cgma
00001 #include "OldUnmergeCode.hpp" 00002 00003 #include "Body.hpp" 00004 #include "CoVolume.hpp" 00005 #include "RefVolume.hpp" 00006 #include "Shell.hpp" 00007 #include "CoFace.hpp" 00008 #include "RefFace.hpp" 00009 #include "Loop.hpp" 00010 #include "CoEdge.hpp" 00011 #include "RefEdge.hpp" 00012 #include "Chain.hpp" 00013 #include "CoVertex.hpp" 00014 #include "RefVertex.hpp" 00015 00016 #include "BodySM.hpp" 00017 #include "Lump.hpp" 00018 #include "ShellSM.hpp" 00019 #include "Surface.hpp" 00020 #include "LoopSM.hpp" 00021 #include "CoEdgeSM.hpp" 00022 #include "Curve.hpp" 00023 #include "Point.hpp" 00024 00025 #include "GeometryQueryTool.hpp" 00026 #include "RefEntityFactory.hpp" 00027 #include "CpuTimer.hpp" 00028 #include "ProgressTool.hpp" 00029 #include "AppUtil.hpp" 00030 00031 #include "MergeTool.hpp" 00032 #include "MergeToolAssistant.hpp" 00033 #include "SettingHandler.hpp" 00034 00035 00036 void OldUnmergeCode::initialize_settings() 00037 { 00038 SettingHandler::instance()->add_setting("unmerge new ids", 00039 OldUnmergeCode::set_use_old_unmerge_code, 00040 OldUnmergeCode::get_use_old_unmerge_code); 00041 } 00042 00043 bool OldUnmergeCode::useOldUnmergeCode = false; 00044 00045 00046 bool OldUnmergeCode::get_use_old_unmerge_code() 00047 { return useOldUnmergeCode; } 00048 00049 void OldUnmergeCode::set_use_old_unmerge_code( bool value ) 00050 { useOldUnmergeCode = value; } 00051 00052 00053 00054 00055 OldUnmergeCode& OldUnmergeCode::instance() 00056 { 00057 static OldUnmergeCode instance_; 00058 return instance_; 00059 } 00060 00061 //------------------------------------------------------------------------- 00062 // Purpose : Unmerge everything 00063 // 00064 // Special Notes : 00065 // 00066 // Creator : Jason Kraftcheck 00067 // 00068 // Creation Date : 03/27/01 00069 //------------------------------------------------------------------------- 00070 CubitStatus OldUnmergeCode::unmerge_all() 00071 { 00072 if (!get_use_old_unmerge_code()) 00073 return MergeTool::instance()->unmerge_all(); 00074 00075 int i; 00076 CubitStatus result = CUBIT_SUCCESS; 00077 CubitBoolean top = start_unmerge(); 00078 00079 00080 DLIList<RefFace*> face_list; 00081 DLIList<RefEdge*> edge_list; 00082 DLIList<RefVertex*> vtx_list; 00083 00084 GeometryQueryTool::instance()->ref_faces( face_list ); 00085 GeometryQueryTool::instance()->ref_edges( edge_list ); 00086 GeometryQueryTool::instance()->ref_vertices( vtx_list ); 00087 00088 for( i = face_list.size(); (i > 0) && !AppUtil::instance()->interrupt(); i-- ) 00089 if( ! unmerge(face_list.get_and_step(),CUBIT_FALSE) ) 00090 result = CUBIT_FAILURE; 00091 00092 for( i = edge_list.size(); (i > 0) && !AppUtil::instance()->interrupt(); i-- ) 00093 if( ! unmerge(edge_list.get_and_step(),CUBIT_FALSE) ) 00094 result = CUBIT_FAILURE; 00095 00096 for( i = vtx_list.size(); (i > 0) && !AppUtil::instance()->interrupt(); i-- ) 00097 if( ! unmerge(vtx_list.get_and_step()) ) 00098 result = CUBIT_FAILURE; 00099 00100 end_unmerge(top); 00101 return result; 00102 } 00103 00104 00105 //------------------------------------------------------------------------- 00106 // Purpose : Unmerge RefEntities 00107 // 00108 // Special Notes : 00109 // 00110 // Creator : Jason Kraftcheck 00111 // 00112 // Creation Date : 01/18/01 00113 //------------------------------------------------------------------------- 00114 CubitStatus OldUnmergeCode::unmerge( DLIList<RefEntity*> &entity_list, 00115 CubitBoolean descend ) 00116 { 00117 if (!get_use_old_unmerge_code()) 00118 return MergeTool::instance()->unmerge(entity_list, descend); 00119 00120 CubitBoolean top = start_unmerge(); 00121 00122 for( int i = entity_list.size(); (i > 0) && !AppUtil::instance()->interrupt(); i-- ) 00123 unmerge( entity_list.get_and_step(), descend ); 00124 00125 end_unmerge(top); 00126 return CUBIT_SUCCESS; 00127 } 00128 00129 //------------------------------------------------------------------------- 00130 // Purpose : Unmerge a RefEntity 00131 // 00132 // Special Notes : All parents must be unmerged. 00133 // 00134 // Creator : Jason Kraftcheck 00135 // 00136 // Creation Date : 01/18/01 00137 //------------------------------------------------------------------------- 00138 CubitStatus OldUnmergeCode::unmerge( RefEntity* entity_ptr, CubitBoolean descend ) 00139 { 00140 if (!get_use_old_unmerge_code()) 00141 return MergeTool::instance()->unmerge(entity_ptr, descend); 00142 00143 if( CAST_TO( entity_ptr, Body ) ) 00144 return descend ? unmerge(CAST_TO(entity_ptr,Body)) : CUBIT_FAILURE; 00145 else if( CAST_TO( entity_ptr, RefVolume ) ) 00146 return descend ? unmerge(CAST_TO(entity_ptr,RefVolume)) : CUBIT_FAILURE; 00147 else if( CAST_TO( entity_ptr, RefFace ) ) 00148 return unmerge( CAST_TO(entity_ptr,RefFace), descend ); 00149 else if( CAST_TO( entity_ptr, RefEdge ) ) 00150 return unmerge( CAST_TO(entity_ptr,RefEdge), descend ); 00151 else if( CAST_TO( entity_ptr, RefVertex ) ) 00152 return unmerge( CAST_TO(entity_ptr,RefVertex) ); 00153 else 00154 { 00155 PRINT_ERROR("Bad Entity \"%s\" in " 00156 "OldUnmergeCode::unmerge(RefEntity*,CubitBoolean)\n", 00157 entity_ptr->class_name()); 00158 return CUBIT_FAILURE; 00159 } 00160 } 00161 00162 CubitStatus OldUnmergeCode::unmerge( Body* body_ptr ) 00163 { 00164 if (!get_use_old_unmerge_code()) 00165 return MergeTool::instance()->unmerge(body_ptr); 00166 00167 CubitBoolean top = start_unmerge(); 00168 CubitStatus result = CUBIT_SUCCESS; 00169 DLIList<RefVolume*> vol_list; 00170 body_ptr->ref_volumes(vol_list); 00171 for( int i = vol_list.size(); (i > 0) && !AppUtil::instance()->interrupt(); i-- ) 00172 if( !unmerge(vol_list.get_and_step()) ) 00173 result = CUBIT_FAILURE; 00174 end_unmerge(top); 00175 return result; 00176 } 00177 00178 CubitStatus OldUnmergeCode::unmerge( RefVolume* vol_ptr ) 00179 { 00180 if (!get_use_old_unmerge_code()) 00181 return MergeTool::instance()->unmerge(vol_ptr); 00182 00183 CubitBoolean top = start_unmerge(); 00184 CubitStatus result = CUBIT_SUCCESS; 00185 DLIList<RefFace*> face_list, new_faces; 00186 DLIList<RefEdge*> edge_list, new_edges; 00187 DLIList<RefVertex*> vtx_list; 00188 vol_ptr->ref_faces(face_list); 00189 vol_ptr->ref_edges(edge_list); 00190 vol_ptr->ref_vertices(vtx_list); 00191 face_list.reset(); 00192 while( face_list.size() && !AppUtil::instance()->interrupt() ) 00193 { 00194 RefFace* old_face = face_list.extract(); 00195 RefFace* new_face = unmerge(old_face,vol_ptr); 00196 if( new_face ) 00197 new_faces.append(new_face); 00198 else 00199 result = CUBIT_FAILURE; 00200 } 00201 00202 while( edge_list.size() && !AppUtil::instance()->interrupt() ) 00203 { 00204 RefEdge* old_edge = edge_list.extract(); 00205 face_list.clean_out(); 00206 old_edge->ref_faces(face_list); 00207 while( face_list.size() ) 00208 { 00209 RefFace* face_ptr = face_list.extract(); 00210 if( new_faces.is_in_list(face_ptr) ) 00211 { 00212 RefEdge* new_edge = unmerge(old_edge,face_ptr); 00213 if( new_edge ) 00214 new_edges.append(new_edge); 00215 else 00216 result = CUBIT_FAILURE; 00217 break; 00218 } 00219 } 00220 } 00221 00222 00223 while( vtx_list.size() && !AppUtil::instance()->interrupt() ) 00224 { 00225 RefVertex* old_vtx = vtx_list.extract(); 00226 edge_list.clean_out(); 00227 old_vtx->ref_edges(edge_list); 00228 while( edge_list.size() ) 00229 { 00230 RefEdge* edge_ptr = edge_list.extract(); 00231 if( new_edges.is_in_list(edge_ptr) ) 00232 { 00233 RefVertex* new_vtx = unmerge(old_vtx,edge_ptr); 00234 if( !new_vtx ) 00235 result = CUBIT_FAILURE; 00236 break; 00237 } 00238 } 00239 } 00240 00241 end_unmerge(top); 00242 return result; 00243 } 00244 00245 CubitStatus OldUnmergeCode::unmerge( RefFace* face_ptr, CubitBoolean descend ) 00246 { 00247 if (!get_use_old_unmerge_code()) 00248 return MergeTool::instance()->unmerge(face_ptr, descend); 00249 00250 CubitBoolean top = start_unmerge(); 00251 CubitStatus result = CUBIT_SUCCESS; 00252 CubitBoolean reversed; 00253 int i; 00254 00255 // if( !face_ptr->can_modify() ) 00256 // return CUBIT_FAILURE; 00257 00258 DLIList<RefFace*> unmerged_faces; 00259 DLIList<RefVolume*> vol_list; 00260 face_ptr->ref_volumes(vol_list); 00261 if( vol_list.size() ) 00262 { 00263 for( i = vol_list.size(); i > 0; i-- ) 00264 { 00265 RefFace* new_face = unmerge(face_ptr,vol_list.get_and_step()); 00266 if( new_face ) 00267 unmerged_faces.append_unique(new_face); 00268 else 00269 result = CUBIT_FAILURE; 00270 } 00271 } 00272 else 00273 { 00274 DLIList<TopologyBridge*> bridge_list; 00275 face_ptr->bridge_manager()->get_bridge_list( bridge_list ); 00276 00277 //Try top remove each bridge 00278 for( i = bridge_list.size(); i > 0; i-- ) 00279 { 00280 //but stop if there is only one left 00281 if( face_ptr->bridge_manager()->number_of_bridges() == 1 ) 00282 { 00283 unmerged_faces.append(face_ptr); 00284 break; 00285 } 00286 00287 TopologyBridge* bridge_ptr = bridge_list.get_and_step(); 00288 Surface* surf_ptr = CAST_TO(bridge_ptr,Surface); 00289 assert(surf_ptr != 0); 00290 RefFace* new_face = split_out_Surface(surf_ptr, reversed); 00291 if( new_face ) 00292 { 00293 unmerged_faces.append(new_face); 00294 00295 //Notify merge assistants of unmerge 00296 DLIList<MergeToolAssistant*>& assistant_list_ = MergeTool::instance()->assistant_list_; 00297 for( int a = assistant_list_.size(); a > 0; a-- ) 00298 assistant_list_.get_and_step()-> 00299 unmerged( face_ptr, new_face, reversed ); 00300 } 00301 else 00302 result = CUBIT_FAILURE; 00303 } 00304 if( !unmerged_faces.is_in_list(face_ptr) ) 00305 result = CUBIT_FAILURE; 00306 } 00307 00308 if( !descend ) 00309 { 00310 end_unmerge(top); 00311 return result; 00312 } 00313 00314 DLIList<RefEdge*> edge_list, unmerged_edges; 00315 for( i = unmerged_faces.size(); i > 0; i-- ) 00316 { 00317 face_ptr = unmerged_faces.get_and_step(); 00318 edge_list.clean_out(); 00319 face_ptr->ref_edges(edge_list); 00320 for( int j = edge_list.size(); j > 0; j-- ) 00321 { 00322 RefEdge* new_edge = unmerge(edge_list.get_and_step(),face_ptr); 00323 if( new_edge ) 00324 unmerged_edges.append_unique(new_edge); 00325 else 00326 result = CUBIT_FAILURE; 00327 } 00328 } 00329 00330 DLIList<RefVertex*> vtx_list; 00331 for( i = unmerged_edges.size(); i > 0; i-- ) 00332 { 00333 RefEdge* edge_ptr = unmerged_edges.get_and_step(); 00334 vtx_list.clean_out(); 00335 edge_ptr->ref_vertices(vtx_list); 00336 for( int j = vtx_list.size(); j > 0; j-- ) 00337 { 00338 RefVertex* new_vtx = unmerge(vtx_list.get_and_step(),edge_ptr); 00339 if( !new_vtx ) result = CUBIT_FAILURE; 00340 } 00341 } 00342 00343 end_unmerge(top); 00344 return result; 00345 } 00346 00347 00348 CubitStatus OldUnmergeCode::unmerge( RefEdge* edge_ptr, CubitBoolean descend ) 00349 { 00350 if (!get_use_old_unmerge_code()) 00351 return MergeTool::instance()->unmerge(edge_ptr, descend); 00352 00353 CubitBoolean top = start_unmerge(); 00354 CubitStatus result = CUBIT_SUCCESS; 00355 CubitBoolean reversed; 00356 int i; 00357 00358 // if( !edge_ptr->can_modify() ) 00359 // return CUBIT_FAILURE; 00360 00361 DLIList<RefEdge*> unmerged_edges; 00362 DLIList<RefFace*> face_list; 00363 edge_ptr->ref_faces(face_list); 00364 if( face_list.size() ) 00365 { 00366 for( i = face_list.size(); i > 0; i-- ) 00367 { 00368 RefEdge* new_edge = unmerge(edge_ptr,face_list.get_and_step()); 00369 if( new_edge ) 00370 unmerged_edges.append_unique(new_edge); 00371 else 