iMOAB
driver.c File Reference
#include "mpi.h"
#include "moab/iMOAB.h"
#include <stdlib.h>
#include <string.h>
Defines
#define CHECKRC(rc, message)   if (0!=rc) { printf ("%s", message); return 1;}
Functions
int main (int argc, char *argv[])
Define Documentation
#define CHECKRC (   rc,
  message
Definition at line 8 of file driver.c.
Function Documentation
int main ( int  argc,
char *  argv[]
Definition at line 9 of file driver.c.
  MPI_Init(&argc, &argv);
  int nprocs, rank;
  MPI_Comm comm=MPI_COMM_WORLD;
  MPI_Comm_size(comm, &nprocs);
  MPI_Comm_rank(comm, &rank);
  char * filen = "p8ex1.h5m";
  if (argc>1)
    filen = argv[1];
   * MOAB needs to be initialized; A MOAB instance will be created, and will be used by each application
   * in this framework. There is no parallel context yet.
  ErrCode rc = iMOAB_Initialize(argc, argv);
  CHECKRC(rc, "failed to initialize MOAB");
  int num_global_vertices=0, num_global_elements=0, num_dimension=0, num_parts=0;
   * Header information is cheap to retrieve from an hdf5 file; it can be called by each process or can be
   * called by one master task and broadcasted.
   * The hdf5 file has to be in MOAB native format, and has to be partitioned in advance. There should
   * be at least as many partitions in the file as number of tasks in the communicator.
  rc = iMOAB_ReadHeaderInfo ( filen, &num_global_vertices, &num_global_elements, &num_dimension,
      &num_parts, (int)strlen(filen) );
  CHECKRC(rc, "failed to read header info");
  if (0==rank)
    printf("file %s has %d vertices, %d elements, %d parts in partition\n", filen,
        num_global_vertices, num_global_elements, num_parts);
  int appID;
  iMOAB_AppID pid=&appID;
   * Each application has to be registered once. A mesh set and a parallel communicator will be associated
   * with each application. A unique application id will be returned, and will be used for all future
   * mesh operations/queries.
  rc = iMOAB_RegisterApplication( "PROTEUS", &comm,  pid);
  CHECKRC(rc, "failed to register application");
  char *read_opts="PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION;PARALLEL_RESOLVE_SHARED_ENTS";
  int num_ghost_layers=1;
   * Loading the mesh is a parallel IO operation. Ghost layers can be exchanged too, and default MOAB
   * sets are augmented with ghost elements. By convention, blocks correspond to MATERIAL_SET sets,
   * side sets with NEUMANN_SET sets, node sets with DIRICHLET_SET sets. Each element and vertex entity should have
   * a GLOBAL ID tag in the file, which will be available for visible entities
  rc = iMOAB_LoadMesh(  pid, filen, read_opts, &num_ghost_layers, strlen(filen), strlen(read_opts) );
  CHECKRC(rc, "failed to load mesh");
  int nverts[3], nelem[3], nblocks[3], nsbc[3], ndbc[3];
   * Each process in the communicator will have access to a local mesh instance, which will contain the
   * original cells in the local partition and ghost entities. Number of vertices, primary cells, visible blocks,
   * number of sidesets and nodesets boundary conditions will be returned in size 3 arrays, for local, ghost and total
   * numbers.
  rc = iMOAB_GetMeshInfo(  pid, nverts, nelem, nblocks, nsbc, ndbc);
  CHECKRC(rc, "failed to get mesh info");
  iMOAB_GlobalID * vGlobalID = (iMOAB_GlobalID*)malloc(nverts[2]*sizeof(iMOAB_GlobalID)) ;
   * All visible vertices have a unique global ID. All arrays are allocated by client.
   * Currently, global ID is a 32 bit integer, total number of visible vertices was returned by  iMOAB_GetMeshInfo
  rc = iMOAB_GetVertexID(pid, &nverts[2], vGlobalID);
  CHECKRC(rc, "failed to get vertex id info");
  int * vranks = (int*)malloc(nverts[2]*sizeof(int));
   * In MOAB terminology, a vertex can be owned, shared or ghost. An owned vertex will be
   * owned by the current process. A shared vertex appears at the interface between partitions, it can
   * be owned by another process, while a ghost vertex is owned by another process always.
