = boundaryList.get_and_step(); 01136 01137 //if lines are parallel 01138 CubitVector tmp_vec1 = end_pt - start_pt; 01139 CubitVector tmp_vec2 = tmp_edge->end_coord() - tmp_edge->start_coord(); 01140 tmp_vec1 *= tmp_vec2; 01141 if( tmp_vec1.length_squared() < TOL_SQR ) 01142 continue; 01143 01144 double t1 = tmp_edge->closest_on_line( start_pt, end_pt - start_pt ); 01145 01146 //ignore points that are coincident with start_pt or end_pt 01147 CubitVector position_on_edge = tmp_edge->position( t1 ); 01148 double dist_sq_start = position_on_edge.distance_between_squared( start_pt ); 01149 double dist_sq_end = position_on_edge.distance_between_squared( end_pt ); 01150 if( dist_sq_start < TOL_SQR || dist_sq_end < TOL_SQR ) 01151 continue; 01152 01153 if( t1 >= 0 && t1 <= 1 ) 01154 { 01155 if( debug ) 01156 { 01157 GfxDebug::draw_line( start_pt, end_pt, CUBIT_MAGENTA_INDEX ); 01158 PRINT_INFO("t1 = %f\n", t1 ); 01159 tmp_edge->debug_draw( CUBIT_YELLOW_INDEX ); 01160 } 01161 01162 CubitVector tmp_pos = tmp_edge->position( t1 ); 01163 01164 //This checks if the intersection between the edge and segment 01165 //is not within the segment. 01166 if( tmp_pos.distance_between_squared( start_pt ) > seg_length_sq || 01167 tmp_pos.distance_between_squared( end_pt ) > seg_length_sq ) 01168 continue; 01169 01170 if( debug ) 01171 { 01172 GfxDebug::draw_point( tmp_pos, CUBIT_RED_INDEX ); 01173 GfxDebug::flush(); 01174 GfxDebug::mouse_xforms(); 01175 } 01176 01177 double tmp_dist = tmp_pos.distance_between( start_pt ); 01178 01179 if( tmp_dist < shortest_length ) 01180 { 01181 shortest_length = tmp_dist; 01182 closest_pt = tmp_pos; 01183 } 01184 } 01185 } 01186 01187 if( shortest_length == CUBIT_DBL_MAX ) 01188 return CUBIT_FAILURE; 01189 01190 return CUBIT_SUCCESS; 01191 } 01192 01193 01194 //------------------------------------------------------------------------- 01195 // Purpose : Given two existing points in a triangulation, add edges 01196 // to the triangulation to connect those two points by the 01197 // most direct path that does not leave the triangulation. 01198 // 01199 // Special Notes : Thisis the second step of the facet-polyline projection 01200 // algorithm. First each point of the polyline is 01201 // projected onto the facetting. Second this function is 01202 // called to find/create the set of facet edges connecting 01203 // those points. 01204 // 01205 // Creator : Jason Kraftcheck 01206 // 01207 // Creation Date : ?? 01208 //------------------------------------------------------------------------- 01209 CubitStatus FacetProjectTool::project( PST_Point* &start, PST_Point* &end ) 01210 { 01211 PST_Edge* edge,* closest_edge, *last_closest_edge=NULL; 01212 PST_Face* closest_face; 01213 PST_Point* point; 01214 PST_Point* start_point = start; 01215 CubitStatus stat; 01216 01217 const double TOL_SQR = GEOMETRY_RESABS*GEOMETRY_RESABS; 01218 01219 while( start_point != end ) 01220 { 01221 // If the points share an edge, that edge is the result. 01222 // Return it. 01223 CubitBoolean is_boundary_edge; 01224 if( (edge = start_point->common( end )) ) 01225 { 01226 PST_CoEdge* coedge = edge->end_point() == end ? 