MeshKit  1.0
MeshImporter Struct Reference
#include <Mesh.hpp>
List of all members.
Public Member Functions
Mesh * load (const string &fname, Mesh *m=NULL)
Static Public Attributes
static const int SIMPLE_FORMAT = 0
static const int OFF_FORMAT = 1
static const int OBJ_FORMAT = 2
static const int VTK_FORMAT = 3
static const int TRIANGLE_FORMAT = 4
static const int CUBIT_FORMAT = 5
Private Member Functions
void readTriNodes (const string &s)
void readTriEdges (const string &s)
void readTriFaces (const string &s)
int vtk_file (const string &s)
int off_file (const string &s)
int simple_file (const string &s)
int triangle_file (const string &s)
int xml_file (const string &s)
int cubit_file (const string &s)
Private Attributes
Mesh * mesh
std::map< int, int > global2local
Detailed Description
Definition at line 1454 of file Mesh.hpp.
Member Function Documentation
int cubit_file ( const string &  s) [private]
Definition at line 8 of file cubit_io.cpp.
Mesh* load ( const string &  fname,
Mesh *  m = NULL
) [inline]
Definition at line 1462 of file Mesh.hpp.
int off_file ( const string &  s) [private]
Definition at line 26 of file off_io.cpp.
void readTriEdges ( const string &  s) [private]
Definition at line 45 of file tri_io.cpp.
void readTriFaces ( const string &  s) [private]
Definition at line 76 of file tri_io.cpp.
void readTriNodes ( const string &  s) [private]
Definition at line 7 of file tri_io.cpp.
int simple_file ( const string &  s) [private]
Definition at line 84 of file mesh_io.cpp.
int triangle_file ( const string &  s) [private]
Definition at line 138 of file tri_io.cpp.
int vtk_file ( const string &  s) [private]
Definition at line 62 of file vtk_io.cpp.
int xml_file ( const string &  s) [private]
Definition at line 6 of file xml_io.cpp.
Member Data Documentation
const int CUBIT_FORMAT = 5 [static]
Definition at line 1460 of file Mesh.hpp.
std::map<int, int> global2local [private]
Definition at line 1499 of file Mesh.hpp.
Mesh* mesh [private]
Definition at line 1498 of file Mesh.hpp.
const int OBJ_FORMAT = 2 [static]
Definition at line 1457 of file Mesh.hpp.
const int OFF_FORMAT = 1 [static]
Definition at line 1456 of file Mesh.hpp.
const int SIMPLE_FORMAT = 0 [static]
Definition at line 1455 of file Mesh.hpp.
const int TRIANGLE_FORMAT = 4 [static]
Definition at line 1459 of file Mesh.hpp.
const int VTK_FORMAT = 3 [static]
Definition at line 1458 of file Mesh.hpp.
The documentation for this struct was generated from the following files:
