MeshKit
1.0
#include <IASolverBend.hpp>
Public Member Functions | |
| IASolverBend (const IAData *ia_data_ptr, IASolution *relaxed_solution_ptr, const bool set_silent=true) | |
| virtual | ~IASolverBend () |
| bool | solve () |
Private Member Functions | |
| void | initialize_ip_bends () |
| bool | update_ip_bends () |
| double | raw_weight (const double g, double xlit, double xbig) |
| void | merge_tilts (IPBend::TiltVec &tilts) |
| void | tilt_weight (const IPBend::TiltVec &tilts, const int tilt_direction, const double g, const double xlit, const double xbig, const int delta_direction, double &w) |
| bool | solve_nlp () |
| void | cleanup () |
| bool | round_solution () |
| void | add_bend_weights (unsigned int i) |
| double | f_x_value (double I_i, double x_i) const |
| double | fpow (double f) const |
| double | get_f_xl (int i) const |
| double | get_f_xh (int i) const |
| IASolverBend (const IASolverBend &) | |
| IASolverBend & | operator= (const IASolverBend &) |
Private Attributes | |
| bool | evenConstraintsActive |
| const bool | silent |
| const bool | debugging |
| IABendNlp * | myianlp |
| IPBendData | bendData |
| IAWeights | weights |
Definition at line 24 of file IASolverBend.hpp.
| IASolverBend | ( | const IAData * | ia_data_ptr, |
| IASolution * | relaxed_solution_ptr, | ||
| const bool | set_silent = true |
default constructor
Definition at line 20 of file IASolverBend.cpp.
| ~IASolverBend | ( | ) | [virtual] |
default destructor
Definition at line 32 of file IASolverBend.cpp.
| IASolverBend | ( | const IASolverBend & | ) | [private] |
| void add_bend_weights | ( | unsigned int | i | ) | [private] |
Definition at line 538 of file IASolverBend.cpp.
| void cleanup | ( | ) | [private] |
Definition at line 252 of file IASolverBend.cpp.
| double f_x_value | ( | double | I_i, |
| double | x_i | ||
| ) | const [private] |
Definition at line 261 of file IASolverBend.cpp.
| double fpow | ( | double | f | ) | const [private] |
Definition at line 267 of file IASolverBend.cpp.
| double get_f_xh | ( | int | i | ) | const [private] |
| double get_f_xl | ( | int | i | ) | const [private] |
| void initialize_ip_bends | ( | ) | [private] |
Definition at line 615 of file IASolverBend.cpp.
| void merge_tilts | ( | IPBend::TiltVec & | tilts | ) | [private] |
Definition at line 441 of file IASolverBend.cpp.
| IASolverBend& operator= | ( | const IASolverBend & | ) | [private] |
| double raw_weight | ( | const double | g, |
| double | xlit, | ||
| double | xbig | ||
| ) | [private] |
Definition at line 518 of file IASolverBend.cpp.
| bool round_solution | ( | ) | [private] |
Reimplemented from IASolverToolInt.
Definition at line 231 of file IASolverBend.cpp.
| bool solve | ( | ) |
Definition at line 965 of file IASolverBend.cpp.
| bool solve_nlp | ( | ) | [private] |
Definition at line 37 of file IASolverBend.cpp.
| void tilt_weight | ( | const IPBend::TiltVec & | tilts, |
| const int | tilt_direction, | ||
| const double | g, | ||
| const double | xlit, | ||
| const double | xbig, | ||
| const int | delta_direction, | ||
| double & | w | ||
| ) | [private] |
Definition at line 466 of file IASolverBend.cpp.
| bool update_ip_bends | ( | ) | [private] |
Definition at line 723 of file IASolverBend.cpp.
IPBendData bendData [private] |
Definition at line 80 of file IASolverBend.hpp.
const bool debugging [private] |
Definition at line 50 of file IASolverBend.hpp.
bool evenConstraintsActive [private] |
Definition at line 46 of file IASolverBend.hpp.
Definition at line 78 of file IASolverBend.hpp.
const bool silent [private] |
Definition at line 49 of file IASolverBend.hpp.
Definition at line 83 of file IASolverBend.hpp.
