cgma
00001 00002 00003 00004 00005 00006 00007 00008 00009 00010 00011 00012 00013 00014 00015 00016 #include "MedialTool3D.hpp" 00017 #include "CubitMessage.hpp" 00018 00019 #ifdef USING_MEDIAL 00020 00021 00022 00023 #include "medial/medial_util/MedialDefines.hpp" 00024 #include "medial/medial_util/Triangle3D.hpp" 00025 #include "medial/medial_util/Vec3D.hpp" 00026 #include "medial/medial3D/Medial3DAPI.hpp" 00027 #include "medial/medial3D/MedialVertex3D.hpp" 00028 #include "medial/medial3D/MedialEdge3D.hpp" 00029 #include "medial/medial3D/MedialFace3D.hpp" 00030 00034 #include "GfxDebug.hpp" 00035 #include "CubitVector.hpp" 00036 #include "RefVertex.hpp" 00037 #include "RefFace.hpp" 00038 #include "RefVolume.hpp" 00039 #include "CubitPoint.hpp" 00040 #include "CubitFacet.hpp" 00041 #endif //USING_MEDIAL 00042 00043 00050 MedialTool3D::MedialTool3D(RefVolume *ref_volume_ptr) 00051 { 00052 myRefVolume = ref_volume_ptr; 00053 } 00054 00061 MedialTool3D::~MedialTool3D() 00062 { 00063 00064 } 00065 00076 #ifndef USING_MEDIAL 00077 CubitStatus MedialTool3D::create_medial_axis_3d( 00078 DLIList <RefVertex*> &medial_verts, 00079 DLIList <RefEdge*> &medial_edges, 00080 DLIList <RefFace*> &medial_faces, 00081 bool full_search, 00082 double cube_size, 00083 double accuracy, 00084 double min_ang_strong, 00085 double min_angle_diff_components) 00086 { 00087 PRINT_ERROR("Medial Axis Code is not included with this version of CGM.\n"); 00088 return CUBIT_FAILURE; 00089 } 00090 #endif 00091 00093 // Functions that gets compiled only when compiling the medial stuff 00095 #ifdef USING_MEDIAL 00096 00097 00098 00099 00100 00101 00102 00103 00104 00105 00106 CubitStatus MedialTool3D::create_medial_axis_3d( 00107 DLIList <RefVertex*> &medial_verts, 00108 DLIList <RefEdge*> &medial_edges, 00109 DLIList <RefFace*> &medial_faces, 00110 bool full_search, 00111 double cube_size, 00112 double accuracy, 00113 double min_ang_strong, 00114 double min_angle_diff_components) 00115 { 00116 // create the array of vertices and triangles to represent objectdata3d 00117 Vec3DPArray my_vertices; 00118 Triangle3DPArray my_facets; 00119 00120 MedialVertex3DPArray my_output_verts; 00121 MedialEdge3DPArray my_output_edges; 00122 MedialFace3DPArray my_output_faces; 00123 00124 // get the boundary facets 00125 CubitStatus boundaries = get_boundary_facets(my_vertices, my_facets); 00126 00127 // create the medial axis by calling the Medial3DAPI 00128 int results = Medial3DAPI::create_medial3d(my_vertices, my_facets, 00129 full_search, cube_size, accuracy, min_ang_strong, 00130 min_angle_diff_components, my_output_verts, 00131 my_output_edges, my_output_faces); 00132 00133 if ( results != 1 ) 00134 { 00135 PRINT_ERROR("Medial Extraction Failed.\n"); 00136 return CUBIT_FAILURE; 00137 } 00138 draw_medial_results( my_output_verts, my_output_edges, my_output_faces, 00139 CUBIT_RED_INDEX, CUBIT_CYAN_INDEX, CUBIT_RED_INDEX); 00140 00141 // translate the data from Medial Extractor format back to Cubit Format 00142 //?