cgma
00001 00010 #undef NDEBUG 00011 #include <cassert> 00012 00013 #include "GeometryModifyEngine.hpp" 00014 #include "GeometryModifyTool.hpp" 00015 #include "GeometryQueryTool.hpp" 00016 #include "CubitMessage.hpp" 00017 #include "Body.hpp" 00018 #include "RefVolume.hpp" 00019 #include "RefFace.hpp" 00020 #include "RefEdge.hpp" 00021 #include "RefVertex.hpp" 00022 #include "InitCGMA.hpp" 00023 #include "OCCBody.hpp" 00024 #include "OCCSurface.hpp" 00025 #include "OCCCurve.hpp" 00026 #include "OCCDrawTool.hpp" 00027 #include "CubitCompat.hpp" 00028 00029 #ifndef SRCDIR 00030 # define SRCDIR . 00031 #endif 00032 00033 #define STRINGIFY_(X) #X 00034 #define STRINGIFY(X) STRINGIFY_(X) 00035 #define SRCPATH STRINGIFY(SRCDIR) "/" 00036 00037 // forward declare some functions used and defined later 00038 CubitStatus read_geometry(int, const char **, bool local = false); 00039 CubitStatus make_Point(); 00040 // macro for printing a separator line 00041 #define PRINT_SEPARATOR PRINT_INFO("=======================================\n"); 00042 00043 00044 // main program - initialize, then send to proper function 00045 int main (int argc, char **argv) 00046 { 00047 CubitStatus status = InitCGMA::initialize_cgma("OCC"); 00048 if (CUBIT_SUCCESS != status) return 1; 00049 00050 //Do make point. 00051 status = make_Point(); 00052 if (status == CUBIT_FAILURE) 00053 PRINT_INFO("Operation Failed"); 00054 00055 int ret_val = ( CubitMessage::instance()->error_count() ); 00056 if ( ret_val > 0 ) 00057 { 00058 PRINT_ERROR("Errors found during Mergechk session.\n"); 00059 } 00060 return ret_val; 00061 00062 } 00063 00068 CubitStatus read_geometry(int num_files, const char **argv, bool local) 00069 { 00070 CubitStatus status = CUBIT_SUCCESS; 00071 GeometryQueryTool *gti = GeometryQueryTool::instance(); 00072 assert(gti); 00073 int i; 00074 00075 PRINT_SEPARATOR; 00076 00077 for (i = 0; i < num_files; i++) { 00078 std::string filename( local ? "./" : SRCPATH ); 00079 filename += argv[i]; 00080 status = CubitCompat_import_solid_model(filename.c_str(), "OCC"); 00081 if (status != CUBIT_SUCCESS) { 00082 PRINT_ERROR("Problems reading geometry file %s.\n", filename.c_str()); 00083 } 00084 } 00085 PRINT_SEPARATOR; 00086 00087 return CUBIT_SUCCESS; 00088 } 00089 00090 CubitStatus make_Point() 00091 { 00092 GeometryQueryTool *gti = GeometryQueryTool::instance(); 00093 GeometryModifyTool *gmti = GeometryModifyTool::instance(); 00094 00095 //test for loft two surfaces: 00096 Body* body = gmti->brick(10, 10, 10); 00097 CubitVector vector1(23,13,11); 00098 DLIList<Body*> bods; 00099 bods.append(body); 00100 gti->translate(bods, vector1); 00101 Body* body2 = gmti->brick(10, 10, 10); 00102 00103 //use the surface1 and surface8 to make a loft 00104 DLIList<RefFace*> face_list; 00105 body->ref_faces(face_list); 00106 DLIList<RefFace*> loft_surfaces; 00107 face_list.last(); 00108 loft_surfaces.append(face_list.get()); 00109 face_list.clean_out(); 00110 body2->ref_faces(face_list); 00111 face_list.last(); 00112 face_list.back(); 00113 loft_surfaces.append(face_list.get()); 00114 00115 //Do loft 00116 Body* new_body = NULL; 00117 DLIList<double> takeoff_factor_list; 00118 DLIList<RefFace*> takeoff_vector_surface_list; 00119 DLIList<CubitVector> surface_takeoff_vector_list; 00120 DLIList<RefEdge*> takeoff_vector_curve_list; 00121 DLIList<CubitVector> curve_takeoff_vector_list; 00122 DLIList<RefEdge*> guides; 00123 DLIList<RefVertex*> match_vertices_list; 00124 gmti->loft_surfaces_to_body(loft_surfaces, takeoff_factor_list, 00125 takeoff_vector_surface_list, 00126 surface_takeoff_vector_list, 00127 takeoff_vector_curve_list, 00128 curve_takeoff_vector_list, guides, 00129 match_vertices_list, new_body, 00130 false, false, false, false); 00131 double volume = new_body->measure(); 00132 assert(fabs(volume - 2100) < 0.000001); 00133 00134 DLIList<RefEntity*> ref_entity_list; 00135 const CubitString cubit_version="12.2"; 00136 int num_ents_exported=0; 00137 const char *filename = "loft.brep"; 00138 const char *filetype = "OCC"; 00139 CubitStatus rsl = CubitCompat_export_solid_model(ref_entity_list, filename, filetype, 00140 num_ents_exported, cubit_version); 00141 00142 assert(rsl); 00143 remove(filename); 00144 DLIList<Body*> bodies; 00145 gti->bodies(bodies); 00146 00147 //delete all entities 00148 gti->delete_Body(bodies); 00149 00150 CubitVector p1(0, 0 ,0); 00151 CubitVector p2(1, 0 ,0); 00152 CubitVector p3(0, 1 ,0); 00153 CubitVector p4(1, 1 ,0); 00154 00155 gmti->make_RefVertex(p1,5); 00156 gmti->make_RefVertex(p2,5); 00157 gmti->make_RefVertex(p3,5); 00158 gmti->make_RefVertex(p4,5); 00159 DLIList<RefEntity*> free_entities; 00160 gti->get_free_ref_entities(free_entities); 00161 00162 RefVertex* vertex1 = CAST_TO(free_entities.step_and_get(),RefVertex); 00163 RefVertex* vertex2 = CAST_TO(free_entities.step_and_get(),RefVertex); 00164 RefVertex* vertex3 = CAST_TO(free_entities.step_and_get(),RefVertex); 00165 RefVertex* vertex4 = CAST_TO(free_entities.step_and_get(),RefVertex); 00166 RefEdge* new_edge1 = gmti->make_RefEdge(STRAIGHT_CURVE_TYPE, vertex1, vertex2); 00167 RefEdge* new_edge2 = gmti->make_RefEdge(STRAIGHT_CURVE_TYPE, vertex3, vertex4); 00168 DLIList<RefEdge*> edges; 00169 edges.append(new_edge1); 00170 edges.append(new_edge2); 00171 gmti->create_skin_surface(edges, new_body, guides); 00172 CubitVector center = new_body->center_point(); 00173 CubitVector comp (0.5, 0.5, 0); 00174 assert(center.distance_between(comp) < 0.00001); 00175 CubitBoolean is_sheet = new_body->is_sheet_body(); 00176 assert(is_sheet == CUBIT_TRUE); 00177 return CUBIT_SUCCESS; 00178 } 00179
