MeshKit
1.0
00001 /* 00002 * AF2Algorithm.hpp 00003 * 00004 * \brief An AF2Algorithm provides the capability to execute 00005 * a two-dimensional advancing front algorithm. 00006 * 00007 * An AF2Algorithm is an object that executes a two-dimensional advancing 00008 * front algorithm. It is constructed with a list of rules. When the 00009 * execute method is called, AF2Algorithm enters a loop attempting to 00010 * advance the front until the front is empty, which means the algorithm 00011 * has completed successfully, or failure termination criteria have 00012 * been satisfied. In the loop, the algorithm selects a baseline edge 00013 * on the current advancing front. The neighborhood surrounding that 00014 * edge is transformed to a two-dimensional coordinate space, and 00015 * the algorithm attempts to apply each of the rules to that baseline 00016 * edge in the two-dimensional coordinate space. If a rule can be 00017 * applied, the best rule is chosen and the front is advanced. If no 00018 * rule can be applied, the baseline edge has its quality decreased 00019 * so that the next time, if any, that the same baseline edge is chosen, 00020 * there will be more flexibility in what constitutes a successful 00021 * application of a rule. 00022 * 00023 * The execute method returns an AF2Algorithm result that is either 00024 * successful or unsuccessful. If it is successful, it contains lists 00025 * of all points and faces that are part of the result mesh. 00026 */ 00027 #ifndef AF2ALGORITHM_HPP 00028 #define AF2ALGORITHM_HPP 00029 00030 // C++ 00031 #include <list> 00032 #include <map> 00033 00034 // MOAB 00035 #include "moab/Types.hpp" 00036 00037 // MeshKit 00038 #include "meshkit/AF2AlgorithmResult.hpp" 00039 #include "meshkit/AF2LocalTransformMaker.hpp" 00040 #include "meshkit/AF2Front.hpp" 00041 #include "meshkit/AF2Neighborhood.hpp" 00042 #include "meshkit/AF2Point2D.hpp" 00043 #include "meshkit/AF2Point3D.hpp" 00044 #include "meshkit/AF2Polygon2D.hpp" 00045 #include "meshkit/AF2Polygon3D.hpp" 00046 #include "meshkit/AF2Rule.hpp" 00047 00048 class AF2Algorithm 00049 { 00050 private: 00051 00052 const std::list<const AF2Rule*> ruleList; 00053 00057 void initFront(AF2Front & front, std::list<AF2Point3D*> & pntList, 00058 unsigned long & pntId, 00059 const double* coords, unsigned int numPoints, 00060 const unsigned int* edges, unsigned int numEdges, 00061 const moab::EntityHandle* vertexHandles) const; 00062 00066 void processNewFace(const AF2Polygon2D* newFace2D, 00067 AF2Neighborhood* & ngbhd, 00068 std::map<const AF2Point2D*, AF2Point3D*> & newPointsMap, 00069 std::list<const AF2Polygon3D*> & allFaces, AF2Front & front) const; 00070 00074 void processNewPoint(const AF2Point2D* newPoint2D, 00075 unsigned long & pntId, AF2Neighborhood* & ngbhd, 00076 std::map<const AF2Point2D*, AF2Point3D*> & newPointsMap, 00077 std::list<AF2Point3D*> & allPoints, AF2Front & front) const; 00078 00082 void release(std::list<AF2Point3D*> & allPoints, 00083 std::list<const AF2Polygon3D*> & allFaces) const; 00084 00089 void output_intermediate_result (std::list<AF2Point3D*> & allPoints, 00090 std::list<const AF2Polygon3D*> & allFaces,int face, int step) const; 00091 00092 public: 00093 00108 AF2Algorithm(const std::list<const AF2Rule*> & ruleListArg); 00109 00113 ~AF2Algorithm(); 00114 00121 AF2Algorithm(const AF2Algorithm & toCopy); 00122 00129 AF2Algorithm& operator=(const AF2Algorithm & rhs); 00130 00194 AF2AlgorithmResult* execute( 00195 const AF2LocalTransformMaker* const & transformMaker, 00196 const double* coords, unsigned int numPoints, 00197 const unsigned int* edges, unsigned int numEdges, 00198 const moab::EntityHandle* vertexHandles = NULL, int debug = 0) const; 00199 }; 00200 00201 #endif
