lasso
#include "iGeom.h"#include "iMesh.h"#include "iRel.h"#include "stdio.h"#include "stdlib.h"#include "string.h"Go to the source code of this file.
Defines | |
| #define | DEFAULT_GEOM_FILE brick.cub |
| #define | DEFAULT_MESH_FILE brick.cub |
| #define | STRINGIFY_(X) #X |
| #define | STRINGIFY(X) STRINGIFY_(X) |
| #define | DEFAULT_GEOM STRINGIFY(DEFAULT_GEOM_FILE) |
| #define | DEFAULT_MESH STRINGIFY(DEFAULT_MESH_FILE) |
| #define | CHECK_SIZE_C(type, array, allocated_size, size) |
Typedefs | |
| typedef void * | iRel_EntityHandle |
Functions | |
| void | handle_error_code (const int result, int *number_failed, int *number_not_implemented, int *number_successful) |
| int | print_geom_info (iGeom_Instance geom, iBase_EntityHandle gent) |
| int | print_mesh_info (iMesh_Instance mesh, iBase_EntityHandle ment) |
| int | load_geom_mesh_test (const char *geom_filename, const char *mesh_filename, iGeom_Instance geom, iMesh_Instance mesh) |
| int | create_relation_test (iRel_Instance assoc, iGeom_Instance geom, iMesh_Instance mesh, iRel_PairHandle *pair) |
| int | relate_geom_mesh_test (iRel_Instance assoc, iGeom_Instance geom, iMesh_Instance mesh, iRel_PairHandle pair) |
| int | query_relations_test (iRel_Instance assoc, iGeom_Instance geom, iMesh_Instance mesh, iRel_PairHandle pair) |
| int | main (int argc, char *argv[]) |
| #define CHECK_SIZE_C | ( | type, | |
| array, | |||
| allocated_size, | |||
| size | |||
if (NULL == *array || *allocated_size == 0) {\ *array = (type *) malloc(sizeof(type) * size); \ *allocated_size = size;} \ else if (*allocated_size < size) { \ printf(" Array passed in is non-zero but too short.\n"); }
Definition at line 27 of file test_entset.cpp.
| #define DEFAULT_GEOM STRINGIFY(DEFAULT_GEOM_FILE) |
Definition at line 23 of file test_entset.cpp.
| #define DEFAULT_GEOM_FILE brick.cub |
Definition at line 13 of file test_entset.cpp.
| #define DEFAULT_MESH STRINGIFY(DEFAULT_MESH_FILE) |
Definition at line 24 of file test_entset.cpp.
| #define DEFAULT_MESH_FILE brick.cub |
Definition at line 14 of file test_entset.cpp.
| #define STRINGIFY | ( | X | ) | STRINGIFY_(X) |
Definition at line 18 of file test_entset.cpp.
| #define STRINGIFY_ | ( | X | ) | #X |
Definition at line 17 of file test_entset.cpp.
| typedef void* iRel_EntityHandle |
Definition at line 34 of file test_entset.cpp.
| int create_relation_test | ( | iRel_Instance | assoc, |
| iGeom_Instance | geom, | ||
| iMesh_Instance | mesh, | ||
| iRel_PairHandle * | pair | ||
Definition at line 210 of file test_entset.cpp.
int result;
iBase_Instance iface1, iface2;
int type1, type2;
int ent_or_set1, ent_or_set2;
int status1, status2;
iRel_PairHandle tmp_pair;
iRel_PairHandle *pair_ptr = &tmp_pair;
int pairs_alloc = 1, pairs_size;
/* create an relation, entity to set */
iRel_createPair(assoc,
geom, iRel_ENTITY, iRel_IGEOM_IFACE, iRel_ACTIVE,
mesh, iRel_SET, iRel_IMESH_IFACE, iRel_ACTIVE,
pair, &result);
if (iBase_SUCCESS != result) {
printf("Couldn't create a new relation.\n");
return 0;
iRel_getPairInfo(assoc, *pair,
&iface1, &ent_or_set1, &type1, &status1,
&iface2, &ent_or_set2, &type2, &status2, &result);
printf("Couldn't retrieve relation info.\n");
return 0;
if (iface1 != geom || ent_or_set1 != iRel_ENTITY ||
type1 != iRel_IGEOM_IFACE || iface2 != mesh || ent_or_set2 != iRel_SET ||
type2 != iRel_IMESH_IFACE) {
printf("Unexpected relation info returned.\n");
return 0;
iRel_findPairs(assoc, geom, &pair_ptr, &pairs_alloc, &pairs_size, &result);
printf("Couldn't find relation pair when querying geom.\n");
return 0;
if (pairs_size != 1 || tmp_pair != *pair) {
printf("Unexpected relation pairs returned when querying geom.\n");
return 0;
iRel_findPairs(assoc, mesh, &pair_ptr, &pairs_alloc, &pairs_size, &result);
printf("Couldn't find relation pair when querying mesh.\n");
return 0;
printf("Unexpected relation pairs returned when querying mesh.\n");
return 0;
return 1;
| void handle_error_code | ( | const int | result, |
| int * | number_failed, | ||
| int * | number_not_implemented, | ||
| int * | number_successful | ||
prints out a result string based on the value of error_code
Definition at line 39 of file test_entset.cpp.
if (result) {
printf("Success");
(*number_successful)++;
else {
printf("Failure");
(*number_failed)++;
| int load_geom_mesh_test | ( | const char * | geom_filename, |
| const char * | mesh_filename, | ||
| iMesh_Instance | mesh | ||
Definition at line 182 of file test_entset.cpp.
/* load a geom */
int result;
iGeom_load(geom, geom_filename, 0, &result, strlen(geom_filename), 0);
printf("ERROR : can not load a geometry\n");
return 0;
/* load a mesh */
iMesh_load(mesh, 0, mesh_filename, 0, &result, strlen(mesh_filename), 0);
printf("ERROR : can not load a mesh\n");
return 0;
return 1;
| int main | ( | int | argc, |
| char * | argv[] | ||
Definition at line 537 of file test_entset.cpp.
/* Check command line arg */
const char *geom_filename = DEFAULT_GEOM;
const char *mesh_filename = DEFAULT_MESH;
int result;
int number_tests = 0;
int number_tests_successful = 0;
int number_tests_not_implemented = 0;
int number_tests_failed = 0;
iGeom_Instance geom;
iMesh_Instance mesh;
iRel_Instance assoc;
iRel_PairHandle pair;
if (argc == 2 && !strcmp(argv[1], "-h")) {
printf("Usage: %s <geom_filename> <mesh_filename>\n",
argv[0]);
return 1;
else if (argc == 2) {
geom_filename = argv[1];
mesh_filename = argv[1];
else if (argc == 3) {
mesh_filename = argv[2];
/* initialize the Geometry */
iGeom_newGeom(0, &geom, &result, 0);
/* initialize the Mesh */
iMesh_newMesh(0, &mesh, &result, 0);
/* initialize the Associate */
iRel_create(0, &assoc, &result, 0);
/* Print out Header information */
printf("\n\niRel TEST PROGRAM:\n\n");
/* load_geom_mesh test */
printf(" load_geom_mesh: ");
result = load_geom_mesh_test(geom_filename, mesh_filename,
geom, mesh);
handle_error_code(result, &number_tests_failed,
&number_tests_not_implemented,
&number_tests_successful);
number_tests++;
printf("\n");
/* create_relation test */
printf(" create_relation: ");
result = create_relation_test(assoc, geom, mesh, &pair);
number_tests++;
printf("\n");
/* relate_geom_mesh test */
printf(" relate_geom_mesh: ");
result = relate_geom_mesh_test(assoc, geom, mesh, pair);
number_tests++;
printf("\n");
/* query_relations test */
printf(" query_relations: ");
result = query_relations_test(assoc, geom, mesh, pair);
number_tests++;
printf("\n");
/* summary */
printf("\niRel TEST SUMMARY: \n");
printf(" Number Tests: %d\n", number_tests);
printf(" Number Successful: %d\n", number_tests_successful);
printf(" Number Not Implemented: %d\n", number_tests_not_implemented);
printf(" Number Failed: %d\n", number_tests_failed);
printf("\n\n");
iRel_destroy(assoc, &result);
return number_tests_failed != 0;
| int print_geom_info | ( | iGeom_Instance | geom, |
| iBase_EntityHandle | gent | ||
Definition at line 54 of file test_entset.cpp.
/* print information about this entity */
int ent_type;
int result;
const char *type_names[] = {"Vertex", "Edge", "Face", "Region"};
iGeom_getEntType(geom, gent, &ent_type, &result);
printf("Trouble getting entity adjacencies or types.");
return 0;
printf("%s 0x%lx\n", type_names[ent_type], (unsigned long)gent);
return 1;
| int print_mesh_info | ( | iMesh_Instance | mesh, |
| iBase_EntityHandle | ment | ||
Definition at line 73 of file test_entset.cpp.
