cgma
00001 00010 #undef NDEBUG 00011 #include <cassert> 00012 00013 #include "GeometryModifyTool.hpp" 00014 #include "GeometryQueryTool.hpp" 00015 #include "OCCQueryEngine.hpp" 00016 #include "CubitMessage.hpp" 00017 #include "Body.hpp" 00018 #include "RefVolume.hpp" 00019 #include "RefFace.hpp" 00020 #include "RefEdge.hpp" 00021 #include "RefVertex.hpp" 00022 #include "CastTo.hpp" 00023 #include "OCCModifyEngine.hpp" 00024 #include "OCCLump.hpp" 00025 #include "OCCBody.hpp" 00026 #include "OCCSurface.hpp" 00027 #include "OCCCurve.hpp" 00028 #include "OCCShell.hpp" 00029 #include "TopoDS_Shape.hxx" 00030 #include "InitCGMA.hpp" 00031 #include "CubitCompat.hpp" 00032 00033 #ifndef SRCDIR 00034 # define SRCDIR . 00035 #endif 00036 00037 #define STRINGIFY_(X) #X 00038 #define STRINGIFY(X) STRINGIFY_(X) 00039 #define SRCPATH STRINGIFY(SRCDIR) "/" 00040 00041 // forward declare some functions used and defined later 00042 CubitStatus read_geometry(int, const char **, bool local = false); 00043 CubitStatus make_Point(); 00044 // macro for printing a separator line 00045 #define PRINT_SEPARATOR PRINT_INFO("=======================================\n"); 00046 00047 00048 // main program - initialize, then send to proper function 00049 int main (int argc, char **argv) 00050 { 00051 CubitStatus status = InitCGMA::initialize_cgma("OCC"); 00052 if (CUBIT_SUCCESS != status) return 1; 00053 00054 //Do make point. 00055 status = make_Point(); 00056 if (status == CUBIT_FAILURE) 00057 PRINT_INFO("Operation Failed"); 00058 00059 int ret_val = ( CubitMessage::instance()->error_count() ); 00060 if ( ret_val != 0 ) 00061 { 00062 PRINT_ERROR("Errors found during Mergechk session.\n"); 00063 } 00064 else 00065 ret_val = 0; 00066 00067 return ret_val; 00068 00069 } 00070 00075 CubitStatus read_geometry(int num_files, const char **argv, bool local) 00076 { 00077 CubitStatus status = CUBIT_SUCCESS; 00078 GeometryQueryTool *gti = GeometryQueryTool::instance(); 00079 assert(gti); 00080 int i; 00081 00082 PRINT_SEPARATOR; 00083 00084 for (i = 0; i < num_files; i++) { 00085 std::string filename( local ? "./" : SRCPATH ); 00086 filename += argv[i]; 00087 status = CubitCompat_import_solid_model(filename.c_str(), "OCC"); 00088 if (status != CUBIT_SUCCESS) { 00089 PRINT_ERROR("Problems reading geometry file %s.\n", filename.c_str()); 00090 abort(); 00091 } 00092 } 00093 PRINT_SEPARATOR; 00094 00095 return CUBIT_SUCCESS; 00096 } 00097 00098 CubitStatus make_Point() 00099 { 00100 GeometryQueryTool *gti = GeometryQueryTool::instance(); 00101 GeometryModifyTool *gmti = GeometryModifyTool::instance(); 00102 00103 OCCQueryEngine::instance(); 00104 //OCCModifyEngine* ome = OCCModifyEngine::instance(); 00105 00106 //test for tweak fillet and chamfer 00107 Body* body = gmti->brick(10, 10, 10); 00108 Body* body2 = gmti->brick(20,20,1); 00109 DLIList<Body*> from_bodies, new_bodies; 00110 from_bodies.append(body); 00111 CubitStatus rsl = gmti->subtract(body2, from_bodies, new_bodies, 00112 CUBIT_TRUE, CUBIT_FALSE); 00113 00114 int num_ents_exported=0; 00115 DLIList<RefEntity*> ref_entities; 00116 const CubitString cubit_version="10.2"; 00117 const char * filename = "subtract.occ"; 00118 const char * filetype = "OCC"; 00119 00120 gti->get_free_ref_entities(ref_entities); 00121 for(int i = 0; i < ref_entities.size(); i++) 00122 gti->delete_RefEntity(ref_entities.get_and_step()); 00123 00124 ref_entities.clean_out(); 00125 rsl = CubitCompat_export_solid_model(ref_entities, filename, filetype, 00126 num_ents_exported, cubit_version); 00127 assert(num_ents_exported == 1); 00128 00129 DLIList<Body*> bodies; 00130 gti->bodies(bodies); 00131 //delete all entities 00132 gti->delete_Body(bodies); 00133 00134 DLIList<RefEntity*> free_entities; 00135 gti->get_free_ref_entities(free_entities); 00136 for(int i = 0; i < free_entities.size(); i++) 00137 gti->delete_RefEntity(free_entities.get_and_step()); 00138 00139 const char *argv = "subtract.occ"; 00140 rsl = read_geometry(1, &argv, true); 00141 if (rsl == CUBIT_FAILURE) exit(1); 00142 00143 bodies.clean_out(); 00144 gti->bodies(bodies); 00145 assert(bodies.size() == 1); 00146 //delete all entities 00147 gti->delete_Body(bodies); 00148 00149 free_entities.clean_out(); 00150 gti->get_free_ref_entities(free_entities); 00151 for(int i = 0; i < free_entities.size(); i++) 00152 gti->delete_RefEntity(free_entities.get_and_step()); 00153 00154 remove(filename); 00155 return CUBIT_SUCCESS; 00156 }