   * All vertex arrays have a natural local order, in which the ghost vertices are at the end of
   * the arrays. The local index of the vertex will vary from 0 to number of visible vertices
   * (in this example nverts[2]-1)
  rc = iMOAB_GetVertexOwnership(pid, &nverts[2], vranks );
  CHECKRC(rc, "failed to get vertex ranks");
  double * coords = (double*) malloc(3*nverts[2]*sizeof(double));
  int size_coords= 3*nverts[2];
   * Coordinates are returned interleaved, for all visible vertices. Size is dimension times
   * number of visible vertices
  rc = iMOAB_GetVisibleVerticesCoordinates( pid, &size_coords, coords);
  CHECKRC(rc, "failed to get coordinates");
   * Block IDs correspond to MATERIAL_SET tag values in hdf5 file
   * They also correspond to block IDs in a Cubit model.
   * Local visible blocks might contain ghost cells, owned by other
   * processes.
   * Inside MOAB, a block will correspond to a meshset with a MATERIAL_SET tag,
   * with value the block ID.
   * A MATERIAL_SET tag in moab if SPARSE and type INTEGER.
  iMOAB_GlobalID * gbIDs = (iMOAB_GlobalID*) malloc(nblocks[2]*sizeof(iMOAB_GlobalID));
  rc = iMOAB_GetBlockID(pid, &nblocks[2], gbIDs);
  CHECKRC(rc, "failed to get block info");
   * The 2 tags used in this example exist in the file, already.
   * If a user needs a new tag, it can be defined with the same call as this one
   * this method, iMOAB_DefineTagStorage, will return a local index for the tag.
   * The name of the tag is case sensitive.
   * This method is collective.
  int tagIndex[2];
  int entTypes[2] = {0, 1}; /* first is on vertex, second is on elements; */
  int tagTypes[2] = { DENSE_INTEGER, DENSE_DOUBLE } ;
  int num_components = 1;
  rc = iMOAB_DefineTagStorage(pid, "INTFIELD", &tagTypes[0], &num_components, &tagIndex[0],  strlen("INTFIELD") );
  CHECKRC(rc, "failed to get tag INTFIELD ");
  rc = iMOAB_DefineTagStorage(pid, "DFIELD", &tagTypes[1], &num_components, &tagIndex[1],  strlen("DFIELD") );
  CHECKRC(rc, "failed to get tag DFIELD ");
  // synchronize one of the tags only, just to see what happens
  int num_tags_to_sync=1;
   * tags are not exchanged for ghost entities by default. The user has to explicitly
   * synchronize them with a call like this one. The tags to synchronize are referenced by the index
   * returned at their "definition" with iMOAB_DefineTagStorage method.
  rc = iMOAB_SynchronizeTags(pid, &num_tags_to_sync, &tagIndex[0], &tagTypes[0] );
  CHECKRC(rc, "failed to sync tag INTFIELD ");
  for (int irank=0; irank<nprocs; irank++)
    if (irank==rank)
      /* printf some of the block info */
      printf("on rank %d, there are \n"
              "  %3d visible vertices of which  %3d local  %3d ghost \n"
              "  %3d visible elements of which  %3d owned  %3d ghost \n"
              "  %3d visible blocks\n"
              "  %3d visible neumann BCs\n"
              "  %3d visible dirichlet BCs\n", rank,
              nverts[2], nverts[0], nverts[1],
              nelem[2], nelem[0], nelem[1],
              nblocks[2], nsbc[2], ndbc[2]);
      /* printf some of the vertex id infos */
      int numToPrint = nverts[2];
      printf("on rank %d vertex info:\n", rank);
      for (int i=0; i<numToPrint; i++)
        printf(" vertex local id: %3d, rank ID:%d  global ID: %3d  coords: %g, %g, %g\n", i, vranks[i], vGlobalID[i],
              coords[3*i], coords[3*i+1], coords[3*i+2]);
      iMOAB_GlobalID * element_global_IDs = (iMOAB_GlobalID*)malloc(nelem[2]*sizeof(iMOAB_GlobalID));
      iMOAB_GlobalID * block_IDs = (iMOAB_GlobalID*)malloc(nelem[2]*sizeof(iMOAB_GlobalID));
      int * ranks = (int*)malloc(nelem[2]*sizeof(int));
       * visible elements info is available for all visible elements, with this call. Similar information
       * can be retrieved by looping over visible blocks
      rc = iMOAB_GetVisibleElementsInfo(pid, &nelem[2], element_global_IDs, ranks, block_IDs);
      CHECKRC(rc, "failed to get all elem info");
      for (int i=0; i<nelem[2]; i++)
        printf(" element local id: %3d,  global ID: %3d  rank:%d  block ID: %2d \n", i, element_global_IDs[i],
            ranks[i], block_IDs[i]);
      free(element_global_IDs);
      free(ranks);
      free(block_IDs);
      // get first element connectivity
      int conn[27];
      int nv = 27;
      int eindex = 0;
       * element connectivity can be retrieved for a single element. Local vertex indices are returned.
