lasso
00001 #include "iGeom.h" 00002 #include "iMesh.h" 00003 #include "iRel.h" 00004 00005 #include "TestUtil.hpp" 00006 00007 #include <cstdlib> 00008 00009 iGeom_Instance geom; 00010 iMesh_Instance mesh; 00011 iRel_Instance rel; 00012 00013 void test_initial_inactive() 00014 { 00015 int err; 00016 iRel_PairHandle pair; 00017 00018 iRel_createPair(rel, geom, iRel_SET, iRel_IGEOM_IFACE, iRel_INACTIVE, 00019 mesh, iRel_SET, iRel_IMESH_IFACE, iRel_ACTIVE, 00020 &pair, &err); 00021 CHECK_ERR(err); 00022 00023 iBase_EntitySetHandle geom_set; 00024 iGeom_createEntSet(geom, false, &geom_set, &err); 00025 CHECK_ERR(err); 00026 00027 iBase_EntitySetHandle mesh_set; 00028 iMesh_createEntSet(mesh, false, &mesh_set, &err); 00029 CHECK_ERR(err); 00030 00031 iRel_setSetSetRelation(rel, pair, geom_set, mesh_set, &err); 00032 CHECK_ERR(err); 00033 00034 iBase_EntitySetHandle related_set; 00035 iRel_getSetSetRelation(rel, pair, mesh_set, 1, &related_set, &err); 00036 CHECK_ERR(err); 00037 CHECK_EQUAL(related_set, geom_set); 00038 00039 iRel_getSetSetRelation(rel, pair, geom_set, 0, &related_set, &err); 00040 CHECK(err != iBase_SUCCESS); 00041 00042 iRel_changePairStatus(rel, pair, iRel_ACTIVE, iRel_ACTIVE, &err); 00043 CHECK_ERR(err); 00044 00045 iRel_getSetSetRelation(rel, pair, geom_set, 0, &related_set, &err); 00046 CHECK_ERR(err); 00047 CHECK_EQUAL(related_set, mesh_set); 00048 00049 } 00050 00051 void test_initial_notexist() 00052 { 00053 int err; 00054 iRel_PairHandle pair; 00055 00056 iRel_createPair(rel, geom, iRel_SET, iRel_IGEOM_IFACE, iRel_NOTEXIST, 00057 mesh, iRel_SET, iRel_IMESH_IFACE, iRel_ACTIVE, 00058 &pair, &err); 00059 CHECK_ERR(err); 00060 00061 iBase_EntitySetHandle geom_set; 00062 iGeom_createEntSet(geom, false, &geom_set, &err); 00063 CHECK_ERR(err); 00064 00065 iBase_EntitySetHandle mesh_set; 00066 iMesh_createEntSet(mesh, false, &mesh_set, &err); 00067 CHECK_ERR(err); 00068 00069 iRel_setSetSetRelation(rel, pair, geom_set, mesh_set, &err); 00070 CHECK_ERR(err); 00071 00072 iBase_EntitySetHandle related_set; 00073 iRel_getSetSetRelation(rel, pair, mesh_set, 1, &related_set, &err); 00074 CHECK_ERR(err); 00075 CHECK_EQUAL(related_set, geom_set); 00076 00077 iRel_getSetSetRelation(rel, pair, geom_set, 0, &related_set, &err); 00078 CHECK(err != iBase_SUCCESS); 00079 00080 iRel_changePairStatus(rel, pair, iRel_ACTIVE, iRel_ACTIVE, &err); 00081 CHECK_ERR(err); 00082 00083 iRel_getSetSetRelation(rel, pair, geom_set, 0, &related_set, &err); 00084 CHECK_ERR(err); 00085 CHECK_EQUAL(related_set, mesh_set); 00086 00087 } 00088 00089 int main() 00090 { 00091 int err; 00092 int num_fail = 0; 00093 00094 iGeom_newGeom(0, &geom, &err, 0); 00095 iMesh_newMesh(0, &mesh, &err, 0); 00096 iRel_create(0, &rel, &err, 0); 00097 00098 num_fail += RUN_TEST(test_initial_inactive); 00099 num_fail += RUN_TEST(test_initial_notexist); 00100 00101 iRel_destroy(rel, &err); 00102 iMesh_dtor(mesh, &err); 00103 iGeom_dtor(geom, &err); 00104 00105 return num_fail; 00106 }
