lasso
00001 #include "AssocPair.hpp" 00002 00003 #include <cstdlib> 00004 00005 #include "Lasso.hpp" 00006 00007 #ifdef ENABLE_IGEOM 00008 #include "GeomAssocPairSide.hpp" 00009 #endif 00010 #ifdef ENABLE_FBIGEOM 00011 #include "FBGeomAssocPairSide.hpp" 00012 #endif 00013 #ifdef ENABLE_IMESH 00014 #include "MeshAssocPairSide.hpp" 00015 #endif 00016 00017 int AssocPair::currId = 0; 00018 00019 AssocPair::AssocPair(iRel_Instance instance, 00020 iBase_Instance iface0, 00021 iRel_RelationType ent_or_set0, 00022 iRel_IfaceType type0, 00023 iRel_RelationStatus status0, 00024 iBase_Instance iface1, 00025 iRel_RelationType ent_or_set1, 00026 iRel_IfaceType type1, 00027 iRel_RelationStatus status1) 00028 : instance(instance) 00029 { 00030 pairId = currId++; 00031 00032 iBase_Instance ifaces[] = {iface0, iface1}; 00033 iRel_IfaceType types[] = {type0, type1}; 00034 for (int i = 0; i < 2; i++) { 00035 switch (types[i]) { 00036 #ifdef ENABLE_IGEOM 00037 case iRel_IGEOM_IFACE: 00038 relSides[i] = new GeomAssocPairSide(instance, ifaces[i], pairId); 00039 break; 00040 #endif 00041 #ifdef ENABLE_FBIGEOM 00042 case iRel_FBIGEOM_IFACE: 00043 relSides[i] = new FBGeomAssocPairSide(instance, ifaces[i], pairId); 00044 break; 00045 #endif 00046 #ifdef ENABLE_IMESH 00047 case iRel_IMESH_IFACE: 00048 relSides[i] = new MeshAssocPairSide(instance, ifaces[i], pairId); 00049 break; 00050 #endif 00051 default: 00052 relSides[i] = NULL; 00053 } 00054 } 00055 00056 entOrSet[0] = ent_or_set0; 00057 entOrSet[1] = ent_or_set1; 00058 relStatus[0] = status0; 00059 relStatus[1] = status1; 00060 } 00061 00062 AssocPair::~AssocPair() 00063 { 00064 for (int i = 0; i < 2; i++) 00065 delete relSides[i]; 00066 } 00067 00068 int AssocPair::get_all_entities(int iface_no, int dimension, 00069 iBase_EntityHandle **entities, 00070 int *entities_alloc, int *entities_size) 00071 { 00072 return relSides[iface_no]->get_all_entities(dimension, entities, 00073 entities_alloc, entities_size); 00074 } 00075 00076 int AssocPair::get_all_sets(int iface_no, iBase_EntitySetHandle **sets, 00077 int *sets_alloc, int *sets_size) 00078 { 00079 return relSides[iface_no]->get_all_sets(sets, sets_alloc, sets_size); 00080 } 00081 00082 int AssocPair::get_entities(int iface_no, int dimension, 00083 iBase_EntitySetHandle set_handle, 00084 iBase_EntityHandle **entities, int *entities_alloc, 00085 int *entities_size) 00086 { 00087 return relSides[iface_no]->get_entities(dimension, set_handle, entities, 00088 entities_alloc, entities_size); 00089 } 00090 00091 int AssocPair::get_ents_dims(int iface_no, iBase_EntityHandle *entities, 00092 int entities_size, int **ent_types, 00093 int *ent_types_alloc, int *ent_types_size) 00094 { 00095 return relSides[iface_no]->get_ents_dims(entities, entities_size, ent_types, 00096 ent_types_alloc, ent_types_size); 00097 } 00098 00099 int AssocPair::set_relation(iBase_EntityHandle ent1, iBase_EntityHandle ent2) 00100 { 00101 if (entOrSet[0] == iRel_SET || entOrSet[1] == iRel_SET) 00102 ERRORR(iBase_FAILURE, "Invalid relation type"); 00103 00104 // check that if we're passing in an ent for a 'both'-type 00105 // assoc, there's already a set associated to the other ent 00106 iBase_EntityHandle tmp_ent; 00107 if (entOrSet[0] == iRel_BOTH && 00108 relSides[1]->get_relation_side(&ent2, 1, &tmp_ent) != iBase_SUCCESS) 00109 ERRORR(iBase_FAILURE, "Couldn't find associated set on left