cgma
00001 //----------------------------------------------------------------------------- 00002 // Filename : GeometryHealerTool.hpp 00003 // 00004 // Purpose : Define the healer interface for all solid modeling engines. 00005 // 00006 // Special Notes : This is a singleton pattern class for the healer functions. 00007 // 00008 // Creator : Tyronne Lim (CAT) 00009 // 00010 // Creation Date : 7/21/03 00011 // 00012 // Owner : 00013 //----------------------------------------------------------------------------- 00014 00015 #ifndef _GEOMETRYHEALERTOOL_HPP 00016 #define _GEOMETRYHEALERTOOL_HPP 00017 00018 // *** BEGIN INCLUDES *** // 00019 00020 #include "CubitDefines.h" 00021 #include "DLIList.hpp" 00022 #include "CGMGeomConfigure.h" 00023 00024 // *** END INCLUDES *** // 00025 00026 // *** BEGIN FORWARD DECLARATIONS *** // 00027 00028 class GeometryHealerEngine; 00029 00030 class TopologyBridge; 00031 class TopologyEntity; 00032 00033 class RefEntity; 00034 class RefFace; 00035 class RefEdge; 00036 00037 class Body; 00038 // *** END FORWARD DECLARATIONS *** // 00039 00041 class CUBIT_GEOM_EXPORT GeometryHealerTool 00042 { 00043 public: 00044 00045 // singleton pattern class instance interface 00046 static GeometryHealerTool* instance( GeometryHealerEngine* GHEPtr = NULL ); 00047 00048 static void delete_instance() 00049 { 00050 if (instance_) 00051 { 00052 delete instance_; 00053 instance_ = NULL; 00054 } 00055 }; 00056 00057 // destructor 00058 ~GeometryHealerTool(); 00059 00060 // *** BEGIN ENGINE OPERATIONS *** // 00061 00062 // set the default healer engine 00063 // void set_default_engine( GeometryHealerEngine *ghe_ptr ); 00064 00066 void add_ghe( GeometryHealerEngine *ghe_ptr ); 00067 00068 // remove a healer engine from the list 00069 // CubitStatus remove_ghe( GeometryHealerEngine *ghe_ptr ); 00070 00071 // get the list of healer engines 00072 // void get_ghe_list( DLIList<GeometryHealerEngine*> &ghe_list ); 00073 00074 private: 00075 // returns the healer engine of an entity 00076 GeometryHealerEngine* get_engine( TopologyBridge *tb_ptr ) const; 00077 GeometryHealerEngine* get_engine( TopologyEntity *te_ptr ) const; 00078 00079 // determines if entities belong to the same engine 00080 CubitBoolean same_healer_engine( DLIList<RefEntity*> &ref_entity_list, 00081 CubitBoolean check_children ) const; 00082 CubitBoolean same_healer_engine( DLIList<TopologyEntity*> &topo_list ) const; 00083 00084 // *** END ENGINE OPERATIONS *** // 00085 00086 // *** BEGIN HEALER FUNCTIONS *** // 00087 public: 00091 CubitStatus auto_heal_bodies( DLIList<Body*> &body_list, 00092 DLIList<Body*> &new_body_list, 00093 DLIList<TopologyEntity*> &bad_geometry, 00094 CubitBoolean rebuild = CUBIT_FALSE, 00095 CubitBoolean keep_old = CUBIT_FALSE, 00096 CubitBoolean make_tolerant = CUBIT_FALSE, 00097 FILE* logfile_ptr = NULL ); 00098 00102 CubitStatus heal_bodies( DLIList<Body*> &body_list, 00103 DLIList<Body*> &new_body_list, 00104 DLIList<TopologyEntity*> &bad_geometry, 00105 CubitBoolean rebuild = CUBIT_FALSE, 00106 CubitBoolean keep_old = CUBIT_FALSE, 00107 CubitBoolean make_tolerant = CUBIT_FALSE, 00108 FILE* logfile_ptr = NULL ); 00109 00114 