01227 edge->forward() : edge->reverse(); 01228 imprintResult.append( coedge ); 01229 01230 if( DEBUG_FLAG( VG_FACET_DEBUG ) ) 01231 { 01232 edge->debug_draw( VG_FACET_IMPRINT_COLOR ); 01233 } 01234 01235 return CUBIT_SUCCESS; 01236 } 01237 01238 // Draw the current segment 01239 if( DEBUG_FLAG( VG_FACET_DEBUG ) ) 01240 { 01241 GfxDebug::draw_line( 01242 (float)start_point->x(), (float)start_point->y(), 01243 (float)start_point->z(), 01244 (float)end->x() , (float)end->y() , (float)end->z(), 01245 VG_FACET_SEGMENT_COLOR ); 01246 GfxDebug::flush(); 01247 GfxDebug::mouse_xforms(); 01248 } 01249 01250 // Get face or edge adjacent to start and closest to the polyline segment 01251 stat = next_around_point( start_point, *end, closest_face, closest_edge, 01252 is_boundary_edge, last_closest_edge ); 01253 01254 if(closest_edge) 01255 last_closest_edge = closest_edge; 01256 01257 if (!stat || (closest_face && closest_edge)) 01258 { 01259 // assert(false); 01260 return stat; 01261 } 01262 01263 const CubitVector seg_tan = *end - *start_point; 01264 double t_seg = 0.0; 01265 point = 0; 01266 01267 if (closest_face) 01268 { 01269 // calculate intersection with triangle edge opposite 01270 // 'start_point'. 01271 double t_edge; 01272 edge = closest_face->opposite(start_point); 01273 PST_Point* edge_start = edge->start_point(); 01274 PST_Point* edge_end = edge->end_point(); 01275 closest_on_lines( *edge_start, *edge_end - *edge_start, 01276 *start_point, seg_tan, t_edge, t_seg); 01277 01278 const CubitVector seg_pt = *start_point + t_seg * seg_tan; 01279 const CubitVector edge_pt = (1.0 - t_edge) * *edge_start 01280 + t_edge * *edge_end; 01281 01282 // if line segment intersects opposite edge of triangle... 01283 if ( (t_seg < 1.0) || ((seg_pt - edge_pt).length_squared() < TOL_SQR) ) 01284 { 01285 // Check if intersection is near start of opposite edge 01286 if ((t_edge <= 0.0) || 01287 ((*edge_start - edge_pt).length_squared() < TOL_SQR) || 01288 ((*edge_start - seg_pt ).length_squared() < TOL_SQR) ) 01289 point = edge_start; 01290 // Check if intersection is near end of opposite edge 01291 else if ((t_edge >= 1.0) || 01292 ((*edge_end - edge_pt).length_squared() < TOL_SQR) || 01293 ((*edge_end - seg_pt).length_squared() < TOL_SQR)) 01294 point = edge_end; 01295 // Otherwise intersection is in the interior of the edge 01296 else 01297 point = split_edge(edge, t_edge); 01298 } 01299 // otherwise segment end is inside triangle 01300 else 01301 { 01302 t_seg = 1.0; 01303 const CubitVector proj = closest_face->plane().project(*end); 01304 PST_Edge *edge1, *edge2; 01305 closest_face->two_edges (start_point, edge1, edge2); 01306 // Too close to start position - skip segment 01307 if ( (*start_point - proj).length_squared() < TOL_SQR ) 01308 point = start_point; 01309 // If close to side of triangle, fall through to edge 01310 // handling code 01311 else if (within_tolerance(edge1, *end, GEOMETRY_RESABS) || 01312 within_tolerance(edge1, proj, GEOMETRY_RESABS)) 01313 closest_edge = edge1; 01314 // If close to side of triangle, fall through to edge 01315 // handling code 01316 else if (within_tolerance(edge2, *end, GEOMETRY_RESABS) || 01317 within_tolerance(edge2, proj, GEOMETRY_RESABS)) 01318 closest_edge = edge2; 01319 // Insert new point in triangle interior... 01320 else 01321 point = insert_in_face (closest_face, proj); 01322 } 01323 } // if(closest_face) 01324 01325 if (closest_edge) 01326 { 01327 PST_Point *const edge_end = closest_edge->other(start_point); 01328 // If edge and segment ends are equal... 