side"); 00110 if (entOrSet[1] == iRel_BOTH && 00111 relSides[0]->get_relation_side(&ent1, 1, &tmp_ent) != iBase_SUCCESS) 00112 ERRORR(iBase_FAILURE, "Couldn't find associated set on right side"); 00113 00114 // set ent1 => ent2 00115 if (relStatus[0] == iRel_ACTIVE) 00116 CHK_ERRORR( relSides[0]->set_relation_side(&ent1, 1, &ent2) ); 00117 00118 // set ent1 <= ent2 00119 if (relStatus[1] == iRel_ACTIVE) 00120 CHK_ERRORR( relSides[1]->set_relation_side(&ent2, 1, &ent1) ); 00121 00122 RETURNR(iBase_SUCCESS); 00123 } 00124 00125 int AssocPair::set_relation(iBase_EntityHandle ent1, iBase_EntitySetHandle set2) 00126 { 00127 if (entOrSet[0] == iRel_SET || entOrSet[1] == iRel_ENTITY) 00128 ERRORR(iBase_FAILURE, "Invalid relation type"); 00129 00130 // check that if we're passing in an ent for a 'both'-type 00131 // assoc, there's already a set associated to the other ent 00132 iBase_EntityHandle tmp_ent; 00133 if (entOrSet[0] == iRel_BOTH && 00134 relSides[1]->get_relation_side(&set2, 1, &tmp_ent) != iBase_SUCCESS) 00135 ERRORR(iBase_FAILURE, "Couldn't find associated set on left side"); 00136 00137 // set ent1 => set2 00138 if (relStatus[0] == iRel_ACTIVE) 00139 CHK_ERRORR( relSides[0]->set_relation_side(&ent1, 1, &set2) ); 00140 00141 // set ent1 <= set2 00142 if (relStatus[1] == iRel_ACTIVE) 00143 CHK_ERRORR( relSides[1]->set_relation_side(&set2, 1, &ent1) ); 00144 00145 // if the right side is a 'both'-type association, set the contents of set2 00146 // to point to ent1 as well 00147 if (entOrSet[1] == iRel_BOTH) 00148 CHK_ERRORR( populate_recursive(1, set2, ent1) ); 00149 00150 RETURNR(iBase_SUCCESS); 00151 } 00152 00153 int AssocPair::set_relation(iBase_EntitySetHandle set1, iBase_EntityHandle ent2) 00154 { 00155 if (entOrSet[0] == iRel_ENTITY || entOrSet[1] == iRel_SET) 00156 ERRORR(iBase_FAILURE, "Invalid relation type"); 00157 00158 // check that if we're passing in an ent for a 'both'-type 00159 // assoc, there's already a set associated to the other ent 00160 iBase_EntityHandle tmp_ent; 00161 if (entOrSet[1] == iRel_BOTH && 00162 relSides[0]->get_relation_side(&set1, 1, &tmp_ent) != iBase_SUCCESS) 00163 ERRORR(iBase_FAILURE, "Couldn't find associated set on right side"); 00164 00165 // set set1 => ent2 00166 if (relStatus[0] == iRel_ACTIVE) 00167 CHK_ERRORR( relSides[0]->set_relation_side(&set1, 1, &ent2) ); 00168 00169 // set ent1 <= set2 00170 if (relStatus[1] == iRel_ACTIVE) 00171 CHK_ERRORR( relSides[1]->set_relation_side(&ent2, 1, &set1) ); 00172 00173 // if the left side is a 'both'-type association, set the contents of set1 00174 // to point to ent2 as well 00175 if (entOrSet[0] == iRel_BOTH) 00176 CHK_ERRORR( populate_recursive(0, set1, ent2) ); 00177 00178 RETURNR(iBase_SUCCESS); 00179 } 00180 00181 int AssocPair::set_relation(iBase_EntitySetHandle set1, 00182 iBase_EntitySetHandle set2) 00183 { 00184 if (entOrSet[0] == iRel_ENTITY || entOrSet[1] == iRel_ENTITY) 00185 ERRORR(iBase_FAILURE, "Invalid relation type"); 00186 00187 // set set1 => set2 00188 if (relStatus[0] == iRel_ACTIVE) 00189 CHK_ERRORR( relSides[0]->set_relation_side(&set1, 1, &set2) ); 00190 00191 // set set1 <= set2 00192 if (relStatus[1] == iRel_ACTIVE) 00193 CHK_ERRORR( relSides[1]->set_relation_side(&set2, 1, &set1) ); 00194 00195 // if either side is a 'both'-type association, set the contents of set1 00196 // to point to set2 as well (and/or vice-versa) 00197 