00372 result = CUBIT_FAILURE; 00373 } 00374 } 00375 else 00376 { 00377 DLIList<TopologyBridge*> bridge_list; 00378 DLIList<Curve*> curve_list; 00379 edge_ptr->bridge_manager()->get_bridge_list( bridge_list ); 00380 00381 //Try top remove each bridge 00382 for( i = bridge_list.size(); i > 0; i-- ) 00383 { 00384 //but stop if there is only one left 00385 if( edge_ptr->bridge_manager()->number_of_bridges() == 1 ) 00386 { 00387 unmerged_edges.append(edge_ptr); 00388 break; 00389 } 00390 00391 TopologyBridge* bridge_ptr = bridge_list.get_and_step(); 00392 curve_list.clean_out(); 00393 curve_list.append( CAST_TO(bridge_ptr,Curve) ); 00394 RefEdge* new_edge = split_out_Curves(curve_list, reversed); 00395 if( new_edge ) 00396 { 00397 unmerged_edges.append(new_edge); 00398 00399 //Notify merge assistants of unmerge 00400 DLIList<MergeToolAssistant*>& assistant_list_ = MergeTool::instance()->assistant_list_; 00401 for( int a = assistant_list_.size(); a > 0; a-- ) 00402 assistant_list_.get_and_step()-> 00403 unmerged( edge_ptr, new_edge, reversed ); 00404 } 00405 else 00406 result = CUBIT_FAILURE; 00407 } 00408 if( !unmerged_edges.is_in_list(edge_ptr) ) 00409 result = CUBIT_FAILURE; 00410 } 00411 00412 if( !descend ) 00413 { 00414 end_unmerge(top); 00415 return result; 00416 } 00417 00418 DLIList<RefVertex*> vtx_list; 00419 for( i = unmerged_edges.size(); i > 0; i-- ) 00420 { 00421 edge_ptr = unmerged_edges.get_and_step(); 00422 vtx_list.clean_out(); 00423 edge_ptr->ref_vertices(vtx_list); 00424 for( int j = vtx_list.size(); j > 0; j-- ) 00425 { 00426 RefVertex* new_vtx = unmerge(vtx_list.get_and_step(),edge_ptr); 00427 if( !new_vtx ) 00428 result = CUBIT_FAILURE; 00429 } 00430 } 00431 00432 end_unmerge(top); 00433 return result; 00434 } 00435 00436 00437 CubitStatus OldUnmergeCode::unmerge( RefVertex* vtx_ptr ) 00438 { 00439 if (!get_use_old_unmerge_code()) 00440 return MergeTool::instance()->unmerge(vtx_ptr); 00441 00442 CubitBoolean top = start_unmerge(); 00443 CubitStatus result = CUBIT_SUCCESS; 00444 int i; 00445 00446 // if( !vtx_ptr->can_modify() ) 00447 // return CUBIT_FAILURE; 00448 00449 DLIList<RefVertex*> unmerged_vtxs; 00450 DLIList<RefEdge*> edge_list; 00451 vtx_ptr->ref_edges(edge_list); 00452 if( edge_list.size() ) 00453 { 00454 for( i = edge_list.size(); i > 0; i-- ) 00455 { 00456 RefVertex* new_vtx = unmerge(vtx_ptr,edge_list.get_and_step()); 00457 if( new_vtx ) 00458 unmerged_vtxs.append_unique(new_vtx); 00459 else 00460 result = CUBIT_FAILURE; 00461 } 00462 } 00463 else 00464 { 00465 DLIList<TopologyBridge*> bridge_list; 00466 DLIList<TBPoint*> point_list; 00467 vtx_ptr->bridge_manager()->get_bridge_list( bridge_list ); 00468 00469 //Try top remove each bridge 00470 for( i = bridge_list.size(); i > 0; i-- ) 00471 { 00472 //but stop if there is only one left 00473 if( vtx_ptr->bridge_manager()->number_of_bridges() == 1 ) 00474 { 00475 unmerged_vtxs.append(vtx_ptr); 00476 break; 00477 } 00478 00479 TopologyBridge* bridge_ptr = bridge_list.get_and_step(); 00480 point_list.clean_out(); 00481 point_list.append( CAST_TO(bridge_ptr,TBPoint) ); 00482 RefVertex* new_vtx = split_out_Points(point_list); 00483 if( new_vtx ) 00484 { 00485 unmerged_vtxs.append(new_vtx); 00486 00487 //Notify merge assistants of unmerge 00488 DLIList<MergeToolAssistant*>& assistant_list_ = MergeTool::instance()->assistant_list_; 00489 for( int a = assistant_list_.size(); a > 0; a-- ) 00490 assistant_list_.get_and_step()-> 00491 unmerged( vtx_ptr, new_vtx, CUBIT_FALSE ); 00492 } 00493 else 00494 result = CUBIT_FAILURE; 00495 } 00496 if( !unmerged_vtxs.is_in_list(vtx_ptr) ) 00497 result = CUBIT_FAILURE; 00498 } 00499 00500 end_unmerge(top); 00501 return result; 00502 } 00503 00504 00505 //------------------------------------------------------------------------- 00506 // Purpose : Given an unmerged parent, and a merged child, 00507 // unmerge the topology bridge of the child that 00508 // corresponds to the passed parent. 00509 // 00510 // Special Notes : 00511 // 00512 // Creator : Jason Kraftcheck 00513 // 00514 // Creation Date : 01/18/01 00515 //------------------------------------------------------------------------- 00516 RefFace* OldUnmergeCode::unmerge( RefFace* face_ptr, RefVolume* vol_ptr ) 00517 { 00518 assert( face_ptr && vol_ptr ); 00519 CubitBoolean top = start_unmerge(); 00520 CubitBoolean reversed; 00521 int i; 00522 00523 // if( !face_ptr->can_modify() ) 00524 // { 00525 // end_unmerge(top); 00526 // return 0; 00527 // } 00528 00529 //If passed entity is not merged, just return it. 00530 if( face_ptr->bridge_manager()->number_of_bridges() < 2 ) 00531 { 00532 end_unmerge(top); 00533 return face_ptr; 00534 } 00535 00536 //Find the Surfaces of face_ptr that go with vol_ptr 00537 DLIList<Lump*> surf_lumps; 00538 DLIList<Surface*> surface_list; 00539 DLIList<TopologyBridge*> bridge_list; 00540 face_ptr->bridge_manager()->get_bridge_list(bridge_list); 00541 for( i = bridge_list.size(); i > 0; i-- ) 00542 { 00543 TopologyBridge* bridge_ptr = bridge_list.get_and_step(); 00544 surf_lumps.clean_out(); 00545 bridge_ptr->lumps(surf_lumps); 00546 for( int j = surf_lumps.size(); j> 0; j-- ) 00547 { 00548 if( surf_lumps.get_and_step()->topology_entity() == vol_ptr ) 00549 { 00550 surface_list.append(CAST_TO(bridge_ptr,Surface)); 00551 break; 00552 } 00553 } 00554 } 00555 //face_ptr and vol_ptr have no association in SM topology!! 00556 if( ! surface_list.size() ) 00557 { 00558 end_unmerge(top); 00559 return 0; 00560 } 00561 00562 //Assuming this is true, until this assert fails 00563 assert(surface_list.size() == 1); 00564 Surface* surface_ptr = surface_list.get(); 00565 00566 // Unmerge any child GroupingEntities and SenseEntities, 00567 // and reconstruct a new owner. 