cgma
00001 //------------------------------------------------------------------------- 00002 // Filename : Faceter.hpp 00003 // 00004 // Purpose : Facets a surface. 00005 // 00006 // Special Notes : 00007 // 00008 // Creator : David White 00009 // 00010 // Creation Date : 03/01/02 00011 //------------------------------------------------------------------------- 00012 00013 #ifndef FACETER_HPP 00014 #define FACETER_HPP 00015 00016 #include "CubitDefines.h" 00017 #include "GeometryDefines.h" //need GEOMETRY_RESABS 00018 #include "DLIList.hpp" 00019 #include "CubitVector.hpp" 00020 00021 class CubitFacet; 00022 class CubitPoint; 00023 class CubitVector; 00024 class FaceterPointData; 00025 class RefFace; 00026 class RefEdge; 00027 class PointGridSearch; 00028 class GMem; 00029 00030 00031 template <class X> class DLIList; 00032 00033 class Faceter 00034 { 00035 00036 public: 00037 00038 Faceter( RefFace *face ); 00039 ~Faceter(); 00040 00041 CubitStatus facet_surface( DLIList <CubitFacet*> &results, 00042 DLIList <CubitPoint*> &point_list); 00043 //- Facets the surface and returns the list of facets that 00044 //- approximate the surface. 00045 00046 protected: 00047 00048 private: 00049 00050 RefFace *thisRefFacePtr; 00051 PointGridSearch *gridSearchPtr; 00052 const double gridCellScale; 00053 CubitBoolean avoidedOverlap; 00054 DLIList <CubitPoint*> *globalPointList; 00055 // GeomIntersectionTool* iToolPtr; 00056 00057 CubitStatus facet_loop(DLIList <CubitPoint*> *loop_ptr, 00058 DLIList <CubitFacet*> &results); 00059 //- Facets' the loop of CubitPoints. 00060 00061 CubitStatus facet_factory(FaceterPointData* curr_faceter_data, 00062 CubitFacet *&new_facet, 00063 DLIList <FaceterPointData*> &order_list); 00064 //- given the current data, create a new trianglular facet. 00065 //- Also update the data associated with the curr_data (next and prev data). 00066 CubitBoolean avoid_facet(FaceterPointData* curr_faceter_data, 00067 DLIList<FaceterPointData*> &order_list); 00068 //- Determine if the facet should be avoided. Also adds curr_faceter_data 00069 //- back to the order_list at the begining of the list (since we 00070 //- pop through the list, this is really the end). Also modify 00071 //- the angle by angle + 2pi so we don't hit this point for a while and 00072 //- hopefully serendiputiously we avoid having to create this facet... 00073 //- Set the class variable avoidedOverlap to be true if the 00074 //- facet is avoided. Returns FALSE if nothing is done and the 00075 //- facet is okay to create. 00076 00077 00078 CubitStatus get_boundary_points( DLIList <DLIList<CubitPoint*>*> &boundary_point_loops ) const; 00079 //- Get the loops of boundary facet points. 00080 00081 CubitStatus get_curve_facets( RefEdge* curve, DLIList<CubitPoint*>& segments ) const; 00082 //- Get the facet points in order from start to end for the curve. 00083 00084 void max_min_edge_ratio( DLIList <DLIList <CubitPoint*>*> &boundary_point_loops, 00085 double &ratio, 00086 double &cell_size); 00087 //- Gets the ratio for the gridcell size for the gridsearch tool. 00088 00089 CubitStatus interior_angle(DLIList <CubitPoint*> *loop_ptr, 00090 double &my_angle); 00091 //- Gets the interior angle of the loop_ptr measured at the 00092 //- current point in the list. The angle is taken between the prev 00093 //- point and next point in the list. 00094 00095 00096 }; 00097 00098 00099 #endif