if (entOrSet[0] == iRel_BOTH) 00198 CHK_ERRORR( populate_recursive(0, set1, set2) ); 00199 if (entOrSet[1] == iRel_BOTH) 00200 CHK_ERRORR( populate_recursive(1, set2, set1) ); 00201 00202 RETURNR(iBase_SUCCESS); 00203 } 00204 00205 int AssocPair::get_relation(int iface_no, iBase_EntityHandle *entities, 00206 int num_entities, iBase_EntityHandle *tag_values) 00207 { 00208 if (relStatus[iface_no] == iRel_NOTEXIST) 00209 ERRORR(iBase_FAILURE, "Relation does not exist on this side"); 00210 if (entOrSet[!iface_no] != iRel_ENTITY) // other iface is sets 00211 ERRORR(iBase_INVALID_ENTITY_HANDLE, "Expected EntitySet, got Entity"); 00212 00213 return relSides[iface_no]->get_relation_side(entities, num_entities, 00214 tag_values); 00215 } 00216 00217 int AssocPair::get_relation(int iface_no, iBase_EntitySetHandle *sets, 00218 int num_sets, iBase_EntityHandle *tag_values) 00219 { 00220 if (relStatus[iface_no] == iRel_NOTEXIST) 00221 ERRORR(iBase_FAILURE, "Relation does not exist on this side"); 00222 if (entOrSet[!iface_no] != iRel_ENTITY) // other iface is sets 00223 ERRORR(iBase_INVALID_ENTITY_HANDLE, "Expected EntitySet, got Entity"); 00224 00225 return relSides[iface_no]->get_relation_side(sets, num_sets, tag_values); 00226 } 00227 00228 int AssocPair::get_relation(int iface_no, iBase_EntityHandle *entities, 00229 int num_entities, iBase_EntitySetHandle *tag_values) 00230 { 00231 if (relStatus[iface_no] == iRel_NOTEXIST) 00232 ERRORR(iBase_FAILURE, "Relation does not exist on this side"); 00233 if (entOrSet[!iface_no] == iRel_ENTITY) // other iface is not sets 00234 ERRORR(iBase_INVALID_ENTITY_HANDLE, "Expected Entity, got EntitySet"); 00235 00236 return relSides[iface_no]->get_relation_side(entities, num_entities, 00237 tag_values); 00238 } 00239 00240 int AssocPair::get_relation(int iface_no, iBase_EntitySetHandle *sets, 00241 int num_sets, iBase_EntitySetHandle *tag_values) 00242 { 00243 if (relStatus[iface_no] == iRel_NOTEXIST) 00244 ERRORR(iBase_FAILURE, "Relation does not exist on this side"); 00245 if (entOrSet[!iface_no] == iRel_ENTITY) // other iface is not sets 00246 ERRORR(iBase_INVALID_ENTITY_HANDLE, "Expected Entity, got EntitySet"); 00247 00248 return relSides[iface_no]->get_relation_side(sets, num_sets, tag_values); 00249 } 00250 00251 int AssocPair::get_relation(int iface_no, iBase_EntityHandle *entities, 00252 int num_entities, iBase_EntityIterator *tag_values) 00253 { 00254 std::vector<iBase_EntitySetHandle> sets(num_entities); 00255 CHK_ERRORR( get_relation(iface_no, entities, num_entities, &sets[0]) ); 00256 00257 for(int i=0; i<num_entities; i++) 00258 CHK_ERRORR( relSides[i]->get_iterator(sets[i], &tag_values[i]) ); 00259 00260 RETURNR(iBase_SUCCESS); 00261 } 00262 00263 int AssocPair::get_relation(int iface_no, iBase_EntitySetHandle *sets, 00264 int num_sets, iBase_EntityIterator *tag_values) 00265 { 00266 std::vector<iBase_EntitySetHandle> sets2(num_sets); 00267 CHK_ERRORR( get_relation(iface_no, sets, num_sets, &sets2[0]) ); 00268 00269 for(int i=0; i<num_sets; i++) 00270 CHK_ERRORR( relSides[iface_no]->get_iterator(sets2[i], &tag_values[i]) ); 00271 00272 RETURNR(iBase_SUCCESS); 00273 } 00274 00275 int AssocPair::rmv_relation(int iface_no, iBase_EntityHandle *entities, 00276 int num_entities) 00277 { 00278 if (relStatus[iface_no] == iRel_NOTEXIST) 00279 ERRORR(iBase_FAILURE, "Relation does not exist on this side"); 00280 