01329 if ( (*edge_end - *end).length_squared() < TOL_SQR ) 01330 { 01331 point = edge_end; 01332 edge = closest_edge; 01333 if (is_boundary_edge) 01334 end = edge_end; 01335 } 01336 // Otherwise calculate closest point 01337 else 01338 { 01339 // edge and segment share a start point so just need 01340 // to calculate the projection of each on the other. 01341 const CubitVector edge_tan = *edge_end - *start_point; 01342 const double dot_prod = seg_tan % edge_tan; 01343 const double t_seg = dot_prod / seg_tan.length_squared(); 01344 const double t_edge = dot_prod / edge_tan.length_squared(); 01345 01346 const CubitVector seg_pt = *start_point + t_seg * seg_tan; 01347 const CubitVector edge_pt = *start_point + t_edge * edge_tan; 01348 01349 // Too close to start point -- skip segment 01350 if (t_edge <= 0.0 || t_seg <= 0.0 || 01351 (*start_point - edge_pt).length_squared() < TOL_SQR || 01352 (*start_point - seg_pt).length_squared() < TOL_SQR ) 01353 point = start_point; 01354 // If segment end is near or passed edge end, 01355 // then the edge end is the intersection with this triangle 01356 else if (t_edge > 1.0 || 01357 (*edge_end - edge_pt).length_squared() < TOL_SQR || 01358 (*edge_end - seg_pt).length_squared() < TOL_SQR) 01359 { 01360 //make sure the facet edge is not a boundary edge. 01361 if (is_boundary_edge && start_point == start) 01362 start = edge_end; 01363 point = edge_end; 01364 } 01365 // Otherwise closest point to segment end is in the interior 01366 // of the edge -- split the edge. 01367 else 01368 { 01369 if(start_point != closest_edge->start_point()) 01370 point = split_edge( closest_edge, 1.0 - t_edge ); 01371 else 01372 point = split_edge( closest_edge, t_edge ); 01373 } 01374 } 01375 } // if(closest_edge) 01376 01377 if (point == start_point) // skip perpendicular or very short segment 01378 continue; 01379 01380 edge = start_point->common( point ); 01381 if (!edge) 01382 { 01383 assert(false); 01384 continue; 01385 } 01386 01387 if ( !is_boundary_edge || start_point != start ) 01388 { 01389 PST_CoEdge* coedge = edge->end_point() == point ? 01390 edge->forward() : edge->reverse(); 01391 imprintResult.append(coedge); 01392 } 01393 01394 if( DEBUG_FLAG( VG_FACET_DEBUG ) ) 01395 { 01396 edge->debug_draw( VG_FACET_IMPRINT_COLOR ); 01397 point->debug_draw( VG_FACET_IMPRINT_COLOR ); 01398 } 01399 start_point = point; 01400 } 01401 01402 return CUBIT_SUCCESS; 01403 } 01404 01405 //------------------------------------------------------------------------- 01406 // Purpose : Check if a point is within the passed tolerance 01407 // of a bounded edge. 01408 // 01409 // Special Notes : 01410 // 01411 // Creator : Jason Kraftcheck 01412 // 01413 // Creation Date : 09/04/03 01414 //------------------------------------------------------------------------- 01415 bool FacetProjectTool::within_tolerance( PST_Edge* edge, 01416 const CubitVector& point, 01417 double tolerance ) 01418 { 01419 const double t_edge = edge->closest_on_edge( point ); 01420 const CubitVector edge_pos = edge->position(t_edge); 01421 return (edge_pos - point).length_squared() < tolerance*tolerance; 01422 } 01423 01424 //------------------------------------------------------------------------- 01425 // Purpose : Given a line segment beginning at a point in the 01426 // triangulation, find the face or edge adjacent to the 01427 // point and closest to the line segment. 