      rc = iMOAB_GetElementConnectivity(pid, &eindex, &nv, conn);
      CHECKRC(rc, "failed to get first element connectivity");
      printf(" conn for first element: \n");
      for (int i=0; i<nv; i++)
        printf(" %3d", conn[i]);
      printf("\n");
      // test neighbors
      int local_index = 0; // test element with local index 0
      int num_adjacent_elements = 10; // we can have maximum 6 actually
      iMOAB_LocalID  adjacent_element_IDs[10];
       * Neighbor elements that share a face with current element can be determined with this call
       * Elements are identified by their local index
      rc = iMOAB_GetNeighborElements(pid, &local_index, &num_adjacent_elements, adjacent_element_IDs);
      CHECKRC(rc, "failed to get first element neighbors");
      printf("  neighbors for first element:\n");
      for (int i=0; i<num_adjacent_elements; i++)
        printf("  %4d", adjacent_element_IDs[i]);
      printf("\n");
      for (int i=0; i<nblocks[2]; i++)
        printf(" block index: %3d, block ID: %3d \n", i, gbIDs[i] );
        int vertices_per_element, num_elements_in_block;
         * blocks should have the same type of primary elements. Number of elements in block and
         * number of vertices per element are found with this call. The method refers only to the
         * visible elements on the process.
         * The block is identified with its block ID. Should it be identified with its local index in the
         * list of visible blocks?
        rc = iMOAB_GetBlockInfo(pid,  &gbIDs[i] , &vertices_per_element, &num_elements_in_block);
        CHECKRC(rc, "failed to elem block info");
        printf("    has %4d elements with %d vertices per element\n",  num_elements_in_block, vertices_per_element);
        int size_conn= num_elements_in_block*vertices_per_element;
        iMOAB_LocalID * element_connectivity = (iMOAB_LocalID*) malloc (sizeof(iMOAB_LocalID)*size_conn);
         * Connectivity for all elements in the block can be determined with this method. Vertices are
         * identified by their local index (from 0 to number of visible vertices -1)
        rc = iMOAB_GetBlockElementConnectivities(pid, &gbIDs[i], &size_conn, element_connectivity);
        CHECKRC(rc, "failed to get block elem connectivity");
        int * element_ownership = (int*) malloc (sizeof(int)*num_elements_in_block);
         * Each element is owned by a particular process. Ownership can be returned for all elements
         * in a block with this call.
        rc = iMOAB_GetElementOwnership(pid, &gbIDs[i], &num_elements_in_block,  element_ownership);
        CHECKRC(rc, "failed to get block elem ownership");
        iMOAB_GlobalID* global_element_ID = (iMOAB_GlobalID*)malloc(sizeof(iMOAB_GlobalID)*num_elements_in_block);
        iMOAB_LocalID* local_element_ID =(iMOAB_LocalID*)malloc(sizeof(iMOAB_LocalID)*num_elements_in_block);
         * Global element IDs are determined with this call. Local indices within the process are returned too.
        rc = iMOAB_GetElementID(pid, &gbIDs[i], &num_elements_in_block, global_element_ID, local_element_ID);
        CHECKRC(rc, "failed to get block elem IDs");
        for (int j=0; j< num_elements_in_block; j++)
          printf("  elem %3d owned by %d gid: %4d lid: %4d  -- ", j, element_ownership[j], global_element_ID[j], local_element_ID[j]);
          for (int k=0; k<vertices_per_element; k++)
            printf( " %5d", element_connectivity[j*vertices_per_element+k]);
          printf("\n");
        free(global_element_ID);
        free(local_element_ID);
        free (element_connectivity);
        free (element_ownership);
       * query integer tag values on vertices
       * this tag was synchronized (see iMOAB_SynchronizeTags above)
       * Being a dense tag, all visible vertices have a value.
