MeshKit
1.0
00001 #include "meshkit/CESets.hpp" 00002 00003 #include <cassert> 00004 #include <cstdlib> 00005 #include <cstring> 00006 #include <iMesh_extensions.h> 00007 00008 #include <meshkit/Error.hpp> 00009 00010 namespace MeshKit { 00011 00012 CESets::~CESets() 00013 { 00014 std::vector<tag_data>::iterator i; 00015 for (i = tags_.begin(); i != tags_.end(); ++i) 00016 free(i->value); 00017 } 00018 00019 void CESets::add_tag(iMesh::TagHandle tag_handle, const char *value) 00020 { 00021 assert(tag_handle != NULL); 00022 char *tmp = NULL; 00023 00024 if (value) { 00025 int tag_size; 00026 IBERRCHK(mesh_->getTagSizeBytes(tag_handle, tag_size), *mesh_); 00027 00028 tmp = static_cast<char*>(malloc(tag_size)); 00029 memcpy(tmp, value, tag_size); 00030 } 00031 00032 tags_.push_back(tag_data(tag_handle, tmp)); 00033 } 00034 00035 void CESets::add_tag(const std::string &tag_name, const char *value) 00036 { 00037 iMesh::TagHandle tag_handle; 00038 IBERRCHK(mesh_->getTagHandle(tag_name.c_str(), tag_handle), *mesh_); 00039 add_tag(tag_handle, value); 00040 } 00041 00042 void CESets::update_tagged_sets() 00043 { 00044 int err; 00045 iMesh::EntitySetHandle root_set = mesh_->getRootSet(); 00046 00047 std::vector<tag_data>::const_iterator tag; 00048 for (tag = tags_.begin(); tag != tags_.end(); ++tag) { 00049 iMesh::EntitySetHandle *tmp_sets = NULL; 00050 int tmp_sets_alloc = 0, tmp_sets_size; 00051 iMesh_getEntSetsByTagsRec(mesh_->instance(), root_set, &tag->tag, 00052 (tag->value ? &tag->value : NULL), 1, false, 00053 &tmp_sets, &tmp_sets_alloc, &tmp_sets_size, &err); 00054 IBERRCHK(err, *mesh_); 00055 sets_.insert(tmp_sets, tmp_sets+tmp_sets_size); 00056 free(tmp_sets); 00057 } 00058 } 00059 00060 void link_expand_sets(const CESets &ce_sets, iMesh::TagHandle local_tag) 00061 { 00062 CESets::set_iterator set; 00063 for (set = ce_sets.sbegin(); set != ce_sets.send(); ++set) { 00064 IBERRCHK(ce_sets.imesh_instance()->setEntSetESHData(*set, local_tag, *set), 00065 *ce_sets.imesh_instance()); 00066 } 00067 } 00068 00078 static 00079 void get_copied_ents(iMesh *mesh, iMesh::EntitySetHandle set, 00080 iMesh::TagHandle local_tag, 00081 std::vector<iMesh::EntityHandle> &ents) 00082 { 00083 std::vector<iMesh::EntityHandle> tmp_ents; 00084 IBERRCHK(mesh->getEntities(set, iBase_ALL_TYPES, iMesh_ALL_TOPOLOGIES, 00085 tmp_ents), *mesh); 00086 00087 ents.reserve(tmp_ents.size()); 00088 00089 // get copied entities 00090 for (size_t i = 0; i < tmp_ents.size(); i++) { 00091 iMesh::EntityHandle eh_tag; 00092 iMesh::Error err = mesh->getEHData(tmp_ents[i], local_tag, eh_tag); 00093 if (err == iBase_SUCCESS && eh_tag) 00094 ents.push_back(eh_tag); 00095 } 00096 } 00097 00107 static 00108 void get_dest_set(iMesh *mesh, iMesh::TagHandle local_tag, 00109 iMesh::EntitySetHandle src, iMesh::EntitySetHandle &dest) 00110 { 00111 iMesh::Error err; 00112 00113 err = mesh->getEntSetESHData(src, local_tag, dest); 00114 00115 if (err != iBase_SUCCESS) { 00116 IBERRCHK(mesh->createEntSet(false, dest), *mesh); 00117 IBERRCHK(mesh->setEntSetESHData(src, local_tag, dest), *mesh); 00118 } 00119 } 00120 00133 static 00134 void process_ce_subsets(iMesh *mesh, iMesh::EntitySetHandle src, 00135 iMesh::EntitySetHandle current, 00136 const std::set<iMesh::EntitySetHandle> &cesets, 00137 iMesh::TagHandle local_tag) 00138 { 00139 iMesh::EntitySetHandle dest; 00140 00141 // First, add entities directly contained in this set. 00142 std::vector<iMesh::EntityHandle> tmp_tags; 00143 get_copied_ents(mesh, current, local_tag, tmp_tags); 00144 00145 if (!tmp_tags.empty()) { 00146 get_dest_set(mesh, local_tag, src, dest); 00147 IBERRCHK(mesh->addEntArrToSet(&tmp_tags[0], tmp_tags.size(), dest), *mesh); 00148 } 00149 00150 // Next, start looking at children. 