01428 // 01429 // Special Notes : 01430 // 01431 // Creator : Jason Kraftcheck 01432 // 01433 // Creation Date : 09/04/03 01434 //------------------------------------------------------------------------- 01435 CubitStatus FacetProjectTool::next_around_point ( PST_Point*& start, 01436 const CubitVector& seg_end, 01437 PST_Face*& closest_face, 01438 PST_Edge*& closest_edge, 01439 CubitBoolean & is_boundary_edge, 01440 PST_Edge *last_closest_edge) 01441 { 01442 DLIList<PST_Face*> face_list; 01443 DLIList<PST_Edge*> boundary_edges; 01444 is_boundary_edge = CUBIT_FALSE; 01445 double shortest_dist_sqr = CUBIT_DBL_MAX; 01446 closest_face = 0; 01447 closest_edge = 0; 01448 01449 //const double TOL_SQR = GEOMETRY_RESABS*GEOMETRY_RESABS; 01450 01451 const CubitVector tangent = seg_end - *start; 01452 01453 // To traverse the edges in clockwise order about the point, 01454 // it is necessary to start with the appropriate boundary edge 01455 // if there is one. If this point is not on the boundary of 01456 // the facet patch, any edge is acceptable. 01457 01458 // First mark all faces adjacent to the vertex. This is to make 01459 // sure disjoint sets of faces (sets of faces with no edges in 01460 // common) are not missed when traversing edge-face adjacencies. 01461 start->faces( &face_list ); 01462 for (int i = face_list.size(); i--; ) 01463 face_list.step_and_get()->mark = true; 01464 01465 // Loop until all faces in face_list have been un-marked 01466 boundary_edges.clean_out(); 01467 closest_edge = 0; 01468 closest_face = 0; 01469 while (face_list.size()) 01470 { 01471 PST_Face* face = face_list.pop(); 01472 if (!face->mark) 01473 continue; 01474 01475 PST_CoEdge* coedge = face->first_coedge(); 01476 if (coedge->edge()->other(start) == 0) 01477 coedge = coedge->next(); 01478 01479 // search for the 'first' coedge in the clockwise list. 01480 PST_CoEdge* first = coedge; 01481 while (coedge->face()) 01482 { 01483 if (coedge->end_point() == start) 01484 coedge = coedge->other(); 01485 else 01486 coedge = coedge->previous(); 01487 01488 if (coedge == first) // no start, point is not on boundary 01489 break; 01490 } 01491 01492 // keep boundary edges encountered for later 01493 if (!coedge->face()) 01494 boundary_edges.append(coedge->edge()); 01495 01496 // Of the two edges on the face that are adjacent to the 01497 // point, begin with the one that is first in clockwise 01498 // order around the point. 01499 if (coedge->start_point() == start) 01500 coedge = coedge->other(); 01501 first = coedge; 01502 01503 // Traverse adjacent facets in clockwise order 01504 // around point. 01505 bool clockwise_of_prev = false; 01506 while ( (face = coedge->face()) ) 01507 { 01508 face->mark = false; 01509 01510 // get vectors for edges of face pointing outwards 01511 // from vertex. 01512 assert(coedge->end_point() == start && coedge->next()->start_point() == start); 01513 CubitVector prev = coedge->other()->direction(); 01514 CubitVector next = coedge->next()->direction(); 01515 01516 // calculate if segment is to the 'inside' of each 01517 // adjacent edge. 01518 CubitVector normal = next * prev; // ccw 01519 bool inside_prev = ((tangent * prev) % normal) >= 0.0; 01520 bool inside_next = ((next * tangent) % normal) >= 0.0; 01521 01522 // If edge is inside face, check distance from face 01523 if( (inside_prev && inside_next) ) 01524 { 01525 // calculate distance from end point to plane of face 01526 const double plane_coeff = normal % *start; 01527 const double end_coeff = normal % seg_end; 01528 const