00568 RefFace* new_entity 00569 = split_out_Surface( surface_ptr, reversed ); 00570 if( !new_entity ) 00571 { 00572 end_unmerge(top); 00573 return 0; 00574 } 00575 00576 // Find any links from parent to old entity, and move them 00577 // to the new, unmerged entity. 00578 DLIList<CoFace*> coface_list; 00579 DLIList<ShellSM*> shellsm_list; 00580 surface_ptr->shellsms( shellsm_list ); 00581 for( i = shellsm_list.size(); i > 0; i-- ) 00582 { 00583 ShellSM* shellsm = shellsm_list.get_and_step(); 00584 Shell* shell_ptr = CAST_TO(shellsm->topology_entity(),Shell); 00585 if( !shell_ptr ) continue; 00586 00587 coface_list.clean_out(); 00588 shell_ptr->co_faces(coface_list); 00589 for( int j = coface_list.size(); j > 0; j-- ) 00590 { 00591 CoFace* cof_ptr = coface_list.get_and_step(); 00592 if( cof_ptr->get_ref_face_ptr() == face_ptr ) 00593 { 00594 cof_ptr->switch_basic_topology_entity(new_entity); 00595 if( reversed ) cof_ptr->reverse_sense(); 00596 } 00597 } 00598 } 00599 00600 //We have changed the topology of the passed RefVolume. 00601 //Note this for later. 00602 unmerge_modified.append( face_ptr ); 00603 00604 //Notify merge assistants of unmerge 00605 DLIList<MergeToolAssistant*>& assistant_list_ = MergeTool::instance()->assistant_list_; 00606 for( int a = assistant_list_.size(); a > 0; a-- ) 00607 assistant_list_.get_and_step()-> 00608 unmerged( face_ptr, new_entity, reversed ); 00609 00610 end_unmerge(top); 00611 return new_entity; 00612 } 00613 00614 00615 RefEdge* OldUnmergeCode::unmerge( RefEdge* edge_ptr, RefFace* face_ptr ) 00616 { 00617 assert( face_ptr && edge_ptr ); 00618 CubitBoolean top = start_unmerge(); 00619 CubitBoolean reversed; 00620 int i; 00621 00622 // if( !edge_ptr->can_modify() ) 00623 // { 00624 // end_unmerge(top); 00625 // return 0; 00626 // } 00627 00628 //If passed entity is not merged, just return it. 00629 if( edge_ptr->bridge_manager()->number_of_bridges() < 2 ) 00630 { 00631 end_unmerge(top); 00632 return edge_ptr; 00633 } 00634 00635 //If parent is merged, cannot proceed. 00636 if( face_ptr->bridge_manager()->number_of_bridges() != 1 ) 00637 { 00638 end_unmerge(top); 00639 return 0; 00640 } 00641 00642 //Parent is not merged. This is the only Surface 00643 Surface* surf_ptr = CAST_TO( face_ptr->get_geometry_entity_ptr(), Surface ); 00644 assert(surf_ptr != 0); 00645 00646 //Find curves in edge_ptr associated with surf_ptr. 00647 //We need to check links in both directions becuase with virtual 00648 //geometry, links may only exist in one direction. 00649 // 00650 //Check downward links. 00651 DLIList<Curve*> curve_list, surf_curves; 00652 surf_ptr->curves(surf_curves); 00653 for( i = surf_curves.size(); i > 0; i-- ) 00654 { 00655 Curve* curve_ptr = surf_curves.get_and_step(); 00656 if( curve_ptr->topology_entity() == edge_ptr ) 00657 curve_list.append(curve_ptr); 00658 // else if( curve_ptr->topology_entity()->is_parasite(edge_ptr) ) 00659 // curve_list.append(curve_ptr); 00660 } 00661 //Check upward links. 00662 DLIList<TopologyBridge*> bridge_list; 00663 DLIList<Surface*> curve_surfs; 00664 edge_ptr->bridge_manager()->get_bridge_list(bridge_list); 00665 for( i = bridge_list.size(); i > 0; i-- ) 00666 { 00667 TopologyBridge* bridge_ptr = bridge_list.get_and_step(); 00668 curve_surfs.clean_out(); 00669 bridge_ptr->surfaces(curve_surfs); 00670 for( int j = curve_surfs.size(); j > 0; j-- ) 00671 { 00672 TopologyEntity* te_ptr = curve_surfs.get_and_step()->topology_entity(); 00673 //if( te_ptr == face_ptr ) 00674 if (te_ptr == face_ptr) /*|| face_ptr->is_host(te_ptr)*/ 00675 { 00676 curve_list.append_unique(CAST_TO(bridge_ptr,Curve)); 00677 break; 00678 } 00679 } 00680 } 00681 00682 //If there is no association between the passed edge_ptr and 00683 //face_ptr in the SM topology 00684 if( ! curve_list.size() ) 00685 { 00686 end_unmerge(top); 00687 return 0; 00688 } 00689 00690 // Unmerge any child GroupingEntities and SenseEntities, 00691 // and reconstruct a new owner. 00692 RefEdge* new_entity 00693 = split_out_Curves( curve_list, reversed ); 00694 if( !new_entity ) 00695 { 00696 end_unmerge(top); 00697 return 0; 00698 } 00699 00700 //We have changed the topology of the passed RefFace. 00701 //Note this for later. 00702 unmerge_modified.append( edge_ptr ); 00703 00704 // Find any links from parent to old entity, and move them 00705 // to the new, unmerged entity. 00706 DLIList<CoEdge*> coedge_list; 00707 DLIList<Curve*> coe_curves, tmp_list; 00708 DLIList<TopologyBridge*> tb_list; 00709 edge_ptr->get_co_edges (coedge_list); 00710 for( i = coedge_list.size(); i > 0; i-- ) 00711 { 00712 tb_list.clean_out(); 00713 coe_curves.clean_out(); 00714 CoEdge* coe_ptr = coedge_list.get_and_step(); 00715 coe_ptr->bridge_manager()->get_bridge_list(tb_list); 00716 for( int j = tb_list.size(); j> 0; j-- ) 00717 { 00718 tmp_list.clean_out(); 00719 tb_list.get_and_step()->curves(tmp_list); 00720 coe_curves.merge_unique(tmp_list); 00721 } 00722 coe_curves.intersect(curve_list); 00723 00724 if( coe_curves.size() ) 00725 { 00726 coe_ptr->switch_basic_topology_entity(new_entity); 00727 if( reversed ) 00728 coe_ptr->reverse_sense(); 00729 } 00730 } 00731 00732 //Notify merge assistants of unmerge 00733 DLIList<MergeToolAssistant*>& assistant_list_ = MergeTool::instance()->assistant_list_; 00734 for( int a = assistant_list_.size(); a > 0; a-- ) 00735 assistant_list_.get_and_step()-> 00736 unmerged( edge_ptr, new_entity, reversed ); 00737 00738 00739 end_unmerge(top); 00740 return new_entity; 00741 } 00742 00743 RefVertex* OldUnmergeCode::unmerge( RefVertex* vtx_ptr, RefEdge* edge_ptr ) 00744 { 00745 assert( vtx_ptr && edge_ptr ); 00746 CubitBoolean top = start_unmerge(); 00747 int i; 00748 00749 // if( !vtx_ptr->can_modify() ) 00750 // { 00751 // end_unmerge(top); 00752 // return 0; 00753 // } 00754 00755 //If passed entity is not merged, just return it. 00756 if( vtx_ptr->bridge_manager()->number_of_bridges() < 2 ) 00757 { 00758 end_unmerge(top); 00759 return vtx_ptr; 00760 } 00761 00762 //If parent is merged, cannot proceed. 