00281 // TODO: handle "both" case 00282 00283 // Remove the opposite side first 00284 if (relStatus[!iface_no] == iRel_ACTIVE) { 00285 if (entOrSet[!iface_no] == iRel_ENTITY) { 00286 std::vector<iBase_EntityHandle> other_entities(num_entities); 00287 CHK_ERRORR( get_relation(iface_no, entities, num_entities, 00288 &other_entities[0]) ); 00289 CHK_ERRORR( relSides[!iface_no]->rmv_relation_side(&other_entities[0], 00290 num_entities) ); 00291 } 00292 else { 00293 std::vector<iBase_EntitySetHandle> other_sets(num_entities); 00294 CHK_ERRORR( get_relation(iface_no, entities, num_entities, 00295 &other_sets[0]) ); 00296 CHK_ERRORR( relSides[!iface_no]->rmv_relation_side(&other_sets[0], 00297 num_entities) ); 00298 } 00299 } 00300 00301 return relSides[iface_no]->rmv_relation_side(entities, num_entities); 00302 } 00303 00304 int AssocPair::rmv_relation(int iface_no, iBase_EntitySetHandle *sets, 00305 int num_sets) 00306 { 00307 if (relStatus[iface_no] == iRel_NOTEXIST) 00308 ERRORR(iBase_FAILURE, "Relation does not exist on this side"); 00309 00310 // TODO: handle "both" case 00311 00312 // Remove the opposite side first 00313 if (relStatus[!iface_no] == iRel_ACTIVE) { 00314 if (entOrSet[!iface_no] == iRel_ENTITY) { 00315 std::vector<iBase_EntityHandle> other_entities(num_sets); 00316 CHK_ERRORR( get_relation(iface_no, sets, num_sets, &other_entities[0]) ); 00317 CHK_ERRORR( relSides[!iface_no]->rmv_relation_side(&other_entities[0], 00318 num_sets) ); 00319 } 00320 else { 00321 std::vector<iBase_EntitySetHandle> other_sets(num_sets); 00322 CHK_ERRORR( get_relation(iface_no, sets, num_sets, &other_sets[0]) ); 00323 CHK_ERRORR( relSides[!iface_no]->rmv_relation_side(&other_sets[0], 00324 num_sets) ); 00325 } 00326 } 00327 00328 return relSides[iface_no]->rmv_relation_side(sets, num_sets); 00329 } 00330 00331 int AssocPair::get_gids(int iface_no, iBase_EntityHandle *entities, 00332 int num_entities, int *tag_values) 00333 { 00334 return relSides[iface_no]->get_gids(entities, num_entities, tag_values); 00335 } 00336 00337 int AssocPair::get_gids(int iface_no, iBase_EntitySetHandle *sets, 00338 int num_sets, int *tag_values) 00339 { 00340 return relSides[iface_no]->get_gids(sets, num_sets, tag_values); 00341 } 00342 00343 int AssocPair::get_dims(int iface_no, iBase_EntityHandle *entities, 00344 int num_entities, int *tag_values) 00345 { 00346 return relSides[iface_no]->get_dims(entities, num_entities, tag_values); 00347 } 00348 00349 int AssocPair::get_dims(int iface_no, iBase_EntitySetHandle *sets, 00350 int num_sets, int *tag_values) 00351 { 00352 return relSides[iface_no]->get_dims(sets, num_sets, tag_values); 00353 } 00354 00355 int AssocPair::change_type(int iface_no, iRel_RelationType type) 00356 { 00357 if (entOrSet[iface_no] == type) 00358 RETURNR(iBase_SUCCESS); 00359 if (entOrSet[iface_no] == iRel_ENTITY || type == iRel_ENTITY) 00360 ERRORR(iBase_FAILURE, "Can only change type from \"set\" to \"both\", or " 00361 "vice-versa"); 00362 00363 entOrSet[iface_no] = type; 00364 if (relStatus[iface_no] != iRel_ACTIVE) 00365 RETURNR(iBase_SUCCESS); 00366 00367 iBase_EntitySetHandle *sets = NULL; 00368 int set_alloc = 0, set_size; 00369 CHK_ERRORR( relSides[iface_no]->get_related_sets(&sets, &set_alloc, 00370 &set_size) ); 00371 if (type == iRel_BOTH) { 00372 if (entOrSet[!iface_no] == iRel_ENTITY) { 00373 std::vector<iBase_EntityHandle> related_ents(set_size); 