cgma
00001 //------------------------------------------------------------------------- 00002 // Filename : SplitSurfaceVirtual.cpp 00003 // 00004 // Purpose : Split a surface and create virtual surfaces 00005 // 00006 // Special Notes : 00007 // 00008 // Creator : KGM 00009 // 00010 // Creation Date : 30-Jun-2005 00011 //------------------------------------------------------------------------- 00012 00013 #include "SplitSurfaceVirtual.hpp" 00014 #include "SplitSurfaceTool.hpp" 00015 #include "RefVertex.hpp" 00016 #include "RefEdge.hpp" 00017 #include "RefFace.hpp" 00018 #include "Curve.hpp" 00019 #include "Surface.hpp" 00020 #include "GeometryQueryTool.hpp" 00021 #include "PartitionTool.hpp" 00022 #include "CubitMessage.hpp" 00023 #include "CubitUtil.hpp" 00024 #include "DLIList.hpp" 00025 #include "GfxDebug.hpp" 00026 #include "GMem.hpp" 00027 00028 CubitStatus 00029 SplitSurfaceVirtual::split_surface_virtual( RefFace *ref_face_ptr, 00030 DLIList<CubitVector*> &locations, 00031 DLIList<DLIList<CubitVector*>*> &vec_lists ) 00032 { 00033 // find the splitting curves. 00034 SplitSurfaceTool sst; 00035 DLIList<Curve*> curve_list; 00036 CubitStatus err = sst.calculate_split_curves( ref_face_ptr, locations, 00037 vec_lists, curve_list ); 00038 00039 GMem gmem; 00040 int num_points; 00041 DLIList<CubitVector*> segments; 00042 00043 // loop over all the curves 00044 int i; 00045 for (i = 0; i < curve_list.size(); i++) 00046 { 00047 Curve* curve_ptr = curve_list.get_and_step(); 00048 00049 // get the curve facets 00050 err = curve_ptr->get_geometry_query_engine()-> 00051 get_graphics( curve_ptr, num_points, &gmem ); 00052 00053 // load the graphics points into a CubitVector for insert_curve 00054 --num_points; 00055 int j; 00056 for (j = 0; j < num_points; j++) 00057 { 00058 const GPoint& p = gmem.point_list()[j]; 00059 segments.append( new CubitVector( p.x, p.y, p.z ) ); 00060 } 00061 } 00062 00063 // add last point to the end of the list 00064 const GPoint& p = gmem.point_list()[num_points]; 00065 segments.append( new CubitVector(p.x, p.y, p.z ) ); 00066 00067 // now partition the surface 00068 DLIList<RefEdge*> new_edges; 00069 RefFace* new_surf = PartitionTool::instance()->insert_edge( ref_face_ptr, segments, 00070 false, new_edges ); 00071 //DLIList<Curve*> new_curves; 00072 //Surface* new_surf = PartitionEngine::instance().insert_curve( old_surf, segments, new_curves ); 00073 00074 // called routines allocate memory. Clean up for them. 00075 while( curve_list.size() ) 00076 delete curve_list.pop(); 00077 00078 //while( new_curves.size() ) 00079 // delete new_curves.pop(); 00080 00081 return CUBIT_SUCCESS; 00082 } 00083 00084 00085 //=============================================================================== 00086 // Function : split_surfaces 00087 // Member Type: PUBLIC 00088 // Description: Split a chain of surfaces into one or more pieces 00089 // Author : Steve Storm (CAT) 00090 // Date : 01/04 00091 //=============================================================================== 00092 CubitStatus 00093 SplitSurfaceVirtual::split_surfaces_virtual( DLIList<RefFace*> &ref_face_list, 00094 int num_segs, 00095 double fraction, 00096 double distance, 00097 RefEdge *from_curve_ptr, 00098 DLIList<RefVertex*> &corner_vertex_list, 00099 DLIList<RefVertex*> &through_vertex_list, 00100 RefEdge *curve_dir_ptr, 00101 CubitBoolean preview_flg, 00102 CubitBoolean create_ref_edges_flg ) 00103 { 00104 // Get parent bodies - all surfs must be from same body 00105 int i; 00106 DLIList<Body*> old_body_list; 00107 RefFace *ref_face_ptr; 00108 ref_face_list.reset(); 00109 for( i=ref_face_list.size(); i--; ) 00110 { 00111 ref_face_ptr = ref_face_list.get_and_step(); 00112 00113 DLIList<Body*> body_list; 00114 ref_face_ptr->bodies( body_list ); 00115 old_body_list.merge_unique( body_list ); 00116 } 00117 00118 if( old_body_list.size() > 1 ) 00119 { 00120 PRINT_ERROR( "This operation requires all surfaces to be from the same volume\n" ); 00121 // Note: this restriction could be pretty easily lifted by sorting the 00122 // input lists and calling the SplitSurfaceTool separately for each set of 00123 // surfaces on each body. 00124 return CUBIT_FAILURE; 00125 } 00126 00127 //bad geom with no body -- dont try to imprint this... 00128 //quick and dirty fix by (aga@cat|1/7/04) 00129 if( old_body_list.size() < 1 ) 00130 { 00131 PRINT_ERROR( "A surface is not contained within a parent body.\n" 00132 " It cannot be split.\n"); 00133 return CUBIT_FAILURE; 00134 } 00135 /* KGM -- need this? 00136 // Check for virtual geometry 00137 if ( contains_intermediate_geometry(ref_face_list) ) 00138 { 00139 PRINT_ERROR("SPLITTING surfaces containing virtual geometry is not\n" 00140 " allowed. Delete virtual geometry on these surfaces\n" 00141 " before operation.\n" ); 00142 return CUBIT_FAILURE; 00143 } 00144 */ 00145 00146 // Make sure all surfaces are from same geometry engine 00147 DLIList<RefEntity*> ref_ent_list; 00148 CAST_LIST_TO_PARENT(ref_face_list, ref_ent_list); 00149 /* KGM -- need this? 00150 if ( !same_modify_engine(ref_ent_list, CUBIT_TRUE) ) 00151 { 00152 PRINT_ERROR("Performing SPLIT with surfaces containing geometry from\n" 00153 "different modeling engines is not allowed.\n" 00154 "Delete uncommon geometry on these surfaces before operation.\n\n"); 00155 return CUBIT_FAILURE; 00156 } 00157 */ 00158 00159 // get the splitting curves 00160 DLIList<DLIList<Curve*>*> curve_lists_list; 00161 SplitSurfaceTool sst; 00162 CubitStatus err = sst.calculate_split_curves( ref_face_list, num_segs, fraction, distance, 00163 from_curve_ptr,corner_vertex_list, 00164 through_vertex_list, curve_dir_ptr, 00165 preview_flg, create_ref_edges_flg, 00166 false, curve_lists_list ); 00167 00168 00169 // loop over all the curves 00170 GMem gmem; 00171 int num_points; 00172 DLIList<CubitVector*> segments; 00173 int k; 00174 for (k=0; k < curve_lists_list.size(); k++) 00175 { 00176 DLIList<Curve*> *curve_list = curve_lists_list[k]; 00177 00178 int i; 00179 for (i = 0; i < curve_list->size(); i++) 00180 { 00181 Curve* curve_ptr = curve_list->get_and_step(); 00182 00183 // get the curve facets 00184 err = curve_ptr->get_geometry_query_engine()-> 00185 get_graphics( curve_ptr, num_points, &gmem ); 00186 00187 // load the graphics points into a CubitVector for insert_curve 00188 --num_points; 00189 int j; 00190 for (j = 0; j < num_points; j++) 00191 { 00192 const GPoint& p = gmem.point_list()[j]; 00193 segments.append( new CubitVector( p.x, p.y, p.z ) ); 00194 } 00195 } 00196 } 00197 00198 // add last point to the end of the list 00199 const GPoint& p = gmem.point_list()[num_points]; 00200 segments.append( new CubitVector(p.x, p.y, p.z ) ); 00201 00202 // Get the underlying surface (what if it is virtual does this still work?) 00203 //Surface *old_surf = ref_face_list[k]->get_surface_ptr(); KGM 00204 00205 // now partition the surface 00206 DLIList<RefEdge*> new_edges; 00207 DLIList<RefFace*> new_faces; 00208 err = PartitionTool::instance()->insert_edge( ref_face_list, 00209 segments, new_faces, new_edges); 00210 //DLIList<Curve*> new_curves; 00211 //Surface* new_surf = PartitionEngine::instance().insert_curve( old_surf, segments, new_curves ); 00212 00213 // insert_curve allocates memory. Clean up. 00214 //while( new_curves.size() ) 00215 // delete new_curves.pop(); 00216 00217 // called routines allocate memory. Clean up for them. 00218 for (k=0; k < curve_lists_list.size(); k++) 00219 { 00220 DLIList<Curve*> *curve_list = curve_lists_list[k]; 00221 while( curve_list->size() ) 00222 delete curve_list->pop(); 00223 } 00224 00225 return CUBIT_SUCCESS; 00226 }