00763 if( edge_ptr->bridge_manager()->number_of_bridges() != 1 ) 00764 { 00765 end_unmerge(top); 00766 return 0; 00767 } 00768 00769 //Parent is not merged, This is the only Curve. 00770 Curve* curve_ptr = CAST_TO( edge_ptr->get_geometry_entity_ptr(), Curve ); 00771 assert(curve_ptr != 0); 00772 00773 //Find points in vtx_ptr associated with curve_ptr. 00774 DLIList<TBPoint*> curve_points, point_list; 00775 curve_ptr->points(curve_points); 00776 for( i = curve_points.size(); i > 0; i-- ) 00777 { 00778 TBPoint* point_ptr = curve_points.get_and_step(); 00779 if( point_ptr->topology_entity() == vtx_ptr ) 00780 point_list.append(point_ptr); 00781 } 00782 00783 //If parent and child are not related in the SolidModelingEngine, 00784 //return failure. 00785 if( ! point_list.size() ) 00786 { 00787 end_unmerge(top); 00788 return 0; 00789 } 00790 00791 // Find any links from parent to old entity, and move them 00792 // to the new, unmerged entity. 00793 DLIList<RefEdge*> edge_list; 00794 DLIList<TBPoint*> curve_pts; 00795 DLIList<CoVertex*> cvtx_to_change; 00796 00797 vtx_ptr->ref_edges( edge_list ); 00798 for( i = edge_list.size(); i > 0; i-- ) 00799 { 00800 edge_ptr = edge_list.get_and_step(); 00801 if( edge_ptr->bridge_manager()->number_of_bridges() > 1 ) 00802 continue; 00803 00804 curve_ptr = edge_ptr->get_curve_ptr(); 00805 assert( curve_ptr != 0 ); 00806 curve_pts.clean_out(); 00807 curve_ptr->points(curve_pts); 00808 curve_pts.intersect(point_list); 00809 if( ! curve_pts.size() ) 00810 continue; 00811 00812 CoVertex* start_cvtx = edge_ptr->get_chain_ptr()->start_co_vertex(); 00813 CoVertex* end_cvtx = edge_ptr->get_chain_ptr()-> end_co_vertex(); 00814 if (start_cvtx && start_cvtx->get_ref_vertex_ptr() == vtx_ptr) 00815 cvtx_to_change.append( start_cvtx ); 00816 if (end_cvtx && end_cvtx->get_ref_vertex_ptr() == vtx_ptr) 00817 cvtx_to_change.append( end_cvtx ); 00818 00819 } 00820 00821 // Make new RefVertex with points. 00822 RefVertex* new_entity = split_out_Points( point_list ); 00823 if( !new_entity ) 00824 { 00825 end_unmerge(top); 00826 return 0; 00827 } 00828 00829 for( i = cvtx_to_change.size(); i--; ) 00830 { 00831 cvtx_to_change.get_and_step()->switch_basic_topology_entity(new_entity); 00832 } 00833 00834 //We have changed the topology of the passed RefEdge. 00835 //Note this for later. 00836 unmerge_modified.append( vtx_ptr ); 00837 00838 //Notify merge assistants of unmerge 00839 DLIList<MergeToolAssistant*>& assistant_list_ = MergeTool::instance()->assistant_list_; 00840 for( int a = assistant_list_.size(); a > 0; a-- ) 00841 assistant_list_.get_and_step()-> 00842 unmerged( vtx_ptr, new_entity, CUBIT_FALSE ); 00843 00844 00845 end_unmerge(top); 00846 return new_entity; 00847 } 00848 00849 00850 void OldUnmergeCode::remove_CAEntityId_attrib( TopologyBridge* tb_ptr ) 00851 { 00852 DLIList<CubitSimpleAttrib> attrib_list; 00853 tb_ptr->get_simple_attribute( attrib_list ); 00854 for( int i = attrib_list.size(); i > 0; i-- ) 00855 { 00856 const CubitSimpleAttrib& attrib = attrib_list.get_and_step(); 00857 if( attrib.character_type() == "ENTITY_ID" ) 00858 { 00859 tb_ptr->remove_simple_attribute_virt( attrib ); 00860 } 00861 } 00862 } 00863 00864 00865 //------------------------------------------------------------------------- 00866 // Purpose : Remove a surface from its owning RefFace, and make a new 00867 // RefFace with the Surface. 00868 // 00869 // Special Notes : 00870 // 00871 // Creator : Jason Kraftcheck 00872 // 00873 // Creation Date : 01/18/01 00874 //------------------------------------------------------------------------- 00875 RefFace* OldUnmergeCode::split_out_Surface( Surface* surface, CubitBoolean& reversed ) 00876 { 00877 // Remove the child from the old owner. 00878 reversed = false; 00879 TopologyEntity* te_ptr = surface->topology_entity(); 00880 RefFace* old_entity = CAST_TO( te_ptr, RefFace ); 00881 if( te_ptr ) 00882 { 00883 assert( old_entity != 0 ); 00884 00885 te_ptr->bridge_manager()->remove_bridge( surface ); 00886 remove_CAEntityId_attrib( surface ); 00887 old_unmerged.append( old_entity ); 00888 00889 if (te_ptr->bridge_manager()->topology_bridge()->bridge_sense() == CUBIT_REVERSED) 00890 { 00891 te_ptr->reverse_topology(); 00892 te_ptr->bridge_manager()->reverse_bridge_senses(); 00893 reversed = !reversed; 00894 } 00895 if (surface->bridge_sense() == CUBIT_REVERSED) 00896 { 00897 surface->reverse_bridge_sense(); 00898 reversed = !reversed; 00899 } 00900 } 00901 00902 surface->set_saved_id(0); 00903 00904 // make new refface 00905 RefFace* new_entity = RefEntityFactory::instance()->construct_RefFace( surface ); 00906 00907 // Unmerge Loops 00908 DLIList<LoopSM*> loopsms; 00909 surface->loopsms( loopsms ); 00910 for( int i = loopsms.size(); i > 0; i-- ) 00911 { 00912 Loop* new_loop = split_out_Loop(loopsms.get_and_step(), new_entity, reversed); 00913 new_entity->add_grouping_entity( new_loop ); 00914 } 00915 00916 new_unmerged.append(new_entity); 00917 event_list.append( new UnMergeEvent( old_entity, new_entity ) ); 00918 00919 return new_entity; 00920 } 00921 00922 //------------------------------------------------------------------------- 00923 // Purpose : Unmerge Loop and CoEdges 00924 // 00925 // Special Notes : 00926 // 00927 // Creator : Jason Kraftcheck 00928 // 00929 // Creation Date : 01/23/01 00930 //------------------------------------------------------------------------- 00931 Loop* OldUnmergeCode::split_out_Loop( LoopSM* loopsm, RefFace* /*new_entity*/, CubitBoolean reverse ) 00932 { 00933 // Remove from existing TopologyEntity 00934 TopologyEntity* topo = loopsm->topology_entity(); 00935 loopsm->bridge_manager()->remove_bridge( loopsm ); 00936 00937 int i; 00938 Loop* old_loop = CAST_TO( topo, Loop ); 00939 assert( old_loop != 0 ); 00940 //RefFace* old_face = old_loop->get_ref_face_ptr(); 00941 Loop* new_loop = new Loop( loopsm ); 00942 DLIList<TopologyBridge*> tb_list; 00943 DLIList<CoEdge*> coedges; 00944 old_loop->ordered_co_edges( coedges ); 00945 if( !reverse ) coedges.reverse(); 00946 00947 CoEdge* prev = 0; 00948 while( coedges.size() > 0 ) 00949 { 00950 coedges.last(); 00951 CoEdge* coedge_ptr = coedges.remove(); 00952 00953 // Find the corresponding CoEdgeSM to unmerge. 00954 tb_list.clean_out(); 00955 coedge_ptr->bridge_manager()->get_bridge_list(tb_list); 00956 CoEdgeSM* coedgesm = NULL; //Match to LoopSM 00957 for( i = tb_list.size(); i > 0; i-- ) 00958 { 00959 TopologyBridge* tb_ptr = tb_list.get_and_step(); 00960 if( tb_ptr->loopsm() == loopsm ) 00961 { 00962 coedgesm = CAST_TO(tb_ptr,CoEdgeSM); 00963 break; 00964 } 00965 } 00966 00967 assert(coedgesm != 0); 00968 00969 // Unmerge CoEdge 00970 coedge_ptr->bridge_manager()->remove_bridge( coedgesm ); 00971 RefEdge* edge_ptr = coedge_ptr->get_ref_edge_ptr(); 00972 CubitSense sense = coedge_ptr->get_sense(); 00973 if( reverse ) 00974 sense = CubitUtil::opposite_sense( sense ); 00975 CoEdge* new_coedge = new CoEdge( edge_ptr, sense ); 00976 new_coedge->set_co_edge_sm_ptr( coedgesm ); 00977 new_loop->add_sense_entity( new_coedge, prev ); 00978 prev = new_coedge; 00979 } 00980 00981 return new_loop; 00982 } 00983 00984 00985 00986 //------------------------------------------------------------------------- 00987 // Purpose : VG provides downward query of TopologyBridges, but 00988 // not always upward queries. So to do upward queries, 00989 // do downward queries and search for source object. 00990 // 00991 // Special Notes : 00992 // 00993 // Creator : Jason Kraftcheck 00994 // 00995 // Creation Date : 03/26/01 00996 //------------------------------------------------------------------------- 00997 void OldUnmergeCode::find_curves( TBPoint* point_ptr, DLIList<Curve*>& result_set ) 00998 { 00999 //Do normal TB query for real geometry 01000 point_ptr->curves(result_set); 01001 01002 //Now account for missing TB links due to virtual geometry 01003 RefVertex* vtx_ptr = CAST_TO(point_ptr->topology_entity(),RefVertex); 01004 if( vtx_ptr ) 01005 { 01006 DLIList<RefEdge*> vtx_edges; 01007 DLIList<TBPoint*> curve_pts; 01008 DLIList<TopologyBridge*> edge_bridges; 01009 vtx_ptr->ref_edges(vtx_edges); 01010 for( int i = vtx_edges.size(); i > 0; i-- ) 01011 { 01012 RefEdge* edge_ptr = vtx_edges.get_and_step(); 01013 edge_bridges.clean_out(); 01014 edge_ptr->bridge_manager()->get_bridge_list( edge_bridges ); 01015 for( int j = edge_bridges.size(); j > 0; j-- ) 01016 { 01017 TopologyBridge* bridge_ptr = edge_bridges.get_and_step(); 01018 curve_pts.clean_out(); 01019 bridge_ptr->points(curve_pts); 01020 if( curve_pts.is_in_list( point_ptr ) ) 01021 { 01022 Curve* curve_ptr = CAST_TO(bridge_ptr,Curve); 01023 assert(curve_ptr != 0); 01024 result_set.append_unique(curve_ptr); 01025 } 01026 } 01027 } 01028 } 01029 } 01030 01031 //------------------------------------------------------------------------- 01032 // Purpose : VG provides downward query of TopologyBridges, but 01033 // not always upward queries. So to do upward queries, 01034 // do downward queries and search for source object. 01035 // 01036 // Special Notes : 01037 // 01038 // Creator : Jason Kraftcheck 01039 // 01040 // Creation Date : 03/26/01 01041 //------------------------------------------------------------------------- 01042 void OldUnmergeCode::find_surfaces( Curve* curve_ptr, DLIList<Surface*>& result_set ) 01043 { 01044 //Do normal TB query for real geometry 01045 curve_ptr->surfaces(result_set); 01046 } 01047 01048 01049 //------------------------------------------------------------------------- 01050 // Purpose : Unmerge a Curve from its owning RefEdge, and make a new 01051 // RefEdge 01052 // 01053 // Special Notes : 01054 // 01055 // Creator : Jason Kraftcheck 01056 // 01057 // Creation Date : 01/18/01 01058 //------------------------------------------------------------------------- 01059 RefEdge* OldUnmergeCode::split_out_Curves( DLIList<Curve*>& curve_list, CubitBoolean& reversed ) 01060 { 01061 int i; 01062 01063 // If any parent Surfaces are still merged, we 01064 // cannot continue. 01065 DLIList<Surface*> surface_list; 01066 for( i = curve_list.size(); i > 0; i-- ) 01067 { 01068 surface_list.clean_out(); 01069 find_surfaces( curve_list.get_and_step(), surface_list ); 01070 for( int j = surface_list.size(); j > 0; j-- ) 01071 if( surface_list.get_and_step()->bridge_manager() 01072 ->number_of_bridges() != curve_list.size() ) 01073 return NULL; 01074 } 01075 01076 // Remove the curves from the old owner. 