MeshKit
1.0
#include <AF2RuleNewTriangle.hpp>
Public Member Functions | |
| AF2RuleNewTriangle (unsigned int firstIndex, unsigned int secondIndex, unsigned int thirdIndex) | |
| Constructor. | |
| unsigned int | getNumVertices () const |
| Get the number of vertices that the element this rule would create would have. | |
| unsigned int | getVertexIndex (unsigned int vtxNum) const |
| Get the index of one of the vertices of the element that the rule would create. | |
Private Attributes | |
| unsigned int | triVtxIndices [3] |
Definition at line 12 of file AF2RuleNewTriangle.hpp.
| AF2RuleNewTriangle | ( | unsigned int | firstIndex, |
| unsigned int | secondIndex, | ||
| unsigned int | thirdIndex | ||
Constructor.
The constructor requires arguments for the indices of the three vertices of the triangle that the rule would create. The indices must index into the list of vertices associated with whichever rules this AF2RuleNewTriangle is a member of. The list of vertices associated with the rule is the concatenation of the list of existing vertices in the rule and the list of new vertices that the rule would create.
| firstIndex | the index of a vertex of the triangle |
| secondIndex | the index of the next vertex of the triangle after the firstIndex traversing the vertices counterclockwise |
| thirdIndex | the index of the remaining vertex of the element |
Definition at line 6 of file AF2RuleNewTriangle.cpp.
| unsigned int getNumVertices | ( | ) | const [virtual] |
Implements AF2RuleNewFace.
Definition at line 14 of file AF2RuleNewTriangle.cpp.
| unsigned int getVertexIndex | ( | unsigned int | vtxNum | ) | const [virtual] |
Indices returned by this method index into the list of vertices associated with the rule, i.e., a list consisting of a list of the rule's existing vertices followed by a list of the new vertices that the rule would create. The numbering of the vertices of the face begins with 0, so the valid arguments to this method are 0 through n - 1, where n is the value returned from getNumVertices().
| vtxNum | the number of the vertex for which to get the index |
Definition at line 19 of file AF2RuleNewTriangle.cpp.
unsigned int triVtxIndices[3] [private] |
Definition at line 16 of file AF2RuleNewTriangle.hpp.