***** Not implemented as of now. 00143 return CUBIT_SUCCESS; 00144 } 00145 00153 void MedialTool3D::convert_vec3d_to_cubitvector( Vec3D &my_vec3d, 00154 CubitVector &my_cubitvec) 00155 { 00156 my_cubitvec.set(my_vec3d.x, my_vec3d.y, my_vec3d.z); 00157 } 00158 00166 void MedialTool3D::convert_cubitvector_to_vec3d( CubitVector &my_cubitvec, 00167 Vec3D &my_vec3d) 00168 { 00169 my_vec3d.x = my_cubitvec.x(); 00170 my_vec3d.y = my_cubitvec.y(); 00171 my_vec3d.z = my_cubitvec.z(); 00172 } 00173 00180 void MedialTool3D::draw_medial_results( 00181 MedialVertex3DPArray &output_vertices, 00182 MedialEdge3DPArray &output_edges, 00183 MedialFace3DPArray &output_faces, 00184 int vert_color, int edge_color, int face_color) 00185 { 00186 int ii; 00187 Vec3D curr_vec3d_1, curr_vec3d_2; 00188 00189 int n1 = output_vertices.size(); 00190 int n2 = output_edges.size(); 00191 00192 printf("Before drawing the results to screen\n"); 00193 printf("Number of output vertices = %d\n",output_vertices.size()); 00194 printf("Number of output segments = %d\n",output_edges.size()); 00195 printf("Number of output triangles= %d\n",output_faces.size()); 00196 /* 00197 // draw the vertices 00198 for(ii =0; ii < output_vertices.size(); ii++) 00199 { 00200 curr_vec3d_1 = output_vertices[ii]->coordinates(); 00201 GfxDebug::draw_point(curr_vec3d_1.x, curr_vec3d_1.y, curr_vec3d_1.z, vert_color); 00202 } 00203 GfxDebug::flush(); 00204 00205 // draw the edges 00206 for(ii=0; ii < output_edges.size(); ii++) 00207 { 00208 // get the start, end vertices and convert them to CubitVector format 00209 curr_vec3d_1 = output_edges[ii]->get_start_coordinates(); 00210 curr_vec3d_2 = output_edges[ii]->get_end_coordinates(); 00211 GfxDebug::draw_line(curr_vec3d_1.x, curr_vec3d_1.y, 00212 curr_vec3d_1.z, curr_vec3d_2.x, curr_vec3d_2.y, curr_vec3d_2.z, 00213 edge_color); 00214 } 00215 GfxDebug::flush(); 00216 */ 00217 //draw faces 00218 for(ii=0; ii<output_faces.size(); ii++) 00219 { 00220 // Points are ordered clockwise around the tri. 00221 draw_medial_face(output_faces[ii], face_color); 00222 // void draw_tri (GPoint p[], int color); 00223 } 00224 GfxDebug::flush(); 00225 } 00226 00234 void MedialTool3D::draw_medial_face(MedialFace3D* my_face, int tri_color) 00235 { 00236 // array of three points 00237 GPoint my_points[3]; 00238 Vec3D v1, v2, v3; 00239 v1 = my_face->get_vertex1_coordinates(); 00240 v2 = my_face->get_vertex2_coordinates(); 00241 v3 = my_face->get_vertex3_coordinates(); 00242 my_points[0].x = v1.x; my_points[0].y = v1.y; my_points[0].z = v1.z; 00243 my_points[1].x = v2.x; my_points[1].y = v2.y; my_points[1].z = v2.z; 00244 my_points[2].x = v3.x; my_points[2].y = v3.y; my_points[2].z = v3.z; 00245 //GfxDebug::draw_tri(my_points, tri_color); 00246 GfxDebug::draw_polygon(my_points, 3, 8/*CUBIT_GREEN_INDEX*/, CUBIT_GREEN_INDEX); 00247 } 00248 00249 00259 CubitStatus MedialTool3D::get_boundary_facets( 00260 Vec3DPArray &boundary_verts, 00261 Triangle3DPArray &boundary_facets) 00262 { 00263 // get all the ref faces of the volume 00264 DLIList<RefFace*> ref_faces_list; 00265 CubitStatus get_faces_status = myRefVolume->ref_faces(ref_faces_list); 00266 if(get_faces_status != CUBIT_SUCCESS) 00267 { 00268 PRINT_ERROR("Problem in getting the faces of volume geometry\n" 00269 "Check volume %d\n", myRefVolume->id()); 