01077 curve_list.reset(); 01078 Curve* curve = curve_list.get(); 01079 TopologyEntity* te_ptr = curve->topology_entity(); 01080 for( i = curve_list.size(); i > 0; i-- ) 01081 if( curve_list.get_and_step()->topology_entity() != te_ptr ) 01082 return 0; 01083 01084 assert( te_ptr->bridge_manager()->number_of_bridges() > curve_list.size() ); 01085 01086 reversed = false; 01087 RefEdge* old_entity = CAST_TO( te_ptr, RefEdge ); 01088 if( te_ptr ) 01089 { 01090 assert( old_entity != 0 ); 01091 01092 curve_list.reset(); 01093 for( i = curve_list.size(); i > 0; i-- ) 01094 { 01095 Curve* ptr = curve_list.get_and_step(); 01096 te_ptr->bridge_manager()->remove_bridge( ptr ); 01097 remove_CAEntityId_attrib( ptr ); 01098 } 01099 old_unmerged.append( old_entity ); 01100 01101 curve_list.reset(); 01102 if (te_ptr->bridge_manager()->topology_bridge()->bridge_sense() == CUBIT_REVERSED) 01103 { 01104 te_ptr->reverse_topology(); 01105 te_ptr->bridge_manager()->reverse_bridge_senses(); 01106 reversed = !reversed; 01107 } 01108 01109 if (curve->bridge_sense() == CUBIT_REVERSED) 01110 { 01111 for (i = curve_list.size(); i--; ) 01112 curve_list.get_and_step()->reverse_bridge_sense(); 01113 reversed = !reversed; 01114 } 01115 } 01116 01117 curve_list.reset(); 01118 for ( i = curve_list.size(); i--; ) 01119 curve_list.get_and_step()->set_saved_id(0); 01120 01121 RefEdge* new_entity = RefEntityFactory::instance()->construct_RefEdge( curve ); 01122 Chain* chain = new Chain; 01123 new_entity->add_grouping_entity(chain); 01124 01125 DLIList<TopologyBridge*> points(2); 01126 curve->get_children(points); 01127 points.reset(); 01128 for (i = 0; i < 2; i++) 01129 { 01130 CoVertex* cvtx = new CoVertex; 01131 TopologyEntity* owner = points.get_and_step()->topology_entity(); 01132 cvtx->attach_basic_topology_entity( dynamic_cast<RefVertex*>(owner) ); 01133 chain->add_sense_entity(cvtx); 01134 } 01135 01136 for( i = curve_list.size(); i > 0; i-- ) 01137 { 01138 Curve* a_curve = curve_list.get_and_step(); 01139 if( curve != a_curve ) 01140 new_entity->bridge_manager()->add_bridge(a_curve); 01141 } 01142 01143 PRINT_DEBUG_19(" Unmerged %s from %s.\n", 01144 new_entity->entity_name().c_str(), 01145 old_entity->entity_name().c_str() ); 01146 01147 01148 01149 new_unmerged.append( new_entity ); 01150 event_list.append( new UnMergeEvent( old_entity, new_entity ) ); 01151 01152 return new_entity; 01153 } 01154 01155 //------------------------------------------------------------------------- 01156 // Purpose : Unmerge a TBPoint from its Vertex and make new Vertex 01157 // 01158 // Special Notes : 01159 // 01160 // Creator : Jason Kraftcheck 01161 // 01162 // Creation Date : 01/18/01 01163 //------------------------------------------------------------------------- 01164 RefVertex* OldUnmergeCode::split_out_Points( DLIList<TBPoint*>& point_list ) 01165 { 01166 int i; 01167 01168 // If any parent Curves are still merged, we 01169 // cannot continue. 01170 DLIList<Curve*> curve_list; 01171 for( i = point_list.size(); i > 0; i-- ) 01172 { 01173 curve_list.clean_out(); 01174 find_curves(point_list.get_and_step(),curve_list); 01175 for( int j = curve_list.size(); j > 0; j-- ) 01176 if( curve_list.get_and_step()->bridge_manager() 01177 ->number_of_bridges() != point_list.size() ) 01178 return NULL; 01179 } 01180 01181 // Remove the child from the old owner. 01182 TopologyEntity* te_ptr = point_list.get()->topology_entity(); 01183 01184 // All points must have same bridge manager. 01185 for( i = point_list.size(); i > 0; i-- ) 01186 if( point_list.get_and_step()->topology_entity() != te_ptr ) 01187 return NULL; 01188 01189 RefVertex* old_entity = CAST_TO( te_ptr, RefVertex ); 01190 if( te_ptr ) 01191 { 01192 assert(old_entity != 0); 01193 for( i = point_list.size(); i > 0; i-- ) 01194 { 01195 TBPoint* ptr = point_list.get_and_step(); 01196 te_ptr->bridge_manager()->remove_bridge( ptr ); 01197 remove_CAEntityId_attrib( ptr ); 01198 } 01199 old_unmerged.append( old_entity ); 01200 } 01201 01202 point_list.reset(); 01203 for (i = point_list.size(); i--; ) 01204 point_list.get_and_step()->set_saved_id(0); 01205 01206 RefVertex* new_entity = RefEntityFactory::instance() 01207 ->construct_RefVertex(point_list.get_and_step()); 01208 for( i = point_list.size(); i > 1; i-- ) 01209 new_entity->bridge_manager()->add_bridge(point_list.get_and_step()); 01210 01211 PRINT_DEBUG_19(" Unmerged %s from %s.\n", 01212 new_entity->entity_name().c_str(), 01213 old_entity->entity_name().c_str() ); 01214 01215 new_unmerged.append( new_entity ); 01216 event_list.append( new UnMergeEvent( old_entity, new_entity ) ); 01217 01218 return new_entity; 01219 } 01220 01221 //------------------------------------------------------------------------- 01222 // Purpose : Handle sending various events as a result of unmerging. 01223 // 01224 // Special Notes : 01225 // 01226 // Creator : Jason Kraftcheck 01227 // 01228 // Creation Date : 01/18/01 01229 //------------------------------------------------------------------------- 01230 void OldUnmergeCode::cleanup_unmerge() 01231 { 01232 DLIList<RefEntity*> temp_list, marked_list; 01233 int i, j; 01234 CpuTimer timer; 01235 01236 //Remove entities from unmerge_modified that 01237 // a) are duplicate entries in the list 01238 // b) also exist in new_unmerged 01239 // c) have parent entities already in unmerge_modified. 01240 01241 //Change unmerge_modified to be a list of the immediate 01242 //parents of the entities currently in the list 01243 marked_list = unmerge_modified; 01244 unmerge_modified.clean_out(); 01245 for( i = marked_list.size(); i--; ) 01246 { 01247 temp_list.clean_out(); 01248 marked_list.get_and_step()->get_parent_ref_entities( temp_list ); 01249 unmerge_modified += temp_list; 01250 } 01251 for( i = new_unmerged.size(); i > 0; i-- ) 01252 { 01253 temp_list.clean_out(); 01254 new_unmerged.get_and_step()->get_parent_ref_entities( temp_list ); 01255 unmerge_modified += temp_list; 01256 } 01257 01258 //Reset marks on all entities in list 01259 for( i = unmerge_modified.size(); i > 0; i-- ) 01260 unmerge_modified.get_and_step()->marked(0); 01261 01262 //Set instance count (mark) to one for all in new_unmerged 01263 for( i = new_unmerged.size(); i > 0; i-- ) 01264 new_unmerged.get_and_step()->marked(1); 01265 01266 01267 01268 //Increment instance count (mark) for each occurance 01269 //in unmerge_modified. 