       * As usual, the client allocates the returned array, which is filled with data with this call (deep copy)
      int * int_tag_vals = (int *) malloc (sizeof(int) * nverts[2]); // for all visible vertices on the rank
      rc = iMOAB_GetIntTagStorage(pid, "INTFIELD", &nverts[2], &entTypes[0],
          int_tag_vals, strlen("INTFIELD"));
      CHECKRC(rc, "failed to get INTFIELD tag");
      printf("INTFIELD tag values:\n");
      for (int i=0; i<nverts[2]; i++)
        printf(" %4d", int_tag_vals[i]);
        if (i%20==19)
          printf("\n");
      printf("\n");
      free(int_tag_vals);
       * query double tag values on elements
       * This tag was not synchronized, so ghost elements have a default value of 0.
      double * double_tag_vals = (double *) malloc (sizeof(double) * nelem[2]); // for all visible elements on the rank
      rc = iMOAB_GetDoubleTagStorage(pid, "DFIELD", &nelem[2], &entTypes[1],
          double_tag_vals, strlen("DFIELD"));
      CHECKRC(rc, "failed to get DFIELD tag");
      printf("DFIELD tag values: (not exchanged) \n");
        printf(" %f", double_tag_vals[i]);
        if (i%8==7)
          printf("\n");
      printf("\n");
      free(double_tag_vals);
      /* query surface BCs */
      iMOAB_LocalID * surfBC_ID = (iMOAB_LocalID*) malloc (sizeof(iMOAB_LocalID)*nsbc[2]);
      int * ref_surf = (int *)  malloc (sizeof(int)*nsbc[2]);
      int * bc_value = (int *)  malloc (sizeof(int)*nsbc[2]);
       * Surface boundary condition information is returned for all visible Neumann conditions
       * the reference surfaces are indexed from 1 to 6 for hexahedrons, 1 to 4 to tetrahedrons, in the MOAB
       * canonical ordering convention
      rc = iMOAB_GetPointerToSurfaceBC(pid, &nsbc[2], surfBC_ID, ref_surf, bc_value);
      CHECKRC(rc, "failed to get surf boundary conditions");
      printf(" Surface boundary conditions:\n");
      for (int i=0; i<nsbc[2]; i++)
        printf("  elem_localID %4d  side:%d  BC:%2d\n",surfBC_ID[i] ,ref_surf[i], bc_value[i] );
      free(surfBC_ID);
      free(ref_surf);
      free(bc_value);
      /* query vertex BCs */
      iMOAB_LocalID * vertBC_ID = (iMOAB_LocalID*) malloc (sizeof(iMOAB_LocalID)*ndbc[2]);
      int * vertBC_value = (int *)  malloc (sizeof(int)*ndbc[2]);
      rc = iMOAB_GetPointerToVertexBC(pid, &ndbc[2], vertBC_ID, vertBC_value);
      CHECKRC(rc, "failed to get vertex boundary conditions");
      printf("  Vertex boundary conditions:\n");
      for (int i=0; i<ndbc[2]; i++)
        printf("   vertex %4d   BC:%2d\n",vertBC_ID[i], vertBC_value[i] );
      free(vertBC_ID);
      free(vertBC_value);
    MPI_Barrier(comm); // to avoid printing problems, as we write all procs data
  // free allocated data
  free(coords);
  free (vGlobalID);
  free (vranks);
  char outputFile[] = "fnew.h5m";
  char writeOptions[] ="PARALLEL=WRITE_PART";
   * the file can be written in parallel, and it will contain additional tags defined by the user
   * we may extend the method to write only desired tags to the file
  rc = iMOAB_WriteMesh(pid, outputFile, writeOptions,
      strlen(outputFile), strlen(writeOptions) );
   * deregistering application will delete all mesh entities associated with the application and will
   *  free allocated tag storage.
  rc = iMOAB_DeregisterApplication(pid);
  CHECKRC(rc, "failed to de-register application");
   * this method will delete MOAB instance
  rc = iMOAB_Finalize();
  CHECKRC(rc, "failed to finalize MOAB");
  MPI_Finalize();
  return 0;
All Files Functions Enumerations Enumerator Defines