/* get adjacencies first; assume not more than 50 */
iBase_EntityHandle adj_ents[50], *adj_ents_ptr = adj_ents;
int ent_types[50], *ent_types_ptr = ent_types;
int adj_ents_alloc = 50, adj_ents_size, ent_types_size,
ent_types_allocated = 50;
int result;
iBase_TagHandle *ment_tags = NULL;
int ment_tags_size, ment_tags_alloc;
char **tag_names;
int i;
iMesh_getEntAdj(mesh, ment, iBase_ALL_TYPES,
&adj_ents_ptr, &adj_ents_alloc, &adj_ents_size,
&result);
if (iBase_SUCCESS != result) return 0;
/* put this ent on the end, then get types */
adj_ents[adj_ents_size] = ment;
iMesh_getEntArrType(mesh, adj_ents, adj_ents_size+1,
&ent_types_ptr, &ent_types_allocated,
&ent_types_size, &result);
return 0;
/* get tags on ment */
iMesh_getAllTags(mesh, ment,
&ment_tags, &ment_tags_alloc, &ment_tags_size,
&result);
printf("Trouble getting tags on an entity or their names.");
/* while we're at it, get all the tag names */
tag_names = (char **) malloc(ment_tags_size * sizeof(char*));
for (i = 0; i < ment_tags_size; i++) {
tag_names[i] = (char*)malloc(120*sizeof(char));
iMesh_getTagName(mesh, ment_tags[i], tag_names[i], &result, 120);
/* now print the information */
printf("%s %ld:\n", type_names[ent_types[ent_types_size-1]], (long)ment);
printf("Adjacencies:");
for (i = 0; i < adj_ents_size; i++) {
if (i > 0) printf(", ");
printf("%s %ld", type_names[ent_types[i]],
(long)adj_ents[i]);
printf("\nTags: \n");
int tag_type;
printf("%s ", tag_names[i]);
iMesh_getTagType(mesh, ment_tags[i], &tag_type, &result);
printf("(trouble getting type...)\n");
else {
char *dum_handle = NULL;
int dum_handle_alloc = 0, dum_handle_size = 0;
int int_data;
double dbl_data;
iBase_EntityHandle eh_data;
switch (tag_type) {
case iBase_INTEGER:
iMesh_getIntData(mesh, ment, ment_tags[i], &int_data, &result);
printf("(Int value=%d)", int_data);
break;
case iBase_DOUBLE:
iMesh_getDblData(mesh, ment, ment_tags[i], &dbl_data, &result);
printf("(Dbl value=%f)", dbl_data);
break;
case iBase_ENTITY_HANDLE:
iMesh_getEHData(mesh, ment, ment_tags[i], &eh_data, &result);
printf("(EH value=%ld)", (long)eh_data);
break;
case iBase_BYTES:
iMesh_getData(mesh, ment, ment_tags[i],
(void**)&dum_handle, &dum_handle_alloc,
&dum_handle_size, &result);
if (NULL != dum_handle && dum_handle_size > 0)
printf("(Opaque value=%c)", dum_handle[0]);
break;
printf("\n");
printf("(end tags)\n\n");
return 1;
| int query_relations_test | ( | iRel_Instance | assoc, |
| iRel_PairHandle | pair | ||
Definition at line 452 of file test_entset.cpp.
int result;
int i;
iBase_EntityHandle *gentities = NULL;
int gentities_size = 0, gentities_alloc = 0;
iBase_EntitySetHandle *out_mentities = NULL;
int out_mentities_size, out_mentities_alloc = 0;
iBase_EntityHandle *out_gentities = NULL;
int out_gentities_size, out_gentities_alloc = 0;
/* get all the geom entities, and find relation to some mesh entity */
iGeom_getEntities(geom, NULL, iBase_ALL_TYPES,
&gentities, &gentities_alloc,
&gentities_size, &result);
printf("Problem getting all geom entities.\n" );
return 0;
iRel_getEntArrSetArrRelation(assoc, pair,
gentities, gentities_size, 0,
&out_mentities, &out_mentities_alloc,
&out_mentities_size,
&result);
/* might not all be */
char descr[120];
printf("Failed to get mesh entities related to geom entities in query_relations_test.\n");
iRel_getDescription(assoc, descr, sizeof(descr)-1);
printf("Entities missing relations: %s\n", descr);
for (i = 0; i < gentities_size; i++) {
print_geom_info(geom, gentities[i]);
return 0;
/* check that they're all non-null */
if (out_mentities_size != gentities_size) {
printf("Number of mesh & related geom entities don't match.\n");
return 0;
/* check to make sure they're mesh sets; how to do that? */
for (i = 0; i < out_mentities_size; i++) {
int is_list;
iMesh_isList(mesh, (iBase_EntitySetHandle)out_mentities[i], &is_list, &result);
printf("Entity set returned from classification wasn't valid.\n");
return 0;
/* now turn around and check classification of those mesh entities */
iRel_getSetArrEntArrRelation(assoc, pair,
out_mentities, out_mentities_size, 1,
&out_gentities, &out_gentities_alloc,
&out_gentities_size,
&result);
printf("Failed to get geom entities related to mesh entities in query_relations_test.\n");
return 0;
if (out_mentities_size != out_gentities_size) {
printf("Number of geom & related mesh entities don't match.\n" );
return 0;
/* ok, we're done */
return 1;
| int relate_geom_mesh_test | ( | iRel_Instance | assoc, |
Definition at line 277 of file test_entset.cpp.