01270 for( i = unmerge_modified.size(); i > 0; i-- ) 01271 { 01272 unmerge_modified.get()->marked( unmerge_modified.get()->marked()+1 ); 01273 temp_list.clean_out(); 01274 unmerge_modified.get()->get_all_child_ref_entities(temp_list); 01275 marked_list += temp_list; 01276 unmerge_modified.step(); 01277 } 01278 01279 for( i = marked_list.size(); i > 0; i-- ) 01280 { 01281 marked_list.get()->marked( marked_list.get()->marked() + 1 ); 01282 marked_list.step(); 01283 } 01284 01285 //If the entity's mark is non-zero after decrementing 01286 //the mark, remove it because it occurs again later in 01287 //the list. 01288 unmerge_modified.reset(); 01289 for( i = unmerge_modified.size(); i > 0; i-- ) 01290 { 01291 unmerge_modified.get()->marked( unmerge_modified.get()->marked() - 1 ); 01292 if( unmerge_modified.get()->marked() ) 01293 unmerge_modified.extract(); 01294 else 01295 unmerge_modified.step(); 01296 } 01297 01298 //Clear out other marks we set. 01299 for( i = new_unmerged.size(); i > 0; i-- ) 01300 new_unmerged.get_and_step()->marked(0); 01301 for( i = marked_list.size(); i > 0; i-- ) 01302 marked_list.get_and_step()->marked(0); 01303 01304 01305 //Now remove duplicates from old_unmerged. 01306 for( i = old_unmerged.size(); i > 0; i-- ) 01307 old_unmerged.get_and_step()->marked(1); 01308 old_unmerged.reset(); 01309 for( i = old_unmerged.size(); i > 0; i-- ) 01310 { 01311 if( old_unmerged.get()->marked() ) 01312 old_unmerged.get_and_step()->marked(0); 01313 else 01314 old_unmerged.extract(); 01315 } 01316 01317 01318 // Finally, done rearranging lists. Now actually do 01319 // the important stuff. 01320 01321 // Count occurances of each type of entity, and 01322 // output counts. 01323 int face_count = 0, edge_count = 0, vtx_count = 0; 01324 new_unmerged.reset(); 01325 for( i = new_unmerged.size(); i > 0; i-- ) 01326 { 01327 if( CAST_TO( new_unmerged.get(), RefFace ) ) 01328 face_count++; 01329 else if( CAST_TO( new_unmerged.get(), RefEdge ) ) 01330 edge_count++; 01331 else if( CAST_TO( new_unmerged.get(), RefVertex ) ) 01332 vtx_count++; 01333 else 01334 assert( 0 /*Bad EntityType*/ ); 01335 01336 new_unmerged.step(); 01337 } 01338 01339 if( AppUtil::instance()->interrupt() ) PRINT_WARNING("Unmerge aborted.\n"); 01340 if( face_count ) PRINT_INFO("%4d surfaces unmerged.\n",face_count); 01341 if( edge_count ) PRINT_INFO("%4d curves unmerged.\n",edge_count); 01342 if( vtx_count ) PRINT_INFO("%4d vertices unmerged.\n",vtx_count); 01343 PRINT_DEBUG_19("Unmerge completed in %0.2f seconds.\n", 01344 timer.cpu_secs() ); 01345 01346 //Let the user know if we actually unmerged anything. 01347 if( !new_unmerged.size() ) 01348 PRINT_INFO("No entities unmerged.\n"); 01349 01350 int event_count = new_unmerged.size() + event_list.size() + unmerge_modified.size(); 01351 ProgressTool* progress = 0; 01352 if (event_count > 20) 01353 progress = AppUtil::instance()->progress_tool(); 01354 if (progress) 01355 progress->start( 0, event_count, "Updating Graphics" ); 01356 01357 //Info for DEBUG output 01358 const char* entity_names[] = { "Vertices", "Curves", "Surfaces" }; 01359 timer.cpu_secs(); 01360 01361 //Add all new entities to the graphics. Do lowest-dimension 01362 //entities first, so that they exist in the graphics when the 01363 //higher-dimension entities owning them are added. 01364 for( j = 0; j < 3; j++ ) 01365 { 01366 int count = 0; //for PRINT_DEBUG statement below. 01367 01368 for( i = new_unmerged.size(); i > 0; i-- ) 01369 { 01370 RefEntity* entity = new_unmerged.get_and_step(); 01371 if( entity->dimension() != j ) 01372 continue; 01373 01374 count++; 01375 01376 //Is this a free RefEntity? 01377 temp_list.clean_out(); 01378 entity->get_parent_ref_entities( temp_list ); 01379 01380 if( temp_list.size() == 0 ) 01381 AppUtil::instance()->send_event(GeometryEvent(GeometryEvent::FREE_REF_ENTITY_GENERATED, entity)); 01382 01383 if (progress) 01384 progress->step(); 01385 PRINT_DEBUG_19("\t\tAdded %s to graphics\n", entity->entity_name().c_str() ); 01386 01387 //entity->notify_all_observers( NEW_ENTITY_UNMERGED ); 01388 } 01389 PRINT_DEBUG_19("\tAdded %d new %s to graphics in %0.2f seconds.\n", 01390 count, entity_names[j], timer.cpu_secs() ); 01391 } 01392 01393 while( event_list.size() ) 01394 { 01395 UnMergeEvent* event = event_list.pop(); 01396 //event->new_entity->notify_observers(event) 01397 AppUtil::instance()->send_event( *event ); 01398 delete event; 01399 if (progress) 01400 progress->step(); 01401 } 01402 01403 //Update for other non-new entities that got modified 01404 //as a part of unmerging. 01405 for( i = unmerge_modified.size(); i > 0; i-- ) 01406 { 01407 PRINT_DEBUG_19("\t\tUpdated graphics for %s.\n", unmerge_modified.get()->entity_name().c_str() ); 01408 AppUtil::instance()->send_event(GeometryEvent(GeometryEvent::TOPOLOGY_MODIFIED, unmerge_modified.get_and_step())); 01409 if (progress) 01410 progress->step(); 01411 } 01412 if (progress) 01413 progress->end(); 01414 01415 PRINT_DEBUG_19("Sent TOPOLOGY_MODIFIED event for %d entities in %0.2f " 01416 "seconds\n",unmerge_modified.size(), timer.cpu_secs()); 01417 PRINT_DEBUG_19("Total time to update after unmerge: %0.2f seconds.\n", 01418 timer.elapsed() ); 01419 01420 DLIList<MergeToolAssistant*>& assistant_list_ = MergeTool::instance()->assistant_list_; 01421 for( int a = assistant_list_.size(); a--; ) 01422 assistant_list_.get_and_step()->finish_unmerge(); 01423 } 01424 01425 01426