00374 CHK_ERRORR( relSides[iface_no]->get_relation_side(sets, set_size, 00375 &related_ents[0]) ); 00376 00377 for (int i = 0; i < set_size; i++) 00378 CHK_ERRORR( populate_recursive(iface_no, sets[i], related_ents[i]) ); 00379 } 00380 else { 00381 std::vector<iBase_EntitySetHandle> related_sets(set_size); 00382 CHK_ERRORR( relSides[iface_no]->get_relation_side(sets, set_size, 00383 &related_sets[0]) ); 00384 00385 for (int i = 0; i < set_size; i++) 00386 CHK_ERRORR( populate_recursive(iface_no, sets[i], related_sets[i]) ); 00387 } 00388 } 00389 else if (type == iRel_SET) { 00390 for (int i = 0; i < set_size; i++) 00391 CHK_ERRORR( unpopulate_recursive(iface_no, sets[i]) ); 00392 } 00393 00394 free(sets); 00395 RETURNR(iBase_SUCCESS); 00396 } 00397 00398 int AssocPair::change_status(int iface_no, iRel_RelationStatus status) 00399 { 00400 if (relStatus[iface_no] == status) 00401 RETURNR(iBase_SUCCESS); 00402 00403 relStatus[iface_no] = status; 00404 00405 if (status == iRel_NOTEXIST) { 00406 // Destroy the assoc tag 00407 CHK_ERRORR( relSides[iface_no]->destroy_relation_side() ); 00408 } 00409 else if (status == iRel_INACTIVE) { 00410 // Create the assoc tag 00411 CHK_ERRORR( relSides[iface_no]->create_relation_side() ); 00412 } 00413 // Update the assoc tag 00414 else if (status == iRel_ACTIVE) { 00415 CHK_ERRORR( relSides[iface_no]->destroy_relation_side() ); 00416 CHK_ERRORR( relSides[iface_no]->create_relation_side() ); 00417 00418 if (entOrSet[!iface_no] == iRel_ENTITY) { 00419 iBase_EntityHandle *entities = NULL; 00420 int ent_alloc = 0, ent_size; 00421 00422 CHK_ERRORR( relSides[!iface_no]->get_related_ents(&entities, &ent_alloc, 00423 &ent_size) ); 00424 if (entOrSet[iface_no] == iRel_ENTITY) { 00425 std::vector<iBase_EntityHandle> related_ents(ent_size); 00426 int result = relSides[!iface_no]->get_relation_side( 00427 entities, ent_size, &related_ents[0]); 00428 00429 if (result == iBase_SUCCESS) { 00430 if (iface_no == 0) 00431 for (int i = 0; i < ent_size; i++) 00432 CHK_ERRORR( set_relation(related_ents[i], entities[i]) ); 00433 else 00434 for (int i = 0; i < ent_size; i++) 00435 CHK_ERRORR( set_relation(entities[i], related_ents[i]) ); 00436 } 00437 } 00438 else { 00439 std::vector<iBase_EntitySetHandle> related_sets(ent_size); 00440 int result = relSides[!iface_no]->get_relation_side( 00441 entities, ent_size, &related_sets[0]); 00442 00443 if (result == iBase_SUCCESS) { 00444 if (iface_no == 0) 00445 for (int i = 0; i < ent_size; i++) 00446 CHK_ERRORR( set_relation(related_sets[i], entities[i]) ); 00447 else 00448 for (int i = 0; i < ent_size; i++) 00449 CHK_ERRORR( set_relation(entities[i], related_sets[i]) ); 00450 } 00451 } 00452 00453 free(entities); 00454 } 00455 else { 00456 iBase_EntitySetHandle *sets = NULL; 00457 int set_alloc = 0, set_size; 00458 00459 CHK_ERRORR( relSides[!iface_no]->get_related_sets(&sets, &set_alloc, 00460 &set_size) ); 00461 if (entOrSet[iface_no] == iRel_ENTITY) { 00462 std::vector<iBase_EntityHandle> related_ents(set_size); 00463 int result = relSides[!iface_no]->get_relation_side( 00464 sets, set_size, &related_ents[0]); 00465 00466 if (result == iBase_SUCCESS) { 00467 if (iface_no == 0) 00468 for (int i = 0; i < set_size; i++) 00469 CHK_ERRORR( set_relation(related_ents[i], sets[i]) ); 00470 else 00471 for (int i = 0; i < set_size; i++) 00472 CHK_ERRORR( set_relation(sets[i], related_ents[i]) ); 