CubitStatus analyze_badgeom( DLIList<Body*> &body_list, 00115 DLIList<TopologyEntity*> &bad_geometry, 00116 FILE* logfile = NULL ); 00117 00121 CubitStatus get_badgeom( DLIList<Body*> &body_list, 00122 DLIList<TopologyEntity*> &bad_geometry ); 00123 00126 CubitStatus get_tcurves( DLIList<Body*> &body_list, 00127 DLIList<RefEdge*> &t_curves ); 00128 00177 CubitStatus heal_incremental( DLIList<Body*> &body_list, 00178 DLIList<Body*> &new_bodies, 00179 DLIList<TopologyEntity*> &bad_geometry, 00180 double simplify_tol = CUBIT_DBL_MAX, 00181 double stitch_min_tol = CUBIT_DBL_MAX, 00182 double stitch_max_tol = CUBIT_DBL_MAX, 00183 double geombuild_tol = CUBIT_DBL_MAX, 00184 double analytic_tol = CUBIT_DBL_MAX, 00185 double isospline_tol = CUBIT_DBL_MAX, 00186 double reblend_classify_tol = CUBIT_DBL_MAX, 00187 double reblend_tol = CUBIT_DBL_MAX, 00188 CubitBoolean keep_old = CUBIT_FALSE, 00189 CubitBoolean make_tolerant = CUBIT_FALSE, 00190 FILE* logfile_ptr = NULL); 00191 00193 void list_incremental(); 00194 00196 void list_tolerances( DLIList<Body*> &body_list ); 00197 00199 00200 00201 00202 00203 00204 00205 double get_default_simplify_tol(); 00206 void set_default_simplify_tol( double tol ); 00207 double get_default_stitch_min_tol(); 00208 void set_default_stitch_min_tol( double tol ); 00209 double get_default_stitch_max_tol(); 00210 void set_default_stitch_max_tol( double tol ); 00211 double get_default_geombuild_tol(); 00212 void set_default_geombuild_tol( double tol ); 00213 double get_default_analytic_tol(); 00214 void set_default_analytic_tol( double tol ); 00215 double get_default_isospline_tol(); 00216 void set_default_isospline_tol( double tol ); 00217 double get_default_reblend_classify_tol(); 00218 void set_default_reblend_classify_tol( double tol ); 00219 double get_default_reblend_tol(); 00220 void set_default_reblend_tol( double tol ); 00221 void reset_default_tolerances(); 00222 void list_default_tolerances(); 00224 00227 void clean_attributes( DLIList<Body*>& body_list ); 00228 00230 00231 00232 CubitBoolean get_cleanatt_flg(); 00233 void set_cleanatt_flg( CubitBoolean flg ); 00235 00237 00238 int get_show_method(); // 0-none, 1-highlight, 2-draw 00239 void set_show_method( int method ); 00241 00243 00244 CubitBoolean get_show_summary_flg(); 00245 void set_show_summary_flg( CubitBoolean flg ); 00247 00249 00250 CubitBoolean get_show_details_flg(); 00251 void set_show_details_flg( CubitBoolean flg ); 00253 00255 00256 CubitBoolean get_show_on_heal_flg(); 00257 void set_show_on_heal_flg( CubitBoolean flg ); 00259 00261 00262 CubitBoolean get_check_vol_on_heal_flg(); 00263 void set_check_vol_on_heal_flg( CubitBoolean flg ); 00264 double get_vol_on_heal_limit(); 00265 void set_vol_on_heal_limit( double limit ); 00267 00269 00270 CubitBoolean get_check_surf_on_heal_flg(); 00271 void set_check_surf_on_heal_flg( CubitBoolean flg ); 00272 double get_surf_on_heal_limit(); 00273 void set_surf_on_heal_limit( double limit ); 00275 00277 00278 CubitBoolean get_check_curve_on_heal_flg(); 00279 void set_check_curve_on_heal_flg( CubitBoolean flg ); 00280 double get_curve_on_heal_limit(); 00281 void set_curve_on_heal_limit( double