double numerator = end_coeff - plane_coeff; 01529 const double dist_sqr = (numerator * numerator) / normal.length_squared(); 01530 01531 if (dist_sqr < shortest_dist_sqr) 01532 { 01533 closest_face = face; 01534 closest_edge = 0; 01535 shortest_dist_sqr = dist_sqr; 01536 } 01537 01538 clockwise_of_prev = false; 01539 } 01540 // If the edge is above a peak formed by the shared edge of two faces 01541 else if (inside_next && clockwise_of_prev) 01542 { 01543 // calculate distance from end of segment to line of facet edge 01544 const double dot_prod = tangent % prev; 01545 const double dist_sqr = 01546 tangent.length_squared() - dot_prod * dot_prod / prev.length_squared(); 01547 01548 if (dist_sqr <= shortest_dist_sqr && coedge->edge() != last_closest_edge) 01549 { 01550 closest_face = 0; 01551 closest_edge = coedge->edge(); 01552 shortest_dist_sqr = dist_sqr; 01553 } 01554 clockwise_of_prev = false; 01555 } 01556 // If clockwise of the face, note for next iteration 01557 else if (inside_prev) 01558 { 01559 clockwise_of_prev = true; 01560 } 01561 else 01562 { 01563 clockwise_of_prev = false; 01564 } 01565 01566 coedge = coedge->next()->other(); 01567 if (coedge == first) 01568 break; 01569 } // while(coedge->face()) 01570 01571 if (!coedge->face()) 01572 boundary_edges.append(coedge->edge()); 01573 01574 } // while(face_list.size()) 01575 01576 // If a closest entity was found, then done. 01577 if (closest_face || closest_edge) 01578 return CUBIT_SUCCESS; 01579 01580 01581 //Here we try to intersect the segment with the boundary 01582 //facet edge closest to 'start' (farthest from 'end') 01583 bool debug = false; 01584 if( !closest_edge ) 01585 { 01586 CubitVector seg_direction = seg_end - *start; 01587 double seg_length = seg_direction.length(); 01588 double longest_length = 0; 01589 01590 if( debug ) 01591 { 01592 GfxDebug::clear(); 01593 start->debug_draw(CUBIT_GREEN_INDEX); 01594 GfxDebug::draw_point( seg_end, CUBIT_RED_INDEX ); 01595 for( int j=facetList.size(); j--; ) 01596 facetList.get_and_step()->debug_draw( CUBIT_CYAN_INDEX ); 01597 GfxDebug::mouse_xforms(); 01598 } 01599 01600 //find the farthest boundary edge that is on the line segment 01601 CubitVector split_position; 01602 for( int k=boundaryList.size(); k--; ) 01603 { 01604 PST_Edge *tmp_edge = boundaryList.get_and_step(); 01605 01606 if( tmp_edge->start_point() == start || 01607 tmp_edge->end_point() == start ) 01608 continue; 01609 01610 double t1 = tmp_edge->closest_on_line( *start, seg_end - *start ); 01611 01612 if( t1 > 1e-6 && t1 < 1 ) 01613 { 01614 CubitVector tmp_pos = tmp_edge->position( t1 ); 01615 01616 if( debug ) 01617 { 01618 GfxDebug::draw_line( *start, seg_end, CUBIT_MAGENTA_INDEX ); 01619 PRINT_INFO("t1 = %f\n", t1 ); 01620 tmp_edge->debug_draw( CUBIT_YELLOW_INDEX ); 01621 GfxDebug::draw_point( tmp_pos, CUBIT_RED_INDEX ); 01622 GfxDebug::flush(); 01623 GfxDebug::mouse_xforms(); 01624 } 01625 01626 double tmp_dist = tmp_pos.distance_between( seg_end ); 01627 01628 if( tmp_dist > longest_length && tmp_dist < seg_length ) 01629 { 01630 longest_length = tmp_dist; 01631 closest_edge = tmp_edge; 01632 split_position = tmp_pos; 01633 } 01634 } 01635 } 01636 01637 if( closest_edge ) 01638 { 01639 start = project( split_position ); 01640 01641 CubitStatus my_stat = next_around_point( start, seg_end, closest_face, 01642 closest_edge, is_boundary_edge, last_closest_edge ); 01643 01644 if( CUBIT_FAILURE == my_stat ) 01645 return CUBIT_FAILURE; 01646 01647 return closest_face ? CUBIT_SUCCESS : CUBIT_FAILURE; 01648 } 01649 } 01650 01651 return closest_edge ? CUBIT_SUCCESS : CUBIT_FAILURE; 01652 } 01653 01654 01655 01656 01657 01658 01659 //------------------------------------------------------------------------- 01660 // Purpose : Remove duplciate edges from results if input polyline 01661 // was self-intersecting. 