lasso
Functions | |
| void | test_both () |
| void | test_change_to_both () |
| void | test_change_to_set () |
| int | main () |
Variables | |
| iGeom_Instance | geom |
| iMesh_Instance | mesh |
| iRel_Instance | rel |
| iBase_EntityHandle | geom_ent |
| iBase_EntityHandle | mesh_ents [4] |
| iBase_EntitySetHandle | mesh_set |
| int main | ( | ) |
Definition at line 95 of file test_both.cpp.
int err;
int num_fail = 0;
iGeom_newGeom(0, &geom, &err, 0);
iMesh_newMesh(0, &mesh, &err, 0);
iRel_create(0, &rel, &err, 0);
iGeom_createBrick(geom, 2, 2, 2, &geom_ent, &err);
double coords[] = {
0, 0, 0,
0, 1, 0,
1, 1, 0,
1, 0, 0,
iBase_EntityHandle *mesh_ents_ptr = mesh_ents;
int mesh_ents_alloc = 4, mesh_ents_size;
iMesh_createVtxArr(mesh, 4, iBase_INTERLEAVED, coords, 12,
&mesh_ents_ptr, &mesh_ents_alloc, &mesh_ents_size, &err);
iMesh_createEntSet(mesh, false, &mesh_set, &err);
iMesh_addEntArrToSet(mesh, mesh_ents, mesh_ents_size, mesh_set, &err);
num_fail += RUN_TEST(test_both);
num_fail += RUN_TEST(test_change_to_both);
num_fail += RUN_TEST(test_change_to_set);
iRel_destroy(rel, &err);
iMesh_dtor(mesh, &err);
iGeom_dtor(geom, &err);
return num_fail;
| void test_both | ( | ) |
Definition at line 17 of file test_both.cpp.
int err;
iRel_PairHandle pair;
iRel_createPair(rel, geom, iRel_ENTITY, iRel_IGEOM_IFACE, iRel_ACTIVE,
mesh, iRel_BOTH, iRel_IMESH_IFACE, iRel_ACTIVE,
&pair, &err);
CHECK_ERR(err);
iRel_setEntSetRelation(rel, pair, geom_ent, mesh_set, &err);
CHECK_ERR(err);
iBase_EntityHandle *related_ents = NULL;
int related_ents_alloc = 0, related_ents_size;
iRel_getEntArrEntArrRelation(rel, pair, mesh_ents, 4, 1,
&related_ents, &related_ents_alloc,
&related_ents_size, &err);
CHECK_ERR(err);
for(int i = 0; i < related_ents_size; i++)
CHECK_EQUAL(related_ents[i], geom_ent);
free(related_ents);
| void test_change_to_both | ( | ) |
Definition at line 43 of file test_both.cpp.
int err;
mesh, iRel_SET, iRel_IMESH_IFACE, iRel_ACTIVE,
&pair, &err);
CHECK_ERR(err);
CHECK_ERR(err);
iRel_changePairType(rel, pair, iRel_ENTITY, iRel_BOTH, &err);
CHECK_ERR(err);
CHECK_ERR(err);
free(related_ents);
| void test_change_to_set | ( | ) |
Definition at line 72 of file test_both.cpp.
int err;
&pair, &err);
CHECK_ERR(err);
CHECK_ERR(err);
iRel_changePairType(rel, pair, iRel_ENTITY, iRel_SET, &err);
CHECK_ERR(err);
for(int i = 0; i < 4; i++) {
iBase_EntityHandle related_ent;
iRel_getEntEntRelation(rel, pair, mesh_ents[i], 1, &related_ent, &err);
CHECK(err != iBase_SUCCESS);
| iGeom_Instance geom |
Definition at line 9 of file test_both.cpp.
| iBase_EntityHandle geom_ent |
Definition at line 13 of file test_both.cpp.
| iMesh_Instance mesh |
Definition at line 10 of file test_both.cpp.
| iBase_EntityHandle mesh_ents[4] |
Definition at line 14 of file test_both.cpp.
| iBase_EntitySetHandle mesh_set |
Definition at line 15 of file test_both.cpp.
Definition at line 11 of file test_both.cpp.
