MeshKit
1.0
00001 // IASolver.cpp 00002 // Interval Assignment for Meshkit 00003 // 00004 #include "meshkit/IASolver.hpp" 00005 #include "meshkit/IPData.hpp" 00006 // #include "meshkit/IAMilp.hpp" 00007 #include "meshkit/IASolverRelaxed.hpp" 00008 #include "meshkit/IASolverInt.hpp" 00009 00010 #include <cstdlib> 00011 #include <stdio.h> 00012 #include <math.h> 00013 #include <limits.h> 00014 00015 // timing tests 00016 #include <time.h> //zzyk 00017 #include <iostream> 00018 00019 namespace MeshKit 00020 { 00021 00022 IASolver::IASolver(IAData *ia_data_ptr, IASolution *ia_solution_ptr) 00023 : IASolverToolInt( ia_data_ptr, ia_solution_ptr ), 00024 debugging(true) 00025 // debugging(false) 00026 {} 00027 00029 IASolver::~IASolver() {} 00030 00031 00032 bool IASolver::solve_relaxed() 00033 { 00034 IASolverRelaxed relaxed(ia_data(), ia_solution(), !debugging); 00035 bool succeeded=relaxed.solve(); 00036 return succeeded; 00037 } 00038 00039 00040 /* milp solution is too slow 00041 bool IASolver::solve_int() 00042 { 00043 IAMilp milp(this,this); 00044 bool succeeded=milp.solve(); 00045 return succeeded; 00046 } 00047 */ 00048 00049 bool IASolver::solve_int() 00050 { 00051 // set relaxed solution to this's solution (from solve_relaxed) 00052 IASolverInt solver_int(ia_data(), ia_solution(), !debugging); 00053 bool succeeded=solver_int.solve(); 00054 return succeeded; 00055 } 00056 00057 bool IASolver::solve_even() 00058 { 00059 bool succeeded=true; 00060 return succeeded; 00061 } 00062 00063 00064 bool IASolver::solve() 00065 { 00066 00067 if (debugging) 00068 { 00069 printf("Solving subproblem %p\n", this); 00070 print_problem(); 00071 } 00072 00073 // todo: subdivide problem into independent sub-problems for speed 00074 //zzyk 00075 clock_t t = clock(); 00076 bool relaxed_succeeded = solve_relaxed(); 00077 print_solution(); 00078 00079 t = clock()-t; 00080 float seconds = ((float)t)/CLOCKS_PER_SEC; 00081 std::cout << "relaxed solution " << ((relaxed_succeeded) ? "succeeded" : "failed") << " took " << seconds << " seconds" << std::endl; 00082 00083 t = clock(); 00084 bool int_succeeded = relaxed_succeeded && solve_int(); 00085 t = clock()-t; 00086 seconds = ((float)t)/CLOCKS_PER_SEC; 00087 std::cout << "integer solution " << ((int_succeeded) ? "succeeded" : "failed") << " took " << seconds << " seconds" << std::endl; 00088 00089 bool even_succeeded = int_succeeded && solve_even(); 00090 00091 if (debugging) 00092 { 00093 printf("==========IA summary:\n"); 00094 if (relaxed_succeeded) 00095 { 00096 printf(" relaxed succeeded\n"); 00097 if (int_succeeded) 00098 { 00099 printf(" integer succeeded\n"); 00100 if (even_succeeded) 00101 { 00102 printf(" even succeeded\n"); 00103 } 00104 else 00105 { 00106 printf(" even failed\n"); 00107 } 00108 } 00109 else 00110 { 00111 printf(" integer failed\n"); 00112 } 00113 } 00114 else 00115 { 00116 printf(" relaxed failed\n"); 00117 } 00118 print_solution(); 00119 } 00120 00121 return even_succeeded; 00122 } 00123 00124 00125 } // namespace MeshKit