01662 // 01663 // Special Notes : 01664 // 01665 // Creator : Jason Kraftcheck 01666 // 01667 // Creation Date : ?? 01668 //------------------------------------------------------------------------- 01669 void FacetProjectTool::finalize_results() 01670 { 01671 imprintResult.reset(); 01672 for ( int i = imprintResult.size(); i--; ) 01673 { 01674 PST_Edge* edge = imprintResult.step_and_get()->edge(); 01675 if (edge->mark) 01676 imprintResult.change_to(0); 01677 else 01678 edge->mark = 1; 01679 } 01680 imprintResult.remove_all_with_value(0); 01681 imprintResult.reset(); 01682 } 01683 01684 //------------------------------------------------------------------------- 01685 // Purpose : Return non-intersecting chains of result edges, in the 01686 // same sequence as the input polyline and with the same 01687 // orientation. 01688 // 01689 // Special Notes : This is called after the projection is done to get the 01690 // resulting facet edge chains. 01691 // 01692 // Creator : Jason Kraftcheck 01693 // 01694 // Creation Date : 09/04/03 01695 //------------------------------------------------------------------------- 01696 CubitStatus FacetProjectTool::get_result_set( DLIList<PST_CoEdge*>& coedges ) 01697 { 01698 if ( !imprintResult.size() ) 01699 return CUBIT_FAILURE; 01700 01701 imprintResult.reset(); 01702 PST_CoEdge* prev = imprintResult.get(); 01703 imprintResult.change_to(0); 01704 coedges.append(prev); 01705 01706 for ( int i = imprintResult.size() - 1; i--; ) 01707 { 01708 PST_CoEdge* coedge = imprintResult.step_and_get(); 01709 PST_Point* pt = prev->end_point(); 01710 if (pt != coedge->start_point()) 01711 break; 01712 01713 int count = 1; 01714 for (PST_Edge* pt_edge = pt->next(coedge->edge()); 01715 pt_edge != coedge->edge(); 01716 pt_edge = pt->next(pt_edge)) 01717 { 01718 if (pt_edge->mark) 01719 count++; 01720 } 01721 01722 if (count != 2) 01723 break; 01724 01725 coedges.append(coedge); 01726 prev = coedge; 01727 imprintResult.change_to(0); 01728 } 01729 01730 imprintResult.remove_all_with_value(0); 01731 return CUBIT_SUCCESS; 01732 } 01733 01734 01735 double FacetProjectTool::closest_on_line( const CubitVector& B, 01736 const CubitVector& M, 01737 const CubitVector& P ) 01738 { 01739 const double dist_tol_sqr = GEOMETRY_RESABS*GEOMETRY_RESABS; 01740 double D = M.length_squared(); 01741 return (D < dist_tol_sqr ) ? 0.0 : (M % (P - B)) / D; 01742 } 01743 01744 01745 void FacetProjectTool::closest_on_lines( const CubitVector& B1, 01746 const CubitVector& M1, 01747 const CubitVector& B2, 01748 const CubitVector& M2, 01749 double& t1, double& t2 ) 01750 { 01751 CubitVector N = M2 * (M2 * M1); 01752 double d = N % M1; 01753 if( fabs(d) < CUBIT_RESABS ) //parallel lines 01754 t1 = 0.0; 01755 else 01756 t1 = ((N % B2) - (N % B1)) / d; 01757 01758 t2 = closest_on_line( B2, M2, B1 + t1 * M1 ); 01759 } 01760 01761 01762 bool FacetProjectTool::inside_face( PST_Face* face, const CubitVector& pos ) 01763 { 01764 // This code checks if the position is in the interior of 01765 // the prism formed by sweeping the facet infinetly in the 01766 // direction of, and opposite direction of the facet normal. 01767 PST_CoEdge* coe = face->first_coedge(); 01768 do { 01769 CubitVector vect( pos ); 01770 vect -= *coe->start_point(); 01771 vect *= coe->direction(); 01772 if( vect % face->normal() > -CUBIT_RESABS ) 01773 return false; 01774 coe = coe->next(); 01775 } while( coe != face->first_coedge() ); 01776 return true; 01777 } 01778 01779 /* 01780 static void draw_pt( const std::vector<double>& list, int index, int color ) 01781 { 01782 GfxDebug::draw_point( 01783 (float)list[index], (float)list[index+1], (float)list[index+2], color ); 01784 } 01785 01786 static void draw_edge( const std::vector<double>& list, int i1, int i2, int color ) 01787 { 01788 i1 *= 3; i2 *= 3; 01789 GfxDebug::draw_line( 01790 (float)list[i1], (float)list[i1+1], (float)list[i1+2], 01791 (float)list[i2], (float)list[i2+1], (float)list[i2+2], 01792 color ); 01793 } 01794 01795 static void draw_tri( const std::vector<double>& pts, 01796 const std::vector<int>& tris, int index, 01797 const std::vector<int>& seq, int color ) 01798 { 01799 for ( int i = 0; i < 3; i++ ) 01800 { 01801 int i1 = tris[index + i]; 01802 int i2 = tris[index + (i + 1) % 3]; 01803 if ( !seq[i1] || !seq[i2] || abs(seq[i1]-seq[i2]) != 1 ) 01804 draw_edge( pts, i1, i2, color ); 01805 } 01806 } 01807 */ 01808 01809 void FacetProjectTool::debug( DLIList<CubitVector*>& segments, 01810 std::vector<double>& coordinates, 01811 std::vector<int>& connections ) 01812 { 01813 #if 1 /* test with old interface */ 01814 DLIList<PST_Edge*> edges; 01815 PST_Edge::make_facets(coordinates, connections, GEOMETRY_RESABS, edges); 01816 01817 DLIList<PST_Face*> faces; 01818 PST_Edge::faces( edges, faces ); 01819 populate_data(faces); 01820 01821 CubitBoolean point_changed; 01822 do_projection( segments, point_changed ); 01823 01824 PST_Edge::debug_draw_edges( edgeList, CUBIT_BLUE_INDEX ); 01825 01826 DLIList<PST_CoEdge*> coedges; 01827 finalize_results(); 01828 while( get_result_set( coedges ) ) { 01829 edges.clean_out(); 01830 coedges.reverse(); 01831 while (coedges.size()) edges.append(coedges.pop()->edge()); 01832 PST_Edge::debug_draw_edges( edges, CUBIT_WHITE_INDEX ); 01833 PST_Edge::debug_draw_points( edges, CUBIT_WHITE_INDEX ); 01834 } 01835 01836 #else /* test with new interface */ 01837 01838 int i, j; 01839 01840 // do projection 01841 std::vector<double> new_pts; 01842 std::vector<int> dudded, new_facets, facet_index, polyline; 01843 if( !project( segments, coordinates, connections, dudded, 01844 new_facets, facet_index, new_pts, polyline ) ) 01845 { 01846 PRINT_ERROR("FacetProjectTool::project returned CUBIT_FAILURE\n"); 01847 return; 01848 } 01849 01850 assert( connections.size() % 3 == 0 ); 01851 assert( coordinates.size() % 3 == 0 ); 01852 assert( new_facets.size() % 3 == 0 ); 01853 assert( new_pts.size() % 3 == 0 ); 01854 assert( dudded.size() == facet_index.size() ); 01855 int num_old_tri = connections.size() / 3; 01856 int num_new_tri = new_facets.size() / 3; 01857 int num_old_pts = coordinates.size() / 3; 01858 int num_new_pts = new_pts.size() / 3; 01859 int num_tot_tri = num_new_tri + num_old_tri; 01860 int num_tot_pts = num_new_pts + num_old_pts; 01861 01862 PRINT_INFO("%d input triangles using %d points.\n", num_old_tri, num_old_pts ); 01863 PRINT_INFO("%d new triangles and %d new poitns.