int result;
iBase_EntitySetHandle *mentity_handles = NULL;
int mentity_handles_size = 0, mentity_handles_alloc = 0;
const char *dim_tag_name = "GEOM_DIMENSION";
iBase_TagHandle dim_tag_mesh;
iBase_EntitySetHandle *mentities_vec;
int mentities_vec_size = 0;
int i;
int out_mentities_size = 0, out_mentities_alloc = 0;
iBase_EntitySetHandle *out_mentities2 = NULL;
int out_mentities2_size = 0, out_mentities2_alloc = 0;
int out_gentities_size = 0, out_gentities_alloc = 0;
/* relate geometry entities with coresponding mesh entity sets */
iBase_VERTEX,
&gentities,
&gentities_alloc,
printf("Failed to get gentities by type in relate_geom_mesh_test.\n");
return 0;
iRel_inferEntArrRelations(assoc, pair,
&result);
printf("Failed to relate geom entities in relate_geom_mesh_test.\n");
return 0;
/* relate coresponding mesh entity sets for geometry entities */
/* get 1-dimensional mesh entitysets */
iMesh_getEntSets(mesh, NULL, 1,
&mentity_handles, &mentity_handles_alloc,
&mentity_handles_size, &result);
printf("Problem to get all entity sets.\n");
return 0;
/* get geom dimension tags for mesh entitysets */
iMesh_createTag(mesh, dim_tag_name, 1, iBase_INTEGER,
&dim_tag_mesh, &result, 15);
if (iBase_SUCCESS != result && result != iBase_TAG_ALREADY_EXISTS) {
printf("Couldn't create geom dim tag for mesh entities.\n");
return 0;
mentities_vec = (iBase_EntitySetHandle*)
malloc(mentity_handles_size*sizeof(iBase_EntitySetHandle));
for (i = 0; i < mentity_handles_size; i++) { /* test */
int dim;
iMesh_getEntSetIntData(mesh, mentity_handles[i], dim_tag_mesh,
&dim, &result);
continue;
if (dim == 1)
mentities_vec[mentities_vec_size++] = mentity_handles[i];
iRel_inferSetArrRelations(assoc, pair,
mentities_vec, mentities_vec_size,
1, &result);
printf("Failed to relate mesh entities in relate_geom_mesh_test.\n");
return 0;
/* relate all geometry and mesh entities */
iRel_inferAllRelations(assoc, pair, &result);
printf("Failed to relate all geom and mesh entities in relate_geom_mesh_test.\n");
return 0;
/* reset geom entities list and get all geom entities (prev
only vertices) */
free(gentities);
gentities = NULL;
iBase_ALL_TYPES,
&gentities,
&gentities_alloc,
return 0;
/* get related mesh entity sets for geometry entities */
&result);
printf("Failed to get geom entities in relate_geom_mesh_test.\n");
return 0;
printf("Number of input geom entities and output mesh entity sets should be same\n");
return 0;
/* now try deleting this relation */
iRel_rmvEntArrRelation(assoc, pair, gentities, gentities_size, 0, &result);
printf("Failed to remove relation in relate_geom_mesh_test.\n");
return 0;
&out_mentities2, &out_mentities2_alloc,
&out_mentities2_size,
&result);
if (iBase_SUCCESS == result) {
printf("Shouldn't have gotten mesh sets in relate_geom_mesh_test.\n");
return 0;
/* restore the relation, since we need it later */
iRel_setEntArrSetArrRelation(assoc, pair, gentities, gentities_size,
out_mentities, out_mentities_size, &result);
printf("Failed to restore relation in relate_geom_mesh_test.\n");
return 0;
/* get related geometry entities for mesh entity sets */
&result);
printf("Failed to get mesh entities in relate_geom_mesh_test.\n");
return 0;
printf("Number of input mesh entity sets and output geom entities should be same\n");
return 0;
return 1;