00473 } 00474 } 00475 else { 00476 std::vector<iBase_EntitySetHandle> related_sets(set_size); 00477 int result = relSides[!iface_no]->get_relation_side( 00478 sets, set_size, &related_sets[0]); 00479 00480 if (result == iBase_SUCCESS) { 00481 if (iface_no == 0) 00482 for (int i = 0; i < set_size; i++) 00483 CHK_ERRORR( set_relation(related_sets[i], sets[i]) ); 00484 else 00485 for (int i = 0; i < set_size; i++) 00486 CHK_ERRORR( set_relation(sets[i], related_sets[i]) ); 00487 } 00488 } 00489 00490 free(sets); 00491 } 00492 } 00493 else { 00494 ERRORR(iBase_INVALID_ARGUMENT, "Invalid argument for relation status"); 00495 } 00496 00497 RETURNR(iBase_SUCCESS); 00498 } 00499 00500 bool AssocPair::equivalent(iBase_Instance iface0, iBase_Instance iface1, 00501 bool *order_switched) 00502 { 00503 if (iface0 == relSides[0]->instance() && 00504 iface1 == relSides[1]->instance()) { 00505 if (order_switched) *order_switched = false; 00506 return true; 00507 } 00508 else if (iface0 == relSides[1]->instance() && 00509 iface1 == relSides[0]->instance()) { 00510 if (order_switched) *order_switched = true; 00511 return true; 00512 } 00513 else 00514 return false; 00515 } 00516 00517 bool AssocPair::equivalent(iRel_IfaceType type0, iRel_IfaceType type1, 00518 bool *order_switched) 00519 { 00520 if (type0 == relSides[0]->type() && 00521 type1 == relSides[1]->type()) { 00522 if (order_switched) *order_switched = false; 00523 return true; 00524 } 00525 else if (type0 == relSides[1]->type() && 00526 type1 == relSides[0]->type()) { 00527 if (order_switched) *order_switched = true; 00528 return true; 00529 } 00530 else 00531 return false; 00532 } 00533 00534 bool AssocPair::contains(iBase_Instance iface) 00535 { 00536 return (iface == relSides[0]->instance() || 00537 iface == relSides[1]->instance()); 00538 } 00539 00540 int AssocPair::populate_recursive(int iface_no, iBase_EntitySetHandle set, 00541 iBase_EntityHandle related_ent) 00542 { 00543 iBase_EntityHandle *entities = NULL; 00544 int entities_alloc = 0, entities_size; 00545 00546 CHK_ERRORR( relSides[iface_no]->get_entities(-1, set, &entities, 00547 &entities_alloc, 00548 &entities_size) ); 00549 00550 for (int i = 0; i < entities_size; i++) 00551 CHK_ERRORR( relSides[iface_no]->set_relation_side(entities+i, 1, 00552 &related_ent) ); 00553 00554 free(entities); 00555 RETURNR(iBase_SUCCESS); 00556 } 00557 00558 int AssocPair::populate_recursive(int iface_no, iBase_EntitySetHandle set, 00559 iBase_EntitySetHandle related_set) 00560 { 00561 iBase_EntityHandle *entities = NULL; 00562 int entities_alloc, entities_size; 00563 00564 CHK_ERRORR( relSides[iface_no]->get_entities(-1, set, &entities, 00565 &entities_alloc, 00566 &entities_size) ); 00567 00568 for (int i = 0; i < entities_size; i++) 00569 CHK_ERRORR( relSides[iface_no]->set_relation_side(entities+i, 1, 00570 &related_set) ); 00571 00572 free(entities); 00573 RETURNR(iBase_SUCCESS); 00574 } 00575 00576 int AssocPair::unpopulate_recursive(int iface_no, iBase_EntitySetHandle set) 00577 { 00578 iBase_EntityHandle *entities = NULL; 00579 int entities_alloc = 0, entities_size; 00580 00581 CHK_ERRORR( relSides[iface_no]->get_entities(-1, set, &entities, 00582 &entities_alloc, 00583 &entities_size) ); 00584 CHK_ERRORR( relSides[iface_no]->rmv_relation_side(entities, entities_size) ); 00585 00586 free(entities); 00587 RETURNR(iBase_SUCCESS); 00588 }