\n", num_new_tri, num_new_pts ); 01864 PRINT_INFO("%d total triangles using %d total points.\n", num_tot_tri, num_tot_pts ); 01865 PRINT_INFO("connections.size() = %d\n", (int)connections.size()); 01866 PRINT_INFO("coordinates.size() = %d\n", (int)coordinates.size()); 01867 PRINT_INFO("dudded.size() = %d\n", (int)dudded.size()); 01868 PRINT_INFO("new_facets.size() = %d\n", (int)new_facets.size()); 01869 PRINT_INFO("facet_index.size() = %d\n", (int)facet_index.size()); 01870 PRINT_INFO("new_pts.size() = %d\n", (int)new_pts.size()); 01871 PRINT_INFO("polyline.size() = %d\n", (int)polyline.size()); 01872 01873 for ( i = 0; i < (int)new_facets.size(); i++ ) 01874 if ( new_facets[i] >= num_tot_pts || new_facets[i] < 0 ) 01875 PRINT_ERROR("Invalid value %d at new_facets[%d]\n", new_facets[i], i); 01876 for ( i = 0; i < (int)dudded.size(); i++ ) 01877 if ( dudded[i] >= num_old_tri || dudded[i] < 0 ) 01878 PRINT_ERROR("Invalid value %d at dudded[%d]\n", dudded[i], i); 01879 for ( i = 0; i < (int)polyline.size()-1; ) 01880 { 01881 int count = polyline[i]; 01882 if ( count < 2 ) 01883 PRINT_ERROR("Invalid polyline length %d at polyline[%d]\n", count, i ); 01884 i++; 01885 for ( j = 0; j < count; j++, i++ ) 01886 { 01887 if( i >= (int)polyline.size() ) 01888 PRINT_ERROR("Ran out of indices in polyline.\n"); 01889 if ( polyline[i] >= num_tot_pts || polyline[i] < 0 ) 01890 PRINT_ERROR("Invalid value %d at dudded[%d]\n", dudded[i], i); 01891 } 01892 } 01893 01894 // draw original points 01895 for ( i = 0; i < (int)coordinates.size(); i += 3 ) 01896 draw_pt( coordinates, i, CUBIT_BLUE_INDEX ); 01897 /* 01898 // draw new points 01899 for ( i = 0; i < (int)new_pts.size(); i += 3 ) 01900 draw_pt( new_pts, i, CUBIT_RED_INDEX ); 01901 */ 01902 // concatenate point lists 01903 for ( i = 0; i < (int)new_pts.size(); i++ ) 01904 coordinates.push_back(new_pts[i]); 01905 01906 // make reverse mapping for dudded facets 01907 std::vector<bool> dead(connections.size()/3); 01908 for ( i = 0; i < (int)dead.size(); i++ ) 01909 dead[i] = false; 01910 for ( i = 0; i < (int)dudded.size(); i++ ) 01911 dead[dudded[i]] = true; 01912 01913 // make polyline sequence list (this won't work quite 01914 // right for self-intersecting polylines -- *shrug*) 01915 std::vector<int> sequence(coordinates.size() / 3); 01916 for ( i = 0; i < (int)sequence.size(); i++ ) 01917 sequence[i] = 0; 01918 j = 0; 01919 for ( i = 0; i < (int)polyline.size(); i++ ) 01920 sequence[polyline[i]] = ++j; 01921 01922 01923 // draw orginal facets 01924 for ( i = 0; i < (int)dead.size(); i++ ) 01925 if( ! dead[i] ) 01926 draw_tri( coordinates, connections, 3*i, sequence, CUBIT_BLUE_INDEX ); 01927 01928 // draw new facets 01929 for ( i = 0; i < (int)new_facets.size(); i += 3 ) 01930 draw_tri( coordinates, new_facets, i, sequence, CUBIT_RED_INDEX ); 01931 01932 // draw polyline 01933 for ( i = 0; i < (int)polyline.size()-1; i++) 01934 { 01935 int count = polyline[i]; 01936 if ( count < 2 ) 01937 PRINT_ERROR("Invalid polyline length %d at polyline[%d]\n", count, i ); 01938 int first = ++i; 01939 for ( j = 0; j < count-1; j++, i++ ) 01940 { 01941 draw_edge( coordinates, polyline[i], polyline[i+1], CUBIT_WHITE_INDEX ); 01942 } 01943 if( polyline[first] == polyline[i] ) 01944 PRINT_INFO("Polyline is closed.\n"); 01945 } 01946 01947 GfxDebug::flush(); 01948 #endif 01949 cleanup(); 01950 } 01951