00270 return CUBIT_FAILURE; 00271 } 00272 00273 // loop through each RefFace and get its facets 00274 int ii; 00275 RefFace *my_face; 00276 CubitStatus face_facet_stat; 00277 DLIList<CubitFacet*> my_facet_list; // delete these after done 00278 DLIList<CubitPoint*> my_point_list; // delete after done 00279 00280 for(ii = ref_faces_list.size(); ii > 0; ii--) 00281 { 00282 my_face = ref_faces_list.get_and_step(); 00283 00284 // get the facets for the current face 00285 // get_facets appends the new vertices and facets to the exusting list 00286 face_facet_stat = my_face->get_facets( my_facet_list, my_point_list); 00287 00288 if(face_facet_stat != CUBIT_SUCCESS) 00289 { 00290 PRINT_ERROR("Problem in getting the facets of face geometry\n" 00291 "Check surface %d in volume %d\n", 00292 my_face->id(), myRefVolume->id()); 00293 return CUBIT_FAILURE; 00294 } 00295 } 00296 00297 // translate the points to Vec3D format and flag the my_point_list 00298 CubitPoint *my_point; 00299 Vec3D *new_vec3d; 00300 00301 // resize the size of "boundary_verts" and "boundary_facets" to equal that 00302 // of "my_point_list" and "my_facet_list" 00303 boundary_verts.resize(my_point_list.size()); 00304 boundary_facets.resize(my_facet_list.size()); 00305 00306 // set all the pointers in vector list to NULL for safety 00307 for(ii=0; ii < boundary_verts.size(); ii++) 00308 boundary_verts[ii] = NULL; 00309 for(ii=0; ii < boundary_facets.size(); ii++) 00310 boundary_facets[ii] = NULL; 00311 00312 // location of the current point 00313 CubitVector pt_coord; 00314 00315 // go to each cubit point; set a flag and create corresponding new Vec3D 00316 for(ii = my_point_list.size(); ii > 0; ii--) 00317 { 00318 my_point = my_point_list.get_and_step(); 00319 // set the mark number 00320 my_point->marked(ii-1); 00321 // create new Vec3D 00322 pt_coord = my_point->coordinates(); 00323 new_vec3d = new Vec3D(pt_coord.x(), pt_coord.y(), pt_coord.z()); 00324 boundary_verts[ii-1] = new_vec3d; 00325 } 00326 00327 // translate the facets to Triangle3D format 00328 CubitFacet *my_facet; 00329 CubitPoint *vert0, *vert1, *vert2; 00330 Vec3D my_vert0, my_vert1, my_vert2; 00331 Triangle3D *my_tri; 00332 00333 // go through each facet and create new Triangle3D 00334 for(ii = my_facet_list.size(); ii > 0; ii--) 00335 { 00336 my_facet = my_facet_list.get_and_step(); 00337 // get the three points that form the facet and also their id's 00338 vert0 = my_facet->point(0); 00339 vert1 = my_facet->point(1); 00340 vert2 = my_facet->point(2); 00341 00342 // create new Triangle3D 00343 my_tri = new Triangle3D(boundary_verts, 00344 vert0->marked(), vert1->marked(), vert2->marked()); 00345 // assign the Triangle3D to its position in vector list 00346 boundary_facets[ii-1] = my_tri; 00347 } 00348 00349 // delete the facet entities 00350 for(ii=my_facet_list.size(); ii >0; ii--) 00351 delete my_facet_list.pop(); 00352 my_facet_list.clean_out(); 00353 00354 // delete the vertex entities 00355 for(ii=my_point_list.size(); ii>0; ii--) 00356 delete my_point_list.pop(); 00357 my_point_list.clean_out(); 00358 00359 return CUBIT_SUCCESS; 00360 } 00361 #endif // USING_MEDIAL