limit ); 00283 00285 00286 CubitBoolean get_show_bad_vertices_flg(); 00287 void set_show_bad_vertices_flg( CubitBoolean flg ); 00288 CubitBoolean get_show_bad_curves_flg(); 00289 void set_show_bad_curves_flg( CubitBoolean flg ); 00290 CubitBoolean get_show_bad_coedges_flg(); 00291 void set_show_bad_coedges_flg( CubitBoolean flg ); 00292 CubitBoolean get_show_bad_loops_flg(); 00293 void set_show_bad_loops_flg( CubitBoolean flg ); 00294 CubitBoolean get_show_bad_surfaces_flg(); 00295 void set_show_bad_surfaces_flg( CubitBoolean flg ); 00296 CubitBoolean get_show_bad_shells_flg(); 00297 void set_show_bad_shells_flg( CubitBoolean flg ); 00298 CubitBoolean get_show_bad_volumes_flg(); 00299 void set_show_bad_volumes_flg( CubitBoolean flg ); 00300 CubitBoolean get_show_bad_bodies_flg(); 00301 void set_show_bad_bodies_flg( CubitBoolean flg ); 00303 00305 void list_onshow_flgs(); 00306 00308 // Functions for controlling incremental healing 00309 CubitBoolean get_inc_preprocess_flg(); 00310 void set_inc_preprocess_flg( CubitBoolean flg ); 00311 CubitBoolean get_inc_simplify_flg(); 00312 void set_inc_simplify_flg( CubitBoolean flg ); 00313 CubitBoolean get_inc_stitch_flg(); 00314 void set_inc_stitch_flg( CubitBoolean flg ); 00315 CubitBoolean get_inc_geombuild_flg(); 00316 void set_inc_geombuild_flg( CubitBoolean flg ); 00317 CubitBoolean get_inc_analytic_flg(); 00318 void set_inc_analytic_flg( CubitBoolean flg ); 00319 CubitBoolean get_inc_isospline_flg(); 00320 void set_inc_isospline_flg( CubitBoolean flg ); 00321 CubitBoolean get_inc_reblend_flg(); 00322 void set_inc_reblend_flg( CubitBoolean flg ); 00323 CubitBoolean get_inc_sharpedge_flg(); 00324 void set_inc_sharpedge_flg( CubitBoolean flg ); 00325 CubitBoolean get_inc_genericspline_flg(); 00326 void set_inc_genericspline_flg( CubitBoolean flg ); 00327 CubitBoolean get_inc_wrapup_flg(); 00328 void set_inc_wrapup_flg( CubitBoolean flg ); 00329 CubitBoolean get_inc_postprocess_flg(); 00330 void set_inc_postprocess_flg( CubitBoolean flg ); 00332 00334 00335 CubitStatus force_simplify_to_plane( DLIList<RefFace*> &ref_face_list, DLIList<Body*>& new_body_list, 00336 CubitBoolean keep = CUBIT_FALSE ); 00337 CubitStatus force_simplify_to_cylinder( DLIList<RefFace*> &ref_face_list, DLIList<Body*>& new_body_list, 00338 CubitBoolean keep = CUBIT_FALSE ); 00339 CubitStatus force_simplify_to_cone( DLIList<RefFace*> &ref_face_list, DLIList<Body*>& new_body_list, 00340 CubitBoolean keep = CUBIT_FALSE ); 00341 CubitStatus force_simplify_to_sphere( DLIList<RefFace*> &ref_face_list, DLIList<Body*>& new_body_list, 00342 CubitBoolean keep = CUBIT_FALSE ); 00343 CubitStatus force_simplify_to_torus( DLIList<RefFace*> &ref_face_list, DLIList<Body*>& new_body_list, 00344 CubitBoolean keep = CUBIT_FALSE ); 00346 00347 // *** END HEALER FUNCTIONS *** // 00348 00349 protected: 00350 00351 // constructor 00352 GeometryHealerTool( GeometryHealerEngine *GHEPtr ); 00353 00354 private: 00355 00356 // singleton pattern class instance interface 00357 static GeometryHealerTool* instance_; 00358 00359 // list of healer engines 00360 DLIList<GeometryHealerEngine*> gheList; 00361 }; 00362 00363 #endif 00364