00151 std::vector<iMesh::EntitySetHandle> children; 00152 IBERRCHK(mesh->getEntSets(current, 0, children), *mesh); 00153 00154 for (size_t i = 0; i < children.size(); i++) { 00155 00156 // If this child set is one of our cesets, add just the set... 00157 if (cesets.find(children[i]) != cesets.end()) { 00158 get_dest_set(mesh, local_tag, src, dest); 00159 if (src == dest) continue; 00160 00161 IBERRCHK(mesh->addEntSet(children[i], dest), *mesh); 00162 } 00163 00164 // ... otherwise, add the entities and recurse into the next level of 00165 // children. 00166 else { 00167 process_ce_subsets(mesh, src, children[i], cesets, local_tag); 00168 } 00169 } 00170 } 00171 00172 // xxx - still need to do unique tags 00173 // - for each unique tag 00174 // . if this set has the tag, add/append to get unique value 00175 void process_ce_sets(iMesh *mesh, 00176 const std::set<iMesh::EntitySetHandle> &cesets, 00177 iMesh::TagHandle local_tag) 00178 { 00179 std::set<iMesh::EntitySetHandle>::const_iterator src; 00180 for (src = cesets.begin(); src != cesets.end(); ++src) 00181 process_ce_subsets(mesh, *src, *src, cesets, local_tag); 00182 } 00183 00184 void tag_copy_sets(iMesh *mesh, iMesh::TagHandle copyTag, 00185 const std::set<iMesh::EntitySetHandle> ©Sets, 00186 iMesh::TagHandle tag, const char *tag_val) 00187 { 00188 iMesh::Error err; 00189 00190 int tag_size; 00191 IBERRCHK(mesh->getTagSizeBytes(tag, tag_size), *mesh); 00192 00193 // allocate temp space for tag value 00194 std::vector<char> value(tag_size); 00195 00196 // for each orig copy set with this tag, copy it to its copy 00197 std::set<iMesh::EntitySetHandle>::iterator set; 00198 for (set = copySets.begin(); set != copySets.end(); ++set) { 00199 // get the tag value 00200 err = mesh->getEntSetData(*set, tag, &value[0]); 00201 if (err == iBase_TAG_NOT_FOUND) 00202 continue; 00203 IBERRCHK(err, *mesh); 00204 00205 // compare to tag value if necessary 00206 if (tag_val && strncmp(tag_val, &value[0], tag_size)) 00207 continue; 00208 00209 // if we got here, we should set the tag on the copy; get the copy 00210 iMesh::EntitySetHandle copy_set; 00211 err = mesh->getEntSetESHData(*set, copyTag, copy_set); 00212 if (err == iBase_TAG_NOT_FOUND) 00213 continue; 00214 IBERRCHK(err, *mesh); 00215 00216 if (copy_set != *set) 00217 IBERRCHK(mesh->setEntSetData(copy_set, tag, &value[0]), *mesh); 00218 } 00219 } 00220 00221 void tag_copy_sets(const CESets &ce_sets, iMesh::TagHandle local_tag, 00222 iMesh::TagHandle copy_tag) 00223 { 00224 // set the copy tag on all copied sets 00225 for (CESets::const_set_iterator set = ce_sets.sbegin(); set != ce_sets.send(); 00226 ++set) { 00227 iMesh::Error err; 00228 iMesh::EntityHandle eh; 00229 err = ce_sets.imesh_instance()->getEntSetEHData(*set, local_tag, eh); 00230 if (err == iBase_SUCCESS) { 00231 IBERRCHK(ce_sets.imesh_instance()->setEntSetEHData(*set, copy_tag, eh), 00232 *ce_sets.imesh_instance()); 00233 } 00234 } 00235 00236 // tag the newly-created sets 00237 for (CESets::const_tag_iterator tag = ce_sets.tbegin(); 00238 tag != ce_sets.tend(); ++tag) { 00239 tag_copy_sets(ce_sets.imesh_instance(), copy_tag, ce_sets.sets(), 00240 tag->tag, tag->value); 00241 } 00242 } 00243 00244 } // namespace MeshKit
