MeshKit  1.0
IASolverToolInt Class Reference
#include <IASolverToolInt.hpp>
Inheritance diagram for IASolverToolInt:
List of all members.
Public Member Functions
 IASolverToolInt ()
 IASolverToolInt (const bool debugging_set)
 IASolverToolInt (const IAData *ia_data, IASolution *ia_solution, bool debugging_set=false)
virtual ~IASolverToolInt ()
IPData * ip_data ()
void ip_data (IPData *set_data)
virtual void set_debug (const bool debugging_set)
void round_solution ()
bool solution_is_integer (const bool print_non_integer=false)
void get_frac (double x, int &integer, double &frac) const
double get_xl (int i) const
double get_xh (int i) const
double get_km (int i, double x) const
double get_kp (int i, double x) const
void get_km (int i, double x, int &km_integer, double &km_frac) const
void get_kp (int i, double x, int &kp_integer, double &kp_frac) const
bool randomize_weights_of_non_int (IAWeights *weights, const double rand_factor)
Protected Attributes
IPData * ipData
bool debuggingToolInt
Detailed Description
Definition at line 15 of file IASolverToolInt.hpp.
default constructor
Definition at line 16 of file IASolverToolInt.cpp.
IASolverToolInt ( const bool  debugging_set)
Definition at line 26 of file IASolverToolInt.cpp.
IASolverToolInt ( const IAData *  ia_data,
IASolution *  ia_solution,
bool  debugging_set = false
Definition at line 21 of file IASolverToolInt.cpp.
~IASolverToolInt ( ) [virtual]
default destructor
Definition at line 32 of file IASolverToolInt.cpp.
Member Function Documentation
void get_frac ( double  x,
int &  integer,
double &  frac
) const
Definition at line 115 of file IASolverToolInt.cpp.
double get_km ( int  i,
double  x
) const
Definition at line 134 of file IASolverToolInt.cpp.
void get_km ( int  i,
double  x,
int &  km_integer,
double &  km_frac
) const
Definition at line 140 of file IASolverToolInt.cpp.
double get_kp ( int  i,
double  x
) const
Definition at line 145 of file IASolverToolInt.cpp.
void get_kp ( int  i,
double  x,
int &  kp_integer,
double &  kp_frac
) const
Definition at line 151 of file IASolverToolInt.cpp.
double get_xh ( int  i) const
Definition at line 129 of file IASolverToolInt.cpp.
double get_xl ( int  i) const
Definition at line 124 of file IASolverToolInt.cpp.
IPData* ip_data ( ) [inline]
Definition at line 28 of file IASolverToolInt.hpp.
void ip_data ( IPData *  set_data) [inline]
Definition at line 29 of file IASolverToolInt.hpp.
bool randomize_weights_of_non_int ( IAWeights *  weights,
Definition at line 158 of file IASolverToolInt.cpp.
void round_solution ( )
Reimplemented in IASolverBend.
Definition at line 38 of file IASolverToolInt.cpp.
virtual void set_debug ( const bool  debugging_set) [inline, virtual]
Reimplemented from IASolverTool.
Definition at line 30 of file IASolverToolInt.hpp.
bool solution_is_integer ( const bool  print_non_integer = false)
Definition at line 49 of file IASolverToolInt.cpp.
Member Data Documentation
bool debuggingToolInt [protected]
Definition at line 58 of file IASolverToolInt.hpp.
IPData* ipData [protected]
Definition at line 55 of file IASolverToolInt.hpp.
